XBDRED-00-0000-000000501
    CREELED
    LED 照明 - 彩色 XLamp® XB-D 红色 625nm(620nm ~ 630nm) 1010(2525 公制)
XBDRED-00-0000-000000501 数据手册
Cree® XLamp® XB-D LEDs PRODUCT DESCRIPTION The XLamp® XB-D LED brings next‑generation performance, price and size to all LED lighting applications. The XB-D’s footprint enables smaller designs with densely packed arrays for better light mixing and concentration. FEATURES Table of Contents • Cree’s smallest lighting class LED: Characteristics........................................ 2 2.45 X 2.45 mm • XB-D white binned @ 85 °C; XB-D color binned @ 25 °C • Up to 136 lm/W in cool white (@ 85 °C, 350 mA) Flux Characteristics................................ 3 Relative Spectral Power Distribution..... 6 Relative Flux vs. Junction Temperature............................................ 7 Electrical Characteristics........................ 8 • Available in white, 80-minimum CRI Relative Flux vs. Current......................... 9 The XB-D shares common footprint and white, and 70-minimum CRI cool Relative Chromaticity vs. Current......... 10 uniform package design across all white white, royal blue, blue, green, amber, Relative Chromaticity vs. and color configurations, simplifying red-orange & red Temperature.......................................... 11 board and optical designs for many • 1 A maximum drive current Typical Spatial Distribution................... 11 LED systems. The XB-D is optimized to • Wide viewing angle: from 115° Thermal Design..................................... 12 dramatically lower system cost in any illumination application, from indoor and outdoor lighting to architectural and transportation lighting. (white) to 140° (red) • Reflow solderable - JEDEC J-STD‑020C compatible • Unlimited floor life at ≤ 30 °C/85% RH Reflow Soldering Characteristics......... 13 Notes..................................................... 14 Mechanical Dimensions....................... 16 Tape and Reel........................................ 18 Packaging.............................................. 19 • Electrically neutral thermal path • RoHS and REACh compliant • UL® recognized component www.cree.com/Xlamp (E349212) Copyright © 2011-2016 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and XLamp® are registered trademarks and the Cree logo is a trademark of Cree, Inc UL® and the UR logo are registered trademarks of UL LLC. Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 CLD-DS45 Rev 10E Product family data sheet XLamp ® XB-D LED Characteristics Characteristics Unit Thermal resistance, junction to solder point - white, royal blue, blue °C/W 6.5 Thermal resistance, junction to solder point - green °C/W 11 Thermal resistance, junction to solder point - amber °C/W 7 Thermal resistance, junction to solder point - red-orange, red Minimum Typical °C/W 5 Viewing angle (FWHM) - white degrees 115 Viewing angle (FWHM) - royal blue, blue, green degrees 135 Viewing angle (FWHM) - amber, red-orange, red degrees 140 Temperature coefficient of voltage - white mV/°C -2.5 Temperature coefficient of voltage - royal blue, blue, green mV/°C -3.3 Temperature coefficient of voltage - amber, red-orange, red mV/°C -2 ESD withstand voltage (HBM per Mil-Std-883D) - white, royal blue, blue, green V ESD classification (HBM per Mil-Std-883D) - amber, red-orange, red DC forward current Maximum 8000 Class 2 mA 1000 Reverse voltage V -5 Forward voltage (@ 350 mA, 85 °C) - white V 2.9 3.5 Forward voltage (@ 350 mA, 25 °C) - royal blue, blue V 3.1 3.7 Forward voltage (@ 350 mA, 25 °C) - green V 3.3 3.9 Forward voltage (@ 350 mA, 25 °C) - amber, red-orange, red V 2.25 2.6 LED junction temperature °C 150 Copyright © 2011-2016 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and XLamp® are registered trademarks and the Cree logo is a trademark of Cree, Inc UL® and the UR logo are registered trademarks of UL LLC. 2 XLamp ® XB-D LED Flux Characteristics - White (TJ = 85 °C) The following table provides several base order codes for XLamp XB-D LEDs. It is important to note that the base order codes listed here are a subset of the total available order codes for the product family. For more order codes, as well as a complete description of the ordercode nomenclature, please consult the XLamp XB-D LED Binning and Labeling document. Minimum Luminous Flux @ 350 mA CCT Range Color Minimum Maximum Cool White 5000 K 8300 K 70 CRI Minimum Cool White 5000 K 8300 K Neutral White 80 CRI Minimum White Warm White 3700 K 2600 K 2600 K 5000 K 6200 K 3700 K Calculated Minimum Luminous Flux (lm)** Order Code Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* 700 mA 1000 mA R3 122 139 210 271 XBDAWT-00-0000-000000F51 R2 114 130 196 253 XBDAWT-00-0000-000000E51 R3 122 139 210 271 XBDAWT-00-0000-00000BF51 R2 114 130 196 253 XBDAWT-00-0000-00000BE51 R2 114 130 196 253 XBDAWT-00-0000-00000LEE4 Q5 107 122 184 237 XBDAWT-00-0000-00000LDE4 Q4 100 114 172 222 XBDAWT-00-0000-00000LCE4 Q4 100 114 172 222 XBDAWT-00-0000-00000HCE7 Q3 93.9 107 162 208 XBDAWT-00-0000-00000HBE7 Q2 87.4 100 150 194 XBDAWT-00-0000-00000HAE7 Q4 100 114 172 222 XBDAWT-00-0000-00000LCE7 Q3 93.9 107 162 208 XBDAWT-00-0000-00000LBE7 Q2 87.4 100 150 194 XBDAWT-00-0000-00000LAE7 Notes: • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 14). • Typical CRI for Neutral White, 3700 K - 5000K CCT is 75. • Typical CRI for Warm White, 2600 K - 3700 K CCT is 80. • Minimum CRI for 70 CRI Minimum Cool White is 70. • Minimum CRI for 80 CRI Minimum White is 80. * Flux values @ 25 °C are calculated and are for reference only. ** Calculated flux values at 700 mA and 1000 mA are for 85 °C and are for reference only. Copyright © 2011-2016 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and XLamp® are registered trademarks and the Cree logo is a trademark of Cree, Inc UL® and the UR logo are registered trademarks of UL LLC. 3 XLamp ® XB-D LED Flux Characteristics - Color (TJ = 25 °C) The following tables provide several base order codes for XLamp XB-D LEDs. It is important to note that the base order codes listed here are a subset of the total available order codes for the product family. For more order codes, as well as a complete description of the ordercode nomenclature, please consult the XLamp XB-D LED Binning and Labeling document. Dominant Wavelength Range Minimum Color Group Royal Blue D36 DWL (nm) 450 Maximum DWL (nm) Group D57 465 Dominant Wavelength Range Minimum Color Group Blue B3 DWL (nm) 465 Maximum Group B6 DWL (nm) 485 Dominant Wavelength Range Color Minimum Group Green G2 DWL (nm) 520 Maximum Group G4 DWL (nm) 535 Dominant Wavelength Range Color Minimum Group Amber A2 DWL (nm) 585 Maximum Group A3 DWL (nm) 595 Minimum Radiant Flux (mW) @ 350 mA Order Code Group Flux (mW) 34 (N) 550 XBDROY-00-0000-000000N01 33 (M) 525 XBDROY-00-0000-000000M01 32 (L) 500 XBDROY-00-0000-000000L01 31 (K) 475 XBDROY-00-0000-000000K01 30 (J) 450 XBDROY-00-0000-000000J01 Minimum Luminous Flux (lm) @ 350 mA Order Code Group Flux (lm) M2 39.8 K3 35.2 XBDBLU-00-0000-000000Z01 K2 30.6 XBDBLU-00-0000-000000Y01 Minimum Luminous Flux (lm) @ 350 mA XBDBLU-00-0000-000000201 Order Code Group Flux (lm) Q5 107 XBDGRN-00-0000-000000D01 Q4 100 XBDGRN-00-0000-000000C01 Q3 93.9 XBDGRN-00-0000-000000B01 Q2 87.4 XBDGRN-00-0000-000000A01 Minimum Luminous Flux (lm) @ 350 mA Group Order Code Flux (lm) P3 73.9 XBDAMB-00-0000-000000801 P2 67.2 XBDAMB-00-0000-000000701 N4 62 XBDAMB-00-0000-000000601 N3 56.8 XBDAMB-00-0000-000000501 Copyright © 2011-2016 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and XLamp® are registered trademarks and the Cree logo is a trademark of Cree, Inc UL® and the UR logo are registered trademarks of UL LLC. 4 XLamp ® XB-D LED Flux Characteristics - Color (TJ = 25 °C) - Continued Dominant Wavelength Range Color Minimum DWL (nm) Group RedOrange O3 610 Maximum Group DWL (nm) O4 620 Dominant Wavelength Range Color Minimum Group Red R2 DWL (nm) 620 Maximum Group R3 DWL (nm) 630 Minimum Luminous Flux (lm) @ 350 mA Order Code Group Flux (lm) Q4 100 XBDRDO-00-0000-000000C01 Q3 93.9 XBDRDO-00-0000-000000B01 Q2 87.4 XBDRDO-00-0000-000000A01 P4 80.6 XBDRDO-00-0000-000000901 P3 73.9 XBDRDO-00-0000-000000801 Minimum Luminous Flux (lm) @ 350 mA Order Code Group Flux (lm) P2 67.2 XBDRED-00-0000-000000701 N4 62 XBDRED-00-0000-000000601 N3 56.8 XBDRED-00-0000-000000501 Note: Cree maintains a tolerance of ±7% on flux and power measurements and ±1 nm on dominant wavelength measurements.See the Measurements section (page 14). Copyright © 2011-2016 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and XLamp® are registered trademarks and the Cree logo is a trademark of Cree, Inc UL® and the UR logo are registered trademarks of UL LLC. 5 XLamp ® XB-D LED Relative Spectral Power Relative Spectral Power Distribution Relative Radiant Power (%) 100 80 5000 K - 10000 K CCT 60 3700 K - 5000 K CCT 2600 K - 3700 K CCT 40 20 0 380 430 480 530 580 630 680 730 780 Wavelength (nm) Relative Radiant Power (%) 100 80 Royal Blue Blue 60 Green Amber 40 Red-Orange Red 20 0 380 430 480 530 580 630 680 730 780 Wavelength (nm) Copyright © 2011-2016 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and XLamp® are registered trademarks and the Cree logo is a trademark of Cree, Inc UL® and the UR logo are registered trademarks of UL LLC. 6 XLamp ® XB-D LED Relative Flux Output vs. Junction Temperature Relative Flux vs. Junction Temperature (IF = 350 mA) Relative Luminous Flux (%) 120 100 White 80 Blue Green 60 Amber Red-Orange, Red 40 20 0 Relative Flux Output vs. Junction Temperature 25 50 75 100 125 150 Junction Temperature (ºC) royal blue Relative Radiant Flux (%) 120 100 80 60 Royal Blue 40 20 0 25 50 75 100 125 150 Junction Temperature (ºC) Copyright © 2011-2016 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and XLamp® are registered trademarks and the Cree logo is a trademark of Cree, Inc UL® and the UR logo are registered trademarks of UL LLC. 7 XLamp ® XB-D LED Electrical Characteristics (TJ = 85 °C) 1000 900 Forward Current (mA) 800 700 600 White 500 400 300 200 100 0 2.0 Electrical Characteristics (Tj = 25ºC) 2.5 3.0 3.5 4.0 Forward Voltage (V) Electrical Characteristics (TJ = 25 °C) 1000 900 Forward Current (mA) 800 700 600 Royal Blue, Blue 500 Green 400 Amber, Red-Orange, Red 300 200 100 0 2.0 2.5 3.0 3.5 4.0 Forward Voltage (V) Copyright © 2011-2016 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and XLamp® are registered trademarks and the Cree logo is a trademark of Cree, Inc UL® and the UR logo are registered trademarks of UL LLC. 8 XLamp ® XB-D LED Relative Flux vs. Current (TJ = 85 °C) 300 Relative Luminous Flux (%) 250 200 150 White 100 50 0 Relative Intensity vs. Current (Tj = 25ºC) Forward Current (mA) 0 100 200 300 400 500 600 700 800 900 1000 Relative Flux vs. Current (TJ = 25 °C) Relative Luminous Flux (%) 300 250 200 Blue Green 150 Amber Red-Orange, Red 100 50 0 0 100 200 300 400 500 600 700 800 900 1000 Forward Current (mA) Copyright © 2011-2016 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and XLamp® are registered trademarks and the Cree logo is a trademark of Cree, Inc UL® and the UR logo are registered trademarks of UL LLC. 9 Relative Intensity vs. Current (Tj = 25ºC) XLamp ® XB-D LED royal blue Relative Flux vs. Current (TJ = 25 °C) - Continued 300 Relative Radiant Flux (%) 250 200 Royal Blue 150 100 50 0 0 100 200 300 400 500 600 700 800 900 1000 Forward Current (mA) Relative Chromaticity Vs. Current, Relative Chromaticity vs. Current (WarmWW White) 0.020 T = 85 °C J 0.015 0.010 0.005 ΔCCx 0.000 ΔCCy -0.005 -0.010 -0.015 -0.020 0 100 200 300 400 500 600 700 800 900 1000 Current (mA) Copyright © 2011-2016 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and XLamp® are registered trademarks and the Cree logo is a trademark of Cree, Inc UL® and the UR logo are registered trademarks of UL LLC. 10 XLamp ® XB-D LED Relative Chromaticity vs. Temperature (Warm White) Relative Chromaticity Vs. Temperature WW 0.020 I = 350 mA F 0.015 0.010 0.005 ΔCCx 0.000 ΔCCy -0.005 -0.010 -0.015 -0.020 0 25 50 75 100 125 150 Tsp (°C) Typical Spatial Radiation Pattern Typical Spatial Distribution Relative Luminous Intensity (%) 100 80 60 White 40 Royal Blue, Blue, Green Amber, RedOrange, Red 20 -90 -70 -50 -30 -10 0 10 30 50 70 90 Angle (°) Copyright © 2011-2016 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and XLamp® are registered trademarks and the Cree logo is a trademark of Cree, Inc UL® and the UR logo are registered trademarks of UL LLC. 11 XLamp ® XB-D LED Thermal Design white Thermal royal blue, blue The maximum forward current is determined by the thermal resistance between the LED junction and ambient. It is crucial for the end product to be designed in a manner that minimizes the thermal resistance from the solder point to ambient in order to optimize lamp life and optical characteristics. 1200 1200 White Royal Blue, Blue 1000 Maximum Current (mA) Maximum Current (mA) 1000 800 600 400 Rj-a = 10°C/W 800 600 400 Rj-a = 10°C/W Rj-a = 15°C/W 200 Rj-a = 15°C/W 200 Rj-a = 20°C/W Rj-a = 20°C/W Rj-a = 25°C/W 0 green 0 20 40 Rj-a = 25°C/W 60 80 100 120 140 Ambient Temperature (ºC) 0 160 amber 40 60 80 100 120 140 160 120 140 160 Ambient Temperature (ºC) Amber Green 1000 Maximum Current (mA) 1000 Maximum Current (mA) 20 1200 1200 800 600 400 Rj-a = 15°C/W 200 800 600 400 Rj-a = 20°C/W 0 20 Rj-a = 10°C/W Rj-a = 15°C/W 200 Rj-a = 20°C/W Rj-a = 25°C/W Rj-a = 25°C/W 0 0 0 red-orange, red 40 60 80 100 120 140 160 0 20 40 60 80 100 Ambient Temperature (ºC) Ambient Temperature (ºC) 1200 Red-Orange, Red Maximum Current (mA) 1000 800 600 400 Rj-a = 10°C/W Rj-a = 15°C/W 200 Rj-a = 20°C/W Rj-a = 25°C/W 0 0 20 40 60 80 100 120 140 160 Ambient Temperature (ºC) Copyright © 2011-2016 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and XLamp® are registered trademarks and the Cree logo is a trademark of Cree, Inc UL® and the UR logo are registered trademarks of UL LLC. 12 XLamp ® XB-D LED Reflow Soldering Characteristics In testing, Cree has found XLamp XB-D LEDs to be compatible with JEDEC J-STD-020C, using the parameters listed below. As a general guideline, Cree recommends that users follow the recommended soldering profile provided by the manufacturer of the solder paste used. Note that this general guideline may not apply to all PCB designs and configurations of reflow soldering equipment. tP TP Critical Zone TL to TP Temperature Ramp-up TL tS Tsmax Tsmin Ramp-down ts Preheat 25 t 25˚C to Peak IPC/JEDEC J-STD-020C Time Profile Feature Average Ramp-Up Rate (Tsmax to Tp) Lead-Free Solder 1.2 °C/second Preheat: Temperature Min (Tsmin) 120 °C Preheat: Temperature Max (Tsmax) 170 °C Preheat: Time (tsmin to tsmax) Time Maintained Above: Temperature (TL) Time Maintained Above: Time (tL) Peak/Classification Temperature (Tp) 65-150 seconds 217 °C 45-90 seconds 235 - 245 °C Time Within 5 °C of Actual Peak Temperature (tp) 20-40 seconds Ramp-Down Rate 1 - 6 °C/second Time 25 °C to Peak Temperature 4 minutes max. Note: All temperatures refer to topside of the package, measured on the package body surface. Copyright © 2011-2016 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and XLamp® are registered trademarks and the Cree logo is a trademark of Cree, Inc UL® and the UR logo are registered trademarks of UL LLC. 13 XLamp ® XB-D LED Notes Measurements The luminous flux, radiant power, chromaticity and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree applies to ensure long-term reliability for XLamp LEDs and details of Cree’s pre-release qualification testing for XLamp LEDs. Lumen Maintenance Cree now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. Moisture Sensitivity Cree recommends keeping XLamp LEDs in the provided, resealable moisture-barrier packaging (MBP) until immediately prior to soldering. Unopened MBPs that contain XLamp LEDs do not need special storage for moisture sensitivity. Once the MBP is opened, XLamp XB-D LEDs may be stored as MSL 1 per JEDEC J-STD-033, meaning they have unlimited floor life in conditions of ≤ 30 ºC/85% relative humidity (RH). Regardless of storage condition, Cree recommends sealing any unsoldered LEDs in the original MBP. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree representative or from the Product Documentation sections of www.cree.com. REACh Compliance REACh substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree representative to insure you get the most up-to-date REACh SVHC Declaration. REACh banned substance information (REACh Article 67) is also available upon request. Copyright © 2011-2016 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and XLamp® are registered trademarks and the Cree logo is a trademark of Cree, Inc UL® and the UR logo are registered trademarks of UL LLC. 14 XLamp ® XB-D LED Notes - Continued UL® Recognized Component Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/ UL 8750. Vision Advisory WARNING: Do not look at exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. Copyright © 2011-2016 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and XLamp® are registered trademarks and the Cree logo is a trademark of Cree, Inc UL® and the UR logo are registered trademarks of UL LLC. 15 XLamp ® XB-D LED 6 5 6 5 4 NOTICE NOTICE CREE CONFIDENTIAL. THIS PLOT AND THE INFORMATION CREE CONFIDENTIAL. THIS PLOT AND THE INFORMATION CONTAINED WITHIN ARE THE PROPRIETARY AND CONTAINED WITHIN ARE THE PROPRIETARY AND CONFIDENTIAL CREE, INC. THIS PLOT CONFIDENTIAL INFORMATION OF INFORMATION CREE, INC. THISOF PLOT Mechanical Dimensions MAY NOT BE COPIED, REPRODUCED DISCLOSED TO ANY MAY NOT BE COPIED, REPRODUCED OR DISCLOSED TOOR ANY UNAUTHORIZED PERSON THE WITHOUT WRITTEN CONSENT UNAUTHORIZED PERSON THE WITHOUT WRITTEN CONSENT OF CREE INC. OF CREE INC. 4 3 Thermal vias, if present, are not shown on these drawings. All measurements are ±.13 mm unless otherwise indicated. D D 1.84 1.84 2.45 2.45 0.46 0.46 0.76 0.76 0.46 0.46 2.45 2.45 4 RMATION ATION N D S PLOT LOT ED ANY ANY TO TO ANY 4 1.63 1.63 2.286 4 3 3R1.09 3 R1.09 2 2 1 1 1 REVISONS REVISONS REVISONS 0.82 0.82 BYDATE DATE APP'D APP'D REV REVREV BY BY DATE APP'D DESCRIPTION DESCRIPTION DESCRIPTION 0.65 0.65 10/16/12 10/16/12 10/16/12 0.36DC DC 0.36 DC ADDED NOTCH TO BACKSIDE B B ADDED B ADDED NOTCH TO BACKSIDE NOTCH TO BACKSIDE 7/1/15 7/1/15 DC7/1/15 CORRECTED SOLDERPAD DIMENSION DC DC C C CORRECTED SOLDERPAD DIMENSION C CORRECTED SOLDERPAD DIMENSION 0.92 0.92 Side View 8/19/15 8/19/15 DC8/19/15 ADDED ALTERNATE VIEWS DC DC D D ADDED ADDED ALTERNATE VIEWS D ALTERNATE VIEWS C C 2 Top View PRIMARY PRIMARY 41.84 1.63 1.631.63 2.292.29 REFREF 2.29 REF 2.29 REF 2.292.29 REFREF D D D 0.46 0.460.46 76 0.760.76 0.46 0.460.46 2.29 2.29 0.36 0.36 B B 2.286 2.2862.286 0.92 Anode 2.29 2.29 0.39 0.39 REF 2.29 2.292.29 REF0.85 0.33REF 0.92 0.33 Anode 2.292.29 REFREF 0.85 2.29 REF Anode 0.85 0.82 0.820.82 65 0.650.65 2.29 0.36 0.360.36 2.29 2.29 Alternate Bottom View UN MI TO A RECOMMENDED STENCIL PATTERN RECOMMENDED STENCIL PATTERN RECOMMENDED PCB SOLDER PAD(HATCHED AREA IS OPENING) RECOMMENDED PCB SOLDER PAD (HATCHED AREA IS OPENING) TH THIRD ANGLE PROJECT FO 6 6 5 5 4 4 B B B 3 Copyright © 2011-2016 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and XLamp® are registered trademarks and the Cree logo is a trademark of Cree, Inc UL® and the UR logo are registered trademarks of UL LLC. 0.85 0.850.85 2.29 2.292.29 0 0.17 0.17 0.39 0.390.39 0.85 0.850.85 0.85 Alternate Bottom View ALTERNATIVE ALTERNATIVE ALTERNATIVE PRIMARY PRIMARY PRIMARY 2.29 2.292.29 0.25 0.85 Bottom View 0.85 C C 2.29 0.92 0.920.92 A C 16 S R1.09 R1.09 C 0.82 0.82 C 0.65 0.65 0.36 0.36 0.92 0.92 XLamp ® XB-D LED PRIMARY PRIMARY Mechanical Dimensions - Continued 2.29 2.29 2.29 2.29 0.36 0.36 B 0.92 0.92 B 0.39 0.39 0.33 0.33 0.85 0.85 0.85 0.85 2.29 2.29 2.29 2.29 0.85 0.85 0.25 0.25 A ALL DIM 0.17 0.17 A A Recommended Stencil Pattern (Hatched Area is Opening) Recommended PCB Solder Pad RECOMMENDED STENCIL PATTERN RECOMMENDED STENCIL PATTERN (HATCHED AREA IS OPENING) (HATCHED AREA IS OPENING) RECOMMENDED PCB SOLDER RECOMMENDED PCB SOLDER PAD PAD 6 6 5 5 4 4 UNLESS UNLESS OTHE DIME DIMENSION MILLIMEA MILLIMETERS TOLERA TOLERANCE U .XX ± .X. .XXX± .X . X° ± X°. ANGLE PROJECTION THIRDTHIRD ANGLE PROJECTION FOR SHE FOR SHEET ME .X ± .X 1 .XX ± .X. .XXX± .X . X° ± X°. SURFAC SURFACE FIN1 3 3 Copyright © 2011-2016 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and XLamp® are registered trademarks and the Cree logo is a trademark of Cree, Inc UL® and the UR logo are registered trademarks of UL LLC. 17 6 DETAIL B SCALE 2 : 1 5 4 NOTICE CREE CONFIDENTIAL. THIS PLOT AND THE INFORMATION CONTAINED WITHIN ARE THE PROPRIETARY AND CONFIDENTIAL INFORMATION OF CREE, INC. THIS PLOT MAY NOT BE COPIED, REPRODUCED OR DISCLOSED TO ANY UNAUTHORIZED PERSON WITHOUTTHE WRITTEN CONSENT OF CREE INC. 3 2 1 REVISONS REV A DESCRIPTION BY Released DC DATE APP'D 10/23/11 JL DC ® XLampDC XB-D LED B ADDED CATHODE AND ANODE NOTE 2/26/12 C CHANGED POCKET DIMS AND TOLERANCES 8/3/12 D D Tape and Reel All Cree carrier tapes conform to EIA-481D, Automated Component Handling Systems Standard. Except as noted, all dimensions in mm C 1.50 +.10/-.00 C 1.75 ±.10 4.00 ±.10 CATHODE SIDE 2.00 ±.10 B B 2.60+/-0.1mm 4° 1.5±.1 4.0±.1 12.00 Nominal 12.30 Max 8.0±.1 1.75±.10 10.25 ±.10 .30 ± .10 8.00 ±.10 B 2.5±.1 Cathode Side ANODE SIDE B 5.50 ±.10 1.00 ± .10 +.3 12.0 .0 Anode Side SECTION B-B (denoted by + and circle) 2.05 +/-0.1 2.60 +/-0.1 REFERENCE VENDOR PART NUMBER 020246 UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS AND AFTER FINISH. TOLERANCE UNLESS SPECIFIED: .XX ± .25 .XXX ± .125 X° ± .5 ° DATE DRAWN BY User Feed Direction A END THIRD ANGLE PROJECTION Notes: 1. 10 sprocket hole pitch cumulative tolerance ± 0.2mm FOR SHEET METAL PARTS ONLY .X ± 1.5 .XX ± .75 .XXX ± .25 X° ± .5 ° SURFACE FINISH: 6 5 Trailer 160mm (min) of empty pockets sealed with tape (20 pockets min.) 4 D. CRONIN DATE APPROVED DATE Phone (919) 313-5300 START TITLE Fax (919) 313-5558 A Carrier Tape, 2525 HEW MATERIAL SIZE FINAL PROTECTIVE FINISH SCALE 1.6 3 Loaded Pockets (1,000 Lamps) 4600 Silicon Drive Durham, N.C 27703 10/23/11 CHECK C REV. DRAWING NO. 4.000 2 2402-00020 SHEET C OF 1 /1 1 Leader 400mm (min) of empty pockets with at least 100mm sealed by tape (50 empty pockets min.) User Feed Direction Cover Tape Pocket Tape 13mm 7" Copyright © 2011-2016 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and XLamp® are registered trademarks and the Cree logo is a trademark of Cree, Inc UL® and the UR logo are registered trademarks of UL LLC. 18 XLamp ® XB-D LED Packaging Unpackaged Reel Vacuum-Sealed Vacuum-Sealed Moisture Barrier Bag Moisture Barrier Bag Label CREE Binwith Code Cree Bin & Barcode LabelLot # Code, Qty, Label with Cree Bin Code, Quantity, Reel ID Label with Cree Bin Label with Customer P/N, Qty,Qty, Lot #, Lot PO # # Code, Packaged Reel Patent Label Label with Customer Order Label with Cree Order Code, Code, Qty, Reel ID, PO # Quantity, Reel ID, PO # Label with Cree Bin Code, Quantity, Reel ID Boxed Reel Label with Cree Order Code, Quantity, Reel ID, PO # Label with Cree Bin Code, Quantity, Reel ID Patent Label (on bottom of box) Copyright © 2011-2016 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and XLamp® are registered trademarks and the Cree logo is a trademark of Cree, Inc UL® and the UR logo are registered trademarks of UL LLC. 19
XBDRED-00-0000-000000501 价格&库存
很抱歉,暂时无法提供与“XBDRED-00-0000-000000501”相匹配的价格&库存,您可以联系我们找货
