XREWHT-L1-0000-008A2
    CREELED
    LED-3P_9X7MM_SM
    LED 照明 XLamp® XR-E 白色,天然 4750K 3.3V 350mA 90° 3529(9073 裸露焊盘)
XREWHT-L1-0000-008A2 数据手册
PRODUCT FAMILY DATA SHEET XLamp® XR-E LED PRODUCT DESCRIPTION FEATURES TABLE OF CONTENTS The XLamp® XR-E LED is leading the LED • Available in white (2600 K to 10,000 K Characteristics................................................ 2 lighting revolution with its unprecedented Order Codes Suggested for New Designs..... 3 CCT) lighting-class brightness, efficacy, lifetime • Maximum drive current: up to 1000 mA Relative Spectral Power Distribution............. 6 and quality of light. These lighting-class • Maximum junction temperature: 150 °C Relative Flux vs. Junction Temperature......... 6 features enable the XLamp XR-E LED to Electrical Characteristics................................ 7 replace many traditional light sources and • Industry-leading JEDEC standard pre‑qualification testing Relative Flux vs. Current................................. 7 save money with energy‑efficient light and • Reflow solderable – JEDEC Typical Spatial Distribution............................. 8 long lifetimes. • J-STD-020C compatible Thermal design............................................... 8 • Electrically neutral thermal path Performance Groups - Brightness................. 9 • RoHS and REACH compliant Performance Groups - Chromaticity.............. 9 XLamp LEDs bring high performance and quality of light to a wide range of lighting • UL recognized component (E349212) Standard Chromaticity Regions Plotted on applications, color-changing the 1931 CIE Curve....................................... 11 lighting, portable and personal lighting, Bin and Order Code Formats........................ 12 outdoor lighting, indoor directional lighting, Reflow Soldering Characteristics................. 13 commercial lighting and emergency‑vehicle Notes............................................................. 14 lighting. Mechanical Dimensions............................... 16 ® including Tape and Reel................................................ 17 Packaging...................................................... 18 Appendix - Order Codes Not For New Designs.......................................................... 19 Cree LED / 4001 E. Hwy. 54, Suite 2000 / Durham, NC 27709 USA / +1.919.313.5330 / www.cree-led.com © 2006-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS5 REV 21 1 XLAMP ® XR-E LED CHARACTERISTICS Characteristics Unit Thermal Resistance, junction to solder point °C/W 5 degrees 90 mV/°C -1.3 Viewing Angle (FWHM) Temperature Coefficient of Voltage Minimum ESD Classification (HBM per Mil-Std-883D) Typical Maximum Class 2 DC Forward Current ≥ 5000 K mA 1000 DC Forward Current < 5000 K mA 700 DC Pulse Current (@ 1 kHz, 10% duty cycle) A 1.8 Reverse Voltage V 5 Forward Voltage (@ 350 mA) V 2.9 Forward Voltage (@ 700 mA) V 3.08 Forward Voltage (@ 1000 mA) ≥ 5000 K V 3.2 LED Junction Temperature °C © 2006-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 3.25 150 CLD-DS5 REV 21 2 XLAMP ® XR-E LED ORDER CODES SUGGESTED FOR NEW DESIGNS (TJ = 25 °C) The following tables list standard kit numbers and performance bins for XR-E white LEDs. Kit numbers completely describe an order code’s chromaticity regions and luminous flux range. For a complete description of the order-code nomenclature, please consult the Bin and Order Code Formats section (page 12). Minimum Luminous Flux (lm) @ 350 mA Group Chromaticity Regions Kit Number Order Code WA, WB, WC, WD, WE, WF, WG, WH, WJ, WK, WM, WN, WP 00G01 XREWHT-L1-0000-00G01 WC, WD, WF, WG 00G02 XREWHT-L1-0000-00G02 WC, WD, WF, WG, WH, WJ, WN, WP 00G03 XREWHT-L1-0000-00G03 WA, WB, WC, WD, WE, WF, WG, WH, WJ, WK, WM, WN, WP 00H01 XREWHT-L1-0000-00H01 Flux (lm) Cool White (5000 K – 10,000 K) R4 R5 S2 S3 130 139 148 156 WC, WD, WF, WG 00H02 XREWHT-L1-0000-00H02 WC, WD, WF, WG, WH, WJ, WN, WP 00H03 XREWHT-L1-0000-00H03 WA, WB, WC, WD, WE, WF, WG, WH, WJ, WK, WM, WN, WP 00J01 XREWHT-L1-0000-00J01 WC, WD, WF, WG 00J02 XREWHT-L1-0000-00J02 WC, WD, WF, WG, WH, WJ, WN, WP 00J03 XREWHT-L1-0000-00J03 WA, WB, WC, WD, WE, WF, WG, WH, WJ, WK, WM, WN, WP 00K01 XREWHT-L1-0000-00K01 WC, WD, WF, WG 00K02 XREWHT-L1-0000-00K02 WC, WD, WF, WG, WH, WJ, WN, WP 00K03 XREWHT-L1-0000-00K03 Notes: • • • • • For additional order codes NOT recommended for new designs please see the Appendix section starting on page 19. Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 14). XR-E LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity or DWL bin restrictions specified by the order code. Typical CRI for Cool White & Neutral White (3700 K – 10,000 K CCT) is 75. Typical CRI for Warm White (2600 K – 3700 K CCT) is 80. © 2006-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS5 REV 21 3 XLAMP ® XR-E LED ORDER CODES SUGGESTED FOR NEW DESIGNS (TJ = 25 °C) - CONTINUED Minimum Luminous Flux (lm) @ 350 mA Chromaticity Regions CCT Kit Number Order Code Group Flux (lm) P4 80.6 5C, 5D, 6A, 6B 3700 K 009F6 XREWHT-L1-0000-009F6 Q2 87.4 5C, 5D, 6A, 6B 3700 K 00AF6 XREWHT-L1-0000-00AF6 4C, 4D, 5A, 5B 4300 K 00BF5 XREWHT-L1-0000-00BF5 5A, 5B, 5C, 5D 4000 K 00BE5 XREWHT-L1-0000-00BE5 5C, 5D, 6A, 6B 3700 K 00BF6 XREWHT-L1-0000-00BF6 4C, 4D, 5A, 5B 4300 K 00CF5 XREWHT-L1-0000-00CF5 5A, 5B, 5C, 5D 4000 K 00CE5 XREWHT-L1-0000-00CE5 5C, 5D, 6A, 6B 3700 K 00CF6 XREWHT-L1-0000-00CF6 3C, 3D, 4A, 4B 4750 K 00DF4 XREWHT-L1-0000-00DF4 4A, 4B, 4C, 4D 4500 K 00DE4 XREWHT-L1-0000-00DE4 4C, 4D, 5A, 5B 4300 K 00DF5 XREWHT-L1-0000-00DF5 5A, 5B, 5C, 5D 4000 K 00DE5 XREWHT-L1-0000-00DE5 3C, 3D, 4A, 4B 4750 K 00EF4 XREWHT-L1-0000-00EF4 4A, 4B, 4C, 4D 4500 K 00EE4 XREWHT-L1-0000-00EE4 3A, 3B, 3C, 3D 5000 K 00FE3 XREWHT-L1-0000-00FE3 Neutral White (3700 K - 5000 K) Q3 Q4 Q5 R2 R3 93.9 100 107 114 122 3C, 3D, 4A, 4B 4750 K 00FF4 XREWHT-L1-0000-00FF4 4A, 4B, 4C, 4D 4500 K 00FE4 XREWHT-L1-0000-00FE4 R4 130 3A, 3B, 3C, 3D 5000 K 00GE3 XREWHT-L1-0000-00GE3 R5 139 3A, 3B, 3C, 3D 5000 K 00HE3 XREWHT-L1-0000-00HE3 S2 148 3A, 3B, 3C, 3D 5000 K 00JE3 XREWHT-L1-0000-00JE3 Notes: • • • • • For additional order codes NOT recommended for new designs please see the Appendix section starting on page 19. Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 14). XR-E LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity or DWL bin restrictions specified by the order code. Typical CRI for Cool White & Neutral White (3700 K – 10,000 K CCT) is 75. Typical CRI for Warm White (2600 K – 3700 K CCT) is 80. © 2006-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS5 REV 21 4 XLAMP ® XR-E LED ORDER CODES SUGGESTED FOR NEW DESIGNS (TJ = 25 °C) - CONTINUED COPY  Minimum Luminous Flux (lm) @ 350 mA Group Chromaticity Regions CCT Kit Number Order Code Flux (lm) Warm White (2600 K - 3700 K) P2 P3 P4 Q2 67.2 73.9 80.6 87.4 Q3 93.9 Q4 100 7C, 7D, 8A, 8B 2900 K 007F8 XREWHT-L1-0000-007F8 8A, 8B, 8C, 8D 2700 K 007E8 XREWHT-L1-0000-007E8 6C, 6D, 7A, 7B 3200 K 008F7 XREWHT-L1-0000-008F7 7A, 7B, 7C, 7D 3000 K 008E7 XREWHT-L1-0000-008E7 7C, 7D, 8A, 8B 2900 K 008F8 XREWHT-L1-0000-008F8 8A, 8B, 8C, 8D 2700 K 008E8 XREWHT-L1-0000-008E8 6A, 6B, 6C, 6D 3500 K 009E6 XREWHT-L1-0000-009E6 6C, 6D, 7A, 7B 3200 K 009F7 XREWHT-L1-0000-009F7 7A, 7B, 7C, 7D 3000 K 009E7 XREWHT-L1-0000-009E7 7C, 7D, 8A, 8B 2900 K 009F8 XREWHT-L1-0000-009F8 8A, 8B, 8C, 8D 2700 K 008E9 XREWHT-L1-0000-009E8 6A, 6B, 6C, 6D 3500 K 00AE6 XREWHT-L1-0000-00AE6 6C, 6D, 7A, 7B 3200 K 00AF7 XREWHT-L1-0000-00AF7 7A, 7B, 7C, 7D 3000 K 00AE7 XREWHT-L1-0000-00AE7 7C, 7D, 8A, 8B 2900 K 00AF8 XREWHT-L1-0000-00AF8 8A, 8B, 8C, 8D 2700 K 00AE9 XREWHT-L1-0000-00AE8 6A, 6B, 6C, 6D 3500 K 00BE6 XREWHT-L1-0000-00BE6 6C, 6D, 7A, 7B 3200 K 00BF7 XREWHT-L1-0000-00BF7 7A, 7B, 7C, 7D 3000 K 00BE7 XREWHT-L1-0000-00BE7 6A, 6B, 6C, 6D 3500 K 00CE6 XREWHT-L1-0000-00CE6 Notes: • • • • • For additional order codes NOT recommended for new designs please see the Appendix section starting on page 19. Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 14). XR-E LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity or DWL bin restrictions specified by the order code. Typical CRI for Cool White & Neutral White (3700 K – 10,000 K CCT) is 75. Typical CRI for Warm White (2600 K – 3700 K CCT) is 80. © 2006-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS5 REV 21 5 XLAMP ® XR-E LED Relative Spectral Power RELATIVE SPECTRAL POWER DISTRIBUTION 100% Relative Radiant Power 90% 80% 70% 60% 50% 5000 K - 10000 K CCT 40% 30% 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Relative Flux Output vs. Junction Temperature RELATIVE FLUX VS. JUNCTION TEMPERATURE (IF = 350 mA) 100% Relative Luminous Flux 90% 80% 70% 60% 50% 40% 30% 20% 10% 0% 25 50 75 100 125 150 Junction Temperature (°C) © 2006-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS5 REV 21 6 XLAMP ® XR-E LED ELECTRICAL CHARACTERISTICS (TJ = 25 ˚C) 1000 Forward Current (mA) 900 800 700 600 500 400 Thermal Design 300 200 100 0 0.0 1.0 2.0 3.0 4.0 5.0 Forward Voltage (V) Relative Intensity vs. Current (Tj = 25ºC) RELATIVE FLUX VS. CURRENT (TJ = 25 ˚C) Relative Luminous Flux 250% 200% 150% 100% 50% 0% 0 200 400 600 800 1000 Forward Current (mA) © 2006-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS5 REV 21 7 XLAMP ® XR-E LED Typical Spatial Radiation Pattern TYPICAL SPATIAL DISTRIBUTION 100% Relative Luminous Intensity 80% 60% 40% 20% -90 -70 -50 -30 0% -10 10 30 50 70 90 Angle (°) THERMAL DESIGN Thermal Design Cool White - 1A Neutral White - .7 A 800 1200 700 Maximum Current (mA) Maximum Current (mA) 1000 800 600 400 Rj-a = 10°C/W 600 500 400 300 Rj-a = 10°C/W 200 Rj-a = 15°C/W Rj-a = 15°C/W 200 Rj-a = 25°C/W 0 0 20 40 Rj-a = 25°C/W 100 Rj-a = 20°C/W 0 60 80 100 Ambient Temperature (°C) ≥ 5,000 K 120 140 160 Rj-a = 35°C/W 0 20 40 60 80 100 120 140 160 Ambient Temperature (°C) < 5,000 K © 2006-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS5 REV 21 8 XLAMP ® XR-E LED PERFORMANCE GROUPS - BRIGHTNESS XR-E LEDs are tested for luminous flux and placed into one of the following luminous‑lux groups: Group Minimum Luminous Flux @ 350 mA (lm) Maximum Luminous Flux @ 350 mA (lm) P2 67.2 73.9 P3 73.9 80.6 P4 80.6 87.4 Q2 87.4 93.9 Q3 93.9 100 Q4 100 107 Q5 107 114 R2 114 122 R3 122 130 R4 130 139 R5 139 148 S2 148 156 S3 156 164 S4 164 172 S5 172 180 S6 180 188 PERFORMANCE GROUPS - CHROMATICITY XR-E LEDs are tested for chromaticity and placed into one of the regions defined by the bounding coordinates below. Region WK WA WM x y .283 .284 .295 .297 .298 .288 .287 .292 .295 .297 .283 .284 .279 .295 .308 .311 .310 .300 .298 .288 Region x y .314 .355 .316 .332 .306 .322 .276 .301 .342 .306 .317 .319 .329 .330 .329 .318 .291 .318 .308 .297 .329 .345 .329 .330 .317 .319 .316 .332 WF WP WD © 2006-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS5 REV 21 9 XLAMP ® XR-E LED PERFORMANCE GROUPS - CHROMATICITY (CONTINUED) Region WB WE WN WC Region 3A 4A 5A 6A 7A 8A x y .3371 .3490 .3451 .3554 .3440 .3428 .3366 x y .306 .308 .295 .297 .292 .306 .301 .306 .292 .306 .287 .321 .308 .317 .318 .308 .310 .300 .316 .332 .317 .319 .308 .311 .306 .322 Region Region x y .322 .329 .369 .311 .329 .345 .316 .332 .314 .355 .342 .329 .330 .322 .329 .345 .346 .359 .344 .342 .311 .348 .384 .319 .346 .359 .329 .345 .329 .369 x y .3376 .3616 .3463 .3687 .3451 .3554 .3369 .3371 .3512 .3465 .3529 .3597 .3615 .3659 .3590 .3521 .3670 .3578 .3702 .3722 .3825 .3798 .3783 WG WJ WH x y .3463 .3687 x y .3451 .3554 .3551 .3760 .3533 .3620 .3533 .3620 .3515 .3490 .3451 .3487 .3554 .3440 .3428 .3529 .3597 .3548 .3736 .3615 .3659 .3590 .3521 .3641 .3804 .3615 .3659 .3641 .3804 .3615 .3659 .3736 .3874 .3702 .3722 .3702 .3722 .3670 .3702 .3722 .3578 .3825 .3798 .3783 .3646 .3736 .3874 .3869 .3958 .3869 .3958 .3825 .3798 .4006 .4044 .3950 .3646 .3825 .3875 .3798 .3950 .3875 .3898 .3716 .3889 .3690 .3941 .3848 .3941 .3848 .4080 .3916 .4017 .3751 .3996 .4015 .4146 .4089 .4080 .4080 .3916 .3916 .4146 .4089 .4299 .4165 .4221 .3984 .4017 .4147 .3751 .4080 .3916 .4221 .3984 .4147 .3814 .3814 .4221 .3984 .4342 .4028 .4259 .3853 .4221 .3984 .4342 .4028 .4299 .4165 .4430 .4212 .4342 .4028 .4430 .4212 .4562 .4260 .4465 .4259 .4071 .3853 .4342 .4028 .4465 .4071 .4373 .3893 .4373 .3893 .4465 .4071 .4582 .4099 .4483 .3919 .4465 .4071 .4562 .4260 .4687 .4289 .4582 .4099 .4582 .4099 .4687 .4289 .4813 .4319 .4700 .4126 .4483 .3919 .4582 .4099 .4700 .4126 .4593 .3944 3B 4B 5B 6B 7B 8B Region 3C 4C 5C 6C 7C 8C Region 3D 4D 5D 6D 7D 8D © 2006-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS5 REV 21 10 XLAMP ® XR-E LED STANDARD CHROMATICITY REGIONS PLOTTED ON THE 1931 CIE CURVE 0.40 5000 K 0.39 0.38 5700 K 0.37 WH 6350 K 0.36 BBL 7000 K 0.35 WG WJ CCy 0.34 WF WD 0.33 8300 K WE 0.32 WC 0.31 0.30 WP WN WB 10000 K WM WA 0.29 WK 0.28 0.27 0.26 0.28 0.27 0.31 0.30 0.29 0.33 0.32 0.35 0.34 0.36 CCx 0.45 0.44 2900 K 0.43 2600 K 3000 K 3200 K 0.42 3500 K 7B 4000 K 0.40 6C 4300 K 0.39 0.37 4B 3C 0.36 3B 3D 0.35 8D 7A 6D 5B 4C 8A 7D 5C 4750 K 5300 K 0.38 6B 4500 K 5000 K 8C 8B 7C 3700 K 0.41 CCy 2700 K 6A 5D ANSI C78.377A 5A 4D 4A 3A 0.34 0.33 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.32 CCx © 2006-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS5 REV 21 11 XLAMP ® XR-E LED BIN AND ORDER CODE FORMATS Bin codes and order codes are configured in the following manner: Order Code Bin Code Series XRE = XR-E Series XRE = XR-E Optical configuration (default = L1) Optical configuration (default = L1) Kit number Luminous flux group SSSCCC-BD-HHHH-NNNNN Internal code Internal code SSSCCC-BD-WW-FF-G-AA Color WHT = White Voltage performance group Chromaticity group Color WHT = White © 2006-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS5 REV 21 12 XLAMP ® XR-E LED REFLOW SOLDERING CHARACTERISTICS In testing, Cree LED has found XR-E LEDs to be compatible with JEDEC J-STD-020C, using the parameters listed below. As a general guideline, Cree LED recommends that users follow the recommended soldering profile provided by the manufacturer of the solder paste used, and therefore it is the lamp or luminaire manufacturer’s responsibility to determine applicable soldering requirements. Note that this general guideline may not apply to all PCB designs and configurations of reflow soldering equipment. tP TP Critical Zone TL to TP Temperature Ramp-up TL tL Tsmax Tsmin Ramp-down ts Preheat 25 t 25˚C to Peak IPC/JEDEC J-STD-020C Time Profile Feature Average Ramp-Up Rate (Tsmax to Tp) Lead-Free Solder 1.2 °C/second Preheat: Temperature Min (Tsmin) 120 °C Preheat: Temperature Max (Tsmax) 170 °C Preheat: Time (tsmin to tsmax) 65-150 seconds Time Maintained Above: Temperature (TL) Time Maintained Above: Time (tL) Peak/Classification Temperature (Tp) 217 °C 45-90 seconds 235 - 245 °C Time Within 5 °C of Actual Peak Temperature (tp) 20-40 seconds Ramp-Down Rate 1 - 6 °C/second Time 25 °C to Peak Temperature 4 minutes max. Note: All temperatures refer to topside of the package, measured on the package body surface. © 2006-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS5 REV 21 13 XLAMP ® XR-E LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Lumen Maintenance Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. Moisture Sensitivity Cree LED recommends keeping XLamp XR-E LEDs in the provided, resealable moisture-barrier packaging (MBP) until immediately prior to soldering. Unopened MBPs that contain XLamp LEDs do not need special storage for moisture sensitivity. Once the MBP is opened, XLamp XR-E LEDs should be handled and stored as MSL 4 per JEDEC J-STD-033, meaning they have limited exposure time before damage to the LED may occur during the soldering operation. The table on the right specifies the maximum exposure time in days depending on temperature and humidity conditions. LEDs with Temp. Maximum Percent Relative Humidity 30% 40% 50% 60% 70% 80% 90% 30 ºC 9 5 4 3 1 1 1 25 ºC 12 7 5 4 2 1 1 20 ºC 17 9 7 6 2 2 1 exposure time longer than the specified maximums must be baked according to the baking conditions listed below. Baking Conditions It is not necessary to bake all XLamp LEDs. Only the LEDs that meet all of the following criteria must be baked: 1. LEDs that have been removed from the original MBP. 2. LEDs that have been exposed to a humid environment longer than listed in the Moisture Sensitivity section above. 3. LEDs that have not been soldered. © 2006-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS5 REV 21 14 XLAMP ® XR-E LED NOTES - CONTINUED LEDs should be baked at 70 ºC for 24 hours. LEDs may be baked on the original reels. Remove LEDs from the MBP before baking. Do not bake parts at temperatures higher than 70 ºC. This baking operation resets the exposure time as defined in the Moisture Sensitivity section above. Storage Conditions XLamp LEDs that have been removed from the original MBP but not soldered yet should be stored in a room or cabinet that will maintain an atmosphere of 25 ± 5 ºC and no greater than 10% RH (relative humidity). For LEDs stored in these conditions, storage time does not add to exposure time as defined in the Moisture Sensitivity section above. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. REACH Compliance REACH substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative to insure you get the most up-to-date REACH SVHC Declaration. REACH banned substance information (REACH Article 67) is also available upon request. UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. © 2006-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS5 REV 21 15 XLAMP ® XR-E LED MECHANICAL DIMENSIONS (TA = 25 °C) All measurements are ±.1 mm unless otherwise indicated. Lens Substrate Reflector Reflector Anode Lens Substrate 6.8 mm 4.4 ± .2 mm Side View 9.0 mm 8.4 mm 5.6 mm 0.7 mm 6.46 mm 7.0 mm Anode Bottom View Top View 8.4 mm 7.0 mm 9.4 mm 8.30 5.6 mm 0.70 mm 7.0 mm 7.10 6.46 mm 5.50 1.2 mm 6.36 5.6 mm 7.4 mm Recommended PC Board Solder Pad Recommended solder pad for XLamp XR family LEDs 0.60 0.80 0.80 0.60 RECOMMENDED STENCIL PATTERN 7090 Recommended stencil pattern for XLamp XR family LEDs (HATCHED AREA IS OPENING) Recommended PC (hatched Board Solder Pad area is opening) © 2006-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS5 REV 21 16 XLAMP ® XR-E LED TAPE AND REEL 1.5 ± .1 4.0±.1 All Cree LED carrier tapes conform to EIA-481D, Automated Component Handling Systems Standard. 12.0±.1 1.75±.10 CATHODE SIDE All dimensions in mm. 16.0 +.3 -.0 1.5 ± .1 4.0±.1 13.5 (MIN) 1.75±.10 12.0±.1 +.3 SIDE ANODE 16.0 -.0 CATHODE SIDE 5.5±.1 13.5 (MIN) ANODE SIDE 5.5±.1 START USER FEED DIRECTION LOADED POCKETS 50 EMPTY POCKETS WITH TAPE LOADED POCKETS 60 (MIN) EMPTY POCKETS WITH TAPE USER FEED DIRECTION 5-10 EMPTY POCKTES WITH UNSEALED COVER TAPE 60 (MIN) EMPTY POCKETS WITH TAPE START 50 EMPTY POCKETS WITH TAPE 5-10 EMPTY POCKTES WITH UNSEALED COVER TAPE + 330.2 mm © 2006-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS5 REV 21 17 XLAMP ® XR-E LED PACKAGING © 2006-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS5 REV 21 18 XLAMP ® XR-E LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS The following order codes are active and valid order codes, but higher performance options are also available. Please see page 3 for order codes of XLamp XR-E LEDs that could serve as alternatives for the order codes set forth below. XR-E Cool White, TJ = 25 °C Minimum Luminous Flux (lm) @ 350 mA Group Chromaticity Regions Kit Number Order Code WA, WB, WC, WD, WE, WF, WG, WH, WJ, WK, WM, WN, WP 00901 XREWHT-L1-0000-00901 WC, WD, WF, WG 00902 XREWHT-L1-0000-00902 Flux (lm) Cool White (5000 K – 10,000 K) P4 Q2 Q3 Q4 Q5 R2 80.6 87.4 93.9 100 107 114 WC, WD, WF, WG, WH, WJ, WN, WP 00903 XREWHT-L1-0000-00903 WA, WB, WC, WD, WE, WF, WG, WH, WJ, WK, WM, WN, WP 00A01 XREWHT-L1-0000-00A01 WC, WD, WF, WG 00A02 XREWHT-L1-0000-00A02 WC, WD, WF, WG, WH, WJ, WN, WP 00A03 XREWHT-L1-0000-00A03 WA, WB, WC, WD, WE, WF, WG, WH, WJ, WK, WM, WN, WP 00B01 XREWHT-L1-0000-00B01 WC, WD, WF, WG 00B02 XREWHT-L1-0000-00B02 WC, WD, WF, WG, WH, WJ, WN, WP 00B03 XREWHT-L1-0000-00B03 WA, WB, WC, WD, WE, WF, WG, WH, WJ, WK, WM, WN, WP 00C01 XREWHT-L1-0000-00C01 WC, WD, WF, WG 00C02 XREWHT-L1-0000-00C02 WC, WD, WF, WG, WH, WJ, WN, WP 00C03 XREWHT-L1-0000-00C03 WA, WB, WC, WD, WE, WF, WG, WH, WJ, WK, WM, WN, WP 00D01 XREWHT-L1-0000-00D01 WC, WD, WF, WG 00D02 XREWHT-L1-0000-00D02 WC, WD, WF, WG, WH, WJ, WN, WP 00D03 XREWHT-L1-0000-00D03 WA, WB, WC, WD, WE, WF, WG, WH, WJ, WK, WM, WN, WP 00E01 XREWHT-L1-0000-00E01 WC, WD, WF, WG 00E02 XREWHT-L1-0000-00E02 WC, WD, WF, WG, WH, WJ, WN, WP 00E03 XREWHT-L1-0000-00E03 Notes: • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 14). © 2006-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS5 REV 21 19 XLAMP ® XR-E LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED The following order codes are active and valid order codes, but higher performance options are also available. Please see page 4 for order codes of XLamp XR-E LEDs that could serve as alternatives for the order codes set forth below. XR-E Neutral White, TJ = 25 °C Minimum Luminous Flux (lm) @ 350 mA Group Flux (lm) N4 62.0 Chromaticity Regions CCT Kit Number Order Code Neutral White (3700 K - 5000 K) P2 P3 P4 Q2 Q3 Q4 67.2 73.9 80.6 87.4 93.9 100 5C, 5D, 6A, 6B 3700 K 006F6 XREWHT-L1-0000-006F6 4C, 4D, 5A, 5B 4300 K 007F5 XREWHT-L1-0000-007F5 5A, 5B, 5C, 5D 4000 K 007E5 XREWHT-L1-0000-007E5 5C, 5D, 6A, 6B 3700 K 007F6 XREWHT-L1-0000-007F6 3A, 3B, 3C, 3D 5000 K 008E3 XREWHT-L1-0000-008E3 3C, 3D, 4A, 4B 4750 K 008F4 XREWHT-L1-0000-008F4 4A, 4B, 4C, 4D 4500 K 008E4 XREWHT-L1-0000-008E4 4C, 4D, 5A, 5B 4300 K 008F5 XREWHT-L1-0000-008F5 5A, 5B, 5C, 5D 4000 K 008E5 XREWHT-L1-0000-008E5 5C, 5D, 6A, 6B 3700 K 008F6 XREWHT-L1-0000-008F6 3A, 3B, 3C, 3D 5000 K 009E3 XREWHT-L1-0000-009E3 3C, 3D, 4A, 4B 4750 K 009F4 XREWHT-L1-0000-009F4 4A, 4B, 4C, 4D 4500 K 009E4 XREWHT-L1-0000-009E4 4C, 4D, 5A, 5B 4300 K 009F5 XREWHT-L1-0000-009F5 5A, 5B, 5C, 5D 4000 K 009E5 XREWHT-L1-0000-009E5 3A, 3B, 3C, 3D 5000 K 00AE3 XREWHT-L1-0000-00AE3 3C, 3D, 4A, 4B 4750 K 00AF4 XREWHT-L1-0000-00AF4 4A, 4B, 4C, 4D 4500 K 00AE4 XREWHT-L1-0000-00AE4 4C, 4D, 5A, 5B 4300 K 00AF5 XREWHT-L1-0000-00AF5 5A, 5B, 5C, 5D 4000 K 00AE5 XREWHT-L1-0000-00AE5 3A, 3B, 3C, 3D 5000 K 00BE3 XREWHT-L1-0000-00BE3 3C, 3D, 4A, 4B 4750 K 00BF4 XREWHT-L1-0000-00BF4 4A, 4B, 4C, 4D 4500 K 00BE4 XREWHT-L1-0000-00BE4 3A, 3B, 3C, 3D 5000 K 00CE3 XREWHT-L1-0000-00CE3 3C, 3D, 4A, 4B 4750 K 00CF4 XREWHT-L1-0000-00CF4 4A, 4B, 4C, 4D 4500 K 00CE4 XREWHT-L1-0000-00CE4 Notes: • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 14). © 2006-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS5 REV 21 20 XLAMP ® XR-E LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED The following order codes are active and valid order codes, but higher performance options are also available. Please see page 5 for order codes of XLamp XR-E LEDs that could serve as alternatives for the order codes set forth below. XR-E Warm White, TJ = 25 °C  Minimum Luminous Flux (lm) @ 350 mA Group Chromaticity Regions CCT Kit Number Order Code Flux (lm) Warm White (2600 K - 3700 K) N3 N4 56.8 62.0 P2 67.2 P3 73.9 6C, 6D, 7A, 7B 3200 K 005F7 XREWHT-L1-0000-005F7 7A, 7B, 7C, 7D 3000 K 005E7 XREWHT-L1-0000-005E7 7C, 7D, 8A, 8B 2900 K 005F8 XREWHT-L1-0000-005F8 8A, 8B, 8C, 8D 2700 K 005E8 XREWHT-L1-0000-005E8 6A, 6B, 6C, 6D 3500 K 006E6 XREWHT-L1-0000-006E6 6C, 6D, 7A, 7B 3200 K 006F7 XREWHT-L1-0000-006F7 7A, 7B, 7C, 7D 3000 K 006E7 XREWHT-L1-0000-006E7 7C, 7D, 8A, 8B 2900 K 006F8 XREWHT-L1-0000-006F8 8A, 8B, 8C, 8D 2700 K 006E8 XREWHT-L1-0000-006E8 6A, 6B, 6C, 6D 3500 K 007E6 XREWHT-L1-0000-007E6 6C, 6D, 7A, 7B 3200 K 007F7 XREWHT-L1-0000-007F7 7A, 7B, 7C, 7D 3000 K 007E7 XREWHT-L1-0000-007E7 6A, 6B, 6C, 6D 3500 K 008E6 XREWHT-L1-0000-008E6 Notes: • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 14). © 2006-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS5 REV 21 21
物料型号:CREE XLamp® XR-E LED
器件简介: - CREE XLamp® XR-E LED以其前所未有的亮度、效率、寿命和光源质量引领LED照明革命。 - 该LED适用于多种照明应用,包括颜色变化的照明、便携式和个人照明、户外照明、室内定向照明、商业照明和紧急车辆照明。
引脚分配:文档中未明确提供引脚分配图,但提到了JEDEC标准兼容性,包括J-STD-020C。
参数特性: - 热阻:结到焊接点的热阻具有最小值。 - 视场角度:半高全宽(FWHM)为90度。 - 电压温度系数:-1.3 mV/°C。 - ESD分类:符合HBMper Mi-Std-883D标准的Class 2。 - 直流正向电流:根据不同色温,最大直流正向电流为700 mA至1000 mA不等。 - 反向电压:最大5V。 - 正向电压:在350 mA、700 mA和1000 mA下的电压范围从2.9 V至3.25 V不等。 - 最大结温:150°C。
功能详解: - Cree XLamp XR-E LED具有高效率和长寿命的特点,适用于节能照明应用。 - 提供了多种色温和亮度选项,以满足不同设计需求。 - 符合RoHS和REACH标准,UL®认可的组件。
应用信息: - 适用于需要高亮度和节能的照明应用。
封装信息: - 提供了详细的机械尺寸图和推荐的PCB焊盘图案。 - 遵循EIA-481D标准,提供了胶带和卷轴的详细信息。
XREWHT-L1-0000-008A2 价格&库存
很抱歉,暂时无法提供与“XREWHT-L1-0000-008A2”相匹配的价格&库存,您可以联系我们找货
