XPGWHT-H1-0000-00AE8
    CREELED
    LED-3P_3.45X3.45MM_SM
    LED 照明 XLamp® XP-G 白色,暖色 2700K 2.9V 350mA 125° 1414(3535 公制)
XPGWHT-H1-0000-00AE8 数据手册
PRODUCT FAMILY DATA SHEET XLamp® XP-G LEDs PRODUCT DESCRIPTION The XLamp® XP-G LED FEATURES delivers • Available in white, outdoor white and TABLE OF CONTENTS Characteristics................................................ 2 unprecedented levels of light output and 80-CRI, 85-CRI and 90-CRI white Order Codes Suggested for New Designs..... 3 efficacy for a single die LED. The XLamp • ANSI-compatible chromaticity bins Relative Spectral Power Distribution............. 7 XP-G LED continues Cree LED’s history of • Maximum drive current: 1500 mA Relative Flux vs. Junction Temperature......... 7 innovation in LEDs for lighting applications • Low thermal resistance: 2 °C/W Electrical Characteristics................................ 8 with wide viewing angle, symmetrical Relative Flux vs. Current................................. 8 • Wide viewing angle: 130° package, unlimited floor life and electrically • Unlimited floor life at ≤ 30 ºC/85% RH Relative Chromaticity vs Current and neutral thermal path. • Reflow solderable - JEDEC J‑STD‑020C Temperature.................................................... 9 • Electrically neutral thermal path Typical Spatial Distribution........................... 10 • RoHS and REACH compliant Thermal Design............................................. 10 XLamp XP-G LEDs are the ideal choice for lighting applications where high light • UL recognized component (E349212) Performance Groups – Luminous Flux....... 11 output and maximum efficacy are required, Performance Groups – Chromaticity........... 12 such as LED light bulbs, outdoor lighting, Standard Cool White Kits Plotted on ANSI portable lighting, indoor lighting and solar- Standard Chromaticity Regions................... 15 powered lighting. Standard Warm and Neutral White Kits ® Plotted on ANSI Standard Chromaticity Regions.......................................................... 16 Standard Chromaticity Kits.......................... 18 Bin and Order Code Formats........................ 19 Reflow Soldering Characteristics................. 20 Notes............................................................. 21 Mechanical Dimensions............................... 23 Tape and Reel................................................ 25 Packaging...................................................... 27 Appendix - Order Codes Not For New Designs.......................................................... 28 Cree LED / 4001 E. Hwy. 54, Suite 2000 / Durham, NC 27709 USA / +1.919.313.5330 / www.cree-led.com © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS20 REV 19 1 XLAMP ® XP-G LED CHARACTERISTICS Characteristics Unit Thermal resistance, junction to solder point* °C/W 2 degrees 130 mV/°C -1.3 Viewing angle (FWHM) Temperature coefficient of voltage ESD withstand voltage (HBM per Mil-Std-883D) Minimum Typical Maximum V 8000 mA 1500 Reverse voltage V 1 Forward voltage (@ 350 mA, 25 °C) V 2.75 Forward voltage (@ 700 mA, 25 °C) V 2.88 Forward voltage (@ 1000 mA, 25 °C) V 2.97 Forward voltage (@ 1500 mA, 25 °C) V 3.10 LED junction temperature °C DC forward current * 3.1 150 Thermal resistance measurement performed as per JEDEC JESD51-14 standard. See the Thermal Resistance Measurement application note for more details. © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS20 REV 19 2 XLAMP ® XP-G LED ORDER CODES SUGGESTED FOR NEW DESIGNS (TJ = 25 °C) The following table provides order codes for XLamp XP-G LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 19). For definitions of the chromaticity kits, please see the Standard Chromaticity Kits section (page 18). Chromaticity Kit 51 53 50 E1 E2 CCT 6200 K 6000 K 6200 K 6500 K 5700 K Minimum Luminous Flux (lm) @ 350 mA Order Codes Code Flux (lm) 70 CRI Typical S6 180 XPGWHT-L1-0000-00N51 S5 172 XPGWHT-L1-0000-00M51 S4 164 XPGWHT-L1-0000-00L51 S6 180 XPGWHT-L1-0000-00N53 S5 172 XPGWHT-L1-0000-00M53 S4 164 XPGWHT-L1-0000-00L53 S6 180 XPGWHT-L1-0000-00N50 S5 172 XPGWHT-L1-0000-00M50 S4 164 XPGWHT-L1-0000-00L50 S6 180 XPGWHT-L1-0000-00NE1 S5 172 XPGWHT-L1-0000-00ME1 S4 164 XPGWHT-L1-0000-00LE1 S7 188 XPGWHT-L1-0000-00PE2 S6 180 XPGWHT-L1-0000-00NE2 S5 172 XPGWHT-L1-0000-00ME2 Notes • • • For additional order codes NOT recommended for new designs please see the Appendix section starting on page 28. Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 21). XLamp XP-G LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS20 REV 19 3 XLAMP ® XP-G LED ORDER CODES SUGGESTED FOR NEW DESIGNS - CONTINUED Chromaticity Kit E3 F4 E4 F5 E5 Z5 CCT 5000 K 4750 K 4500 K 4250 K 4000 K 4000 K Minimum Luminous Flux (lm) @ 350 mA Order Codes Code Flux (lm) 70 CRI Typical 75 CRI Typical 80 CRI Minimum S5 172 XPGWHT-01-0000-00ME3 S4 164 XPGWHT-01-0000-00LE3 XPGWHT-L1-0000-00LE3 S3 156 XPGWHT-01-0000-00KE3 XPGWHT-L1-0000-00KE3 S5 172 XPGWHT-01-0000-00MF4 S4 164 XPGWHT-01-0000-00LF4 XPGWHT-L1-0000-00LF4 S3 156 XPGWHT-01-0000-00KF4 XPGWHT-L1-0000-00KF4 S4 164 XPGWHT-01-0000-00LE4 XPGWHT-L1-0000-00LE4 S3 156 XPGWHT-01-0000-00KE4 XPGWHT-L1-0000-00KE4 S2 148 S4 164 XPGWHT-01-0000-00LF5 XPGWHT-L1-0000-00FL5 S3 156 XPGWHT-01-0000-00KF5 XPGWHT-L1-0000-00KF5 S2 148 S4 164 XPGWHT-01-0000-00LE5 XPGWHT-L1-0000-00LE5 S3 156 XPGWHT-01-0000-00KE5 XPGWHT-L1-0000-00KE5 XPGWHT-H1-0000-00KE5 S2 148 XPGWHT-L1-0000-00JE5 XPGWHT-H1-0000-00JE5 S4 164 XPGWHT-L1-0000-00LZ5 S3 156 XPGWHT-L1-0000-00KZ5 XPGWHT-H1-0000-00KZ5 S2 148 XPGWHT-L1-0000-00JZ5 XPGWHT-H1-0000-00JZ5 XPGWHT-L1-0000-00JE4 XPGWHT-L1-0000-00JF5 Notes • • • For additional order codes NOT recommended for new designs please see the Appendix section starting on page 28. Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 21). XLamp XP-G LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS20 REV 19 4 XLAMP ® XP-G LED ORDER CODES SUGGESTED FOR NEW DESIGNS - CONTINUED Chromaticity Kit F6 E6 Z6 F7 E7 Z7 CCT 3750 K 3500 K 3500 K 3250 K 3000 K 3000 K Minimum Luminous Flux (lm) @ 350 mA Order Codes Code Flux (lm) 70 CRI Typical 80 CRI Typical S4 164 XPGWHT-01-0000-00LF6 XPGWHT-L1-0000-00LF6 S3 156 XPGWHT-01-0000-00KF6 XPGWHT-L1-0000-00KF6 XPGWHT-H1-0000-00KF6 S2 148 XPGWHT-L1-0000-00JF6 XPGWHT-H1-0000-00JF6 S4 164 XPGWHT-01-0000-00LF6 XPGWHT-L1-0000-00LE6 S3 156 XPGWHT-01-0000-00KF6 XPGWHT-L1-0000-00KE6 XPGWHT-H1-0000-00KE6 S2 148 XPGWHT-L1-0000-00JE6 XPGWHT-H1-0000-00JE6 S4 164 XPGWHT-L1-0000-00LZ6 S3 156 XPGWHT-L1-0000-00KZ6 XPGWHT-H1-0000-00KZ6 S2 148 XPGWHT-L1-0000-00JZ6 XPGWHT-H1-0000-00JZ6 S4 164 XPGWHT-L1-0000-00LF7 S3 156 XPGWHT-L1-0000-00KF7 XPGWHT-H1-0000-00KF7 S2 148 XPGWHT-L1-0000-00JF7 XPGWHT-H1-0000-00JF7 S3 156 XPGWHT-L1-0000-00KE7 80 CRI Minimum 85 CRI Minimum 90 CRI Minimum S2 148 XPGWHT-L1-0000-00JE7 XPGWHT-H1-0000-00JE7 R5 139 XPGWHT-L1-0000-00HE7 XPGWHT-H1-0000-00HE7 R4 130 R3 122 XPGWHT-P1-0000-00FE7 XPGWHT-U1-0000-00FE7 R2 114 XPGWHT-P1-0000-00EE7 XPGWHT-U1-0000-00EE7 Q5 107 XPGWHT-P1-0000-00DE7 XPGWHT-U1-0000-00DE7 S3 156 XPGWHT-L1-0000-00KZ7 S2 148 XPGWHT-L1-0000-00JZ7 XPGWHT-H1-0000-00JZ7 R5 139 XPGWHT-L1-0000-00HZ7 XPGWHT-H1-0000-00HZ7 R4 130 R3 122 XPGWHT-P1-0000-00FZ7 XPGWHT-U1-0000-00FZ7 R2 114 XPGWHT-P1-0000-00EZ7 XPGWHT-U1-0000-00EZ7 Q5 107 XPGWHT-P1-0000-00DZ7 XPGWHT-U1-0000-00DZ7 Notes • • • For additional order codes NOT recommended for new designs please see the Appendix section starting on page 28. Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 21). XLamp XP-G LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS20 REV 19 5 XLAMP ® XP-G LED ORDER CODES SUGGESTED FOR NEW DESIGNS - CONTINUED Chromaticity Kit F8 E8 Z8 CCT 2850 K 2700 K 2700 K Minimum Luminous Flux (lm) @ 350 mA Order Codes Code Flux (lm) S3 156 XPGWHT-L1-0000-00KF8 S2 148 XPGWHT-L1-0000-00JF8 XPGWHT-H1-0000-00JF8 R5 139 XPGWHT-L1-0000-00HF8 XPGWHT-H1-0000-00HF8 R4 130 R3 70 CRI Typical 80 CRI Typical 80 CRI Minimum 85 CRI Minimum 90 CRI Minimum 122 XPGWHT-P1-0000-00FF8 XPGWHT-U1-0000-00FF8 R2 114 XPGWHT-P1-0000-00EF8 XPGWHT-U1-0000-00EF8 Q5 107 XPGWHT-P1-0000-00DF8 XPGWHT-U1-0000-00DF8 S3 156 XPGWHT-L1-0000-00KE8 S2 148 XPGWHT-L1-0000-00JE8 R5 139 XPGWHT-L1-0000-00HE8 R4 130 R3 122 R2 114 XPGWHT-P1-0000-00EE8 XPGWHT-U1-0000-00EE8 Q5 107 XPGWHT-P1-0000-00DE8 XPGWHT-U1-0000-00DE8 Q4 100 XPGWHT-P1-0000-00CE8 XPGWHT-U1-0000-00CE8 S3 156 XPGWHT-L1-0000-00KZ8 S2 148 XPGWHT-L1-0000-00JZ8 R5 139 XPGWHT-L1-0000-00HZ8 R4 130 R3 122 R2 114 XPGWHT-P1-0000-00EZ8 XPGWHT-U1-0000-00EZ8 Q5 107 XPGWHT-P1-0000-00DZ8 XPGWHT-U1-0000-00DZ8 Q4 100 XPGWHT-P1-0000-00CZ8 XPGWHT-U1-0000-00CZ8 XPGWHT-H1-0000-00HE8 XPGWHT-H1-0000-00GE8 XPGWHT-H1-0000-00HZ8 XPGWHT-H1-0000-00GZ8 Notes • • • For additional order codes NOT recommended for new designs please see the Appendix section starting on page 28. Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 21). XLamp XP-G LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS20 REV 19 6 XLAMP ® XP-G LED RELATIVE SPECTRAL POWER DISTRIBUTION Relative Spectral Power 100% Relative Radiant Power 80% 60% 5000 K - 8300 K CCT 3700 K - 5000 K CCT 2600 K - 3700 K CCT 40% 20% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Relative Flux Output vs. Junction Temperature RELATIVE FLUX VS. JUNCTION TEMPERATURE (IF = 350 mA) 100% Relative Luminous Flux 80% 60% 40% 20% 0% 25 50 75 100 125 150 Junction Temperature (ºC) © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS20 REV 19 7 XLAMP ® XP-G LED Electrical Characteristics ELECTRICAL CHARACTERISTICS (TJ = 25 °C) (Tj = 25ºC) 1500 1400 1300 Forward Current (mA) 1200 1100 1000 900 800 700 600 500 400 300 200 100 0 2.45 2.50 2.55 2.60 2.65 2.70 2.75 2.80 2.85 2.90 2.95 3.00 3.05 3.10 3.15 Forward Voltage (V) Relative Intensity vs. Current (Tj = 25ºC) RELATIVE FLUX VS. CURRENT (TJ = 25 °C) 350% Relative Luminous Flux 300% 250% 200% 150% 100% 50% 0% 0 100 200 300 400 500 600 700 800 900 1000 1100 1200 1300 1400 1500 Forward Current (mA) © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS20 REV 19 8 XLAMP ® XP-G LED RELATIVE CHROMATICITY VS CURRENT AND TEMPERATURE (WARM WHITE*) Delta CCT vs. Current 0.020 0.015 0.010 0.005 ΔCCx 0.000 ΔCCy -0.005 -0.010 -0.015 -0.020 100 300 500 700 900 1100 1300 1500 Current (mA) Delta CCT vs Temp 0.020 0.015 0.010 0.005 ΔCCx 0.000 ΔCCy -0.005 -0.010 -0.015 -0.020 25 50 75 100 125 150 Tsp (°C) * Warm White XLamp XP-G LEDs have a typical CRI of 80. © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS20 REV 19 9 XLAMP ® XP-G LED Typical Spatial Radiation TYPICAL SPATIAL DISTRIBUTION Pattern 100% Relative Luminous Intensity 80% 60% 40% 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) THERMAL DESIGN The maximum forward current is determined by the thermal resistance between the LED junction and ambient. It is crucial for the end Thermal Design product to be designed in a manner that minimizes the thermal resistance from the solder point to ambient in order to optimize lamp life and optical characteristics. 1600 Maximum Current (mA) 1400 1200 1000 800 600 Rj-a = 10°C/W 400 Rj-a = 15°C/W Rj-a = 20°C/W 200 0 Rj-a = 25°C/W 0 20 40 60 80 100 120 140 160 Ambient Temperature (ºC) © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS20 REV 19 10 XLAMP ® XP-G LED PERFORMANCE GROUPS – LUMINOUS FLUX XLamp XP-G LEDs are tested for luminous flux and placed into one of the following luminous‑flux groups: Group Code Minimum Luminous Flux (lm) @ 350 mA Maximum Luminous Flux (lm) @ 350 mA P2 67.2 73.9 P3 73.9 80.6 P4 80.6 87.4 Q2 87.4 93.9 Q3 93.9 100 Q4 100 107 Q5 107 114 R2 114 122 R3 122 130 R4 130 139 R5 139 148 S2 148 156 S3 156 164 S4 164 172 S5 172 180 S6 180 188 © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS20 REV 19 11 XLAMP ® XP-G LED PERFORMANCE GROUPS – CHROMATICITY Region 0A 0R 1A 1R 2A 2R 3A 4A 4R x y 0.2950 0.2970 0.2920 0.3060 0.2984 0.3133 0.3009 Region x y 0.2920 0.3060 x y x y 0.2984 0.3133 0.2984 0.3133 0.2895 0.3135 0.2962 0.3220 0.3048 0.3207 0.2962 0.3220 0.3028 0.3304 0.3068 0.3113 0.3042 0.2984 0.3133 0.3048 0.3207 0.3009 0.3042 0.2980 0.2880 0.2895 0.3135 0.2962 0.3220 0.3037 0.2937 0.2950 0.2970 0.2870 0.3210 0.2937 0.3312 0.3009 0.3042 0.3009 0.3042 0.2937 0.3312 0.3005 0.3415 0.3068 0.3113 0.3037 0.2937 0.2962 0.3220 0.3028 0.3304 0.3093 0.2993 0.3048 0.3207 0.3028 0.3304 0.3115 0.3391 0.3130 0.3290 0.3130 0.3290 0.3115 0.3391 0.3205 0.3481 0.3213 0.3373 0.3144 0.3186 0.3130 0.3290 0.3213 0.3373 0.3221 0.3261 0.3068 0.3113 0.3048 0.3207 0.3130 0.3290 0.3144 0.3186 0.3068 0.3113 0.3005 0.3415 0.3099 0.3509 0.3144 0.3186 0.3144 0.3186 0.3099 0.3509 0.3196 0.3602 0.3221 0.3261 0.3161 0.3059 0.3115 0.3391 0.3205 0.3481 0.3231 0.3120 0.3093 0.2993 0.3028 0.3304 0.3115 0.3391 0.3161 0.3059 0.3215 0.3350 0.3207 0.3462 0.3290 0.3538 0.3290 0.3417 0.3290 0.3417 0.3290 0.3538 0.3376 0.3616 0.3371 0.3490 0.3290 0.3300 0.3290 0.3417 0.3371 0.3490 0.3366 0.3369 0.3222 0.3243 0.3215 0.3350 0.3290 0.3417 0.3290 0.3300 0.3222 0.3243 0.3196 0.3602 0.3290 0.3690 0.3290 0.3300 0.3290 0.3300 0.3290 0.3690 0.3381 0.3762 0.3366 0.3369 0.3290 0.3180 0.3290 0.3538 0.3376 0.3616 0.3361 0.3245 0.3231 0.3120 0.3207 0.3462 0.3290 0.3538 0.3290 0.3180 0.3371 0.3490 0.3376 0.3616 0.3366 0.3369 0.3381 0.3762 0.3451 0.3554 0.3463 0.3687 0.3440 0.3428 0.3480 0.3840 0.3440 0.3427 0.3451 0.3554 0.3429 0.3307 0.3463 0.3687 0.3366 0.3369 0.3371 0.3490 0.3361 0.3245 0.3376 0.3616 0.3530 0.3597 0.3548 0.3736 0.3641 0.3804 0.3615 0.3659 0.3615 0.3659 0.3641 0.3804 0.3736 0.3874 0.3702 0.3722 0.3590 0.3521 0.3615 0.3659 0.3702 0.3722 0.3670 0.3578 0.3512 0.3465 0.3530 0.3597 0.3615 0.3659 0.3590 0.3521 0.3512 0.3465 0.3571 0.3907 0.3668 0.3957 0.3590 0.3521 0.3590 0.3521 0.3668 0.3957 0.3771 0.4034 0.3670 0.3578 0.3567 0.3389 0.3641 0.3804 0.3736 0.3874 0.3640 0.3440 0.3495 0.3339 0.3548 0.3736 0.3641 0.3804 0.3567 0.3389 0B 0S 1B 1S 2B 2S 3B 4B 4S Region 0C 0T 1C 1T 2C 2T 3R 4C 4T © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Region 0D 0U 1D 1U 2D 2U 3S 4D 4U CLD-DS20 REV 19 12 XLAMP ® XP-G LED PERFORMANCE GROUPS – CHROMATICITY (CONTINUED) Region 5A1 5B1 5C1 5D1 6A1 6B1 6C1 6D1 7A1 x y 0.3670 0.3578 0.3686 0.3649 0.3744 0.3685 0.3726 0.3612 0.3702 0.3722 0.3719 0.3797 0.3782 0.3837 0.3763 Region x y 0.3686 0.3649 x y x y 0.3744 0.3685 0.3726 0.3612 0.3702 0.3722 0.3763 0.3760 0.3744 0.3685 0.3763 0.3760 0.3744 0.3685 0.3825 0.3798 0.3804 0.3721 0.3804 0.3721 0.3783 0.3646 0.3719 0.3797 0.3782 0.3837 0.3763 0.3760 0.3736 0.3874 0.3802 0.3916 0.3782 0.3837 0.3802 0.3916 0.3869 0.3958 0.3847 0.3877 0.3760 0.3782 0.3837 0.3847 0.3877 0.3825 0.3798 0.3825 0.3798 0.3847 0.3877 0.3912 0.3917 0.3887 0.3836 0.3847 0.3877 0.3869 0.3958 0.3937 0.4001 0.3912 0.3917 0.3912 0.3917 0.3937 0.4001 0.4006 0.4044 0.3978 0.3958 0.3887 0.3836 0.3912 0.3917 0.3978 0.3958 0.3950 0.3875 0.3783 0.3646 0.3804 0.3721 0.3863 0.3758 0.3840 0.3681 0.3804 0.3721 0.3825 0.3798 0.3887 0.3836 0.3863 0.3758 0.3863 0.3758 0.3887 0.3836 0.3950 0.3875 0.3924 0.3794 0.3840 0.3681 0.3863 0.3758 0.3924 0.3794 0.3898 0.3716 0.3889 0.3690 0.3915 0.3768 0.3981 0.3800 0.3953 0.3720 0.3915 0.3768 0.3941 0.3848 0.4010 0.3882 0.3981 0.3800 0.3981 0.3800 0.4010 0.3882 0.4080 0.3916 0.4048 0.3832 0.3953 0.3720 0.3981 0.3800 0.4048 0.3832 0.4017 0.3751 0.3941 0.3848 0.3968 0.3930 0.4040 0.3966 0.4010 0.3882 0.3968 0.3930 0.3996 0.4015 0.4071 0.4052 0.4040 0.3966 0.4040 0.3966 0.4071 0.4052 0.4146 0.4089 0.4113 0.4001 0.4010 0.3882 0.4040 0.3966 0.4113 0.4001 0.4080 0.3916 0.4080 0.3916 0.4113 0.4001 0.4186 0.4037 0.4150 0.3950 0.4113 0.4001 0.4146 0.4089 0.4222 0.4127 0.4186 0.4037 0.4186 0.4037 0.4222 0.4127 0.4299 0.4165 0.4259 0.4073 0.4150 0.3950 0.4186 0.4037 0.4259 0.4073 0.4221 0.3984 0.4017 0.3751 0.4048 0.3832 0.4116 0.3865 0.4082 0.3782 0.4048 0.3832 0.4080 0.3916 0.4150 0.3950 0.4116 0.3865 0.4116 0.3865 0.4150 0.3950 0.4221 0.3984 0.4183 0.3898 0.4082 0.3782 0.4116 0.3865 0.4183 0.3898 0.4147 0.3814 0.4147 0.3814 0.4183 0.3898 0.4242 0.3919 0.4203 0.3833 0.4183 0.3898 0.4221 0.3984 0.4281 0.4006 0.4242 0.3919 0.4242 0.3919 0.4281 0.4006 0.4342 0.4028 0.4300 0.3939 0.4203 0.3833 0.4242 0.3919 0.4300 0.3939 0.4259 0.3853 5A2 5B2 5C2 5D2 6A2 6B2 6C2 6D2 7A2 Region 5A3 5B3 5C3 5D3 6A3 6B3 6C3 6D3 7A3 © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Region 5A4 5B4 5C4 5D4 6A4 6B4 6C4 6D4 7A4 CLD-DS20 REV 19 13 XLAMP ® XP-G LED PERFORMANCE GROUPS – CHROMATICITY (CONTINUED) Region 7B1 7C1 7D1 8A1 8B1 8C1 8D1 x y 0.4221 0.3984 0.4259 0.4073 0.4322 0.4096 0.4281 0.4006 0.4342 0.4028 0.4385 0.4119 0.4449 0.4141 0.4403 Region x y 0.4259 0.4073 x y x y 0.4322 0.4096 0.4281 0.4006 0.4299 0.4165 0.4364 0.4188 0.4322 0.4096 0.4364 0.4188 0.4322 0.4096 0.4430 0.4212 0.4385 0.4119 0.4385 0.4119 0.4342 0.4028 0.4385 0.4119 0.4449 0.4141 0.4403 0.4049 0.4430 0.4212 0.4496 0.4236 0.4449 0.4141 0.4496 0.4236 0.4562 0.4260 0.4513 0.4164 0.4049 0.4449 0.4141 0.4513 0.4164 0.4465 0.4071 0.4259 0.3853 0.4300 0.3939 0.4359 0.3960 0.4316 0.3873 0.4300 0.3939 0.4342 0.4028 0.4403 0.4049 0.4359 0.3960 0.4359 0.3960 0.4403 0.4049 0.4465 0.4071 0.4418 0.3981 0.4316 0.3873 0.4359 0.3960 0.4418 0.3981 0.4373 0.3893 0.4373 0.3893 0.4418 0.3981 0.4475 0.3994 0.4428 0.3906 0.4418 0.3981 0.4465 0.4071 0.4523 0.4085 0.4475 0.3994 0.4475 0.3994 0.4523 0.4085 0.4582 0.4099 0.4532 0.4008 0.4428 0.3906 0.4475 0.3994 0.4532 0.4008 0.4483 0.3919 0.4465 0.4071 0.4513 0.4164 0.4573 0.4178 0.4523 0.4085 0.4513 0.4164 0.4562 0.4260 0.4624 0.4274 0.4573 0.4178 0.4573 0.4178 0.4624 0.4274 0.4687 0.4289 0.4634 0.4193 0.4523 0.4085 0.4573 0.4178 0.4634 0.4193 0.4582 0.4099 0.4582 0.4099 0.4634 0.4193 0.4695 0.4207 0.4641 0.4112 0.4634 0.4193 0.4687 0.4289 0.4750 0.4304 0.4695 0.4207 0.4695 0.4207 0.4750 0.4304 0.4813 0.4319 0.4756 0.4221 0.4641 0.4112 0.4695 0.4207 0.4756 0.4221 0.4700 0.4126 0.4483 0.3919 0.4532 0.4008 0.4589 0.4021 0.4538 0.3931 0.4532 0.4008 0.4582 0.4099 0.4641 0.4112 0.4589 0.4021 0.4589 0.4021 0.4641 0.4112 0.4700 0.4126 0.4646 0.4034 0.4538 0.3931 0.4589 0.4021 0.4646 0.4034 0.4593 0.3944 7B2 7C2 7D2 8A2 8B2 8C2 8D2 Region 7B3 7C3 7D3 8A3 8B3 8C3 8D3 © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Region 7B4 7C4 7D4 8A4 8B4 8C4 8D4 CLD-DS20 REV 19 14 XLAMP ® XP-G LED STANDARD COOL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS 0.40 0.40 5000 K 0.39 0.38 3S 51 6500 K 0.36 8000 K 0T 0C 0D 0A 0S CCy 0.32 1R 0C 0D 0A 0U CCx CCx 0.40 0.40 5000 K 0.39 5000 K 0.39 0.38 5700 K 0.38 6500 K 0.36 2T 6500 K 8000 K 1U 0.31 1R 0.36 0.35 CCx 0.34 0.28 0.36 0.35 0.34 0.33 0.32 0.28 0.31 0.28 0.30 1R 0R 0.29 0.29 ANSI C78.377A 2R 1U 0U 0.30 0R 2U 1A 0D 0A 0U 0.29 0.28 0C 0B 1D 0.33 0A 0.30 0S 0.32 3R 2A 1B 0.32 0.31 ANSI C78.377A 2R 1A 0D 0T 0.33 2U 3A 2D 1C 0.31 0C 0B 1D 2C 2B 1S 3R 2A 1B 3B 2S 1T 8000 K 0.34 0.30 0S 0.32 2D 1C 0.29 0T 0.33 3A 2B 1S 2T E1 0.35 CCy 0.34 0.36 3B 2C 1T 3S 0.37 2S 0.35 5700 K 3S 50 0.37 CCy 0.36 0.30 0.29 0.28 0.36 0.35 0.34 0.33 0.32 0.28 0.31 0.28 0.30 0.29 0.29 1R 0R 0.29 0.28 1U 0U 0.30 0R ANSI C78.377A 2R 1A 0B 0.31 2U 1D 0.35 0.30 1U 3R 2A 1B 0.34 0.31 ANSI C78.377A 2R 1A 2D 1C 0.33 0B 0T 3A 2B 1S 0.33 2U 1D 0.34 0.32 0S 0.32 8000 K 3R 2A 1B 3B 2C 1T 3A 2D 1C 3S 2T 2S 0.35 0.31 0.33 0.36 3B 2B 1S 53 6500 K 2C 1T 0.34 5700 K 0.37 2T 2S 0.35 CCy 0.38 5700 K 0.37 5000 K 0.39 CCx 0.40 5000 K 0.39 0.38 5700 K E2 0.37 6500 K 0.36 3B 2S 0.35 CCy 3S 2T 2C 1T 8000 K 0.34 0T 0.33 0S 0.32 0C 0.31 0A 3R 2A 2U 1D ANSI C78.377A 2R 1A 0D 2D 1C 1B 0B 3A 2B 1S 1U 1R 0U 0.30 0R 0.29 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.28 CCx © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS20 REV 19 15 XLAMP ® XP-G LED STANDARD WARM AND NEUTRAL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS 0.46 0.45 2700 K 3000 K 0.44 0.43 0.42 4000 K 0.41 E6 4500 K E5 0.40 CCy E7 3500 K 5000 K 0.39 0.38 E3 0.37 0.36 5B4 4C 4B 3C 4D 3B 6B2 5C3 5C2 5B1 5D2 5A3 5D4 6A1 5A2 5D1 5A4 5A1 6D2 6A3 5D3 6A2 6A4 6D1 7A4 7A1 6D4 7D1 8B3 8C1 8B4 8C2 8C3 8C4 8D3 8D2 8D4 8A4 8D1 8A1 7D4 8B2 8A3 8A2 7D3 7D2 7A3 7A2 6D3 8B1 7C4 7C1 7B4 7B1 6C4 6C1 6B4 5C4 6B1 5C1 5B2 6C2 6B3 5B3 E4 6C3 7C2 7B3 7B2 7C3 E8 ANSI C78.377A 4A 3D 0.35 3A 0.34 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.33 CCx 0.46 0.45 2700 K 3000 K 0.44 0.43 3500 K 0.42 4000 K 0.41 4500 K CCy 0.40 F5 5000 K 0.39 F4 0.38 0.37 4B 4D 3B 5C4 5C1 5B4 3C 0.36 5B3 5B1 5D2 5A3 5D4 6A1 5A2 5D1 5A4 5A1 6C2 6B3 6B4 6B1 5D3 6A2 6A3 6A4 7B2 6C3 6B2 5C3 5C2 5B2 4C F6 F7 6C1 6D2 6D1 7B1 6C4 6D3 6D4 7A2 7A1 7A4 F8 7A3 7D1 7C2 7B3 7B4 7C1 7D4 8B1 7C4 7D3 7D2 7C3 8A1 8A2 8B2 8B3 8B4 8A3 8D2 8C1 8C2 8C3 8C4 8D3 8D4 8A4 8D1 ANSI C78.377A 4A 3D 0.35 3A 0.34 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.33 CCx © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS20 REV 19 16 XLAMP ® XP-G LED STANDARD WARM AND NEUTRAL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS CONTINUED 0.46 0.45 2700 K 3000 K 0.44 0.43 0.42 Z6 4000 K 0.41 Z5 4500 K 0.40 CCy Z7 3500 K 6C3 6C2 6B3 6B2 5C3 5000 K 0.39 5C2 5B3 5C1 5B2 5B4 0.38 4C 0.37 4B 3C 0.36 4D 3B 6B4 5C4 6B1 5D3 6A2 5B1 5D2 5A3 5D4 6A1 5A2 5D1 5A4 5A1 6A3 6A4 6C1 6D2 6D1 7B1 6C4 6D3 6D4 7A2 7A1 7A4 7B4 7A3 7D1 7C2 7B3 7B2 7C1 7D4 8B1 7C4 7D3 7D2 7C3 8A1 8A2 8A3 8B2 Z8 8B3 8B4 8D2 8C1 8C2 8C3 8C4 8D3 8D4 8A4 8D1 ANSI C78.377A 4A 3D 0.35 3A 0.34 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.33 CCx © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS20 REV 19 17 XLAMP ® XP-G LED STANDARD CHROMATICITY KITS The following table provides the chromaticity bins associated with chromaticity kits. Color Cool White Neutral White Warm White CCT Kit Chromaticity Bins 6200 K 51 0A, 0B, 0C, 0D, 0R, 0S, 0T, 0U, 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U, 2A, 2B, 2C, 2D, 2R, 2S, 2T, 2U, 3A, 3B, 3R, 3S 6000 K 53 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U, 2A, 2B, 2C, 2D, 2R, 2S, 2T, 3A, 3B, 3S 6200 K 50 1A, 1B, 1C, 1D, 2A, 2B, 2C, 2D 6500 K E1 1A, 1B, 1C, 1D 5700 K E2 2A, 2B, 2C, 2D 5000 K E3 3A, 3B, 3C, 3D 4750 K F4 3C, 3D, 4A, 4B 4500 K E4 4A, 4B, 4C, 4D 4250 K F5 4C, 4D, 5A1, 5A2, 5A3, 5A4, 5B1, 5B2, 5B3, 5B4 4000 K E5 5A1, 5A2, 5A3, 5A4, 5B1, 5B2, 5B3, 5B4, 5C1, 5C2, 5C3, 5C4, 5D1, 5D2, 5D3, 5D4 4000 K Z5 5A3, 5B4, 5C1, 5D2 3750 K F6 5C1, 5C2, 5C3, 5C4, 5D1, 5D2, 5D3, 5D4, 6A1, 6A2, 6A3, 6A4, 6B1, 6B2, 6B3, 6B4 3500 K E6 6A1, 6A2, 6A3, 6A4, 6B1, 6B2, 6B3, 6B4, 6C1, 6C2, 6C3, 6C4, 6D1, 6D2, 6D3, 6D4 3500 K Z6 6A3, 6B4, 6C1, 6D2 3250 K F7 6C1, 6C2, 6C3, 6C4, 6D1, 6D2, 6D3, 6D4, 7A1, 7A2, 7A3, 7A4, 7B1, 7B2, 7B3, 7B4 3000 K E7 7A1, 7A2, 7A3, 7A4, 7B1, 7B2, 7B3, 7B4, 7C1, 7C2, 7C3, 7C4, 7D1, 7D2, 7D3, 7D4 3000 K Z7 7A3, 7B4, 7C1, 7D2 2850 K F8 7C1, 7C2, 7C3, 7C4, 7D1, 7D2, 7D3, 7D4, 8A1, 8A2, 8A3, 8A4, 8B1, 8B2, 8B3, 8B4 2700 K E8 8A1, 8A2, 8A3, 8A4, 8B1, 8B2, 8B3, 8B4, 8C1, 8C2, 8C3, 8C4, 8D1, 8D2, 8D3, 8D4 2700 K Z8 8A3, 8B4, 8C1, 8D2 © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS20 REV 19 18 XLAMP ® XP-G LED BIN AND ORDER CODE FORMATS XP-G bin codes and order codes are configured in the following manner: Order Code Bin Code Series XPG = XP-G Series XPG = XP-G Color specification 01 = Outdoor White L1 = Standard CRI H1 = 80 CRI minimum P1 = 85 CRI minimum U1 = 90 CRI minimum Color specification 01 = Outdoor White L1 = Standard CRI H1 = 80 CRI minimum P1 = 85 CRI minimum U1 = 90 CRI minimum Luminous flux group Kit number SSSCCC-BD-HHHH-NNNNN SSSCCC-BD-WWW-FF-G-AA Internal code Internal code Color WHT = White Chromaticity bin © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Color WHT = White CLD-DS20 REV 19 19 XLAMP ® XP-G LED REFLOW SOLDERING CHARACTERISTICS In testing, Cree LED has found XLamp XP-G LEDs to be compatible with JEDEC J-STD-020C, using the parameters listed below. As a general guideline, Cree LED recommends that users follow the recommended soldering profile provided by the manufacturer of the solder paste used, and therefore it is the lamp or luminaire manufacturer’s responsibility to determine applicable soldering requirements. Note that this general guideline may not apply to all PCB designs and configurations of reflow soldering equipment. tP TP Critical Zone TL to TP Temperature Ramp-up TL tL Tsmax Tsmin Ramp-down ts Preheat 25 t 25˚C to Peak Time Profile Feature Average Ramp-Up Rate (Tsmax to Tp) Lead-Free Solder 1.2 °C/second Preheat: Temperature Min (Tsmin) 120 °C Preheat: Temperature Max (Tsmax) Preheat: Time (tsmin to tsmax) 170 °C 65-150 seconds Time Maintained Above: Temperature (TL) Time Maintained Above: Time (tL) Peak/Classification Temperature (Tp) 217 °C 45-90 seconds 235 - 245 °C Time Within 5 °C of Actual Peak Temperature (tp) 20-40 seconds Ramp-Down Rate 1 - 6 °C/second Time 25 °C to Peak Temperature 4 minutes max. Note: All temperatures refer to topside of the package, measured on the package body surface. © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS20 REV 19 20 XLAMP ® XP-G LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Lumen Maintenance Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. Moisture Sensitivity Cree LED recommends keeping XLamp LEDs in the provided, resealable moisture-barrier packaging (MBP) until immediately prior to soldering. Unopened MBPs that contain XLamp LEDs do not need special storage for moisture sensitivity. Once the MBP is opened, XLamp XP-G LEDs may be stored as MSL 1 per JEDEC J-STD-033, meaning they have unlimited floor life in conditions of ≤ 30 ºC/85% relative humidity (RH). Regardless of the storage condition, Cree LED recommends sealing any unsoldered LEDs in the original MBP. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. REACH Compliance REACH substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative to insure you get the most up-to-date REACH SVHC Declaration. REACH banned substance information (REACH Article 67) is also available upon request. © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS20 REV 19 21 XLAMP ® XP-G LED NOTES - CONTINUED UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS20 REV 19 22 XLAMP ® XP-G LED MECHANICAL DIMENSIONS (TA = 25 °C) 8 7 6 Thermal vias, if present, are not shown on these drawings. 4 5 All measurements are ±.13 mm unless otherwise indicated. F BOTTOM OPTICAL MODEL ORIGIN OPTICAL MODEL ORIGIN 3 2.00 CATHODE SIDE 0.73 ANODE SIDE 2 0.50 ANODE SIDE 3.45 E 0.58 R1.30 3.45 ALTERNATE BOTTOM VIEW SideVIEW View SIDE BOTTOM VIEW Top TOPView VIEW D 3.30 2.00 0.73 0.50 1.01 3.30 3.30 0.75 CATHODE SIDE 1.30 B E 3.30 REF. SOLDERMASK MAY BE PRESENT SIDE VIEW 3.30 2.30 0.50 ANODE SIDE 0.58 F 2.30 0.50 C SOLDERMASK MAY BE PRESENT CENTER PAD IS ELECTRICALLY ISOLATED SOLDERMASK MAY BE PRESENT 3.30 2.30 1 1 2 3 3.30 REF. 4 5 CENTER PAD IS ELECTRICALLY ISOLATED D 0.64 1.30 0.50 Bottom View 3.30 RECOMMENDED PCB FOOTPRINT 2.30 0.28 Alternate Bottom View RECOMMENDED STENCIL OPEN 1.01 A 0.75 C © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 8 7 6 PROPRIETARY AND CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF 23 LED. ANY REPRODUCTION IN CLD-DS20 CREE PART OR AS A WHOLE WITHOUT WRITTEN PERMISSION OF CREE LED REV 19 IS PROHIBITED. © 2021 CreeLED, Inc. a subsidiary of SMART Global Holdings, Inc. 5 4 B A RE CATHODE SIDE 0.73 ANODE SIDE 2.30 0.50 0.50 CATHODE SIDE ANODE SIDE XLAMP ® XP-G LED 3.45 E 0.58 R1.30 3.45 MECHANICAL DIMENSIONS - CONTINUED (TA = 25 °C) SIDE VIEW TOP VIEW 3.30 3.30 REF. SOLDERMASK MAY BE PRESENT CENTER PAD IS ELECTRICALLY ISOLATED 3.30 2.30 0.28 D 1.30 2.30 0.50 1.01 0.25 3.30 3.30 0.75 C B 0.50 0.64 1.30 RECOMMENDED PCB FOOTPRINT RECOMMENDED STENCIL OPENING Recommended PCB Footprint Recommended Stencil Opening UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS DRAWN TOLERANCES: • ANGULAR: MACH 0.5° BEND 1° • ONE PLACE DECIMAL 0.5 CHECKED • TWO PLACE DECIMAL 0.05 • INSIDE BEND RADII EQUAL ENG APPR. MATERIAL • MACHINE/CASTING RADII 0.50 MFG APPR. • RADII AND DIA: 0.10 A PROPRIETARY AND CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF CREE LED. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT WRITTEN PERMISSION OF CREE LED IS PROHIBITED. © 2021 CreeLED, Inc. a subsidiary of SMART Global Holdings, Inc. 8 7 6 5 4 © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. B OPTICAL MODEL ORIGIN A DRAWING INITIATED REV DESCRIPTION INTERPRET GEOMETRIC TOLERANCING PER: MATERIAL NAME DATE TLING 24AUG22 Q.A. THIRD ANGLE PROJECTION MATERIAL SIZE DWG. NO. 350 C FINISH FINISH SCALE: 20:1 WEIG APPLICATION 2 X X X TITLE: 3 1 2 CLD-DS20 REV 19 24 XLAMP ® XP-G LED TAPE AND REEL All Cree LED carrier tapes conform to EIA-481D, Automated Component Handling Systems Standard. Except as noted, all dimensions in mm. All measurements are ±.15 mm unless otherwise indicated. Po T E Do Bo R P2 W A Anode side F A P1 B D1 "H" Ko B-B SECTION Bo (on a place in the bottom of the corner radii) Ao (on a place in the bottom of the corner radii) R "I" Ao Item Dim. ITEM Ao 3.75Dim. Bo Ao Ko 3.75 3.75 2.10 DETAIL"H" DETAIL"I" A-A SECTION Bo Po 3.754.00 Ko P1 Po P2 2.10 8.00 4.00 2.00 T P1 E 0.30 8.00 1.75 ITEM F Do D1 W R Dim. 5.50 1.50 1.50 12.00 8deg P2 F 2.00 5.50 T Do 0.30 1.50 E D1 1.75 1.50 W R 12.00 8° NOTICE 1) All Cree LED carrier tapes conform to EIA-481D, Automated Component handling Systems Standard 2) Measurement tolerances unless indicated otherwise: .xx = ±.15 mm 2402-M007 XPG © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS20 REV 19 25 XLAMP ® XP-G LED TAPE AND REEL - CONTINUED Feed Direction END START Trailer Loaded Pockets Leader Min. 160 mm empty pockets sealed with tape 1000 Lamps Min. 400 mm empty pockets with min. 100 mm sealed Feed Direction Cover Tape Pocket Tape 13 mm 7” © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS20 REV 19 26 XLAMP ® XP-G LED PACKAGING © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS20 REV 19 27 XLAMP ® XP-G LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS The following order codes are active and valid order codes, but higher performance options are also available. Please see page 3 for order codes of XLamp XP-G LEDs that could serve as alternatives for the order codes set forth below. Chromaticity Kit 51 53 50 E1 E2 CCT 6200 K 6000 K 6200 K 6500 K 5700 K Minimum Luminous Flux (lm) @ 350 mA Order Codes Code Flux (lm) 70 CRI Typical S3 156 XPGWHT-L1-0000-00K51 S2 148 XPGWHT-L1-0000-00J51 R5 139 XPGWHT-L1-0000-00H51 R4 130 XPGWHT-L1-0000-00G51 R3 122 XPGWHT-L1-0000-00F51 S3 156 XPGWHT-L1-0000-00K53 S2 148 XPGWHT-L1-0000-00J53 R5 139 XPGWHT-L1-0000-00H53 R4 130 XPGWHT-L1-0000-00G53 R3 122 XPGWHT-L1-0000-00F53 S3 156 XPGWHT-L1-0000-00K50 S2 148 XPGWHT-L1-0000-00J50 R5 139 XPGWHT-L1-0000-00H50 R4 130 XPGWHT-L1-0000-00G50 R3 122 XPGWHT-L1-0000-00F50 S3 156 XPGWHT-L1-0000-00KE1 S2 148 XPGWHT-L1-0000-00JE1 R5 139 XPGWHT-L1-0000-00HE1 R4 130 XPGWHT-L1-0000-00GE1 R3 122 XPGWHT-L1-0000-00FE1 S4 164 XPGWHT-L1-0000-00LE2 S3 156 XPGWHT-L1-0000-00KE2 S2 148 XPGWHT-L1-0000-00JE2 R5 139 XPGWHT-L1-0000-00HE1 R4 130 XPGWHT-L1-0000-00GE1 R3 122 XPGWHT-L1-0000-00FE1 Notes • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 21). XLamp XP-G LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS20 REV 19 28 XLAMP ® XP-G LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED The following order codes are active and valid order codes, but higher performance options are also available. Please see page 4 for order codes of XLamp XP-G LEDs that could serve as alternatives for the order codes set forth below. Chromaticity Kit E3 F4 E4 F5 E5 CCT 5000 K 4750 K 4500 K 4250 K 4000 K Minimum Luminous Flux (lm) @ 350 mA Code Flux (lm) Order Codes 70 CRI Minimum 75 CRI Typical S2 148 XPGWHT-01-0000-00JE3 XPGWHT-L1-0000-00JE3 R5 139 XPGWHT-01-0000-00HE3 XPGWHT-L1-0000-00HE3 R4 130 XPGWHT-01-0000-00GE3 XPGWHT-L1-0000-00GE3 R3 122 XPGWHT-01-0000-00FE3 XPGWHT-L1-0000-00FE3 R2 114 XPGWHT-01-0000-00EE3 XPGWHT-L1-0000-00EE3 Q5 107 S2 148 XPGWHT-01-0000-00JF4 XPGWHT-L1-0000-00JF4 R5 139 XPGWHT-01-0000-00HF4 XPGWHT-L1-0000-00HF4 R4 130 XPGWHT-01-0000-00GF4 XPGWHT-L1-0000-00GF4 R3 122 XPGWHT-01-0000-00FF4 XPGWHT-L1-0000-00FF4 R2 114 XPGWHT-01-0000-00EF4 XPGWHT-L1-0000-00EF4 Q5 107 80 CRI Minimum XPGWHT-L1-0000-00DE3 XPGWHT-L1-0000-00DF4 S2 148 XPGWHT-01-0000-00JE4 R5 139 XPGWHT-01-0000-00HE4 XPGWHT-L1-0000-00HE4 R4 130 XPGWHT-01-0000-00GE4 XPGWHT-L1-0000-00GE4 R3 122 XPGWHT-01-0000-00FE4 XPGWHT-L1-0000-00FE4 R2 114 XPGWHT-01-0000-00EE4 XPGWHT-L1-0000-00EE4 Q5 107 Q4 100 S2 148 XPGWHT-01-0000-00JF5 R5 139 XPGWHT-01-0000-00HF5 XPGWHT-L1-0000-00HF5 R4 130 XPGWHT-01-0000-00GF5 XPGWHT-L1-0000-00GF5 R3 122 XPGWHT-01-0000-00FF5 XPGWHT-L1-0000-00FF5 R2 114 XPGWHT-01-0000-00EF5 XPGWHT-L1-0000-00EF5 Q5 107 S2 148 XPGWHT-01-0000-00JE5 R5 139 XPGWHT-01-0000-00HE5 XPGWHT-L1-0000-00HE5 XPGWHT-H1-0000-00HE5 R4 130 XPGWHT-01-0000-00GE5 XPGWHT-L1-0000-00GE5 XPGWHT-H1-0000-00GE5 R3 122 XPGWHT-01-0000-00FE5 XPGWHT-L1-0000-00FE5 XPGWHT-H1-0000-00FE5 R2 114 XPGWHT-01-0000-00EE5 XPGWHT-L1-0000-00EE5 XPGWHT-H1-0000-00EE5 Q5 107 XPGWHT-L1-0000-00DE5 XPGWHT-H1-0000-00DE5 Q4 100 XPGWHT-L1-0000-00CE5 XPGWHT-L1-0000-00DE4 XPGWHT-L1-0000-00CE4 XPGWHT-L1-0000-00DF5 Notes • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 21). XLamp XP-G LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS20 REV 19 29 XLAMP ® XP-G LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED Chromaticity Kit Z5 CCT 4000 K Minimum Luminous Flux (lm) @ 350 mA Order Codes Code Flux (lm) 70 CRI Minimum 75 CRI Typical 80 CRI Minimum R5 R4 139 XPGWHT-L1-0000-00HZ5 XPGWHT-H1-0000-00HZ5 130 XPGWHT-L1-0000-00GZ5 XPGWHT-H1-0000-00GZ5 R3 122 XPGWHT-L1-0000-00FZ5 XPGWHT-H1-0000-00FZ5 R2 114 XPGWHT-L1-0000-00EZ5 XPGWHT-H1-0000-00EZ5 Q5 107 XPGWHT-L1-0000-00DZ5 XPGWHT-H1-0000-00DZ5 Notes • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 21). XLamp XP-G LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS20 REV 19 30 XLAMP ® XP-G LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED The following order codes are active and valid order codes, but higher performance options are also available. Please see page 5 page 6 for order codes of XLamp XP-G LEDs that could serve as alternatives for the order codes set forth below. Chromaticity Kit F6 E6 Z6 F7 CCT 3750 K 3500 K 3500 K 3250 K Minimum Luminous Flux (lm) @ 350 mA Code Flux (lm) Order Codes 70 CRI Typical 80 CRI Typical 80 CRI Minimum S2 148 XPGWHT-01-0000-00JF6 R5 139 XPGWHT-01-0000-00HF6 XPGWHT-L1-0000-00HF6 XPGWHT-H1-0000-00HF6 R4 130 XPGWHT-01-0000-00GF6 XPGWHT-L1-0000-00GF6 XPGWHT-H1-0000-00GF6 R3 122 XPGWHT-01-0000-00FF6 XPGWHT-L1-0000-00FF6 XPGWHT-H1-0000-00FF6 R2 114 XPGWHT-01-0000-00EF6 XPGWHT-L1-0000-00EF6 XPGWHT-H1-0000-00EF6 Q5 107 XPGWHT-01-0000-00DF6 XPGWHT-L1-0000-00DF6 XPGWHT-H1-0000-00DF6 Q4 100 XPGWHT-L1-0000-00CF6 XPGWHT-H1-0000-00CF6 S2 148 XPGWHT-01-0000-00JE6 R5 139 XPGWHT-01-0000-00HE6 XPGWHT-L1-0000-00HE6 XPGWHT-H1-0000-00HE6 R4 130 XPGWHT-01-0000-00GE6 XPGWHT-L1-0000-00GE6 XPGWHT-H1-0000-00GE6 R3 122 XPGWHT-01-0000-00FE6 XPGWHT-L1-0000-00FE6 XPGWHT-H1-0000-00FE6 R2 114 XPGWHT-01-0000-00EE6 XPGWHT-L1-0000-00EE6 XPGWHT-H1-0000-00EE6 Q5 107 XPGWHT-01-0000-00DE6 XPGWHT-L1-0000-00DE6 XPGWHT-H1-0000-00DE6 Q4 100 XPGWHT-L1-0000-00CE6 XPGWHT-H1-0000-00CE6 R5 139 XPGWHT-L1-0000-00HZ6 XPGWHT-H1-0000-00HZ6 R4 130 XPGWHT-L1-0000-00GZ6 XPGWHT-H1-0000-00GZ6 R3 122 XPGWHT-L1-0000-00FZ6 XPGWHT-H1-0000-00FZ6 R2 114 XPGWHT-L1-0000-00EZ6 XPGWHT-H1-0000-00EZ6 Q5 107 XPGWHT-L1-0000-00DZ6 XPGWHT-H1-0000-00DZ6 Q4 100 XPGWHT-L1-0000-00CZ6 XPGWHT-H1-0000-00CZ6 S2 148 R5 139 XPGWHT-L1-0000-00HF7 XPGWHT-H1-0000-00HF7 R4 130 XPGWHT-L1-0000-00GF7 XPGWHT-H1-0000-00GF7 R3 122 XPGWHT-L1-0000-00FF7 XPGWHT-H1-0000-00FF7 R2 114 XPGWHT-L1-0000-00EF7 XPGWHT-H1-0000-00EF7 Q5 107 XPGWHT-L1-0000-00DF7 XPGWHT-H1-0000-00DF7 Q4 100 XPGWHT-L1-0000-00CF7 XPGWHT-H1-0000-00CF7 Q3 93.9 XPGWHT-L1-0000-00BF7 XPGWHT-H1-0000-00BF7 85 CRI Minimum 90 CRI Minimum Notes • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 21). XLamp XP-G LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS20 REV 19 31 XLAMP ® XP-G LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED Chromaticity Kit E7 Z7 F8 CCT 3000 K 3000 K 2850 K Minimum Luminous Flux (lm) @ 350 mA Code Flux (lm) Order Codes 70 CRI Typical 80 CRI Typical 80 CRI Minimum R4 130 XPGWHT-L1-0000-00GE7 XPGWHT-H1-0000-00GE7 R3 122 XPGWHT-L1-0000-00FE7 XPGWHT-H1-0000-00FE7 R2 114 XPGWHT-L1-0000-00EE7 XPGWHT-H1-0000-00EE7 Q5 107 XPGWHT-L1-0000-00DE7 XPGWHT-H1-0000-00DE7 Q4 100 XPGWHT-L1-0000-00CE7 XPGWHT-H1-0000-00CE7 Q3 93.9 XPGWHT-L1-0000-00BE7 XPGWHT-H1-0000-00BE7 Q2 87.4 XPGWHT-L1-0000-00AE7 P4 80.6 P3 73.9 R4 130 XPGWHT-L1-0000-00GZ7 XPGWHT-H1-0000-00GZ7 R3 122 XPGWHT-L1-0000-00FZ7 XPGWHT-H1-0000-00FZ7 R2 114 XPGWHT-L1-0000-00EZ7 XPGWHT-H1-0000-00EZ7 Q5 107 XPGWHT-L1-0000-00DZ7 XPGWHT-H1-0000-00DZ7 Q4 100 XPGWHT-L1-0000-00CZ7 Q3 93.9 XPGWHT-L1-0000-00BZ7 Q2 87.4 XPGWHT-L1-0000-00AZ7 P4 80.6 P3 73.9 85 CRI Minimum 90 CRI Minimum XPGWHT-P1-0000-00CE7 XPGWHT-U1-0000-00CE7 XPGWHT-P1-0000-00BE7 XPGWHT-U1-0000-00BE7 XPGWHT-P1-0000-00AE7 XPGWHT-U1-0000-00AE7 XPGWHT-P1-0000-009E7 XPGWHT-U1-0000-009E7 XPGWHT-P1-0000-008E7 XPGWHT-U1-0000-008E7 XPGWHT-H1-0000-00CZ7 XPGWHT-P1-0000-00CZ7 XPGWHT-U1-0000-00CZ7 XPGWHT-H1-0000-00BZ7 XPGWHT-P1-0000-00BZ7 XPGWHT-U1-0000-00BZ7 XPGWHT-P1-0000-00AZ7 XPGWHT-U1-0000-00AZ7 XPGWHT-P1-0000-009Z7 XPGWHT-U1-0000-009Z7 XPGWHT-P1-0000-008Z7 XPGWHT-U1-0000-008Z7 R4 130 XPGWHT-L1-0000-00GF8 R3 122 XPGWHT-L1-0000-00FF8 XPGWHT-H1-0000-00GF8 XPGWHT-H1-0000-00FF8 R2 114 XPGWHT-L1-0000-00EF8 XPGWHT-H1-0000-00EF8 Q5 107 XPGWHT-L1-0000-00DF8 XPGWHT-H1-0000-00DF8 Q4 100 XPGWHT-L1-0000-00CF8 XPGWHT-H1-0000-00CF8 XPGWHT-P1-0000-00CF8 XPGWHT-U1-0000-00CF8 Q3 93.9 XPGWHT-L1-0000-00BF8 XPGWHT-H1-0000-00BF8 XPGWHT-P1-0000-00BF8 XPGWHT-U1-0000-00BF8 Q2 87.4 XPGWHT-L1-0000-00AF8 XPGWHT-H1-0000-00AF8 XPGWHT-P1-0000-00AF8 XPGWHT-U1-0000-00AF8 P4 80.6 XPGWHT-P1-0000-009F8 XPGWHT-U1-0000-009F8 P3 73.9 XPGWHT-P1-0000-008F8 XPGWHT-U1-0000-008F8 P2 67.2 XPGWHT-P1-0000-007F8 XPGWHT-U1-0000-007F8 Notes • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 21). XLamp XP-G LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS20 REV 19 32 XLAMP ® XP-G LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED Chromaticity Kit E8 Z8 CCT 2700 K 2700 K Minimum Luminous Flux (lm) @ 350 mA Code Flux (lm) Order Codes 70 CRI Typical 80 CRI Typical R4 130 XPGWHT-L1-0000-00GE8 R3 122 XPGWHT-L1-0000-00FE8 80 CRI Minimum 85 CRI Minimum 90 CRI Minimum XPGWHT-H1-0000-00FE8 R2 114 XPGWHT-L1-0000-00EE8 XPGWHT-H1-0000-00EE8 Q5 107 XPGWHT-L1-0000-00DE8 XPGWHT-H1-0000-00DE8 Q4 100 XPGWHT-L1-0000-00CE8 XPGWHT-H1-0000-00CE8 Q3 93.9 XPGWHT-L1-0000-00BE8 XPGWHT-H1-0000-00BE8 XPGWHT-P1-0000-00BE8 XPGWHT-U1-0000-00BE8 Q2 87.4 XPGWHT-L1-0000-00AE8 XPGWHT-H1-0000-00AE8 XPGWHT-P1-0000-00AE8 XPGWHT-U1-0000-00AE8 P4 80.6 XPGWHT-P1-0000-009E8 XPGWHT-U1-0000-009E8 P3 73.9 XPGWHT-P1-0000-008E8 XPGWHT-U1-0000-008E8 P2 67.2 XPGWHT-P1-0000-007E8 XPGWHT-U1-0000-007E8 R4 130 R3 122 XPGWHT-L1-0000-00FZ8 XPGWHT-H1-0000-00FZ8 R2 114 XPGWHT-L1-0000-00EZ8 XPGWHT-H1-0000-00EZ8 Q5 107 XPGWHT-L1-0000-00DZ8 XPGWHT-H1-0000-00DZ8 Q4 100 XPGWHT-L1-0000-00CZ8 XPGWHT-H1-0000-00CZ8 Q3 93.9 XPGWHT-L1-0000-00BZ8 XPGWHT-H1-0000-00BZ8 XPGWHT-P1-0000-00BZ8 XPGWHT-U1-0000-00BZ8 Q2 87.4 XPGWHT-L1-0000-00AZ8 XPGWHT-H1-0000-00AZ8 XPGWHT-P1-0000-00AZ8 XPGWHT-U1-0000-00AZ8 P4 80.6 XPGWHT-P1-0000-009Z8 XPGWHT-U1-0000-009Z8 P3 73.9 XPGWHT-P1-0000-008Z8 XPGWHT-U1-0000-008Z8 P2 67.2 XPGWHT-P1-0000-007Z8 XPGWHT-U1-0000-007Z8 XPGWHT-L1-0000-00GZ8 Notes • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 21). XLamp XP-G LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2009-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS20 REV 19 33
物料型号:CREE XLamp® XP-G LED
器件简介: - Cree XLamp® XP-G LED以其高光输出和高能效而闻名,适用于需要高光效的照明应用,如LED灯泡、户外照明、便携式照明、室内照明和太阳能照明等。 - 该LED提供白色、户外白色以及不同CRI(色彩还原指数)的版本。
引脚分配: - 文档中未明确提供引脚分配图,但通常这类LED会有阳极和阴极两个引脚。
参数特性: - 热阻:2°C/W(从结到焊接点) - 视场角:130° - 电压温度系数:-1.3 mV/°C - ESD(静电放电)耐受电压:8000V(人体模型,根据Mil-Std-883D) - 直流正向电流:最高1500 mA - 反向电压:最高1V - 正向电压:在350 mA时为2.75V至3.1V,在1500 mA时为3.10V - LED结温:最高150°C
功能详解: - Cree XLamp® XP-G LED具有中性热路径,即使在高电流驱动下也能保持较低的热阻,有助于提高LED的寿命和性能。 - 提供ANSI兼容的色彩二进制(CCT)和色彩还原指数(CRI)的版本。
应用信息: - 适用于需要高光输出和高能效的照明应用。
封装信息: - 该LED封装符合JEDEC J-STD-020C标准,可进行回流焊接。 - Cree LED保持对光通量和功率测量的±7%容差,对色度(CCx,CCy)测量的±0.005容差,以及对CRI测量的±2容差。
XPGWHT-H1-0000-00AE8 价格&库存
很抱歉,暂时无法提供与“XPGWHT-H1-0000-00AE8”相匹配的价格&库存,您可以联系我们找货
