XPEBWT-H1-R250-00BF7
    CREELED
    LED-3P_3.45X3.45MM_SM
    LED 照明 XLamp® XP-E2 白色,暖色 3250K 2.9V 350mA 110° 1414(3535 公制)
XPEBWT-H1-R250-00BF7 数据手册
PRODUCT FAMILY DATA SHEET XLamp® XP-E2 LEDs PRODUCT DESCRIPTION FEATURES The XLamp® XP-E2 LED builds on the unprecedented performance • Available in white, outdoor white, 80-CRI, 90-CRI white, royal of the original XP-E by increasing lumen output up to 20% while providing a single die LED point source for precise optical control. blue, blue, green, PC amber, amber, red-orange, red, photo red & far red The XP‑E2 LED shares the same footprint as the original XP‑E, • ANSI-compatible chromaticity bins providing a seamless upgrade path to more lumens and/or • White binned at 85 °C greater efficiency while shortening the design cycle for existing • Maximum drive current: royal blue, blue 1.2 A, others 1.5 A XP customers. • Low thermal resistance: as low as 1.4 °C/W • Wide viewing angle: 105°-140° XLamp XP-E2 LEDs are the ideal choice for lighting applications • Unlimited floor life at ≤ 30 °C/85% RH where high light output and maximum efficacy are required, • Reflow solderable - JEDEC J‑STD‑020C compatible such as LED retrofit lamps, outdoor, portable, indoor directional, • Electrically neutral thermal path emergency vehicle or architectural. • RoHS and REACH compliant • UL® recognized component (E349212) Cree LED / 4001 E. Hwy. 54, Suite 2000 / Durham, NC 27709 USA / +1.919.313.5330 / www.cree-led.com © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 1 XLAMP ® XP-E2 LED TABLE OF CONTENTS Characteristics........................................................................................................................................................................................................ 3 Order Codes Suggested for New Designs - White................................................................................................................................................ 5 Order Codes Suggested for New Designs - Color............................................................................................................................................... 10 Relative Spectral Power Distribution................................................................................................................................................................... 14 Relative Flux vs. Junction Temperature............................................................................................................................................................... 15 Electrical Characteristics - White......................................................................................................................................................................... 16 Electrical Characteristics - Color.......................................................................................................................................................................... 16 Relative Flux vs. Current - White........................................................................................................................................................................... 17 Relative Flux vs. Current - Color........................................................................................................................................................................... 17 Relative Chromaticity vs. Current and Temperature........................................................................................................................................... 18 Typical Spatial Distribution................................................................................................................................................................................... 19 Thermal Design..................................................................................................................................................................................................... 20 Performance Groups - Luminous Flux................................................................................................................................................................. 22 Performance Groups - Radiant Flux..................................................................................................................................................................... 23 Performance Groups - Chromaticity.................................................................................................................................................................... 24 Performance Groups - Dominant Wavelength.................................................................................................................................................... 27 Performance Groups - Peak Wavelength............................................................................................................................................................ 28 Performance Groups - Forward Voltage.............................................................................................................................................................. 28 Standard Cool White Kits Plotted on ANSI Standard Chromaticity Regions..................................................................................................... 29 Standard Warm and Neutral White Kits Plotted on ANSI Standard Chromaticity Regions.............................................................................. 30 PC Amber Kit Plotted on the 1931 CIE Curve...................................................................................................................................................... 31 2200 K CCT White Kits Plotted on ANSI Standard Chromaticity Regions......................................................................................................... 32 Standard Chromaticity Kits.................................................................................................................................................................................. 33 Bin and Order Code Formats................................................................................................................................................................................ 34 Reflow Soldering Characteristics......................................................................................................................................................................... 35 Notes..................................................................................................................................................................................................................... 36 Mechanical Dimensions....................................................................................................................................................................................... 38 Tape and Reel........................................................................................................................................................................................................ 40 Packaging.............................................................................................................................................................................................................. 42 Appendix - Order Codes Not For New Designs................................................................................................................................................... 43 © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 2 XLAMP ® XP-E2 LED CHARACTERISTICS Characteristics Unit Thermal resistance, junction to solder point - white °C/W 5.8 Thermal resistance, junction to solder point - royal blue, blue °C/W 5.7 Thermal resistance, junction to solder point - green °C/W 9 Thermal resistance, junction to solder point - PC amber °C/W 5.5 Thermal resistance, junction to solder point - amber °C/W 7.5 Thermal resistance, junction to solder point - red-orange, red °C/W 6.5 Thermal resistance, junction to solder point - photo red °C/W 2.5 Thermal resistance, junction to solder point - far red °C/W 1.4 Viewing angle (FWHM) - white degrees 110 Viewing angle (FWHM) - royal blue, blue, green degrees 135 Viewing angle (FWHM) - PC amber degrees 105 Viewing angle (FWHM) - amber, red-orange, red, photo red degrees 130 Viewing angle (FWHM) - far red degrees 140 Temperature coefficient of voltage - white mV/°C -1.5 Temperature coefficient of voltage - royal blue mV/°C -1.5 Temperature coefficient of voltage - blue mV/°C -1.9 Temperature coefficient of voltage - green mV/°C -1.2 Temperature coefficient of voltage - PC amber mV/°C -1.6 Temperature coefficient of voltage - amber mV/°C -2.1 Temperature coefficient of voltage - red-orange, red mV/°C -1.8 Temperature coefficient of voltage - photo red, far red mV/°C -1.3 ESD withstand voltage (HBM per Mil-Std-883D)- white, royal blue, blue, green Minimum Typical V ESD classification (HBM per Mil-Std-883D) - PC amber, amber, red-orange, red, photo red, far red Maximum 8000 Class 2 DC forward current - white, green, PC amber, amber, red‑orange, red, photo red, far red mA 1500 DC forward current - royal blue, blue mA 1200 Reverse voltage - white, oyal blue, blue, green, PC amber, amber, red-orange, red V 1 Reverse voltage photo red, far red V 10 © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 3 XLAMP ® XP-E2 LED CHARACTERISTICS - CONTINUED Characteristics Unit Minimum Typical Maximum 3.1 Forward voltage (@ 350 mA, 85 °C) - white V 2.84 Forward voltage (@ 700 mA, 85 °C) - white V 2.99 Forward voltage (@ 1000 mA, 85 °C) - white V 3.12 Forward voltage (@ 350 mA, 25 °C) - royal blue V 2.93 Forward voltage (@ 1000 mA, 25 °C) - royal blue V 3.2 Forward voltage (@ 350 mA, 25 °C) - blue V 2.85 Forward voltage (@ 1000 mA, 25 °C) - blue V 3.14 Forward voltage (@ 350 mA, 25 °C) - green V 2.7 Forward voltage (@ 1000 mA, 25 °C) - green V 3.01 Forward voltage (@ 350 mA, 25 °C) - PC amber V 2.94 Forward voltage (@ 1000 mA, 25 °C) - PC amber V 3.28 Forward voltage (@ 350 mA, 25 °C) - amber, red-orange, red V 2.18 Forward voltage (@ 1000 mA, 25 °C) - amber, red-orange, red V 2.6 Forward voltage (@ 350 mA, 25 °C) - photo red V 2.09 Forward voltage (@ 1000 mA, 25 °C) - photo red V 2.56 Forward voltage (@ 350 mA, 25 °C) - far red V 1.88 Forward voltage (@ 1000 mA, 25 °C) - far red V 2.16 LED junction temperature °C 3.4 3.4 3.25 3.24 2.6 2.2 2.2 150 Note • Thermal resistance measurement was performed per the JEDEC JESD51-14 standard. See the Thermal Resistance Measurement application note for more details. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 4 XLAMP ® XP-E2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - WHITE (TJ = 85 °C) The following tables provide order codes for XLamp XP-E2 white LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 34). For definitions of the chromaticity kits, please see the Cree LED’s Standard Chromaticity Kits section (page 33). Chromaticity Kit 51 53 50 E1 E2 CCT 6200 K 6000 K 6200 K 6500 K 5700 K Minimum Luminous Flux @ 350 mA Calculated Minimum Luminous Flux (lm)** @ 85 °C Order Codes Code Flux (lm) @ 85 °C Flux (lm) @ 25 °C* 700 mA 1.0 A 70 CRI Typical S3 156 181 267 340 XPEBWT-L1-0000-00K51 S2 148 172 254 323 XPEBWT-L1-0000-00J51 R5 139 161 238 303 XPEBWT-L1-0000-00H51 S3 156 181 267 340 XPEBWT-L1-0000-00K53 S2 148 172 254 323 XPEBWT-L1-0000-00J53 R5 139 161 238 303 XPEBWT-L1-0000-00H53 S3 156 181 267 340 XPEBWT-L1-0000-00K50 S2 148 172 254 323 XPEBWT-L1-0000-00J50 R5 139 161 238 303 XPEBWT-L1-0000-00H50 S3 156 181 267 340 XPEBWT-L1-0000-00KE1 S2 148 172 254 323 XPEBWT-L1-0000-00JE1 R5 139 161 238 303 XPEBWT-L1-0000-00HE1 S3 156 181 267 340 XPEBWT-L1-0000-00KE2 S2 148 172 254 323 XPEBWT-L1-0000-00JE2 R5 139 161 238 303 XPEBWT-L1-0000-00HE2 Notes: • For additional order codes NOT recommended for new designs please see the Appendix section starting on page 43. • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 36). • XLamp XP-E2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. ** Calculated flux values at 700 mA and 1 A are for reference only. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 5 XLAMP ® XP-E2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - WHITE (TJ = 85 °C) - CONTINUED Chromaticity Kit E3 F4 E4 F5 E5 Z5 CCT 5000 K 4750 K 4500 K 4250 K 4000 K 4000 K Minimum Luminous Flux @ 350 mA Calculated Minimum Luminous Flux (lm)** @ 85 °C Order Codes Code Flux (lm) @ 85 °C Flux (lm) @ 25 °C* 700 mA 1.0 A 70 CRI Typical 75 CRI Typical S3 156 181 267 340 XPEBWT-01-0000-00KE3 XPEBWT-L1-0000-00KE3 S2 148 172 254 323 XPEBWT-01-0000-00JE3 XPEBWT-L1-0000-00JE3 R5 139 161 238 303 XPEBWT-01-0000-00HE3 XPEBWT-L1-0000-00HE3 R4 130 151 223 284 XPEBWT-L1-0000-00GE3 S3 156 181 267 340 XPEBWT-L1-0000-00KF4 S2 148 172 254 323 XPEBWT-01-0000-00JF4 XPEBWT-L1-0000-00JF4 R5 139 161 238 303 XPEBWT-01-0000-00HF4 XPEBWT-L1-0000-00HF4 R4 130 151 223 284 XPEBWT-01-0000-00GF4 XPEBWT-L1-0000-00GF4 S3 156 181 267 340 80 CRI Minimum XPEBWT-L1-0000-00KE4 S2 148 172 254 323 XPEBWT-01-0000-00JE4 XPEBWT-L1-0000-00JE4 R5 139 161 238 303 XPEBWT-01-0000-00HE4 XPEBWT-L1-0000-00HE4 R4 130 151 223 284 XPEBWT-01-0000-00GE4 XPEBWT-L1-0000-00GE4 S2 148 172 254 323 XPEBWT-01-0000-00JF5 R5 139 161 238 303 XPEBWT-01-0000-00HF5 XPEBWT-L1-0000-00HF5 R4 130 151 223 284 XPEBWT-01-0000-00GF5 XPEBWT-L1-0000-00GF5 R3 122 142 209 266 S2 148 172 254 323 XPEBWT-01-0000-00JE5 R5 139 161 238 303 XPEBWT-01-0000-00HE5 XPEBWT-L1-0000-00HE5 XPEBWT-H1-0000-00HE5 R4 130 151 223 284 XPEBWT-01-0000-00GE5 XPEBWT-L1-0000-00GE5 XPEBWT-H1-0000-00GE5 R3 122 142 209 266 XPEBWT-L1-0000-00FE5 XPEBWT-H1-0000-00FE5 R4 130 151 223 284 XPEBWT-L1-0000-00GZ5 XPEBWT-H1-0000-00GZ5 R3 122 142 209 266 XPEBWT-L1-0000-00FZ5 XPEBWT-H1-0000-00FZ5 R2 114 132 195 249 XPEBWT-L1-0000-00EZ5 XPEBWT-H1-0000-00EZ5 XPEBWT-L1-0000-00FF5 Notes: • For additional order codes NOT recommended for new designs please see the Appendix section starting on page 43. • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 36). • XLamp XP-E2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. ** Calculated flux values at 700 mA and 1 A are for reference only. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 6 XLAMP ® XP-E2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - WHITE (TJ = 85 °C) - CONTINUED Chromaticity Kit F6 E6 Z6 F7 CCT Minimum Luminous Flux @ 350 mA Calculated Minimum Luminous Flux (lm)** @ 85 °C Code Flux (lm) @ 85 °C Flux (lm) @ 25 °C* 700 mA 1.0 A 70 CRI Typical R5 139 161 238 303 XPEBWT-01-000000HF6 R4 130 151 223 284 R3 122 142 209 266 R2 114 132 195 249 R5 139 161 238 303 XPEBWT-01-000000HE6 R4 130 151 223 284 R3 122 142 209 266 R2 114 132 195 R3 122 142 R2 114 Q5 80 CRI Typical 80 CRI Minimum XPEBWT-01-000000GF6 XPEBWT-L1-000000GF6 XPEBWT-H1-000000GF6 XPEBWT-01-000000FF6 XPEBWT-L1-000000FF6 XPEBWT-H1-000000FF6 XPEBWT-L1-000000EF6 XPEBWT-H1-000000EF6 XPEBWT-01-000000GE6 XPEBWT-L1-000000GE6 XPEBWT-H1-000000GE6 XPEBWT-01-000000FE6 XPEBWT-L1-000000FE6 XPEBWT-H1-000000FE6 249 XPEBWT-L1-000000EE6 XPEBWT-H1-000000EE6 209 266 XPEBWT-L1-000000FZ6 XPEBWT-H1-000000FZ6 132 195 249 XPEBWT-L1-000000EZ6 XPEBWT-H1-000000EZ6 107 124 183 233 XPEBWT-L1-000000DZ6 XPEBWT-H1-000000DZ6 R5 139 161 238 303 XPEBWT-01-000000HF7 R4 130 151 223 284 XPEBWT-01-000000GF7 XPEBWT-L1-000000GF7 XPEBWT-H1-000000GF7 R3 122 142 209 266 XPEBWT-01-000000FF7 XPEBWT-L1-000000FF7 XPEBWT-H1-000000FF7 R2 114 132 195 249 XPEBWT-L1-000000EF7 XPEBWT-H1-000000EF7 3750 K 3500 K 3500 K Order Codes 3250 K 90 CRI Minimum Notes: • For additional order codes NOT recommended for new designs please see the Appendix section starting on page 43. • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 36). • XLamp XP-E2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. ** Calculated flux values at 700 mA and 1 A are for reference only. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 7 XLAMP ® XP-E2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - WHITE (TJ = 85 °C) - CONTINUED Chromaticity Kit E7 Z7 F8 CCT 3000 K Minimum Luminous Flux @ 350 mA Calculated Minimum Luminous Flux (lm)** @ 85 °C Order Codes Code Flux (lm) @ 85 °C Flux (lm) @ 25 °C* 700 mA 1.0 A 70 CRI Typical R5 139 161 238 303 XPEBWT-01-000000HE7 R4 130 151 223 284 R3 122 142 209 266 R2 114 132 195 249 Q5 107 124 183 233 XPEBWT-U1-000000DE7 Q4 100 116 171 218 XPEBWT-U1-000000CE7 Q3 93.9 109 161 205 XPEBWT-U1-000000BE7 R3 122 142 209 266 XPEBWT-L1-000000FZ7 XPEBWT-H1-000000FZ7 R2 114 132 195 249 XPEBWT-L1-000000EZ7 XPEBWT-H1-000000EZ7 Q5 107 124 183 233 XPEBWT-L1-000000DZ7 XPEBWT-H1-000000DZ7 Q4 100 116 171 218 XPEBWT-U1-000000CZ7 Q3 93.9 109 161 205 XPEBWT-U1-000000BZ7 Q2 87.4 102 150 191 XPEBWT-U1-000000AZ7 R3 122 142 209 266 XPEBWT-L1-000000FF8 XPEBWT-H1-000000FF8 R2 114 132 195 249 XPEBWT-L1-000000EF8 XPEBWT-H1-000000EF8 Q5 107 124 183 233 XPEBWT-L1-000000DF8 XPEBWT-H1-000000DF8 Q4 100 116 171 218 XPEBWT-U1-000000CF8 Q3 93.9 109 161 205 XPEBWT-U1-000000BF8 Q2 87.4 102 150 191 XPEBWT-U1-000000AF8 3000 K 2850 K 80 CRI Typical 80 CRI Minimum XPEBWT-01-000000GE7 XPEBWT-L1-000000GE7 XPEBWT-H1-000000GE7 XPEBWT-01-000000FE7 XPEBWT-L1-000000FE7 XPEBWT-H1-000000FE7 XPEBWT-L1-000000EE7 XPEBWT-H1-000000EE7 90 CRI Minimum Notes: • For additional order codes NOT recommended for new designs please see the Appendix section starting on page 43. • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 36). • XLamp XP-E2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. ** Calculated flux values at 700 mA and 1 A are for reference only. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 8 XLAMP ® XP-E2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - WHITE (TJ = 85 °C) - CONTINUED Chromaticity Kit E8 Z8 EA ZA CCT Minimum Luminous Flux @ 350 mA Calculated Minimum Luminous Flux (lm)** @ 85 °C Code Flux (lm) @ 85 °C Flux (lm) @ 25 °C* 700 mA 1.0 A R3 122 142 209 R2 114 132 Q5 107 Q4 80 CRI Typical 80 CRI Minimum 266 XPEBWT-L1-000000FE8 XPEBWT-H1-000000FE8 195 249 XPEBWT-L1-000000EE8 XPEBWT-H1-000000EE8 124 183 233 XPEBWT-L1-000000DE8 XPEBWT-H1-000000DE8 100 116 171 218 XPEBWT-U1-000000CE8 Q3 93.9 109 161 205 XPEBWT-U1-000000BE8 Q2 87.4 102 150 191 XPEBWT-U1-000000AE8 R2 114 132 195 249 XPEBWT-L1-000000EZ8 XPEBWT-H1-000000EZ8 Q5 107 124 183 233 XPEBWT-L1-000000DZ8 XPEBWT-H1-000000DZ8 Q4 100 116 171 218 XPEBWT-L1-000000CZ8 XPEBWT-H1-000000CZ8 Q3 93.9 109 161 205 XPEBWT-U1-000000BZ8 Q2 87.4 102 150 191 XPEBWT-U1-000000AZ8 P4 80.6 93.6 138 176 XPEBWT-U1-0000009Z8 Q2 87.4 102 150 191 XPEBWT-L1-000000AEA XPEBWT-H1-000000AEA P4 80.6 93.6 138 176 XPEBWT-L1-0000009EA XPEBWT-H1-0000009EA P3 73.9 85.8 127 161 XPEBWT-L1-0000008EA XPEBWT-H1-0000008EA Q2 87.4 102 150 191 XPEBWT-L1-000000AZA XPEBWT-H1-000000AZA P4 80.6 93.6 138 176 XPEBWT-L1-0000009ZA XPEBWT-H1-0000009ZA P3 73.9 85.8 127 161 XPEBWT-L1-0000008ZA XPEBWT-H1-0000008ZA 2700 K 2700 K 2200 K 2200 K Order Codes 70 CRI Typical 90 CRI Minimum Notes: • For additional order codes NOT recommended for new designs please see the Appendix section starting on page 43. • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 36). • XLamp XP-E2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. ** Calculated flux values at 700 mA and 1 A are for reference only. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 9 XLAMP ® XP-E2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - COLOR (TJ = 25 °C) The following tables provide order codes for XLamp XP-E2 color LEDs. For a complete description of the order-code nomenclature, please see the Bin and Order Code Formats section (page 34). Minimum Radiant Flux @ 350 mA Color Group Flux (mW) 36 600 37 Dominant Wavelength (nm) Calculated Minimum PPF (µmol/s)* Minimum 2.27 625 2.37 Royal Blue 38 Color Blue 650 2.46 39 675 2.56 40 700 2.65 Minimum Luminous Flux (lm) @ 350 mA Group Flux (lm) K3 35.2 M2 M3 39.8 45.7 Maximum Order Codes Group DWL (nm) Group DWL (nm) D3 450 D5 465 XPEBRY-L1-0000-00Q01 D3 450 D4 460 XPEBRY-L1-0000-00Q02 D4 455 D5 465 XPEBRY-L1-0000-00Q03 D3 450 D5 465 XPEBRY-L1-0000-00R01 D3 450 D4 460 XPEBRY-L1-0000-00R02 D4 455 D5 465 XPEBRY-L1-0000-00R03 D3 450 D5 465 XPEBRY-L1-0000-00S01 D3 450 D4 460 XPEBRY-L1-0000-00S02 D4 455 D5 465 XPEBRY-L1-0000-00S03 D3 450 D5 465 XPEBRY-L1-0000-00T01 D3 450 D4 460 XPEBRY-L1-0000-00T02 D3 450 D5 465 XPEBRY-L1-0000-00U01 D3 450 D4 460 XPEBRY-L1-0000-00U02 Dominant Wavelength (nm) Minimum Maximum Order Codes Group DWL (nm) Group DWL (nm) B3 465 B6 485 XPEBBL-L1-0000-00Z01 B3 465 B5 480 XPEBBL-L1-0000-00Z02 B4 470 B5 480 XPEBBL-L1-0000-00Z05 B3 465 B6 485 XPEBBL-L1-0000-00201 B3 465 B5 480 XPEBBL-L1-0000-00202 B4 470 B5 480 XPEBBL-L1-0000-00205 B3 465 B6 485 XPEBBL-L1-0000-00301 B3 465 B5 480 XPEBBL-L1-0000-00302 B4 470 B5 480 XPEBBL-L1-0000-00305 Note: • For additional order codes NOT recommended for new designs please see the Appendix section starting on page 43. • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements, ±2 on CRI measurements and ±1 on dominant wavelength measurements. See the Measurements section (page 36). • XLamp XP-E2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Calculated Photosynthetic Photon Flux (PPF) values are for reference only. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 10 XLAMP ® XP-E2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - COLOR (TJ = 25 °C) - CONTINUED Color Minimum Luminous Flux (lm) @ 350 mA Group Flux (lm) S2 148 S3 Calculated Minimum PPF (µmol/s)* Dominant Wavelength (nm) Minimum Group Group DWL (nm) G2 520 G4 535 XPEBGR-L1-0000-00J01 G2 520 G3 530 XPEBGR-L1-0000-00J02 G3 525 G4 535 XPEBGR-L1-0000-00J03 G2 520 G4 535 XPEBGR-L1-0000-00K01 G2 520 G3 530 XPEBGR-L1-0000-00K02 G3 525 G4 535 XPEBGR-L1-0000-00K03 G2 520 G4 535 XPEBGR-L1-0000-00L01 G2 520 G3 530 XPEBGR-L1-0000-00L02 G3 525 G4 535 XPEBGR-L1-0000-00L03 G2 520 G4 535 XPEBGR-L1-0000-00M01 G2 520 G3 530 XPEBGR-L1-0000-00M02 G3 525 G4 535 XPEBGR-L1-0000-00M03 1.42 Green S4 164 S5 1.49 172 Color PC Amber 1.56 Color Bin Y2 Order Codes DWL (nm) 1.34 156 Maximum Minimum Luminous Flux (lm) @ 350 mA Order Codes Group Flux (lm) Q3 93.9 XPEBPA-L1-0000-00B01 Q4 100 XPEBPA-L1-0000-00C01 Q5 107 XPEBPA-L1-0000-00D01 Note: • For additional order codes NOT recommended for new designs please see the Appendix section starting on page 43. • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements, ±2 on CRI measurements and ±1 on dominant wavelength measurements. See the Measurements section (page 36). • XLamp XP-E2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Calculated Photosynthetic Photon Flux (PPF) values are for reference only. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 11 XLAMP ® XP-E2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - COLOR (TJ = 25 °C) - CONTINUED Color Minimum Luminous Flux (lm) @ 350 mA Group P3 Amber P4 Q2 Q3 Color Flux (lm) 73.9 80.6 87.4 93.9 Minimum Luminous Flux (lm) @ 350 mA Group Q2 Q3 Flux (lm) 87.4 93.9 Red-Orange Q4 Q5 100 107 Dominant Wavelength (nm) Minimum Maximum Order Codes Group DWL (nm) Group DWL (nm) A2 585 A3 595 XPEBAM-L1-0000-00801 A2 585 A2 590 XPEBAM-L1-0000-00802 A3 590 A3 595 XPEBAM-L1-0000-00803 A2 585 A3 595 XPEBAM-L1-0000-00901 A2 585 A2 590 XPEBAM-L1-0000-00902 A3 590 A3 595 XPEBAM-L1-0000-00903 A2 585 A3 595 XPEBAM-L1-0000-00A01 A2 585 A2 590 XPEBAM-L1-0000-00A02 A2 585 A3 595 XPEBAM-L1-0000-00B01 A2 585 A2 590 XPEBAM-L1-0000-00B02 Dominant Wavelength (nm) Minimum Maximum Order Codes Group DWL (nm) Group DWL (nm) O3 610 O4 620 XPEBRO-L1-0000-00A01 O3 610 O3 615 XPEBRO-L1-0000-00A02 O4 615 O4 620 XPEBRO-L1-0000-00A03 O3 610 O4 620 XPEBRO-L1-0000-00B01 O3 610 O3 615 XPEBRO-L1-0000-00B02 O4 615 O4 620 XPEBRO-L1-0000-00B03 O3 610 O4 620 XPEBRO-L1-0000-00C01 O3 610 O3 615 XPEBRO-L1-0000-00C02 O4 615 O4 620 XPEBRO-L1-0000-00C03 O3 610 O4 620 XPEBRO-L1-0000-00D01 O3 610 O3 615 XPEBRO-L1-0000-00D02 Note: • For additional order codes NOT recommended for new designs please see the Appendix section starting on page 43. • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements, ±2 on CRI measurements and ±1 on dominant wavelength measurements. See the Measurements section (page 36). • XLamp XP-E2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 12 XLAMP ® XP-E2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - COLOR (TJ = 25 °C) - CONTINUED Color Red Minimum Luminous Flux (lm) @ 350 mA Group Flux (lm) P2 67.2 P3 P4 Color Photo Red Color Far Red 73.9 80.6 Minimum Radiant Flux (mW) @ 350 mA Calculated Minimum PPF (µmol/s)* 1.75 1.92 2.10 Calculated Minimum PPF (µmol/s)* Dominant Wavelength (nm) Minimum Maximum Order Codes Group DWL (nm) Group DWL (nm) R2 620 R3 630 XPEBRD-L1-0000-00701 R2 620 R2 625 XPEBRD-L1-0000-00702 R2 620 R3 630 XPEBRD-L1-0000-00801 R2 620 R2 625 XPEBRD-L1-0000-00802 R2 620 R3 630 XPEBRD-L1-0000-00901 R2 620 R2 625 XPEBRD-L1-0000-00902 Peak Wavelength (nm) Minimum Maximum Group PWL (nm) Group PWL (nm) Color Order Codes Group Flux (mW) 30 450 2.5 P2 650 P5 670 XPEBPR-L1-0000-00D01 31 475 2.57 P2 650 P5 670 XPEBPR-L1-0000-00E01 32 500 2.71 P2 650 P5 670 XPEBPR-L1-0000-00F01 Minimum Radiant Flux (mW) @ 350 mA Calculated Minimum PFFR (µmol/s)* Peak Wavelength (nm) Minimum Maximum Group PWL (nm) Group PWL (nm) Color Order Codes Group Flux (mW) 27 375 2.2 F2 720 F5 740 XPEBFR-L1-0000-00A01 28 400 2.34 F2 720 F5 740 XPEBFR-L1-0000-00B01 29 425 2.49 F2 720 F5 740 XPEBFR-L1-0000-00C01 Note: • For additional order codes NOT recommended for new designs please see the Appendix section starting on page 43. • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements, ±2 on CRI measurements and ±1 on dominant wavelength measurements. See the Measurements section (page 36). • XLamp XP-E2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Calculated Photosynthetic Photon Flux (PPF) values are for reference only. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 13 XLAMP ® XP-E2 LED Relative Spectral Power RELATIVE SPECTRAL POWER DISTRIBUTION Relative Radiant Power 100% 90% 80% 70% 60% Cool White 50% Warm White 40% 30% 20% 10% 0% 380 430 480 530 580 630 Relative Spectral PowerWavelength (nm) 680 730 780 PC Amber from 220823 XPEB+ PCA Datasheet 1.5A Max.xlsx Photo Red & Far Red from XPEB FR and XPEB PR Updated Datasheet LIVT 1500mA.xlsx 100% Royal Blue Relative Radiant Power 80% Blue Green 60% PC Amber Amber Red-Orange 40% Red Photo Red Far Red 20% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 14 XLAMP ® XP-E2 LED Relative Flux Output vs. Junction Temperature RELATIVE FLUX VS. JUNCTION TEMPERATURE (IF = 350 mA) Relative Luminous Flux 120% 100% 80% White 60% 40% 20% 0% Relative Flux Output Temperature 25 50 vs. Junction 75 100 125 Photo Red & Far Red from XPEB FR and XPEB PR Updated Datasheet LIVT 1500mA.xlsx 150 Junction Temperature (ºC) 120% Relative Radiant Flux 100% 80% Royal Blue Photo Red 60% Far Red 40% 20% 0% 25 50 75 100 Relative Flux Output vs. Junction Temperature 125 150 Junction Temperature (ºC) PC Amber from 220823 XPEB+ PCA Datasheet 1.5A Max.xlsx 120% Relative Luminous Flux 100% 80% Blue Green 60% PC Amber 40% Amber Red-Orange, Red 20% 0% 25 50 75 100 125 150 Junction Temperature (ºC) © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 15 XLAMP ® XP-E2 LED Electrical Characteristics (Tj = 25ºC) - WHITE (T = 85 °C) ELECTRICAL CHARACTERISTICS J 1500 Forward Current (mA) 1250 1000 750 White 500 250 0 2.65 2.75 2.85 2.95 3.05 3.15 3.25 3.35 Forward Voltage (V) Electrical Characteristics (Tj = 85ºC) PC Amber from 220823 XPEB+ PCA Datasheet 1.5A Max.xlsx Photo Red & Far Red from XPEB FR and XPEB PR Updated Datasheet LIVT 1500mA.xlsx ELECTRICAL CHARACTERISTICS - COLOR (TJ = 25 °C) 1500 Forward Current (mA) 1250 Royal Blue Blue 1000 Green PC Amber 750 Amber Red-Orange, Red 500 Photo Red Far Red 250 0 1.60 1.80 2.00 2.20 2.40 2.60 2.80 3.00 3.20 3.40 3.60 Forward Voltage (V) © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 16 XLAMP ® XP-E2 LED Relative Intensity vs. Current (Tj = 85ºC) RELATIVE FLUX VS. CURRENT - WHITE (TJ = 85 °C) 300% Relative Luminous Flux 250% 200% White 150% 100% 50% 0% RELATIVE 0 250 500 750 Current (mA) Relative Intensity vs. Current (TjForward = 25ºC) 1000 1250 1500 Photo Red & Far Red from XPEB and XPEB(T PR = Updated Datasheet LIVT 1500mA.xlsx FLUX VS. CURRENT - FR COLOR 25 °C) J 420% Relative Radiant Flux 360% 300% Royal Blue 240% Photo Red Far Red 180% 120% 60% Relative Intensity vs. Current (Tj = 25ºC) 0% PC Amber from 220823 XPEB+ PCA Datasheet 1.5A Max.xlsx 0 250 500 750 1000 1250 1500 Forward Current (mA) 420% Relative Luminous Flux 360% 300% Blue Green 240% PC Amber 180% Amber Red-Orange, Red 120% 60% 0% 0 250 500 750 1000 1250 1500 Forward Current (mA) © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 17 XLAMP ® XP-E2 LED Relative Chromaticity Vs. Current, WW RELATIVE CHROMATICITY VS. CURRENT AND TEMPERATURE - WARM WHITE* 0.020 T = 85 °C J 0.015 0.010 0.005 ΔCCx 0.000 ΔCCy -0.005 -0.010 -0.015 Relative Chromaticity Vs. Temperature WW -0.020 0 250 500 750 1000 1250 1500 Current (mA) 0.020 I = 350 mA F 0.015 0.010 0.005 ΔCCx 0.000 ΔCCy -0.005 -0.010 -0.015 -0.020 0 25 50 75 100 125 150 Tsp (°C) * Warm White XLamp XP-E2 LEDs have a typical CRI of 80. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 18 XLAMP ® XP-E2 LED Typical Spatial Radiation Pattern TYPICAL SPATIAL DISTRIBUTION 100% Relative Luminous Intensity 80% 60% White 40% 20% 0% Typical Spatial Radiation Pattern -90 -70 -50 -30 -10 PC Amber from 210506 XPEB+ PCA Preliminary Datasheet.xlsx 10 30 50 70 90 Angle (°) 100% Relative Luminous Intensity 80% Royal Blue, Blue, Green 60% PC Amber Amber, Red-Orange, Red Photo Red 40% Far Red 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 19 XLAMP ® XP-E2 LED THERMAL DESIGN The maximum forward current is determined by the thermal resistance between the LED junction and ambient. It is crucial for the end product to be designed in a manner that minimizes the thermal resistance from the solder point to ambient in order to optimize lamp life and optical characteristics. Thermal Design - royal blue 1600 1600 1400 1400 Maximum Current (mA) Maximum Current (mA) White Royal Blue 1200 1000 800 600 Rj-a = 11°C/W 400 Rj-a = 20°C/W 0 20 40 Thermal Design - blue 800 600 Rj-a = 10°C/W Rj-a = 15°C/W Rj-a = 20°C/W 200 Rj-a = 25°C/W 0 1000 400 Rj-a = 15°C/W 200 1200 60 80 100 120 140 = 25°C/W Thermal Design -Rj-agreen 0 160 0 20 40 Ambient Temperature (ºC) 60 80 100 120 140 160 100 120 140 160 100 120 140 160 Ambient Temperature (ºC) 1600 1600 1400 1400 1200 1200 Maximum Current (mA) Maximum Current (mA) Blue Green 1000 800 600 Rj-a = 10°C/W 400 Rj-a = 15°C/W Rj-a = 20°C/W 200 1000 800 600 Rj-a = 10°C/W 400 Rj-a = 15°C/W Rj-a = 20°C/W 200 Rj-a = 25°C/W Rj-a = 25°C/W 0 0 20 40 Thermal Design - PC amber 60 80 100 120 Ambient Temperature (ºC) 0 160 20 Thermal Design0 - amber 140 40 60 80 Ambient Temperature (ºC) PC Amber from 220823 XPEB+ PCA Datasheet 1.5A Max.xlsx 1600 1600 1400 1400 1200 1200 Maximum Current (mA) Maximum Current (mA) PC Amber Amber 1000 800 600 Rj-a = 10°C/W 400 Rj-a = 15°C/W 0 20 600 Rj-a = 10°C/W 400 Rj-a = 15°C/W Rj-a = 20°C/W Rj-a = 25°C/W Rj-a = 25°C/W 0 800 200 Rj-a = 20°C/W 200 1000 0 40 60 80 Ambient Temperature (ºC) 100 120 140 160 0 20 40 60 80 Ambient Temperature (ºC) © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 20 XLAMP ® XP-E2 LED Thermal Design -DESIGN red-orange, red THERMAL - CONTINUED Thermal Design - photo red 1600 1600 1400 1400 1200 1200 Maximum Current (mA) Maximum Current (mA) Photo Red from XPEB FR and XPEB PR Updated Datasheet LIVT 1500mA.xlsx Red-Orange, Red Photo Red 1000 800 600 Rj-a = 10°C/W 400 Rj-a = 15°C/W Rj-a = 20°C/W 200 1000 800 600 Rj-a = 10°C/W 400 Rj-a = 15°C/W Rj-a = 20°C/W 200 Rj-a = 25°C/W 0 0 20 Rj-a = 25°C/W 40 60 80 100 120 140 160 Ambient Temperature (ºC) Thermal Design - far red 0 0 20 40 60 80 100 120 140 160 Ambient Temperature (ºC) Far Red from XPEB FR and XPEB PR Updated Datasheet LIVT 1500mA.xlsx Far Red 1600 1400 Maximum Current (mA) 1200 1000 800 600 Rj-a = 10°C/W 400 Rj-a = 15°C/W Rj-a = 20°C/W 200 Rj-a = 25°C/W 0 0 20 40 60 80 100 120 140 160 Ambient Temperature (ºC) © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 21 XLAMP ® XP-E2 LED PERFORMANCE GROUPS - LUMINOUS FLUX XLamp XP-E2 LEDs (except royal blue, photo red and far red) are tested for luminous flux and placed into one of the following luminous‑flux groups: Group Code Minimum Luminous Flux (lm) @ 350 mA Maximum Luminous Flux (lm) @ 350 mA K2 30.6 35.2 K3 35.2 39.8 M2 39.8 45.7 M3 45.7 51.7 N2 51.7 56.8 N3 56.8 62.0 N4 62.0 67.2 P2 67.2 73.9 P3 73.9 80.6 P4 80.6 87.4 Q2 87.4 93.9 Q3 93.9 100 Q4 100 107 Q5 107 114 R2 114 122 R3 122 130 R4 130 139 R5 139 148 S2 148 156 S3 156 164 S4 164 172 S5 172 180 © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 22 XLAMP ® XP-E2 LED PERFORMANCE GROUPS - RADIANT FLUX (TJ = 25 °C) XLamp XP-E2 royal blue LEDs are tested for radiant flux and placed into one the following bins: Group Minimum Radiant Flux (mW) @ 350 mA Maximum Radiant Flux (mW) @ 350 mA 36 600 625 37 625 650 38 650 675 39 675 700 40 700 725 XLamp XP-E2 photo red LEDs are tested for radiant flux and placed into one the following bins: Group Minimum Radiant Flux (mW) @ 350 mA Maximum Radiant Flux (mW) @ 350 mA 29 425 450 30 450 475 31 475 500 32 500 525 XLamp XP-E2 far red LEDs are tested for radiant flux and sorted into one of the following radiant‑flux bins: Group Minimum Radiant Flux (mW) @ 350 mA Maximum Radiant Flux (mW) @ 350 mA 26 350 375 27 375 400 28 400 425 29 425 450 © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 23 XLAMP ® XP-E2 LED PERFORMANCE GROUPS - CHROMATICITY White XLamp XP-E2 LEDs are tested for chromaticity and placed into one of the regions defined by the bounding coordinates on the following pages. Region 0A 0R 1A 1R 2A 2R 3A 3R 4A x y 0.2950 0.2920 0.2984 0.3133 0.3009 0.3042 0.2980 0.2880 0.2950 0.2970 0.3009 0.3042 0.3037 0.3048 0.3130 0.3290 0.3144 0.3186 0.3068 0.3113 0.3068 0.3144 0.3161 0.3059 0.3093 0.3215 0.3290 0.3417 0.3290 0.3300 0.3222 Region x y 0.2970 0.2920 0.3060 0.2895 x y 0.3060 0.2984 0.3135 0.2962 0.2962 0.3220 0.2984 0.3133 0.3028 0.3304 0.3048 0.3207 0.2895 0.3135 0.2962 0.3220 0.2870 0.3210 0.2937 0.3312 0.2937 0.3312 0.3005 0.3415 0.2937 0.2962 0.3207 0.3028 0.3220 0.3028 0.3304 0.3115 0.3115 0.3391 0.3205 0.3481 0.3130 0.3290 0.3048 0.3207 0.3213 0.3373 0.3130 0.3290 0.3113 0.3005 0.3186 0.3099 0.3415 0.3099 0.3509 0.3196 0.3115 0.3391 0.3205 0.3481 0.2993 0.3028 0.3350 0.3207 0.3304 0.3115 0.3462 0.3290 0.3290 0.3538 0.3290 0.3417 0.3376 0.3616 0.3371 0.3490 0.3243 0.3215 0.3350 0.3290 0.3417 0.3222 0.3243 0.3290 0.3300 0.3196 0.3602 0.3290 0.3290 0.3690 0.3381 0.3290 0.3180 0.3231 0.3120 0.3290 0.3538 0.3376 0.3616 0.3207 0.3462 0.3290 0.3538 0.3371 0.3451 0.3490 0.3376 0.3616 0.3463 0.3554 0.3463 0.3687 0.3551 0.3440 0.3427 0.3451 0.3554 0.3533 0.3620 0.3366 0.3366 0.3369 0.3371 0.3490 0.3451 0.3554 0.3369 0.3381 0.3762 0.3440 0.3428 0.3429 0.3307 0.3480 0.3840 0.3463 0.3687 0.3361 0.3245 0.3376 0.3616 0.3530 0.3597 0.3548 0.3736 0.3641 0.3615 0.3659 0.3641 0.3804 0.3736 0.3590 0.3521 0.3615 0.3659 0.3702 0.3722 0.3512 0.3465 0.3530 0.3597 0.3615 0.3659 0B 0S 1B 1S 2B 2S 3B 3S 4B Region 0C 0T 1C 1T 2C 2T 3C 4C x y 0.3133 0.2984 0.3133 0.3220 0.3048 0.3207 0.3068 0.3113 0.3009 0.3042 0.3037 0.2937 0.3009 0.3042 0.3068 0.3113 0.3304 0.3093 0.2993 0.3391 0.3130 0.3290 0.3213 0.3373 0.3221 0.3261 0.3144 0.3186 0.3509 0.3144 0.3186 0.3602 0.3221 0.3261 0.3231 0.3120 0.3391 0.3161 0.3059 0.3538 0.3290 0.3417 0.3371 0.3490 0.3366 0.3369 0.3290 0.3300 0.3690 0.3290 0.3300 0.3762 0.3366 0.3369 0.3361 0.3245 0.3290 0.3180 0.3687 0.3451 0.3554 0.3760 0.3533 0.3620 0.3515 0.3487 0.3440 0.3427 0.3804 0.3615 0.3659 0.3874 0.3702 0.3722 0.3670 0.3578 0.3590 0.3521 © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Region 0D 0U 1D 1U 2D 2U 3D 4D CLD-DS56 REV 20 24 XLAMP ® XP-E2 LED PERFORMANCE GROUPS - CHROMATICITY (CONTINUED) Region 5A1 5B1 5C1 5D1 6A1 6B1 6C1 6D1 7A1 7B1 x y 0.3670 0.3686 0.3744 0.3685 0.3726 0.3702 0.3719 0.3797 0.3782 0.3837 0.3763 0.3825 0.3847 0.3877 0.3912 0.3917 0.3887 0.3836 0.3783 0.3804 0.3863 0.3758 0.3840 0.3889 0.3915 0.3768 0.3981 0.3800 0.3953 Region x y 0.3578 0.3686 0.3649 0.3702 x y 0.3649 0.3744 0.3722 0.3763 0.3763 0.3760 0.3825 0.3798 0.3612 0.3744 0.3722 0.3719 0.3685 0.3804 0.3797 0.3782 0.3736 0.3874 0.3802 0.3916 0.3802 0.3916 0.3869 0.3958 0.3760 0.3782 0.3798 0.3847 0.3837 0.3847 0.3877 0.3912 0.3869 0.3958 0.3937 0.4001 0.3937 0.4001 0.3912 0.3917 0.4006 0.4044 0.3978 0.3958 0.3646 0.3804 0.3721 0.3825 0.3721 0.3863 0.3798 0.3887 0.3887 0.3836 0.3950 0.3875 0.3681 0.3863 0.3690 0.3915 0.3758 0.3924 0.3768 0.3981 0.3941 0.3848 0.4010 0.3882 0.4010 0.3882 0.4080 0.3916 0.3720 0.3981 0.3800 0.4048 0.3832 0.3941 0.3848 0.3968 0.3930 0.3968 0.3930 0.4040 0.3996 0.4015 0.4071 0.4040 0.3966 0.4010 0.3882 0.4071 0.4052 0.4146 0.4089 0.4040 0.3966 0.4113 0.4001 0.4080 0.3916 0.4113 0.4001 0.4186 0.4037 0.4113 0.4001 0.4186 0.4037 0.4146 0.4089 0.4222 0.4127 0.4222 0.4127 0.4299 0.4165 0.4150 0.4017 0.3950 0.4186 0.4037 0.4259 0.3751 0.4048 0.3832 0.4116 0.4048 0.3832 0.4116 0.3865 0.4080 0.3916 0.4150 0.3950 0.4150 0.3950 0.4221 0.3984 0.4082 0.3782 0.4116 0.3865 0.4183 0.3898 0.4147 0.3814 0.4183 0.3898 0.4242 0.4183 0.3898 0.4221 0.3984 0.4281 0.4242 0.3919 0.4281 0.4006 0.4342 0.4028 0.4203 0.3833 0.4242 0.3919 0.4300 0.3939 0.4221 0.3984 0.4259 0.4073 0.4322 0.4096 0.4259 0.4073 0.4299 0.4165 0.4364 0.4188 0.4322 0.4096 0.4364 0.4188 0.4430 0.4212 0.4281 0.4006 0.4322 0.4096 0.4385 0.4119 5A2 5B2 5C2 5D2 6A2 6B2 6C2 6D2 7A2 7B2 Region 5A3 5B3 5C3 5D3 6A3 6B3 6C3 6D3 7A3 7B3 x y 0.3685 0.3726 0.3612 0.3760 0.3744 0.3685 0.3804 0.3721 0.3721 0.3783 0.3646 0.3837 0.3763 0.3760 0.3782 0.3837 0.3847 0.3877 0.3877 0.3825 0.3798 0.3917 0.3887 0.3836 0.3912 0.3917 0.3978 0.3958 0.3950 0.3875 0.3758 0.3840 0.3681 0.3836 0.3863 0.3758 0.3924 0.3794 0.3794 0.3898 0.3716 0.3800 0.3953 0.3720 0.3981 0.3800 0.4048 0.3832 0.4017 0.3751 0.3966 0.4010 0.3882 0.4052 0.4040 0.3966 0.4113 0.4001 0.4080 0.3916 0.4150 0.3950 0.4186 0.4037 0.4259 0.4073 0.4073 0.4221 0.3984 0.3865 0.4082 0.3782 0.4116 0.3865 0.4183 0.3898 0.4147 0.3814 0.3919 0.4203 0.3833 0.4006 0.4242 0.3919 0.4300 0.3939 0.4259 0.3853 0.4281 0.4006 0.4322 0.4096 0.4385 0.4119 0.4342 0.4028 © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Region 5A4 5B4 5C4 5D4 6A4 6B4 6C4 6D4 7A4 7B4 CLD-DS56 REV 20 25 XLAMP ® XP-E2 LED PERFORMANCE GROUPS - CHROMATICITY (CONTINUED) Region 7C1 7D1 8A1 8B1 8C1 8D1 AA1 AB1 AC1 AD1 x y 0.4342 0.4385 0.4449 0.4141 0.4403 0.4259 0.4300 0.3939 0.4359 0.3960 0.4316 0.4373 0.4418 0.3981 0.4475 0.3994 0.4428 0.3906 0.4465 0.4513 0.4573 0.4178 0.4523 0.4582 0.4634 0.4193 0.4695 0.4207 0.4641 Region x y 0.4028 0.4385 0.4119 0.4430 x y 0.4119 0.4449 0.4212 0.4496 0.4496 0.4236 0.4562 0.4260 0.4049 0.4449 0.3853 0.4300 0.4141 0.4513 0.3939 0.4359 0.4342 0.4028 0.4403 0.4049 0.4403 0.4049 0.4465 0.4071 0.3873 0.4359 0.3893 0.4418 0.3960 0.4418 0.3981 0.4475 0.4465 0.4071 0.4523 0.4085 0.4523 0.4085 0.4475 0.3994 0.4582 0.4099 0.4532 0.4008 0.4071 0.4513 0.4164 0.4562 0.4164 0.4573 0.4260 0.4624 0.4624 0.4274 0.4687 0.4289 0.4085 0.4573 0.4099 0.4634 0.4178 0.4634 0.4193 0.4695 0.4687 0.4289 0.4750 0.4304 0.4750 0.4304 0.4813 0.4319 0.4112 0.4695 0.4207 0.4756 0.4221 0.4483 0.3919 0.4532 0.4008 0.4532 0.4008 0.4589 0.4582 0.4099 0.4641 0.4589 0.4021 0.4538 0.3931 0.4641 0.4112 0.4700 0.4126 0.4589 0.4021 0.4646 0.4034 0.4822 0.4884 0.3973 0.4884 0.4067 0.4942 0.4067 0.4946 0.4162 0.5006 0.4942 0.4066 0.5006 0.4160 0.5066 0.4158 0.4879 0.4946 0.3972 0.4942 0.4066 0.5001 0.4162 0.5008 0.4256 0.5069 0.5008 0.4256 0.5069 0.4254 0.5070 0.4350 0.5133 0.4348 0.5133 0.4348 0.5196 0.4346 0.5006 0.4160 0.5069 0.4254 0.5131 0.4252 0.5066 0.4158 0.5131 0.4252 0.5192 0.5131 0.4252 0.5196 0.4346 0.5258 0.5192 0.4250 0.5258 0.4343 0.5321 0.4341 0.5126 0.4156 0.5192 0.4250 0.5253 0.4248 0.4936 0.3970 0.5001 0.4064 0.5059 0.4062 0.5001 0.4064 0.5066 0.4158 0.5126 0.4156 0.5059 0.4062 0.5126 0.4156 0.5186 0.4154 0.4993 0.3969 0.5059 0.4062 0.5118 0.4061 7C2 7D2 8A2 8B2 8C2 8D2 AA2 AB2 AC2 AD2 Region 7C3 7D3 8A3 8B3 8C3 8D3 AA3 AB3 AC3 AD3 x y 0.4141 0.4403 0.4049 0.4236 0.4449 0.4141 0.4513 0.4164 0.4164 0.4465 0.4071 0.3960 0.4316 0.3873 0.4359 0.3960 0.4418 0.3981 0.3981 0.4373 0.3893 0.3994 0.4428 0.3906 0.4475 0.3994 0.4532 0.4008 0.4483 0.3919 0.4178 0.4523 0.4085 0.4274 0.4573 0.4178 0.4634 0.4193 0.4193 0.4582 0.4099 0.4207 0.4641 0.4112 0.4695 0.4207 0.4756 0.4221 0.4700 0.4126 0.4021 0.4538 0.3931 0.4112 0.4589 0.4021 0.4646 0.4034 0.4593 0.3944 0.4066 0.4879 0.3972 0.4160 0.4942 0.4066 0.5001 0.4064 0.4064 0.4936 0.3970 0.4254 0.5006 0.4160 0.5069 0.4254 0.5131 0.4252 0.5066 0.4158 0.4250 0.5126 0.4156 0.4343 0.5192 0.4250 0.5253 0.4248 0.5186 0.4154 0.4993 0.3969 0.5059 0.4062 0.5118 0.4061 0.5050 0.3967 © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Region 7C4 7D4 8A4 8B4 8C4 8D4 AA4 AB4 AC4 AD4 CLD-DS56 REV 20 26 XLAMP ® XP-E2 LED PERFORMANCE GROUPS - CHROMATICITY (CONTINUED) XLamp XP-E2 PC amber LEDs are placed into the region defined by the following bounding coordinates. Region Y2 x y 0.5469 0.4249 0.5700 0.4100 0.5900 0.4100 0.5610 0.4390 PERFORMANCE GROUPS - DOMINANT WAVELENGTH Color XLamp XP-E2 LEDs are tested for dominant wavelength (DWL) and sorted into one of the DWL bins defined below. Color Royal Blue Blue Green Amber Red-Orange Red DWL Group Minimum DWL (nm) @ 350 mA Maximum DWL (nm) @ 350 mA D3 450 455 D4 455 460 D5 460 465 B3 465 470 B4 470 475 B5 475 480 B6 480 485 G2 520 525 G3 525 530 G4 530 535 A2 585 590 A3 590 595 O3 610 615 O4 615 620 R2 620 625 R3 625 630 © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 27 XLAMP ® XP-E2 LED PERFORMANCE GROUPS - PEAK WAVELENGTH Photo red and far red XLamp XP-E2 LEDs are tested for peak wavelength (PWL) and sorted into one of the PWL bins defined below. Color Photo Red Far Red PWL Group Minimum PWL (nm) @ 350 mA Maximum PWL (nm) @ 350 mA P2 650 655 P3 655 660 P4 660 665 P5 665 670 F2 720 725 F3 725 730 F4 730 735 F5 735 740 PERFORMANCE GROUPS - FORWARD VOLTAGE Amber, red-orange, red, photo red and far red XLamp XP-E2 LEDs are tested for forward voltage and sorted into one of the forward voltage bins defined below. Forward Voltage Group Minimum Forward Voltage (V) @ 350 mA Maximum Forward Voltage (V) @ 350 mA A 1.5 1.75 B 1.75 2.0 C 2.0 2.25 D 2.25 2.5 E 2.5 2.75 F 2.75 3.0 G 3.0 3.25 H 3.25 3.5 J 3.5 3.75 © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 28 XLAMP ® XP-E2 LED STANDARD COOL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS 0.40 0.40 5000 K 0.39 0.38 3S 51 6500 K 0.36 8000 K 0T 0C 0D 0A 0S 0.32 0.31 1R 0C 0B 1R 0.30 0.29 0.28 0.36 0.35 0.34 0.33 0.32 0.28 0.31 0.28 0.30 0.29 CCx 0.36 0R 0R 0.29 1U 0U 0.30 0.29 0.28 ANSI C78.377A 2R 1A 0D 0A 0U 2U 1D 0.35 0.30 1U 3R 2A 1B 0.34 0.31 ANSI C78.377A 2R 1A 2D 1C 0.33 0B 0T 0.33 2U 1D 3A 2B 1S 0.32 0S 0.32 3R 2A 1B 0.34 0.31 0.33 3B 2C 1T 8000 K 3A 2D 1C 3S 2T 2S 0.35 2B 1S 0.36 3B CCy 0.34 53 6500 K 2C 1T 5700 K 0.37 2T 2S 0.35 CCy 0.38 5700 K 0.37 5000 K 0.39 CCx 0.40 5000 K 0.39 0.38 5700 K 6500 K 0.36 2T 3B 2S 0.35 2C 1T 8000 K 0.34 CCy 3S 50 0.37 0T 0.33 0S 0.32 0.31 0C 3R 2A 1D 2U ANSI C78.377A 2R 1A 1U 0D 0A 2D 1C 1B 0B 3A 2B 1S 1R 0U 0.30 0R 0.29 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.28 CCx 0.40 0.40 5000 K 0.39 0.38 0.38 5700 K 3S 0.37 6500 K 1T 0T 0.33 0S 0.32 0C 8000 K 0.34 0T ANSI C78.377A 2R 1U 0S 0.32 1R 0.31 0U 0.30 0C 0A 2U ANSI C78.377A 2R 1U 1R 0U 0.30 0R 3R 2A 1D 1A 0D 2D 1C 1B 0B 3A 2B 1S 0.33 2U 2C 1T 3R 2A 1D 1A 0D 0A 2D 1C 1B 0B 0.31 3A 2B 1S 3B 2S 0.35 0R 0.29 0.29 © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.36 0.35 0.34 0.28 0.29 CCx 0.33 0.32 0.31 0.30 0.29 0.28 0.28 0.28 CCy 2C 3S 2T 0.36 3B 2S 8000 K 0.34 6500 K 2T E1 0.35 5700 K E2 0.37 CCy 0.36 5000 K 0.39 CCx CLD-DS56 REV 20 29 XLAMP ® XP-E2 LED STANDARD WARM AND NEUTRAL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS 0.46 0.45 2700 K 3000 K 0.44 0.43 0.42 4000 K 0.41 E6 4500 K E5 0.40 CCy E7 3500 K 5000 K 0.39 0.38 E3 0.37 0.36 E4 4C 4B 3C 4D 3B 6B2 5C3 5C2 5B3 6D2 6A3 5B4 5D3 6A2 5D2 6A4 5A3 5D4 6A1 5A2 5D1 5A4 5A1 5B1 6D1 7A4 7A1 6D4 7D1 8B2 8B3 8C1 8B4 8C2 8C3 8C4 8D3 8D2 8D4 8A4 8D1 8A1 7D4 8A3 8A2 7D3 7D2 7A3 7A2 6D3 8B1 7C4 7C1 7B4 7B1 6C4 6C1 6B4 5C4 6B1 5C1 5B2 6C3 6C2 6B3 7C2 7B3 7B2 7C3 E8 ANSI C78.377A 4A 3D 0.35 3A 0.34 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.33 CCx 0.46 0.45 2700 K 3000 K 0.44 0.43 3500 K 0.42 4000 K 0.41 4500 K CCy 0.40 F5 5000 K 0.39 F4 0.38 0.37 4B 4D 3B 5C4 5C1 5B4 3C 0.36 5B3 5B1 5D2 5A3 5D4 6A1 5A2 5D1 5A4 5A1 6C2 6B3 6B4 6B1 5D3 6A2 6A3 6A4 7B2 6C3 6B2 5C3 5C2 5B2 4C F6 F7 6C1 6D2 6D1 7B1 6C4 6D3 6D4 7A2 7A1 7A4 F8 7A3 7D1 7C2 7B3 7B4 7C1 7D4 8B1 7C4 7D3 7D2 7C3 8A1 8A2 8A3 8B2 8B3 8B4 8D2 8C1 8C2 8C3 8C4 8D3 8D4 8A4 8D1 ANSI C78.377A 4A 3D 0.35 3A 0.34 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.33 CCx © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 30 XLAMP ® XP-E2 LED STANDARD WARM AND NEUTRAL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS CONTINUED 0.46 0.45 2700 K 3000 K 0.44 0.43 0.42 Z6 4000 K 0.41 Z5 4500 K 0.40 CCy Z7 3500 K 6C3 6C2 6B3 6B2 5C3 5000 K 0.39 5C2 5B3 5C1 5B2 5B4 0.38 4C 0.37 4B 3C 0.36 4D 3B 5D3 6A2 5B1 5D2 5A3 5D4 6A1 5A2 5D1 5A4 5A1 6C1 6B4 5C4 6B1 6A3 6A4 6D2 6D1 7B1 6C4 6D3 6D4 7A2 7A4 7A1 7C1 7B4 7A3 7D1 7C2 7B3 7B2 7D4 8B1 7C4 7D3 7D2 7C3 8A1 8A2 8A3 8B2 Z8 8B3 8B4 8D2 8C1 8C2 8C3 8C4 8D3 8D4 8A4 8D1 ANSI C78.377A 4A 3D 0.35 3A 0.34 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.33 CCx PC AMBER KIT PLOTTED ON THE 1931 CIE CURVE 0.46 0.45 CCy 0.44 Y2 0.43 0.42 0.41 0.61 0.60 0.59 0.58 0.57 0.56 0.55 0.54 0.53 0.40 CCx © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 31 XLAMP ® XP-E2 LED 2200 K CCT WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS 0.45 0.44 3000 K 0.43 0.42 8B1 7C4 CCy 0.41 8A3 8A2 7D3 0.40 8B2 7C3 7C2 8D1 8A4 8A1 8B3 8B4 8D2 8C1 8C2 EA 2450 K 2700 K 2200 K AB2 AB3 AC2 AB4 AC1 AC4 8C3 AB1 AC3 8C4 AA2 AA3 AD2 AD3 8D3 AA1 AA4 AD1 8D4 AD4 0.39 0.38 0.37 0.53 0.54 0.55 0.53 0.54 0.55 0.52 0.51 0.50 0.49 0.48 0.47 0.46 0.45 0.44 0.36 CCx 0.45 0.44 3000 K 0.43 0.42 CCy 8B1 7C4 0.41 0.40 7C3 7C2 7D3 8A1 8A3 8A2 8A4 8D1 8B3 8B2 8B4 8D2 8C1 8C2 ZA 2450 K 2700 K 2200 K AB2 AB3 AC2 AB4 AC1 AC4 8C3 AB1 AC3 8C4 AA2 AA3 AD2 AD3 8D3 AA1 AA4 AD1 8D4 AD4 0.39 0.38 0.37 0.52 0.51 0.50 0.49 0.48 0.47 0.46 0.45 0.44 0.36 CCx © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 32 XLAMP ® XP-E2 LED STANDARD CHROMATICITY KITS The following table provides the chromaticity bins associated with chromaticity kits. Color Cool White Neutral White Warm White CCT Kit Chromaticity Bins 6200 K 51 0A, 0B, 0C, 0D, 0R, 0S, 0T, 0U, 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U, 2A, 2B, 2C, 2D, 2R, 2S, 2T, 2U, 3A, 3B, 3R, 3S 6000 K 53 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U, 2A, 2B, 2C, 2D, 2R, 2S, 2T, 3A, 3B, 3S 6200 K 50 1A, 1B, 1C, 1D, 2A, 2B, 2C, 2D 6500 K E1 1A, 1B, 1C, 1D 5700 K E2 2A, 2B, 2C, 2D 5000 K E3 3A, 3B, 3C, 3D 4750 K F4 3C, 3D, 4A, 4B 4500 K E4 4A, 4B, 4C, 4D 4250 K F5 4C, 4D, 5A1, 5A2, 5A3, 5A4, 5B1, 5B2, 5B3, 5B4 4000 K E5 5A1, 5A2, 5A3, 5A4, 5B1, 5B2, 5B3, 5B4, 5C1, 5C2, 5C3, 5C4, 5D1, 5D2, 5D3, 5D4 4000 K Z5 5A3, 5B4, 5C1, 5D2 3750 K F6 5C1, 5C2, 5C3, 5C4, 5D1, 5D2, 5D3, 5D4, 6A1, 6A2, 6A3, 6A4, 6B1, 6B2, 6B3, 6B4 3500 K E6 6A1, 6A2, 6A3, 6A4, 6B1, 6B2, 6B3, 6B4, 6C1, 6C2, 6C3, 6C4, 6D1, 6D2, 6D3, 6D4 3500 K Z6 6A3, 6B4, 6C1, 6D2 3250 K F7 6C1, 6C2, 6C3, 6C4, 6D1, 6D2, 6D3, 6D4, 7A1, 7A2, 7A3, 7A4, 7B1, 7B2, 7B3, 7B4 3000 K E7 7A1, 7A2, 7A3, 7A4, 7B1, 7B2, 7B3, 7B4, 7C1, 7C2, 7C3, 7C4, 7D1, 7D2, 7D3, 7D4 3000 K Z7 7A3, 7B4, 7C1, 7D2 2850 K F8 7C1, 7C2, 7C3, 7C4, 7D1, 7D2, 7D3, 7D4, 8A1, 8A2, 8A3, 8A4, 8B1, 8B2, 8B3, 8B4 2700 K E8 8A1, 8A2, 8A3, 8A4, 8B1, 8B2, 8B3, 8B4, 8C1, 8C2, 8C3, 8C4, 8D1, 8D2, 8D3, 8D4 2700 K Z8 8A3, 8B4, 8C1, 8D2 2200 K EA AA1, AA2, AA3, AA4, AB1, AB2, AB3, AB4, AC1, AC2, AC3, AC4, AD1, AD2, AD3, AD4 2200 K ZA AA3, AB4, AC1, AD2 © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 33 XLAMP ® XP-E2 LED BIN AND ORDER CODE FORMATS XP-E2 bin codes and order codes are configured in the following manner: Order Code SSSCCC-BD-HHHH-NNNNN Bin Code Series XPE = XP-E Series XPE = XP-E Color specification 01 = Outdoor White L1 = Standard CRI H1 = 80 CRI minimum P1 = 85 CRI minimum U1 = 90 CRI minimum Color specification 01 = Outdoor White L1 = Standard CRI H1 = 80 CRI minimum P1 = 85 CRI minimum U1 = 90 CRI minimum Kit Number Luminous or radiant flux group Internal code Color BWT = Gen 2 White BRY = Gen 2 Royal Blue BBL = Gen 2 Blue BGR = Gen 2 Green BPA = Gen 2 PC Amber BAM = Gen 2 Amber BRO = Gen 2 Red-Orange BRD = Gen 2 Red BPR = Gen 2 Photo Red BFR = Gen 2 Far Red Internal code SSSCCC-BD-WWW-FF-G-AA © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Voltage performance group Chromaticity bin or dominant-wavelength group Color BWT = Gen 2 White BRY = Gen 2 Royal Blue BBL = Gen 2 Blue BGR = Gen 2 Green BPA = Gen 2 PC Amber BAM = Gen 2 Amber BRO = Gen 2 Red-Orange BRD = Gen 2 Red BPR = Gen 2 Photo Red BFR = Gen 2 Far Red CLD-DS56 REV 20 34 XLAMP ® XP-E2 LED REFLOW SOLDERING CHARACTERISTICS In testing, Cree LED has found XLamp XP-E2 LEDs to be compatible with JEDEC J-STD-020C, using the parameters listed below. As a general guideline, Cree LED recommends that users follow the recommended soldering profile provided by the manufacturer of the solder paste used, and therefore it is the lamp or luminaire manufacturer’s responsibility to determine applicable soldering requirements. Note that this general guideline may not apply to all PCB designs and configurations of reflow soldering equipment. tP TP Critical Zone TL to TP Temperature Ramp-up TL tL Tsmax Tsmin Ramp-down ts Preheat 25 t 25˚C to Peak IPC/JEDEC J-STD-020C Time Profile Feature Average Ramp-Up Rate (Tsmax to Tp) Lead-Free Solder 1.2 °C/second Preheat: Temperature Min (Tsmin) 120 °C Preheat: Temperature Max (Tsmax) 170 °C Preheat: Time (tsmin to tsmax) 65-150 seconds Time Maintained Above: Temperature (TL) Time Maintained Above: Time (tL) Peak/Classification Temperature (Tp) 217 °C 45-90 seconds 235 - 245 °C Time Within 5 °C of Actual Peak Temperature (tp) 20-40 seconds Ramp-Down Rate 1 - 6 °C/second Time 25 °C to Peak Temperature 4 minutes max. Note: All temperatures refer to topside of the package, measured on the package body surface. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 35 XLAMP ® XP-E2 LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Lumen Maintenance Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. Moisture Sensitivity Cree LED recommends keeping XLamp LEDs in the provided, resealable moisture-barrier packaging (MBP) until immediately prior to soldering. Unopened MBPs that contain XLamp LEDs do not need special storage for moisture sensitivity. Once the MBP is opened, XLamp XP-E2 LEDs may be stored as MSL 1 per JEDEC J-STD-033, meaning they have unlimited floor life in conditions of ≤ 30 ºC/85% relative humidity (RH). Regardless of the storage condition, Cree LED recommends sealing any unsoldered LEDs in the original MBP. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. REACH Compliance REACH substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative to insure you get the most up-to-date REACH SVHC Declaration. REACH banned substance information (REACH Article 67) is also available upon request. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 36 XLAMP ® XP-E2 LED NOTES - CONTINUED UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 37 XLAMP ® XP-E2 LED MECHANICAL DIMENSIONS 8 if present, are not shown 7 Thermal vias, on these drawings. 8 6 5 7 4 6 3 5 All measurements are ±.13 mm unless otherwise indicated. SOLDERMASK MAY BE PRESENT OPTICAL MODEL ORIGIN OPTICAL OPTICAL MODEL ORIGIN OPTICAL MODEL ORIGIN 2.26 MODEL ORIGIN F F CATHODE SIDE 3.30 2.40 2.30 0.73 CATHODE SIDE ANODE 0.50 SIDE 0.50 ANODE SIDE 3.30 3.45 E E R1.53 R1.53 3.45 3.45 1.30 0.58 TOP VIEW TOPView VIEW Top 4 5 ANODE SIDE CENTER IS ELECT ISOLATE SIDE VIEW SIDE VIEW Side View BOTTOM VIEW Side View - PC Amber 1 2 3 0.58 0.50 2.30 0.50 0.50 ANODE SIDE CATHODE SIDE C 0.50 0.56 SIDE VIEW BOTTOM VIEW Bottom View 0.50 1.30 3 (2 PLACES) P 0.18 0.50 D REC RECOMMENDED STENCIL OPENING 7 6 © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 9 TYP 0.08 Alternate Bottom View 0.18 8 7 3.30 0.50 ALTERNATE BOTTOM VIEW 3.30 RECOMMENDED PCB FOOTPRINT A 0.56 0.50 0.56 8 E 3.30 REF. RECOMMENDED PCB FOOTPRINT 0.43 0.18 0.50 A CENTER PAD IS ELECTRICALLY 0.50 1.30 ISOLATED 0.08 B 0.08 B 0.58 3.30 REF. 0.18 TYP 0.29 TYP 3.30 3.30 3.30 3.30 C 1.30 0.50 F 0.08 0.50 0.50 MAY BE PRESENT 0.50 0.43 SOLDERMASK 3.30 CENTER3.30 PAD IS ELECTRICALLY 0.56 ISOLATED 0.29 TYP 0.73 3.30 3.30 0.18 2.26 0.43 SOLDERMASK MAY BE PRESENT D 0.18 D 6 5 B PROPRIETARY AND CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF A CREE LED. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT WRITTEN PERMISSION OF CREE LED REV IS PROHIBITED. © 2021 CreeLED, Inc. a subsidiary C of SMART Global Holdings, Inc. CLD-DS56 REV 20 4 5 UPDATED OPTICAL MODEL ORIGIN INITIAL DRAWING RELEASED 38 DESCRIPTION APPLICATION 2 3 OPTICAL MODEL ORIGIN 2.26 MODEL ORIGIN 2.30 0.73 CATHODE SIDE ANODE SIDE XLAMP ® XP-E2 LED SOLDERMASK MAY BE PRESENT 3.30 F 0.50 0.50 CATHODE SIDE 3.45 3.30 ANODE SIDE E MECHANICAL DIMENSIONS - CONTINUED R1.53 Thermal vias, if present, are 3.45 not shown on these drawings. TOP VIEW 1.30 0.58 CENTER PAD IS ELECTRICALLY ISOLATED All measurements are ±.13 mmVIEW unless otherwise indicated. BOTTOM SIDE VIEW ALTERN D 3.30 0.18 3.30 0.56 0.50 0.50 0.56 0.83 (2 PLACES) 0.08 0.43 0.50 0.08 0.18 0.18 TYP 0.29 TYP 3.30 3.30 C B 0.50 1.30 0.18 0.50 Recommended Footprint RECOMMENDED PCB PCB FOOTPRINT 0.50 Recommended StencilOPENING Opening RECOMMENDED STENCIL UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS TOLERANCES: • ANGULAR: MACH 0.5° BEND 1° • ONE PLACE DECIMAL 0.5 • TWO PLACE DECIMAL 0.05 • INSIDE BEND RADII EQUAL MATERIAL • MACHINE/CASTING RADII 0.50 • RADII AND DIA: 0.10 A PROPRIETARY AND CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF CREE LED. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT WRITTEN PERMISSION OF CREE LED IS PROHIBITED. © 2021 CreeLED, Inc. a subsidiary of SMART Global Holdings, Inc. 8 7 6 5 4 © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. B UPDATED OPTICAL MODEL ORIGIN A INITIAL DRAWING RELEASED REV DESCRIPTION INTERPRET GEOMETRIC TOLERANCING PER: MATERIAL DRAWN MFG APPR. Q.A. THIRD ANGLE PROJECTION MATERIAL FINISH FINISH 3 2 CLD-DS56 REV 20 DA 24AU ENG APPR. APPLICATION 2 NAME TLING CHECKED 39 XLAMP ® XP-E2 LED TAPE AND REEL All Cree LED carrier tapes conform to EIA-481D, Automated Component Handling Systems Standard. All dimensions in mm. Po T E Do Bo R P2 W A Anode side F A P1 B D1 "H" Ko B-B SECTION Bo (on a place in the bottom of the corner radii) Ao (on a place in the bottom of the corner radii) R "I" Ao Item Dim. ITEM Ao Dim.Ao Bo 3.70 3.70 3.70 ITEM F Dim. 5.50 DETAIL"H" DETAIL"I" A-A SECTION Bo Ko3.70 2.40 Do 1.55 Ko Po 4.00 2.40 P1 D1 8.00 1.50 P1 Po P2 4.00 T 2.00 0.30 W 12.00 8.00 R E 1.75 2.00F 5.50 E T P2 Do0.30 1.55 D1 1.50 1.75 W R 12.00 5° 5deg NOTICE 1) All Cree LED carrier tapes conform to EIA-481D, Automated Component handling Systems Standard 2) Measurement tolerances unless indicated otherwise: .xx = ±.15 mm © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 2402-M031 XPGB CLD-DS56 REV 20 40 XLAMP ® XP-E2 LED TAPE AND REEL - CONTINUED All Cree LED carrier tapes conform to EIA-481D, Automated Component Handling Systems Standard. Feed Direction END All dimensions in mm. START Trailer Loaded Pockets Leader Min. 160 mm empty pockets sealed with tape 1000 Lamps Min. 400 mm empty pockets with min. 100 mm sealed Feed Direction Cover Tape Pocket Tape 13 mm 7.5” © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 41 XLAMP ® XP-E2 LED PACKAGING © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 42 XLAMP ® XP-E2 LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS The following order codes are active and valid order codes, but higher performance options are also available. Please see page 5 for order codes of XLamp XP-E2 white LEDs that could serve as alternatives for the order codes set forth below. Chromaticity Kit 51 53 50 E1 E2 CCT 6200 K 6000 K 6200 K 6500 K 5700 K Minimum Luminous Flux @ 350 mA Order Codes Code Flux (lm) @ 85 °C 70 CRI Typical R4 130 XPEBWT-L1-0000-00G51 R3 122 XPEBWT-L1-0000-00F51 R2 114 XPEBWT-L1-0000-00E51 Q5 107 XPEBWT-L1-0000-00D51 Q4 100 XPEBWT-L1-0000-00C51 R4 130 XPEBWT-L1-0000-00G53 R3 122 XPEBWT-L1-0000-00F53 R2 114 XPEBWT-L1-0000-00E53 Q5 107 XPEBWT-L1-0000-00D53 Q4 100 XPEBWT-L1-0000-00C53 R4 130 XPEBWT-L1-0000-00G50 R3 122 XPEBWT-L1-0000-00F50 R2 114 XPEBWT-L1-0000-00E50 Q5 107 XPEBWT-L1-0000-00D50 Q4 100 XPEBWT-L1-0000-00C50 R4 130 XPEBWT-L1-0000-00GE1 R3 122 XPEBWT-L1-0000-00FE1 R2 114 XPEBWT-L1-0000-00EE1 Q5 107 XPEBWT-L1-0000-00DE1 Q4 100 XPEBWT-L1-0000-00CE1 R4 130 XPEBWT-L1-0000-00GE2 R3 122 XPEBWT-L1-0000-00FE2 R2 114 XPEBWT-L1-0000-00EE2 Q5 107 XPEBWT-L1-0000-00DE2 Q4 100 XPEBWT-L1-0000-00CE2 Note: • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 36). © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 43 XLAMP ® XP-E2 LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED The following order codes are active and valid order codes, but higher performance options are also available. Please see page 6 for order codes of XLamp XP-E2 white LEDs that could serve as alternatives for the order codes set forth below. Chromaticity Kit E3 F4 E4 F5 E5 Z5 CCT 5000 K 4750 K 4500 K 4250 K 4000 K 4000 K Minimum Luminous Flux @ 350 mA Order Codes Code Flux (lm) @ 85 °C 70 CRI Typical R4 130 XPEBWT-01-0000-00GE3 R3 122 XPEBWT-01-0000-00FE3 XPEBWT-L1-0000-00FE3 R2 114 XPEBWT-01-0000-00EE3 XPEBWT-L1-0000-00EE3 Q5 107 Q4 100 R3 122 XPEBWT-01-0000-00FF4 XPEBWT-01-0000-00EF4 75 CRI Typical 80 CRI Minimum XPEBWT-L1-0000-00DE3 XPEBWT-L1-0000-00CE3 XPEBWT-L1-0000-00FF4 R2 114 Q5 107 XPEBWT-L1-0000-00DF4 XPEBWT-L1-0000-00EF4 Q4 100 XPEBWT-L1-0000-00CF4 R3 122 XPEBWT-01-0000-00FE4 XPEBWT-L1-0000-00FE4 R2 114 XPEBWT-01-0000-00EE4 XPEBWT-L1-0000-00EE4 Q5 107 Q4 100 R3 122 XPEBWT-01-0000-00FF5 R2 114 XPEBWT-01-0000-00EF5 XPEBWT-L1-0000-00EF5 Q5 107 XPEBWT-01-0000-00DF5 XPEBWT-L1-0000-00DF5 Q4 100 XPEBWT-L1-0000-00CF5 Q3 93.9 XPEBWT-L1-0000-00BF5 R3 122 XPEBWT-01-0000-00FE5 R2 114 XPEBWT-01-0000-00EE5 XPEBWT-L1-0000-00EE5 XPEBWT-H1-0000-00EE5 Q5 107 XPEBWT-01-0000-00DE5 XPEBWT-L1-0000-00DE5 XPEBWT-H1-0000-00DE5 Q4 100 XPEBWT-L1-0000-00CE5 XPEBWT-H1-0000-00CE5 Q3 93.9 XPEBWT-L1-0000-00BE5 XPEBWT-H1-0000-00BE5 Q5 107 XPEBWT-L1-0000-00DZ5 XPEBWT-H1-0000-00DZ5 Q4 100 XPEBWT-L1-0000-00CZ5 XPEBWT-H1-0000-00CZ5 Q3 93.9 XPEBWT-L1-0000-00BZ5 XPEBWT-H1-0000-00BZ5 XPEBWT-L1-0000-00DE4 XPEBWT-L1-0000-00CE4 Note: • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 36). © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 44 XLAMP ® XP-E2 LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED The following order codes are active and valid order codes, but higher performance options are also available. Please see page 7 page 9 for order codes of XLamp XP-E2 white LEDs that could serve as alternatives for the order codes set forth below. Chromaticity Kit F6 E6 Z6 F7 E7 Z7 CCT 3750 K 3500 K 3500 K 3250 K 3000 K 3000 K Minimum Luminous Flux @ 350 mA Order Codes Code Flux (lm) @ 85 °C R2 114 XPEBWT-01-0000-00EF6 Q5 107 XPEBWT-01-0000-00DF6 70 CRI Typical 80 CRI Typical 80 CRI Minimum XPEBWT-L1-0000-00DF6 XPEBWT-H1-0000-00DF6 XPEBWT-H1-0000-00CF6 Q4 100 XPEBWT-L1-0000-00CF6 Q3 93.9 XPEBWT-L1-0000-00BF6 XPEBWT-H1-0000-00BF6 Q2 87.4 XPEBWT-L1-0000-00AF6 XPEBWT-H1-0000-00AF6 XPEBWT-L1-0000-00DE6 XPEBWT-H1-0000-00DE6 XPEBWT-L1-0000-00CE6 XPEBWT-H1-0000-00CE6 R2 114 XPEBWT-01-0000-00EE6 Q5 107 XPEBWT-01-0000-00DE6 Q4 100 Q3 93.9 XPEBWT-L1-0000-00BE6 XPEBWT-H1-0000-00BE6 Q2 87.4 XPEBWT-L1-0000-00AE6 XPEBWT-H1-0000-00AE6 Q4 100 XPEBWT-L1-0000-00CZ6 XPEBWT-H1-0000-00CZ6 Q3 93.9 XPEBWT-L1-0000-00BZ6 XPEBWT-H1-0000-00BZ6 Q2 87.4 XPEBWT-L1-0000-00AZ6 XPEBWT-H1-0000-00AZ6 R2 114 XPEBWT-01-0000-00EF7 Q5 107 XPEBWT-01-0000-00DF7 XPEBWT-L1-0000-00DF7 XPEBWT-H1-0000-00DF7 XPEBWT-H1-0000-00CF7 Q4 100 XPEBWT-L1-0000-00CF7 Q3 93.9 XPEBWT-L1-0000-00BF7 XPEBWT-H1-0000-00BF7 Q2 87.4 XPEBWT-L1-0000-00AF7 XPEBWT-H1-0000-00AF7 XPEBWT-L1-0000-00DE7 XPEBWT-H1-0000-00DE7 XPEBWT-L1-0000-00CE7 XPEBWT-H1-0000-00CE7 85 CRI Minimum 90 CRI Minimum R2 114 XPEBWT-01-0000-00EE7 Q5 107 XPEBWT-01-0000-00DE7 Q4 100 Q3 93.9 XPEBWT-L1-0000-00BE7 XPEBWT-H1-0000-00BE7 Q2 87.4 XPEBWT-L1-0000-00AE7 XPEBWT-H1-0000-00AE7 XPEBWT-P1-0000-00AE7 XPEBWT-U1-0000-00AE7 P4 80.6 XPEBWT-P1-0000-009E7 XPEBWT-U1-0000-009E7 P3 73.9 XPEBWT-P1-0000-008E7 XPEBWT-U1-0000-008E7 P2 67.2 XPEBWT-P1-0000-007E7 XPEBWT-U1-0000-007E7 Q4 100 Q3 93.9 XPEBWT-L1-0000-00BZ7 XPEBWT-H1-0000-00BZ7 Q2 87.4 XPEBWT-L1-0000-00AZ7 XPEBWT-H1-0000-00AZ7 P4 80.6 XPEBWT-P1-0000-009Z7 XPEBWT-U1-0000-009Z7 P3 73.9 XPEBWT-P1-0000-008Z7 XPEBWT-U1-0000-008Z7 P2 67.2 XPEBWT-P1-0000-007Z7 XPEBWT-U1-0000-007Z7 XPEBWT-L1-0000-00CZ7 XPEBWT-H1-0000-00CZ7 XPEBWT-P1-0000-00AZ7 Note: • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 36). © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 45 XLAMP ® XP-E2 LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED Chromaticity Kit F8 E8 Z8 CCT 2850 K 2700 K 2700 K EA 2200 K ZA 2200 K Minimum Luminous Flux @ 350 mA Code Flux (lm) @ 85 °C Order Codes 70 CRI Typical 80 CRI Typical 80 CRI Minimum XPEBWT-H1-0000-00CF8 85 CRI Minimum 90 CRI Minimum Q4 100 XPEBWT-L1-0000-00CF8 Q3 93.9 XPEBWT-L1-0000-00BF8 XPEBWT-H1-0000-00BF8 Q2 87.4 XPEBWT-L1-0000-00AF8 XPEBWT-H1-0000-00AF8 XPEBWT-P1-0000-00AF8 P4 80.6 XPEBWT-L1-0000-009F8 XPEBWT-H1-0000-009F8 XPEBWT-P1-0000-009F8 XPEBWT-U1-0000-009F8 P3 73.9 XPEBWT-P1-0000-008F8 XPEBWT-U1-0000-008F8 P2 67.2 XPEBWT-P1-0000-007F8 XPEBWT-U1-0000-007F8 XPEBWT-P1-0000-006F8 XPEBWT-U1-0000-006F8 N4 62 Q4 100 XPEBWT-L1-0000-00CE8 XPEBWT-H1-0000-00CE8 Q3 93.9 XPEBWT-L1-0000-00BE8 XPEBWT-H1-0000-00BE8 Q2 87.4 XPEBWT-L1-0000-00AE8 XPEBWT-H1-0000-00AE8 P4 80.6 XPEBWT-L1-0000-009E8 XPEBWT-H1-0000-009E8 XPEBWT-P1-0000-009E8 XPEBWT-U1-0000-009E8 P3 73.9 XPEBWT-P1-0000-008E8 XPEBWT-U1-0000-008E8 P2 67.2 XPEBWT-P1-0000-007E8 XPEBWT-U1-0000-007E8 XPEBWT-P1-0000-006E8 XPEBWT-U1-0000-006E8 N4 62 Q3 93.9 XPEBWT-L1-0000-00BZ8 XPEBWT-H1-0000-00BZ8 Q2 87.4 XPEBWT-L1-0000-00AZ8 XPEBWT-H1-0000-00AZ8 P4 80.6 XPEBWT-L1-0000-009Z8 XPEBWT-H1-0000-009Z8 P3 73.9 XPEBWT-P1-0000-008Z8 XPEBWT-U1-0000-008Z8 P2 67.2 XPEBWT-P1-0000-007Z8 XPEBWT-U1-0000-007Z8 XPEBWT-P1-0000-006Z8 XPEBWT-U1-0000-006Z8 N4 62 P2 67.2 XPEBWT-L1-0000-007EA XPEBWT-H1-0000-007EA N4 62 XPEBWT-L1-0000-006EA XPEBWT-H1-0000-006EA P2 67.2 XPEBWT-L1-0000-007ZA XPEBWT-H1-0000-007ZA N4 62 XPEBWT-L1-0000-006ZA XPEBWT-H1-0000-006ZA XPEBWT-P1-0000-009Z8 Note: • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 36). © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 46 XLAMP ® XP-E2 LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED The following order codes are active and valid order codes, but higher performance options are also available. Please see page 10 for order codes of XLamp XP-E2 color LEDs that could serve as alternatives for the order codes set forth below. Color Minimum Radiant Flux @ 350 mA Group Flux (mW) 30 450 31 Minimum 1.71 475 32 Dominant Wavelength (nm) Calculated Minimum PPF (µmol/s)* 1.80 500 1.90 Royal Blue 33 525 34 550 35 Color Blue 1.99 2.08 575 2.18 Minimum Luminous Flux (lm) @ 350 mA Group Flux (lm) K2 30.6 Maximum Order Codes Group DWL (nm) Group DWL (nm) D3 450 D5 465 XPEBRY-L1-0000-00J01 D3 450 D4 460 XPEBRY-L1-0000-00J02 D4 455 D5 465 XPEBRY-L1-0000-00J03 D3 450 D5 465 XPEBRY-L1-0000-00K01 D3 450 D4 460 XPEBRY-L1-0000-00K02 D4 455 D5 465 XPEBRY-L1-0000-00K03 D3 450 D5 465 XPEBRY-L1-0000-00L01 D3 450 D4 460 XPEBRY-L1-0000-00L02 D4 455 D5 465 XPEBRY-L1-0000-00L03 D3 450 D5 465 XPEBRY-L1-0000-00M01 D3 450 D4 460 XPEBRY-L1-0000-00M02 D4 455 D5 465 XPEBRY-L1-0000-00M03 D3 450 D5 465 XPEBRY-L1-0000-00N01 D3 450 D4 460 XPEBRY-L1-0000-00N02 D4 455 D5 465 XPEBRY-L1-0000-00N03 D3 450 D5 465 XPEBRY-L1-0000-00P01 D3 450 D4 460 XPEBRY-L1-0000-00P02 D4 455 D5 465 XPEBRY-L1-0000-00P03 Dominant Wavelength (nm) Minimum Maximum Order Codes Group DWL (nm) Group DWL (nm) B3 465 B6 485 XPEBBL-L1-0000-00Y01 B3 465 B5 480 XPEBBL-L1-0000-00Y02 B4 470 B5 480 XPEBBL-L1-0000-00Y05 Note: • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 36). * Calculated Photosynthetic Photon Flux (PPF) and Far-Red Photon Flux (PFFR) values are for reference only. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 47 XLAMP ® XP-E2 LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED The following order codes are active and valid order codes, but higher performance options are also available. Please see page 11 for order codes of XLamp XP-E2 color LEDs that could serve as alternatives for the order codes set forth below. Color Minimum Luminous Flux (lm) @ 350 mA Group Flux (lm) Calculated Minimum PPF (µmol/s)* Q2 87.4 0.80 Q3 93.9 Q4 Green R2 R3 PC Amber G2 520 G4 535 XPEBGR-L1-0000-00A01 G2 520 G3 530 XPEBGR-L1-0000-00A02 G3 525 G4 535 XPEBGR-L1-0000-00A03 G2 520 G4 535 XPEBGR-L1-0000-00B01 G2 520 G3 530 XPEBGR-L1-0000-00B02 G3 525 G4 535 XPEBGR-L1-0000-00B03 G2 520 G4 535 XPEBGR-L1-0000-00C01 G2 520 G3 530 XPEBGR-L1-0000-00C02 G3 525 G4 535 XPEBGR-L1-0000-00C03 G2 520 G4 535 XPEBGR-L1-0000-00D01 G2 520 G3 530 XPEBGR-L1-0000-00D02 G3 525 G4 535 XPEBGR-L1-0000-00D03 G2 520 G4 535 XPEBGR-L1-0000-00E01 G2 520 G3 530 XPEBGR-L1-0000-00E02 G3 525 G4 535 XPEBGR-L1-0000-00E03 G2 520 G4 535 XPEBGR-L1-0000-00F01 G2 520 G3 530 XPEBGR-L1-0000-00F02 G3 525 G4 535 XPEBGR-L1-0000-00F03 G2 520 G4 535 XPEBGR-L1-0000-00G01 G2 520 G3 530 XPEBGR-L1-0000-00G02 G3 525 G4 535 XPEBGR-L1-0000-00G03 1.11 130 Color Group 1.04 122 R4 Group 0.98 114 1.18 Color Bin Y2 Order Codes DWL (nm) 0.91 107 Maximum DWL (nm) 0.86 100 Q5 Dominant Wavelength (nm) Minimum Minimum Luminous Flux (lm) @ 350 mA Group Flux (lm) Q2 87.4 Order Codes XPEBPA-L1-0000-00A01 Note: • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 36). * Calculated Photosynthetic Photon Flux (PPF) and Far-Red Photon Flux (PFFR) values are for reference only. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 48 XLAMP ® XP-E2 LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED The following order codes are active and valid order codes, but higher performance options are also available. Please see page 12 page 13 for order codes of XLamp XP-E2 color LEDs that could serve as alternatives for the order codes set forth below. Dominant Wavelength (nm) Minimum Luminous Flux (lm) @ 350 mA Color Group Flux (lm) N4 62.0 Minimum Group Group DWL (nm) A2 585 A3 595 XPEBAM-L1-0000-00601 A2 585 A2 590 XPEBAM-L1-0000-00602 A3 590 A3 595 XPEBAM-L1-0000-00603 A2 585 A3 595 XPEBAM-L1-0000-00701 A2 585 A2 590 XPEBAM-L1-0000-00702 A3 590 A3 595 XPEBAM-L1-0000-00703 67.2 Group Flux (lm) P2 Red-Orange Minimum P3 Group DWL (nm) O3 610 O4 620 XPEBRO-L1-0000-00701 O3 610 O3 615 XPEBRO-L1-0000-00702 O4 615 O4 620 XPEBRO-L1-0000-00703 O3 610 O4 620 XPEBRO-L1-0000-00801 O3 610 O3 615 XPEBRO-L1-0000-00802 O4 615 O4 620 XPEBRO-L1-0000-00803 O3 610 O4 620 XPEBRO-L1-0000-00901 O3 610 O3 615 XPEBRO-L1-0000-00902 O4 615 O4 620 XPEBRO-L1-0000-00903 80.6 Group Flux (lm) Calculated Minimum PPF (µmol/s)* N3 56.8 1.48 Red N4 62 Order Codes Group 73.9 Minimum Luminous Flux (lm) @ 350 mA Maximum DWL (nm) 67.2 P4 Color Dominant Wavelength (nm) Minimum Luminous Flux (lm) @ 350 mA Color Order Codes DWL (nm) Amber P2 Maximum 1.61 Dominant Wavelength (nm) Minimum Maximum Order Codes Group DWL (nm) Group DWL (nm) R2 620 R3 630 XPEBRD-L1-0000-00501 R2 620 R2 625 XPEBRD-L1-0000-00502 R2 620 R3 630 XPEBRD-L1-0000-00601 R2 620 R2 625 XPEBRD-L1-0000-00602 Note: • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 36). * Calculated Photosynthetic Photon Flux (PPF) and Far-Red Photon Flux (PFFR) values are for reference only. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 49 XLAMP ® XP-E2 LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED The following order codes are active and valid order codes, but higher performance options are also available. Please see page 13 for order codes of XLamp XP-E2 color LEDs that could serve as alternatives for the order codes set forth below. Color Photo Red Color Far Red Minimum Radiant Flux (mW) @ 350 mA Group Flux (mW) 29 425 Minimum Radiant Flux (mW) @ 350 mA Group Flux (mW) 26 350 Calculated Minimum PPF (µmol/s)* 2.3 Calculated Minimum PFFR (µmol/s)* 2.0 Peak Wavelength (nm) Minimum Maximum Group PWL (nm) Group PWL (nm) P2 650 P5 670 Color Order Codes XPEBPR-L1-0000-00C01 Peak Wavelength (nm) Minimum Maximum Group PWL (nm) Group PWL (nm) F2 720 F5 740 Color Order Codes XPEBFR-L1-0000-00901 Note: • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 36). * Calculated Photosynthetic Photon Flux (PPF) and Far-Red Photon Flux (PFFR) values are for reference only. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, and XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS56 REV 20 50
XPEBWT-H1-R250-00BF7
物料型号:CREE XLamp® XP-E2 LED
器件简介: XLamp® XP-E2 LED在原始XP-E的基础上,通过增加高达20%的光通量,同时提供单一芯片LED点光源,以实现精确的光学控制。XP-E2 LED与原始XP-E共享相同的封装尺寸,为现有XP客户提供了无缝升级路径,以获得更多的光通量和/或更高的效率,同时缩短了设计周期。
引脚分配:文档中未明确提供引脚分配图,但通常LED的引脚分配为两个引脚,一个为正极(阳极),另一个为负极(阴极)。
参数特性: - 提供多种颜色选项,包括白色、户外白色、不同CRI的白色、皇家蓝、蓝色、绿色、PC琥珀色、琥珀色、红橙色、红色、光敏红色、远红色等。 - ANSI兼容的色度分选箱。 - 白色LED在85°C下的色度分选。 - 最大驱动电流:皇家蓝、蓝色1.2A,其他1.5A。 - 低热阻:低至1.4°C/W。 - 宽视角:105°-140°。 - 无限制的使用寿命在≤ 30°C/85% RH条件下。 - 可回流焊接 - 兼容JEDEC J-STD-020C。 - 电气中性的热路径。 - 符合RoHS和REACH标准。 - UL®认可的组件(E349212)。
功能详解: XLamp XP-E2 LED是照明应用的理想选择,特别是在需要高光输出和最大效率的应用中,如LED替换灯、户外、便携式、室内定向、紧急车辆或建筑照明。
应用信息: 适用于需要高光输出和高能效的照明应用,包括LED灯具的替换、户外照明、便携式照明设备、室内照明、紧急车辆照明和建筑照明等。
封装信息: 封装细节包括热阻、视角、电压温度系数、静电放电耐受电压、直流正向电流、反向电压等参数,以及机械尺寸、胶带和卷轴包装信息。
XPEBWT-H1-R250-00BF7 价格&库存
很抱歉,暂时无法提供与“XPEBWT-H1-R250-00BF7”相匹配的价格&库存,您可以联系我们找货
