XPGBWT-H1-0000-00DZ6
    CREELED
    LED-3P_3.45X3.45MM_SM
    LED 照明 XLamp® XP-G2 白色,暖色 3500K 2.72V 350mA 115° 1414(3535 公制)
XPGBWT-H1-0000-00DZ6 数据手册
PRODUCT FAMILY DATA SHEET XLamp® XP-G2 LEDs XP-G2 Standard LED XP-G2 High Efficacy LED PRODUCT DESCRIPTION FEATURES The original XLamp® XP-G2 LED pioneered a broad set of LED • Available in white, outdoor white and 80-, 85- and 90-CRI white applications for the industry, including outdoor and area lighting, • ANSI-compatible chromaticity bins and has since served as a preferred choice by manufacturers • Broadcast color option at 5700 K that require advanced output, efficacy and optical control. The • Binned at 85 °C compact and proven 3.45‑mm XP platform has an excellent • Maximum drive current: Standard: 1500 mA, HE: 2000 mA ecosystem of optics and system solutions available, enabling • Low thermal resistance: 1.4 °C/W lighting manufacturers to simplify their design process and • Wide viewing angle: Standard: 120°, HE: 125° shorten time to market. • Unlimited floor life at ≤ 30 ºC/85% RH • Reflow solderable - JEDEC J‑STD‑020C XP-G2 LEDs are now available in two different White versions: • Electrically neutral thermal path Standard and High Efficacy (HE). XP-G2 Standard is the same • RoHS and REACH compliant breakthrough product that enabled a broad set of new LED • UL® recognized component (E349212) applications for ceramic high-power LEDs. The new High Efficacy version extends this legacy with a drop‑in upgrade for existing designs optimized around XP‑G2 LEDs. XP‑G2 HE LEDs leverage Cree LED’s latest high‑power chip technology to deliver 25 percent more light output via a higher maximum current of 2000 mA and higher efficacy. Cree LED / 4001 E. Hwy. 54, Suite 2000 / Durham, NC 27709 USA / +1.919.313.5330 / www.cree-led.com © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 1 XLAMP ® XP-G2 LED TABLE OF CONTENTS Characteristics........................................................................................................................................................................................................ 3 Order Codes Suggested for New Designs - High Efficacy.................................................................................................................................... 4 Order Codes Suggested for New Designs - Standard......................................................................................................................................... 10 Flux Characteristics - Broadcast Order Codes and Bins.................................................................................................................................... 14 Relative Spectral Power Distribution................................................................................................................................................................... 15 Relative Flux vs. Junction Temperature............................................................................................................................................................... 15 Electrical Characteristics - High Efficacy............................................................................................................................................................ 16 Electrical Characteristics - Standard................................................................................................................................................................... 16 Relative Flux vs. Current - High Efficacy.............................................................................................................................................................. 17 Relative Flux vs. Current - Standard..................................................................................................................................................................... 17 Relative Chromaticity vs Current and Temperature - High Efficacy................................................................................................................... 18 Relative Chromaticity vs Current and Temperature - Standard.......................................................................................................................... 19 Typical Spatial Distribution - High Efficacy......................................................................................................................................................... 20 Typical Spatial Distribution - Standard................................................................................................................................................................ 20 Thermal Design - High Efficacy............................................................................................................................................................................ 21 Thermal Design - Standard................................................................................................................................................................................... 21 Performance Groups – Luminous Flux............................................................................................................................................................... 22 Performance Groups – Chromaticity................................................................................................................................................................... 23 Standard Cool White Kits Plotted on ANSI Standard Chromaticity Regions..................................................................................................... 26 Standard Warm and Neutral White Kits Plotted on ANSI Standard Chromaticity Regions.............................................................................. 28 Standard Chromaticity Kits.................................................................................................................................................................................. 30 Bin and Order Code Formats................................................................................................................................................................................ 31 Reflow Soldering Characteristics......................................................................................................................................................................... 32 Notes..................................................................................................................................................................................................................... 33 Mechanical Dimensions....................................................................................................................................................................................... 35 Tape and Reel........................................................................................................................................................................................................ 37 Packaging.............................................................................................................................................................................................................. 39 Appendix - Order Codes Not For New Designs................................................................................................................................................... 40 © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 2 XLAMP ® XP-G2 LED CHARACTERISTICS Characteristics Unit Minimum Typical Thermal resistance, junction to solder point - High Efficacy◊ °C/W 1.4 Thermal resistance, junction to solder point - Standard °C/W 1.4 Viewing angle (FWHM) - High Efficacy degrees 125 Viewing angle (FWHM) - Standard degrees 120 Temperature coefficient of voltage - High Efficacy mV/°C -1.3 Temperature coefficient of voltage - Standard mV/°C -1.3 ◊ ESD withstand voltage (HBM per Mil-Std-883D) Maximum V 8000 DC forward current - High Efficacy mA 2000 DC forward current - Standard mA 1500 Reverse voltage V 1 Forward voltage (@ 350 mA, 85 °C) - High Efficacy V 2.70 2.90 Forward voltage (@ 350 mA, 85 °C) - Standard V 2.72 3.1 Forward voltage (@ 700 mA, 85 °C) - High Efficacy V 2.80 Forward voltage (@ 700 mA, 85 °C) - Standard V 2.83 Forward voltage (@ 1000 mA, 85 °C) - High Efficacy V 2.87 Forward voltage (@ 1000 mA, 85 °C) - Standard V 2.90 Forward voltage (@ 1500 mA, 85 °C) - High Efficacy V 2.97 Forward voltage (@ 1500 mA, 85 °C) - Standard V 3.02 LED junction temperature °C 150 Note: ◊ Thermal resistance measurement was performed per the JEDEC JESD51-14 standard. See the Thermal Resistance Measurement application note for more details. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 3 XLAMP ® XP-G2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - HIGH EFFICACY (TJ = 85 °C) The following table provides order codes for XLamp High‑Efficacy XP-G2 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 31). For definitions of the chromaticity kits, please see the Standard Chromaticity Kits section (page 30). Chromaticity Kit DT E1 51 CCT 7000 K 6500 K 6200 K Minimum Luminous Flux (lm) @ 350 mA Order Codes Code Flux (lm) @ 85 °C Flux (lm) @ 25 °C* 70 CRI Minimum S5 172 189 XPGBWT-BE-0000-00MDT S4 164 180 XPGBWT-BE-0000-00LDT XPGBWT-HE-0000-00LDT S3 156 171 XPGBWT-BE-0000-00KDT XPGBWT-HE-0000-00KDT S2 148 163 S6 180 198 XPGBWT-BE-0000-00NE1 S5 172 189 XPGBWT-BE-0000-00ME1 S4 164 180 XPGBWT-BE-0000-00LE1 XPGBWT-HE-0000-00LE1 S3 156 171 XPGBWT-BE-0000-00KE1 XPGBWT-HE-0000-00KE1 S2 148 163 S6 180 198 XPGBWT-BE-0000-00N51 S5 172 189 XPGBWT-BE-0000-00M51 S4 164 180 XPGBWT-BE-0000-00L51 XPGBWT-HE-0000-00L51 S3 156 171 XPGBWT-BE-0000-00K51 XPGBWT-HE-0000-00K51 80 CRI Minimum 90 CRI Minimum XPGBWT-HE-0000-00JDT XPGBWT-HE-0000-00JE1 S2 148 163 R5 139 153 XPGBWT-HE-0000-00J51 XPGBWT-UE-0000-00H51 R4 130 143 XPGBWT-UE-0000-00G51 R3 122 134 XPGBWT-UE-0000-00F51 R2 114 125 Notes • • • * For additional order codes NOT recommended for new designs please see the Appendix section starting on page 40 . Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 33). XP-G2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 4 XLAMP ® XP-G2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - HIGH EFFICACY (TJ = 85 °C) - CONTINUED Chromaticity Kit DV 50 E2 CCT 6000 K 6000 K 5700 K Minimum Luminous Flux (lm) @ 350 mA Order Codes Code Flux (lm) @ 85 °C Flux (lm) @ 25 °C* 70 CRI Minimum S6 180 198 XPGBWT-BE-0000-00NDV S5 172 189 XPGBWT-BE-0000-00MDV S4 164 180 XPGBWT-BE-0000-00LDV XPGBWT-HE-0000-00LDV S3 156 171 XPGBWT-BE-0000-00KDV XPGBWT-HE-0000-00KDV S2 148 163 R5 139 153 XPGBWT-UE-0000-00HDV R4 130 143 XPGBWT-UE-0000-00GDV R3 122 134 XPGBWT-UE-0000-00FDV S6 180 198 XPGBWT-BE-0000-00N50 S5 172 189 XPGBWT-BE-0000-00M50 S4 164 180 XPGBWT-BE-0000-00L50 XPGBWT-HE-0000-00L50 S3 156 171 XPGBWT-BE-0000-00K50 XPGBWT-HE-0000-00K50 S2 148 163 R5 139 153 XPGBWT-UE-0000-00H50 R4 130 143 XPGBWT-UE-0000-00G50 R3 122 134 XPGBWT-UE-0000-00F50 S6 180 198 XPGBWT-BE-0000-00NE2 S5 172 189 XPGBWT-BE-0000-00ME2 S4 164 180 XPGBWT-BE-0000-00LE2 XPGBWT-HE-0000-00LE2 S3 156 171 XPGBWT-BE-0000-00KE2 XPGBWT-HE-0000-00KE2 S2 148 163 R5 139 153 XPGBWT-UE-0000-00HE2 R4 130 143 XPGBWT-UE-0000-00GE2 R3 122 134 XPGBWT-UE-0000-00FE2 80 CRI Minimum 90 CRI Minimum XPGBWT-HE-0000-00JDV XPGBWT-HE-0000-00J50 XPGBWT-HE-0000-00JE2 Notes • • • * For additional order codes NOT recommended for new designs please see the Appendix section starting on page 40 . Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 33). XP-G2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 5 XLAMP ® XP-G2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - HIGH EFFICACY (TJ = 85 °C) - CONTINUED Chromaticity Kit E3 F4 E4 CCT 5000 K 4750 K 4500 K Minimum Luminous Flux (lm) @ 350 mA Order Codes Code Flux (lm) @ 85 °C Flux (lm) @ 25 °C* 70 CRI Minimum S6 180 198 XPGBWT-BE-0000-00NE3 S5 172 189 XPGBWT-BE-0000-00ME3 S4 164 180 XPGBWT-BE-0000-00LE3 XPGBWT-HE-0000-00LE3 S3 156 171 XPGBWT-BE-0000-00KE3 XPGBWT-HE-0000-00KE3 S2 148 163 R5 139 153 XPGBWT-UE-0000-00HE3 R4 130 143 XPGBWT-UE-0000-00GE3 R3 122 134 XPGBWT-UE-0000-00FE3 S6 180 198 XPGBWT-BE-0000-00NF4 S5 172 189 XPGBWT-BE-0000-00MF4 XPGBWT-HE-0000-00MF4 S4 164 180 XPGBWT-BE-0000-00LF4 XPGBWT-HE-0000-00LF4 S3 156 171 XPGBWT-BE-0000-00KF4 XPGBWT-HE-0000-00KF4 S2 148 163 R5 139 153 XPGBWT-UE-0000-00HF4 R4 130 143 XPGBWT-UE-0000-00GF4 R3 122 134 XPGBWT-UE-0000-00FF4 S6 180 198 XPGBWT-BE-0000-00NE4 S5 172 189 XPGBWT-BE-0000-00ME4 S4 164 180 XPGBWT-BE-0000-00LE4 XPGBWT-HE-0000-00LE4 S3 156 171 XPGBWT-BE-0000-00KE4 XPGBWT-HE-0000-00KE4 S2 148 163 R5 139 153 XPGBWT-UE-0000-00HE4 R4 130 143 XPGBWT-UE-0000-00GE4 R3 122 134 XPGBWT-UE-0000-00FE4 80 CRI Minimum 90 CRI Minimum XPGBWT-HE-0000-00ME3 XPGBWT-HE-0000-00JE3 XPGBWT-HE-0000-00JF4 XPGBWT-UE-0000-00JE3 XPGBWT-UE-0000-00JF4 XPGBWT-HE-0000-00JE4 Notes • • • * For additional order codes NOT recommended for new designs please see the Appendix section starting on page 40 . Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 33). XP-G2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 6 XLAMP ® XP-G2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - HIGH EFFICACY (TJ = 85 °C) - CONTINUED Chromaticity Kit F5 E5 F6 CCT 4250 K 4000 K 3750 K Minimum Luminous Flux (lm) @ 350 mA Order Codes Code Flux (lm) @ 85 °C Flux (lm) @ 25 °C* 70 CRI Minimum S6 180 198 XPGBWT-BE-0000-00NF5 S5 172 189 XPGBWT-BE-0000-00MF5 S4 164 180 XPGBWT-BE-0000-00LF5 XPGBWT-HE-0000-00LF5 S3 156 171 XPGBWT-BE-0000-00KF5 XPGBWT-HE-0000-00KF5 S2 148 163 R5 139 153 XPGBWT-UE-0000-00HF5 R4 130 143 XPGBWT-UE-0000-00GF5 R3 122 134 XPGBWT-UE-0000-00FF5 S6 180 198 XPGBWT-BE-0000-00NE5 S5 172 189 XPGBWT-BE-0000-00ME5 S4 164 180 XPGBWT-BE-0000-00LE5 XPGBWT-HE-0000-00LE5 S3 156 171 XPGBWT-BE-0000-00KE5 XPGBWT-HE-0000-00KE5 S2 148 163 R5 139 153 XPGBWT-UE-0000-00HE5 R4 130 143 XPGBWT-UE-0000-00GE5 R3 122 134 XPGBWT-UE-0000-00FE5 S5 172 189 XPGBWT-BE-0000-00MF6 S4 164 180 XPGBWT-BE-0000-00LF6 XPGBWT-HE-0000-00LF6 S3 156 171 XPGBWT-BE-0000-00KF6 XPGBWT-HE-0000-00KF6 S2 148 163 R5 139 153 XPGBWT-UE-0000-00HF6 R4 130 143 XPGBWT-UE-0000-00GF6 R3 122 134 XPGBWT-UE-0000-00FF6 80 CRI Minimum 90 CRI Minimum XPGBWT-HE-0000-00JF5 XPGBWT-HE-0000-00JE5 XPGBWT-HE-0000-00JF6 Notes • • • * For additional order codes NOT recommended for new designs please see the Appendix section starting on page 40 . Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 33). XP-G2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 7 XLAMP ® XP-G2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - HIGH EFFICACY (TJ = 85 °C) - CONTINUED Chromaticity Kit E6 F7 E7 CCT 3500 K 3250 K 3000 K Minimum Luminous Flux (lm) @ 350 mA Order Codes Code Flux (lm) @ 85 °C Flux (lm) @ 25 °C* 70 CRI Minimum S5 172 189 XPGBWT-BE-0000-00ME6 S4 164 180 XPGBWT-BE-0000-00LE6 XPGBWT-HE-0000-00LE6 S3 156 171 XPGBWT-BE-0000-00KE6 XPGBWT-HE-0000-00KE6 S2 148 163 R5 139 153 XPGBWT-UE-0000-00HE6 R4 130 143 XPGBWT-UE-0000-00GE6 R3 122 134 XPGBWT-UE-0000-00FE6 S5 172 189 XPGBWT-BE-0000-00MF7 S4 164 180 XPGBWT-BE-0000-00LF7 S3 156 171 XPGBWT-BE-0000-00KF7 S2 148 163 XPGBWT-HE-0000-00JF7 R5 139 153 XPGBWT-HE-0000-00HF7 R4 130 143 XPGBWT-UE-0000-00GF7 R3 122 134 XPGBWT-UE-0000-00FF7 R2 114 125 XPGBWT-UE-0000-00EF7 S5 172 189 XPGBWT-BE-0000-00ME7 S4 164 180 XPGBWT-BE-0000-00LE7 S3 156 171 XPGBWT-BE-0000-00KE7 80 CRI Minimum 90 CRI Minimum XPGBWT-HE-0000-00JE6 XPGBWT-HE-0000-00KF7 XPGBWT-HE-0000-00KE7 S2 148 163 XPGBWT-HE-0000-00JE7 R5 139 153 XPGBWT-HE-0000-00HE7 R4 130 143 XPGBWT-UE-0000-00GE7 R3 122 134 XPGBWT-UE-0000-00FE7 R2 114 125 XPGBWT-UE-0000-00EE7 Notes • • • * For additional order codes NOT recommended for new designs please see the Appendix section starting on page 40 . Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 33). XP-G2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 8 XLAMP ® XP-G2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - HIGH EFFICACY (TJ = 85 °C) - CONTINUED Chromaticity Kit F8 E8 CCT 2850 K 2700 K Minimum Luminous Flux (lm) @ 350 mA Order Codes Code Flux (lm) @ 85 °C Flux (lm) @ 25 °C* 70 CRI Minimum S4 164 180 XPGBWT-BE-0000-00LF8 S3 156 171 XPGBWT-BE-0000-00KF8 80 CRI Minimum 90 CRI Minimum S2 148 163 XPGBWT-HE-0000-00JF8 R5 139 153 XPGBWT-HE-0000-00HF8 R4 130 143 R3 122 134 XPGBWT-UE-0000-00FF8 R2 114 125 XPGBWT-UE-0000-00EF8 S4 164 180 XPGBWT-BE-0000-00LE8 S3 156 171 XPGBWT-BE-0000-00KE8 S2 148 163 XPGBWT-HE-0000-00JE8 R5 139 153 XPGBWT-HE-0000-00HE8 R4 130 143 R3 122 134 XPGBWT-UE-0000-00FE8 R2 114 125 XPGBWT-UE-0000-00EE8 Notes • • • * For additional order codes NOT recommended for new designs please see the Appendix section starting on page 40 . Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 33). XP-G2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 9 XLAMP ® XP-G2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - STANDARD (TJ = 85 °C) The following table provides order codes for XLamp Standard XP-G2 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 31). For definitions of the chromaticity kits, please see the Standard Chromaticity Kits section (page 30). Chromaticity Minimum Luminous Flux (lm) @ 350 mA Order Codes Kit Code Flux (lm) @ 85 °C Flux (lm) @ 25 °C* 70 CRI Typical S5 172 189 XPGBWT-L1-0000-00M51 S4 164 180 XPGBWT-L1-0000-00L51 S3 156 171 XPGBWT-L1-0000-00K51 S2 148 163 XPGBWT-L1-0000-00J51 S5 172 189 XPGBWT-L1-0000-00M53 S4 164 180 XPGBWT-L1-0000-00L53 S3 156 171 XPGBWT-L1-0000-00K53 S2 148 163 XPGBWT-L1-0000-00J53 S5 172 189 XPGBWT-L1-0000-00M50 S4 164 180 XPGBWT-L1-0000-00L50 S3 156 171 XPGBWT-L1-0000-00K50 S2 148 163 XPGBWT-L1-0000-00J50 S5 172 189 XPGBWT-L1-0000-00ME1 S4 164 180 XPGBWT-L1-0000-00LE1 S3 156 171 XPGBWT-L1-0000-00KE1 S2 148 163 XPGBWT-L1-0000-00JE1 S5 172 189 XPGBWT-L1-0000-00ME2 S4 164 180 XPGBWT-L1-0000-00LE2 S3 156 171 XPGBWT-L1-0000-00KE2 S2 148 163 XPGBWT-L1-0000-00JE2 51 53 50 E1 E2 CCT 6200 K 6000 K 6200 K 6500 K 5700 K Notes • • • * For additional order codes NOT recommended for new designs please see the Appendix section starting on page 40 . Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 33). XP-G2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 10 XLAMP ® XP-G2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - STANDARD (TJ = 85 °C) - CONTINUED Chromaticity Minimum Luminous Flux (lm) @ 350 mA Kit Code Flux (lm) @ 85 °C Flux (lm) @25 °C* 70 CRI Typical S5 172 189 XPGBWT-01-0000-00ME3 S4 164 180 XPGBWT-01-0000-00LE3 S3 156 171 XPGBWT-01-0000-00KE3 S2 148 163 XPGBWT-01-0000-00JE3 S5 172 189 XPGBWT-01-0000-00MF4 S4 164 180 XPGBWT-01-0000-00LF4 S3 156 171 XPGBWT-01-0000-00KF4 S2 148 163 XPGBWT-01-0000-00JF4 S5 172 189 XPGBWT-01-0000-00ME4 S4 164 180 XPGBWT-01-0000-00LE4 S3 156 171 XPGBWT-01-0000-00KE4 S2 148 163 XPGBWT-01-0000-00JE4 S5 172 189 XPGBWT-01-0000-00MF5 S4 164 180 XPGBWT-01-0000-00LF5 S3 156 171 XPGBWT-01-0000-00KF5 S2 148 163 XPGBWT-01-0000-00JF5 S5 172 189 XPGBWT-01-0000-00ME5 S4 164 180 XPGBWT-01-0000-00LE5 S3 156 171 XPGBWT-01-0000-00KE5 XPGBWT-H1-0000-00KE5 S2 148 163 XPGBWT-01-0000-00JE5 XPGBWT-H1-0000-00JE5 R5 139 153 XPGBWT-H1-0000-00HE5 R4 130 143 XPGBWT-H1-0000-00GE5 S3 156 171 XPGBWT-H1-0000-00KZ5 S2 148 163 XPGBWT-H1-0000-00JZ5 R5 139 153 XPGBWT-H1-0000-00HZ5 R4 130 143 XPGBWT-H1-0000-00GZ5 E3 F4 E4 F5 E5 Z5 CCT 5000 K 4750 K 4500 K 4250 K 4000 K 4000 K Order Codes 80 CRI Minimum Notes • • • * For additional order codes NOT recommended for new designs please see the Appendix section starting on page 40 . Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 33). XP-G2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 11 XLAMP ® XP-G2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - STANDARD (TJ = 85 °C) - CONTINUED Chromaticity Minimum Luminous Flux (lm) @ 350 mA Kit Code Flux (lm) @ 85 °C Flux (lm) @25 °C* 70 CRI Typical S4 164 180 XPGBWT-01-0000-00LF6 S3 156 171 S2 148 163 R5 139 153 R4 130 143 S4 164 180 XPGBWT-01-0000-00LE6 S3 156 171 XPGBWT-01-0000-00KE6 S2 148 163 R5 139 153 R4 130 S2 F6 CCT 3750 K E6 3500 K Z6 3500 K F7 3250 K E7 3000 K Order Codes 80 CRI Typical 80 CRI Minimum 90 CRI Minimum XPGBWT-01-0000-00KF6 XPGBWT-L1-0000-00KF6 XPGBWT-H1-0000-00KF6 XPGBWT-01-0000-00JF6 XPGBWT-L1-0000-00JF6 XPGBWT-H1-0000-00JF6 XPGBWT-01-0000-00HF6 XPGBWT-L1-0000-00HF6 XPGBWT-H1-0000-00HF6 XPGBWT-L1-0000-00GF6 XPGBWT-H1-0000-00GF6 XPGBWT-01-0000-00JE6 XPGBWT-L1-0000-00JE6 XPGBWT-H1-0000-00JE6 XPGBWT-01-0000-00HE6 XPGBWT-L1-0000-00HE6 XPGBWT-H1-0000-00HE6 143 XPGBWT-L1-0000-00GE6 XPGBWT-H1-0000-00GE6 148 163 XPGBWT-L1-0000-00JZ6 XPGBWT-H1-0000-00JZ6 R5 139 153 XPGBWT-L1-0000-00HZ6 XPGBWT-H1-0000-00HZ6 R4 130 143 XPGBWT-L1-0000-00GZ6 XPGBWT-H1-0000-00GZ6 S4 164 180 XPGBWT-01-0000-00LF7 S3 156 171 XPGBWT-01-0000-00KF7 S2 148 163 XPGBWT-01-0000-00JF7 XPGBWT-L1-0000-00JF7 XPGBWT-H1-0000-00JF7 R5 139 153 XPGBWT-01-0000-00HF7 XPGBWT-L1-0000-00HF7 XPGBWT-H1-0000-00HF7 R4 130 143 XPGBWT-L1-0000-00GF7 XPGBWT-H1-0000-00GF7 S3 156 171 XPGBWT-01-0000-00KE7 S2 148 163 XPGBWT-01-0000-00JE7 XPGBWT-L1-0000-00JE7 XPGBWT-H1-0000-00JE7 R5 139 153 XPGBWT-01-0000-00HE7 XPGBWT-L1-0000-00HE7 XPGBWT-H1-0000-00HE7 R4 130 143 XPGBWT-01-0000-00GE7 XPGBWT-L1-0000-00GE7 XPGBWT-H1-0000-00GE7 XPGBWT-U1-0000-00GE7 R3 122 134 XPGBWT-L1-0000-00FE7 XPGBWT-H1-0000-00FE7 XPGBWT-U1-0000-00FE7 R2 114 125 XPGBWT-U1-0000-00EE7 Q5 107 118 XPGBWT-U1-0000-00DE7 Notes • • • * For additional order codes NOT recommended for new designs please see the Appendix section starting on page 40 . Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 33). XP-G2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 12 XLAMP ® XP-G2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - STANDARD (TJ = 85 °C) - CONTINUED Chromaticity Minimum Luminous Flux (lm) @ 350 mA Kit Code Flux (lm) @ 85 °C Flux (lm) @25 °C* R5 139 R4 Z7 CCT 3000 K F8 2850 K E8 2700 K Z8 2700 K Order Codes 70 CRI Typical 80 CRI Typical 80 CRI Minimum 90 CRI Minimum 153 XPGBWT-L1-0000-00HZ7 XPGBWT-H1-0000-00HZ7 130 143 XPGBWT-L1-0000-00GZ7 XPGBWT-H1-0000-00GZ7 R3 122 134 XPGBWT-L1-0000-00FZ7 XPGBWT-H1-0000-00FZ7 R2 114 125 XPGBWT-U1-0000-00EZ7 Q5 107 118 XPGBWT-U1-0000-00DZ7 R5 139 153 XPGBWT-L1-0000-00HF8 XPGBWT-H1-0000-00HF8 R4 130 143 XPGBWT-L1-0000-00GF8 XPGBWT-H1-0000-00GF8 R3 122 134 XPGBWT-L1-0000-00FF8 XPGBWT-H1-0000-00FF8 R2 114 125 XPGBWT-U1-0000-00EF8 Q5 107 118 XPGBWT-U1-0000-00DF8 R5 139 153 XPGBWT-L1-0000-00HE8 XPGBWT-H1-0000-00HE8 R4 130 143 XPGBWT-L1-0000-00GE8 XPGBWT-H1-0000-00GE8 R3 122 134 XPGBWT-L1-0000-00FE8 XPGBWT-H1-0000-00FE8 R2 114 125 XPGBWT-U1-0000-00EE8 Q5 107 118 XPGBWT-U1-0000-00DE8 Q4 100 110 XPGBWT-U1-0000-00CE8 R4 130 143 XPGBWT-L1-0000-00GZ8 XPGBWT-H1-0000-00GZ8 R3 122 134 XPGBWT-L1-0000-00FZ8 XPGBWT-H1-0000-00FZ8 XPGBWT-L1-0000-00EZ8 XPGBWT-H1-0000-00EZ8 XPGBWT-U1-0000-00FZ7 XPGBWT-U1-0000-00FF8 R2 114 125 Q5 107 118 XPGBWT-U1-0000-00DZ8 Q4 100 110 XPGBWT-U1-0000-00CZ8 Q3 93.9 103 XPGBWT-U1-0000-00BZ8 Notes • • • * For additional order codes NOT recommended for new designs please see the Appendix section starting on page 40 . Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 33). XP-G2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 13 XLAMP ® XP-G2 LED FLUX CHARACTERISTICS - BROADCAST ORDER CODES AND BINS (TJ = 85 °C) The following table provides order codes for XLamp XP-G2 Broadcast LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 31). For definitions of the chromaticity kits, please see the Standard Chromaticity Kits section (page 30). Chromaticity Kit CCT E2 5700 K Minimum Luminous Flux (lm) @ 1050 mA Order Codes Flux Bin Flux (lm) @ 85 °C Flux (lm) @ 25 °C* 90 CRI Minimum 90 TLCI Minimum R4 130 143 XPGBWT-U1-B001-A0GE2 R3 122 134 95 CRI Minimum 95 TLCI Minimum XPGBWT-Z1-B001-A0FE2 Notes • • • * For additional order codes NOT recommended for new designs please see the Appendix section starting on page 40 . Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 33). XP-G2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 14 XLAMP ® XP-G2 LED Relative Spectral Power RELATIVE SPECTRAL POWER DISTRIBUTION 100% Relative Radiant Power 80% 60% 5000 K - 8300 K CCT 3700 K - 5000 K CCT 40% 2600 K - 3700 K CCT 20% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Relative Flux Output vs. Junction Temperature-standard RELATIVE FLUX VS. JUNCTION TEMPERATURE (IF = 350 mA) 120% Relative Luminous Flux 100% 80% 60% 40% 20% 0% 25 50 75 100 125 150 Junction Temperature (ºC) © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 15 XLAMP ® XP-G2 LED Electrical Characteristics (Tj = 85ºC) - high efficacy ELECTRICAL CHARACTERISTICS - HIGH EFFICACY (TJ = 85 °C) 2000 Forward Current (mA) 1750 1500 1250 1000 750 500 250 0 2.55 2.60 2.65 2.70 2.75 2.80 2.85 2.90 2.95 3.00 3.05 3.10 2.90 2.95 3.00 3.05 3.10 Forward Voltage (V) Electrical Characteristics (Tj = 85ºC) - standard efficacy data from: graphics/SA products Vf data sheet update.xlsx ELECTRICAL CHARACTERISTICS - STANDARD (TJ = 85 °C) 1500 Forward Current (mA) 1250 1000 750 500 250 0 2.55 2.60 2.65 2.70 2.75 2.80 2.85 Forward Voltage (V) © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 16 XLAMP ® XP-G2 LED Relative Intensity vs. Current (Tj = 85ºC) - high efficacy RELATIVE FLUX VS. CURRENT - HIGH EFFICACY (TJ = 85 °C) 450% Relative Luminous Flux 400% 350% 300% 250% 200% 150% 100% 50% 0% 0 250 500 750 1000 1250 1500 1750 2000 Forward Current (mA) Relative Intensity vs. Current (Tj = 85ºC) - standard RELATIVE FLUX VS. CURRENT - STANDARD (TJ = 85 °C) 350% Relative Luminous Flux 300% 250% 200% 150% 100% 50% 0% 0 250 500 750 1000 1250 1500 Forward Current (mA) © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 17 XLAMP ® XP-G2 LED RELATIVE CHROMATICITY CURRENT TEMPERATURE - HIGH EFFICACY (WARM WHITE) Delta CCT vs. Current -VS high efficacyAND - warm white 0.020 TJ = 85 °C 0.015 0.010 0.005 ΔCCx 0.000 ΔCCy -0.005 -0.010 -0.015 -0.020 0 250 500 750 Delta CCT vs Temp - high efficacy - warm white 1000 1250 1500 1750 2000 Current (mA) 0.020 IF = 350 mA 0.015 0.010 0.005 ΔCCx 0.000 ΔCCy -0.005 -0.010 -0.015 -0.020 25 50 75 100 125 150 Tsp (°C) © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 18 XLAMP ® XP-G2 LED Delta CCT vs. Current - standard - warm white RELATIVE CHROMATICITY VS CURRENT AND TEMPERATURE - STANDARD (WARM WHITE*) 0.020 TJ = 85 °C 0.015 0.010 0.005 ΔCCx 0.000 ΔCCy -0.005 -0.010 -0.015 -0.020 250- warm white 500 Delta CCT vs Temp0 - standard 750 1000 1250 1500 Current (mA) 0.020 IF = 350 mA 0.015 0.010 0.005 ΔCCx 0.000 ΔCCy -0.005 -0.010 -0.015 -0.020 25 50 75 100 125 150 Tsp (°C) • Warm White XLamp XP-G2 LEDs have a typical CRI of 80. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 19 XLAMP ® XP-G2 LED Typical Spatial Radiation Pattern TYPICAL SPATIAL DISTRIBUTION - HIGH EFFICACY - high efficacy 100% Relative Luminous Intensity 80% 60% 40% 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 50 70 90 Angle (º) Typical Spatial Radiation Pattern - standard efficacy TYPICAL SPATIAL DISTRIBUTION - STANDARD 100% Relative Luminous Intensity 80% 60% 40% 20% -90 -70 -50 -30 -10 0% 10 30 Angle (º) © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 20 XLAMP ® XP-G2 LED Thermal Design - high efficacy THERMAL DESIGN - HIGH EFFICACY The maximum forward current is determined by the thermal resistance between the LED junction and ambient. It is crucial for the end product to be designed in a manner that minimizes the thermal resistance from the solder point to ambient in order to optimize lamp life and optical characteristics. 2200 2000 Maximum Current (mA) 1800 1600 1400 1200 1000 800 Rj-a = 10°C/W 600 Rj-a = 15°C/W 400 Rj-a = 20°C/W 200 0 Rj-a = 25°C/W 0 20 40 60 80 100 120 140 160 60 80 100 120 140 160 Thermal Design - standard Ambient efficacy Temperature (ºC) THERMAL DESIGN - STANDARD 1600 Maximum Current (mA) 1400 1200 1000 800 600 Rj-a = 10°C/W 400 Rj-a = 15°C/W Rj-a = 20°C/W 200 Rj-a = 25°C/W 0 0 20 40 Ambient Temperature (ºC) © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 21 XLAMP ® XP-G2 LED PERFORMANCE GROUPS – LUMINOUS FLUX XLamp XP-G2 LEDs are tested for luminous flux and placed into one of the following luminous‑flux groups: Group Code Minimum Luminous Flux (lm) @ 350 mA Maximum Luminous Flux (lm) @ 350 mA P2 67.2 73.9 P3 73.9 80.6 P4 80.6 87.4 Q2 87.4 93.9 Q3 93.9 100 Q4 100 107 Q5 107 114 R2 114 122 R3 122 130 R4 130 139 R5 139 148 S2 148 156 S3 156 164 S4 164 172 S5 172 180 S6 180 188 S7 188 196 © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 22 XLAMP ® XP-G2 LED PERFORMANCE GROUPS – CHROMATICITY Region 0A 0R 1A 1R 2A 2R 3A 3R 4A x y 0.2950 0.2970 0.2920 0.3060 0.2984 0.3133 0.3009 Region x y 0.2920 0.3060 x y x y 0.2984 0.3133 0.2984 0.3133 0.2895 0.3135 0.2962 0.3220 0.2962 0.3220 0.3028 0.3304 0.3048 0.3207 0.3068 0.3113 0.3042 0.2984 0.3133 0.3048 0.3207 0.3009 0.3042 0.2980 0.2880 0.2895 0.3135 0.2962 0.3220 0.3037 0.2937 0.2950 0.2970 0.2870 0.3210 0.2937 0.3312 0.3009 0.3042 0.3009 0.3042 0.2937 0.3312 0.3005 0.3415 0.3068 0.3113 0.3037 0.2937 0.2962 0.3220 0.3028 0.3304 0.3093 0.2993 0.3048 0.3207 0.3028 0.3304 0.3115 0.3391 0.3130 0.3290 0.3130 0.3290 0.3115 0.3391 0.3205 0.3481 0.3213 0.3373 0.3144 0.3186 0.3130 0.3290 0.3213 0.3373 0.3221 0.3261 0.3068 0.3113 0.3048 0.3207 0.3130 0.3290 0.3144 0.3186 0.3068 0.3113 0.3005 0.3415 0.3099 0.3509 0.3144 0.3186 0.3144 0.3186 0.3099 0.3509 0.3196 0.3602 0.3221 0.3261 0.3161 0.3059 0.3115 0.3391 0.3205 0.3481 0.3231 0.3120 0.3093 0.2993 0.3028 0.3304 0.3115 0.3391 0.3161 0.3059 0.3215 0.3350 0.3207 0.3462 0.3290 0.3538 0.3290 0.3417 0.3290 0.3417 0.3290 0.3538 0.3376 0.3616 0.3371 0.3490 0.3290 0.3300 0.3290 0.3417 0.3371 0.3490 0.3366 0.3369 0.3222 0.3243 0.3215 0.3350 0.3290 0.3417 0.3290 0.3300 0.3222 0.3243 0.3196 0.3602 0.3290 0.3690 0.3290 0.3300 0.3290 0.3300 0.3290 0.3690 0.3381 0.3762 0.3366 0.3369 0.3290 0.3180 0.3290 0.3538 0.3376 0.3616 0.3361 0.3245 0.3231 0.3120 0.3207 0.3462 0.3290 0.3538 0.3290 0.3180 0.3371 0.3490 0.3376 0.3616 0.3463 0.3687 0.3451 0.3554 0.3451 0.3554 0.3463 0.3687 0.3551 0.3760 0.3533 0.3620 0.3440 0.3427 0.3451 0.3554 0.3533 0.3620 0.3515 0.3487 0.3366 0.3369 0.3371 0.3490 0.3451 0.3554 0.3440 0.3427 0.3366 0.3369 0.3381 0.3762 0.3440 0.3428 0.3480 0.3840 0.3429 0.3307 0.3463 0.3687 0.3361 0.3245 0.3376 0.3616 0B 0S 1B 1S 2B 2S 3B 3S Region 0C 0T 1C 1T 2C 2T 3C Region 0D 0U 1D 1U 2D 2U 3D 0.3530 0.3597 0.3548 0.3736 0.3641 0.3804 0.3615 0.3659 0.3615 0.3659 0.3641 0.3804 0.3736 0.3874 0.3702 0.3722 0.3590 0.3521 0.3615 0.3659 0.3702 0.3722 0.3670 0.3578 0.3512 0.3465 0.3530 0.3597 0.3615 0.3659 0.3590 0.3521 4B 4C © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. 4D CLD-DS51 REV 22 23 XLAMP ® XP-G2 LED PERFORMANCE GROUPS – CHROMATICITY (CONTINUED) Region 5A1 5B1 5C1 5D1 6A1 6B1 6C1 6D1 7A1 x y 0.3670 0.3578 0.3686 0.3649 0.3744 0.3685 0.3726 Region x y 0.3686 0.3649 x y x y 0.3744 0.3685 0.3726 0.3612 0.3702 0.3722 0.3763 0.3760 0.3744 0.3685 0.3763 0.3760 0.3825 0.3798 0.3804 0.3721 0.3612 0.3744 0.3685 0.3804 0.3721 0.3783 0.3646 0.3702 0.3722 0.3719 0.3797 0.3782 0.3837 0.3763 0.3760 0.3719 0.3797 0.3736 0.3874 0.3802 0.3916 0.3782 0.3837 0.3782 0.3837 0.3763 0.3760 0.3802 0.3916 0.3782 0.3837 0.3869 0.3958 0.3847 0.3877 0.3847 0.3877 0.3825 0.3798 0.3825 0.3798 0.3847 0.3877 0.3912 0.3917 0.3887 0.3836 0.3847 0.3877 0.3869 0.3958 0.3937 0.4001 0.3912 0.3917 0.3912 0.3917 0.3937 0.4001 0.4006 0.4044 0.3978 0.3958 0.3887 0.3836 0.3912 0.3917 0.3978 0.3958 0.3950 0.3875 0.3783 0.3646 0.3804 0.3721 0.3863 0.3758 0.3840 0.3681 0.3804 0.3721 0.3825 0.3798 0.3887 0.3836 0.3863 0.3758 0.3863 0.3758 0.3887 0.3836 0.3950 0.3875 0.3924 0.3794 0.3840 0.3681 0.3863 0.3758 0.3924 0.3794 0.3898 0.3716 0.3889 0.3690 0.3915 0.3768 0.3981 0.3800 0.3953 0.3720 0.3915 0.3768 0.3941 0.3848 0.4010 0.3882 0.3981 0.3800 0.3981 0.3800 0.4010 0.3882 0.4080 0.3916 0.4048 0.3832 0.3953 0.3720 0.3981 0.3800 0.4048 0.3832 0.4017 0.3751 0.3941 0.3848 0.3968 0.3930 0.4040 0.3966 0.4010 0.3882 0.3968 0.3930 0.3996 0.4015 0.4071 0.4052 0.4040 0.3966 0.4040 0.3966 0.4071 0.4052 0.4146 0.4089 0.4113 0.4001 0.4010 0.3882 0.4040 0.3966 0.4113 0.4001 0.4080 0.3916 0.4080 0.3916 0.4113 0.4001 0.4186 0.4037 0.4150 0.3950 0.4113 0.4001 0.4146 0.4089 0.4222 0.4127 0.4186 0.4037 0.4186 0.4037 0.4222 0.4127 0.4299 0.4165 0.4259 0.4073 0.4150 0.3950 0.4186 0.4037 0.4259 0.4073 0.4221 0.3984 0.4017 0.3751 0.4048 0.3832 0.4116 0.3865 0.4082 0.3782 0.4048 0.3832 0.4080 0.3916 0.4150 0.3950 0.4116 0.3865 0.4116 0.3865 0.4150 0.3950 0.4221 0.3984 0.4183 0.3898 0.4082 0.3782 0.4116 0.3865 0.4183 0.3898 0.4147 0.3814 0.4147 0.3814 0.4183 0.3898 0.4242 0.3919 0.4203 0.3833 0.4183 0.3898 0.4221 0.3984 0.4281 0.4006 0.4242 0.3919 0.4242 0.3919 0.4281 0.4006 0.4342 0.4028 0.4300 0.3939 0.4203 0.3833 0.4242 0.3919 0.4300 0.3939 0.4259 0.3853 5A2 5B2 5C2 5D2 6A2 6B2 6C2 6D2 7A2 Region 5A3 5B3 5C3 5D3 6A3 6B3 6C3 6D3 7A3 © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. Region 5A4 5B4 5C4 5D4 6A4 6B4 6C4 6D4 7A4 CLD-DS51 REV 22 24 XLAMP ® XP-G2 LED PERFORMANCE GROUPS – CHROMATICITY (CONTINUED) Region 7B1 7C1 7D1 8A1 8B1 8C1 8D1 x y 0.4221 0.3984 0.4259 0.4073 0.4322 0.4096 0.4281 Region x y 0.4259 0.4073 x y x y 0.4322 0.4096 0.4281 0.4006 0.4299 0.4165 0.4364 0.4188 0.4322 0.4096 0.4364 0.4188 0.4430 0.4212 0.4385 0.4119 0.4006 0.4322 0.4096 0.4385 0.4119 0.4342 0.4028 0.4342 0.4028 0.4385 0.4119 0.4449 0.4141 0.4403 0.4049 0.4385 0.4119 0.4430 0.4212 0.4496 0.4236 0.4449 0.4141 0.4449 0.4141 0.4403 0.4049 0.4496 0.4236 0.4449 0.4141 0.4562 0.4260 0.4513 0.4164 0.4513 0.4164 0.4465 0.4071 0.4259 0.3853 0.4300 0.3939 0.4359 0.3960 0.4316 0.3873 0.4300 0.3939 0.4342 0.4028 0.4403 0.4049 0.4359 0.3960 0.4359 0.3960 0.4403 0.4049 0.4465 0.4071 0.4418 0.3981 0.4316 0.3873 0.4359 0.3960 0.4418 0.3981 0.4373 0.3893 0.4373 0.3893 0.4418 0.3981 0.4475 0.3994 0.4428 0.3906 0.4418 0.3981 0.4465 0.4071 0.4523 0.4085 0.4475 0.3994 0.4475 0.3994 0.4523 0.4085 0.4582 0.4099 0.4532 0.4008 0.4428 0.3906 0.4475 0.3994 0.4532 0.4008 0.4483 0.3919 0.4465 0.4071 0.4513 0.4164 0.4573 0.4178 0.4523 0.4085 0.4513 0.4164 0.4562 0.4260 0.4624 0.4274 0.4573 0.4178 0.4573 0.4178 0.4624 0.4274 0.4687 0.4289 0.4634 0.4193 0.4523 0.4085 0.4573 0.4178 0.4634 0.4193 0.4582 0.4099 0.4582 0.4099 0.4634 0.4193 0.4695 0.4207 0.4641 0.4112 0.4634 0.4193 0.4687 0.4289 0.4750 0.4304 0.4695 0.4207 0.4695 0.4207 0.4750 0.4304 0.4813 0.4319 0.4756 0.4221 0.4641 0.4112 0.4695 0.4207 0.4756 0.4221 0.4700 0.4126 0.4483 0.3919 0.4532 0.4008 0.4589 0.4021 0.4538 0.3931 0.4532 0.4008 0.4582 0.4099 0.4641 0.4112 0.4589 0.4021 0.4589 0.4021 0.4641 0.4112 0.4700 0.4126 0.4646 0.4034 0.4538 0.3931 0.4589 0.4021 0.4646 0.4034 0.4593 0.3944 7B2 7C2 7D2 8A2 8B2 8C2 8D2 Region 7B3 7C3 7D3 8A3 8B3 8C3 8D3 © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. Region 7B4 7C4 7D4 8A4 8B4 8C4 8D4 CLD-DS51 REV 22 25 XLAMP ® XP-G2 LED STANDARD COOL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS 0.40 0.40 5000 K 0.39 0.38 0.38 5700 K 6500 K 3S 6500 K 2T 0.36 0.36 DT 1T 2B 1S 0T 0.33 0.31 2A 1D 0C 0B 2D 1C 1B 0S 0.32 ANSI C78.377A 2R 1U 0.31 1R 0C 0B 2U ANSI C78.377A 2R 1U 1R 0U 0R 0.29 0.29 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.28 CCx 0.29 0.28 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.28 CCx 0.40 0.40 5000 K 0.39 5000 K 0.39 0.38 5700 K 0.37 0.38 3S 51 6500 K 0.36 6500 K 2C 0T 0C 0A CCy 1U 0S 0.32 0.31 1R 0C 0B 2U ANSI C78.377A 2R 1U 1R 0U 0.36 0.30 0.29 0.28 0.36 0.35 0.34 0.33 0.32 0.28 0.31 0.28 0.30 0.29 0.35 0R 0R 0.29 1D 0D 0.30 0.29 0.28 2A 1A 0A 0U 2D 1C 1B 0.34 0.30 ANSI C78.377A 2R 0D 1S 0T 0.33 2U 1D 1A 0.34 0.33 0B 0.31 3R 2A 2B 0.32 0S 0.32 2D 1C 1B 2C 1T 8000 K 0.31 0.33 2T 2S 0.35 3A 2B 1S 0.36 3B 1T 8000 K 0.34 5700 K DV 0.37 2T 2S 0.35 CCx CCx 0.40 0.40 5000 K 0.39 0.38 0.38 3S 50 6500 K 0.36 6500 K 1U 0A 1R 0U CCx © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. 0.36 0.35 0.29 0.28 0.36 0.35 0.34 0.33 0.28 0.32 0.28 0.31 0.29 0.30 ANSI C78.377A 2R 1U 0R 0R 0.29 2U 1D 1A 0D 0.30 0.29 0.28 0C 0B 0.31 1R 0U 0.30 0S 0.32 3R 2A 1B 0.34 0A ANSI C78.377A 2R 1A 0D 0T 0.33 2U 2D 1C 0.33 0.31 1D 3A 2B 1S 0.32 0C 0B 3R 2A 1B 8000 K 0.34 0.31 0S 0.32 2D 1C 2C 1T 0.30 0T 0.33 3A 2B 1S 3B 2S 0.35 CCy 8000 K 3S 2T 0.36 3B 2C 1T 0.34 5700 K E2 0.37 2T 2S 0.35 5000 K 0.39 5700 K 0.37 CCy 3R 2A 1A 0.30 0R 2D 1D 0D 0A 3A 2B 1C 1B 0S 0.32 0U 0.30 2C 1T 1S 0T 3B 2S 8000 K 0.34 0.33 2U 1A 0D 0A CCy 8000 K 0.34 0.35 2C 2T E1 2S 0.35 CCy 5700 K 0.37 0.37 CCy 5000 K 0.39 CCx CLD-DS51 REV 22 26 XLAMP ® XP-G2 LED STANDARD COOL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS - CONTINUED 0.40 5000 K 0.39 0.38 5700 K 53 0.37 6500 K 0.36 3B 2S 0.35 2C 1T 8000 K CCy 3S 2T 0.34 0T 0.33 0S 0.32 0C 0.31 0A 3R 2A 2U 1D ANSI C78.377A 2R 1A 0D 2D 1C 1B 0B 3A 2B 1S 1U 1R 0U 0.30 0R 0.29 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.28 CCx © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 27 XLAMP ® XP-G2 LED STANDARD WARM AND NEUTRAL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS 0.46 0.45 2700 K 3000 K 0.44 0.43 0.42 4000 K 0.41 E6 4500 K E5 0.40 CCy E7 3500 K 5000 K 0.39 0.38 E3 0.37 0.36 5B4 4C 4B 3C 4D 3B 6B2 5C3 5C2 5B1 5D2 5A3 5D4 6A1 5A2 5D1 5A4 5A1 6D2 6A3 5D3 6A2 6A4 6D1 7A4 7A1 6D4 7D1 8B3 8C1 8B4 8C2 8C3 8C4 8D3 8D2 8D4 8A4 8D1 8A1 7D4 8B2 8A3 8A2 7D3 7D2 7A3 7A2 6D3 8B1 7C4 7C1 7B4 7B1 6C4 6C1 6B4 5C4 6B1 5C1 5B2 6C2 6B3 5B3 E4 6C3 7C2 7B3 7B2 7C3 E8 ANSI C78.377A 4A 3D 0.35 3A 0.34 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.33 CCx 0.46 0.45 2700 K 3000 K 0.44 0.43 3500 K 0.42 4000 K 0.41 4500 K CCy 0.40 F5 5000 K 0.39 F4 0.38 0.37 4B 4D 3B 5C4 5C1 5B4 3C 0.36 5B3 5B1 5D2 5A3 5D4 6A1 5A2 5D1 5A4 5A1 6C2 6B3 6B4 6B1 5D3 6A2 6A3 6A4 7B2 6C3 6B2 5C3 5C2 5B2 4C F6 F7 6C1 6D2 6D1 7B1 6C4 6D3 6D4 7A2 7A1 7A4 F8 7A3 7D1 7C2 7B3 7B4 7C1 7D4 8B1 7C4 7D3 7D2 7C3 8A1 8A2 8B2 8B3 8B4 8A3 8D2 8C1 8C2 8C3 8C4 8D3 8D4 8A4 8D1 ANSI C78.377A 4A 3D 0.35 3A 0.34 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.33 CCx © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 28 XLAMP ® XP-G2 LED STANDARD WARM AND NEUTRAL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS CONTINUED 0.46 0.45 2700 K 3000 K 0.44 0.43 0.42 Z6 4000 K 0.41 Z5 4500 K 0.40 CCy Z7 3500 K 6C3 6C2 6B3 6B2 5C3 5000 K 0.39 5C2 5B3 5C1 5B2 5B4 0.38 4C 0.37 4B 3C 0.36 4D 3B 6B4 5C4 6B1 5D3 6A2 5B1 5D2 5A3 5D4 6A1 5A2 5D1 5A4 5A1 6A3 6A4 6C1 6D2 6D1 7B1 6C4 6D3 6D4 7A2 7A1 7A4 7B4 7A3 7D1 7C2 7B3 7B2 7C1 7D4 8B1 7C4 7D3 7D2 7C3 8A1 8A2 8A3 8B2 Z8 8B3 8B4 8D2 8C1 8C2 8C3 8C4 8D3 8D4 8A4 8D1 ANSI C78.377A 4A 3D 0.35 3A 0.34 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.33 CCx © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 29 XLAMP ® XP-G2 LED STANDARD CHROMATICITY KITS The following table provides the chromaticity bins associated with chromaticity kits. Color Cool White Neutral White Warm White CCT Kit Chromaticity Bins 7000 K DT 0A, 0B, 0C, 0D, 0R, 0S, 0T, 0U, 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U 6200 K 51 0A, 0B, 0C, 0D, 0R, 0S, 0T, 0U, 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U, 2A, 2B, 2C, 2D, 2R, 2S, 2T, 2U, 3A, 3B, 3R, 3S 6000 K 53 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U, 2A, 2B, 2C, 2D, 2R, 2S, 2T, 3A, 3B, 3S 6000 K 50 1A, 1B, 1C, 1D, 2A, 2B, 2C, 2D 6500 K E1 1A, 1B, 1C, 1D 6000 K DV 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U, 2A, 2B, 2C, 2D, 2R, 2S, 2T, 2U 5700 K E2 2A, 2B, 2C, 2D 5000 K E3 3A, 3B, 3C, 3D 4750 K F4 3C, 3D, 4A, 4B 4500 K E4 4A, 4B, 4C, 4D 4250 K F5 4C, 4D, 5A1, 5A2, 5A3, 5A4, 5B1, 5B2, 5B3, 5B4 4000 K E5 5A1, 5A2, 5A3, 5A4, 5B1, 5B2, 5B3, 5B4, 5C1, 5C2, 5C3, 5C4, 5D1, 5D2, 5D3, 5D4 4000 K Z5 5A3, 5B4, 5C1, 5D2 3750 K F6 5C1, 5C2, 5C3, 5C4, 5D1, 5D2, 5D3, 5D4, 6A1, 6A2, 6A3, 6A4, 6B1, 6B2, 6B3, 6B4 3500 K E6 6A1, 6A2, 6A3, 6A4, 6B1, 6B2, 6B3, 6B4, 6C1, 6C2, 6C3, 6C4, 6D1, 6D2, 6D3, 6D4 3500 K Z6 6A3, 6B4, 6C1, 6D2 3250 K F7 6C1, 6C2, 6C3, 6C4, 6D1, 6D2, 6D3, 6D4, 7A1, 7A2, 7A3, 7A4, 7B1, 7B2, 7B3, 7B4 3000 K E7 7A1, 7A2, 7A3, 7A4, 7B1, 7B2, 7B3, 7B4, 7C1, 7C2, 7C3, 7C4, 7D1, 7D2, 7D3, 7D4 3000 K Z7 7A3, 7B4, 7C1, 7D2 2850 K F8 7C1, 7C2, 7C3, 7C4, 7D1, 7D2, 7D3, 7D4, 8A1, 8A2, 8A3, 8A4, 8B1, 8B2, 8B3, 8B4 2700 K E8 8A1, 8A2, 8A3, 8A4, 8B1, 8B2, 8B3, 8B4, 8C1, 8C2, 8C3, 8C4, 8D1, 8D2, 8D3, 8D4 2700 K Z8 8A3, 8B4, 8C1, 8D2 © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 30 XLAMP ® XP-G2 LED BIN AND ORDER CODE FORMATS XP-G2 bin codes and order codes are configured in the following manner: Order Code Bin Code Series XPG = XP-G Series XPG = XP-G Color specification 0 = Outdoor White B = 70 CRI minimum L = Standard CRI H = 80 CRI minimum U = 90 CRI minimum Color specification 0 = Outdoor White B = 70 CRI minimum L = Standard CRI H = 80 CRI minimum U = 90 CRI minimum Internal code Chromaticity bin SSSCCC-BD-HHHH-NNNNN Kit number Version 1 = Standard E = High Efficacy Internal code SSSCCC-BD-WWW-FF-G-AA Color BWT = Gen 2 White Luminous flux group Version 1 = Standard E = High Efficacy Color BWT = Gen 2 White © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 31 XLAMP ® XP-G2 LED REFLOW SOLDERING CHARACTERISTICS In testing, Cree LED has found XLamp XP-G2 LEDs to be compatible with JEDEC J-STD-020C, using the parameters listed below. As a general guideline, Cree LED recommends that users follow the recommended soldering profile provided by the manufacturer of the solder paste used, and therefore it is the lamp or luminaire manufacturer’s responsibility to determine applicable soldering requirements. Note that this general guideline may not apply to all PCB designs and configurations of reflow soldering equipment. tP TP Critical Zone TL to TP Temperature Ramp-up TL tL Tsmax Tsmin Ramp-down ts Preheat 25 t 25˚C to Peak IPC/JEDEC J-STD-020C Time Profile Feature Average Ramp-Up Rate (Tsmax to Tp) Lead-Free Solder 1.2 °C/second Preheat: Temperature Min (Tsmin) 120 °C Preheat: Temperature Max (Tsmax) Preheat: Time (tsmin to tsmax) 170 °C 65-150 seconds Time Maintained Above: Temperature (TL) Time Maintained Above: Time (tL) Peak/Classification Temperature (Tp) 217 °C 45-90 seconds 235 - 245 °C Time Within 5 °C of Actual Peak Temperature (tp) 20-40 seconds Ramp-Down Rate 1 - 6 °C/second Time 25 °C to Peak Temperature 4 minutes max. Note: All temperatures refer to topside of the package, measured on the package body surface. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 32 XLAMP ® XP-G2 LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Lumen Maintenance Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. Moisture Sensitivity Cree LED recommends keeping XLamp LEDs in the provided, resealable moisture-barrier packaging (MBP) until immediately prior to soldering. Unopened MBPs that contain XLamp LEDs do not need special storage for moisture sensitivity. Once the MBP is opened, XLamp XP-G2 LEDs may be stored as MSL 1 per JEDEC J-STD-033, meaning they have unlimited floor life in conditions of ≤ 30 ºC/85% relative humidity (RH). Regardless of the storage condition, Cree LED recommends sealing any unsoldered LEDs in the original MBP. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. REACH Compliance REACH substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative to insure you get the most up-to-date REACH Declaration. REACH banned substance information (REACH Article 67) is also available upon request. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 33 XLAMP ® XP-G2 LED NOTES - CONTINUED UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 34 XLAMP ® XP-G2 LED MECHANICAL DIMENSIONS (TA = 25 °C) Thermal vias, if present, are not shown on these drawings. All measurements are ±.13 mm unless otherwise indicated. SOLDERMASK MAY BE PRES OPTICAL 2.26 MODEL ORIGIN 3.30 OPTICAL MODEL ORIGIN F 2.30 0.73 CATHODE SIDE ANODE SIDE 0.50 3.45 ANODE SIDE E R1.53 3.45 1.30 0.58 TOP VIEW Top View SIDE VIEW Side View BOTTOM V D 3.30 0.50 3.30 0.50 0.50 ANODE SIDE SIDE VIEW 0.50 0.18 0.56 1.30 BOTTOM BottomVIEW View 0.50 3.30 REF. 0.18 TYP 3.30 REF. 0.29 TYP E 0.08 CENTER PAD IS ELECTRICALLY ISOLATED ALTERNATE BOTTOMView VIEW Alternate Bottom 3.30 RECOMMENDED PCB FOOTPRINT A 0.43 3.30 3.30 1.30 0.58 B 0.50 0.56 F CATHODE SIDE 3.30 C SOLDERMASK MAY BE PRESENT 0.50 2.30 0.73 CENTER PAD IS ELECTRICALLY ISOLATED 0.50 0.43 2.26 0.18 SOLDERMASK 3.30 MAY BE PRESENT 0.18 D RECOMMENDED STENCIL OP 0.56 0.56 CES) 0.08 © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 C PROPRIETARY A 35 THE INFORMATIO DRAWING IS THER CREE LED. ANY PART OR AS AW WRITTEN PERMIS IS PROHIBITED. © CreeLE of 2021 SMART Glob 3.45 XLAMP ® XP-G2 LED E SIDE 3.30 SIDE R1.53 3.45 1.30 0.58 TOP VIEW (T  = 25 °C) - CONTINUED MECHANICAL DIMENSIONS A SIDE VIEW CENTER PAD IS ELECTRICALLY ISOLATED BOTTOM VIEW D 3.30 0.56 0.50 0.50 0.56 0.83 (2 PLACES) 0.08 0.43 0.50 0.18 3.30 0.08 0.18 0.18 TYP 0.29 TYP 3.30 3.30 C B 0.50 1.30 RECOMMENDED PCB FOOTPRINT 0.50 Recommended PCB Footprint 0.18 0.50 RECOMMENDED STENCIL OPENING Recommended Stencil Openings* UNLESS OTHERWISE S DIMENSIONS ARE IN M TOLERANCES: 0.5°0.5 BEND 1°DRAWN ANGULAR: MACH ••• TWO ONE PLACE DECIMAL CHECK PLACE 0.05 DECIMA Notes: A • INSIDE BEND RADII E ENG AP MATERIAL •• MACHINE/CASTING MFG AR RADII AND 0.10DIA: • Cree LED recommends using thermal pad kickouts to maximize component thermal performance. Q.A. INTERPRET GEOMETRI B CONFIDENTIAL UPDATED OPTICAL MODEL ORIGIN PROPRIETARY AND TOLERANCING PER: THIRD • Cree LED recommends using white solder mask material to minimize system optical loss. THE INFORMATION CONTAINED INOF THISMATERIAL DRAWING IS THEREPRODUCTION SOLE PROPERTY A INITIAL DRAWING RELEASED CREE LED. ANY INotherMATERIAL PART OR AS Asolder WHOLEpaste. WITHOUT * This stencil has been tested and optimized for the avoidance of voiding when using ALPHA® LUMET® P30 Maxrel For solder FINISH WRITTEN PERMISSION OF CREE LED REVDESCRIPTION IS PROHIBITED. FINISH 2021 CreeLED, Inc. a APPLICATION subsidiary pastes, a “window pane” design for the thermal pad stencil may result in a lower voiding percentage. Contact© local Cree LED Field ofyour SMART Global Holdings, Inc. Applications 5 4 7 2 2 3 Engineer for8 consultation regarding your specific application.6 © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 36 XLAMP ® XP-G2 LED TAPE AND REEL All Cree LED carrier tapes conform to EIA-481D, Automated Component Handling Systems Standard. All dimensions in mm. Po T E Do Bo R P2 W A Anode side F A P1 B D1 "H" Ko B-B SECTION Bo (on a place in the bottom of the corner radii) Ao (on a place in the bottom of the corner radii) R "I" Ao Item Dim. ITEM Ao Dim. 3.70 Bo Ao 3.70 5.40 Ko 2.40 DETAIL"H" DETAIL"I" A-A SECTION Bo Po 5.40 4.00 Ko Po P2 3.35 8.00 4.00 2.00 P1 T P1 E 0.30 8.00 1.75 ITEM F Do D1 W R Dim. 5.50 1.50 1.50 12.00 3deg P2 F 2.00 5.50 TDo 0.36 1.55 E D1 1.75 1.50 W R 12.00 5° NOTICE 1) All Cree LED carrier tapes conform to EIA-481D, Automated Component handling Systems Standard 2) Measurement tolerances unless indicated otherwise: .xx = ±.15 mm 2402-M022 XML3 © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 37 XLAMP ® XP-G2 LED TAPE AND REEL - CONTINUED Feed Direction END START Trailer Loaded Pockets Leader Min. 160 mm empty pockets sealed with tape 1000 Lamps Min. 400 mm empty pockets with min. 100 mm sealed Feed Direction Cover Tape Pocket Tape 13 mm 7.5” © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 38 XLAMP ® XP-G2 LED PACKAGING © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 39 XLAMP ® XP-G2 LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS The following order codes are active and valid order codes, but higher performance options are also available. Please see page 4 page 9 for order codes of XLamp XP-G2 LEDs that could serve as alternatives for the order codes set forth below. XP-G2 High Efficacy, TJ = 85 °C Chromaticity Kit CCT DT 7000 K E1 6500 K 51 6200 K DV 6000 K 50 E2 E3 F4 E4 F5 6200 K 5700 K 5000 K 4750 K 4500 K 4250 K Minimum Luminous Flux (lm) @ 350 mA Order Codes Code Flux (lm) 70 CRI Minimum XPGBWT-BE-0000-00JDT S2 148 R5 139 S2 148 R5 139 S2 148 R5 139 S2 148 R5 139 S2 148 R5 139 S2 148 R5 139 S2 148 R5 139 R4 130 R3 122 R2 114 S2 148 R5 139 R4 130 R3 122 R2 114 S2 148 R5 139 R4 130 R3 122 R2 114 S2 148 R5 139 R4 130 R3 122 R2 114 80 CRI Minimum 90 CRI Minimum XPGBWT-HE-0000-00HDT XPGBWT-BE-0000-00JE1 XPGBWT-HE-0000-00HE1 XPGBWT-BE-0000-00J51 XPGBWT-HE-0000-00H51 XPGBWT-BE-0000-00JDV XPGBWT-HE-0000-00HDV XPGBWT-BE-0000-00J50 XPGBWT-HE-0000-00H50 XPGBWT-BE-0000-00JE2 XPGBWT-HE-0000-00HE2 XPGBWT-BE-0000-00JE3 XPGBWT-HE-0000-00HE3 XPGBWT-UE-0000-00EE3 XPGBWT-BE-0000-00JF4 XPGBWT-HE-0000-00HF4 XPGBWT-UE-0000-00EF4 XPGBWT-BE-0000-00JE4 XPGBWT-HE-0000-00HE4 XPGBWT-UE-0000-00EE4 XPGBWT-BE-0000-00JF5 XPGBWT-HE-0000-00HF5 XPGBWT-UE-0000-00EF5 Note • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 33). © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 40 XLAMP ® XP-G2 LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED Chromaticity Kit E5 F6 E6 F7 E7 F8 E8 CCT 4000 K 3750 K 3500 K 3250 K 3000 K 2850 K 2700 K Minimum Luminous Flux (lm) @ 350 mA Order Codes Code Flux (lm) 70 CRI Minimum XPGBWT-BE-0000-00JE5 S2 148 R5 139 R4 130 R3 122 R2 114 S2 148 R5 139 R4 130 R3 122 R2 114 S2 148 R5 139 R4 130 R3 122 R2 114 80 CRI Minimum 90 CRI Minimum XPGBWT-HE-0000-00HE5 XPGBWT-UE-0000-00EE5 XPGBWT-BE-0000-00JF6 XPGBWT-HE-0000-00HF6 XPGBWT-UE-0000-00EF6 XPGBWT-BE-0000-00JE6 XPGBWT-HE-0000-00HE6 XPGBWT-UE-0000-00EF6 S2 148 XPGBWT-BE-0000-00JF7 R5 139 XPGBWT-BE-0000-00HF7 R4 130 XPGBWT-HE-0000-00GF7 S2 148 XPGBWT-BE-0000-00JE7 R5 139 XPGBWT-BE-0000-00HE7 R4 130 XPGBWT-HE-0000-00GE7 S2 148 XPGBWT-BE-0000-00JF8 R5 139 XPGBWT-BE-0000-00HF8 R4 130 R3 122 R2 114 Q5 107 XPGBWT-HE-0000-00GF8 XPGBWT-UE-0000-00DF8 S2 148 XPGBWT-BE-0000-00JE8 R5 139 XPGBWT-BE-0000-00HE8 R4 130 R3 122 R2 114 Q5 107 XPGBWT-HE-0000-00GE8 XPGBWT-UE-0000-00DE8 Note • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 33). © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 41 XLAMP ® XP-G2 LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED The following order codes are active and valid order codes, but higher performance options are also available. Please see page 10 page 13 for order codes of XLamp XP-G2 LEDs that could serve as alternatives for the order codes set forth below. XP-G2 Standard TJ = 85 °C Minimum Luminous Flux (lm) @ 350 mA Chromaticity Kit CCT 51 6200 K 53 50 E1 E2 Chromaticity Kit E3 F4 E4 CCT 5000 K 4750 K 4500 K Order Codes Code Flux (lm) 70 CRI Typical R5 139 XPGBWT-L1-0000-00H51 R4 130 XPGBWT-L1-0000-00G51 R3 122 XPGBWT-L1-0000-00F51 R5 139 XPGBWT-L1-0000-00H53 R4 130 XPGBWT-L1-0000-00G53 R3 122 XPGBWT-L1-0000-00F53 R5 139 XPGBWT-L1-0000-00H50 R4 130 XPGBWT-L1-0000-00G50 R3 122 XPGBWT-L1-0000-00F50 R5 139 XPGBWT-L1-0000-00HE1 R4 130 XPGBWT-L1-0000-00GE1 R3 122 XPGBWT-L1-0000-00FE1 R5 139 XPGBWT-L1-0000-00HE2 R4 130 XPGBWT-L1-0000-00GE2 R3 122 XPGBWT-L1-0000-00FE2 6000 K 6200 K 6500 K 5700 K Minimum Luminous Flux (lm) @ 350 mA Order Codes Code Flux (lm) 70 CRI Typical R5 139 XPGBWT-01-0000-00HE3 R4 130 XPGBWT-01-0000-00GE3 R3 122 XPGBWT-01-0000-00FE3 R2 114 XPGBWT-01-0000-00EE3 R5 139 XPGBWT-01-0000-00HF4 R4 130 XPGBWT-01-0000-00GF4 R3 122 XPGBWT-01-0000-00FF4 R2 114 XPGBWT-01-0000-00EF4 R5 139 XPGBWT-01-0000-00HE4 R4 130 XPGBWT-01-0000-00GE4 R3 122 XPGBWT-01-0000-00FE4 R2 114 XPGBWT-01-0000-00EE4 80 CRI Minimum Note • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 33). © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 42 XLAMP ® XP-G2 LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED Chromaticity Kit F5 E5 Z5 CCT 4250 K 4000 K 4000- K Minimum Luminous Flux (lm) @ 350 mA Order Codes Code Flux (lm) 70 CRI Typical 80 CRI Minimum R5 139 XPGBWT-01-0000-00HF5 R4 130 XPGBWT-01-0000-00GF5 R3 122 XPGBWT-01-0000-00FF5 R2 114 XPGBWT-01-0000-00EF5 R5 139 XPGBWT-01-0000-00HE5 R4 130 XPGBWT-01-0000-00GE5 R3 122 XPGBWT-01-0000-00FE5 XPGBWT-H1-0000-00FE5 R2 114 XPGBWT-01-0000-00EE5 XPGBWT-H1-0000-00EE5 Q5 107 R3 122 XPGBWT-H1-0000-00FZ5 R2 114 XPGBWT-H1-0000-00EZ5 Q5 107 XPGBWT-H1-0000-00DZ5 XPGBWT-H1-0000-00DE5 Chromaticity Minimum Luminous Flux (lm) @ 350 mA Kit Code Flux (lm) 70 CRI Typical R4 130 XPGBWT-01-0000-00GF6 R3 122 XPGBWT-01-0000-00FF6 XPGBWT-L1-0000-00FF6 XPGBWT-H1-0000-00FF6 R2 114 XPGBWT-01-0000-00EF6 XPGBWT-L1-0000-00EF6 XPGBWT-H1-0000-00EF6 Q5 107 XPGBWT-01-0000-00DF6 XPGBWT-L1-0000-00DF6 XPGBWT-H1-0000-00DF6 R4 130 XPGBWT-01-0000-00GE6 R3 122 XPGBWT-01-0000-00FE6 XPGBWT-L1-0000-00FE6 XPGBWT-H1-0000-00FE6 R2 114 XPGBWT-01-0000-00EE6 XPGBWT-L1-0000-00EE6 XPGBWT-H1-0000-00EE6 Q5 107 XPGBWT-01-0000-00DE6 XPGBWT-L1-0000-00DE6 XPGBWT-H1-0000-00DE6 R3 122 XPGBWT-L1-0000-00FZ6 XPGBWT-H1-0000-00FZ6 R2 114 XPGBWT-L1-0000-00EZ6 XPGBWT-H1-0000-00EZ6 Q5 107 XPGBWT-L1-0000-00DZ6 XPGBWT-H1-0000-00DZ6 R4 130 R3 122 XPGBWT-01-0000-00FF7 XPGBWT-L1-0000-00FF7 XPGBWT-H1-0000-00FF7 R2 114 XPGBWT-01-0000-00EF7 XPGBWT-L1-0000-00EF7 XPGBWT-H1-0000-00EF7 Q5 107 XPGBWT-L1-0000-00DF7 XPGBWT-H1-0000-00DF7 CCT F6 3750 K E6 3500 K Z6 3500 K F7 3250 K Order Codes 80 CRI Typical 80 CRI Minimum 90 CRI Minimum XPGBWT-01-0000-00GF7 Note • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 33). © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 43 XLAMP ® XP-G2 LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED Chromaticity Minimum Luminous Flux (lm) @ 350 mA Kit Code Flux (lm) R3 122 XPGBWT-01-0000-00FE7 R2 114 XPGBWT-01-0000-00EE7 Q5 Q4 Q3 93.9 XPGBWT-U1-0000-00BE7 Q2 87.4 XPGBWT-U1-0000-00AE7 P4 80.6 XPGBWT-U1-0000-009E7 P3 73.9 XPGBWT-U1-0000-008E7 CCT E7 3000 K Z7 3000 K F8 2850 K E8 2700 K Z8 2700 K Order Codes 70 CRI Typical 80 CRI Typical 80 CRI Minimum XPGBWT-L1-0000-00EE7 XPGBWT-H1-0000-00EE7 107 XPGBWT-L1-0000-00DE7 XPGBWT-H1-0000-00DE7 100 XPGBWT-L1-0000-00CE7 XPGBWT-H1-0000-00CE7 90 CRI Minimum XPGBWT-U1-0000-00CE7 R2 114 XPGBWT-L1-0000-00EZ7 XPGBWT-H1-0000-00EZ7 Q5 107 XPGBWT-L1-0000-00DZ7 XPGBWT-H1-0000-00DZ7 Q4 100 XPGBWT-L1-0000-00CZ7 XPGBWT-H1-0000-00CZ7 Q3 93.9 XPGBWT-U1-0000-00BZ7 Q2 87.4 XPGBWT-U1-0000-00AZ7 P4 80.6 XPGBWT-U1-0000-009Z7 P3 73.9 XPGBWT-U1-0000-008Z7 XPGBWT-U1-0000-00CZ7 R2 114 XPGBWT-L1-0000-00EF8 XPGBWT-H1-0000-00EF8 Q5 107 XPGBWT-L1-0000-00DF8 XPGBWT-H1-0000-00DF8 Q4 100 XPGBWT-L1-0000-00CF8 XPGBWT-H1-0000-00CF8 Q3 93.9 XPGBWT-L1-0000-00BF8 XPGBWT-H1-0000-00BF8 Q2 87.4 XPGBWT-U1-0000-00AF8 P4 80.6 XPGBWT-U1-0000-009F8 P3 73.9 XPGBWT-U1-0000-008F8 P2 67.2 R2 114 XPGBWT-L1-0000-00EE8 XPGBWT-H1-0000-00EE8 Q5 107 XPGBWT-L1-0000-00DE8 XPGBWT-H1-0000-00DE8 Q4 100 XPGBWT-L1-0000-00CE8 XPGBWT-H1-0000-00CE8 Q3 93.9 XPGBWT-L1-0000-00BE8 XPGBWT-H1-0000-00BE8 Q2 87.4 XPGBWT-U1-0000-00AE8 P4 80.6 XPGBWT-U1-0000-009E8 P3 73.9 XPGBWT-U1-0000-008E8 P2 67.2 XPGBWT-U1-0000-007E8 Q5 107 XPGBWT-L1-0000-00DZ8 XPGBWT-H1-0000-00DZ8 Q4 100 XPGBWT-L1-0000-00CZ8 XPGBWT-H1-0000-00CZ8 Q3 93.9 XPGBWT-L1-0000-00BZ8 XPGBWT-H1-0000-00BZ8 Q2 87.4 XPGBWT-U1-0000-00AZ8 P4 80.6 XPGBWT-U1-0000-009Z8 P3 73.9 XPGBWT-U1-0000-008Z8 P2 67.2 XPGBWT-U1-0000-007Z8 XPGBWT-U1-0000-00CF8 XPGBWT-U1-0000-00BF8 XPGBWT-U1-0000-007F8 XPGBWT-U1-0000-00BE8 Note • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 33). © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS51 REV 22 44
XPGBWT-H1-0000-00DZ6 价格&库存
很抱歉,暂时无法提供与“XPGBWT-H1-0000-00DZ6”相匹配的价格&库存,您可以联系我们找货
