XPCWHT-L1-0000-004AA
    CREELED
    LED-3P_3.45X3.45MM_SM
    LED 照明 XLamp® XP-C 白色,暖色 2700K 3.2V 350mA 115° 1414(3535 公制)
XPCWHT-L1-0000-004AA 数据手册
PRODUCT FAMILY DATA SHEET XLamp® XP-C LEDs PRODUCT DESCRIPTION FEATURES TABLE OF CONTENTS The XLamp® XP-C LED combines the proven • Available in white (2600 K to 10,000 K Characteristics................................................ 2 lighting-class performance and reliability of CCT), blue, green, amber, red‑orange, Order Codes Suggested for New Designs - the XLamp XR-E LED in a package with 80% red White................................................................ 3 smaller footprint. The XLamp XP-C LED • Maximum drive current: up to 500 mA Order Codes Suggested for New Designs - continues Cree LED’s history of innovation • Low thermal resistance: as low as Color................................................................ 6 in LEDs for lighting applications with wide Relative Spectral Power Distribution............. 9 viewing angle, symmetrical package, 11 °C/W • Wide viewing angle: 120° - 135° Relative Flux vs. Junction Temperature....... 10 unlimited floor life and electrically neutral • Unlimited floor life at ≤ 30 ºC/85% RH Electrical Characteristics.............................. 11 thermal path. Relative Flux vs. Current............................... 12 • Reflow solderable - JEDEC J-STD‑020C compatible XLamp LEDs bring high performance and • Electrically neutral thermal path Typical Spatial Distribution........................... 13 Thermal Design............................................. 14 quality of light to a wide range of lighting • RoHS and REACH compliant Performance Groups - Luminous Flux......... 17 applications, Performance Groups - Chromaticity............ 18 including color‑changing • UL® recognized component (E349212) lighting, portable and personal lighting, Performance Groups - Dominant outdoor lighting, indoor directional lighting, Wavelength.................................................... 22 commercial lighting and emergency‑vehicle Performance Groups - Forward Voltage...... 22 lighting. Standard Cool White Kits Plotted on ANSI Standard Chromaticity Regions................... 23 Standard Warm and Neutral White Kits Plotted on ANSI Standard Chromaticity Regions.......................................................... 24 Standard Chromaticity Kits.......................... 25 Bin and Order Code Formats........................ 25 Reflow Soldering Characteristics................. 26 Notes............................................................. 27 Mechanical Dimensions............................... 29 Tape and Reel................................................ 31 Packaging...................................................... 33 Appendix - Order Codes Not For New Designs.......................................................... 34 Cree LED / 4001 E. Hwy. 54, Suite 2000 / Durham, NC 27709 USA / +1.919.313.5330 / www.cree-led.com © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS19 REV 19 1 XLAMP ® XP-C LED CHARACTERISTICS Characteristics Unit Thermal resistance, junction to solder point◊ - white °C/W 12 Thermal resistance, junction to solder point◊ - blue °C/W 11 Thermal resistance, junction to solder point◊ - green °C/W 13 Thermal resistance, junction to solder point - amber °C/W 12.5 Thermal resistance, junction to solder point - red, red-orange °C/W 11.5 Viewing angle (FWHM) - white degrees 120 Viewing angle (FWHM) - blue, green degrees 135 Viewing angle (FWHM) - amber degrees 125 Viewing angle (FWHM) - red, red-orange degrees 129 Temperature coefficient of voltage - white, blue, green mV/°C -1.0 Temperature coefficient of voltage - amber, red-orange, red mV/°C -2.0 ◊ ◊ ESD withstand voltage (HBM per Mil-Std-883D) - white, blue, green Minimum Typical V ESD Classification (HBM per Mil-Std-883D) - amber, red-orange, red Maximum 8000 Class 2 DC forward current - white, blue, green mA 500 DC forward current - amber, red-orange, red mA 350 Reverse voltage V 1 Forward voltage (@ 350 mA) - white V 3 3.7 Forward voltage (@ 350 mA) - blue, green V 2.9 3.7 Forward voltage (@ 350 mA) - amber V 2.2 2.5 Forward voltage (@ 350 mA) - red-orange, red V 2.35 2.6 Forward voltage (@ 150 mA) - blue V 2.7 Forward voltage (@ 100 mA) - green V 2.55 Forward voltage (@ 150 mA) - red-orange, red V 2.1 Forward voltage (@ 125 mA) - amber V 2.1 Forward voltage (@ 500 mA) - white V 3.1 Forward voltage (@ 500 mA) - blue V 3.0 Forward voltage (@ 500 mA) - green V 3.05 LED junction temperature °C 150 Note: ◊ Thermal resistance measurement was performed per the JEDEC JESD51-14 standard. See the Thermal Resistance Measurement application note for more details. © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS19 REV 19 2 XLAMP ® XP-C LED ORDER CODES SUGGESTED FOR NEW DESIGNS - WHITE (TJ = 25 °C) The following tables provide order codes for XLamp XP-C white LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 25). Minimum Luminous Flux (lm) @ 350 mA Group Flux (lm) R5 139 S2 S3 148 156 Chromaticity Regions Order Codes WA, WB, WC, WD, WE, WF, WG, WH, WJ, WK, WM, WN, WP XPCWHT-L1-0000-00H01 WC, WD, WF, WG XPCWHT-L1-0000-00H02 WC, WD, WF, WG, WH, WJ, WN, WP XPCWHT-L1-0000-00H03 WA, WB, WC, WD, WE, WF, WG, WH, WJ, WK, WM, WN, WP XPCWHT-L1-0000-00J01 WC, WD, WF, WG XPCWHT-L1-0000-00J02 WC, WD, WF, WG, WH, WJ, WN, WP XPCWHT-L1-0000-00J03 WA, WB, WC, WD, WE, WF, WG, WH, WJ, WK, WM, WN, WP XPCWHT-L1-0000-00K01 WC, WD, WF, WG XPCWHT-L1-0000-00K02 WC, WD, WF, WG, WH, WJ, WN, WP XPCWHT-L1-0000-00K03 Notes: • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 27). XLamp XP-C LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS19 REV 19 3 XLAMP ® XP-C LED ORDER CODES SUGGESTED FOR NEW DESIGNS - WHITE (TJ = 25 °C) - CONTINUED The following tables provide order codes for XLamp XP-C white LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 25). For definitions of the chromaticity kits, please see the Standard Chromaticity Kits section (page 25). Chromaticity Kit CCT 51 6200 K 53 50 E1 E2 E3 F4 E4 F5 E5 6000 K 6200 K 6500 K 5700 K 5000 K 4750 K 4500 K 4250 K 4000 K Minimum Luminous Flux (lm) @ 350 mA Order Codes Code Flux (lm) 70 CRI Typical S3 156 XPCWHT-L1-0000-00K51 S2 148 XPCWHT-L1-0000-00J51 R5 139 XPCWHT-L1-0000-00H51 S3 156 XPCWHT-L1-0000-00K53 S2 148 XPCWHT-L1-0000-00J53 R5 139 XPCWHT-L1-0000-00H53 S3 156 XPCWHT-L1-0000-00K50 S2 148 XPCWHT-L1-0000-00J50 R5 139 XPCWHT-L1-0000-00H50 S3 156 XPCWHT-L1-0000-00KE1 S2 148 XPCWHT-L1-0000-00JE1 R5 139 XPCWHT-L1-0000-00HE1 S3 156 XPCWHT-L1-0000-00KE2 S2 148 XPCWHT-L1-0000-00JE2 R5 139 XPCWHT-L1-0000-00HE2 S3 156 XPCWHT-L1-0000-00KE3 S2 148 XPCWHT-L1-0000-00JE3 R5 139 XPCWHT-L1-0000-00HE3 S3 156 XPCWHT-L1-0000-00KF4 S2 148 XPCWHT-L1-0000-00JF4 R5 139 XPCWHT-L1-0000-00HF4 S3 156 XPCWHT-L1-0000-00KE4 S2 148 XPCWHT-L1-0000-00JE4 R5 139 XPCWHT-L1-0000-00HE4 S3 156 XPCWHT-L1-0000-00KF5 S2 148 XPCWHT-L1-0000-00JF5 R5 139 XPCWHT-L1-0000-00HF5 R4 130 XPCWHT-L1-0000-00GF5 S3 156 XPCWHT-L1-0000-00KE5 S2 148 XPCWHT-L1-0000-00JE5 R5 139 XPCWHT-L1-0000-00HE5 R4 130 XPCWHT-L1-0000-00GE5 Notes: • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 27). XLamp XP-C LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS19 REV 19 4 XLAMP ® XP-C LED ORDER CODES SUGGESTED FOR NEW DESIGNS - WHITE (TJ = 25 °C) - CONTINUED Chromaticity Minimum Luminous Flux (lm) @ 350 mA Order Codes Kit CCT Code Flux (lm) S2 148 XPCWHT-L1-0000-00JF6 F6 3750 K R5 139 XPCWHT-L1-0000-00HF6 R4 130 XPCWHT-L1-0000-00GF6 E6 F7 E7 F8 E8 3500 K 3250 K 3000 K 2850 K 2700 K 70 CRI Typical S2 148 XPCWHT-L1-0000-00JE6 R5 139 XPCWHT-L1-0000-00HE6 R4 130 XPCWHT-L1-0000-00GE6 R5 139 XPCWHT-L1-0000-00HF7 R4 130 XPCWHT-L1-0000-00GF7 R3 122 XPCWHT-L1-0000-00FF7 R5 139 XPCWHT-L1-0000-00HE7 R4 130 XPCWHT-L1-0000-00GE7 R3 122 XPCWHT-L1-0000-00FE7 R5 139 XPCWHT-L1-0000-00HF8 R4 130 XPCWHT-L1-0000-00GF8 R3 122 XPCWHT-L1-0000-00FF8 R5 139 XPCWHT-L1-0000-00HE8 R4 130 XPCWHT-L1-0000-00GE8 R3 122 XPCWHT-L1-0000-00FE8 Notes: • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 27). XLamp XP-C LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS19 REV 19 5 XLAMP ® XP-C LED ORDER CODES SUGGESTED FOR NEW DESIGNS - COLOR (TJ = 25 °C) The following tables provide order codes for XLamp XP-C color LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 25). Color Blue Minimum Luminous Flux (@ 350 mA Maximum Order Codes Flux (lm) Flux (lm) Group DWL (nm) Group DWL (nm) B3 465 B6 485 XPCBLU-L1-0000-00Z01 K3 35.2 18.2 20.6 465 B5 480 XPCBLU-L1-0000-00Z02 23.6 470 B5 480 XPCBLU-L1-0000-00Z05 B3 465 B6 485 XPCBLU-L1-0000-00201 B3 465 B5 480 XPCBLU-L1-0000-00202 B4 470 B5 480 XPCBLU-L1-0000-00205 B3 465 B6 485 XPCBLU-L1-0000-00301 B3 465 B5 480 XPCBLU-L1-0000-00302 B4 470 B5 480 XPCBLU-L1-0000-00305 M2 39.8 45.7 Minimum Luminous Flux (@ 350 mA Group Q3 Q4 Green Minimum Group M3 Color Dominant Wavelength (nm) Calculated Minimum Luminous Flux @ 150 mA* Q5 R2 R3 Flux (lm) 93.9 100 107 114 122 20.6 23.6 Dominant Wavelength (nm) Calculated Minimum Luminous Flux @ 100 mA* Flux (lm) 38.7 41.2 44.1 47.0 50.3 Minimum Maximum Order Codes Group DWL (nm) Group DWL (nm) G2 520 G4 535 XPCGRN-L1-0000-00B01 G2 520 G3 530 XPCGRN-L1-0000-00B02 G3 525 G4 535 XPCGRN-L1-0000-00B03 G2 520 G4 535 XPCGRN-L1-0000-00C01 G2 520 G3 530 XPCGRN-L1-0000-00C02 G3 525 G4 535 XPCGRN-L1-0000-00C03 G2 520 G4 535 XPCGRN-L1-0000-00D01 G2 520 G3 530 XPCGRN-L1-0000-00D02 G3 525 G4 535 XPCGRN-L1-0000-00D03 G2 520 G4 535 XPCGRN-L1-0000-00E01 G2 520 G3 530 XPCGRN-L1-0000-00E02 G3 525 G4 535 XPCGRN-L1-0000-00E03 G2 520 G4 535 XPCGRN-L1-0000-00F01 G2 520 G3 530 XPCGRN-L1-0000-00F02 G3 525 G4 535 XPCGRN-L1-0000-00F03 Notes: • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 27). XLamp XP-C LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values at 125 mA are calculated and for reference only. © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS19 REV 19 6 XLAMP ® XP-C LED ORDER CODES SUGGESTED FOR NEW DESIGNS - COLOR (TJ = 25 °C) - CONTINUED Color Amber Minimum Luminous Flux (@ 350 mA Group Flux (lm) Flux (lm) M2 39.8 14.9 M3 45.7 17.1 N2 51.7 19.4 N3 56.8 21.3 N4 Color Red-Orange 62.0 Minimum Luminous Flux (@ 350 mA 23.3 Flux (lm) Flux (lm) P3 73.9 26.0 Q2 80.6 87.4 Minimum 28.3 30.7 Maximum Order Codes Group DWL (nm) Group DWL (nm) A2 585 A3 595 XPCAMB-L1-0000-00201 A3 590 A3 595 XPCAMB-L1-0000-00203 A2 585 A3 595 XPCAMB-L1-0000-00301 A3 590 A3 595 XPCAMB-L1-0000-00303 A2 585 A3 595 XPCAMB-L1-0000-00401 A3 590 A3 595 XPCAMB-L1-0000-00403 A2 585 A3 595 XPCAMB-L1-0000-00501 A3 590 A3 595 XPCAMB-L1-0000-00503 A2 585 A3 595 XPCAMB-L1-0000-00601 A3 590 A3 595 XPCAMB-L1-0000-00603 Dominant Wavelength (nm) Calculated Minimum Luminous Flux @ 125 mA* Group P4 Dominant Wavelength (nm) Calculated Minimum Luminous Flux @ 125 mA* Minimum Maximum Order Codes Group DWL (nm) Group DWL (nm) O3 610 O4 620 XPCRDO-L1-0000-00801 O3 610 O3 615 XPCRDO-L1-0000-00802 O4 615 O4 620 XPCRDO-L1-0000-00803 O3 610 O4 620 XPCRDO-L1-0000-00901 O3 610 O3 615 XPCRDO-L1-0000-00902 O4 615 O4 620 XPCRDO-L1-0000-00903 O3 610 O4 620 XPCRDO-L1-0000-00A01 O3 610 O3 615 XPCRDO-L1-0000-00A02 O4 615 O4 620 XPCRDO-L1-0000-00A03 Notes: • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 27). XLamp XP-C LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values at 125 mA are calculated and for reference only. © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS19 REV 19 7 XLAMP ® XP-C LED ORDER CODES SUGGESTED FOR NEW DESIGNS - COLOR (TJ = 25 °C) - CONTINUED Color Red Minimum Luminous Flux (@ 350 mA Dominant Wavelength (nm) Calculated Minimum Luminous Flux @ 125 mA* Group Flux (lm) Flux (lm) N4 62.0 21.5 P2 67.2 23.3 P3 73.9 25.6 Minimum Maximum Order Codes Group DWL (nm) Group DWL (nm) R2 620 R3 630 XPCRED-L1-0000-00601 R2 620 R2 625 XPCRED-L1-0000-00602 R2 620 R3 630 XPCRED-L1-0000-00701 R2 620 R2 625 XPCRED-L1-0000-00702 R2 620 R3 630 XPCRED-L1-0000-00801 R2 620 R2 625 XPCRED-L1-0000-00802 Notes: • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 27). XLamp XP-C LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values at 125 mA are calculated and for reference only. © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS19 REV 19 8 XLAMP ® XP-C LED Relative Spectral Power-roboto RELATIVE SPECTRAL POWER DISTRIBUTION data from: Copy of 220412 XPC LSG Datasheet Update.xlsx White Relative Radiant Power 100% 80% 60% 5000 K - 10000 K CCT 40% 2600 K - 3700 K CCT 20% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) blue data from: Copy of 220412 XPC LSG Datasheet Update.xlsx Color 100 Relative Radiant Power (%) 80 Blue 60 Green Amber Red-Orange 40 Red 20 0 380 430 480 530 580 630 680 730 780 Wavelength (nm) © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS19 REV 19 9 XLAMP ® XP-C LED Relative Flux Output vs. Junction Temperature RELATIVE FLUX VS. JUNCTION TEMPERATURE (IF = 350 mA) 100% Relative Luminous Flux 90% 80% 70% 60% White 50% Blue 40% Green 30% 20% 10% 0% 25 50 75 100 125 150 Junction Temperature (ºC) red-orange, red from JPHS XPC_RED_Datasheet_updated.xlsx 100% Relative Luminous Flux 90% 80% 70% 60% Amber 50% Red-Orange, Red 40% 30% 20% 10% 0% 25 50 75 100 125 150 Junction Temperature (°C) © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS19 REV 19 10 XLAMP ® XP-C LED Electrical Characteristics (Tj = 25ºC) ELECTRICAL CHARACTERISTICS (TJ = 25 °C) 500 Forward Current (mA) 450 400 Thermal 350 Design White, Blue 300 250 Green 200 150 100 50 2.0 2.5 3.0 3.5 4.0 red-orange, red from JPHS XPC_RED_Datasheet_updated.xlsx Forward Voltage (V) Forward Current (mA) 350 300 250 Amber 200 Red-Orange Red 150 100 50 1.0 1.5 2.0 2.5 3.0 Forward Voltage (V) © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS19 REV 19 11 XLAMP ® XP-C LED Typical Spatial Radiation Pattern RELATIVE FLUX VS. CURRENT (TJ = 25 °C) 160 Relative Luminous Flux (%) 140 120 100 White, Blue 80 Green 60 40 20 0 0 100 200 300 400 Typical Spatial Radiation Pattern Forward Current (mA) 500 Relative Luminous Flux (%) 120 100 80 Amber, RedOrange, Red 60 40 20 0 0 50 100 150 200 250 300 350 Forward Current (mA) red-orange, red from JPHS XPC_RED_Datasheet_updated.xlsx © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS19 REV 19 12 XLAMP ® XP-C LED red-orange, red from JPHS XPC_RED_Datasheet_updated.xlsx TYPICAL SPATIAL DISTRIBUTION 100 Relative Luminous Intensity (%) 80 White 60 Blue, Green Amber Red-Orange 40 Red 20 -90 -70 -50 -30 -10 0 10 30 50 70 90 Angle (º) © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS19 REV 19 13 XLAMP ® XP-C LED THERMAL DESIGN The maximum forward current is determined by the thermal resistance between the LED junction and ambient. It is crucial for the end product to be designed in a manner that minimizes the thermal resistance from the solder point to ambient in order to optimize lamp life Thermal - white - Rth from 20220826 datasheet update summary.xlsx and optical Design characteristics. White 600 Maximum Current (mA) 500 400 Rj-a = 25°C/W Rj-a = 30°C/W 300 Rj-a = 35°C/W Rj-a = 40°C/W 200 100 0 0 20 40 60 80 100 120 140 160 Thermal Design - blue - Rth from 20220826 datasheet update summary.xlsx Ambient Temperature (ºC) Blue 600 Maximum Current (mA) 500 400 Rj-a = 25°C/W Rj-a = 30°C/W 300 Rj-a = 35°C/W Rj-a = 40°C/W 200 100 0 0 20 40 60 80 100 120 140 160 Ambient Temperature (ºC) © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS19 REV 19 14 XLAMP ® XP-C LED THERMAL DESIGN - CONTINUED Green - Rth from 20220826 datasheet update summary.xlsx Green 600 Maximum Current (mA) 500 400 Rj-a = 25°C/W Rj-a = 30°C/W 300 Rj-a = 35°C/W Rj-a = 40°C/W 200 100 0 0 20 40 60 80 100 120 140 160 Ambient Temperature (ºC) Amber - Rth from 20220826 datasheet update summary.xlsx Amber 400 350 Maximum Current (mA) 300 250 Rj-a = 20°C/W Rj-a = 30°C/W 200 Rj-a = 40°C/W Rj-a = 50°C/W 150 100 50 0 0 20 40 60 80 100 120 140 160 Ambient Temperature (ºC) © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS19 REV 19 15 XLAMP ® XP-C LED THERMAL DESIGN - CONTINUED Red, Red-Orange - Rth from 20220826 datasheet update summary.xlsx Red-Orange, Red 400 350 Maximum Current (mA) 300 250 Rj-a = 15°C/W Rj-a = 20°C/W 200 Rj-a = 25°C/W Rj-a = 30°C/W 150 100 50 0 0 20 40 60 80 100 120 140 160 Ambient Temperature (ºC) red-orange, red from JPHS XPC_RED_Datasheet_updated.xlsx © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS19 REV 19 16 XLAMP ® XP-C LED PERFORMANCE GROUPS - LUMINOUS FLUX XLamp XP-C LEDs are tested for luminous flux and placed into one of the following luminous‑flux groups: Group Code Minimum Luminous Flux (lm) @ 350 mA Maximum Luminous Flux (lm) @ 350 mA J 23.5 30.6 K2 30.6 35.2 K3 35.2 39.8 M2 39.8 45.7 M3 45.7 51.7 N2 51.7 56.8 N3 56.8 62.0 N4 62.0 67.2 P2 67.2 73.9 P3 73.9 80.6 P4 80.6 87.4 Q2 87.4 93.9 Q3 93.9 100 Q4 100 107 Q5 107 114 R2 114 122 R3 122 130 R4 130 139 R5 139 148 S2 148 156 S3 156 164 S4 164 172 S5 172 180 © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS19 REV 19 17 XLAMP ® XP-C LED PERFORMANCE GROUPS - CHROMATICITY White XLamp XP-C LEDs are tested for chromaticity and placed into one of the regions defined by the bounding coordinates on the following pages. Region WK WA WM WB WE WN WC x y .283 .284 .295 .297 .298 .288 .287 Region x y .314 .355 .316 .332 .306 .322 .276 .301 .342 .292 .306 .317 .319 .295 .297 .329 .330 .283 .284 .329 .318 .279 .291 .318 .308 .295 .297 .329 .345 .308 .311 .329 .330 .310 .300 .317 .319 .298 .288 .316 .332 .306 .322 .329 .369 .308 .311 .329 .345 .295 .297 .316 .332 .292 .306 .314 .355 .301 .342 .329 .330 .306 .322 .329 .345 .292 .306 .346 .359 .287 .321 .344 .342 .308 .311 .348 .384 .317 .319 .346 .359 .318 .308 .329 .345 .310 .300 .329 .369 .316 .332 .317 .319 .308 .311 .306 .322 WF WP WD WG WJ WH © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS19 REV 19 18 XLAMP ® XP-C LED PERFORMANCE GROUPS - CHROMATICITY (CONTINUED) Region 0A 0R 1A 1R 2A 2R 3A 3R 4A 5A1 x y 0.2950 0.2970 0.2920 0.3060 0.2984 0.3133 0.3009 0.3042 0.2980 0.2950 0.3009 0.3042 0.3037 0.2937 0.3048 0.3130 0.3144 0.3186 0.3068 0.3068 0.3144 0.3186 0.3161 0.3059 0.3093 0.2993 0.3215 0.3290 0.3290 0.3300 0.3222 0.3243 0.3222 0.3243 0.3290 0.3300 0.3290 0.3180 0.3231 0.3371 0.3451 0.3554 0.3440 0.3427 0.3366 0.3369 0.3366 0.3440 0.3429 0.3307 0.3361 0.3530 0.3615 0.3659 0.3590 0.3521 0.3512 0.3670 0.3686 0.3649 0.3744 0.3685 0.3726 0.3612 Region x y 0.2920 0.3060 0.2895 0.3135 0.2962 0.3220 0.2984 0.3133 0.2880 0.2895 0.2970 0.2870 0.2937 0.3312 0.2962 0.3220 0.3207 0.3028 0.3290 0.3115 0.3130 0.3290 0.3113 0.3048 0.3113 0.3005 0.3099 0.3509 0.3115 0.3391 0.3028 0.3304 0.3350 0.3207 0.3417 0.3290 0.3290 0.3417 0.3215 0.3350 0.3196 0.3602 0.3290 0.3690 0.3290 0.3538 0.3120 0.3207 0.3490 0.3376 0.3463 0.3687 0.3451 0.3554 0.3371 0.3490 0.3369 0.3381 0.3762 0.3428 0.3480 0.3840 0.3463 0.3687 0.3245 0.3376 0.3616 0.3597 0.3548 0.3736 0.3641 0.3804 0.3615 0.3659 0.3465 0.3530 0.3578 0.3686 0.3702 0.3722 0.3763 0.3760 0.3744 0.3685 0B 0S 1B 1S 2B 2S 3B 3S 4B 5A2 Region x y 0.2984 0.3133 0.2962 0.3220 0.3028 0.3304 0.3048 0.3135 0.3210 0.3005 0.3415 0.3028 0.3304 0.3304 0.3115 0.3391 0.3205 0.3213 0.3373 0.3207 0.3130 0.3415 0.3099 0.3196 0.3602 0.3205 0.3481 0.3115 0.3462 0.3538 0.3371 0.3490 0.3290 0.3417 0.3290 0.3690 0.3381 0.3762 0.3376 0.3616 0.3462 0.3290 0.3616 0.3463 0.3551 0.3760 0.3533 0.3620 0.3451 0.3554 0.3641 0.3804 0.3736 0.3874 0.3702 0.3722 0.3597 0.3615 0.3649 0.3744 0.3763 0.3760 0.3825 0.3798 0.3804 0.3721 0C 0T 1C 1T 2C 2T 3C 4C 5A3 x y 0.2984 0.3133 0.3048 0.3207 0.3068 0.3113 0.3207 0.3009 0.3042 0.2962 0.3220 0.3037 0.2937 0.2937 0.3312 0.3009 0.3042 0.3068 0.3113 0.3093 0.2993 0.3391 0.3130 0.3290 0.3481 0.3213 0.3373 0.3221 0.3261 0.3290 0.3144 0.3186 0.3509 0.3144 0.3186 0.3221 0.3261 0.3231 0.3120 0.3391 0.3161 0.3059 0.3290 0.3538 0.3290 0.3417 0.3376 0.3616 0.3371 0.3490 0.3366 0.3369 0.3290 0.3300 0.3290 0.3300 0.3366 0.3369 0.3361 0.3245 0.3538 0.3290 0.3180 0.3687 0.3451 0.3554 0.3533 0.3620 0.3515 0.3487 0.3440 0.3427 0.3615 0.3659 0.3702 0.3722 0.3670 0.3578 0.3659 0.3590 0.3521 0.3685 0.3726 0.3612 0.3744 0.3685 0.3804 0.3721 0.3783 0.3646 © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Region 0D 0U 1D 1U 2D 2U 3D 4D 5A4 CLD-DS19 REV 19 19 XLAMP ® XP-C LED PERFORMANCE GROUPS - CHROMATICITY (CONTINUED) Region 5B1 5C1 5D1 6A1 6B1 6C1 6D1 7A1 7B1 7C1 x y 0.3702 0.3722 0.3719 0.3797 0.3782 0.3837 0.3763 0.3760 0.3825 0.3847 0.3912 0.3917 0.3887 0.3783 0.3804 0.3721 0.3863 0.3758 0.3840 0.3681 0.3889 0.3915 0.3981 0.3800 0.3953 0.3720 0.3941 0.3848 0.3968 0.3930 0.4040 0.3966 0.4010 0.4080 0.4113 0.4001 0.4186 0.4037 0.4150 0.3950 0.4017 0.4048 0.4116 0.3865 0.4082 0.3782 0.4147 0.3814 0.4183 0.3898 0.4242 0.3919 0.4203 0.4221 0.4259 0.4073 0.4322 0.4096 0.4281 0.4006 0.4342 0.4385 0.4449 0.4141 0.4403 0.4049 Region x y 0.3719 0.3797 0.3736 0.3874 0.3802 0.3916 0.3782 0.3837 0.3798 0.3847 0.3877 0.3869 0.3937 0.4001 0.3836 0.3912 0.3646 0.3804 0.3825 0.3798 0.3887 0.3836 0.3863 0.3758 0.3690 0.3915 0.3768 0.3941 0.4010 0.3882 0.3981 0.3800 0.3968 0.3930 0.3996 0.4015 0.4071 0.4052 0.3882 0.4040 0.3916 0.4113 0.4146 0.4089 0.4222 0.4127 0.4186 0.4037 0.3751 0.4048 0.3832 0.4080 0.4150 0.3950 0.4116 0.3865 0.4183 0.3898 0.4221 0.3984 0.4281 0.4006 0.3833 0.4242 0.3984 0.4259 0.4299 0.4165 0.4364 0.4188 0.4322 0.4096 0.4028 0.4385 0.4119 0.4430 0.4496 0.4236 0.4449 0.4141 5B2 5C2 5D2 6A2 6B2 6C2 6D2 7A2 7B2 7C2 Region x y 0.3782 0.3837 0.3802 0.3916 0.3869 0.3958 0.3847 0.3877 0.3877 0.3912 0.3958 0.3937 0.4006 0.4044 0.3917 0.3978 0.3721 0.3863 0.3887 0.3836 0.3950 0.3875 0.3924 0.3768 0.3848 0.4080 0.3916 0.4048 0.3832 0.4040 0.3966 0.4071 0.4052 0.4146 0.4089 0.3966 0.4113 0.4001 0.4186 0.4222 0.4127 0.4299 0.4165 0.4259 0.4073 0.3832 0.4116 0.3916 0.4150 0.4221 0.3984 0.4183 0.3898 0.4242 0.3919 0.4281 0.4006 0.4342 0.4028 0.3919 0.4300 0.4073 0.4322 0.4364 0.4188 0.4430 0.4212 0.4385 0.4119 0.4119 0.4449 0.4212 0.4496 0.4562 0.4260 0.4513 0.4164 5B3 5C3 5D3 6A3 6B3 6C3 6D3 7A3 7B3 7C3 x y 0.3763 0.3760 0.3782 0.3837 0.3847 0.3877 0.3825 0.3798 0.3917 0.3887 0.3836 0.4001 0.3912 0.3917 0.3978 0.3958 0.3958 0.3950 0.3875 0.3758 0.3840 0.3681 0.3863 0.3758 0.3924 0.3794 0.3794 0.3898 0.3716 0.3981 0.3800 0.3953 0.3720 0.4010 0.3882 0.3981 0.3800 0.4048 0.3832 0.4017 0.3751 0.4010 0.3882 0.4040 0.3966 0.4113 0.4001 0.4001 0.4080 0.3916 0.4037 0.4150 0.3950 0.4186 0.4037 0.4259 0.4073 0.4221 0.3984 0.3865 0.4082 0.3782 0.3950 0.4116 0.3865 0.4183 0.3898 0.4147 0.3814 0.4203 0.3833 0.4242 0.3919 0.4300 0.3939 0.3939 0.4259 0.3853 0.4096 0.4281 0.4006 0.4322 0.4096 0.4385 0.4119 0.4342 0.4028 0.4141 0.4403 0.4049 0.4236 0.4449 0.4141 0.4513 0.4164 0.4465 0.4071 © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Region 5B4 5C4 5D4 6A4 6B4 6C4 6D4 7A4 7B4 7C4 CLD-DS19 REV 19 20 XLAMP ® XP-C LED PERFORMANCE GROUPS - CHROMATICITY (CONTINUED) Region 7D1 8A1 8B1 8C1 8D1 x y 0.4259 0.3853 0.4300 0.3939 0.4359 0.3960 0.4316 0.3873 0.4373 0.4418 0.4475 0.3994 0.4428 0.4465 0.4513 0.4164 0.4573 0.4178 0.4523 0.4085 0.4582 0.4634 0.4695 0.4207 0.4641 0.4112 0.4483 0.4532 0.4589 0.4021 0.4538 0.3931 Region x y 0.4300 0.3939 0.4342 0.4028 0.4403 0.4049 0.4359 0.3960 0.3893 0.4418 0.3981 0.4465 0.4523 0.4085 0.3906 0.4475 0.4071 0.4513 0.4562 0.4260 0.4624 0.4274 0.4573 0.4178 0.4099 0.4634 0.4193 0.4687 0.4750 0.4304 0.4695 0.4207 0.3919 0.4532 0.4008 0.4582 0.4641 0.4112 0.4589 0.4021 7D2 8A2 8B2 8C2 8D2 Region x y 0.4359 0.3960 0.4403 0.4049 0.4465 0.4071 0.4418 0.3981 0.3981 0.4475 0.4071 0.4523 0.4582 0.4099 0.3994 0.4532 0.4164 0.4573 0.4624 0.4274 0.4687 0.4289 0.4634 0.4193 0.4289 0.4813 0.4319 0.4756 0.4221 0.4008 0.4589 0.4099 0.4641 0.4700 0.4126 0.4646 0.4034 7D3 8A3 8B3 8C3 8D3 x y 0.4316 0.3873 0.4359 0.3960 0.4418 0.3981 0.4373 0.3893 0.3994 0.4428 0.3906 0.4085 0.4475 0.3994 0.4532 0.4008 0.4008 0.4483 0.3919 0.4178 0.4523 0.4085 0.4573 0.4178 0.4634 0.4193 0.4193 0.4582 0.4099 0.4695 0.4207 0.4641 0.4112 0.4750 0.4304 0.4695 0.4207 0.4756 0.4221 0.4700 0.4126 0.4021 0.4538 0.3931 0.4112 0.4589 0.4021 0.4646 0.4034 0.4593 0.3944 © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Region 7D4 8A4 8B4 8C4 8D4 CLD-DS19 REV 19 21 XLAMP ® XP-C LED PERFORMANCE GROUPS - DOMINANT WAVELENGTH Color XLamp XP-C LEDs are tested for dominant wavelength (DWL) and sorted into one of the DWL bins defined below. Color Blue Green Amber Red-Orange Red DWL Group Minimum DWL (nm) @ 350 mA Maximum DWL (nm) @ 350 mA B3 465 470 B4 470 475 B5 475 480 B6 480 485 G2 520 525 G3 525 530 G4 530 535 A2 585 590 A3 590 595 O3 610 615 O4 615 620 R2 620 625 R3 625 630 PERFORMANCE GROUPS - FORWARD VOLTAGE Amber, red-orange, and red XLamp XP-C LEDs are tested for forward voltage and sorted into one of the forward voltage bins defined below. Forward Voltage Group Minimum Forward Voltage (V) @ 350 mA Maximum Forward Voltage (V) @ 350 mA B 1.75 2.0 C 2.0 2.25 D 2.25 2.5 E 2.5 2.75 F 2.75 3.0 G 3.0 3.25 H 3.25 3.5 J 3.5 3.75 © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS19 REV 19 22 XLAMP ® XP-C LED STANDARD COOL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS 0.40 0.40 5000 K 0.39 0.38 3S 51 6500 K 0.36 0T 0C 0A 0S CCy 0.32 0.31 1R 0C 0B 1U 1R 0U CCx 0.36 0.30 0.29 0.28 0.36 0.35 0.34 0.33 0.32 0.28 0.31 0.28 0.30 0.29 0.35 0R 0R 0.29 ANSI C78.377A 2R 1A 0.30 0.29 0.28 2U 1D 0D 0A 0U 3R 2A 1B 0.34 0.30 1U 2D 1C 0.33 0.31 ANSI C78.377A 2R 1A 0D 0T 0.33 2U 1D 3A 2B 1S 0.32 0B 0.34 3R 2A 1B 0S 0.32 2D 3B 2C 1T 8000 K 3A 2B 1C 3S 2T 2S 0.35 0.31 0.33 0.36 3B 1T 1S 53 6500 K 2C 8000 K 0.34 5700 K 0.37 2T 2S 0.35 CCy 0.38 5700 K 0.37 5000 K 0.39 CCx 0.40 5000 K 0.39 0.38 5700 K 6500 K 0.36 2T 3B 2S 0.35 2C 1T 8000 K 0.34 CCy 3S 50 0.37 0T 0.33 0S 0.32 0.31 0C 3R 2A 1D 2U ANSI C78.377A 2R 1A 1U 0D 0A 2D 1C 1B 0B 3A 2B 1S 1R 0U 0.30 0R 0.29 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.28 CCx 0.40 0.40 5000 K 0.39 0.38 0.38 5700 K 3S 0.37 6500 K 0T 0.33 0S 0.32 0B 0.31 2A 8000 K 0.34 ANSI C78.377A 0T 1U 0S 0.32 1R 0.31 0U 0.30 0C 0A 2U ANSI C78.377A 2R 1U 1R 0U 0.30 0R 3R 2A 1D 1A 0D 2D 1C 1B 0B 3A 2B 1S 0.33 2U 2R 2C 1T 3R 1D 1A 0D 0A 2D 1C 1B 0C 3A 2B 1S 3B 2S 0.35 0R 0.29 0.29 © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.36 0.35 0.34 0.28 0.29 CCx 0.33 0.32 0.31 0.30 0.29 0.28 0.28 0.28 CCy 2C 3S 2T 0.36 3B 2S 1T 8000 K 0.34 6500 K 2T E1 0.35 5700 K E2 0.37 CCy 0.36 5000 K 0.39 CCx CLD-DS19 REV 19 23 XLAMP ® XP-C LED STANDARD WARM AND NEUTRAL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS 0.46 0.45 2700 K 3000 K 0.44 0.43 0.42 4000 K 0.41 E6 4500 K E5 0.40 CCy E7 3500 K 5000 K 0.39 0.38 E3 0.37 0.36 E4 4C 4B 3C 4D 3B 6B2 5C3 5C2 5B3 6D2 6A3 5B4 5D3 6A2 5D2 6A4 5A3 5D4 6A1 5A2 5D1 5A4 5A1 5B1 6D1 7A4 7A1 6D4 7D1 8B2 8B3 8C1 8B4 8C2 8C3 8C4 8D3 8D2 8D4 8A4 8D1 8A1 7D4 8A3 8A2 7D3 7D2 7A3 7A2 6D3 8B1 7C4 7C1 7B4 7B1 6C4 6C1 6B4 5C4 6B1 5C1 5B2 6C3 6C2 6B3 7C2 7B3 7B2 7C3 E8 ANSI C78.377A 4A 3D 0.35 3A 0.34 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.33 CCx 0.46 0.45 2700 K 3000 K 0.44 0.43 3500 K 0.42 4000 K 0.41 4500 K CCy 0.40 F5 5000 K 0.39 F4 0.38 0.37 4B 4D 3B 5C4 5C1 5B4 3C 0.36 5B3 5B1 5D2 5A3 5D4 6A1 5A2 5D1 5A4 5A1 6C2 6B3 6B4 6B1 5D3 6A2 6A3 6A4 7B2 6C3 6B2 5C3 5C2 5B2 4C F6 F7 6C1 6D2 6D1 7B1 6C4 6D3 6D4 7A2 7A1 7A4 F8 7A3 7D1 7C2 7B3 7B4 7C1 7D4 8B1 7C4 7D3 7D2 7C3 8A1 8A2 8A3 8B2 8B3 8B4 8D2 8C1 8C2 8C3 8C4 8D3 8D4 8A4 8D1 ANSI C78.377A 4A 3D 0.35 3A 0.34 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.33 CCx © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS19 REV 19 24 XLAMP ® XP-C LED STANDARD CHROMATICITY KITS The following table provides the chromaticity bins associated with chromaticity kits. Color Cool White Neutral White Warm White CCT Kit Chromaticity Bins 6200 K 51 0A, 0B, 0C, 0D, 0R, 0S, 0T, 0U, 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U, 2A, 2B, 2C, 2D, 2R, 2S, 2T, 2U, 3A, 3B, 3R, 3S 6000 K 53 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U, 2A, 2B, 2C, 2D, 2R, 2S, 2T, 3A, 3B, 3S 6200 K 50 1A, 1B, 1C, 1D, 2A, 2B, 2C, 2D 6500 K E1 1A, 1B, 1C, 1D 5700 K E2 2A, 2B, 2C, 2D 5000 K E3 3A, 3B, 3C, 3D 4750 K F4 3C, 3D, 4A, 4B 4500 K E4 4A, 4B, 4C, 4D 4250 K F5 4C, 4D, 5A1, 5A2, 5A3, 5A4, 5B1, 5B2, 5B3, 5B4 4000 K E5 5A1, 5A2, 5A3, 5A4, 5B1, 5B2, 5B3, 5B4, 5C1, 5C2, 5C3, 5C4, 5D1, 5D2, 5D3, 5D4 3750 K F6 5C1, 5C2, 5C3, 5C4, 5D1, 5D2, 5D3, 5D4, 6A1, 6A2, 6A3, 6A4, 6B1, 6B2, 6B3, 6B4 3500 K E6 6A1, 6A2, 6A3, 6A4, 6B1, 6B2, 6B3, 6B4, 6C1, 6C2, 6C3, 6C4, 6D1, 6D2, 6D3, 6D4 3250 K F7 6C1, 6C2, 6C3, 6C4, 6D1, 6D2, 6D3, 6D4, 7A1, 7A2, 7A3, 7A4, 7B1, 7B2, 7B3, 7B4 3000 K E7 7A1, 7A2, 7A3, 7A4, 7B1, 7B2, 7B3, 7B4, 7C1, 7C2, 7C3, 7C4, 7D1, 7D2, 7D3, 7D4 2850 K F8 7C1, 7C2, 7C3, 7C4, 7D1, 7D2, 7D3, 7D4, 8A1, 8A2, 8A3, 8A4, 8B1, 8B2, 8B3, 8B4 2700 K E8 8A1, 8A2, 8A3, 8A4, 8B1, 8B2, 8B3, 8B4, 8C1, 8C2, 8C3, 8C4, 8D1, 8D2, 8D3, 8D4 BIN AND ORDER CODE FORMATS XP-C bin codes and order codes are configured in the following manner: Order Code Bin Code Series XPC = XP-C Series XPC = XP-C Color specification L1 = Standard CRI Color specification L1 = Standard CRI SSSCCC-BD-HHHH-NNNNN Luminous or radiant flux group Kit number Internal code Internal code SSSCCC-BD-WWW-FF-G-AA Color WHT = White BLU = Blue GRN = Green AMB = Amber RDO = Red-Orange RED = Red © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Voltage performance group (amber, red-orange, red) Chromaticity bin or dominant-wavelength group Color WHT = White BLU = Blue GRN = Green AMB = Amber RDO = Red-Orange RED = Red CLD-DS19 REV 19 25 XLAMP ® XP-C LED REFLOW SOLDERING CHARACTERISTICS In testing, Cree LED has found XLamp XP-C LEDs to be compatible with JEDEC J-STD-020C, using the parameters listed below. As a general guideline, Cree LED recommends that users follow the recommended soldering profile provided by the manufacturer of the solder paste used, and therefore it is the lamp or luminaire manufacturer’s responsibility to determine applicable soldering requirements. Note that this general guideline may not apply to all PCB designs and configurations of reflow soldering equipment. tP TP Critical Zone TL to TP Temperature Ramp-up TL tL Tsmax Tsmin Ramp-down ts Preheat 25 t 25˚C to Peak IPC/JEDEC J-STD-020C Time Profile Feature Average Ramp-Up Rate (Tsmax to Tp) Lead-Free Solder 1.2 °C/second Preheat: Temperature Min (Tsmin) 120 °C Preheat: Temperature Max (Tsmax) 170 °C Preheat: Time (tsmin to tsmax) 65-150 seconds Time Maintained Above: Temperature (TL) Time Maintained Above: Time (tL) Peak/Classification Temperature (Tp) 217 °C 45-90 seconds 235 - 245 °C Time Within 5 °C of Actual Peak Temperature (tp) 20-40 seconds Ramp-Down Rate 1 - 6 °C/second Time 25 °C to Peak Temperature 4 minutes max. Note: All temperatures refer to topside of the package, measured on the package body surface. © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS19 REV 19 26 XLAMP ® XP-C LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Moisture Sensitivity Cree LED recommends keeping XLamp LEDs in the provided, resealable moisture-barrier packaging (MBP) until immediately prior to soldering. Unopened MBPs that contain XLamp LEDs do not need special storage for moisture sensitivity. Once the MBP is opened, XLamp XP-C LEDs may be stored as MSL 1 per JEDEC J-STD-033, meaning they have unlimited floor life in conditions of ≤ 30 ºC/85% relative humidity (RH). Regardless of the storage condition, Cree LED recommends sealing any unsoldered LEDs in the original MBP. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. REACH Compliance REACH substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative to insure you get the most up-to-date REACH SVHC Declaration. REACH banned substance information (REACH Article 67) is also available upon request. UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS19 REV 19 27 XLAMP ® XP-C LED NOTES - CONTINUED Intellectual Property For remote phosphor applications, a separate license to certain Cree LED patents is required. © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS19 REV 19 28 XLAMP ® XP-C LED MECHANICAL DIMENSIONS (TA = 25 °C) 8 7 6 Thermal vias, if present, are not shown on these drawings. 4 5 All measurements are ±.13 mm unless otherwise indicated. F BOTTOM OPTICAL MODEL ORIGIN OPTICAL MODEL ORIGIN 3 2.00 CATHODE SIDE 0.73 ANODE SIDE 2 0.50 ANODE SIDE 3.45 E 0.58 R1.30 3.45 ALTERNATE BOTTOM VIEW SideVIEW View SIDE BOTTOM VIEW Top TOPView VIEW D 3.30 2.00 0.73 0.50 1.01 3.30 3.30 0.75 CATHODE SIDE 1.30 B E 3.30 REF. SOLDERMASK MAY BE PRESENT SIDE VIEW 3.30 2.30 0.50 ANODE SIDE 0.58 F 2.30 0.50 C SOLDERMASK MAY BE PRESENT CENTER PAD IS ELECTRICALLY ISOLATED SOLDERMASK MAY BE PRESENT 3.30 2.30 1 1 2 3 3.30 REF. 4 5 CENTER PAD IS ELECTRICALLY ISOLATED D 0.64 1.30 0.50 Bottom View 3.30 RECOMMENDED PCB FOOTPRINT 2.30 0.28 Alternate Bottom View RECOMMENDED STENCIL OPEN 1.01 A 0.75 C © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 8 7 6 PROPRIETARY AND CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF 29 LED. ANY REPRODUCTION IN CLD-DS19 CREE PART OR AS A WHOLE WITHOUT WRITTEN PERMISSION OF CREE LED REV 19 IS PROHIBITED. © 2021 CreeLED, Inc. a subsidiary of SMART Global Holdings, Inc. 5 4 B A RE CATHODE SIDE 0.73 ANODE SIDE 2.30 0.50 0.50 CATHODE SIDE ANODE SIDE XLAMP ® XP-C LED 3.45 E 0.58 R1.30 3.45 MECHANICAL DIMENSIONS - CONTINUED (TA = 25 °C) SIDE VIEW TOP VIEW 3.30 3.30 REF. SOLDERMASK MAY BE PRESENT CENTER PAD IS ELECTRICALLY ISOLATED 3.30 2.30 0.28 D 1.30 2.30 0.50 1.01 0.25 3.30 3.30 0.75 C B 0.50 0.64 1.30 RECOMMENDED PCB FOOTPRINT RECOMMENDED STENCIL OPENING Recommended PCB Footprint Recommended Stencil Opening UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS DRAWN TOLERANCES: • ANGULAR: MACH 0.5° BEND 1° • ONE PLACE DECIMAL 0.5 CHECKED • TWO PLACE DECIMAL 0.05 • INSIDE BEND RADII EQUAL ENG APPR. MATERIAL • MACHINE/CASTING RADII 0.50 MFG APPR. • RADII AND DIA: 0.10 A PROPRIETARY AND CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF CREE LED. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT WRITTEN PERMISSION OF CREE LED IS PROHIBITED. © 2021 CreeLED, Inc. a subsidiary of SMART Global Holdings, Inc. 8 7 6 5 4 © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. B OPTICAL MODEL ORIGIN A DRAWING INITIATED REV DESCRIPTION INTERPRET GEOMETRIC TOLERANCING PER: MATERIAL NAME DATE TLING 24AUG22 Q.A. THIRD ANGLE PROJECTION MATERIAL SIZE DWG. NO. 350 C FINISH FINISH SCALE: 20:1 WEIG APPLICATION 2 X X X TITLE: 3 1 2 CLD-DS19 REV 19 30 XLAMP ® XP-C LED TAPE AND REEL All Cree LED carrier tapes conform to EIA-481D, Automated Component Handling Systems Standard. Except as noted, all dimensions in mm. All measurements are ±.15 mm unless otherwise indicated. Po T E Do Bo R P2 W A Anode side F A P1 B D1 "H" Ko B-B SECTION Bo (on a place in the bottom of the corner radii) Ao (on a place in the bottom of the corner radii) R "I" Ao Item Dim. ITEM Ao 3.75Dim. Bo Ao Ko 3.75 3.75 2.10 DETAIL"H" DETAIL"I" A-A SECTION Bo Po 3.754.00 Ko P1 Po P2 2.10 8.00 4.00 2.00 T P1 E 0.30 8.00 1.75 ITEM F Do D1 W R Dim. 5.50 1.50 1.50 12.00 8deg P2 F 2.00 5.50 T Do 0.30 1.50 E D1 1.75 1.50 W R 12.00 8° NOTICE 1) All Cree LED carrier tapes conform to EIA-481D, Automated Component handling Systems Standard 2) Measurement tolerances unless indicated otherwise: .xx = ±.15 mm 2402-M004 XPC © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS19 REV 19 31 XLAMP ® XP-C LED TAPE AND REEL - CONTINUED Feed Direction END START Trailer Loaded Pockets Leader Min. 160 mm empty pockets sealed with tape 1000 Lamps Min. 400 mm empty pockets with min. 100 mm sealed Feed Direction Cover Tape Pocket Tape 13 mm 7” © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS19 REV 19 32 XLAMP ® XP-C LED PACKAGING © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS19 REV 19 33 XLAMP ® XP-C LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS The following order codes are active and valid order codes, but higher performance options are also available. Please see page 3 for order codes of XLamp XP-C LEDs that could serve as alternatives for the order codes set forth below. Minimum Luminous Flux (lm) @ 350 mA Group Flux (lm) Q2 87.4 Q3 Q4 Q5 R4 93.9 100 107 130 Chromaticity Regions Order Codes WA, WB, WC, WD, WE, WF, WG, WH, WJ, WK, WM, WN, WP XPCWHT-L1-0000-00A01 WC, WD, WF, WG XPCWHT-L1-0000-00A02 WC, WD, WF, WG, WH, WJ, WN, WP XPCWHT-L1-0000-00A03 WA, WB, WC, WD, WE, WF, WG, WH, WJ, WK, WM, WN, WP XPCWHT-L1-0000-00B01 WC, WD, WF, WG XPCWHT-L1-0000-00B02 WC, WD, WF, WG, WH, WJ, WN, WP XPCWHT-L1-0000-00B03 WA, WB, WC, WD, WE, WF, WG, WH, WJ, WK, WM, WN, WP XPCWHT-L1-0000-00C01 WC, WD, WF, WG XPCWHT-L1-0000-00C02 WC, WD, WF, WG, WH, WJ, WN, WP XPCWHT-L1-0000-00C03 WA, WB, WC, WD, WE, WF, WG, WH, WJ, WK, WM, WN, WP XPCWHT-L1-0000-00D01 WC, WD, WF, WG XPCWHT-L1-0000-00D02 WC, WD, WF, WG, WH, WJ, WN, WP XPCWHT-L1-0000-00D03 WA, WB, WC, WD, WE, WF, WG, WH, WJ, WK, WM, WN, WP XPCWHT-L1-0000-00G01 WC, WD, WF, WG XPCWHT-L1-0000-00G02 Notes: • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 27). XLamp XP-C LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS19 REV 19 34 XLAMP ® XP-C LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED The following order codes are active and valid order codes, but higher performance options are also available. Please see page 4 page 5 for order codes of XLamp XP-C LEDs that could serve as alternatives for the order codes set forth below. Chromaticity Minimum Luminous Flux (lm) @ 350 mA Order Codes Kit CCT Code Flux (lm) 70 CRI Typical 51 6200 K R4 130 XPCWHT-L1-0000-00G51 53 6000 K R4 130 XPCWHT-L1-0000-00G53 50 6200 K R4 130 XPCWHT-L1-0000-00G50 E1 6500 K R4 130 XPCWHT-L1-0000-00GE1 E2 5700 K R4 130 XPCWHT-L1-0000-00GE2 R4 130 XPCWHT-L1-0000-00GE3 R3 122 XPCWHT-L1-0000-00FE3 R4 130 XPCWHT-L1-0000-00GF4 R3 122 XPCWHT-L1-0000-00FF4 R4 130 XPCWHT-L1-0000-00GE4 R3 122 XPCWHT-L1-0000-00FE4 R3 122 XPCWHT-L1-0000-00FF5 R2 114 XPCWHT-L1-0000-00EF5 R3 122 XPCWHT-L1-0000-00FE5 R2 114 XPCWHT-L1-0000-00EE5 R3 122 XPCWHT-L1-0000-00FF6 R2 114 XPCWHT-L1-0000-00EF6 R3 122 XPCWHT-L1-0000-00FE6 R2 114 XPCWHT-L1-0000-00EE6 E3 5000 K F4 4750 K E4 4500 K F5 4250 K E5 4000 K F6 3750 K E6 3500 K F7 3250 K E7 3000 K F8 2850 K E8 2700 K R2 114 XPCWHT-L1-0000-00EF7 Q5 107 XPCWHT-L1-0000-00DF7 R2 114 XPCWHT-L1-0000-00EE7 Q5 107 XPCWHT-L1-0000-00DE7 R2 114 XPCWHT-L1-0000-00EF8 Q5 107 XPCWHT-L1-0000-00DF8 R2 114 XPCWHT-L1-0000-00EE8 Q5 107 XPCWHT-L1-0000-00DE8 Notes: • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 27). XLamp XP-C LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS19 REV 19 35 XLAMP ® XP-C LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED The following order codes are active and valid order codes, but higher performance options are also available. Please see page 6 for order codes of XLamp XP-C LEDs that could serve as alternatives for the order codes set forth below. Color Group Flux (lm) J 23.5 Blue K2 Color 30.6 Minimum N3 N4 P2 P3 P4 Flux (lm) 56.8 62.0 67.2 73.9 80.6 Maximum Order Codes Group DWL (nm) Group DWL (nm) B3 465 B6 485 XPCBLU-L1-0000-00W01 B3 465 B5 480 XPCBLU-L1-0000-00W02 B4 470 B5 480 XPCBLU-L1-0000-00W05 B3 465 B6 485 XPCBLU-L1-0000-00Y01 B3 465 B5 480 XPCBLU-L1-0000-00Y02 B4 470 B5 480 XPCBLU-L1-0000-00Y05 Dominant Wavelength (nm) Minimum Luminous Flux (@ 350 mA Group Green Dominant Wavelength (nm) Minimum Luminous Flux (@ 350 mA Minimum Maximum Order Codes Group DWL (nm) Group DWL (nm) G2 520 G4 535 XPCGRN-L1-0000-00501 G2 520 G3 530 XPCGRN-L1-0000-00502 G3 525 G4 535 XPCGRN-L1-0000-00503 G2 520 G4 535 XPCGRN-L1-0000-00601 G2 520 G3 530 XPCGRN-L1-0000-00602 G3 525 G4 535 XPCGRN-L1-0000-00603 G2 520 G4 535 XPCGRN-L1-0000-00701 G2 520 G3 530 XPCGRN-L1-0000-00702 G3 525 G4 535 XPCGRN-L1-0000-00703 G2 520 G4 535 XPCGRN-L1-0000-00801 G2 520 G3 530 XPCGRN-L1-0000-00802 G3 525 G4 535 XPCGRN-L1-0000-00803 G2 520 G4 535 XPCGRN-L1-0000-00901 G2 520 G3 530 XPCGRN-L1-0000-00902 G3 525 G4 535 XPCGRN-L1-0000-00903 Notes: • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 27). XLamp XP-C LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS19 REV 19 36 XLAMP ® XP-C LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED The following order codes are active and valid order codes, but higher performance options are also available. Please see page 7 and page 8 for order codes of XLamp XP-C LEDs that could serve as alternatives for the order codes set forth below. Color Dominant Wavelength (nm) Minimum Luminous Flux (@ 350 mA Group N2 N3 Flux (lm) Minimum P2 Color Minimum Luminous Flux (@ 350 mA Order Codes Group DWL (nm) Group DWL (nm) O3 610 O4 620 XPCRDO-L1-0000-00401 O3 610 O3 615 XPCRDO-L1-0000-00402 O4 615 O4 620 XPCRDO-L1-0000-00403 O3 610 O4 620 XPCRDO-L1-0000-00501 O3 610 O3 615 XPCRDO-L1-0000-00502 O4 615 O4 620 XPCRDO-L1-0000-00503 O3 610 O4 620 XPCRDO-L1-0000-00601 O3 610 O3 615 XPCRDO-L1-0000-00602 O4 615 O4 620 XPCRDO-L1-0000-00603 O3 610 O4 620 XPCRDO-L1-0000-00701 O3 610 O3 615 XPCRDO-L1-0000-00702 O4 615 O4 620 XPCRDO-L1-0000-00703 51.7 56.8 Red-Orange N4 Maximum 62.0 67.2 Dominant Wavelength (nm) Calculated Minimum Luminous Flux @ 125 mA* Group Flux (lm) Flux (lm) M2 39.8 15.2 M3 45.7 17.5 N2 51.7 19.7 N3 56.8 21.7 Red Minimum Maximum Order Codes Group DWL (nm) Group DWL (nm) R2 620 R3 630 XPCRED-L1-0000-00201 R2 620 R2 625 XPCRED-L1-0000-00202 R2 620 R3 630 XPCRED-L1-0000-00301 R2 620 R2 625 XPCRED-L1-0000-00302 R2 620 R3 630 XPCRED-L1-0000-00401 R2 620 R2 625 XPCRED-L1-0000-00402 R2 620 R3 630 XPCRED-L1-0000-00501 R2 620 R2 625 XPCRED-L1-0000-00502 Notes: • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 27). XLamp XP-C LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2008-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS19 REV 19 37
XPCWHT-L1-0000-004AA 价格&库存
很抱歉,暂时无法提供与“XPCWHT-L1-0000-004AA”相匹配的价格&库存,您可以联系我们找货
