New Featured Products
Aluminum Electrolytic Capacitors MZS Series
SMD Aluminum electrolytic capacitors.
Low ESR/High Ripple current capability!
2,000 hours life operation at 105℃ guaranteed.
For smoothing, filtering and hold-up of electronic circuits
and other applications that require high performance.
United Chemi-Con’s new MZS series SMD type aluminum electrolytic
capacitors are recommended for smoothing, filtering and holdup for
electronic circuits, modules and other extremely high performance
applications.
The MZS series is a higher capacitance per case size version of our
industry leading low ESR MZR series. The temperature range is
-55℃ ~ 105℃.
Due to the downsizing trend in electronic power modules including ECU’s,
super high capacitance per volume is a highly desirable attribute and
Chemi-Con delivers!
The MZS series can also be equipped with an anti-vibration base that
improves anti-vibe resistance to 30-40G. The MZS series is AEC-Q200
Compliant. It is perfect for filtering high frequency noise.
The MZS series can improve the performance of your design along with
enhancing the reliability of your overall system
Features
・Endurance:-55℃ ~ 105℃ 2,000h
・Voltage: 25V ~ 35Vdc
・Capacitance:330 ~ 1000μF
・Size:φ8 and 10mm x 10.0mmL
Applications
・Performance Modules (ECU)
・Excellent Output Filter
・High Frequency smoothing
・Excellent hold-up capability
United Chemi-Con, Inc Rolling Meadows, IL wwww.chemi-con.com 847-696-2000
很抱歉,暂时无法提供与“EMZS350ARA561MJA0G”相匹配的价格&库存,您可以联系我们找货
