EMZS250ARA102MJA0G
EMZS250ARA102MJA0G
    NCC(贵弥功)
    径向,Can-SMD
    CAP ALUM 1000UF 20% 25V SMD
EMZS250ARA102MJA0G 数据手册
New Featured Products Aluminum Electrolytic Capacitors MZS Series SMD Aluminum electrolytic capacitors. Low ESR/High Ripple current capability! 2,000 hours life operation at 105℃ guaranteed. For smoothing, filtering and hold-up of electronic circuits and other applications that require high performance. United Chemi-Con’s new MZS series SMD type aluminum electrolytic capacitors are recommended for smoothing, filtering and holdup for electronic circuits, modules and other extremely high performance applications. The MZS series is a higher capacitance per case size version of our industry leading low ESR MZR series. The temperature range is -55℃ ~ 105℃. Due to the downsizing trend in electronic power modules including ECU’s, super high capacitance per volume is a highly desirable attribute and Chemi-Con delivers! The MZS series can also be equipped with an anti-vibration base that improves anti-vibe resistance to 30-40G. The MZS series is AEC-Q200 Compliant. It is perfect for filtering high frequency noise. The MZS series can improve the performance of your design along with enhancing the reliability of your overall system Features ・Endurance:-55℃ ~ 105℃ 2,000h ・Voltage: 25V ~ 35Vdc ・Capacitance:330 ~ 1000μF ・Size:φ8 and 10mm x 10.0mmL Applications ・Performance Modules (ECU) ・Excellent Output Filter ・High Frequency smoothing ・Excellent hold-up capability United Chemi-Con, Inc Rolling Meadows, IL wwww.chemi-con.com 847-696-2000
EMZS250ARA102MJA0G 价格&库存
很抱歉,暂时无法提供与“EMZS250ARA102MJA0G”相匹配的价格&库存,您可以联系我们找货
