106 PED-ST
www.vishay.com
Vishay BCcomponents
Aluminum Electrolytic Capacitors,
Power Eurodin, Screw Terminals
FEATURES
LINKS TO ADDITIONAL RESOURCES
3D 3D
3D Models
• Very long useful life: 20 000 h at 85 °C
• Extremely low ESR and ESL allowing very high
ripple current load
• High resistance to shock and vibration
• Polarized aluminum electrolytic capacitors,
non-solid electrolyte
• Large types, cylindrical aluminum case, insulated with a
blue sleeve
• Also available in bolt version (106 PED-STB)
• Pressure relief in the sealing
• Charge and discharge proof
• High reliability
• Material categorization: for definitions of compliance
please see www.vishay.com/doc?99912
APPLICATIONS
101/102 PHR-ST
higher
CV/volume
106 PED-ST
Fig. 1
Computer, telecommunications, and industrial systems
Smoothing and filtering
Standard and switched mode power supplies
Energy storage in pulse systems
MARKING
QUICK REFERENCE DATA
DESCRIPTION
Nominal case size (Ø D x L in mm)
Rated capacitance range
(E6 series), CR
Tolerance on CR
Rated voltage range, UR
Category temperature range
Endurance test at 85 °C
Useful life at 85 °C
Shelf life at 0 V, 85 °C
Based on sectional specification
Climatic category IEC 60068
VALUE
35 x 60 to 90 x 220
1000 μF to 330 000 μF
-10 % to +30 %
25 V to 100 V
-40 °C to +85 °C
8000 h
20 000 h
500 h
IEC 60384-4 / EN 130300
40 / 085 / 56
The capacitors are marked with the following information:
• Rated capacitance (in μF)
• Tolerance on rated capacitance, code letter in accordance
with IEC 60062 (Q for -10 % / +30 %)
• Rated voltage (in V)
• Date code
• Name of manufacturer
• Code for factory of origin
• “-” sign to identify the negative terminal, visible from the
top and side of the capacitor
• Code number
• Climatic category in accordance with IEC 60068
• “LL” for long life grade
SELECTION CHART FOR CR, UR, AND RELEVANT NOMINAL CASE SIZES (Ø D x L in mm)
CR
(μF)
1000
1500
2200
3300
4700
6800
10 000
15 000
22 000
33 000
47 000
68 000
100 000
150 000
220 000
330 000
Revision: 03-Jun-2022
UR (V)
25
35 x 60
35 x 60
35 x 80
35 x 105
50 x 80
50 x 105
65 x 105
65 x 105
76 x 105
76 x 146
76 x 220
90 x 146
90 x 220
40
35 x 60
35 x 60
35 x 80
35 x 105
50 x 80
50 x 105
65 x 105
65 x 105
76 x 105
76 x 146
76 x 220
90 x 146
90 x 220
63
35 x 60
35 x 60
35 x 80
35 x 105
50 x 80
50 x 105
65 x 105
65 x 105
76 x 105
76 x 146
76 x 220
90 x 220
100
35 x 60
35 x 60
35 x 80
35 x 105
50 x 80
50 x 105
65 x 105
65 x 105
76 x 105
76 x 146
76 x 220
90 x 220
Document Number: 28384
1
For technical questions, contact: aluminumcaps2@vishay.com
THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT
ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
106 PED-ST
www.vishay.com
Vishay BCcomponents
DIMENSIONS in millimeters AND AVAILABLE FORMS
Lt
Lt
Safety
vent
L
L
Thread M x S
Mb
lb
d1
d1
D
D
P
B
B
H
H
T
Standard M5 disc
T
Clamp mounting (ST)
Threaded stud mounting (STB)
Fig. 2A - Mechanical drawings for standard M5 disc versions.
For details refer to Table 1
Safety
vent
Lt
Thread M x S
Lt
L
Mb
L
d1
lb
d1
P
D
D
B
B
H
H
T
High current M6 disc
T
Clamp mounting (ST)
Fig. 2B - Mechanical drawings for high current M6 disc versions.
Note
• Maximum permissible torque which may be applied to the termination screws: 2 Nm for M5; 2.5 Nm for M6
For accessories refer to document “Mounting Accessories”, see www.vishay.com/doc?28348
The capacitors are delivered with screws and washers
Table 1
DIMENSIONS in millimeters AND MASS
M
S-0
Mb
Ib ± 0.1
MASS
(g)
7.9
M5
9.5
M8
12.0
75
11.0
7.9
M5
9.5
M8
12.0
95
11.0
7.9
M5
9.5
M8
12.0
130
4.8
11.0
7.9
M5
9.5
M12
16.0
200
4.8
11.0
7.9
M5
9.5
M12
16.0
300
7.0
4.6
11.9
7.9
M5
9.5
M12
16.0
480
28.5
5.5
3.5
18.0
13.0
M6
8.5
M12
16.0
480
76.4
31.8
7.0
4.6
11.7
7.9
M5
9.5
M12
16.0
700
105.8 110.2
76.4
31.8
5.5
3.5
18.3
13.0
M6
8.5
M12
16.0
700
2A
145.8 151.7
76.4
31.8
7.0
4.6
11.7
7.9
M5
9.5
M12
16.0
1000
2B
145.8 150.2
76.4
31.8
5.5
3.5
18.3
13.0
M6
8.5
M12
16.0
1000
2A
219.8 225.7
76.4
31.8
7.0
4.6
11.7
7.9
M5
9.5
M12
16.0
1500
76 x 220 HC
2B
219.8 224.2
76.4
31.8
5.5
3.5
18.3
13.0
M6
8.5
M12
16.0
1500
90 x 146 HC
2B
150.1 155.4
89.4
31.8
7.9
0.0
13.0
13.0
M6
10.0
M12
16.0
1300
90 x 220 HC
2B
218.1 223.4
89.4
31.8
7.9
0.0
13.0
13.0
M6
10.0
M12
16.0
2000
DESIGN
DRAWING
L±1
P ± 0.3
T ± 0.2
35 x 60
2A
63.3
68.7
35.3
12.8
7.0
4.6
11.0
35 x 80
2A
81.3
35 x 105
2A
86.7
35.3
12.8
7.0
4.6
103.3 108.7
35.3
12.8
7.0
4.6
50 x 80
2A
82.8
50 x 105
2A
88.8
51.0
22.2
7.1
104.8 110.8
51.0
22.2
7.1
65 x 105
2A
104.8 110.7
65.0
28.5
65 x 105 HC
2B
104.8 109.2
65.0
76 x 105
2A
105.8 111.7
76 x 105 HC
2B
76 x 146
76 x 146 HC
76 x 220
Lt ± 1 D ± 1
H ± 0.3 B ± 0.3 d1 ± 0.1
2
106 PED-ST
www.vishay.com
Vishay BCcomponents
PACKAGING QUANTITIES AND DIMENSIONS in millimeters
(units per box)
50
50
50
25
25
16
16
12
12
12
12
12
12
8
8
DESIGN
35 x 60
35 x 80
35 x 105
50 x 80
50 x 105
65 x 105
65 x 105 HC
76 x 105
76 x 105 HC
76 x 146
76 x 146 HC
76 x 220
76 x 220 HC
90 x 146 HC
90 x 220 HC
CARDBOX DIMENSIONS
LxWxH
377 x 375 x 88
377 x 375 x 123
377 x 375 x 129
377 x 375 x 123
377 x 375 x 129
377 x 375 x 129
377 x 375 x 129
377 x 375 x 129
377 x 375 x 129
377 x 375 x 168
377 x 375 x 168
377 x 375 x 242
377 x 375 x 242
377 x 375 x 168
377 x 375 x 242
Note
• For STB version holds:
H cardbox box: + 10 mm
ORDERING EXAMPLE
ELECTRICAL DATA
SYMBOL
CR
IR
IL5
ESR
Z
Electrolytic capacitor 106 PED-ST series
DESCRIPTION
Rated capacitance at 100 Hz,
tolerance -10 % to +30 %
Rated RMS ripple current at 100 Hz, 85 °C
Max. leakage current after 5 min at UR
Max. equivalent series resistance at 100 Hz
Max. impedance at 20 kHz
10 000 μF / 25 V; -10 % / +30 %
Nominal case size: Ø 35 mm x 80 mm, ST version
Ordering code: MAL210616103E3
Note
• Unless otherwise specified, all electrical values in Tables 2 and 3
apply at Tamb = 20 °C, P = 86 kPa to 106 kPa, RH = 45 % to 75 %
Table 2
ELECTRICAL DATA AND ORDERING INFORMATION
UR
(V)
CR
100 Hz
(μF)
NOMINAL
CASE SIZE
ØDxL
(mm)
IR
100 Hz
85 °C
(A)
IL5
5 MIN.
(mA)
ESR
MAX.
100 Hz
(mΩ)
Z
MAX.
20 kHz
(mΩ)
25
4700
6800
10 000
15 000
22 000
33 000
47 000
68 000
100 000
150 000
220 000
220 000
330 000
35 x 60
35 x 60
35 x 80
35 x 105
50 x 80
50 x 105
65 x 105
65 x 105
76 x 105
76 x 146
76 x 220
90 x 146
90 x 220
5.8
6.3
7.7
9.0
13.5
16.0
22.5
23.0
29.5
34.0
40.0
50.0
50.0
0.24
0.34
0.50
0.75
1.10
1.65
3.35
3.40
5.00
7.5
11.0
11.0
16.5
70
55
40
30
19
14
10
10
9
8
8
8
8
50
42
31
24
15
12
10
10
8
8
8
8
8
STANDARD M5 DISC
STB
ST
ORDERING
ORDERING
CODE
CODE
MAL2106.......
MAL2106.......
16472E3
56472E3
16682E3
56682E3
16103E3
56103E3
16153E3
56153E3
16223E3
56223E3
16333E3
56333E3
16473E3
56473E3
16683E3
56683E3
16104E3
56104E3
16154E3
56154E3
16224E3
56224E3
HIGH CURRENT M6 DISC
STB
ST
ORDERING
ORDERING
CODE
CODE
MAL2106....... MAL2106.......
36473E3
76473E3
36683E3
76683E3
36104E3
76104E3
36154E3
76154E3
36224E3
76224E3
46224E3
86224E3
46334E3
86334E3
3
106 PED-ST
www.vishay.com
Vishay BCcomponents
UR
(V)
40
63
100
STANDARD M5 DISC
STB
ST
ORDERING
ORDERING
CODE
CODE
MAL2106.......
MAL2106.......
STB
ST
ORDERING
ORDERING
CODE
CODE
CR
100 Hz
(μF)
NOMINAL
CASE SIZE
ØDxL
(mm)
IR
100 Hz
85 °C
(A)
IL5
5 MIN.
(mA)
ESR
MAX.
100 Hz
(mΩ)
Z
MAX.
20 kHz
(mΩ)
3300
35 x 60
5.5
0.27
71
49
17332E3
57332E3
4700
35 x 60
5.8
0.38
59
44
17472E3
57472E3
6800
35 x 80
7.1
0.55
42
32
17682E3
57682E3
10 000
35 x 105
10.6
0.80
23
16
17103E3
57103E3
15 000
50 x 80
12.5
1.20
17153E3
57153E3
22 000
50 x 105
14.5
1.76
16
12
17223E3
57223E3
33 000
65 x 105
21.0
2.64
11
8
17333E3
57333E3
37333E3
77333E3
47 000
65 x 105
24.5
3.76
8
8
17473E3
57473E3
37473E3
77473E3
68 000
76 x 105
27.0
5.44
8
8
17683E3
57683E3
37683E3
77683E3
100 000
76 x 146
31.5
8.0
8
8
17104E3
57104E3
37104E3
77104E3
150 000
76 x 220
38.0
12.0
8
8
17154E3
57154E3
37154E3
77154E3
150 000
90 x 146
50.0
12.0
8
8
47154E3
87154E3
220 000
90 x 220
50.0
17.6
8
8
47224E3
87224E3
2200
35 x 60
5.4
0.28
68
47
18222E3
58222E3
3300
35 x 60
7.2
0.42
40
27
18332E3
58332E3
4700
35 x 80
8.8
0.60
29
19
18472E3
58472E3
6800
35 x 105
10.6
0.86
22
15
18682E3
58682E3
10 000
50 x 80
14.5
1.26
16
11
18103E3
58103E3
15 000
50 x 105
17.0
1.89
12
9
18153E3
58153E3
22 000
65 x 105
23.5
2.78
9
8
18223E3
58223E3
38223E3
78223E3
33 000
65 x 105
23.5
4.16
8
8
18333E3
58333E3
38333E3
78333E3
47 000
76 x 105
25.0
5.93
8
8
18473E3
58473E3
38473E3
78473E3
68 000
76 x 146
29.5
8.6
8
8
18683E3
58683E3
38683E3
78683E3
100 000
76 x 220
36.5
12.6
8
8
18104E3
58104E3
38104E3
78104E3
150 000
90 x 220
50.0
18.9
8
8
48154E3
88154E3
1000
35 x 60
3.7
0.20
96
48
19102E3
59102E3
1500
35 x 60
4.8
0.30
59
27
19152E3
59152E3
2200
35 x 80
5.9
0.44
42
19222E3
59222E3
3300
35 x 105
7.3
0.66
29
15
19332E3
59332E3
4700
50 x 80
10.1
0.94
22
12
19472E3
59472E3
6800
50 x 105
12.1
1.36
16
9
19682E3
59682E3
10 000
65 x 105
16.7
2.00
11
7
19103E3
59103E3
39103E3
79103E3
15 000
65 x 105
17.6
3.00
10
6
19153E3
59153E3
39153E3
79153E3
22 000
76 x 105
19.5
4.40
9
6
19223E3
59223E3
39223E3
79223E3
33 000
76 x 146
23.0
6.6
8
6
19333E3
59333E3
39333E3
79333E3
47 000
76 x 220
28.6
9.4
5
5
19473E3
59473E3
39473E3
79473E3
68 000
90 x 220
50.0
13.6
5
5
49683E3
89683E3
4
106 PED-ST
www.vishay.com
Vishay BCcomponents
ADDITIONAL ELECTRICAL DATA
PARAMETER
CONDITIONS
VALUE
Voltage
Surge voltage
Us = 1.15 x UR
Urev ≤ 1 V
Reverse voltage
Current
Leakage current
After 1 min at UR
IL1 ≤ 0.006 CR x UR + 4 μF
After 5 min at UR
IL5 ≤ 0.002 CR x UR + 4 μF
Case Ø D = 35 mm
Typ. 13 nH
Case Ø D = 50 mm
Typ. 16 nH
Case Ø D = 65 mm
Typ. 19 nH (1)
Case Ø D = 76 mm
Typ. 20 nH (1)
Case Ø D = 90 mm
Typ. 21 nH (1)
Inductance
Equivalent series inductance (ESL)
Note
(1) Low ESL designs available on request
RIPPLE CURRENT AND USEFUL LIFE
Table 3
ENDURANCE TEST DURATION AND USEFUL LIFE
ENDURANCE
AT 85 °C
(h)
USEFUL LIFE
AT 85 °C
(h)
8000
20 000
Note
• Multiplier of useful life code: CCC205-05
CCC205-05
2.6
IA
IR
2.4
2.2
2.0
1.8
1.6
1.4
Lifetime multiplier
1.2
5
1.
10
30
1.0
40
IA = actual ripple current at 100 Hz
IR = actual ripple current at 100 Hz and 85 °C
With an absolute maximum of 50 A at 85 °C
(1)
Useful life at 85 °C and IR applied: 20 000 h
(1)
0.5
0.0
40
50
60
70
80
90
100
Tamb (°C)
Fig. 3 - Multiplier of useful life as a function of ambient temperature and ripple current load
5
106 PED-ST
www.vishay.com
Vishay BCcomponents
Table 4
MULTIPLIER OF RIPPLE CURRENT (IR) AS A FUNCTION OF FREQUENCY
FREQUENCY (Hz)
50
100
200
400
1000
≥ 2000
1.15
1.19
1.20
IR MULTIPLIER
0.83
1.00
1.10
Table 5
TEST PROCEDURES AND REQUIREMENTS
TEST
NAME OF TEST
Endurance
REFERENCE
IEC 60384-4 /
EN 130300
subclause 4.13
PROCEDURE
(quick reference)
REQUIREMENTS
Tamb = 85 °C; UR applied;
8000 h
ΔC/C: ± 15 %
tan δ ≤ 1.3 x spec. limit
Z ≤ 2 x spec. limit
IL5 ≤ spec. limit
Useful life
CECC 30301
subclause 1.8.1
Tamb = 85 °C; UR and IR applied;
20 000 h
ΔC/C: ± 45 %
tan δ ≤ 3 x spec. limit
Z ≤ 3 x spec. limit
IL5 ≤ spec. limit
no short or open circuit,
no visible damage
total failure percentage ≤ 1 %
Shelf life
(storage at
high temperature)
IEC 60384-4 /
EN 130300
subclause 4.17
Tamb = 85 °C; no voltage applied;
500 h
after test: UR to be applied for 30 min,
24 h to 48 h before measurement
ΔC/C: ± 10 %
tan δ ≤ 1.2 x spec. limit
IL5 ≤ 2 x spec. limit
Statements about product lifetime are based on calculations and internal testing. They should only be interpreted as estimations. Also due to external factors, the
lifetime in the field application may deviate from the calculated lifetime. In general, nothing stated herein shall be construed as a guarantee of durability.
6
Legal Disclaimer Notice
www.vishay.com
Vishay
Disclaimer
ALL PRODUCT, PRODUCT SPECIFICATIONS AND DATA ARE SUBJECT TO CHANGE WITHOUT NOTICE TO IMPROVE
RELIABILITY, FUNCTION OR DESIGN OR OTHERWISE.
Vishay Intertechnology, Inc., its affiliates, agents, and employees, and all persons acting on its or their behalf (collectively,
“Vishay”), disclaim any and all liability for any errors, inaccuracies or incompleteness contained in any datasheet or in any other
disclosure relating to any product.
Vishay makes no warranty, representation or guarantee regarding the suitability of the products for any particular purpose or
the continuing production of any product. To the maximum extent permitted by applicable law, Vishay disclaims (i) any and all
liability arising out of the application or use of any product, (ii) any and all liability, including without limitation special,
consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for particular
purpose, non-infringement and merchantability.
Statements regarding the suitability of products for certain types of applications are based on Vishay's knowledge of typical
requirements that are often placed on Vishay products in generic applications. Such statements are not binding statements
about the suitability of products for a particular application. It is the customer's responsibility to validate that a particular product
with the properties described in the product specification is suitable for use in a particular application. Parameters provided in
datasheets and / or specifications may vary in different applications and performance may vary over time. All operating
parameters, including typical parameters, must be validated for each customer application by the customer's technical experts.
Product specifications do not expand or otherwise modify Vishay's terms and conditions of purchase, including but not limited
to the warranty expressed therein.
Hyperlinks included in this datasheet may direct users to third-party websites. These links are provided as a convenience and
for informational purposes only. Inclusion of these hyperlinks does not constitute an endorsement or an approval by Vishay of
any of the products, services or opinions of the corporation, organization or individual associated with the third-party website.
Vishay disclaims any and all liability and bears no responsibility for the accuracy, legality or content of the third-party website
or for that of subsequent links.
Except as expressly indicated in writing, Vishay products are not designed for use in medical, life-saving, or life-sustaining
applications or for any other application in which the failure of the Vishay product could result in personal injury or death.
Customers using or selling Vishay products not expressly indicated for use in such applications do so at their own risk. Please
contact authorized Vishay personnel to obtain written terms and conditions regarding products designed for such applications.
No license, express or implied, by estoppel or otherwise, to any intellectual property rights is granted by this document or by
any conduct of Vishay. Product names and markings noted herein may be trademarks of their respective owners.
© 2023 VISHAY INTERTECHNOLOGY, INC. ALL RIGHTS RESERVED
Revision: 01-Jan-2023
1
Document Number: 91000
