E92F501VSN221MR50T
E92F501VSN221MR50T
    NCC(贵弥功)
    Radial, Can - Snap-In
    CAP ALUM 220UF 20% 500V SNAP
E92F501VSN221MR50T 数据手册
CATALOG SM813 U91 / U92 Series High Ripple Snap Mount Capacitors Welcome to United Chemi-Con . . . United Chemi-Con is introducing four new snap mount aluminum electrolytic capacitor series specifically designed for higher ripple current capability. These new series include the U91F, U92F, U92L and U92X which also feature very long life, wide temperature range, high voltage ratings and a variety of case sizes and terminal styles. The U91F series is a high temperature series with a lifetime rating of 5,000 hours at 105C. The three U92 series offer a lifetime rating of 5,000 hours for U92F, 10,000 hours for U92L or 15,000 hours for U92X at 85C. The rated lifetime for all these series is measured with the rated ripple current applied. All the U91/U92 series capacitors are RoHS compliant and are manufactured with or without an end disk in either a standard Pb-free PVC sleeve or optional PET sleeve. There are two basic types of PC board terminals, snap-in or straight standoffs. All of the new snap-in series offer 2, 3, 4 or 5 -pin layouts as either standard or optional configurations depending on case size. Straight standoff terminals, 5 -pin configuration, are available as an option for the larger case diameters. Please contact United Chemi-Con with any questions about these new snap mount capacitors. Custom designs are also available upon request. Specifications Guide for U91/U92 High Ripple Snap Mount Capacitors Series Page No. Terminal Type Features RoHS Compliant Temperature Range (C) Voltage Range (V) Capacitance Range (µF ) Endurance (Hrs.R*) at 85C at 105C U91F 4 Snap Mount Specific High Ripple Design, High Temperature, Long Life, Pin Options  25C ~105C 350~500 120~2,700 — 5,000 U92F 11 Snap Mount Specific High Ripple Design, Long Life, Pin Options  25C ~85C 350~500 180~3,300 5,000 — U92L 18 Snap Mount Specific High Ripple Design, Longer Life, Pin Options  25C ~85C 350~500 150~3,300 10,000 — U92X 25 Snap Mount Specific High Ripple Design, Longest Life, Pin Options  25C ~85C 350~500 150~3,300 15,000 — *R = With rated ripple current applied. In the construction of the components described, the full intent of the specification will be met. United Chemi-Con, however, reserves the right to make, from time to time, such departures from the detail specifications as may be required to permit improvements in the design of its products. Components made under military approvals will be in accordance with the approval requirements. The information included herein is believed to be accurate and reliable. However, United Chemi-Con assumes no responsibility for its use, nor for any infringements of patents or other rights of third parties which may result from its use. United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com 3 Table of Contents Table of Contents  Snap Mount  Specific Design SNAP MOUNT 105C U91F U91F Series For Higher Ripple Current  350 to 500VDC Voltage Range  RoHS Compliant  105C Maximum Temperature  5,000 Hours Lifetime at 105C The U91F series is a high temperature snap-in series specifically designed for higher ripple current capability. The U91F capacitors have an endurance rating of 5,000 hours at 105C with the rated ripple current applied. All the U91F series capacitors are RoHS compliant and available in a variety of sizes, with or without an end disk, and encased in a standard Pb-free PVC sleeve or an optional PET sleeve. Snap-in terminals (2, 4 or 5 -pin configurations) are available as standard or optional styles depending on case size. Straight standoff terminals (5 -pin configuration) are an option for the 40, 45 and 50mm can diameters. Summary of Specifications  PC board snap-in or straight standoff terminals available as standard or optional styles depending on pin styles and case size.  Capacitance range: 120 to 2,700µF.  Voltage range: 350 to 500VDC.  Category temperature range: 25C to 105C.  Leakage current: 3 CV (µA) or 3mA, whichever is smaller, after 5 minutes at 20C.  Standard capacitance tolerance: 20%  Nominal case size (DL): 3040mm to 50105mm.  Rated lifetime: 5,000 hours at 105C with the rated ripple current applied. 4 United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com Engineering Bulletin Aug 2013 U91F Series U91F Specifications - Snap Mount Item Characteristics Category Temperature Range 25 to 105C Rated Voltage Range 350 to 500VDC Capacitance Range 120 to 2,700F Capacitance Tolerance 20% ( M ) at 20C, 120Hz Leakage Current I = 3 CV (A ) or 3mA, whichever is smaller, after 5 minutes at 20C. Where I = Max. leakage current (A ), C = Nominal capacitance (F ) and V = Rated voltage ( V ) At 20C, 120Hz Rated Voltage ( V ) 350 - 400 420 -500 0.15 0.20 Tan  ( DF ) Max. At 120Hz, impedance ( Z ) ratio between the 25C value and 20C value shall not exceed the values given below. Rated Voltage ( V ) 350 -500 Z (25C ) / Z (20C ) Rated Ripple Current Multipliers 8 Ambient Temperature (C ) 65C 85C 105C 2.82 1.73 1.00 Frequency (Hz ) Endurance (Load Life) DC Rated Voltage 50Hz 120Hz 300Hz 1kHz 10kHz 100kHz 350 - 450V 0.77 1.00 1.16 1.30 1.41 1.43 500V 0.70 1.00 1.16 1.30 1.41 1.43 The following specifications shall be satisfied when the capacitors are restored to 20C after subjecting them to DC voltage for 5,000 hours at 105C with the rated ripple current applied. The sum of the DC voltage and peak AC voltage must not exceed the full rated voltage of the capacitors. Capacitance change: ≤ 20% of initial measured value Tan  ( DF ) : ≤ 200% of initial specified value Leakage current : ≤ initial specified value Shelf Life The following specifications shall be satisfied when the capacitors are restored to 20C after exposing them for 1,000 hours at 105C without voltage applied. The rated voltage shall be applied to the capacitors for a minimum of 30 minutes, at least 24 hours and not more than 48 hours before the measurements. Capacitance change: ≤ 20% of initial measured value Tan  ( DF ) : ≤ 150% of initial specified value Leakage current : ≤ initial specified value Product specifications are subject to change without notice. Ask for UCC product bulletins and review specifications before purchase and/or use. Please use our products based on parameters specified in our bulletins. United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com 5 U91F Low Temperature Characteristics SNAP MOUNT 105C Dissipation Factor ( Tan ) Engineering Bulletin Aug 2013 U91F Series Diagram of Dimensions - Snap Mount Unit: mm Snap Mount VND Snap-in Ø 35 and Ø 40 standard; Ø 45 optional VSD Snap-in Ø 35 and Ø 40 optional VSN Snap-in Ø 30 and Ø 35 standard VNN Snap-in Ø 30 and Ø 35 optional *** Brown Insulating Sleeve Negative Mark PC Board Pin-out *** Brown Insulating Sleeve Negative Mark PC Board Pin-out A* U91F SNAP MOUNT 105C D 1 ** Vent 10 2-2x See Pin Detail L 2.5 Insulating Disk ** Vent Negative Mark PC Board Pin-out 3.3 0.1 4.75 0.1 10 2-2x See Pin Detail L 2.5 Insulating Disk C* See Pin Detail L 2.5 2-4x VNT Snap-in Ø 45 and Ø 50 standard D 1 ** Vent 22.5 B Insulating Disk VEN Snap-in Ø 30 and Ø 35 optional *** Brown Insulating Sleeve D 1 30° *** Brown Insulating Sleeve Negative Mark A B* C PC Board Pin-out 360° 6 D 1 ** Vent 25 2.5 MIN.-1x Insulating Disk 2-5x D See Pin Detail L 2.5 VS, VE & VN Snap-in Pin Dimensions W2 W1 P Straight Pin Mount Edge of can VQT Straight Standoff Ø 40, Ø 45 and Ø 50 optional W *** Brown Insulating Sleeve Type VSN Ø 30 VSN Ø 35 VNN Ø 30 - Ø 35 VEN Ø 30 - Ø 35 VSD Ø 35 - Ø 40 VND Ø 35 - Ø 45 VNT Ø 45 - Ø 50 P 4.00.5 3.50.5 5.81.0 4.00.5 3.51.0 5.81.0 5.81.0 W W1 Negative Mark W2 PC Board Pin-out 360° 6 B* A* C D 1 1.50.2 0.80.1 0.80.1 ** Vent 25 D* See Pin Detail L 2.5 Insulating Disk 2- 5x VQ Standoff Pin Dimensions W1 W P CAUTION: * Use the blank terminals for mechanical support only. The blank terminals must not be connected to a solder trace on the PC board but be electrically isolated from the negative and positive terminals. ** The vent may be located either on the bottom or side of the can. *** The brown sleeve with gray stripe negative pin indicator is standard. Also note in some cases, the sleeve color may change slightly due to the operating conditions, however, the discoloration will not impair capacitor function. Edge of can P1 Type Standoff Pin (VQ) P 3.751.0 P1 2.0 max. W 1.50.1 W1 0.70.2 Product specifications are subject to change without notice. Ask for UCC product bulletins and review specifications before purchase and/or use. Please use our products based on parameters specified in our bulletins. 6 United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com Engineering Bulletin Aug 2013 U91F Series Part Numbering System for U91F Series When ordering, always specify complete 18-field global part number. 18 Fields 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E 9 1 F 4 0 1 V S N 4 7 1 M A 5 0 T 9 6 5 4 3 2 1 Capacitance. Fields 11, 12 and 13. Expressed in Microfarads. The first two digits are significant figures inserted in fields 11 and 12, and the third digit inserted in field 13 indicates the number of zeros for capacitance of 10F or more. R indicates the decimal point for capacitance less than 10F (e.g. 4R7 = 4.7F; 470 = 47F; 471 = 470F; 472 = 4,700F; 473 = 47,000F ). Dummy Terminals. Field 10. N = No dummy terminals. D = 2 dummy terminals. T = 3 dummy terminals. Terminal Type. Fields 8 and 9. VS = Snap-in pins, 4.0mm in length ( Ø30 VSN); 3.5mm in length ( Ø35 VSN, Ø35 or Ø40 VSD). VN = Snap-in pins, 5.8mm in length. VE = Snap-in pins, polarized, Ø30 or Ø35 option. VQ = Straight standoff pins. DC Rated Voltage. Fields 5, 6 and 7. Expressed in Volts. The first two digits are significant figures inserted in fields 5 and 6, and the third digit inserted in field 7 indicates the number of zeros for rated voltage of 10VDC or more. R indicates the decimal point for rated voltage less than 10VDC (e.g. 4R0 = 4.0VDC; 400 = 40VDC; 401 = 400VDC). Rule Exception: Coding for rated voltage 385VDC = 3J1. Series Name. Fields 2, 3 and 4. Enter the 3-letter/digit series name in fields 2, 3 and 4. If the series name is only 2 letters/digits, place a dash in field 4. For a series name with more than 3 letters/digits, refer to the individual series for the appropriate 3-field series name. Capacitor Type. Field 1. Aluminum Electrolytic Capacitor (Polar). Product specifications are subject to change without notice. Ask for UCC product bulletins and review specifications before purchase and/or use. Please use our products based on parameters specified in our bulletins. United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com 7 U91F 7 SNAP MOUNT 105C 8 Supplement Code. Field 18. All construction options listed have Sn100% terminal plating. T = Pb-free PVC sleeve with end disk. M = Pb-free PVC sleeve without end disk. W = PET sleeve with end disk. S = PET sleeve without end disk. Case Size. Fields 15, 16 and 17. The single letter diameter code is inserted in field 15. R = Ø 30mm A = Ø 35mm B = Ø 40mm U = Ø 45mm C = Ø 50mm The double digit length code is inserted in fields 16 and 17. 40 = 40mm 50 = 50mm 65 = 65mm 80 = 80mm A0 = 100mm A5 = 105mm Capacitance Tolerance. Field 14. M = 20% Engineering Bulletin Aug 2013 U91F Series Standard Voltage Ratings - Snap Mount U91F SNAP MOUNT 105C Rated Voltage (WVDC) 350 Volts 400 Volts Surge 385 Volts 435 Volts Surge 400 Volts 450 Volts Surge Capacitance (µF ) Global Part Number† Nominal Case Size* DL ( mm ) Case Size Code Maximum ESR ( Ω ) at 20C, 120Hz Rated Ripple Current (A rms) at 105C, 120Hz 270 390 560 390 560 820 1,000 1,200 820 1,200 1,500 1,800 820 1,200 1,800 2,200 1,200 1,800 2,200 2,700 E91F351VSN271MR40T E91F351VSN391MR50T E91F351VSN561MR65T E91F351VSN391MA40T E91F351VSN561MA50T E91F351VND821MA65T E91F351VND102MA80T E91F351VND122MAA0T E91F351VND821MB50T E91F351VND122MB65T E91F351VND152MB80T E91F351VND182MBA0T E91F351VNT821MU50T E91F351VNT122MU65T E91F351VNT182MU80T E91F351VNT222MUA5T E91F351VNT122MC50T E91F351VNT182MC65T E91F351VNT222MC80T E91F351VNT272MCA5T 30  40 30  50 30  65 35  40 35  50 35  65 35  80 35  100 40  50 40  65 40  80 40  100 45  50 45  65 45  80 45  105 50  50 50  65 50  80 50  105 R40 R50 R65 A40 A50 A65 A80 AA0 B50 B65 B80 BA0 U50 U65 U80 UA5 C50 C65 C80 CA5 0.324 0.225 0.156 0.235 0.164 0.112 0.092 0.076 0.121 0.083 0.066 0.055 0.131 0.090 0.060 0.049 0.092 0.066 0.054 0.044 1.5 2.0 2.6 2.0 2.7 3.5 4.1 5.0 3.3 4.3 5.1 6.1 3.3 4.4 5.8 7.1 4.1 5.2 6.3 7.9 220 330 470 330 470 680 1,000 1,200 680 1,000 1,200 1,500 820 1,200 1,500 1,800 1,000 1,500 1,800 2,700 E91F3J1VSN221MR40T E91F3J1VSN331MR50T E91F3J1VSN471MR65T E91F3J1VSN331MA40T E91F3J1VSN471MA50T E91F3J1VND681MA65T E91F3J1VND102MA80T E91F3J1VND122MAA0T E91F3J1VND681MB50T E91F3J1VND102MB65T E91F3J1VND122MB80T E91F3J1VND152MBA0T E91F3J1VNT821MU50T E91F3J1VNT122MU65T E91F3J1VNT152MU80T E91F3J1VNT182MUA5T E91F3J1VNT102MC50T E91F3J1VNT152MC65T E91F3J1VNT182MC80T E91F3J1VNT272MCA5T 30  40 30  50 30  65 35  40 35  50 35  65 35  80 35  100 40  50 40  65 40  80 40  100 45  50 45  65 45  80 45  105 50  50 50  65 50  80 50  105 R40 R50 R65 A40 A50 A65 A80 AA0 B50 B65 B80 BA0 U50 U65 U80 UA5 C50 C65 C80 CA5 0.336 0.245 0.174 0.237 0.173 0.123 0.095 0.073 0.135 0.096 0.075 0.058 0.118 0.084 0.065 0.047 0.094 0.073 0.056 0.041 1.5 1.9 2.5 2.0 2.6 3.3 4.0 5.1 3.1 4.0 4.8 6.0 3.5 4.5 5.5 7.2 4.1 5.0 6.2 8.2 220 330 390 330 470 680 820 1,000 560 820 1,200 1,500 680 1,000 E91F401VSN221MR40T E91F401VSN331MR50T E91F401VSN391MR65T E91F401VSN331MA40T E91F401VSN471MA50T E91F401VND681MA65T E91F401VND821MA80T E91F401VND102MAA0T E91F401VND561MB50T E91F401VND821MB65T E91F401VND122MB80T E91F401VND152MBA0T E91F401VNT681MU50T E91F401VNT102MU65T 30  40 30  50 30  65 35  40 35  50 35  65 35  80 35  100 40  50 40  65 40  80 40  100 45  50 45  65 R40 R50 R65 A40 A50 A65 A80 AA0 B50 B65 B80 BA0 U50 U65 0.380 0.253 0.214 0.265 0.186 0.129 0.107 0.088 0.164 0.112 0.076 0.061 0.146 0.100 1.4 1.8 2.2 1.9 2.5 3.2 3.8 4.7 2.8 3.7 4.8 5.8 3.1 4.1 † For construction and terminal options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. Product specifications are subject to change without notice. Ask for UCC product bulletins and review specifications before purchase and/or use. Please use our products based on parameters specified in our bulletins. 8 United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com Engineering Bulletin Aug 2013 U91F Series Standard Voltage Ratings - Snap Mount Rated Voltage (WVDC) 400 Volts 450 Volts Surge 500 Volts 550 Volts Surge Nominal Case Size* DL ( mm ) Case Size Code Maximum ESR ( Ω ) at 20C, 120Hz Rated Ripple Current (A rms) at 105C, 120Hz 1,200 1,800 1,000 1,200 1,800 2,200 E91F401VNT122MU80T E91F401VNT182MUA5T E91F401VNT102MC50T E91F401VNT122MC65T E91F401VNT182MC80T E91F401VNT222MCA5T 45  80 45  105 50  50 50  65 50  80 50  105 U80 UA5 C50 C65 C80 CA5 0.083 0.055 0.101 0.093 0.062 0.051 4.9 6.7 3.9 4.4 5.9 7.4 180 270 390 270 390 560 680 820 560 820 1,000 1,200 680 1,000 1,200 1,700 820 1,200 1,500 2,200 E91F421VSN181MR40T E91F421VSN271MR50T E91F421VSN391MR65T E91F421VSN2711MA40T E91F421VSN391MA50T E91F421VND561MA65T E91F421VND681MA80T E91F421VND821MAA0T E91F421VND561MB50T E91F421VND821MB65T E91F421VND102MB80T E91F421VND122MBA0T E91F421VNT681MU50T E91F421VNT102MU65T E91F421VNT122MU80T E91F421VNT172MUA5T E91F421VNT821MC50T E91F421VNT122MC65T E91F421VNT152MC80T E91F421VNT222MCA5T 30  40 30  50 30  65 35  40 35  50 35  65 35  80 35  100 40  50 40  65 40  80 40  100 45  50 45  65 45  80 45  105 50  50 50  65 50  80 50  105 R40 R50 R65 A40 A50 A65 A80 AA0 B50 B65 B80 BA0 U50 U65 U80 UA5 C50 C65 C80 CA5 0.442 0.295 0.204 0.310 0.214 0.149 0.123 0.102 0.156 0.107 0.088 0.073 0.141 0.096 0.080 0.056 0.126 0.086 0.069 0.047 1.3 1.7 2.3 1.8 2.3 3.0 3.5 4.3 2.9 3.8 4.5 5.3 3.2 4.2 5.0 6.6 3.5 4.6 5.6 7.7 180 220 330 270 390 470 680 820 470 680 820 1,200 680 820 1,000 1,500 820 1,000 1,500 1,800 E91F451VSN181MR40T E91F451VSN221MR50T E91F451VSN331MR65T E91F451VSN271MA40T E91F451VSN391MA50T E91F451VND471MA65T E91F451VND681MA80T E91F451VND821MAA0T E91F451VND471MB50T E91F451VND681MB65T E91F451VND821MB80T E91F451VND122MBA0T E91F451VNT681MU50T E91F451VNT821MU65T E91F451VNT102MU80T E91F451VNT152MUA5T E91F451VNT821MC50T E91F451VNT102MC65T E91F451VNT152MC80T E91F451VNT182MCA5T 30  40 30  50 30  65 35  40 35  50 35  65 35  80 35  100 40  50 40  65 40  80 40  100 45  50 45  65 45  80 45  105 50  50 50  65 50  80 50  105 R40 R50 R65 A40 A50 A65 A80 AA0 B50 B65 B80 BA0 U50 U65 U80 UA5 C50 C65 C80 CA5 0.442 0.362 0.241 0.310 0.214 0.178 0.123 0.102 0.178 0.123 0.102 0.070 0.135 0.112 0.092 0.061 0.121 0.100 0.066 0.055 1.3 1.5 2.1 1.8 2.3 2.8 3.5 4.3 2.7 3.5 4.1 5.5 3.3 3.9 4.7 6.4 3.6 4.3 5.7 7.1 120 180 270 180 270 390 E91F501VSN121MR40T E91F501VSN181MR50T E91F501VSN271MR65T E91F501VSN181MA40T E91F501VSN271MA50T E91F501VND391MA65T 30  40 30  50 30  65 35  40 35  50 35  65 R40 R50 R65 A40 A50 A65 0.663 0.442 0.295 0.442 0.295 0.204 1.0 1.4 1.9 1.5 2.0 2.6 † For construction and terminal options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. Product specifications are subject to change without notice. Ask for UCC product bulletins and review specifications before purchase and/or use. Please use our products based on parameters specified in our bulletins. United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com 9 U91F 450 Volts 500 Volts Surge Global Part Number† SNAP MOUNT 105C 420 Volts 470 Volts Surge Capacitance (µF ) Engineering Bulletin Aug 2013 U91F Series Standard Voltage Ratings - Snap Mount U91F SNAP MOUNT 105C Rated Voltage (WVDC) 500 Volts 550 Volts Surge Capacitance (µF ) Global Part Number† Nominal Case Size* DL ( mm ) Case Size Code Maximum ESR ( Ω ) at 20C, 120Hz Rated Ripple Current (A rms) at 105C, 120Hz 470 560 330 470 680 820 390 560 820 1,000 560 820 1,000 1,200 E91F501VND471MA80T E91F501VND561MAA0T E91F501VND331MB50T E91F501VND471MB65T E91F501VND681MB80T E91F501VND821MBA0T E91F501VNT391MU50T E91F501VNT561MU65T E91F501VNT821MU80T E91F501VNT102MUA5T E91F501VNT561MC50T E91F501VNT821MC65T E91F501VNT102MC80T E91F501VNT122MCA5T 35  80 35  100 40  50 40  65 40  80 40  100 45  50 45  65 45  80 45  105 50  50 50  65 50  80 50  105 A80 AA0 B50 B65 B80 BA0 U50 U65 U80 UA5 C50 C65 C80 CA5 0.169 0.142 0.253 0.178 0.123 0.102 0.225 0.156 0.107 0.088 0.164 0.112 0.092 0.076 3.0 3.7 2.3 2.9 3.8 4.5 2.5 3.3 4.3 5.3 3.1 4.0 4.9 6.0 † For construction and terminal options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. Product specifications are subject to change without notice. Ask for UCC product bulletins and review specifications before purchase and/or use. Please use our products based on parameters specified in our bulletins. 10 United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com U92F Series  Snap Mount  Specific Design The U92F series is a specifically designed series for higher ripple current capability. The U92F capacitors have an endurance rating of 5,000 hours at 85C with the rated ripple current applied. All U92F series capacitors are RoHS compliant and available in a variety of sizes, with or without an end disk, and encased in a PET sleeve or standard Pb-free PVC sleeve. Snap-in terminals (2, 4 or 5 -pin configurations) are available as standard or optional styles depending on case size. Straight standoff terminals (5 -pin configuration) are an option for 40, 45 and 50mm can diameters. Summary of Specifications  PC board snap-in or straight standoff terminals available as standard or optional styles depending on pin styles and case size.  Capacitance range: 180 to 3,300µF.  Voltage range: 350 to 500VDC.  Category temperature range: 25C to 85C.  Leakage current: 3 CV (µA) or 3mA, whichever is smaller, after 5 minutes at 20C.  Standard capacitance tolerance: 20%  Nominal case size (DL): 3040mm to 50105mm.  Rated lifetime: 5,000 hours at 85C with the rated ripple current applied. United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com 11 U92F SNAP MOUNT 85C For Higher Ripple Current  350 to 500VDC Voltage Range  RoHS Compliant  85C Maximum Temperature  5,000 Hours Lifetime at 85C Engineering Bulletin Aug 2013 U92F Series U92F Specifications - Snap Mount Item Characteristics Category Temperature Range 25 to 85C Rated Voltage Range 350 to 500VDC Capacitance Range 180 to 3,300F Capacitance Tolerance 20% ( M ) at 20C, 120Hz Leakage Current I = 3 CV (A ) or 3mA, whichever is smaller, after 5 minutes at 20C. Where I = Max. leakage current (A ), C = Nominal capacitance (F ) and V = Rated voltage ( V ) Dissipation Factor ( Tan ) At 20C, 120Hz Rated Voltage ( V ) 350 - 400 420 -500 0.15 0.20 Tan  ( DF ) Max. Low Temperature Characteristics At 120Hz, impedance ( Z ) ratio between the 25C value and 20C value shall not exceed the values given below. Rated Voltage ( V ) 350 -500 Z (25C ) / Z (20C ) Rated Ripple Current Multipliers 8 Ambient Temperature (C ) 45C 65C 85C 2.82 1.73 1.00 U92F SNAP MOUNT 85C Frequency (Hz ) Endurance (Load Life) DC Rated Voltage 50Hz 120Hz 300Hz 1kHz 10kHz 100kHz 350 - 450V 0.77 1.00 1.16 1.30 1.41 1.43 500V 0.70 1.00 1.16 1.30 1.41 1.43 The following specifications shall be satisfied when the capacitors are restored to 20C after subjecting them to DC voltage for 5,000 hours at 85C with the rated ripple current applied. The sum of the DC voltage and peak AC voltage must not exceed the full rated voltage of the capacitors. Capacitance change: ≤ 20% of initial measured value Tan  ( DF ) : ≤ 200% of initial specified value Leakage current : ≤ initial specified value Shelf Life The following specifications shall be satisfied when the capacitors are restored to 20C after exposing them for 1,000 hours at 85C without voltage applied. The rated voltage shall be applied to the capacitors for a minimum of 30 minutes, at least 24 hours and not more than 48 hours before the measurements. Capacitance change: ≤ 20% of initial measured value Tan  ( DF ) : ≤ 150% of initial specified value Leakage current : ≤ initial specified value Product specifications are subject to change without notice. Ask for UCC product bulletins and review specifications before purchase and/or use. Please use our products based on parameters specified in our bulletins. 12 United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com Engineering Bulletin Aug 2013 U92F Series Diagram of Dimensions - Snap Mount Unit: mm Snap Mount VND Snap-in Ø 35 and Ø 40 standard; Ø 45 optional VSD Snap-in Ø 35 and Ø 40 optional VSN Snap-in Ø 30 and Ø 35 standard VNN Snap-in Ø 30 and Ø 35 optional *** Black Insulating Sleeve Negative Mark PC Board Pin-out *** Black Insulating Sleeve Negative Mark PC Board Pin-out A* D 1 ** Vent 10 2-2x See Pin Detail L 2.5 Insulating Disk ** Vent Negative Mark PC Board Pin-out 3.3 0.1 4.75 0.1 10 2-2x See Pin Detail L 2.5 Insulating Disk C* See Pin Detail L 2.5 2-4x VNT Snap-in Ø 45 and Ø 50 standard D 1 ** Vent 22.5 B Insulating Disk VEN Snap-in Ø 30 and Ø 35 optional *** Black Insulating Sleeve D 1 30° 2.5 MIN.-1x *** Black Insulating Sleeve Negative Mark A B* C PC Board Pin-out 360° 6 D 1 ** Vent 25 Insulating Disk 2-5x D See Pin Detail L 2.5 W2 W1 P Straight Pin Mount Edge of can VQT Straight Standoff Ø 40, Ø 45 and Ø 50 optional W *** Black Insulating Sleeve Type VSN Ø 30 VSN Ø 35 VNN Ø 30 - Ø 35 VEN Ø 30 - Ø 35 VSD Ø 35 - Ø 40 VND Ø 35 - Ø 45 VNT Ø 45 - Ø 50 P 4.00.5 3.50.5 5.81.0 4.00.5 3.51.0 5.81.0 5.81.0 W W1 Negative Mark W2 PC Board Pin-out 360° 6 B* A* C D 1 1.50.2 0.80.1 0.80.1 ** Vent 25 D* See Pin Detail L 2.5 Insulating Disk 2- 5x VQ Standoff Pin Dimensions W1 W P CAUTION: * Use the blank terminals for mechanical support only. The blank terminals must not be connected to a solder trace on the PC board but be electrically isolated from the negative and positive terminals. ** The vent may be located either on the bottom or side of the can. *** The black sleeve with gray stripe negative pin indicator is standard. Also note in some cases, the sleeve color may change slightly due to the operating conditions, however, the discoloration will not impair capacitor function. Edge of can P1 Type Standoff Pin (VQ) P 3.751.0 P1 2.0 max. W 1.50.1 W1 0.70.2 Product specifications are subject to change without notice. Ask for UCC product bulletins and review specifications before purchase and/or use. Please use our products based on parameters specified in our bulletins. United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com 13 U92F SNAP MOUNT 85C VS, VE & VN Snap-in Pin Dimensions Engineering Bulletin Aug 2013 U92F Series Part Numbering System for U92F Series When ordering, always specify complete 18-field global part number. 18 Fields 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E 9 2 F 4 0 1 V S N 5 6 1 MR 6 5 T 9 8 7 U92F SNAP MOUNT 85C 6 5 4 3 2 1 Supplement Code. Field 18. All construction options listed have Sn100% terminal plating. T = Pb-free PVC sleeve with end disk. M = Pb-free PVC sleeve without end disk. W = PET sleeve with end disk. S = PET sleeve without end disk. Case Size. Fields 15, 16 and 17. The single letter diameter code is inserted in field 15. R = Ø 30mm A = Ø 35mm B = Ø 40mm U = Ø 45mm C = Ø 50mm The double digit length code is inserted in fields 16 and 17. 40 = 40mm 50 = 50mm 65 = 65mm 80 = 80mm A0 = 100mm A5 = 105mm Capacitance Tolerance. Field 14. M = 20% Capacitance. Fields 11, 12 and 13. Expressed in Microfarads. The first two digits are significant figures inserted in fields 11 and 12, and the third digit inserted in field 13 indicates the number of zeros for capacitance of 10F or more. R indicates the decimal point for capacitance less than 10F (e.g. 5R6 = 5.6F; 560 = 56F; 561 = 560F; 562 = 5,600F; 563 = 56,000F ). Dummy Terminals. Field 10. N = No dummy terminals. D = 2 dummy terminals. T = 3 dummy terminals. Terminal Type. Fields 8 and 9. VS = Snap-in pins, 4.0mm in length ( Ø30 VSN); 3.5mm in length ( Ø35 VSN, Ø35 or Ø40 VSD). VN = Snap-in pins, 5.8mm in length. VE = Snap-in pins, polarized, Ø30 or Ø35 option. VQ = Straight standoff pins. DC Rated Voltage. Fields 5, 6 and 7. Expressed in Volts. The first two digits are significant figures inserted in fields 5 and 6, and the third digit inserted in field 7 indicates the number of zeros for rated voltage of 10VDC or more. R indicates the decimal point for rated voltage less than 10VDC (e.g. 4R0 = 4.0VDC; 400 = 40VDC; 401 = 400VDC). Rule Exception: Coding for rated voltage 385VDC = 3J1. Series Name. Fields 2, 3 and 4. Enter the 3-letter/digit series name in fields 2, 3 and 4. If the series name is only 2 letters/digits, place a dash in field 4. For a series name with more than 3 letters/digits, refer to the individual series for the appropriate 3-field series name. Capacitor Type. Field 1. Aluminum Electrolytic Capacitor (Polar). Product specifications are subject to change without notice. Ask for UCC product bulletins and review specifications before purchase and/or use. Please use our products based on parameters specified in our bulletins. 14 United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com Engineering Bulletin Aug 2013 U92F Series Standard Voltage Ratings - Snap Mount Rated Voltage (WVDC) 350 Volts 400 Volts Surge Nominal Case Size* DL ( mm ) Case Size Code Maximum ESR ( Ω ) at 20C, 120Hz 330 470 680 560 680 1,000 1,200 1,800 820 1,200 1,500 2,200 1,200 1,500 2,200 2,700 1,500 2,200 2,700 3,300 E92F351VSN331MR40T E92F351VSN471MR50T E92F351VSN681MR65T E92F351VSN561MA40T E92F351VSN681MA50T E92F351VND102MA65T E92F351VND122MA80T E92F351VND182MAA0T E92F351VND821MB50T E92F351VND122MB65T E92F351VND152MB80T E92F351VND222MBA0T E92F351VNT122MU50T E92F351VNT152MU65T E92F351VNT222MU80T E92F351VNT272MUA5T E92F351VNT152MC50T E92F351VNT222MC65T E92F351VNT272MC80T E92F351VNT332MCA5T 30  40 30  50 30  65 35  40 35  50 35  65 35  80 35  100 40  50 40  65 40  80 40  100 45  50 45  65 45  80 45  105 50  50 50  65 50  80 50  105 R40 R50 R65 A40 A50 A65 A80 AA0 B50 B65 B80 BA0 U50 U65 U80 UA5 C50 C65 C80 CA5 0.338 0.237 0.164 0.192 0.158 0.107 0.090 0.060 0.126 0.086 0.069 0.047 0.093 0.074 0.051 0.041 0.082 0.056 0.046 0.037 2.0 2.6 3.5 3.2 3.8 5.0 5.9 8.0 4.5 5.9 7.1 9.4 5.6 6.8 8.9 10.9 6.2 8.1 9.8 12.2 330 390 560 470 560 820 1,200 1,500 820 1,200 1,500 1,800 1,000 1,500 1,800 2,200 1,200 1,800 2,200 3,300 E92F3J1VSN331MR40T E92F3J1VSN391MR50T E92F3J1VSN561MR65T E92F3J1VSN471MA40T E92F3J1VSN561MA50T E92F3J1VND821MA65T E92F3J1VND122MA80T E92F3J1VND152MAA0T E92F3J1VND821MB50T E92F3J1VND122MB65T E92F3J1VND152MB80T E92F3J1VND182MBA0T E92F3J1VNT102MU50T E92F3J1VNT152MU65T E92F3J1VNT182MU80T E92F3J1VNT222MUA5T E92F3J1VNT122MC50T E92F3J1VNT182MC65T E92F3J1VNT222MC80T E92F3J1VNT332MCA5T 30  40 30  50 30  65 35  40 35  50 35  65 35  80 35  100 40  50 40  65 40  80 40  100 45  50 45  65 45  80 45  105 50  50 50  65 50  80 50  105 R40 R50 R65 A40 A50 A65 A80 AA0 B50 B65 B80 BA0 U50 U65 U80 UA5 C50 C65 C80 CA5 0.302 0.255 0.178 0.195 0.164 0.112 0.076 0.061 0.121 0.083 0.066 0.055 0.111 0.074 0.062 0.051 0.103 0.069 0.056 0.037 2.1 2.5 3.4 3.1 3.8 4.9 6.4 7.9 4.6 6.0 7.3 8.7 5.1 6.8 8.0 9.9 5.5 7.3 8.8 12.2 270 390 560 390 560 820 1,000 1,200 680 1,000 1,200 1,800 1,000 1,200 E92F401VSN271MR40T E92F401VSN391MR50T E92F401VSN561MR65T E92F401VSN391MA40T E92F401VSN561MA50T E92F401VND821MA65T E92F401VND102MA80T E92F401VND122MAA0T E92F401VND681MB50T E92F401VND102MB65T E92F401VND122MB80T E92F401VND182MBA0T E92F401VNT102MU50T E92F401VNT122MU65T 30  40 30  50 30  65 35  40 35  50 35  65 35  80 35  100 40  50 40  65 40  80 40  100 45  50 45  65 R40 R50 R65 A40 A50 A65 A80 AA0 B50 B65 B80 BA0 U50 U65 0.339 0.235 0.164 0.225 0.156 0.107 0.088 0.073 0.141 0.096 0.080 0.053 0.100 0.083 2.0 2.6 3.5 2.9 3.9 5.0 5.9 7.2 4.3 5.6 6.6 8.8 5.4 6.4 † For construction and terminal options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. Product specifications are subject to change without notice. Ask for UCC product bulletins and review specifications before purchase and/or use. Please use our products based on parameters specified in our bulletins. United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com 15 U92F 400 Volts 450 Volts Surge Global Part Number† SNAP MOUNT 85C 385 Volts 435 Volts Surge Rated Ripple Current (A rms) at 85C, 120Hz Capacitance (µF ) Engineering Bulletin Aug 2013 U92F Series Standard Voltage Ratings - Snap Mount Rated Voltage (WVDC) 400 Volts 450 Volts Surge 420 Volts U92F SNAP MOUNT 85C 470 Volts Surge 450 Volts 500 Volts Surge 500 Volts 550 Volts Surge Rated Ripple Current (A rms) at 85C, 120Hz Capacitance (µF ) Global Part Number† Nominal Case Size* DL ( mm ) Case Size Code Maximum ESR ( Ω ) at 20C, 120Hz 1,800 2,200 1,200 1,800 2,200 2,700 E92F401VNT182MU80T E92F401VNT222MUA5T E92F401VNT122MC50T E92F401VNT182MC65T E92F401VNT222MC80T E92F401VNT272MCA5T 45  80 45  105 50  50 50  65 50  80 50  105 U80 UA5 C50 C65 C80 CA5 0.055 0.045 0.093 0.062 0.051 0.041 8.5 10.4 5.6 7.7 9.3 11.6 220 330 470 390 560 680 1,000 1,200 560 820 1,200 1,500 820 1,200 1,500 1,800 1,000 1,500 1,800 2,700 E92F421VSN221MR40T E92F421VSN331MR50T E92F421VSN471MR65T E92F421VSN391MA40T E92F421VSN561MA50T E92F421VND681MA65T E92F421VND102MA80T E92F421VND122MAA0T E92F421VND561MB50T E92F421VND821MB65T E92F421VND122MB80T E92F421VND152MBA0T E92F421VNT821MU50T E92F421VNT122MU65T E92F421VNT152MU80T E92F421VNT182MUA5T E92F421VNT102MC50T E92F421VNT152MC65T E92F421VNT182MC80T E92F421VNT272MCA5T 30  40 30  50 30  65 35  40 35  50 35  65 35  80 35  100 40  50 40  65 40  80 40  100 45  50 45  65 45  80 45  105 50  50 50  65 50  80 50  105 R40 R50 R65 A40 A50 A65 A80 AA0 B50 B65 B80 BA0 U50 U65 U80 UA5 C50 C65 C80 CA5 0.331 0.241 0.172 0.213 0.155 0.110 0.086 0.066 0.131 0.094 0.073 0.057 0.110 0.079 0.062 0.045 0.093 0.067 0.052 0.038 2.0 2.6 3.5 3.0 3.9 5.0 6.0 7.6 4.4 5.7 6.9 8.6 5.1 6.6 8.0 10.5 5.6 7.4 9.1 12.1 220 330 390 390 470 680 820 1,000 560 820 1,000 1,200 680 1,000 1,200 1,800 820 1,200 1,500 2,200 E92F451VSN221MR40T E92F451VSN331MR50T E92F451VSN391MR65T E92F451VSN391MA40T E92F451VSN471MA50T E92F451VND681MA65T E92F451VND821MA80T E92F451VND102MAA0T E92F451VND561MB50T E92F451VND821MB65T E92F451VND102MB80T E92F451VND122MBA0T E92F451VNT681MU50T E92F451VNT102MU65T E92F451VNT122MU80T E92F451VNT182MUA5T E92F451VNT821MC50T E92F451VNT122MC65T E92F451VNT152MC80T E92F451VNT222MCA5T 30  40 30  50 30  65 35  40 35  50 35  65 35  80 35  100 40  50 40  65 40  80 40  100 45  50 45  65 45  80 45  105 50  50 50  65 50  80 50  105 R40 R50 R65 A40 A50 A65 A80 AA0 B50 B65 B80 BA0 U50 U65 U80 UA5 C50 C65 C80 CA5 0.340 0.248 0.177 0.249 0.159 0.113 0.088 0.068 0.135 0.097 0.075 0.058 0.114 0.081 0.063 0.046 0.093 0.066 0.052 0.038 2.0 2.6 3.4 2.8 3.8 4.9 5.9 7.5 4.4 5.6 6.8 8.4 5.0 6.5 7.9 10.3 5.6 7.4 9.2 12.1 180 220 330 270 330 470 E92F501VSN181MR40T E92F501VSN221MR50T E92F501VSN331MR65T E92F501VSN271MA40T E92F501VSN331MA50T E92F501VND471MA65T 30  40 30  50 30  65 35  40 35  50 35  65 R40 R50 R65 A40 A50 A65 0.464 0.380 0.253 0.295 0.241 0.169 1.7 2.1 2.8 2.6 3.1 4.0 † For construction and terminal options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. Product specifications are subject to change without notice. Ask for UCC product bulletins and review specifications before purchase and/or use. Please use our products based on parameters specified in our bulletins. 16 United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com Engineering Bulletin Aug 2013 U92F Series Standard Voltage Ratings - Snap Mount Rated Voltage (WVDC) 500 Volts 550 Volts Surge Capacitance (µF ) Global Part Number† Nominal Case Size* DL ( mm ) Case Size Code Maximum ESR ( Ω ) at 20C, 120Hz 560 820 470 680 820 1,200 560 820 1,200 1,500 820 1,200 1,500 1,800 E92F501VND561MA80T E92F501VND821MAA0T E92F501VND471MB50T E92F501VND681MB65T E92F501VND821MB80T E92F501VND122MBA0T E92F501VNT561MU50T E92F501VNT821MU65T E92F501VNT122MU80T E92F501VNT152MUA5T E92F501VNT821MC50T E92F501VNT122MC65T E92F501VNT152MC80T E92F501VNT182MCA5T 35  80 35  100 40  50 40  65 40  80 40  100 45  50 45  65 45  80 45  105 50  50 50  65 50  80 50  105 A80 AA0 B50 B65 B80 BA0 U50 U65 U80 UA5 C50 C65 C80 CA5 0.142 0.097 0.178 0.123 0.102 0.070 0.164 0.112 0.076 0.061 0.121 0.083 0.066 0.055 Rated Ripple Current (A rms) at 85C, 120Hz 4.7 6.2 3.8 5.0 5.8 7.7 4.2 5.5 7.2 9.0 4.9 6.6 8.1 10.0 † For construction and terminal options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com 17 U92F SNAP MOUNT 85C Product specifications are subject to change without notice. Ask for UCC product bulletins and review specifications before purchase and/or use. Please use our products based on parameters specified in our bulletins. U92L Series  Snap Mount  Specific Design For Higher Ripple Current  350 to 500VDC Voltage Range  RoHS Compliant  85C Maximum Temperature  10,000 Hours Lifetime at 85C U92L SNAP MOUNT 85C The U92L series is a longer life series specifically designed for higher ripple current capability. The U92L capacitors have an endurance rating of 10,000 hours at 85C with the rated ripple current applied. All U92L series capacitors are RoHS compliant and available in a variety of sizes, with or without an end disk, and encased in a PET sleeve or standard Pb-free PVC sleeve. Snap-in terminals (2, 4 or 5 -pin configurations) are available as standard or optional styles depending on case size. Straight standoff terminals (5 -pin configuration) are an option for 40, 45 and 50mm can diameters. Summary of Specifications  PC board snap-in or straight standoff terminals available as standard or optional styles depending on pin styles and case size.  Capacitance range: 150 to 3,300µF.  Voltage range: 350 to 500VDC.  Category temperature range: 25C to 85C.  Leakage current: 3 CV (µA) or 3mA, whichever is smaller, after 5 minutes at 20C.  Standard capacitance tolerance: 20%  Nominal case size (DL): 3040mm to 50105mm.  Rated lifetime: 10,000 hours at 85C with the rated ripple current applied. 18 United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com Engineering Bulletin Aug 2013 U92L Series U92L Specifications - Snap Mount Item Characteristics Category Temperature Range 25 to 85C Rated Voltage Range 350 to 500VDC Capacitance Range 150 to 3,300F Capacitance Tolerance 20% ( M ) at 20C, 120Hz Leakage Current I = 3 CV (A ) or 3mA, whichever is smaller, after 5 minutes at 20C. Where I = Max. leakage current (A ), C = Nominal capacitance (F ) and V = Rated voltage ( V ) Dissipation Factor ( Tan ) At 20C, 120Hz Rated Voltage ( V ) 350 - 400 420 -500 0.15 0.20 Tan  ( DF ) Max. Low Temperature Characteristics At 120Hz, impedance ( Z ) ratio between the 25C value and 20C value shall not exceed the values given below. Rated Voltage ( V ) 350 -500 Z (25C ) / Z (20C ) Rated Ripple Current Multipliers 8 Ambient Temperature (C ) 45C 65C 85C 2.82 1.73 1.00 Frequency (Hz ) Endurance (Load Life) DC Rated Voltage 50Hz 120Hz 300Hz 1kHz 10kHz 100kHz 350 - 450V 0.77 1.00 1.16 1.30 1.41 1.43 500V 0.70 1.00 1.16 1.30 1.41 1.43 The following specifications shall be satisfied when the capacitors are restored to 20C after subjecting them to DC voltage for 10,000 hours at 85C with the rated ripple current applied. The sum of the DC voltage and peak AC voltage must not exceed the full rated voltage of the capacitors. Capacitance change: ≤ 20% of initial measured value Tan  ( DF ) : ≤ 200% of initial specified value Leakage current : ≤ initial specified value Shelf Life The following specifications shall be satisfied when the capacitors are restored to 20C after exposing them for 1,000 hours at 85C without voltage applied. The rated voltage shall be applied to the capacitors for a minimum of 30 minutes, at least 24 hours and not more than 48 hours before the measurements. Product specifications are subject to change without notice. Ask for UCC product bulletins and review specifications before purchase and/or use. Please use our products based on parameters specified in our bulletins. United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com 19 U92L SNAP MOUNT 85C Capacitance change: ≤ 20% of initial measured value Tan  ( DF ) : ≤ 150% of initial specified value Leakage current : ≤ initial specified value Engineering Bulletin Aug 2013 U92L Series Diagram of Dimensions - Snap Mount Unit: mm Snap Mount VND Snap-in Ø 35 and Ø 40 standard; Ø 45 optional VSD Snap-in Ø 35 and Ø 40 optional VSN Snap-in Ø 30 and Ø 35 standard VNN Snap-in Ø 30 and Ø 35 optional *** Black Insulating Sleeve Negative Mark PC Board Pin-out *** Black Insulating Sleeve Negative Mark PC Board Pin-out A* D 1 ** Vent 10 2-2x See Pin Detail L 2.5 Insulating Disk ** Vent Negative Mark PC Board Pin-out 3.3 0.1 4.75 0.1 10 2-2x See Pin Detail L 2.5 Insulating Disk C* See Pin Detail L 2.5 2-4x VNT Snap-in Ø 45 and Ø 50 standard D 1 ** Vent 22.5 B Insulating Disk VEN Snap-in Ø 30 and Ø 35 optional *** Black Insulating Sleeve D 1 30° 2.5 MIN.-1x *** Black Insulating Sleeve Negative Mark A B* C PC Board Pin-out 360° 6 D 1 ** Vent 25 Insulating Disk 2-5x D See Pin Detail L 2.5 VS, VE & VN Snap-in Pin Dimensions W2 W1 P Straight Pin Mount Edge of can VQT Straight Standoff Ø 40, Ø 45 and Ø 50 optional W *** Black Insulating Sleeve U92L SNAP MOUNT 85C Type VSN Ø 30 VSN Ø 35 VNN Ø 30 - Ø 35 VEN Ø 30 - Ø 35 VSD Ø 35 - Ø 40 VND Ø 35 - Ø 45 VNT Ø 45 - Ø 50 P 4.00.5 3.50.5 5.81.0 4.00.5 3.51.0 5.81.0 5.81.0 W W1 Negative Mark W2 PC Board Pin-out 360° 6 B* A* C D 1 1.50.2 0.80.1 0.80.1 ** Vent 25 D* See Pin Detail L 2.5 Insulating Disk 2-5x VQ Standoff Pin Dimensions W1 W P CAUTION: * Use the blank terminals for mechanical support only. The blank terminals must not be connected to a solder trace on the PC board but be electrically isolated from the negative and positive terminals. ** The vent may be located either on the bottom or side of the can. *** The black sleeve with gray stripe negative pin indicator is standard. Also note in some cases, the sleeve color may change slightly due to the operating conditions, however, the discoloration will not impair capacitor function. Edge of can P1 Type Standoff Pin (VQ) P 3.751.0 P1 2.0 max. W 1.50.1 W1 0.70.2 Product specifications are subject to change without notice. Ask for UCC product bulletins and review specifications before purchase and/or use. Please use our products based on parameters specified in our bulletins. 20 United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com Engineering Bulletin Aug 2013 U92L Series Part Numbering System for U92L Series When ordering, always specify complete 18-field global part number. 18 Fields 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E 9 2 L 4 5 1 V S N 4 7 1 M A 5 0 T 9 8 7 6 5 4 1 Product specifications are subject to change without notice. Ask for UCC product bulletins and review specifications before purchase and/or use. Please use our products based on parameters specified in our bulletins. United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com 21 U92L 2 Capacitance. Fields 11, 12 and 13. Expressed in Microfarads. The first two digits are significant figures inserted in fields 11 and 12, and the third digit inserted in field 13 indicates the number of zeros for capacitance of 10F or more. R indicates the decimal point for capacitance less than 10F (e.g. 4R7 = 4.7F; 470 = 47F; 471 = 470F; 472 = 4,700F; 473 = 47,000F ). Dummy Terminals. Field 10. N = No dummy terminals. D = 2 dummy terminals. T = 3 dummy terminals. Terminal Type. Fields 8 and 9. VS = Snap-in pins, 4.0mm in length ( Ø30 VSN); 3.5mm in length ( Ø35 VSN, Ø35 or Ø40 VSD). VN = Snap-in pins, 5.8mm in length. VE = Snap-in pins, polarized, Ø30 or Ø35 option. VQ = Straight standoff pins. DC Rated Voltage. Fields 5, 6 and 7. Expressed in Volts. The first two digits are significant figures inserted in fields 5 and 6, and the third digit inserted in field 7 indicates the number of zeros for rated voltage of 10VDC or more. R indicates the decimal point for rated voltage less than 10VDC (e.g. 4R5 = 4.5VDC; 450 = 45VDC; 451 = 450VDC). Rule Exception: Coding for rated voltage 385VDC = 3J1. Series Name. Fields 2, 3 and 4. Enter the 3-letter/digit series name in fields 2, 3 and 4. If the series name is only 2 letters/digits, place a dash in field 4. For a series name with more than 3 letters/digits, refer to the individual series for the appropriate 3-field series name. Capacitor Type. Field 1. Aluminum Electrolytic Capacitor (Polar). SNAP MOUNT 85C 3 Supplement Code. Field 18. All construction options listed have Sn100% terminal plating. T = Pb-free PVC sleeve with end disk. M = Pb-free PVC sleeve without end disk. W = PET sleeve with end disk. S = PET sleeve without end disk. Case Size. Fields 15, 16 and 17. The single letter diameter code is inserted in field 15. R = Ø 30mm A = Ø 35mm B = Ø 40mm U = Ø 45mm C = Ø 50mm The double digit length code is inserted in fields 16 and 17. 40 = 40mm 50 = 50mm 65 = 65mm 80 = 80mm A0 = 100mm A5 = 105mm Capacitance Tolerance. Field 14. M = 20% Engineering Bulletin Aug 2013 U92L Series Standard Voltage Ratings - Snap Mount Rated Voltage (WVDC) 350 Volts 400 Volts Surge 385 Volts U92L SNAP MOUNT 85C 435 Volts Surge 400 Volts 450 Volts Surge Rated Ripple Current (A rms) at 85C, 120Hz Capacitance (µF ) Global Part Number† Nominal Case Size* DL ( mm ) Case Size Code Maximum ESR ( Ω ) at 20C, 120Hz 330 470 680 470 680 1,000 1,200 1,500 820 1,200 1,500 2,200 1,200 1,500 2,200 2,700 1,500 2,200 2,700 3,300 E92L351VSN331MR40T E92L351VSN471MR50T E92L351VSN681MR65T E92L351VSN471MA40T E92L351VSN681MA50T E92L351VND102MA65T E92L351VND122MA80T E92L351VND152MAA0T E92L351VND821MB50T E92L351VND122MB65T E92L351VND152MB80T E92L351VND222MBA0T E92L351VNT122MU50T E92L351VNT152MU65T E92L351VNT222MU80T E92L351VNT272MUA5T E92L351VNT152MC50T E92L351VNT222MC65T E92L351VNT272MC80T E92L351VNT332MCA5T 30  40 30  50 30  65 35  40 35  50 35  65 35  80 35  100 40  50 40  65 40  80 40  100 45  50 45  65 45  80 45  105 50  50 50  65 50  80 50  105 R40 R50 R65 A40 A50 A65 A80 AA0 B50 B65 B80 BA0 U50 U65 U80 UA5 C50 C65 C80 CA5 0.314 0.220 0.152 0.212 0.146 0.100 0.083 0.066 0.126 0.086 0.069 0.047 0.096 0.077 0.052 0.043 0.088 0.060 0.049 0.040 2.1 2.7 3.7 3.0 4.0 5.2 6.1 7.6 4.5 5.9 7.1 9.4 5.5 6.7 8.7 10.7 5.8 7.8 9.5 11.8 270 390 560 470 560 820 1,200 1,500 820 1,200 1,500 1,800 1,000 1,200 1,800 2,200 1,200 1,800 2,200 2,700 E92L3J1VSN271MR40T E92L3J1VSN391MR50T E92L3J1VSN561MR65T E92L3J1VSN471MA40T E92L3J1VSN561MA50T E92L3J1VND821MA65T E92L3J1VND122MA80T E92L3J1VND152MAA0T E92L3J1VND821MB50T E92L3J1VND122MB65T E92L3J1VND152MB80T E92L3J1VND182MBA0T E92L3J1VNT102MU50T E92L3J1VNT122MU65T E92L3J1VNT182MU80T E92L3J1VNT222MUA5T E92L3J1VNT122MC50T E92L3J1VNT182MC65T E92L3J1VNT222MC80T E92L3J1VNT272MCA5T 30  40 30  50 30  65 35  40 35  50 35  65 35  80 35  100 40  50 40  65 40  80 40  100 45  50 45  65 45  80 45  105 50  50 50  65 50  80 50  105 R40 R50 R65 A40 A50 A65 A80 AA0 B50 B65 B80 BA0 U50 U65 U80 UA5 C50 C65 C80 CA5 0.369 0.255 0.178 0.203 0.171 0.117 0.080 0.064 0.121 0.083 0.066 0.055 0.107 0.090 0.060 0.049 0.103 0.069 0.056 0.046 1.9 2.5 3.4 3.1 3.7 4.8 6.2 7.7 4.6 6.0 7.3 8.7 5.2 6.2 8.2 10.0 5.5 7.3 8.8 11.0 270 390 560 390 560 820 1,000 1,200 680 1,000 1,200 1,800 1,000 1,200 E92L401VSN271MR40T E92L401VSN391MR50T E92L401VSN561MR65T E92L401VSN391MA40T E92L401VSN561MA50T E92L401VND821MA65T E92L401VND102MA80T E92L401VND122MAA0T E92L401VND681MB50T E92L401VND102MB65T E92L401VND122MB80T E92L401VND182MBA0T E92L401VNT102MU50T E92L401VNT122MU65T 30  40 30  50 30  65 35  40 35  50 35  65 35  80 35  100 40  50 40  65 40  80 40  100 45  50 45  65 R40 R50 R65 A40 A50 A65 A80 AA0 B50 B65 B80 BA0 U50 U65 0.354 0.245 0.171 0.235 0.164 0.112 0.092 0.076 0.146 0.100 0.083 0.055 0.107 0.090 1.9 2.6 3.5 2.9 3.8 4.9 5.8 7.0 4.2 5.5 6.5 8.7 5.2 6.2 † For construction and terminal options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. Product specifications are subject to change without notice. Ask for UCC product bulletins and review specifications before purchase and/or use. Please use our products based on parameters specified in our bulletins. 22 United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com Engineering Bulletin Aug 2013 U92L Series Standard Voltage Ratings - Snap Mount Rated Voltage (WVDC) 400 Volts 450 Volts Surge 420 Volts 470 Volts Surge Nominal Case Size* DL ( mm ) Case Size Code Maximum ESR ( Ω ) at 20C, 120Hz 1,500 2,200 1,200 1,500 2,200 2,700 E92L401VNT152MU80T E92L401VNT222MUA5T E92L401VNT122MC50T E92L401VNT152MC65T E92L401VNT222MC80T E92L401VNT272MCA5T 45  80 45  105 50  50 50  65 50  80 50  105 U80 UA5 C50 C65 C80 CA5 0.072 0.049 0.100 0.080 0.054 0.044 7.5 10.0 5.4 6.8 9.0 11.2 220 330 470 390 560 680 820 1,200 680 820 1,200 1,500 820 1,200 1,500 1,800 1,000 1,500 1,800 2,200 E92L421VSN221MR40T E92L421VSN331MR50T E92L421VSN471MR65T E92L421VSN391MA40T E92L421VSN561MA50T E92L421VND681MA65T E92L421VND821MA80T E92L421VND122MAA0T E92L421VND681MB50T E92L421VND821MB65T E92L421VND122MB80T E92L421VND152MBA0T E92L421VNT821MU50T E92L421VNT122MU65T E92L421VNT152MU80T E92L421VNT182MUA5T E92L421VNT102MC50T E92L421VNT152MC65T E92L421VNT182MC80T E92L421VNT222MCA5T 30  40 30  50 30  65 35  40 35  50 35  65 35  80 35  100 40  50 40  65 40  80 40  100 45  50 45  65 45  80 45  105 50  50 50  65 50  80 50  105 R40 R50 R65 A40 A50 A65 A80 AA0 B50 B65 B80 BA0 U50 U65 U80 UA5 C50 C65 C80 CA5 0.408 0.298 0.212 0.264 0.193 0.137 0.106 0.082 0.150 0.107 0.084 0.065 0.130 0.093 0.073 0.053 0.113 0.081 0.063 0.046 1.8 2.3 3.1 2.7 3.5 4.4 5.4 6.8 4.2 5.3 6.5 8.0 4.7 6.1 7.4 9.6 5.1 6.7 8.3 10.9 220 330 390 330 470 680 820 1,000 560 820 1,000 1,200 680 1,000 1,200 1,800 820 1,200 1,500 2,200 E92L451VSN221MR40T E92L451VSN331MR50T E92L451VSN391MR65T E92L451VSN331MA40T E92L451VSN471MA50T E92L451VND681MA65T E92L451VND821MA80T E92L451VND102MAA0T E92L451VND561MB50T E92L451VND821MB65T E92L451VND102MB80T E92L451VND122MBA0T E92L451VNT681MU50T E92L451VNT102MU65T E92L451VNT122MU80T E92L451VNT182MUA5T E92L451VNT821MC50T E92L451VNT122MC65T E92L451VNT152MC80T E92L451VNT222MCA5T 30  40 30  50 30  65 35  40 35  50 35  65 35  80 35  100 40  50 40  65 40  80 40  100 45  50 45  65 45  80 45  105 50  50 50  65 50  80 50  105 R40 R50 R65 A40 A50 A65 A80 AA0 B50 B65 B80 BA0 U50 U65 U80 UA5 C50 C65 C80 CA5 0.428 0.312 0.222 0.318 0.202 0.143 0.111 0.086 0.170 0.122 0.095 0.073 0.142 0.102 0.079 0.058 0.120 0.086 0.067 0.049 1.8 2.3 3.0 2.5 3.4 4.3 5.3 6.6 3.9 5.0 6.1 7.5 4.5 5.8 7.1 9.2 5.0 6.5 8.1 10.6 150 220 270 220 330 390 E92L501VSN151MR40T E92L501VSN221MR50T E92L501VSN271MR65T E92L501VSN221MA40T E92L501VSN331MA50T E92L501VND391MA65T 30  40 30  50 30  65 35  40 35  50 35  65 R40 R50 R65 A40 A50 A65 0.557 0.380 0.310 0.380 0.253 0.214 1.6 2.1 2.6 2.3 3.0 3.6 † For construction and terminal options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. Product specifications are subject to change without notice. Ask for UCC product bulletins and review specifications before purchase and/or use. Please use our products based on parameters specified in our bulletins. United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com 23 U92L 500 Volts 550 Volts Surge Global Part Number† SNAP MOUNT 85C 450 Volts 500 Volts Surge Rated Ripple Current (A rms) at 85C, 120Hz Capacitance (µF ) Engineering Bulletin Aug 2013 U92L Series Standard Voltage Ratings - Snap Mount Rated Voltage (WVDC) 500 Volts 550 Volts Surge Capacitance (µF ) Global Part Number† Nominal Case Size* DL ( mm ) Case Size Code Maximum ESR ( Ω ) at 20C, 120Hz 560 680 390 560 680 1,000 560 820 1,000 1,500 680 1,000 1,200 1,800 E92L501VND561MA80T E92L501VND681MAA0T E92L501VND391MB50T E92L501VND561MB65T E92L501VND681MB80T E92L501VND102MBA0T E92L501VNT561MU50T E92L501VNT821MU65T E92L501VNT102MU80T E92L501VNT152MUA5T E92L501VNT681MC50T E92L501VNT102MC65T E92L501VNT122MC80T E92L501VNT182MCA5T 35  80 35  100 40  50 40  65 40  80 40  100 45  50 45  65 45  80 45  105 50  50 50  65 50  80 50  105 A80 AA0 B50 B65 B80 BA0 U50 U65 U80 UA5 C50 C65 C80 CA5 0.149 0.123 0.225 0.156 0.129 0.088 0.164 0.112 0.092 0.061 0.146 0.100 0.083 0.055 Rated Ripple Current (A rms) at 85C, 120Hz 4.6 5.6 3.4 4.4 5.2 6.9 4.2 5.5 6.6 9.0 4.5 6.1 7.2 10.0 U92L SNAP MOUNT 85C † For construction and terminal options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. Product specifications are subject to change without notice. Ask for UCC product bulletins and review specifications before purchase and/or use. Please use our products based on parameters specified in our bulletins. 24 United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com U92X Series  Snap Mount  Specific Design For Higher Ripple Current  350 to 500VDC Voltage Range  RoHS Compliant  85C Maximum Temperature  15,000 Hours Lifetime at 85C The U92X series is a longest life series specifically designed for higher ripple current capability. The U92X capacitors have an endurance rating of 15,000 hours at 85C with the rated ripple current applied. All U92X series capacitors are RoHS compliant and available in a variety of sizes, with or without an end disk, and encased in a PET sleeve or standard Pb-free PVC sleeve. Snap-in terminals (2, 4 or 5 -pin configurations) are available as standard or optional styles depending on case size. Straight standoff terminals (5 -pin configuration) are an option for 40, 45 and 50mm can diameters. Summary of Specifications  PC board snap-in or straight standoff terminals available as standard or optional styles depending on pin styles and case size.  Capacitance range: 150 to 3,300µF.  Voltage range: 350 to 500VDC.  Category temperature range: 25C to 85C. 25 U92X United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com SNAP MOUNT 85C  Leakage current: 3 CV (µA) or 3mA, whichever is smaller, after 5 minutes at 20C.  Standard capacitance tolerance: 20%  Nominal case size (DL): 3040mm to 50105mm.  Rated lifetime: 15,000 hours at 85C with the rated ripple current applied. Engineering Bulletin Aug 2013 U92X Series U92X Specifications - Snap Mount Item Characteristics Category Temperature Range 25 to 85C Rated Voltage Range 350 to 500VDC Capacitance Range 150 to 3,300F Capacitance Tolerance 20% ( M ) at 20C, 120Hz Leakage Current I = 3 CV (A ) or 3mA, whichever is smaller, after 5 minutes at 20C. Where I = Max. leakage current (A ), C = Nominal capacitance (F ) and V = Rated voltage ( V ) Dissipation Factor ( Tan ) At 20C, 120Hz Rated Voltage ( V ) 350 - 400 420 -500 0.15 0.20 Tan  ( DF ) Max. Low Temperature Characteristics At 120Hz, impedance ( Z ) ratio between the 25C value and 20C value shall not exceed the values given below. Rated Voltage ( V ) 350 -500 Z (25C ) / Z (20C ) Rated Ripple Current Multipliers 8 Ambient Temperature (C ) 45C 65C 85C 2.82 1.73 1.00 Frequency (Hz ) Endurance (Load Life) DC Rated Voltage 50Hz 120Hz 300Hz 1kHz 10kHz 100kHz 350 - 450V 0.77 1.00 1.16 1.30 1.41 1.43 500V 0.70 1.00 1.16 1.30 1.41 1.43 The following specifications shall be satisfied when the capacitors are restored to 20C after subjecting them to DC voltage for 15,000 hours at 85C with the rated ripple current applied. The sum of the DC voltage and peak AC voltage must not exceed the full rated voltage of the capacitors. Capacitance change: ≤ 20% of initial measured value Tan  ( DF ) : ≤ 200% of initial specified value Leakage current : ≤ initial specified value Shelf Life The following specifications shall be satisfied when the capacitors are restored to 20C after exposing them for 1,000 hours at 85C without voltage applied. The rated voltage shall be applied to the capacitors for a minimum of 30 minutes, at least 24 hours and not more than 48 hours before the measurements. U92X SNAP MOUNT 85C Capacitance change: ≤ 20% of initial measured value Tan  ( DF ) : ≤ 150% of initial specified value Leakage current : ≤ initial specified value Product specifications are subject to change without notice. Ask for UCC product bulletins and review specifications before purchase and/or use. Please use our products based on parameters specified in our bulletins. 26 United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com Engineering Bulletin Aug 2013 U92X Series Diagram of Dimensions - Snap Mount Unit: mm Snap Mount VND Snap-in Ø 35 and Ø 40 standard; Ø 45 optional VSD Snap-in Ø 35 and Ø 40 optional VSN Snap-in Ø 30 and Ø 35 standard VNN Snap-in Ø 30 and Ø 35 optional *** Black Insulating Sleeve Negative Mark PC Board Pin-out *** Black Insulating Sleeve Negative Mark PC Board Pin-out A* D 1 ** Vent 10 2-2x See Pin Detail L 2.5 Insulating Disk ** Vent Negative Mark PC Board Pin-out 3.3 0.1 4.75 0.1 10 2-2x See Pin Detail L 2.5 Insulating Disk C* See Pin Detail L 2.5 2-4x VNT Snap-in Ø 45 and Ø 50 standard D 1 ** Vent 22.5 B Insulating Disk VEN Snap-in Ø 30 and Ø 35 optional *** Black Insulating Sleeve D 1 30° 2.5 MIN.-1x *** Black Insulating Sleeve Negative Mark A B* C PC Board Pin-out 360° 6 D 1 ** Vent 25 Insulating Disk 2-5x D See Pin Detail L 2.5 VS, VE & VN Snap-in Pin Dimensions W2 W1 P Straight Pin Mount Edge of can VQT Straight Standoff Ø 40, Ø 45 and Ø 50 optional W *** Black Insulating Sleeve Type VSN Ø 30 VSN Ø 35 VNN Ø 30 - Ø 35 VEN Ø 30 - Ø 35 VSD Ø 35 - Ø 40 VND Ø 35 - Ø 45 VNT Ø 45 - Ø 50 P 4.00.5 3.50.5 5.81.0 4.00.5 3.51.0 5.81.0 5.81.0 W W1 Negative Mark W2 PC Board Pin-out 360° 6 B* A* C D 1 1.50.2 0.80.1 0.80.1 ** Vent 25 D* See Pin Detail L 2.5 Insulating Disk 2- 5x VQ Standoff Pin Dimensions W1 W P CAUTION: * Use the blank terminals for mechanical support only. The blank terminals must not be connected to a solder trace on the PC board but be electrically isolated from the negative and positive terminals. ** The vent may be located either on the bottom or side of the can. *** The black sleeve with gray stripe negative pin indicator is standard. Also note in some cases, the sleeve color may change slightly due to the operating conditions, however, the discoloration will not impair capacitor function. Edge of can P1 Type Standoff Pin (VQ) P 3.751.0 P1 2.0 max. W 1.50.1 W1 0.70.2 27 U92X United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com SNAP MOUNT 85C Product specifications are subject to change without notice. Ask for UCC product bulletins and review specifications before purchase and/or use. Please use our products based on parameters specified in our bulletins. Engineering Bulletin Aug 2013 U92X Series Part Numbering System for U92X Series When ordering, always specify complete 18-field global part number. 18 Fields 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E 9 2 X 5 0 1 V N T 6 8 1 MU 6 5 T 9 8 7 6 5 4 3 2 U92X SNAP MOUNT 85C 1 Supplement Code. Field 18. All construction options listed have Sn100% terminal plating. T = Pb-free PVC sleeve with end disk. M = Pb-free PVC sleeve without end disk. W = PET sleeve with end disk. S = PET sleeve without end disk. Case Size. Fields 15, 16 and 17. The single letter diameter code is inserted in field 15. R = Ø 30mm A = Ø 35mm B = Ø 40mm U = Ø 45mm C = Ø 50mm The double digit length code is inserted in fields 16 and 17. 40 = 40mm 50 = 50mm 65 = 65mm 80 = 80mm A0 = 100mm A5 = 105mm Capacitance Tolerance. Field 14. M = 20% Capacitance. Fields 11, 12 and 13. Expressed in Microfarads. The first two digits are significant figures inserted in fields 11 and 12, and the third digit inserted in field 13 indicates the number of zeros for capacitance of 10F or more. R indicates the decimal point for capacitance less than 10F (e.g. 6R8 = 6.8F; 680 = 68F; 681 = 680F; 682 = 6,800F; 683 = 68,000F ). Dummy Terminals. Field 10. N = No dummy terminals. D = 2 dummy terminals. T = 3 dummy terminals. Terminal Type. Fields 8 and 9. VS = Snap-in pins, 4.0mm in length ( Ø30 VSN); 3.5mm in length ( Ø35 VSN, Ø35 or Ø40 VSD). VN = Snap-in pins, 5.8mm in length. VE = Snap-in pins, polarized, Ø30 or Ø35 option. VQ = Straight standoff pins. DC Rated Voltage. Fields 5, 6 and 7. Expressed in Volts. The first two digits are significant figures inserted in fields 5 and 6, and the third digit inserted in field 7 indicates the number of zeros for rated voltage of 10VDC or more. R indicates the decimal point for rated voltage less than 10VDC (e.g. 5R0 = 5.0VDC; 500 = 50VDC; 501 = 500VDC). Rule Exception: Coding for rated voltage 385VDC = 3J1. Series Name. Fields 2, 3 and 4. Enter the 3-letter/digit series name in fields 2, 3 and 4. If the series name is only 2 letters/digits, place a dash in field 4. For a series name with more than 3 letters/digits, refer to the individual series for the appropriate 3-field series name. Capacitor Type. Field 1. Aluminum Electrolytic Capacitor (Polar). Product specifications are subject to change without notice. Ask for UCC product bulletins and review specifications before purchase and/or use. Please use our products based on parameters specified in our bulletins. 28 United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com Engineering Bulletin Aug 2013 U92X Series Standard Voltage Ratings - Snap Mount Rated Voltage (WVDC) 350 Volts 400 Volts Surge 385 Volts 435 Volts Surge 400 Volts 450 Volts Surge Rated Ripple Current (A rms) at 85C, 120Hz Global Part Number† Nominal Case Size* DL ( mm ) Case Size Code Maximum ESR ( Ω ) at 20C, 120Hz 330 470 680 470 680 1,000 1,200 1,500 820 1,200 1,500 1,800 1,000 1,500 1,800 2,700 1,200 1,800 2,200 3,300 E92X351VSN331MR40T E92X351VSN471MR50T E92X351VSN681MR65T E92X351VSN471MA40T E92X351VSN681MA50T E92X351VND102MA65T E92X351VND122MA80T E92X351VND152MAA0T E92X351VND821MB50T E92X351VND122MB65T E92X351VND152MB80T E92X351VND182MBA0T E92X351VNT102MU50T E92X351VNT152MU65T E92X351VNT182MU80T E92X351VNT272MUA5T E92X351VNT122MC50T E92X351VNT182MC65T E92X351VNT222MC80T E92X351VNT332MCA5T 30  40 30  50 30  65 35  40 35  50 35  65 35  80 35  100 40  50 40  65 40  80 40  100 45  50 45  65 45  80 45  105 50  50 50  65 50  80 50  105 R40 R50 R65 A40 A50 A65 A80 AA0 B50 B65 B80 BA0 U50 U65 U80 UA5 C50 C65 C80 CA5 0.302 0.212 0.146 0.195 0.135 0.092 0.076 0.061 0.121 0.083 0.066 0.055 0.107 0.072 0.060 0.040 0.103 0.069 0.056 0.037 2.1 2.8 3.7 3.1 4.2 5.4 6.4 7.9 4.6 6.0 7.3 8.7 5.2 6.9 8.2 11.1 5.4 7.3 8.8 12.2 270 390 560 390 560 820 1,000 1,200 680 1,000 1,200 1,800 1,000 1,200 1,500 2,200 1,200 1,500 2,200 2,700 E92X3J1VSN271MR40T E92X3J1VSN391MR50T E92X3J1VSN561MR65T E92X3J1VSN391MA40T E92X3J1VSN561MA50T E92X3J1VND821MA65T E92X3J1VND102MA80T E92X3J1VND122MAA0T E92X3J1VND681MB50T E92X3J1VND102MB65T E92X3J1VND122MB80T E92X3J1VND182MBA0T E92X3J1VNT102MU50T E92X3J1VNT122MU65T E92X3J1VNT152MU80T E92X3J1VNT222MUA5T E92X3J1VNT122MC50T E92X3J1VNT152MC65T E92X3J1VNT222MC80T E92X3J1VNT272MCA5T 30  40 30  50 30  65 35  40 35  50 35  65 35  80 35  100 40  50 40  65 40  80 40  100 45  50 45  65 45  80 45  105 50  50 50  65 50  80 50  105 R40 R50 R65 A40 A50 A65 A80 AA0 B50 B65 B80 BA0 U50 U65 U80 UA5 C50 C65 C80 CA5 0.339 0.235 0.164 0.225 0.156 0.107 0.088 0.073 0.135 0.092 0.076 0.051 0.100 0.083 0.066 0.045 0.096 0.077 0.052 0.043 2.0 2.6 3.5 2.9 3.9 5.0 5.9 7.2 4.4 5.8 6.8 9.0 5.4 6.4 7.7 10.4 5.7 6.9 9.1 11.4 270 390 470 390 560 680 1,000 1,200 680 1,000 1,200 1,500 820 1,200 E92X401VSN271MR40T E92X401VSN391MR50T E92X401VSN471MR65T E92X401VSN391MA40T E92X401VSN561MA50T E92X401VND681MA65T E92X401VND102MA80T E92X401VND122MAA0T E92X401VND681MB50T E92X401VND102MB65T E92X401VND122MB80T E92X401VND152MBA0T E92X401VNT821MU50T E92X401VNT122MU65T 30  40 30  50 30  65 35  40 35  50 35  65 35  80 35  100 40  50 40  65 40  80 40  100 45  50 45  65 R40 R50 R65 A40 A50 A65 A80 AA0 B50 B65 B80 BA0 U50 U65 0.339 0.235 0.195 0.225 0.156 0.129 0.088 0.073 0.135 0.092 0.076 0.061 0.121 0.083 2.0 2.6 3.2 2.9 3.9 4.6 5.9 7.2 4.4 5.8 6.8 8.2 4.9 6.4 Product specifications are subject to change without notice. Ask for UCC product bulletins and review specifications before purchase and/or use. Please use our products based on parameters specified in our bulletins. United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com 29 U92X † For construction and terminal options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. SNAP MOUNT 85C Capacitance (µF ) Engineering Bulletin Aug 2013 U92X Series Standard Voltage Ratings - Snap Mount Rated Voltage (WVDC) 400 Volts 450 Volts Surge 420 Volts 470 Volts Surge 450 Volts 500 Volts Surge 500 Volts U92X SNAP MOUNT 85C 550 Volts Surge Rated Ripple Current (A rms) at 85C, 120Hz Capacitance (µF ) Global Part Number† Nominal Case Size* DL ( mm ) Case Size Code Maximum ESR ( Ω ) at 20C, 120Hz 1,500 2,200 1,200 1,500 1,800 2,700 E92X401VNT152MU80T E92X401VNT222MUA5T E92X401VNT122MC50T E92X401VNT152MC65T E92X401VNT182MC80T E92X401VNT272MCA5T 45  80 45  105 50  50 50  65 50  80 50  105 U80 UA5 C50 C65 C80 CA5 0.066 0.045 0.093 0.074 0.062 0.041 7.7 10.4 5.6 7.0 8.4 11.6 220 330 470 390 470 680 820 1,200 680 820 1,200 1,500 820 1,000 1,200 1,800 1,000 1,200 1,800 2,200 E92X421VSN221MR40T E92X421VSN331MR50T E92X421VSN471MR65T E92X421VSN391MA40T E92X421VSN471MA50T E92X421VND681MA65T E92X421VND821MA80T E92X421VND122MAA0T E92X421VND681MB50T E92X421VND821MB65T E92X421VND122MB80T E92X421VND152MBA0T E92X421VNT821MU50T E92X421VNT102MU65T E92X421VNT122MU80T E92X421VNT182MUA5T E92X421VNT102MC50T E92X421VNT122MC65T E92X421VNT182MC80T E92X421VNT222MCA5T 30  40 30  50 30  65 35  40 35  50 35  65 35  80 35  100 40  50 40  65 40  80 40  100 45  50 45  65 45  80 45  105 50  50 50  65 50  80 50  105 R40 R50 R65 A40 A50 A65 A80 AA0 B50 B65 B80 BA0 U50 U65 U80 UA5 C50 C65 C80 CA5 0.389 0.284 0.202 0.251 0.183 0.130 0.101 0.078 0.142 0.102 0.079 0.061 0.124 0.089 0.069 0.051 0.109 0.078 0.061 0.044 1.9 2.4 3.2 2.8 3.6 4.6 5.5 7.0 4.3 5.5 6.6 8.2 4.8 6.2 7.6 9.9 5.2 6.8 8.5 11.2 220 330 390 330 470 560 820 1,000 560 820 1,000 1,200 680 1,000 1,200 1,800 820 1,200 1,500 2,200 E92X451VSN221MR40T E92X451VSN331MR50T E92X451VSN391MR65T E92X451VSN331MA40T E92X451VSN471MA50T E92X451VND561MA65T E92X451VND821MA80T E92X451VND102MAA0T E92X451VND561MB50T E92X451VND821MB65T E92X451VND102MB80T E92X451VND122MBA0T E92X451VNT681MU50T E92X451VNT102MU65T E92X451VNT122MU80T E92X451VNT182MUA5T E92X451VNT821MC50T E92X451VNT122MC65T E92X451VNT152MC80T E92X451VNT222MCA5T 30  40 30  50 30  65 35  40 35  50 35  65 35  80 35  100 40  50 40  65 40  80 40  100 45  50 45  65 45  80 45  105 50  50 50  65 50  80 50  105 R40 R50 R65 A40 A50 A65 A80 AA0 B50 B65 B80 BA0 U50 U65 U80 UA5 C50 C65 C80 CA5 0.411 0.300 0.213 0.304 0.193 0.138 0.107 0.082 0.163 0.117 0.091 0.070 0.137 0.098 0.076 0.056 0.115 0.083 0.064 0.047 1.8 2.3 3.1 2.5 3.5 4.4 5.4 6.8 4.0 5.1 6.2 7.7 4.6 5.9 7.2 9.4 5.1 6.6 8.2 10.8 150 180 270 220 270 390 E92X501VSN151MR40T E92X501VSN181MR50T E92X501VSN271MR65T E92X501VSN221MA40T E92X501VSN271MA50T E92X501VND391MA65T 30  40 30  50 30  65 35  40 35  50 35  65 R40 R50 R65 A40 A50 A65 0.557 0.464 0.310 0.362 0.295 0.204 1.6 1.9 2.6 2.3 2.8 3.6 † For construction and terminal options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. Product specifications are subject to change without notice. Ask for UCC product bulletins and review specifications before purchase and/or use. Please use our products based on parameters specified in our bulletins. 30 United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com Engineering Bulletin Aug 2013 U92X Series Standard Voltage Ratings - Snap Mount Rated Voltage (WVDC) 500 Volts 550 Volts Surge Capacitance (µF ) Global Part Number† Nominal Case Size* DL ( mm ) Case Size Code Maximum ESR ( Ω ) at 20C, 120Hz 560 680 390 560 680 820 560 680 1,000 1,200 680 1,000 1,200 1,800 E92X501VND561MA80T E92X501VND681MAA0T E92X501VND391MB50T E92X501VND561MB65T E92X501VND681MB80T E92X501VND821MBA0T E92X501VNT561MU50T E92X501VNT681MU65T E92X501VNT102MU80T E92X501VNT122MUA5T E92X501VNT681MC50T E92X501VNT102MC65T E92X501VNT122MC80T E92X501VNT182MCA5T 35  80 35  100 40  50 40  65 40  80 40  100 45  50 45  65 45  80 45  105 50  50 50  65 50  80 50  105 A80 AA0 B50 B65 B80 BA0 U50 U65 U80 UA5 C50 C65 C80 CA5 0.142 0.117 0.204 0.142 0.117 0.097 0.156 0.129 0.088 0.073 0.141 0.096 0.080 0.053 Rated Ripple Current (A rms) at 85C, 120Hz 4.7 5.7 3.6 4.6 5.5 6.5 4.3 5.2 6.7 8.2 4.6 6.2 7.4 10.2 † For construction and terminal options, refer to the part numbering system for descriptions and codes. * Refer to diagram of dimensions for detailed case size specifications. 31 U92X United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com SNAP MOUNT 85C Product specifications are subject to change without notice. Ask for UCC product bulletins and review specifications before purchase and/or use. Please use our products based on parameters specified in our bulletins. Corporate Office 9801 West Higgins Road‚ Rosemont‚ Illinois 60018 Phone 847-696-2000 Fax 847-696-9278 Western Regional Sales Office 625 Columbia Street‚ Brea‚ California 92821 Phone 714-255-9500 Fax 714-255-9400 Southeastern Regional Sales Office 2045 Cecil Ashburn Drive, Suite 103, Huntsville, Alabama 35802 Phone 256-489-9385 Fax 256-489-9387 Internet: www.chemi-con.com E-mail: info@chemi-con.com For further information, please contact: Representing North America, United Chemi-Con is a wholly owned subsidiary of Nippon Chemi-Con. © 2013 United Chemi-Con‚ Inc. Printed in USA
E92F501VSN221MR50T AI解析
物料型号: - U91F、U92F、U92L、U92X系列是United Chemi-Con公司推出的高纹波电流能力的铝电解电容器。
器件简介: - 这些系列的电容器专为高纹波电流设计,具有超长寿命、宽温度范围、高电压等级,并提供多种外壳尺寸和端子样式。
引脚分配: - 提供2、3、4或5引脚布局,具体取决于外壳尺寸。有的系列提供标准或可选配置的直插式或立式端子。
参数特性: - U91F系列在105°C下有5000小时的寿命评级。 - U92F、U92L和U92X系列在85°C下分别有5000、10000和15000小时的寿命评级。 - 所有U91/U92系列电容器均符合RoHS标准。
功能详解: - 这些电容器设计用于满足高纹波电流的要求,同时保持较长的使用寿命和高可靠性。
应用信息: - 适用于需要高纹波电流能力的场合,如电源、电源转换器等。
封装信息: - 提供多种尺寸的封装选项,包括直径和长度不同的规格。
*介绍内容由AI识别生成
E92F501VSN221MR50T 价格&库存
很抱歉,暂时无法提供与“E92F501VSN221MR50T”相匹配的价格&库存,您可以联系我们找货
