ESMG6R3ELL153MN30S
ESMG6R3ELL153MN30S
    NCC(贵弥功)
    插件
    15000µF 6.3V Aluminum Capacitors Radial, Can 2000 Hrs @ 85°C
ESMG6R3ELL153MN30S 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Downsized, 85C SMQ @Endurance : 2,000 hours at 85C @Solvent resistant type except 315 to 450Vdc (see PRECAUTIONS AND GUIDELINES) @RoHS Compliant Downsized SMG ?SPECIFICATIONS Items Characteristics Category Temperature Range -40 to +85C(6.3 to 400Vdc) Rated Voltage Range Capacitance Tolerance Leakage Current -25 to +85C(450Vdc) 6.3 to 450Vdc P20% (M) 6.3 to 100Vdc [F18 I=0.03CV or 4MA, whichever is greater. (at 20C, 120Hz) 160 to 450Vdc Time After 1minute CV CV[1,000 I=0.1CV+40 max. CV>1,000 I=0.04CV+100 max. After 5minutes I=0.03CV+15 max. I=0.02CV+25 max. (at 20C) (at 20C after 3 minutes) (at 20C after 1 minute) ]F20 I=0.03CV Where, I : Max. leakage current (MA), C : Nominal capacitance (MF), V : Rated voltage (V) Rated voltage (Vdc) 6.3V 10V 16V 25V 35V 50V 63V 100V 160 to 250V 315 to 400V 450V [F18 0.34 0.24 0.20 0.16 0.14 0.12 0.09 0.08 0.20 0.24 0.24 tanE (Max.) ]F20 0.28 0.24 0.20 0.16 0.14 0.12 0.09 0.08 0.15 0.15 0.20 (at 20C, 120Hz) When nominal capacitance exceeds 1,000MF, add 0.02 to the value above for each 1,000MF increase. Rated voltage (Vdc) 6.3V 10V 16V 25V 35V 50V 63V 100V 160 to 250V 315 to 400V 450V Z(-25C)/Z(+20C) [F18 4 3 2 2 2 2 2 6 5 3 6 ]F20 5 4 3 2 2 2 2 2 6 6 4 Z(-40C)/Z(+20C) [F18 12 10 8 5 4 3 3 3 4 6 - (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20C after the rated voltage is applied for 2,000 hours at 85C. Capacitance change [P20% of the initial value D.F. (tanE) [200% of the initial specified value Leakage current [The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20C after exposing them for 1,000 hours at 85C without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Rated voltage 6.3 to 100Vdc 160 to 450Vdc Capacitance change [P20% of the initial value [P20% of the initial value D.F. (tanE) [200% of the initial specified value [200% of the initial specified value Leakage current [The initial specified value [500% of the initial specified value Dissipation Factor (tane) Low Temperature Characteristics (Max. Impedance Ratio) Endurance Shelf Life ?DIMENSIONS [mm] FP0.5 FD' Fd Sleeve (PET : Black) f5 to f18 FP0.5 @Terminal Code : E L' Vent (except F5) 15min. 4min. (F5 to F10) (F12.5 to F18) FD' Fd Sleeve (PET : Black) ]f20 FP0.5 Gas escape end seal L' Vent 15min. 4min. fD fd F fD' L' 5 0.5 2.0 6.3 0.5 2.5 10 12.5 8 0.6 0.6 0.6 3.5 5.0 5.0 FD+0.5max. L+1.5max. 16 0.8 7.5 22 25.4 18 20 0.8 1.0 1.0 1.0 7.5 10.0 10.0 12.5 FD+0.5max. L+2.0max. ?PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E S MG A A A E A A A A A M A A A N Supplement code Size code Capacitance tolerance code Capacitance code (ex. 0.1MF:R10,10MF:100,100MF:101) Lead forming·taping code Terminal code Voltage code (ex. 6.3V:6R3,100V:101,315V:3B1) Series code Category (1/4) Please refer to "Product code guide (radial lead type)" CAT. No. E1001I MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Downsized, 85C ?STANDARD RATINGS WV (Vdc) 6.3 10 16 Cap (mF) Case size fDbL(mm) tane Rated ripple current (mArms/ 85c,120Hz) Part No. 33 47 100 220 330 470 1,000 2,200 3,300 4,700 6,800 10,000 10,000 15,000 15,000 18,000 18,000 22,000 22,000 22,000 27,000 39,000 22 33 47 100 220 330 470 1,000 2,200 3,300 4,700 6,800 6,800 10,000 10,000 12,000 15,000 15,000 15,000 18,000 22,000 33,000 10 22 33 47 100 220 330 470 1,000 2,200 3,300 4,700 4,700 6,800 6,800 8,200 10,000 10,000 10,000 12,000 12,000 15,000 22,000 5B11 5B11 5B11 5B11 6.3B11 6.3B11 8B11.5 10B20 10B20 12.5B20 12.5B25 16B25 20B25 16B35.5 20B30 20B35 22B30 18B40 20B40 22B35 22B40 25.4B40 5B11 5B11 5B11 5B11 5B11 6.3B11 6.3B11 10B12.5 10B20 12.5B20 12.5B25 16B25 20B20 16B35.5 20B25 20B30 18B35.5 20B35 22B30 22B35 22B40 25.4B40 5B11 5B11 5B11 5B11 5B11 6.3B11 8B11.5 8B11.5 10B16 12.5B20 12.5B25 16B25 20B20 16B31.5 20B25 20B30 18B35.5 20B35 22B30 20B40 22B35 22B40 25.4B40 0.34 0.34 0.34 0.34 0.34 0.34 0.34 0.36 0.38 0.40 0.44 0.52 0.46 0.62 0.56 0.62 0.62 0.76 0.70 0.70 0.80 1.04 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.26 0.28 0.30 0.34 0.34 0.42 0.42 0.46 0.52 0.52 0.52 0.58 0.66 0.88 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.22 0.24 0.26 0.26 0.30 0.30 0.34 0.38 0.38 0.38 0.42 0.42 0.48 0.62 77 92 134 200 270 320 540 1,000 1,185 1,545 1,915 2,330 2,310 2,845 2,660 2,890 2,860 3,320 3,130 3,130 3,280 3,560 66 83 100 146 240 290 350 650 1,070 1,420 1,780 2,220 2,080 2,670 2,410 2,620 3,080 2,870 2,660 3,050 3,480 3,560 50 75 91 109 160 260 370 440 785 1,295 1,655 2,090 1,960 2,520 2,330 2,500 2,920 2,720 2,660 2,900 2,900 3,380 3,720 ESMG6R3ESS330ME11D ESMG6R3ESS470ME11D ESMG6R3ESS101ME11D ESMG6R3ESS221ME11D ESMG6R3ESS331MF11D ESMG6R3ESS471MF11D ESMG6R3ESS102MHB5D ESMG6R3ESS222MJ20S ESMG6R3ESS332MJ20S ESMG6R3ESS472MK20S ESMG6R3ESS682MK25S ESMG6R3ESS103ML25S ESMG6R3ESS103MN25S ESMG6R3ESS153MLP1S ESMG6R3ESS153MN30S ESMG6R3ESS183MN35S ESMG6R3ESS183MP30S ESMG6R3ESS223MM40S ESMG6R3ESS223MN40S ESMG6R3ESS223MP35S ESMG6R3ESS273MP40S ESMG6R3ESS393MQ40S ESMG100ESS220ME11D ESMG100ESS330ME11D ESMG100ESS470ME11D ESMG100ESS101ME11D ESMG100ESS221ME11D ESMG100ESS331MF11D ESMG100ESS471MF11D ESMG100ESS102MJC5S ESMG100ESS222MJ20S ESMG100ESS332MK20S ESMG100ESS472MK25S ESMG100ESS682ML25S ESMG100ESS682MN20S ESMG100ESS103MLP1S ESMG100ESS103MN25S ESMG100ESS123MN30S ESMG100ESS153MMP1S ESMG100ESS153MN35S ESMG100ESS153MP30S ESMG100ESS183MP35S ESMG100ESS223MP40S ESMG100ESS333MQ40S ESMG160ESS100ME11D ESMG160ESS220ME11D ESMG160ESS330ME11D ESMG160ESS470ME11D ESMG160ESS101ME11D ESMG160ESS221MF11D ESMG160ESS331MHB5D ESMG160ESS471MHB5D ESMG160ESS102MJ16S ESMG160ESS222MK20S ESMG160ESS332MK25S ESMG160ESS472ML25S ESMG160ESS472MN20S ESMG160ESS682MLN3S ESMG160ESS682MN25S ESMG160ESS822MN30S ESMG160ESS103MMP1S ESMG160ESS103MN35S ESMG160ESS103MP30S ESMG160ESS123MN40S ESMG160ESS123MP35S ESMG160ESS153MP40S ESMG160ESS223MQ40S WV (Vdc) 25 35 50 Cap (mF) Case size fDbL(mm) tane Rated ripple current (mArms/ 85c,120Hz) Part No. 4.7 10 22 33 47 100 220 330 470 1,000 2,200 3,300 3,300 4,700 4,700 5,600 6,800 6,800 6,800 8,200 8,200 10,000 12,000 15,000 4.7 10 22 33 47 100 220 330 470 1,000 2,200 2,200 3,300 3,300 3,900 4,700 4,700 4,700 5,600 5,600 6,800 10,000 0.10 0.22 0.33 0.47 1.0 2.2 3.3 4.7 10 22 33 47 100 220 330 470 1,000 1,500 2,200 2,200 2,700 5B11 5B11 5B11 5B11 5B11 6.3B11 8B11.5 8B11.5 10B12.5 10B20 12.5B25 16B25 20B20 16B31.5 20B25 20B30 18B35.5 20B35 22B30 20B40 22B35 22B40 22B40 25.4B40 5B11 5B11 5B11 5B11 5B11 6.3B11 8B11.5 10B12.5 10B16 12.5B20 16B25 20B20 16B35.5 20B25 20B30 18B35.5 20B35 22B30 20B40 22B35 22B40 25.4B40 5B11 5B11 5B11 5B11 5B11 5B11 5B11 5B11 5B11 5B11 5B11 6.3B11 8B11.5 10B12.5 10B16 10B20 12.5B25 20B20 16B35.5 20B25 20B30 0.16 0.16 0.16 0.16 0.16 0.16 0.16 0.16 0.16 0.16 0.18 0.20 0.20 0.22 0.22 0.24 0.26 0.26 0.26 0.30 0.30 0.34 0.38 0.44 0.14 0.14 0.14 0.14 0.14 0.14 0.14 0.14 0.14 0.14 0.16 0.16 0.18 0.18 0.18 0.20 0.20 0.20 0.22 0.22 0.24 0.32 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.14 0.14 0.14 36 53 78 96 115 190 330 440 545 955 1,540 1,975 1,850 2,420 2,420 2,430 2,880 2,680 2,510 2,810 2,810 3,240 3,240 3,610 41 59 88 108 130 210 385 490 645 1,145 1,785 1,670 2,275 2,050 2,310 2,700 2,510 2,380 2,690 2,690 3,090 3,480 1.3 2.9 4.3 6.2 17 28 35 41 60 95 125 155 260 430 585 755 1,340 1,570 2,075 1,880 2,150 ESMG250ESS4R7ME11D ESMG250ESS100ME11D ESMG250ESS220ME11D ESMG250ESS330ME11D ESMG250ESS470ME11D ESMG250ESS101MF11D ESMG250ESS221MHB5D ESMG250ESS331MHB5D ESMG250ESS471MJC5S ESMG250ESS102MJ20S ESMG250ESS222MK25S ESMG250ESS332ML25S ESMG250ESS332MN20S ESMG250ESS472MLN3S ESMG250ESS472MN25S ESMG250ESS562MN30S ESMG250ESS682MMP1S ESMG250ESS682MN35S ESMG250ESS682MP30S ESMG250ESS822MN40S ESMG250ESS822MP35S ESMG250ESS103MP40S ESMG250ESS123MP40S ESMG250ESS153MQ40S ESMG350ESS4R7ME11D ESMG350ESS100ME11D ESMG350ESS220ME11D ESMG350ESS330ME11D ESMG350ESS470ME11D ESMG350ESS101MF11D ESMG350ESS221MHB5D ESMG350ESS331MJC5S ESMG350ESS471MJ16S ESMG350ESS102MK20S ESMG350ESS222ML25S ESMG350ESS222MN20S ESMG350ESS332MLP1S ESMG350ESS332MN25S ESMG350ESS392MN30S ESMG350ESS472MMP1S ESMG350ESS472MN35S ESMG350ESS472MP30S ESMG350ESS562MN40S ESMG350ESS562MP35S ESMG350ESS682MP40S ESMG350ESS103MQ40S ESMG500ESSR10ME11D ESMG500ESSR22ME11D ESMG500ESSR33ME11D ESMG500ESSR47ME11D ESMG500ESS1R0ME11D ESMG500ESS2R2ME11D ESMG500ESS3R3ME11D ESMG500ESS4R7ME11D ESMG500ESS100ME11D ESMG500ESS220ME11D ESMG500ESS330ME11D ESMG500ESS470MF11D ESMG500ESS101MHB5D ESMG500ESS221MJC5S ESMG500ESS331MJ16S ESMG500ESS471MJ20S ESMG500ESS102MK25S ESMG500ESS152MN20S ESMG500ESS222MLP1S ESMG500ESS222MN25S ESMG500ESS272MN30S SS : Enter the appropriate lead forming or taping code. (2/4) CAT. No. E1001I MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Downsized, 85C ?STANDARD RATINGS WV (Vdc) Cap (mF) 3,300 3,300 3,300 50 3,900 3,900 4,700 6,800 10 22 33 47 100 220 330 470 820 63 1,000 1,000 1,500 2,200 2,200 2,700 3,300 3,900 0.10 0.22 0.33 0.47 1.0 2.2 3.3 4.7 10 22 33 100 47 100 220 330 330 470 680 820 1,000 1,000 1,200 1,800 3.3 4.7 10 22 33 47 100 220 160 220 330 330 390 390 470 470 560 680 3.3 4.7 200 10 is not solvent resistant. Case size fDbL(mm) tane Rated ripple current (mArms/ 85c,120Hz) Part No. 18B35.5 20B35 22B30 20B40 22B35 22B40 25.4B40 5B11 5B11 6.3B11 6.3B11 10B12.5 10B16 10B20 12.5B20 20B20 16B25 20B25 20B30 20B35 22B30 20B40 22B40 25.4B40 5B11 5B11 5B11 5B11 5B11 5B11 5B11 5B11 6.3B11 8B11.5 8B11.5 10B12.5 10B20 12.5B25 12.5B25 20B20 16B25 20B30 22B30 18B40 20B35 22B40 25.4B40 6.3B11 6.3B11 10B12.5 10B20 10B20 12.5B20 12.5B25 16B31.5 20B25 18B35.5 20B30 20B35 22B30 20B40 22B35 22B40 25.4B40 6.3B11 8B11.5 10B12.5 0.16 0.16 0.16 0.16 0.16 0.18 0.22 0.09 0.09 0.09 0.09 0.09 0.09 0.09 0.09 0.09 0.09 0.09 0.09 0.11 0.11 0.11 0.13 0.13 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.15 0.20 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.20 0.20 0.20 2,500 2,420 2,420 2,590 2,590 2,960 3,360 65 100 140 170 300 490 710 900 1,370 1,300 1,600 1,850 2,330 2,190 2,640 2,810 3,100 2.1 4.7 7.0 10 21 30 40 45 75 130 180 230 370 620 760 870 1,000 1,360 1,540 1,380 1,720 1,980 2,490 40 48 94 170 205 270 430 760 730 995 920 1,160 1,160 1,340 1,340 1,470 1,570 40 55 94 ESMG500ESS332MMP1S ESMG500ESS332MN35S ESMG500ESS332MP30S ESMG500ESS392MN40S ESMG500ESS392MP35S ESMG500ESS472MP40S ESMG500ESS682MQ40S ESMG630ESS100ME11D ESMG630ESS220ME11D ESMG630ESS330MF11D ESMG630ESS470MF11D ESMG630ESS101MJC5S ESMG630ESS221MJ16S ESMG630ESS331MJ20S ESMG630ESS471MK20S ESMG630ESS821MN20S ESMG630ESS102ML25S ESMG630ESS102MN25S ESMG630ESS152MN30S ESMG630ESS222MN35S ESMG630ESS222MP30S ESMG630ESS272MN40S ESMG630ESS332MP40S ESMG630ESS392MQ40S ESMG101ESSR10ME11D ESMG101ESSR22ME11D ESMG101ESSR33ME11D ESMG101ESSR47ME11D ESMG101ESS1R0ME11D ESMG101ESS2R2ME11D ESMG101ESS3R3ME11D ESMG101ESS4R7ME11D ESMG101ESS100MF11D ESMG101ESS220MHB5D ESMG101ESS330MHB5D ESMG101ESS470MJC5S ESMG101ESS101MJ20S ESMG101ESS221MK25S ESMG101ESS331MK25S ESMG101ESS331MN20S ESMG101ESS471ML25S ESMG101ESS681MN30S ESMG101ESS821MP30S ESMG101ESS102MM40S ESMG101ESS102MN35S ESMG101ESS122MP40S ESMG101ESS182MQ40S ESMG161ESS3R3MF11D ESMG161ESS4R7MF11D ESMG161ESS100MJC5S ESMG161ESS220MJ20S ESMG161ESS330MJ20S ESMG161ESS470MK20S ESMG161ESS101MK25S ESMG161ESS221MLN3S ESMG161ESS221MN25S ESMG161ESS331MMP1S ESMG161ESS331MN30S ESMG161ESS391MN35S ESMG161ESS391MP30S ESMG161ESS471MN40S ESMG161ESS471MP35S ESMG161ESS561MP40S ESMG161ESS681MQ40S ESMG201ESS3R3MF11D ESMG201ESS4R7MHB5D ESMG201ESS100MJC5S WV (Vdc) 200 250 315 350 400 Cap (mF) Case size fDbL(mm) tane Rated ripple current (mArms/ 85c,120Hz) Part No. 22 33 47 100 100 180 220 220 270 330 330 390 390 470 560 680 2.2 3.3 4.7 10 22 33 47 82 100 100 120 180 220 220 220 270 270 330 390 47 68 82 100 120 180 180 220 270 0.47 1.0 2.2 3.3 4.7 10 22 33 47 47 68 100 100 120 220 1.0 2.2 3.3 4.7 10 22 33 33 10B20 10B20 12.5B20 16B25 20B20 20B25 18B35.5 20B30 20B30 20B35 22B30 20B40 22B30 22B40 22B40 25.4B40 6.3B11 8B11.5 8B11.5 10B16 10B20 12.5B20 12.5B25 20B20 16B31.5 20B25 20B25 20B30 18B40 20B35 22B30 20B40 22B35 22B40 25.4B40 20B20 20B25 20B25 20B30 20B30 20B40 22B35 22B40 25.4B40 6.3B11 6.3B11 8B11.5 8B11.5 10B12.5 10B20 12.5B20 16B25 16B25 20B20 20B25 18B31.5 20B30 20B35 25.4B40 6.3B11 8B11.5 10B12.5 10B16 10B20 12.5B25 16B25 20B20 0.20 0.20 0.20 0.20 0.15 0.15 0.20 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.15 0.20 0.15 0.15 0.15 0.20 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.15 0.15 0.24 0.15 0.15 0.15 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.15 170 205 270 475 460 660 810 750 830 1,070 1,070 1,190 1,160 1,350 1,430 1,620 32 46 55 105 170 230 295 420 515 490 530 680 825 780 820 880 880 1,060 1,200 310 400 440 500 550 720 720 810 920 15 22 38 46 65 115 185 275 325 310 400 530 500 560 890 22 38 54 71 115 205 275 260 ESMG201ESS220MJ20S ESMG201ESS330MJ20S ESMG201ESS470MK20S ESMG201ESS101ML25S ESMG201ESS101MN20S ESMG201ESS181MN25S ESMG201ESS221MMP1S ESMG201ESS221MN30S ESMG201ESS271MN30S ESMG201ESS331MN35S ESMG201ESS331MP30S ESMG201ESS391MN40S ESMG201ESS391MP30S ESMG201ESS471MP40S ESMG201ESS561MP40S ESMG201ESS681MQ40S ESMG251ESS2R2MF11D ESMG251ESS3R3MHB5D ESMG251ESS4R7MHB5D ESMG251ESS100MJ16S ESMG251ESS220MJ20S ESMG251ESS330MK20S ESMG251ESS470MK25S ESMG251ESS820MN20S ESMG251ESS101MLN3S ESMG251ESS101MN25S ESMG251ESS121MN25S ESMG251ESS181MN30S ESMG251ESS221MM40S ESMG251ESS221MN35S ESMG251ESS221MP30S ESMG251ESS271MN40S ESMG251ESS271MP35S ESMG251ESS331MP40S ESMG251ESS391MQ40S ESMG3B1ESS470MN20S ESMG3B1ESS680MN25S ESMG3B1ESS820MN25S ESMG3B1ESS101MN30S ESMG3B1ESS121MN30S ESMG3B1ESS181MN40S ESMG3B1ESS181MP35S ESMG3B1ESS221MP40S ESMG3B1ESS271MQ40S ESMG351ESSR47MF11D ESMG351ESS1R0MF11D ESMG351ESS2R2MHB5D ESMG351ESS3R3MHB5D ESMG351ESS4R7MJC5S ESMG351ESS100MJ20S ESMG351ESS220MK20S ESMG351ESS330ML25S ESMG351ESS470ML25S ESMG351ESS470MN20S ESMG351ESS680MN25S ESMG351ESS101MMN3S ESMG351ESS101MN30S ESMG351ESS121MN35S ESMG351ESS221MQ40S ESMG401ESS1R0MF11D ESMG401ESS2R2MHB5D ESMG401ESS3R3MJC5S ESMG401ESS4R7MJ16S ESMG401ESS100MJ20S ESMG401ESS220MK25S ESMG401ESS330ML25S ESMG401ESS330MN20S SS : Enter the appropriate lead forming or taping code. (3/4) CAT. No. E1001I MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Downsized, 85C ?STANDARD RATINGS WV (Vdc) 400 450 is not solvent resistant. Cap (mF) Case size fDbL(mm) tane Rated ripple current (mArms/ 85c,120Hz) Part No. 47 56 68 100 100 120 120 180 2.2 3.3 4.7 10 16B31.5 20B25 20B30 20B35 22B30 20B40 22B35 25.4B40 10B12.5 10B16 10B20 12.5B20 0.24 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.24 0.24 0.24 0.24 350 350 420 520 520 580 580 790 32 44 56 91 ESMG401ESS470MLN3S ESMG401ESS560MN25S ESMG401ESS680MN30S ESMG401ESS101MN35S ESMG401ESS101MP30S ESMG401ESS121MN40S ESMG401ESS121MP35S ESMG401ESS181MQ40S ESMG451ESS2R2MJC5S ESMG451ESS3R3MJ16S ESMG451ESS4R7MJ20S ESMG451ESS100MK20S WV (Vdc) Cap (mF) Case size fDbL(mm) tane Rated ripple current (mArms/ 85c,120Hz) Part No. 450 22 22 33 33 47 47 56 68 68 82 82 100 120 16B25 20B20 16B31.5 20B25 16B35.5 20B25 20B30 20B35 22B30 20B40 22B35 22B40 25.4B40 0.24 0.20 0.24 0.20 0.24 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 165 180 215 240 265 290 320 370 370 420 420 470 520 ESMG451ESS220ML25S ESMG451ESS220MN20S ESMG451ESS330MLN3S ESMG451ESS330MN25S ESMG451ESS470MLP1S ESMG451ESS470MN25S ESMG451ESS560MN30S ESMG451ESS680MN35S ESMG451ESS680MP30S ESMG451ESS820MN40S ESMG451ESS820MP35S ESMG451ESS101MP40S ESMG451ESS121MQ40S SS : Enter the appropriate lead forming or taping code. ?RATED RIPPLE CURRENT MULTIPLIERS @Frequency Multipliers (F5 to F18) Capacitance (mF) Frequency (Hz) 0.1 to 4.7 10 to 47 100 to 1,000 2,200 to (F20 to F25.4) 50 0.65 0.75 0.80 0.85 120 1.00 1.00 1.00 1.00 300 1.35 1.25 1.15 1.03 1k 1.75 1.50 1.30 1.05 10k 2.30 1.75 1.40 1.08 Frequency (Hz) Rated Voltage (Vde) 100k 2.50 1.80 1.50 1.08 6.3 to 50 63 to 100 160 to 250 315 to 450 50 0.95 0.92 0.81 0.77 120 1.00 1.00 1.00 1.00 300 1.03 1.07 1.17 1.16 1k 1.05 1.13 1.32 1.30 10k 1.08 1.19 1.45 1.41 100k 1.08 1.20 1.50 1.43 The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5C rise. When long life performance is required in actual use, the rms ripple current has to be reduced. (4/4) CAT. No. E1001I
ESMG6R3ELL153MN30S 价格&库存
很抱歉,暂时无法提供与“ESMG6R3ELL153MN30S”相匹配的价格&库存,您可以联系我们找货
