MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
Standard, Downsized, 105C
KMQ
downsized
@Downsized from KME series
@Solvent-proof type except 350 to 450Vdc
(see PRECAUTIONS AND GUIDELINES)
@Pb-free design
KMG
downsized
KME
?SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
-55 to +105C(6.3 to 100Vdc) -40 to +105C(160 to 400Vdc) -25 to +105C(450Vdc)
Rated Voltage Range
Capacitance Tolerance
Leakage Current
6.3 to 450Vdc
P20% (M)
6.3 to 100Vdc
I=0.03CV or 4MA, whichever is greater.
(at 20C, 120Hz)
160 to 450Vdc
Time After 1minute
CV
CV[1000 I=0.1CV+40 max.
CV>1000 I=0.04CV+100 max.
After 5minutes
I=0.03CV+15 max.
I=0.02CV+25 max.
(at 20C)
(at 20C after 1 minute)
Where, I : Max. leakage current (MA), C : Nominal capacitance (MF), V : Rated voltage (V)
Rated voltage (Vdc)
6.3V 10V 16V 25V 35V 50V 63V 100V 160 to 250V 350 to 400V 450V
tanE (Max.)
0.34 0.24 0.20 0.16 0.14 0.12 0.10 0.08
0.24
0.20
0.24
When nominal capacitance exceeds 1000MF, add 0.02 to the value above for each 1000MF increase.
(at 20C, 120Hz)
Rated voltage (Vdc)
Z(-25C)/Z(+20C)
6
2
2
2
2
2
3
4
5
3
6
Z(-40C)/Z(+20C)
(at 120Hz)
3
3
3
4
5
8
10
12
4
6
The following specifications shall be satisfied when the capacitors are restored to 20C after subjected to DC voltage with the rated
ripple current is applied for 1000 hours (2000 hours to meet the following two conditions 1) : 160Vdc and larger, 2) : F12.5 and larger) at 105C.
Capacitance change
[P20% of the initial value
D.F. (tanE)
[200% of the initial specified value
Leakage current
[The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20C after exposing them for 1000 hours at 105C
without voltage applied.
Rated voltage
6.3 to 100Vdc
160 to 450Vdc
Capacitance change
D.F. (tanE)
[200% of the initial specified value [200% of the initial specified value
Leakage current
[500% of the initial specified value
Dissipation Factor
(tane)
Low Temperature
Characteristics
(Max. Impedance Ratio)
Endurance
Shelf Life
?DIMENSIONS [mm]
FP0.5
FD'
Fd
Sleeve (PET)
FP0.5
@Terminal Code : E
L'
15min.
4min.
(F5 to F10)
Vent
(except F5)
(F12.5 to F18)
fD
fd
F
fD'
L'
5
0.5
2.0
6.3
0.5
2.5
10 12.5
8
0.6 0.6 0.6
3.5 5.0 5.0
FD+0.5max.
L+1.5max
16
0.8
7.5
18
0.8
7.5
Gas escape end seal
?PART NUMBERING SYSTEM
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
E KMG A A A E A A A A A M A A A N
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 0.1MF:R10,10MF:100,100MF:101)
Lead forming·taping code
Terminal code
Voltage code (ex. 6.3V:6R3,35V:350,100V:101)
Series code
Category
Please refer to "A guide to global code (radial lead type)"
(1/3)
CAT. No. E1001E
?STANDARD RATINGS
WV
(Vdc)
6.3
10
16
25
35
Cap
(mF)
Case size
fDbL(mm)
tane
Rated ripple
current
(mArms/
105c,120Hz)
Part No.
33
47
100
220
330
470
1000
2200
3300
4700
6800
10000
15000
22000
22
33
47
100
220
330
470
1000
2200
3300
4700
6800
10000
15000
10
22
33
47
100
220
330
470
1000
2200
3300
4700
6800
10000
4.7
10
22
33
47
100
220
330
470
1000
2200
3300
4700
6800
4.7
10
22
33
47
100
220
330
470
1000
2200
5B11
5B11
5B11
5B11
6.3B11
6.3B11
8B11.5
10B20
10B20
12.5B20
12.5B25
16B25
16B35.5
18B40
5B11
5B11
5B11
5B11
6.3B11
6.3B11
8B11.5
10B12.5
10B20
12.5B20
12.5B25
16B25
16B35.5
18B35.5
5B11
5B11
5B11
5B11
5B11
6.3B11
8B11.5
8B11.5
10B16
12.5B20
12.5B25
16B25
16B31.5
18B35.5
5B11
5B11
5B11
5B11
5B11
6.3B11
8B11.5
8B11.5
10B12.5
10B20
12.5B25
16B25
16B31.5
18B35.5
5B11
5B11
5B11
5B11
5B11
6.3B11
8B11.5
10B12.5
10B16
12.5B20
16B25
0.34
0.34
0.34
0.34
0.34
0.34
0.34
0.36
0.38
0.40
0.44
0.52
0.62
0.76
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.26
0.28
0.30
0.34
0.42
0.52
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.22
0.24
0.26
0.30
0.38
0.16
0.16
0.16
0.16
0.16
0.16
0.16
0.16
0.16
0.16
0.18
0.20
0.22
0.26
0.14
0.14
0.14
0.14
0.14
0.14
0.14
0.14
0.14
0.14
0.16
54
64
94
140
190
230
380
710
840
1090
1350
1650
2010
2350
46
57
68
100
170
200
250
460
760
1000
1260
1570
1890
2180
34
51
63
75
110
180
260
310
560
920
1170
1480
1780
2060
25
36
54
67
80
130
230
310
380
680
1090
1400
1710
2040
28
41
61
75
90
150
270
350
460
810
1260
EKMG6R3ESS330ME11D
EKMG6R3ESS470ME11D
EKMG6R3ESS101ME11D
EKMG6R3ESS221ME11D
EKMG6R3ESS331MF11D
EKMG6R3ESS471MF11D
EKMG6R3ESS102MHB5D
EKMG6R3ESS222MJ20S
EKMG6R3ESS332MJ20S
EKMG6R3ESS472MK20S
EKMG6R3ESS682MK25S
EKMG6R3ESS103ML25S
EKMG6R3ESS153MLP1S
EKMG6R3ESS223MM40S
EKMG100ESS220ME11D
EKMG100ESS330ME11D
EKMG100ESS470ME11D
EKMG100ESS101ME11D
EKMG100ESS221MF11D
EKMG100ESS331MF11D
EKMG100ESS471MHB5D
EKMG100ESS102MJC5S
EKMG100ESS222MJ20S
EKMG100ESS332MK20S
EKMG100ESS472MK25S
EKMG100ESS682ML25S
EKMG100ESS103MLP1S
EKMG100ESS153MMP1S
EKMG160ESS100ME11D
EKMG160ESS220ME11D
EKMG160ESS330ME11D
EKMG160ESS470ME11D
EKMG160ESS101ME11D
EKMG160ESS221MF11D
EKMG160ESS331MHB5D
EKMG160ESS471MHB5D
EKMG160ESS102MJ16S
EKMG160ESS222MK20S
EKMG160ESS332MK25S
EKMG160ESS472ML25S
EKMG160ESS682MLN3S
EKMG160ESS103MMP1S
EKMG250ESS4R7ME11D
EKMG250ESS100ME11D
EKMG250ESS220ME11D
EKMG250ESS330ME11D
EKMG250ESS470ME11D
EKMG250ESS101MF11D
EKMG250ESS221MHB5D
EKMG250ESS331MHB5D
EKMG250ESS471MJC5S
EKMG250ESS102MJ20S
EKMG250ESS222MK25S
EKMG250ESS332ML25S
EKMG250ESS472MLN3S
EKMG250ESS682MMP1S
EKMG350ESS4R7ME11D
EKMG350ESS100ME11D
EKMG350ESS220ME11D
EKMG350ESS330ME11D
EKMG350ESS470ME11D
EKMG350ESS101MF11D
EKMG350ESS221MHB5D
EKMG350ESS331MJC5S
EKMG350ESS471MJ16S
EKMG350ESS102MK20S
EKMG350ESS222ML25S
WV
(Vdc)
35
50
63
100
160
200
250
Cap
(mF)
Case size
fDbL(mm)
tane
Rated ripple
current
(mArms/
105c,120Hz)
Part No.
3300
4700
0.10
0.22
0.33
0.47
1.0
2.2
3.3
4.7
10
22
33
47
100
220
330
470
1000
2200
3300
10
22
33
47
100
220
330
470
1000
0.10
0.22
0.33
0.47
1.0
2.2
3.3
4.7
10
22
33
47
100
220
330
470
1000
3.3
4.7
10
22
33
47
100
220
330
3.3
4.7
10
22
33
47
100
220
2.2
3.3
4.7
16B35.5
18B35.5
5B11
5B11
5B11
5B11
5B11
5B11
5B11
5B11
5B11
5B11
5B11
6.3B11
8B11.5
10B12.5
10B16
10B20
12.5B25
16B35.5
18B35.5
5B11
5B11
6.3B11
6.3B11
10B12.5
10B16
10B20
12.5B20
16B25
5B11
5B11
5B11
5B11
5B11
5B11
5B11
5B11
6.3B11
8B11.5
8B11.5
10B12.5
10B20
12.5B25
16B25
16B31.5
18B40
6.3B11
6.3B11
10B12.5
10B20
10B20
12.5B20
16B25
16B31.5
18B35.5
6.3B11
8B11.5
10B16
10B20
12.5B20
12.5B20
16B25
18B35.5
6.3B11
8B11.5
8B11.5
0.18
0.20
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.14
0.16
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
1610
1910
1.3
2.9
4.3
6.2
13
30
40
65
90
110
180
300
410
530
950
1470
1770
46
71
100
120
215
335
510
640
930
1.5
3.4
5.0
7.1
15
21
29
32
54
93
130
165
265
440
540
715
985
28
34
67
120
145
195
335
540
705
28
39
74
120
160
195
335
575
23
32
39
EKMG350ESS332MLP1S
EKMG350ESS472MMP1S
EKMG500ESSR10ME11D
EKMG500ESSR22ME11D
EKMG500ESSR33ME11D
EKMG500ESSR47ME11D
EKMG500ESS1R0ME11D
EKMG500ESS2R2ME11D
EKMG500ESS3R3ME11D
EKMG500ESS4R7ME11D
EKMG500ESS100ME11D
EKMG500ESS220ME11D
EKMG500ESS330ME11D
EKMG500ESS470MF11D
EKMG500ESS101MHB5D
EKMG500ESS221MJC5S
EKMG500ESS331MJ16S
EKMG500ESS471MJ20S
EKMG500ESS102MK25S
EKMG500ESS222MLP1S
EKMG500ESS332MMP1S
EKMG630ESS100ME11D
EKMG630ESS220ME11D
EKMG630ESS330MF11D
EKMG630ESS470MF11D
EKMG630ESS101MJC5S
EKMG630ESS221MJ16S
EKMG630ESS331MJ20S
EKMG630ESS471MK20S
EKMG630ESS102ML25S
EKMG101ESSR10ME11D
EKMG101ESSR22ME11D
EKMG101ESSR33ME11D
EKMG101ESSR47ME11D
EKMG101ESS1R0ME11D
EKMG101ESS2R2ME11D
EKMG101ESS3R3ME11D
EKMG101ESS4R7ME11D
EKMG101ESS100MF11D
EKMG101ESS220MHB5D
EKMG101ESS330MHB5D
EKMG101ESS470MJC5S
EKMG101ESS101MJ20S
EKMG101ESS221MK25S
EKMG101ESS331ML25S
EKMG101ESS471MLN3S
EKMG101ESS102MM40S
EKMG161ESS3R3MF11D
EKMG161ESS4R7MF11D
EKMG161ESS100MJC5S
EKMG161ESS220MJ20S
EKMG161ESS330MJ20S
EKMG161ESS470MK20S
EKMG161ESS101ML25S
EKMG161ESS221MLN3S
EKMG161ESS331MMP1S
EKMG201ESS3R3MF11D
EKMG201ESS4R7MHB5D
EKMG201ESS100MJ16S
EKMG201ESS220MJ20S
EKMG201ESS330MK20S
EKMG201ESS470MK20S
EKMG201ESS101ML25S
EKMG201ESS221MMP1S
EKMG251ESS2R2MF11D
EKMG251ESS3R3MHB5D
EKMG251ESS4R7MHB5D
SS : Lead forming / Taping code
(2/3)
CAT. No. E1001E
?STANDARD RATINGS
Cap
(mF)
Case size
fDbL(mm)
tane
Rated ripple
current
(mArms/
105c,120Hz)
Part No.
10
22
33
47
100
220
0.47
1.0
2.2
3.3
4.7
10
22
33
47
100
10B16
12.5B20
12.5B20
12.5B25
16B31.5
18B40
6.3B11
6.3B11
8B11.5
10B12.5
10B16
10B20
12.5B20
16B25
16B25
18B31.5
0.20
0.20
0.20
0.20
0.20
0.20
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
74
130
160
210
365
585
11
15
26
38
50
80
130
195
230
375
EKMG251ESS100MJ16S
EKMG251ESS220MK20S
EKMG251ESS330MK20S
EKMG251ESS470MK25S
EKMG251ESS101MLN3S
EKMG251ESS221MM40S
EKMG351ESSR47MF11D
EKMG351ESS1R0MF11D
EKMG351ESS2R2MHB5D
EKMG351ESS3R3MJC5S
EKMG351ESS4R7MJ16S
EKMG351ESS100MJ20S
EKMG351ESS220MK20S
EKMG351ESS330ML25S
EKMG351ESS470ML25S
EKMG351ESS101MMN3S
WV
(Vdc)
250
350
is non solvent-proof.
WV
(Vdc)
400
450
Case size
fDbL(mm)
tane
Rated ripple
current
(mArms/
105c,120Hz)
Part No.
1.0
6.3B11
2.2
8B11.5
3.3
10B12.5
4.7
10B16
10
10B20
22
12.5B25
33
16B25
47
16B31.5
100
16B40
0.47
10B12.5
1.0
10B12.5
2.2
10B12.5
3.3
10B16
4.7
10B20
10
12.5B20
22
16B25
33
16B31.5
47
16B35.5
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
15
26
38
50
80
145
195
250
350
9.0
13
23
31
40
65
115
155
185
EKMG401ESS1R0MF11D
EKMG401ESS2R2MHB5D
EKMG401ESS3R3MJC5S
EKMG401ESS4R7MJ16S
EKMG401ESS100MJ20S
EKMG401ESS220MK25S
EKMG401ESS330ML25S
EKMG401ESS470MLN3S
EKMG401ESS101ML40S
EKMG451ESSR47MJC5S
EKMG451ESS1R0MJC5S
EKMG451ESS2R2MJC5S
EKMG451ESS3R3MJ16S
EKMG451ESS4R7MJ20S
EKMG451ESS100MK20S
EKMG451ESS220ML25S
EKMG451ESS330MLN3S
EKMG451ESS470MLP1S
Cap
(mF)
?RATED RIPPLE CURRENT MULTIPLIERS
@Frequency Multipliers
Capacitance (mF)
Frequency (Hz)
0.1 to 4.7
10 to 47
100 to 1,000
2,200 to
50
0.65
0.75
0.80
0.85
120
1.00
1.00
1.00
1.00
300
1.35
1.25
1.15
1.03
1k
1.75
1.50
1.30
1.05
10k
2.30
1.75
1.40
1.08
100k
2.50
1.80
1.50
1.08
(3/3)
CAT. No. E1001E
很抱歉,暂时无法提供与“EKMG350ELL332MLP1S”相匹配的价格&库存,您可以联系我们找货
