LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS
Downsized snap-ins, 105C
KMQ
@Downsized from current downsized snap-ins KMH series
@Endurance with ripple current : 105C 2000 hours
@Non solvent-proof type
@Pb-free design
downsized
KMH
?SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
-25 to +105C
Rated Voltage Range
Capacitance Tolerance
Leakage Current
160 to 450Vdc
P20% (M)
I[3 CV
Where, I : Max. leakage current (MA), C : Nominal capacitance (MF), V : Rated voltage (V)
Rated voltage (Vdc)
160 to 250V 315 to 400V 420 & 450V
tanE (Max.)
0.20
0.15
0.15
Rated voltage (Vdc)
Z(-25C)/Z(+20C)
8
8
4
Dissipation Factor
(tane)
Low Temperature
Characteristics
(Max. Impedance Ratio)
(at 20C, 120Hz)
(at 20C after 5 minutes)
(at 20C, 120Hz)
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20C after subjected to DC voltage with the rated
ripple current is applied for 2000 hours at 105C.
Capacitance change
[P20% of the initial value
D.F. (tanE)
[200% of the initial specified value
Leakage current
[The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20C after exposing them for 1000 hours at 105C
without voltage applied.
Capacitance change
[P15% of the initial value
D.F. (tanE)
[150% of the initial specified value
Leakage current
Endurance
Shelf Life
?DIMENSIONS [mm]
@Terminal Code : VS (F22 to F35) : Standard
@Terminal Code : LI (F35)
Sleeve (PET)
PC board pin-out
Negative mark
Negative mark
FD+1max.
FD+1max.
10
2-F2
4.0P0.5
LP2
Vent
PC board pin-out
2-1.2B6
4.2P0.5
Sleeve (PET)
Vent
5P0.5
LP2
4.5P1
14.2P1
No plastic disk is the standard design.
?PART NUMBERING SYSTEM
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
E KMQ A A A V S N A A A M A A A S
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 68MF:680,3300MF:332)
Dummy terminal code
Terminal code (VS, LI)
Voltage code (ex. 160V:161,315V:3B1,450V:451)
Series code
Category
Please refer to "A guide to global code (snap-in type)"
(1/3)
CAT. No. E1001E
?STANDARD RATINGS
WV
(Vdc)
160
180
200
Cap
(mF)
Case size
fDbL(mm)
tane
Rated ripple
current
(Arms/
105c,120Hz)
470
560
680
680
820
820
820
1000
1000
1000
1200
1200
1200
1500
1500
1500
1800
1800
1800
2200
2200
2700
2700
3300
390
470
560
560
680
680
820
820
820
1000
1000
1000
1000
1200
1200
1200
1500
1500
1500
1800
1800
2200
2200
2700
390
470
560
560
680
680
820
820
820
1000
1000
1000
1000
1200
1200
1200
1500
1500
1800
22 B 25
22 B 30
22 B 30
25.4 B 25
22 B 35
25.4 B 30
30 B 25
22 B 40
25.4 B 35
30 B 25
25.4 B 40
30 B 30
35 B 25
25.4 B 45
30 B 35
35 B 30
25.4 B 50
30 B 40
35 B 30
30 B 45
35 B 35
30 B 50
35 B 40
35 B 50
22 B 25
22 B 30
22 B 30
25.4 B 25
22 B 35
25.4 B 30
22 B 40
25.4 B 30
30 B 25
22 B 45
25.4 B 40
30 B 30
35 B 25
25.4 B 45
30 B 35
35 B 30
25.4 B 50
30 B 40
35 B 30
30 B 45
35 B 35
30 B 50
35 B 40
35 B 50
22 B 25
22 B 30
22 B 30
25.4 B 25
22 B 40
25.4 B 30
22 B 45
25.4 B 35
30 B 25
22 B 50
25.4 B 45
30 B 30
35 B 25
25.4 B 50
30 B 35
35 B 30
30 B 40
35 B 30
30 B 45
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
1.40
1.50
1.70
1.70
2.00
2.00
2.00
2.20
2.20
2.20
2.30
2.30
2.30
2.50
2.50
2.50
2.70
2.70
2.70
2.90
2.90
3.10
3.10
3.30
1.30
1.40
1.50
1.50
1.70
1.70
2.00
2.00
2.00
2.20
2.20
2.20
2.20
2.30
2.30
2.30
2.50
2.50
2.50
2.70
2.70
2.90
2.90
3.10
1.31
1.45
1.67
1.67
1.75
1.75
2.04
2.04
2.04
2.30
2.30
2.30
2.30
2.65
2.65
2.65
2.80
2.80
3.08
Part No.
EKMQ161VSN471MP25S
EKMQ161VSN561MP30S
EKMQ161VSN681MP30S
EKMQ161VSN681MQ25S
EKMQ161VSN821MP35S
EKMQ161VSN821MQ30S
EKMQ161VSN821MR25S
EKMQ161VSN102MP40S
EKMQ161VSN102MQ35S
EKMQ161VSN102MR25S
EKMQ161VSN122MQ40S
EKMQ161VSN122MR30S
EKMQ161VSN122MA25S
EKMQ161VSN152MQ45S
EKMQ161VSN152MR35S
EKMQ161VSN152MA30S
EKMQ161VSN182MQ50S
EKMQ161VSN182MR40S
EKMQ161VSN182MA30S
EKMQ161VSN222MR45S
EKMQ161VSN222MA35S
EKMQ161VSN272MR50S
EKMQ161VSN272MA40S
EKMQ161VSN332MA50S
EKMQ181VSN391MP25S
EKMQ181VSN471MP30S
EKMQ181VSN561MP30S
EKMQ181VSN561MQ25S
EKMQ181VSN681MP35S
EKMQ181VSN681MQ30S
EKMQ181VSN821MP40S
EKMQ181VSN821MQ30S
EKMQ181VSN821MR25S
EKMQ181VSN102MP45S
EKMQ181VSN102MQ40S
EKMQ181VSN102MR30S
EKMQ181VSN102MA25S
EKMQ181VSN122MQ45S
EKMQ181VSN122MR35S
EKMQ181VSN122MA30S
EKMQ181VSN152MQ50S
EKMQ181VSN152MR40S
EKMQ181VSN152MA30S
EKMQ181VSN182MR45S
EKMQ181VSN182MA35S
EKMQ181VSN222MR50S
EKMQ181VSN222MA40S
EKMQ181VSN272MA50S
EKMQ201VSN391MP25S
EKMQ201VSN471MP30S
EKMQ201VSN561MP30S
EKMQ201VSN561MQ25S
EKMQ201VSN681MP40S
EKMQ201VSN681MQ30S
EKMQ201VSN821MP45S
EKMQ201VSN821MQ35S
EKMQ201VSN821MR25S
EKMQ201VSN102MP50S
EKMQ201VSN102MQ45S
EKMQ201VSN102MR30S
EKMQ201VSN102MA25S
EKMQ201VSN122MQ50S
EKMQ201VSN122MR35S
EKMQ201VSN122MA30S
EKMQ201VSN152MR40S
EKMQ201VSN152MA30S
EKMQ201VSN182MR45S
WV
(Vdc)
200
250
315
350
(2/3)
Cap
(mF)
Case size
fDbL(mm)
tane
Rated ripple
current
(Arms/
105c,120Hz)
1800
2200
220
270
330
330
390
390
470
470
470
560
560
560
680
680
680
680
820
820
820
1000
1000
1200
1200
1500
1800
150
180
220
220
270
270
330
330
330
390
390
390
390
470
470
470
560
560
560
680
680
820
820
1000
120
150
180
180
220
220
270
270
270
330
330
330
390
390
470
470
35 B 40
35 B 45
22 B 25
22 B 25
22 B 30
25.4 B 25
22 B 35
25.4 B 25
22 B 40
25.4 B 30
30 B 25
22 B 45
25.4 B 35
30 B 25
22 B 50
25.4 B 40
30 B 30
35 B 25
25.4 B 45
30 B 35
35 B 30
30 B 40
35 B 30
30 B 45
35 B 35
35 B 45
35 B 50
22 B 25
22 B 30
22 B 30
25.4 B 25
22 B 35
25.4 B 30
22 B 45
25.4 B 35
30 B 25
22 B 45
25.4 B 40
30 B 30
35 B 25
25.4 B 45
30 B 35
35 B 25
25.4 B 50
30 B 40
35 B 30
30 B 45
35 B 35
30 B 50
35 B 40
35 B 45
22 B 25
22 B 30
22 B 30
25.4 B 25
22 B 35
25.4 B 30
22 B 40
25.4 B 30
30 B 25
22 B 45
25.4 B 40
30 B 30
25.4 B 45
30 B 35
25.4 B 50
30 B 35
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
3.08
3.48
1.00
1.10
1.20
1.20
1.30
1.30
1.40
1.40
1.40
1.50
1.50
1.50
1.70
1.70
1.70
1.70
2.00
2.00
2.00
2.20
2.20
2.30
2.30
2.50
2.70
0.82
0.90
1.00
1.00
1.10
1.10
1.20
1.20
1.20
1.30
1.30
1.30
1.30
1.40
1.40
1.40
1.50
1.50
1.50
1.70
1.70
2.00
2.00
2.30
0.75
0.82
0.90
0.90
1.00
1.00
1.10
1.10
1.10
1.20
1.20
1.20
1.30
1.30
1.40
1.40
Part No.
EKMQ201VSN182MA40S
EKMQ201VSN222MA45S
EKMQ251VSN221MP25S
EKMQ251VSN271MP25S
EKMQ251VSN331MP30S
EKMQ251VSN331MQ25S
EKMQ251VSN391MP35S
EKMQ251VSN391MQ25S
EKMQ251VSN471MP40S
EKMQ251VSN471MQ30S
EKMQ251VSN471MR25S
EKMQ251VSN561MP45S
EKMQ251VSN561MQ35S
EKMQ251VSN561MR25S
EKMQ251VSN681MP50S
EKMQ251VSN681MQ40S
EKMQ251VSN681MR30S
EKMQ251VSN681MA25S
EKMQ251VSN821MQ45S
EKMQ251VSN821MR35S
EKMQ251VSN821MA30S
EKMQ251VSN102MR40S
EKMQ251VSN102MA30S
EKMQ251VSN122MR45S
EKMQ251VSN122MA35S
EKMQ251VSN152MA45S
EKMQ251VSN182MA50S
EKMQ3B1VSN151MP25S
EKMQ3B1VSN181MP30S
EKMQ3B1VSN221MP30S
EKMQ3B1VSN221MQ25S
EKMQ3B1VSN271MP35S
EKMQ3B1VSN271MQ30S
EKMQ3B1VSN331MP45S
EKMQ3B1VSN331MQ35S
EKMQ3B1VSN331MR25S
EKMQ3B1VSN391MP45S
EKMQ3B1VSN391MQ40S
EKMQ3B1VSN391MR30S
EKMQ3B1VSN391MA25S
EKMQ3B1VSN471MQ45S
EKMQ3B1VSN471MR35S
EKMQ3B1VSN471MA25S
EKMQ3B1VSN561MQ50S
EKMQ3B1VSN561MR40S
EKMQ3B1VSN561MA30S
EKMQ3B1VSN681MR45S
EKMQ3B1VSN681MA35S
EKMQ3B1VSN821MR50S
EKMQ3B1VSN821MA40S
EKMQ3B1VSN102MA45S
EKMQ351VSN121MP25S
EKMQ351VSN151MP30S
EKMQ351VSN181MP30S
EKMQ351VSN181MQ25S
EKMQ351VSN221MP35S
EKMQ351VSN221MQ30S
EKMQ351VSN271MP40S
EKMQ351VSN271MQ30S
EKMQ351VSN271MR25S
EKMQ351VSN331MP45S
EKMQ351VSN331MQ40S
EKMQ351VSN331MR30S
EKMQ351VSN391MQ45S
EKMQ351VSN391MR35S
EKMQ351VSN471MQ50S
EKMQ351VSN471MR35S
CAT. No. E1001E
?STANDARD RATINGS
WV
(Vdc)
350
400
420
Cap
(mF)
Case size
fDbL(mm)
tane
Rated ripple
current
(Arms/
105c,120Hz)
470
560
560
680
680
820
100
120
150
150
180
180
220
220
220
270
270
270
270
330
330
330
390
390
390
470
470
560
560
680
82
100
100
120
120
150
150
150
180
180
180
35 B 30
30 B 45
35 B 35
30 B 50
35 B 40
35 B 45
22 B 25
22 B 30
22 B 30
25.4 B 25
22 B 35
25.4 B 30
22 B 45
25.4 B 35
30 B 25
22 B 50
25.4 B 40
30 B 30
35 B 25
25.4 B 45
30 B 35
35 B 30
25.4 B 50
30 B 40
35 B 30
30 B 45
35 B 35
30 B 50
35 B 40
35 B 45
22 B 25
22 B 25
25.4 B 25
22 B 30
25.4 B 25
22 B 35
25.4 B 30
30 B 25
22 B 40
25.4 B 30
30 B 25
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
1.40
1.50
1.50
1.70
1.70
1.90
0.70
0.75
0.88
0.88
0.95
0.95
1.10
1.10
1.10
1.22
1.22
1.22
1.22
1.44
1.44
1.44
1.55
1.55
1.55
1.68
1.68
1.90
1.90
2.12
0.64
0.66
0.66
0.81
0.81
0.84
0.84
0.84
0.91
0.91
0.91
Part No.
EKMQ351VSN471MA30S
EKMQ351VSN561MR45S
EKMQ351VSN561MA35S
EKMQ351VSN681MR50S
EKMQ351VSN681MA40S
EKMQ351VSN821MA45S
EKMQ401VSN101MP25S
EKMQ401VSN121MP30S
EKMQ401VSN151MP30S
EKMQ401VSN151MQ25S
EKMQ401VSN181MP35S
EKMQ401VSN181MQ30S
EKMQ401VSN221MP45S
EKMQ401VSN221MQ35S
EKMQ401VSN221MR25S
EKMQ401VSN271MP50S
EKMQ401VSN271MQ40S
EKMQ401VSN271MR30S
EKMQ401VSN271MA25S
EKMQ401VSN331MQ45S
EKMQ401VSN331MR35S
EKMQ401VSN331MA30S
EKMQ401VSN391MQ50S
EKMQ401VSN391MR40S
EKMQ401VSN391MA30S
EKMQ401VSN471MR45S
EKMQ401VSN471MA35S
EKMQ401VSN561MR50S
EKMQ401VSN561MA40S
EKMQ401VSN681MA45S
EKMQ421VSN820MP25S
EKMQ421VSN101MP25S
EKMQ421VSN101MQ25S
EKMQ421VSN121MP30S
EKMQ421VSN121MQ25S
EKMQ421VSN151MP35S
EKMQ421VSN151MQ30S
EKMQ421VSN151MR25S
EKMQ421VSN181MP40S
EKMQ421VSN181MQ30S
EKMQ421VSN181MR25S
WV
(Vdc)
420
450
Cap
(mF)
Case size
fDbL(mm)
tane
Rated ripple
current
(Arms/
105c,120Hz)
220
220
220
220
270
270
270
330
330
330
390
390
470
470
560
680
68
82
100
100
120
120
150
150
150
180
180
180
220
220
220
270
270
270
330
330
390
390
470
560
22 B 45
25.4 B 35
30 B 30
35 B 25
25.4 B 40
30 B 30
35 B 25
25.4 B 50
30 B 35
35 B 30
30 B 40
35 B 35
30 B 45
35 B 40
35 B 45
35 B 50
22 B 25
22 B 30
22 B 30
25.4 B 25
22 B 35
25.4 B 30
22 B 40
25.4 B 30
30 B 25
22 B 45
25.4 B 40
30 B 30
25.4 B 45
30 B 30
35 B 25
25.4 B 50
30 B 40
35 B 30
30 B 45
35 B 35
30 B 50
35 B 40
35 B 45
35 B 50
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
1.05
1.05
1.05
1.05
1.25
1.25
1.25
1.42
1.42
1.42
1.61
1.61
1.86
1.86
2.10
2.20
0.50
0.56
0.64
0.64
0.72
0.72
0.79
0.79
0.79
0.87
0.87
0.87
1.00
1.00
1.00
1.19
1.19
1.19
1.38
1.38
1.55
1.55
1.74
1.90
Part No.
EKMQ421VSN221MP45S
EKMQ421VSN221MQ35S
EKMQ421VSN221MR30S
EKMQ421VSN221MA25S
EKMQ421VSN271MQ40S
EKMQ421VSN271MR30S
EKMQ421VSN271MA25S
EKMQ421VSN331MQ50S
EKMQ421VSN331MR35S
EKMQ421VSN331MA30S
EKMQ421VSN391MR40S
EKMQ421VSN391MA35S
EKMQ421VSN471MR45S
EKMQ421VSN471MA40S
EKMQ421VSN561MA45S
EKMQ421VSN681MA50S
EKMQ451VSN680MP25S
EKMQ451VSN820MP30S
EKMQ451VSN101MP30S
EKMQ451VSN101MQ25S
EKMQ451VSN121MP35S
EKMQ451VSN121MQ30S
EKMQ451VSN151MP40S
EKMQ451VSN151MQ30S
EKMQ451VSN151MR25S
EKMQ451VSN181MP45S
EKMQ451VSN181MQ40S
EKMQ451VSN181MR30S
EKMQ451VSN221MQ45S
EKMQ451VSN221MR30S
EKMQ451VSN221MA25S
EKMQ451VSN271MQ50S
EKMQ451VSN271MR40S
EKMQ451VSN271MA30S
EKMQ451VSN331MR45S
EKMQ451VSN331MA35S
EKMQ451VSN391MR50S
EKMQ451VSN391MA40S
EKMQ451VSN471MA45S
EKMQ451VSN561MA50S
?RATED RIPPLE CURRENT MULTIPLIERS
@Frequency Multipliers
Frequency(Hz)
120
300
1k
10k
50k
160 to 250Vdc 0.81
50
1.00
1.17
1.32
1.45
1.50
315 to 450Vdc 0.77
1.00
1.16
1.30
1.41
1.43
(3/3)
CAT. No. E1001E
很抱歉,暂时无法提供与“EKMQ451VSN181MQ40S”相匹配的价格&库存,您可以联系我们找货
