EKMQ401VSN121MP30S
EKMQ401VSN121MP30S
    NCC(贵弥功)
    插件
    CAP ALUM 120UF 20% 400V SNAP
EKMQ401VSN121MP30S 数据手册
LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS Downsized snap-ins, 105C KMQ @Downsized from current downsized snap-ins KMH series @Endurance with ripple current : 105C 2000 hours @Non solvent-proof type @Pb-free design downsized KMH ?SPECIFICATIONS Items Characteristics Category Temperature Range -25 to +105C Rated Voltage Range Capacitance Tolerance Leakage Current 160 to 450Vdc P20% (M) I[3 CV Where, I : Max. leakage current (MA), C : Nominal capacitance (MF), V : Rated voltage (V) Rated voltage (Vdc) 160 to 250V 315 to 400V 420 & 450V tanE (Max.) 0.20 0.15 0.15 Rated voltage (Vdc) 160 to 250V 315 to 400V 420 & 450V Z(-25C)/Z(+20C) 8 8 4 Dissipation Factor (tane) Low Temperature Characteristics (Max. Impedance Ratio) (at 20C, 120Hz) (at 20C after 5 minutes) (at 20C, 120Hz) (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20C after subjected to DC voltage with the rated ripple current is applied for 2000 hours at 105C. Capacitance change [P20% of the initial value D.F. (tanE) [200% of the initial specified value Leakage current [The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20C after exposing them for 1000 hours at 105C without voltage applied. Capacitance change [P15% of the initial value D.F. (tanE) [150% of the initial specified value Leakage current [The initial specified value Endurance Shelf Life ?DIMENSIONS [mm] @Terminal Code : VS (F22 to F35) : Standard @Terminal Code : LI (F35) Sleeve (PET) PC board pin-out Negative mark Negative mark FD+1max. FD+1max. 10 2-F2 4.0P0.5 LP2 Vent PC board pin-out 2-1.2B6 4.2P0.5 Sleeve (PET) Vent 5P0.5 LP2 4.5P1 14.2P1 No plastic disk is the standard design. ?PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E KMQ A A A V S N A A A M A A A S Supplement code Size code Capacitance tolerance code Capacitance code (ex. 68MF:680,3300MF:332) Dummy terminal code Terminal code (VS, LI) Voltage code (ex. 160V:161,315V:3B1,450V:451) Series code Category Please refer to "A guide to global code (snap-in type)" (1/3) CAT. No. E1001E LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS Downsized snap-ins, 105C ?STANDARD RATINGS WV (Vdc) 160 180 200 Cap (mF) Case size fDbL(mm) tane Rated ripple current (Arms/ 105c,120Hz) 470 560 680 680 820 820 820 1000 1000 1000 1200 1200 1200 1500 1500 1500 1800 1800 1800 2200 2200 2700 2700 3300 390 470 560 560 680 680 820 820 820 1000 1000 1000 1000 1200 1200 1200 1500 1500 1500 1800 1800 2200 2200 2700 390 470 560 560 680 680 820 820 820 1000 1000 1000 1000 1200 1200 1200 1500 1500 1800 22 B 25 22 B 30 22 B 30 25.4 B 25 22 B 35 25.4 B 30 30 B 25 22 B 40 25.4 B 35 30 B 25 25.4 B 40 30 B 30 35 B 25 25.4 B 45 30 B 35 35 B 30 25.4 B 50 30 B 40 35 B 30 30 B 45 35 B 35 30 B 50 35 B 40 35 B 50 22 B 25 22 B 30 22 B 30 25.4 B 25 22 B 35 25.4 B 30 22 B 40 25.4 B 30 30 B 25 22 B 45 25.4 B 40 30 B 30 35 B 25 25.4 B 45 30 B 35 35 B 30 25.4 B 50 30 B 40 35 B 30 30 B 45 35 B 35 30 B 50 35 B 40 35 B 50 22 B 25 22 B 30 22 B 30 25.4 B 25 22 B 40 25.4 B 30 22 B 45 25.4 B 35 30 B 25 22 B 50 25.4 B 45 30 B 30 35 B 25 25.4 B 50 30 B 35 35 B 30 30 B 40 35 B 30 30 B 45 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 1.40 1.50 1.70 1.70 2.00 2.00 2.00 2.20 2.20 2.20 2.30 2.30 2.30 2.50 2.50 2.50 2.70 2.70 2.70 2.90 2.90 3.10 3.10 3.30 1.30 1.40 1.50 1.50 1.70 1.70 2.00 2.00 2.00 2.20 2.20 2.20 2.20 2.30 2.30 2.30 2.50 2.50 2.50 2.70 2.70 2.90 2.90 3.10 1.31 1.45 1.67 1.67 1.75 1.75 2.04 2.04 2.04 2.30 2.30 2.30 2.30 2.65 2.65 2.65 2.80 2.80 3.08 Part No. EKMQ161VSN471MP25S EKMQ161VSN561MP30S EKMQ161VSN681MP30S EKMQ161VSN681MQ25S EKMQ161VSN821MP35S EKMQ161VSN821MQ30S EKMQ161VSN821MR25S EKMQ161VSN102MP40S EKMQ161VSN102MQ35S EKMQ161VSN102MR25S EKMQ161VSN122MQ40S EKMQ161VSN122MR30S EKMQ161VSN122MA25S EKMQ161VSN152MQ45S EKMQ161VSN152MR35S EKMQ161VSN152MA30S EKMQ161VSN182MQ50S EKMQ161VSN182MR40S EKMQ161VSN182MA30S EKMQ161VSN222MR45S EKMQ161VSN222MA35S EKMQ161VSN272MR50S EKMQ161VSN272MA40S EKMQ161VSN332MA50S EKMQ181VSN391MP25S EKMQ181VSN471MP30S EKMQ181VSN561MP30S EKMQ181VSN561MQ25S EKMQ181VSN681MP35S EKMQ181VSN681MQ30S EKMQ181VSN821MP40S EKMQ181VSN821MQ30S EKMQ181VSN821MR25S EKMQ181VSN102MP45S EKMQ181VSN102MQ40S EKMQ181VSN102MR30S EKMQ181VSN102MA25S EKMQ181VSN122MQ45S EKMQ181VSN122MR35S EKMQ181VSN122MA30S EKMQ181VSN152MQ50S EKMQ181VSN152MR40S EKMQ181VSN152MA30S EKMQ181VSN182MR45S EKMQ181VSN182MA35S EKMQ181VSN222MR50S EKMQ181VSN222MA40S EKMQ181VSN272MA50S EKMQ201VSN391MP25S EKMQ201VSN471MP30S EKMQ201VSN561MP30S EKMQ201VSN561MQ25S EKMQ201VSN681MP40S EKMQ201VSN681MQ30S EKMQ201VSN821MP45S EKMQ201VSN821MQ35S EKMQ201VSN821MR25S EKMQ201VSN102MP50S EKMQ201VSN102MQ45S EKMQ201VSN102MR30S EKMQ201VSN102MA25S EKMQ201VSN122MQ50S EKMQ201VSN122MR35S EKMQ201VSN122MA30S EKMQ201VSN152MR40S EKMQ201VSN152MA30S EKMQ201VSN182MR45S WV (Vdc) 200 250 315 350 (2/3) Cap (mF) Case size fDbL(mm) tane Rated ripple current (Arms/ 105c,120Hz) 1800 2200 220 270 330 330 390 390 470 470 470 560 560 560 680 680 680 680 820 820 820 1000 1000 1200 1200 1500 1800 150 180 220 220 270 270 330 330 330 390 390 390 390 470 470 470 560 560 560 680 680 820 820 1000 120 150 180 180 220 220 270 270 270 330 330 330 390 390 470 470 35 B 40 35 B 45 22 B 25 22 B 25 22 B 30 25.4 B 25 22 B 35 25.4 B 25 22 B 40 25.4 B 30 30 B 25 22 B 45 25.4 B 35 30 B 25 22 B 50 25.4 B 40 30 B 30 35 B 25 25.4 B 45 30 B 35 35 B 30 30 B 40 35 B 30 30 B 45 35 B 35 35 B 45 35 B 50 22 B 25 22 B 30 22 B 30 25.4 B 25 22 B 35 25.4 B 30 22 B 45 25.4 B 35 30 B 25 22 B 45 25.4 B 40 30 B 30 35 B 25 25.4 B 45 30 B 35 35 B 25 25.4 B 50 30 B 40 35 B 30 30 B 45 35 B 35 30 B 50 35 B 40 35 B 45 22 B 25 22 B 30 22 B 30 25.4 B 25 22 B 35 25.4 B 30 22 B 40 25.4 B 30 30 B 25 22 B 45 25.4 B 40 30 B 30 25.4 B 45 30 B 35 25.4 B 50 30 B 35 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 3.08 3.48 1.00 1.10 1.20 1.20 1.30 1.30 1.40 1.40 1.40 1.50 1.50 1.50 1.70 1.70 1.70 1.70 2.00 2.00 2.00 2.20 2.20 2.30 2.30 2.50 2.70 0.82 0.90 1.00 1.00 1.10 1.10 1.20 1.20 1.20 1.30 1.30 1.30 1.30 1.40 1.40 1.40 1.50 1.50 1.50 1.70 1.70 2.00 2.00 2.30 0.75 0.82 0.90 0.90 1.00 1.00 1.10 1.10 1.10 1.20 1.20 1.20 1.30 1.30 1.40 1.40 Part No. EKMQ201VSN182MA40S EKMQ201VSN222MA45S EKMQ251VSN221MP25S EKMQ251VSN271MP25S EKMQ251VSN331MP30S EKMQ251VSN331MQ25S EKMQ251VSN391MP35S EKMQ251VSN391MQ25S EKMQ251VSN471MP40S EKMQ251VSN471MQ30S EKMQ251VSN471MR25S EKMQ251VSN561MP45S EKMQ251VSN561MQ35S EKMQ251VSN561MR25S EKMQ251VSN681MP50S EKMQ251VSN681MQ40S EKMQ251VSN681MR30S EKMQ251VSN681MA25S EKMQ251VSN821MQ45S EKMQ251VSN821MR35S EKMQ251VSN821MA30S EKMQ251VSN102MR40S EKMQ251VSN102MA30S EKMQ251VSN122MR45S EKMQ251VSN122MA35S EKMQ251VSN152MA45S EKMQ251VSN182MA50S EKMQ3B1VSN151MP25S EKMQ3B1VSN181MP30S EKMQ3B1VSN221MP30S EKMQ3B1VSN221MQ25S EKMQ3B1VSN271MP35S EKMQ3B1VSN271MQ30S EKMQ3B1VSN331MP45S EKMQ3B1VSN331MQ35S EKMQ3B1VSN331MR25S EKMQ3B1VSN391MP45S EKMQ3B1VSN391MQ40S EKMQ3B1VSN391MR30S EKMQ3B1VSN391MA25S EKMQ3B1VSN471MQ45S EKMQ3B1VSN471MR35S EKMQ3B1VSN471MA25S EKMQ3B1VSN561MQ50S EKMQ3B1VSN561MR40S EKMQ3B1VSN561MA30S EKMQ3B1VSN681MR45S EKMQ3B1VSN681MA35S EKMQ3B1VSN821MR50S EKMQ3B1VSN821MA40S EKMQ3B1VSN102MA45S EKMQ351VSN121MP25S EKMQ351VSN151MP30S EKMQ351VSN181MP30S EKMQ351VSN181MQ25S EKMQ351VSN221MP35S EKMQ351VSN221MQ30S EKMQ351VSN271MP40S EKMQ351VSN271MQ30S EKMQ351VSN271MR25S EKMQ351VSN331MP45S EKMQ351VSN331MQ40S EKMQ351VSN331MR30S EKMQ351VSN391MQ45S EKMQ351VSN391MR35S EKMQ351VSN471MQ50S EKMQ351VSN471MR35S CAT. No. E1001E LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS Downsized snap-ins, 105C ?STANDARD RATINGS WV (Vdc) 350 400 420 Cap (mF) Case size fDbL(mm) tane Rated ripple current (Arms/ 105c,120Hz) 470 560 560 680 680 820 100 120 150 150 180 180 220 220 220 270 270 270 270 330 330 330 390 390 390 470 470 560 560 680 82 100 100 120 120 150 150 150 180 180 180 35 B 30 30 B 45 35 B 35 30 B 50 35 B 40 35 B 45 22 B 25 22 B 30 22 B 30 25.4 B 25 22 B 35 25.4 B 30 22 B 45 25.4 B 35 30 B 25 22 B 50 25.4 B 40 30 B 30 35 B 25 25.4 B 45 30 B 35 35 B 30 25.4 B 50 30 B 40 35 B 30 30 B 45 35 B 35 30 B 50 35 B 40 35 B 45 22 B 25 22 B 25 25.4 B 25 22 B 30 25.4 B 25 22 B 35 25.4 B 30 30 B 25 22 B 40 25.4 B 30 30 B 25 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 1.40 1.50 1.50 1.70 1.70 1.90 0.70 0.75 0.88 0.88 0.95 0.95 1.10 1.10 1.10 1.22 1.22 1.22 1.22 1.44 1.44 1.44 1.55 1.55 1.55 1.68 1.68 1.90 1.90 2.12 0.64 0.66 0.66 0.81 0.81 0.84 0.84 0.84 0.91 0.91 0.91 Part No. EKMQ351VSN471MA30S EKMQ351VSN561MR45S EKMQ351VSN561MA35S EKMQ351VSN681MR50S EKMQ351VSN681MA40S EKMQ351VSN821MA45S EKMQ401VSN101MP25S EKMQ401VSN121MP30S EKMQ401VSN151MP30S EKMQ401VSN151MQ25S EKMQ401VSN181MP35S EKMQ401VSN181MQ30S EKMQ401VSN221MP45S EKMQ401VSN221MQ35S EKMQ401VSN221MR25S EKMQ401VSN271MP50S EKMQ401VSN271MQ40S EKMQ401VSN271MR30S EKMQ401VSN271MA25S EKMQ401VSN331MQ45S EKMQ401VSN331MR35S EKMQ401VSN331MA30S EKMQ401VSN391MQ50S EKMQ401VSN391MR40S EKMQ401VSN391MA30S EKMQ401VSN471MR45S EKMQ401VSN471MA35S EKMQ401VSN561MR50S EKMQ401VSN561MA40S EKMQ401VSN681MA45S EKMQ421VSN820MP25S EKMQ421VSN101MP25S EKMQ421VSN101MQ25S EKMQ421VSN121MP30S EKMQ421VSN121MQ25S EKMQ421VSN151MP35S EKMQ421VSN151MQ30S EKMQ421VSN151MR25S EKMQ421VSN181MP40S EKMQ421VSN181MQ30S EKMQ421VSN181MR25S WV (Vdc) 420 450 Cap (mF) Case size fDbL(mm) tane Rated ripple current (Arms/ 105c,120Hz) 220 220 220 220 270 270 270 330 330 330 390 390 470 470 560 680 68 82 100 100 120 120 150 150 150 180 180 180 220 220 220 270 270 270 330 330 390 390 470 560 22 B 45 25.4 B 35 30 B 30 35 B 25 25.4 B 40 30 B 30 35 B 25 25.4 B 50 30 B 35 35 B 30 30 B 40 35 B 35 30 B 45 35 B 40 35 B 45 35 B 50 22 B 25 22 B 30 22 B 30 25.4 B 25 22 B 35 25.4 B 30 22 B 40 25.4 B 30 30 B 25 22 B 45 25.4 B 40 30 B 30 25.4 B 45 30 B 30 35 B 25 25.4 B 50 30 B 40 35 B 30 30 B 45 35 B 35 30 B 50 35 B 40 35 B 45 35 B 50 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 1.05 1.05 1.05 1.05 1.25 1.25 1.25 1.42 1.42 1.42 1.61 1.61 1.86 1.86 2.10 2.20 0.50 0.56 0.64 0.64 0.72 0.72 0.79 0.79 0.79 0.87 0.87 0.87 1.00 1.00 1.00 1.19 1.19 1.19 1.38 1.38 1.55 1.55 1.74 1.90 Part No. EKMQ421VSN221MP45S EKMQ421VSN221MQ35S EKMQ421VSN221MR30S EKMQ421VSN221MA25S EKMQ421VSN271MQ40S EKMQ421VSN271MR30S EKMQ421VSN271MA25S EKMQ421VSN331MQ50S EKMQ421VSN331MR35S EKMQ421VSN331MA30S EKMQ421VSN391MR40S EKMQ421VSN391MA35S EKMQ421VSN471MR45S EKMQ421VSN471MA40S EKMQ421VSN561MA45S EKMQ421VSN681MA50S EKMQ451VSN680MP25S EKMQ451VSN820MP30S EKMQ451VSN101MP30S EKMQ451VSN101MQ25S EKMQ451VSN121MP35S EKMQ451VSN121MQ30S EKMQ451VSN151MP40S EKMQ451VSN151MQ30S EKMQ451VSN151MR25S EKMQ451VSN181MP45S EKMQ451VSN181MQ40S EKMQ451VSN181MR30S EKMQ451VSN221MQ45S EKMQ451VSN221MR30S EKMQ451VSN221MA25S EKMQ451VSN271MQ50S EKMQ451VSN271MR40S EKMQ451VSN271MA30S EKMQ451VSN331MR45S EKMQ451VSN331MA35S EKMQ451VSN391MR50S EKMQ451VSN391MA40S EKMQ451VSN471MA45S EKMQ451VSN561MA50S ?RATED RIPPLE CURRENT MULTIPLIERS @Frequency Multipliers Frequency(Hz) 120 300 1k 10k 50k 160 to 250Vdc 0.81 50 1.00 1.17 1.32 1.45 1.50 315 to 450Vdc 0.77 1.00 1.16 1.30 1.41 1.43 (3/3) CAT. No. E1001E
EKMQ401VSN121MP30S 价格&库存
很抱歉,暂时无法提供与“EKMQ401VSN121MP30S”相匹配的价格&库存,您可以联系我们找货
