EMVK6R3ADA220MD55G
EMVK6R3ADA220MD55G
    NCC(贵弥功)
    插件
    22 µF 6.3 V 铝电解电容器 径向,Can - SMD 105°C 时为 1000 小时
EMVK6R3ADA220MD55G 数据手册
SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS MVY @Endurance : 105C 1000 to 2000 hours @Suitable to fit for downsized equipment @Solvent-proof type (see PRECAUTIONS AND GUIDELINES) @Pb-free design low Z Standard, 105C MVH 125C MVK MVL MVJ longer life ?SPECIFICATIONS Items Characteristics Category Temperature Range -40 to +105C Rated Voltage Range Capacitance Tolerance Leakage Current 6.3 to 50Vdc P20% (M) (at 20C, 120Hz) I=0.01CV or 3MA, whichever is greater. Where, I : Max. leakage current (MA), C : Nominal capacitance (MF), V : Rated voltage (V) (at 20C after 2 minutes) 6.3V 10V 16V 25V 35V 50V Rated voltage (Vdc) D55 to F55 0.30 0.24 0.20 0.16 0.14 0.12 tanE (Max.) H63 to JA0 0.40 0.30 0.26 0.16 0.14 0.12 (at 20C,120Hz) 6.3V 10V 16V 25V 35V 50V Rated voltage (Vdc) 2 2 2 3 2 4 Z(-25C)/Z(+20C) 3 10 8 6 4 3 Z(-40C)/Z(+20C) (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20C after the rated voltage is applied for the specified period of time at 105C. Case code D55 to F55 H63 to JA0 Time 1000hours 2000hours Capacitance change [P30% of the initial value [P20% of the initial value D.F. (tanE) [300% of the initial specified value [200% of the initial specified value Leakage current [The initial specified value [The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20C after exposing them for the specified time at 105C without voltage applied. Case code D55 to F55 H63 to JA0 Time 500hours 1000hours Capacitance change [P25% of the initial value [P20% of the initial value D.F. (tanE) [200% of the initial specified value [200% of the initial specified value Leakage current [The initial specified value [The initial specified value Dissipation Factor (tane) Low Temperature Characteristics (Max. Impedance Ratio) Endurance Shelf Life ?DIMENSIONS [mm] ?MARKING W Size code D55 E55 F55 H63 HA0 JA0 P CP0.2 BP0.2 FDP0.5 @Terminal Code : A 0.3max. LP0.3 (Note) Note : LP0.5 for H63 to JA0 AP0.2 D 4 5 6.3 8 8 10 L A B C 5.2 4.3 4.3 5.1 5.2 5.3 5.3 5.9 5.2 6.6 6.6 7.2 6.3 8.3 8.3 9.0 10.0 8.3 8.3 9.0 10.0 10.3 10.3 11.0 W 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 0.7 to 1.1 0.7 to 1.1 P 1.0 1.4 1.9 2.3 3.1 4.5 EX) 6.3V100MF 7hK 100 6.3V ?PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E MV K AAA A DA AAA M AAA G Supplement code Size code Capacitance tolerance code Capacitance code (ex. 4.7MF:4R7,10MF:100) Taping code Terminal code Voltage code (ex. 6.3V:6R3,10V:100,50V:500) Series code Category Please refer to "A guide to global code (surface mount type)" (1/2) CAT. No. E1001E SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS Standard, 105C ?STANDARD RATINGS WV (Vdc) 6.3 10 16 25 35 Cap (mF) Case code tane Rated ripple current (mArms/ 105c,120Hz) 22 47 100 330 1000 33 100 220 10 22 47 470 33 47 100 330 4.7 D55 E55 F55 HA0 JA0 E55 H63 HA0 D55 E55 F55 JA0 F55 H63 HA0 JA0 D55 0.30 0.30 0.30 0.40 0.40 0.24 0.30 0.30 0.20 0.20 0.20 0.26 0.16 0.16 0.16 0.16 0.14 21 36 56 290 410 34 90 180 16 30 48 460 45 80 180 450 15 Part No. EMVK6R3ADA220MD55G EMVK6R3ADA470ME55G EMVK6R3ADA101MF55G EMVK6R3ADA331MHA0G EMVK6R3ADA102MJA0G EMVK100ADA330ME55G EMVK100ADA101MH63G EMVK100ADA221MHA0G EMVK160ADA100MD55G EMVK160ADA220ME55G EMVK160ADA470MF55G EMVK160ADA471MJA0G EMVK250ADA330MF55G EMVK250ADA470MH63G EMVK250ADA101MHA0G EMVK250ADA331MJA0G EMVK350ADA4R7MD55G WV (Vdc) 35 50 (2/2) Cap (mF) Case code tane Rated ripple current (mArms/ 105c,120Hz) 10 22 33 220 0.10 0.22 0.33 0.47 1.0 2.2 3.3 4.7 10 22 33 47 100 E55 F55 H63 JA0 D55 D55 D55 D55 D55 D55 D55 E55 F55 H63 HA0 HA0 JA0 0.14 0.14 0.14 0.14 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 25 40 80 375 1.3 2.6 3.2 3.8 5.6 10 14 19 29 70 140 170 310 Part No. EMVK350ADA100ME55G EMVK350ADA220MF55G EMVK350ADA330MH63G EMVK350ADA221MJA0G EMVK500ADAR10MD55G EMVK500ADAR22MD55G EMVK500ADAR33MD55G EMVK500ADAR47MD55G EMVK500ADA1R0MD55G EMVK500ADA2R2MD55G EMVK500ADA3R3MD55G EMVK500ADA4R7ME55G EMVK500ADA100MF55G EMVK500ADA220MH63G EMVK500ADA330MHA0G EMVK500ADA470MHA0G EMVK500ADA101MJA0G CAT. No. E1001E
EMVK6R3ADA220MD55G
物料型号:Alchip MVK系列
器件简介:这些电容器设计用于105°C的高温环境,具有1000至2000小时的耐久性,适合小型化设备,并且是无铅设计。
引脚分配:文档中未明确提供引脚分配信息。
参数特性: - 额定电压范围:6.3至50V - 电容公差:±20%(在20°C,120Hz时) - 漏电流:0.01CV或3μA,取较大者 - 耗散因子(tanδ):随额定电压不同而变化,例如6.3V时为0.30,50V时为0.12 - 低温特性:在-25°C和-40°C时的最大阻抗比
功能详解:文档提供了电容器的耐久性、储存寿命和尺寸信息。
应用信息:适用于需要高温耐受性和小型化设计的电子设备。
封装信息:提供了不同尺寸代码的详细物理尺寸,包括D55至JAO。
EMVK6R3ADA220MD55G 价格&库存
很抱歉,暂时无法提供与“EMVK6R3ADA220MD55G”相匹配的价格&库存,您可以联系我们找货
