ELXR451LGC562MFF5M
ELXR451LGC562MFF5M
    NCC(贵弥功)
    插件
    5600 µF 450 V 铝电解电容器 径向,Can - 螺丝端子 105°C 时为 5000 小时
ELXR451LGC562MFF5M 数据手册
LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS Inverter-use screw terminals ,105℃ LXR LXR Series Higher ripple ・Higher ripple capability than LXA series ・Endurance with ripple current : 5,000 hours at 105℃ ・RoHS Compliant LXA P294 ◆SPECIFICATIONS Items Characteristics Category Temperature Range -25 to +105℃ Rated Voltage Range Capacitance Tolerance Leakage Current 350 to 450Vdc ±20% (M) I=0.02CV or 5mA, whichever is smaller. Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) Dissipation Factor (tanδ) 0.15max. Low Temperature Characteristics Capacitance change (at 20℃, 120Hz) (at 20℃ after 5 minutes) (at 20℃, 120Hz) C (-25℃)/C(+20℃)≧0.7 (at 120Hz) When measured between the terminals that are connected to each other and to the mounting clamp on the insulating sleeve covering the case by using an insulation resistance meter of 500Vdc, the insulation resistance shall not be less than than 100MΩ. When a voltage of 2,000Vac is applied for 1 minute between the terminals that are connected to each other and to the mounting clamp on the insulating sleeve covering the case, there shall not be electrical damage. The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for 5,000 hours at 105℃ . Capacitance change ≦±20% of the initial value ≦200% of the initial specified value D.F. (tanδ) Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value Insulation Resistance Insulation Withstanding Voltage Endurance Shelf Life ◆DIMENSIONS (Screw-Mount) [mm] Clamp Code : B ●Mounting Clamp Code : C 360° 3 A±1 W±1 4.5 B±1 φD+1.8max. F±1 Sleeve (Pb-free PVC : Brown) 6 30°±5° Vent 45°±5° 8 J G±1 L+4max. Plastic disk φD 63.5 76.2 φ63.5 & φ76.2 : G=6 φ89 : G=4 φ100 : G=10 toφ89 Plus hexagon-headed screw :M5×0.8×10 Maximum screw tightening torque :3.23Nm A 90 104.5 B 76 90 W F 80 28.0 93.5 31.5 φD 63.5 76.2 89 100 E 38.1 44.5 50.8 56.5 4.5 ●Mounting Code : LG K±1 E±1 ●Terminal K 43.5 50.0 56.5 63.4 F 28.0 31.5 31.5 41.5 J 14.0 14.0 16.0 18.0 Cross-recessed head (Phillips) screw : M8×1.25×16 Spring washer,Washer Maximum screw tightening torque :6.31Nm * The screw and the mounting clamp are separately supplied and not attached to the product. φ100 ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E L XR AAA LG N AAA M AAA M Supplement code Size code Capacitance tolerance code Capacitance code (ex. 3,300µF:332, 10,000µF:103) Mounting clamp code (N, B, C) Terminal code Voltage code (ex. 350V:351,400V:401) Series code Category Please refer to "Product code guide (screw-mount terminal type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 298 CAT. No. E1001N LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS Inverter-use screw terminals ,105℃ LXRSeries ◆STANDARD RATINGS WV (Vdc) 350 400 Cap (µF) Case size φD×L(mm) tanδ Rated ripple current (Arms/ 105℃,120Hz) 3,300 3,900 4,700 4,700 5,600 5,600 6,800 8,200 8,200 10,000 12,000 15,000 2,700 3,300 3,900 3,900 4,700 4,700 5,600 63.5×115 63.5×130 63.5×155 76.2×115 63.5×170 76.2×130 76.2×155 76.2×170 89×155 89×170 100×190 100×250 63.5×115 63.5×130 63.5×155 76.2×115 63.5×170 76.2×130 76.2×155 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 14.4 16.6 19.8 19.1 22.5 21.9 26.2 30.0 29.2 33.7 37.8 47.7 13.1 15.2 17.9 18.2 20.5 20.1 23.8 Part No. ELXR351LGC332MDB5M ELXR351LGC392MDD0M ELXR351LGC472MDF5M ELXR351LGC472MEB5M ELXR351LGC562MDH0M ELXR351LGC562MED0M ELXR351LGC682MEF5M ELXR351LGC822MEH0M ELXR351LGC822MFF5M ELXR351LGC103MFH0M ELXR351LGC123MGK0M ELXR351LGC153MGR0M ELXR401LGC272MDB5M ELXR401LGC332MDD0M ELXR401LGC392MDF5M ELXR401LGC392MEB5M ELXR401LGC472MDH0M ELXR401LGC472MED0M ELXR401LGC562MEF5M WV (Vdc) 400 450 Cap (µF) Case size φD×L(mm) tanδ Rated ripple current (Arms/ 105℃,120Hz) 6,800 6,800 8,200 10,000 12,000 2,200 2,700 2,700 3,300 3,300 3,900 4,700 5,600 5,600 6,800 8,200 10,000 12,000 76.2×170 89×155 89×170 100×190 100×220 63.5×115 63.5×130 76.2×115 63.5×155 76.2×130 63.5×170 76.2×155 76.2×190 89×155 89×170 89×190 100×220 100×250 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 27.3 26.6 30.5 34.5 40.2 11.8 13.7 14.5 16.5 16.9 18.7 21.7 26.1 24.1 27.8 32.0 36.8 42.7 Part No. ELXR401LGC682MEH0M ELXR401LGC682MFF5M ELXR401LGC822MFH0M ELXR401LGC103MGK0M ELXR401LGC123MGN0M ELXR451LGC222MDB5M ELXR451LGC272MDD0M ELXR451LGC272MEB5M ELXR451LGC332MDF5M ELXR451LGC332MED0M ELXR451LGC392MDH0M ELXR451LGC472MEF5M ELXR451LGC562MEK0M ELXR451LGC562MFF5M ELXR451LGC682MFH0M ELXR451LGC822MFK0M ELXR451LGC103MGN0M ELXR451LGC123MGR0M ◆RATED RIPPLE CURRENT MULTIPLIERS ●Frequency Multipliers Frequency (Hz) Coefficient 120 1.0 300 1.1 1k 1.3 3k 1.4 The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5 to 10℃ rise. When long life performance is required in actual use, the rms ripple current has to be reduced. Also, for the LXR series capacitors, using them at operating voltage less than their rated voltage can extend their lifetime. For details, please contact a representative of Nippon Chemi-Con. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 299 CAT. No. E1001N
ELXR451LGC562MFF5M 价格&库存
很抱歉,暂时无法提供与“ELXR451LGC562MFF5M”相匹配的价格&库存,您可以联系我们找货
