E32D251CDS103MEE3M
E32D251CDS103MEE3M
    NCC(贵弥功)
    插件
    10000 µF 250 V 铝电解电容器 径向,Can - 螺丝端子 105°C 时为 2000 小时
E32D251CDS103MEE3M 数据手册
UNITED CHEMI-CON TECHNICAL DATA SHEET UN ITED CH EMI- CON CUSTOMER: CUSTOMER PN: GPN: DRAWING NO.: DIMENSIONAL CRITERIA X mm in E32D251CDS103MEE3M 568460 ELECTRICAL CRITERIA CAPACITANCE (120Hz/25°C): CAPACITANCE TOLERANCE: RATED VDC SURGE VDC (30 sec): MAX. ESR (120Hz/25°C): MAX. IRMS (120Hz/105°C): MAX. DCL (VDC/5:00/25°C): 10000 ± 20 250 300 18.2 17.0 5.000 D L H F J S T P mF % V V mW A mA 76.2 143.0 147.0 31.8 5.0 13.0 17.5 16.0 - 2.00 1.00 1.00 0.25 0.50 0.25 0.25 1.00 MARKING NI PP ON CHEM I-C ON MECHANICAL CRITERIA MAX. VIBRATION: TERMINAL THREAD THREAD DEPTH MAX. TERMINAL TORQUE: 10-55Hz 10 g M5 8.5 mm 2.8 Nm OPERATING CRITERIA MAX. TEMPERATURE: MIN. TEMPERATURE: LOAD LIFE (VDC+IRMS/105°C): MAX. D CAP. (measured value): MAX. ESR (specified value): MAX. DCL (VDC/5:00/25°C): SHELF LIFE (105°C): MAX. D CAP. (measured value): MAX. ESR (specified value): MAX. DCL (VDC/5:00/25°C): +105 -40 2000 ± 20  200 5.000 500 ± 20  200 5.000 IRMS FREQUENCY MULTIPLIERS VDC 50Hz 120Hz 300Hz 6.3-50 0.95 1.00 1.03 63-80 0.90 1.00 1.06 100-250 0.80 1.00 1.12 315-500 0.80 1.00 1.19 1kHz 1.05 1.10 1.22 1.34 IRMS AMBIENT MULTIPLIERS 55°C 65°C 75°C 85°C 2.65 2.45 2.00 1.73 105°C 1.00 10kHz 1.09 1.18 1.30 1.46 °C °C Hrs % % mA Hrs % % mA U32D 105°C 250V 10000uF Date Code + positive M5 50kHz 1.12 1.22 1.33 1.52 COMMENTS RoHS Compliant Dielectric strength of insulation  2000 volts Insulation resistance 100 megohms TDS NO.: AUTHOR: DATE: ISSUE: 6 DATE: 12/16/09 TDS-12-0095-02 TMASH 15-MAY-2012 + + + + + + + + 2.00 1.00 2.50 0.25 0.50 0.25 0.25 1.00
E32D251CDS103MEE3M 价格&库存
很抱歉,暂时无法提供与“E32D251CDS103MEE3M”相匹配的价格&库存,您可以联系我们找货
