KMM SERIES
Engineering Bulletin Mar 07
KMM Series
The KMM series is a high voltage, long life snap-in capacitor series that offers downsized versions
of the KMH series. The KMM capacitors have smaller case sizes and an extended rated lifetime
compared to the KMH capacitors. These characteristics plus high ripple current capability make
the KMM capacitors ideal for use in power supply filter circuits. The KMM capacitors are available
in 2 or 4-pin snap-in styles and 4 -pin straight terminals. The KMM series capacitors are RoHS
compliant offering Pb-free construction.
The standard KMM series capacitors are not solvent proof. Refer to guidelines and precautions on
the website for usage and installation conditions recommended for United Chemi-Con products.
Summary of Specifications
PC board 2 or 4-pin snap-in; optional 4-pin straight terminals.
Capacitance range: 39 to 3,300µF.
Voltage range: 160 to 450VDC.
Category temperature range: 25C to 105C.
Leakage current: 3 CV (µA) maximum after 5 minutes at 20C.
Standard capacitance tolerance: 20%
Nominal case size (DL): 2020mm to 3560mm.
Rated lifetime: 2,000 to 3,000 hours at 105C with the rated ripple current applied,
depending on case size.
United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com
1/ 12
KMM
SNAP MOUNT 105C
Snap Mount
Downsize
High Voltage
High Ripple
RoHS
Compliant
105C
Maximum
Temperature
KMM Series
KMM Specifications - Snap Mount
Item
Characteristics
Category Temperature Range
25 to 105C
Rated Voltage Range
160 to 450VDC
Capacitance Range
39 to 3,300F
Capacitance Tolerance
20% ( M ) at 20C, 120Hz
Leakage Current
I ≤ 3 CV (A ) after 5 minutes at 20C.
Where I = Max. leakage current (A ), C = Nominal capacitance (F ) and V = Rated voltage ( V )
Dissipation Factor ( Tan )
At 20C, 120Hz
Rated Voltage ( V )
160 - 400
420 - 450
0.15
0.20
Tan ( DF ) Max.
Low Temperature
Characteristics
At 120Hz, impedance ( Z ) ratio between the 25C value and 20C value shall not exceed
the values given below.
Rated Voltage ( V )
160 - 400
420 - 450
4
8
Z (25C ) / Z (20C )
Rated Ripple Current Multipliers
Ambient Temperature (C )
45C
60C
70C
85C
105C
2.64
2.23
2.12
1.73
1.00
KMM
SNAP MOUNT 105C
Frequency (Hz )
Endurance
(Load Life)
DC Rated Voltage
50Hz
120Hz
300Hz
1kHz
10kHz
50kHz
160 - 250V
0.81
1.00
1.17
1.32
1.45
1.50
315 - 450V
0.77
1.00
1.16
1.30
1.41
1.43
The following specifications shall be satisfied when the capacitors are restored to 20C
after subjecting them to DC voltage for the specified test time at 105C with the rated ripple
current applied. The sum of the DC voltage and peak AC voltage must not exceed the full
rated voltage of the capacitors.
Case Diameter
Test Time
Ø 20mm
Ø 22mm & Above
2,000 Hours
3,000 Hours
Capacitance change: ≤ 20% of initial measured value
Tan ( DF )
: ≤ 200% of initial specified value
Leakage current
: ≤ initial specified value
Shelf Life
The following specifications shall be satisfied when the capacitors are restored to 20C after
exposing them for 1,000 hours at 105C without voltage applied. The rated voltage shall be
applied to the capacitors for a minimum of 30 minutes, at least 24 hours and not more than
48 hours before the measurements.
Capacitance change: ≤ 15% of initial measured value
Tan ( DF )
: ≤ 150% of initial specified value
Leakage current
2 / 12
KMM Series
Diagram of Dimensions - Snap Mount
Unit: mm
Snap Mount
Types VSN Ø 20~ Ø 35; VNN Ø 22~ Ø 35
See
Pin
Detail
Pb-free PVC Sleeve
Type VRD Ø 35
See
Pin
Detail
Pb-free PVC Sleeve
PC board pin-out
C*
A*
D 1
PC board pin-out
B
30°
D35 1
10
2-2x
** Vent
** Vent
L2
Type VND Ø 35
2-4x
L2
Type VQD Ø 35
See
Pin
Detail
Pb-free PVC Sleeve
PC board pin-out
B
See
Pin
Detail
Pb-free PVC Sleeve
C*
A*
22.5
2-4x
L2
30°
W1
Edge
of can
W1
W
W
P
Edge
of can
Edge
of can
P1
W
W
W1
W2
1.50.2
1.0
1.0
Type
Straight Pin (VR)
Standoff Pin (VQ)
P
5.501.0
3.751.0
P1
2.0 max.
W
W1
1.50.1
0.7
CAUTION:
* Use the blank terminals for mechanical support only. The blank terminals must not be connected to a solder trace on the
PC board, but be electrically isolated from the negative or positive terminal.
** Vent may be located either on the bottom or side of the can.
3 / 12
KMM
VQ Standoff Pin
W1
P
P
4.00.5
3.50.5
5.81.0
5.81.0
SNAP MOUNT 105C
VR & VQ Pin Dimensions
P
Type
VSN Ø 20 - Ø 30
VSN Ø 35
VNN Ø 22 - Ø 35
VND Ø 35
22.5
2-4x
L2
VR Straight Pin
W2
C*
D35 1
** Vent
VS & VN Pin Dimensions
PC board pin-out
B
A*
30°
D35 1
** Vent
22.5
KMM Series
Part Numbering System for KMM Series
When ordering, always specify complete 18-field global part number.
18 Fields
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15 16
17
18
E K MM 4 5 1 V S N 3 3 1 M A 4 0 T
9
8
KMM
SNAP MOUNT 105C
7
6
5
4
3
2
1
4 / 12
Supplement Code. Field 18.
All construction options listed have Sn100% terminal plating.
S = PET sleeve without end disk.
W = PET sleeve with end disk.
M = Pb-free PVC sleeve without end disk.
T = Pb-free PVC sleeve with end disk.
Case Size. Fields 15, 16 and 17.
The single letter diameter code is inserted in field 15.
N = Ø 20mm
P = Ø 22mm
Q = Ø 25.4mm
R = Ø 30mm
A = Ø 35mm
The double digit length code is inserted in fields 16 and 17.
20 = 20mm
25 = 25mm
30 = 30mm
35 = 35mm
40 = 40mm
45 = 45mm
50 = 50mm
60 = 60mm
Capacitance Tolerance. Field 14.
M = 20%
Capacitance. Fields 11, 12 and 13.
Expressed in Microfarads. The first two digits are significant
figures inserted in fields 11 and 12, and the third digit inserted
in field 13 indicates the number of zeros for capacitance of
10F or more. R indicates the decimal point for capacitance
less than 10F (e.g. 3R3 = 3.3F; 330 = 33F; 331 = 330F;
332 = 3,300F; 333 = 33,000F ).
Dummy Terminals. Field 10.
N = No dummy terminals.
D = 2 dummy terminals.
Terminal Type. Fields 8 and 9.
VS = Snap-in pins, 4.0mm in length, 3.5mm for Ø35 only.
VN = Snap-in pins, 5.8mm in length.
VR = Straight pins.
VQ = Straight standoff pins.
DC Rated Voltage. Fields 5, 6 and 7.
Expressed in Volts. The first two digits are significant figures
inserted in fields 5 and 6, and the third digit inserted in field 7
indicates the number of zeros for rated voltage of 10VDC or
more. R indicates the decimal point for rated voltage less than
10VDC (e.g. 4R5 = 4.5VDC; 450 = 45VDC; 451 = 450VDC).
Rule Exception: Coding for rated voltage 315VDC = 3B1.
Series Name. Fields 2, 3 and 4.
Enter the 3-letter/digit series name in fields 2, 3 and 4. If the
series name is only 2 letters/digits, place a dash in field 4.
For a series name with more than 3 letters/digits, refer to the
individual series for the appropriate 3-field series name.
Capacitor Type. Field 1.
Aluminum Electrolytic Capacitor (Polar).
KMM Series
Standard Voltage Ratings - Snap Mount
Rated
Voltage
(WVDC)
Nominal
Case Size*
DL ( mm )
Case
Size
Code
Maximum ESR
( Ω ) at
20C, 120Hz
Rated
Ripple Current
(A rms) at
105C, 120Hz
180
220
270
330
390
470
560
680
220
330
390
470
560
680
820
1,000
270
330
390
470
560
680
820
1,000
1,200
1,500
390
470
560
680
820
1,000
1,200
1,500
1,800
2,200
560
680
820
1,000
1,200
1,500
1,800
2,200
2,700
3,300
EKMM161VSN181MN20T
EKMM161VSN221MN25T
EKMM161VSN271MN25T
EKMM161VSN331MN30T
EKMM161VSN391MN30T
EKMM161VSN471MN35T
EKMM161VSN561MN40T
EKMM161VSN681MN45T
EKMM161VSN221MP20T
EKMM161VSN331MP25T
EKMM161VSN391MP30T
EKMM161VSN471MP30T
EKMM161VSN561MP35T
EKMM161VSN681MP40T
EKMM161VSN821MP45T
EKMM161VSN102MP50T
EKMM161VSN271MQ20T
EKMM161VSN331MQ20T
EKMM161VSN391MQ25T
EKMM161VSN471MQ25T
EKMM161VSN561MQ30T
EKMM161VSN681MQ30T
EKMM161VSN821MQ35T
EKMM161VSN102MQ40T
EKMM161VSN122MQ45T
EKMM161VSN152MQ60T
EKMM161VSN391MR20T
EKMM161VSN471MR20T
EKMM161VSN561MR25T
EKMM161VSN681MR25T
EKMM161VSN821MR30T
EKMM161VSN102MR30T
EKMM161VSN122MR35T
EKMM161VSN152MR40T
EKMM161VSN182MR45T
EKMM161VSN222MR60T
EKMM161VSN561MA20T
EKMM161VSN681MA20T
EKMM161VSN821MA25T
EKMM161VSN102MA25T
EKMM161VSN122MA30T
EKMM161VSN152MA35T
EKMM161VSN182MA35T
EKMM161VSN222MA45T
EKMM161VSN272MA50T
EKMM161VSN332MA60T
20 20
20 25
20 25
20 30
20 30
20 35
20 40
20 45
22 20
22 25
22 30
22 30
22 35
22 40
22 45
22 50
25.4 20
25.4 20
25.4 25
25.4 25
25.4 30
25.4 30
25.4 35
25.4 40
25.4 45
25.4 60
30 20
30 20
30 25
30 25
30 30
30 30
30 35
30 40
30 45
30 60
35 20
35 20
35 25
35 25
35 30
35 35
35 35
35 45
35 50
35 60
N20
N25
N25
N30
N30
N35
N40
N45
P20
P25
P30
P30
P35
P40
P45
P50
Q20
Q20
Q25
Q25
Q30
Q30
Q35
Q40
Q45
Q60
R20
R20
R25
R25
R30
R30
R35
R40
R45
R60
A20
A20
A25
A25
A30
A35
A35
A45
A50
A60
1.381
1.13
0.921
0.753
0.638
0.529
0.444
0.366
1.13
0.753
0.638
0.529
0.444
0.366
0.303
0.249
0.921
0.753
0.638
0.529
0.444
0.366
0.303
0.249
0.207
0.166
0.638
0.529
0.444
0.366
0.303
0.249
0.207
0.166
0.138
0.113
0.444
0.366
0.303
0.249
0.207
0.166
0.138
0.113
0.092
0.075
0.68
0.85
1.1
1.2
1.3
1.34
1.5
1.7
0.81
1.2
1.3
1.55
1.67
1.82
2.04
2.25
0.98
1.02
1.26
1.55
1.67
1.82
2.04
2.25
2.49
2.97
1.25
1.3
1.67
1.82
2.04
2.25
2.49
2.84
3.32
3.86
1.46
1.51
2.04
2.25
2.49
2.84
3.0
3.5
4.0
4.63
150
180
220
270
330
390
470
560
680
180
270
330
EKMM181VSN151MP20T
EKMM181VSN181MN25T
EKMM181VSN221MN25T
EKMM181VSN271MN30T
EKMM181VSN331MN30T
EKMM181VSN391MN35T
EKMM181VSN471MN40T
EKMM181VSN561MN45T
EKMM181VSN681MN50T
EKMM181VSN181MP20T
EKMM181VSN271MP25T
EKMM181VSN331MP30T
20 20
20 25
20 25
20 30
20 30
20 35
20 40
20 45
20 50
22 20
22 25
22 30
N20
N25
N25
N30
N30
N35
N40
N45
N50
P20
P25
P30
1.658
1.381
1.13
0.921
0.753
0.638
0.529
0.444
0.366
1.381
0.921
0.753
0.62
0.77
1.0
1.1
1.2
1.3
1.4
1.55
1.75
0.8
1.0
1.2
† For terminal and construction options, refer to the part numbering system for descriptions and codes.
* Refer to diagram of dimensions for detailed case size specifications.
5 / 12
KMM
180 Volts
225 Volts Surge
Global
Part Number†
SNAP MOUNT 105C
160 Volts
200 Volts Surge
Capacitance
(µF )
KMM Series
Rated
Voltage
(WVDC)
180 Volts
KMM
SNAP MOUNT 105C
225 Volts Surge
200 Volts
250 Volts Surge
Capacitance
(µF )
Global
Part Number†
Nominal
Case Size*
DL ( mm )
Case
Size
Code
Maximum ESR
( Ω ) at
20C, 120Hz
Rated
Ripple Current
(A rms) at
105C, 120Hz
390
470
560
680
820
220
270
330
390
470
560
680
820
1,000
1,200
330
390
470
560
680
820
1,000
1,200
1,500
1,800
470
560
680
820
1,000
1,200
1,500
1,800
2,200
2,700
EKMM181VSN391MP30T
EKMM181VSN471MP35T
EKMM181VSN561MP40T
EKMM181VSN681MP45T
EKMM181VSN821MP50T
EKMM181VSN221MQ20T
EKMM181VSN271MQ20T
EKMM181VSN331MQ25T
EKMM181VSN391MQ25T
EKMM181VSN471MQ30T
EKMM181VSN561MQ30T
EKMM181VSN681MQ35T
EKMM181VSN821MQ40T
EKMM181VSN102MQ45T
EKMM181VSN122MQ50T
EKMM181VSN331MR20T
EKMM181VSN391MR20T
EKMM181VSN471MR25T
EKMM181VSN561MR25T
EKMM181VSN681MR30T
EKMM181VSN821MR30T
EKMM181VSN102MR35T
EKMM181VSN122MR40T
EKMM181VSN152MR45T
EKMM181VSN182MR60T
EKMM181VSN471MA20T
EKMM181VSN561MA20T
EKMM181VSN681MA25T
EKMM181VSN821MA25T
EKMM181VSN102MA30T
EKMM181VSN122MA30T
EKMM181VSN152MA35T
EKMM181VSN182MA40T
EKMM181VSN222MA50T
EKMM181VSN272MA60T
22 30
22 35
22 40
22 45
22 50
25.4 20
25.4 20
25.4 25
25.4 25
25.4 30
25.4 30
25.4 35
25.4 40
25.4 45
25.4 50
30 20
30 20
30 25
30 25
30 30
30 30
30 35
30 40
30 45
30 60
35 20
35 20
35 25
35 25
35 30
35 30
35 35
35 40
35 50
35 60
P30
P35
P40
P45
P50
Q20
Q20
Q25
Q25
Q30
Q30
Q35
Q40
Q45
Q50
R20
R20
R25
R25
R30
R30
R35
R40
R45
R60
A20
A20
A25
A25
A30
A30
A35
A40
A50
A60
0.638
0.529
0.444
0.366
0.303
1.13
0.921
0.753
0.638
0.529
0.444
0.366
0.303
0.249
0.207
0.753
0.638
0.529
0.444
0.366
0.303
0.249
0.207
0.166
0.138
0.529
0.444
0.366
0.303
0.249
0.207
0.166
0.138
0.113
0.092
1.35
1.5
1.67
1.78
2.04
0.9
0.95
1.16
1.35
1.5
1.67
1.78
2.04
2.3
2.55
1.15
1.2
1.5
1.67
1.78
2.04
2.3
2.55
2.9
3.49
1.36
1.43
1.83
2.04
2.3
2.55
2.9
3.3
3.65
4.19
120
150
180
220
270
330
390
470
560
150
180
270
330
390
470
560
680
220
330
390
470
560
680
EKMM201VSN121MN20T
EKMM201VSN151MN25T
EKMM201VSN181MN25T
EKMM201VSN221MN25T
EKMM201VSN271MN30T
EKMM201VSN331MN35T
EKMM201VSN391MN40T
EKMM201VSN471MN45T
EKMM201VSN561MN50T
EKMM201VSN151MP20T
EKMM201VSN181MP20T
EKMM201VSN271MP25T
EKMM201VSN331MP30T
EKMM201VSN391MP30T
EKMM201VSN471MP35T
EKMM201VSN561MP40T
EKMM201VSN681MP45T
EKMM201VSN221MQ20T
EKMM201VSN331MQ25T
EKMM201VSN391MQ25T
EKMM201VSN471MQ30T
EKMM201VSN561MQ35T
EKMM201VSN681MQ40T
20 20
20 25
20 25
20 25
20 30
20 35
20 40
20 45
20 50
22 20
22 20
22 25
22 30
22 30
22 35
22 40
22 45
25.4 20
25.4 25
25.4 25
25.4 30
25.4 35
25.4 40
N20
N25
N25
N25
N30
N35
N40
N45
N50
P20
P20
P25
P30
P30
P35
P40
P45
Q20
Q25
Q25
Q30
Q35
Q40
2.072
1.658
1.381
1.13
0.921
0.753
0.638
0.529
0.444
1.658
1.381
0.921
0.753
0.638
0.529
0.444
0.366
1.13
0.753
0.638
0.529
0.444
0.366
0.56
0.71
0.77
1.0
1.1
1.2
1.31
1.45
1.58
0.73
0.8
1.1
1.25
1.35
1.5
1.67
1.78
0.85
1.25
1.35
1.5
1.67
1.78
6 / 12
KMM Series
Rated
Voltage
(WVDC)
200 Volts
250 Volts Surge
Global
Part Number†
Nominal
Case Size*
DL ( mm )
Case
Size
Code
Maximum ESR
( Ω ) at
20C, 120Hz
Rated
Ripple Current
(A rms) at
105C, 120Hz
EKMM201VSN821MQ45T
EKMM201VSN102MQ50T
EKMM201VSN122MQ60T
EKMM201VSN271MR20T
EKMM201VSN331MR20T
EKMM201VSN471MR25T
EKMM201VSN561MR25T
EKMM201VSN681MR30T
EKMM201VSN821MR35T
EKMM201VSN102MR40T
EKMM201VSN122MR45T
EKMM201VSN152MR50T
EKMM201VSN182MR60T
EKMM201VSN391MA20T
EKMM201VSN471MA20T
EKMM201VSN681MA25T
EKMM201VSN821MA30T
EKMM201VSN102MA30T
EKMM201VSN122MA35T
EKMM201VSN152MA40T
EKMM201VSN182MA45T
EKMM201VSN222MA60T
25.4 45
25.4 50
25.4 60
30 20
30 20
30 25
30 25
30 30
30 35
30 40
30 45
30 50
30 60
35 20
35 20
35 25
35 30
35 30
35 35
35 40
35 45
35 60
Q45
Q50
Q60
R20
R20
R25
R25
R30
R35
R40
R45
R50
R60
A20
A20
A25
A30
A30
A35
A40
A45
A60
0.303
0.249
0.207
0.921
0.753
0.529
0.444
0.366
0.303
0.249
0.207
0.166
0.138
0.638
0.529
0.366
0.303
0.249
0.207
0.166
0.138
0.113
2.04
2.3
2.66
1.05
1.1
1.5
1.67
1.78
2.04
2.3
2.65
3.08
3.49
1.3
1.41
1.78
2.04
2.3
2.65
3.08
3.48
3.78
120
150
180
220
270
330
390
470
150
220
270
330
390
470
560
180
220
270
330
390
470
560
680
820
1,000
270
390
470
560
680
820
1,000
1,200
1,500
330
390
EKMM221VSN121MN20T
EKMM221VSN151MN25T
EKMM221VSN181MN25T
EKMM221VSN221MN30T
EKMM221VSN271MN35T
EKMM221VSN331MN40T
EKMM221VSN391MN45T
EKMM221VSN471MN50T
EKMM221VSN151MP20T
EKMM221VSN221MP25T
EKMM221VSN271MP30T
EKMM221VSN331MP35T
EKMM221VSN391MP35T
EKMM221VSN471MP40T
EKMM221VSN561MP45T
EKMM221VSN181MQ20T
EKMM221VSN221MQ20T
EKMM221VSN271MQ25T
EKMM221VSN331MQ25T
EKMM221VSN391MQ30T
EKMM221VSN471MQ35T
EKMM221VSN561MQ40T
EKMM221VSN681MQ45T
EKMM221VSN821MQ50T
EKMM221VSN102MQ60T
EKMM221VSN271MR20T
EKMM221VSN391MR25T
EKMM221VSN471MR25T
EKMM221VSN561MR30T
EKMM221VSN681MR35T
EKMM221VSN821MR40T
EKMM221VSN102MR45T
EKMM221VSN122MR50T
EKMM221VSN152MR60T
EKMM221VSN331MA20T
EKMM221VSN391MA20T
20 20
20 25
20 25
20 30
20 35
20 40
20 45
20 50
22 20
22 25
22 30
22 35
22 35
22 40
22 45
25.4 20
25.4 20
25.4 25
25.4 25
25.4 30
25.4 35
25.4 40
25.4 45
25.4 50
25.4 60
30 20
30 25
30 25
30 30
30 35
30 40
30 45
30 50
30 60
35 20
35 20
N20
N25
N25
N30
N35
N40
N45
N50
P20
P25
P30
P35
P35
P40
P45
Q20
Q20
Q25
Q25
Q30
Q35
Q40
Q45
Q50
Q60
R20
R25
R25
R30
R35
R40
R45
R50
R60
A20
A20
2.072
1.658
1.381
1.13
0.921
0.753
0.638
0.529
1.658
1.13
0.921
0.753
0.638
0.529
0.444
1.381
1.13
0.921
0.753
0.638
0.529
0.444
0.366
0.303
0.249
0.921
0.638
0.529
0.444
0.366
0.303
0.249
0.207
0.166
0.753
0.638
0.56
0.73
0.9
1.0
1.15
1.25
1.4
1.51
0.67
1.0
1.15
1.25
1.4
1.51
1.7
0.76
0.84
1.08
1.25
1.4
1.54
1.72
1.94
2.18
2.54
0.98
1.36
1.5
1.7
1.93
2.19
2.5
2.81
3.3
1.13
1.23
7/ 12
KMM
820
1,000
1,200
270
330
470
560
680
820
1,000
1,200
1,500
1,800
390
470
680
820
1,000
1,200
1,500
1,800
2,200
SNAP MOUNT 105C
220 Volts
275 Volts Surge
Capacitance
(µF )
KMM Series
Rated
Voltage
(WVDC)
220 Volts
KMM
SNAP MOUNT 105C
275 Volts Surge
250 Volts
300 Volts Surge
315 Volts
365 Volts Surge
Global
Part Number†
Nominal
Case Size*
DL ( mm )
Case
Size
Code
Maximum ESR
( Ω ) at
20C, 120Hz
Rated
Ripple Current
(A rms) at
105C, 120Hz
560
680
820
1,000
1,200
1,500
1,800
2,200
EKMM221VSN561MA25T
EKMM221VSN681MA25T
EKMM221VSN821MA30T
EKMM221VSN102MA35T
EKMM221VSN122MA40T
EKMM221VSN152MA45T
EKMM221VSN182MA50T
EKMM221VSN222MA60T
35 25
35 25
35 30
35 35
35 40
35 45
35 50
35 60
A25
A25
A30
A35
A40
A45
A50
A60
0.444
0.366
0.303
0.249
0.207
0.166
0.138
0.113
1.71
1.89
2.16
2.44
2.79
3.22
3.63
4.23
100
120
150
180
220
270
330
390
120
180
220
270
330
390
470
560
150
180
220
270
330
390
470
560
680
820
220
270
330
390
470
560
680
820
1,000
1,200
330
470
560
680
820
1,000
1,200
1,500
1,800
EKMM251VSN101MN20T
EKMM251VSN121MN25T
EKMM251VSN151MN25T
EKMM251VSN181MN30T
EKMM251VSN221MN30T
EKMM251VSN271MN35T
EKMM251VSN331MN40T
EKMM251VSN391MN50T
EKMM251VSN121MP20T
EKMM251VSN181MP25T
EKMM251VSN221MP30T
EKMM251VSN271MP30T
EKMM251VSN331MP35T
EKMM251VSN391MP40T
EKMM251VSN471MP45T
EKMM251VSN561MP50T
EKMM251VSN151MQ20T
EKMM251VSN181MQ20T
EKMM251VSN221MQ25T
EKMM251VSN271MQ25T
EKMM251VSN331MQ30T
EKMM251VSN391MQ35T
EKMM251VSN471MQ35T
EKMM251VSN561MQ40T
EKMM251VSN681MQ50T
EKMM251VSN821MQ60T
EKMM251VSN221MR20T
EKMM251VSN271MR20T
EKMM251VSN331MR25T
EKMM251VSN391MR25T
EKMM251VSN471MR30T
EKMM251VSN561MR30T
EKMM251VSN681MR35T
EKMM251VSN821MR40T
EKMM251VSN102MR50T
EKMM251VSN122MR60T
EKMM251VSN331MA20T
EKMM251VSN471MA25T
EKMM251VSN561MA25T
EKMM251VSN681MA30T
EKMM251VSN821MA35T
EKMM251VSN102MA40T
EKMM251VSN122MA45T
EKMM251VSN152MA50T
EKMM251VSN182MA60T
20 20
20 25
20 25
20 30
20 30
20 35
20 40
20 50
22 20
22 25
22 30
22 30
22 35
22 40
22 45
22 50
25.4 20
25.4 20
25.4 25
25.4 25
25.4 30
25.4 35
25.4 35
25.4 40
25.4 50
25.4 60
30 20
30 20
30 25
30 25
30 30
30 30
30 35
30 40
30 50
30 60
35 20
35 25
35 25
35 30
35 35
35 40
35 45
35 50
35 60
N20
N25
N25
N30
N30
N35
N40
N50
P20
P25
P30
P30
P35
P40
P45
P50
Q20
Q20
Q25
Q25
Q30
Q35
Q35
Q40
Q50
Q60
R20
R20
R25
R25
R30
R30
R35
R40
R50
R60
A20
A25
A25
A30
A35
A40
A45
A50
A60
2.486
2.072
1.658
1.381
1.13
0.921
0.753
0.638
2.072
1.381
1.13
0.921
0.753
0.638
0.529
0.444
1.658
1.381
1.13
0.921
0.753
0.638
0.529
0.444
0.366
0.303
1.13
0.921
0.753
0.638
0.529
0.444
0.366
0.303
0.249
0.207
0.753
0.529
0.444
0.366
0.303
0.249
0.207
0.166
0.138
0.51
0.58
0.79
0.9
1.0
1.1
1.2
1.45
0.6
0.78
1.0
1.18
1.3
1.49
1.65
1.67
0.74
0.75
0.95
1.18
1.3
1.49
1.65
1.8
2.0
2.2
0.95
1.0
1.3
1.49
1.65
1.8
2.0
2.3
2.47
2.85
1.16
1.65
1.8
2.0
2.3
2.47
2.6
3.0
3.42
56
68
82
100
EKMM3B1VSN560MN20T
EKMM3B1VSN680MN25T
EKMM3B1VSN820MN25T
EKMM3B1VSN101MN30T
20 20
20 25
20 25
20 30
N20
N25
N25
N30
4.44
3.656
3.032
2.486
0.38
0.47
0.64
0.69
Capacitance
(µF )
8 / 12
KMM Series
Rated
Voltage
(WVDC)
315 Volts
Nominal
Case Size*
DL ( mm )
Case
Size
Code
Maximum ESR
( Ω ) at
20C, 120Hz
Rated
Ripple Current
(A rms) at
105C, 120Hz
120
150
180
220
68
82
100
120
150
180
220
270
330
100
120
150
180
220
270
330
390
470
120
150
180
220
270
330
390
470
560
680
150
180
220
270
330
390
470
560
680
820
1,000
EKMM3B1VSN121MN30T
EKMM3B1VSN151MN35T
EKMM3B1VSN181MN40T
EKMM3B1VSN221MN50T
EKMM3B1VSN680MP20T
EKMM3B1VSN820MP20T
EKMM3B1VSN101MP25T
EKMM3B1VSN121MP30T
EKMM3B1VSN151MP35T
EKMM3B1VSN181MP35T
EKMM3B1VSN221MP40T
EKMM3B1VSN271MP45T
EKMM3B1VSN331MP50T
EKMM3B1VSN101MQ20T
EKMM3B1VSN121MQ20T
EKMM3B1VSN151MQ25T
EKMM3B1VSN181MQ30T
EKMM3B1VSN221MQ35T
EKMM3B1VSN271MQ40T
EKMM3B1VSN331MQ45T
EKMM3B1VSN391MQ50T
EKMM3B1VSN471MQ60T
EKMM3B1VSN121MR20T
EKMM3B1VSN151MR20T
EKMM3B1VSN181MR25T
EKMM3B1VSN221MR25T
EKMM3B1VSN271MR25T
EKMM3B1VSN331MR30T
EKMM3B1VSN391MR35T
EKMM3B1VSN471MR40T
EKMM3B1VSN561MR45T
EKMM3B1VSN681MR50T
EKMM3B1VSN151MA20T
EKMM3B1VSN181MA20T
EKMM3B1VSN221MA20T
EKMM3B1VSN271MA25T
EKMM3B1VSN331MA30T
EKMM3B1VSN391MA30T
EKMM3B1VSN471MA35T
EKMM3B1VSN561MA40T
EKMM3B1VSN681MA45T
EKMM3B1VSN821MA50T
EKMM3B1VSN102MA60T
20 30
20 35
20 40
20 50
22 20
22 20
22 25
22 30
22 35
22 35
22 40
22 45
22 50
25.4 20
25.4 20
25.4 25
25.4 30
25.4 35
25.4 40
25.4 45
25.4 50
25.4 60
30 20
30 20
30 25
30 25
30 25
30 30
30 35
30 40
30 45
30 50
35 20
35 20
35 20
35 25
35 30
35 30
35 35
35 40
35 45
35 50
35 60
N30
N35
N40
N50
P20
P20
P25
P30
P35
P35
P40
P45
P50
Q20
Q20
Q25
Q30
Q35
Q40
Q45
Q50
Q60
R20
R20
R25
R25
R25
R30
R35
R40
R45
R50
A20
A20
A20
A25
A30
A30
A35
A40
A45
A50
A60
2.072
1.658
1.381
1.13
3.656
3.032
2.486
2.072
1.658
1.381
1.13
0.921
0.753
2.486
2.072
1.658
1.381
1.13
0.921
0.753
0.638
0.529
2.072
1.658
1.381
1.13
0.921
0.753
0.638
0.529
0.444
0.366
1.658
1.381
1.13
0.921
0.753
0.638
0.529
0.444
0.366
0.303
0.249
0.75
0.82
0.9
1.0
0.45
0.47
0.61
0.75
0.82
0.92
1.04
1.16
1.33
0.56
0.62
0.82
0.92
1.04
1.16
1.33
1.47
1.7
0.65
0.7
0.9
1.04
1.16
1.33
1.47
1.7
2.05
2.17
0.76
0.85
0.9
1.15
1.33
1.47
1.7
2.05
2.17
2.20
2.55
47
56
68
82
100
120
150
180
220
56
82
100
120
150
180
EKMM351VSN470MN20T
EKMM351VSN560MN25T
EKMM351VSN680MN25T
EKMM351VSN820MN30T
EKMM351VSN101MN30T
EKMM351VSN121MN35T
EKMM351VSN151MN40T
EKMM351VSN181MN45T
EKMM351VSN221MN50T
EKMM351VSN560MP20T
EKMM351VSN820MP25T
EKMM351VSN101MP25T
EKMM351VSN121MP30T
EKMM351VSN151MP35T
EKMM351VSN181MP40T
20 20
20 25
20 25
20 30
20 30
20 35
20 40
20 45
20 50
22 20
22 25
22 25
22 30
22 35
22 40
N20
N25
N25
N30
N30
N35
N40
N45
N50
P20
P25
P25
P30
P35
P40
5.29
4.44
3.656
3.032
2.486
2.072
1.658
1.381
1.13
4.44
3.032
2.486
2.072
1.658
1.381
0.35
0.43
0.47
0.54
0.6
0.68
0.78
0.87
1.0
0.41
0.55
0.69
0.75
0.82
0.92
9 / 12
KMM
350 Volts
400 Volts Surge
Global
Part Number†
SNAP MOUNT 105C
365 Volts Surge
Capacitance
(µF )
KMM Series
Rated
Voltage
(WVDC)
350 Volts
KMM
SNAP MOUNT 105C
400 Volts Surge
400 Volts
450 Volts Surge
Capacitance
(µF )
Global
Part Number†
220
270
68
82
120
150
180
220
270
330
390
470
100
120
150
180
220
270
330
390
470
560
680
150
220
270
330
390
470
560
680
820
EKMM351VSN221MP45T
EKMM351VSN271MP50T
EKMM351VSN680MQ20T
EKMM351VSN820MQ20T
EKMM351VSN121MQ25T
EKMM351VSN151MQ30T
EKMM351VSN181MQ30T
EKMM351VSN221MQ35T
EKMM351VSN271MQ40T
EKMM351VSN331MQ45T
EKMM351VSN391MQ50T
EKMM351VSN471MQ60T
EKMM351VSN101MR20T
EKMM351VSN121MR20T
EKMM351VSN151MR25T
EKMM351VSN181MR25T
EKMM351VSN221MR30T
EKMM351VSN271MR30T
EKMM351VSN331MR35T
EKMM351VSN391MR40T
EKMM351VSN471MR45T
EKMM351VSN561MR50T
EKMM351VSN681MR60T
EKMM351VSN151MA20T
EKMM351VSN221MA25T
EKMM351VSN271MA25T
EKMM351VSN331MA30T
EKMM351VSN391MA35T
EKMM351VSN471MA35T
EKMM351VSN561MA40T
EKMM351VSN681MA50T
EKMM351VSN821MA60T
39
47
56
68
82
100
120
150
47
68
82
100
120
150
180
220
56
68
100
120
150
180
220
270
330
390
EKMM401VSN390MN20T
EKMM401VSN470MN25T
EKMM401VSN560MN25T
EKMM401VSN680MN30T
EKMM401VSN820MN30T
EKMM401VSN101MN35T
EKMM401VSN121MN40T
EKMM401VSN151MN45T
EKMM401VSN470MP20T
EKMM401VSN680MP25T
EKMM401VSN820MP25T
EKMM401VSN101MP30T
EKMM401VSN121MP35T
EKMM401VSN151MP40T
EKMM401VSN181MP45T
EKMM401VSN221MP50T
EKMM401VSN560MQ20T
EKMM401VSN680MQ20T
EKMM401VSN101MQ25T
EKMM401VSN121MQ30T
EKMM401VSN151MQ30T
EKMM401VSN181MQ35T
EKMM401VSN221MQ40T
EKMM401VSN271MQ45T
EKMM401VSN331MQ50T
EKMM401VSN391MQ60T
Case
Size
Code
Maximum ESR
( Ω ) at
20C, 120Hz
Rated
Ripple Current
(A rms) at
105C, 120Hz
22 45
22 50
25.4 20
25.4 20
25.4 25
25.4 30
25.4 30
25.4 35
25.4 40
25.4 45
25.4 50
25.4 60
30 20
30 20
30 25
30 25
30 30
30 30
30 35
30 40
30 45
30 50
30 60
35 20
35 25
35 25
35 30
35 35
35 35
35 40
35 50
35 60
P45
P50
Q20
Q20
Q25
Q30
Q30
Q35
Q40
Q45
Q50
Q60
R20
R20
R25
R25
R30
R30
R35
R40
R45
R50
R60
A20
A25
A25
A30
A35
A35
A40
A50
A60
1.13
0.921
3.656
3.032
2.072
1.658
1.381
1.13
0.921
0.753
0.638
0.529
2.486
2.072
1.658
1.381
1.13
0.921
0.753
0.638
0.529
0.444
0.366
1.658
1.13
0.921
0.753
0.638
0.529
0.444
0.366
0.303
1.05
1.16
0.46
0.51
0.75
0.83
0.92
1.04
1.18
1.29
1.51
1.66
0.6
0.65
0.82
0.9
1.02
1.17
1.34
1.51
1.65
1.85
2.15
0.76
1.04
1.2
1.22
1.47
1.69
1.9
1.99
2.31
20 20
20 25
20 25
20 30
20 30
20 35
20 40
20 45
22 20
22 25
22 25
22 30
22 35
22 40
22 45
22 50
25.4 20
25.4 20
25.4 25
25.4 30
25.4 30
25.4 35
25.4 40
25.4 45
25.4 50
25.4 60
N20
N25
N25
N30
N30
N35
N40
N45
P20
P25
P25
P30
P35
P40
P45
P50
Q20
Q20
Q25
Q30
Q30
Q35
Q40
Q45
Q50
Q60
6.375
5.29
4.44
3.656
3.032
2.486
2.072
1.658
5.29
3.656
3.032
2.486
2.072
1.658
1.381
1.13
4.44
3.656
2.486
2.072
1.658
1.381
1.13
0.921
0.753
0.638
0.32
0.39
0.51
0.56
0.64
0.7
0.75
0.83
0.37
0.5
0.64
0.7
0.75
0.88
0.98
1.1
0.42
0.46
0.7
0.75
0.88
0.98
1.1
1.22
1.44
1.51
Nominal
Case Size*
DL ( mm )
10 / 12 United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com
KMM Series
Rated
Voltage
(WVDC)
400 Volts
450 Volts Surge
Nominal
Case Size*
DL ( mm )
Case
Size
Code
Maximum ESR
( Ω ) at
20C, 120Hz
Rated
Ripple Current
(A rms) at
105C, 120Hz
82
100
120
150
180
220
270
330
390
470
560
120
150
220
270
330
390
470
560
680
EKMM401VSN820MR20T
EKMM401VSN101MR20T
EKMM401VSN121MR25T
EKMM401VSN151MR25T
EKMM401VSN181MR30T
EKMM401VSN221MR30T
EKMM401VSN271MR35T
EKMM401VSN331MR40T
EKMM401VSN391MR45T
EKMM401VSN471MR50T
EKMM401VSN561MR60T
EKMM401VSN121MA20T
EKMM401VSN151MA20T
EKMM401VSN221MA25T
EKMM401VSN271MA30T
EKMM401VSN331MA35T
EKMM401VSN391MA35T
EKMM401VSN471MA40T
EKMM401VSN561MA45T
EKMM401VSN681MA60T
30 20
30 20
30 25
30 25
30 30
30 30
30 35
30 40
30 45
30 50
30 60
35 20
35 20
35 25
35 30
35 35
35 35
35 40
35 45
35 60
R20
R20
R25
R25
R30
R30
R35
R40
R45
R50
R60
A20
A20
A25
A30
A35
A35
A40
A45
A60
3.032
2.486
2.072
1.658
1.381
1.13
0.921
0.753
0.638
0.529
0.444
2.072
1.658
1.13
0.921
0.753
0.638
0.529
0.444
0.366
0.55
0.6
0.73
0.82
0.98
1.1
1.22
1.44
1.6
1.9
2.1
0.75
0.8
1.1
1.22
1.44
1.6
1.9
2.12
2.27
39
47
56
68
82
100
120
150
47
68
82
100
120
150
180
220
56
68
82
100
120
150
180
220
270
330
82
100
120
150
180
220
270
330
390
470
120
180
EKMM421VSN390MN20T
EKMM421VSN470MN25T
EKMM421VSN560MN25T
EKMM421VSN680MN30T
EKMM421VSN820MN35T
EKMM421VSN101MN35T
EKMM421VSN121MN40T
EKMM421VSN151MN50T
EKMM421VSN470MP20T
EKMM421VSN680MP25T
EKMM421VSN820MP25T
EKMM421VSN101MP30T
EKMM421VSN121MP35T
EKMM421VSN151MP40T
EKMM421VSN181MP45T
EKMM421VSN221MP50T
EKMM421VSN560MQ20T
EKMM421VSN680MQ20T
EKMM421VSN820MQ25T
EKMM421VSN101MQ25T
EKMM421VSN121MQ30T
EKMM421VSN151MQ35T
EKMM421VSN181MQ35T
EKMM421VSN221MQ45T
EKMM421VSN271MQ50T
EKMM421VSN331MQ60T
EKMM421VSN820MR20T
EKMM421VSN101MR20T
EKMM421VSN121MR25T
EKMM421VSN151MR25T
EKMM421VSN181MR30T
EKMM421VSN221MR35T
EKMM421VSN271MR40T
EKMM421VSN331MR45T
EKMM421VSN391MR50T
EKMM421VSN471MR60T
EKMM421VSN121MA20T
EKMM421VSN181MA25T
20 20
20 25
20 25
20 30
20 35
20 35
20 40
20 50
22 20
22 25
22 25
22 30
22 35
22 40
22 45
22 50
25.4 20
25.4 20
25.4 25
25.4 25
25.4 30
25.4 35
25.4 35
25.4 45
25.4 50
25.4 60
30 20
30 20
30 25
30 25
30 30
30 35
30 40
30 45
30 50
30 60
35 20
35 25
N20
N25
N25
N30
N35
N35
N40
N50
P20
P25
P25
P30
P35
P40
P45
P50
Q20
Q20
Q25
Q25
Q30
Q35
Q35
Q45
Q50
Q60
R20
R20
R25
R25
R30
R35
R40
R45
R50
R60
A20
A25
8.5
7.053
5.92
4.875
4.043
3.315
2.763
2.21
7.053
4.875
4.043
3.315
2.763
2.21
1.842
1.507
5.92
4.875
4.043
3.315
2.763
2.21
1.842
1.507
1.228
1.005
4.043
3.315
2.763
2.21
1.842
1.507
1.228
1.005
0.85
0.705
2.763
1.842
0.32
0.39
0.51
0.56
0.64
0.7
0.75
0.88
0.37
0.5
0.64
0.7
0.75
0.88
0.95
1.1
0.42
0.46
0.58
0.7
0.75
0.88
0.95
1.1
1.22
1.41
0.53
0.59
0.73
0.88
0.95
1.1
1.22
1.45
1.55
1.79
0.67
0.94
11/ 12
KMM
Global
Part Number†
SNAP MOUNT 105C
420 Volts
470 Volts Surge
Capacitance
(µF )
KMM Series
Rated
Voltage
(WVDC)
420 Volts
KMM
SNAP MOUNT 105C
470 Volts Surge
450 Volts
500 Volts Surge
Capacitance
(µF )
Global
Part Number†
Nominal
Case Size*
DL ( mm )
Case
Size
Code
Maximum ESR
( Ω ) at
20C, 120Hz
Rated
Ripple Current
(A rms) at
105C, 120Hz
220
270
330
390
470
560
680
EKMM421VSN221MA25T
EKMM421VSN271MA30T
EKMM421VSN331MA35T
EKMM421VSN391MA40T
EKMM421VSN471MA45T
EKMM421VSN561MA50T
EKMM421VSN681MA60T
35 25
35 30
35 35
35 40
35 45
35 50
35 60
A25
A30
A35
A40
A45
A50
A60
1.507
1.228
1.005
0.85
0.705
0.592
0.488
1.1
1.22
1.45
1.55
1.9
2.15
2.27
39
47
56
68
82
100
120
56
68
82
100
120
150
68
82
100
120
150
180
220
270
100
120
150
180
220
270
330
390
120
150
220
270
330
390
470
560
EKMM451VSN390MN25T
EKMM451VSN470MN25T
EKMM451VSN560MN30T
EKMM451VSN680MN35T
EKMM451VSN820MN35T
EKMM451VSN101MN45T
EKMM451VSN121MN50T
EKMM451VSN560MP25T
EKMM451VSN680MP30T
EKMM451VSN820MP30T
EKMM451VSN101MP35T
EKMM451VSN121MP40T
EKMM451VSN151MP45T
EKMM451VSN680MQ25T
EKMM451VSN820MQ25T
EKMM451VSN101MQ30T
EKMM451VSN121MQ30T
EKMM451VSN151MQ35T
EKMM451VSN181MQ40T
EKMM451VSN221MQ45T
EKMM451VSN271MQ60T
EKMM451VSN101MR25T
EKMM451VSN121MR25T
EKMM451VSN151MR30T
EKMM451VSN181MR30T
EKMM451VSN221MR35T
EKMM451VSN271MR40T
EKMM451VSN331MR50T
EKMM451VSN391MR60T
EKMM451VSN121MA25T
EKMM451VSN151MA25T
EKMM451VSN221MA30T
EKMM451VSN271MA35T
EKMM451VSN331MA40T
EKMM451VSN391MA40T
EKMM451VSN471MA50T
EKMM451VSN561MA60T
20 25
20 25
20 30
20 35
20 35
20 45
20 50
22 25
22 30
22 30
22 35
22 40
22 45
25.4 25
25.4 25
25.4 30
25.4 30
25.4 35
25.4 40
25.4 45
25.4 60
30 25
30 25
30 30
30 30
30 35
30 40
30 50
30 60
35 25
35 25
35 30
35 35
35 40
35 40
35 50
35 60
N25
N25
N30
N35
N35
N45
N50
P25
P30
P30
P35
P40
P45
Q25
Q25
Q30
Q30
Q35
Q40
Q45
Q60
R25
R25
R30
R30
R35
R40
R50
R60
A25
A25
A30
A35
A40
A40
A50
A60
8.5
7.053
5.92
4.875
4.043
3.315
2.763
5.92
4.875
4.043
3.315
2.763
2.21
4.875
4.043
3.315
2.763
2.21
1.842
1.507
1.228
3.315
2.763
2.21
1.842
1.507
1.228
1.005
0.85
2.763
2.21
1.507
1.228
1.005
0.85
0.705
0.592
0.34
0.39
0.51
0.56
0.64
0.69
0.75
0.4
0.53
0.64
0.69
0.8
0.88
0.5
0.64
0.69
0.8
0.88
1.0
1.12
1.18
0.64
0.8
0.88
1.0
1.12
1.28
1.45
1.51
0.73
0.75
1.12
1.28
1.45
1.55
1.85
1.91
12 / 12 United Chemi-Con, Inc. 9801 W. Higgins Road, Rosemont, IL 60018 Tel 847-696-2000 Fax 847-696-9278 www.chemi-con.com
