EMZD250ADA101MF90G
EMZD250ADA101MF90G
    NCC(贵弥功)
    插件
    100 µF 25 V 铝电解电容器 径向,Can - SMD 105°C 时为 5000 小时
EMZD250ADA101MF90G 数据手册
Engineering Bulletin Vertical Surface Mount Type Aluminum Electrolytic Capacitors No.758C / Sep.2008 @Endurance : 5,000 hours at 105C @Low impedance @Rated voltage range : 6.3 to 50V @Nominal capacitance range : 10 to 470MF @Suitable for high reliability products @RoHS Compliant ?SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current Dissipation Factor (tane) Low Temperature Characteristics (Max. Impedance Ratio) Endurance Shelf Life -25 to +105C 6.3 to 50Vdc P20%(M) I=0.01CV or 3MA, whichever is greater Where, I : Max. leakage current (MA), C : Nominal capacitance (MF), V : Rated voltage (V) 6.3V 10V 16V 25V 35V 50V Rated voltage (Vdc) 0.32 0.28 0.26 0.16 0.14 0.14 tanE (Max.) 6.3V 10V 16V 25V 35V 50V Rated voltage(Vdc) 2 2 2 2 3 4 Z(-10C)/Z(+20C) (at 20C,120Hz) ?PART NUMBERING SYSTEM 1 @Terminal Code : A 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E MZD AAA A DA AAA M AAA G W Supplement code Size code Capacitance tolerance code Capacitance code (ex. 47MF:470,100MF:101) Taping code Terminal code Voltage code (ex. 6.3V:6R3,10V:100,25V:250) Series code Category P CP0.2 BP0.2 FDP0.5 (at 20C, after 2 minutes) (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20C after the rated voltage is applied for 5,000 hours at 105C. Capacitance change [P30% of the initial value D.F. (tanE) [300% of the initial specified value Leakage current [The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20C after exposing them for 1,000 hours at 105C without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change [P30% of the initial value D.F. (tanE) [300% of the initial specified value Leakage current [The initial specified value ?DIMENSIONS [mm] 0.3max. LP0.3 (Note) AP0.2 Note : LP0.5 for HA0 and JA0 Size code E73 F73 F90 HA0 JA0 (at 20C,120Hz) D L A B C 5 7.0 5.3 5.3 5.9 6.3 7.0 6.6 6.6 7.2 6.3 8.7 6.6 6.6 7.2 8 10.0 8.3 8.3 9.0 10 10.0 10.3 10.3 11.0 W 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 0.7 to 1.1 0.7 to 1.1 P 1.4 1.9 1.9 3.1 4.5 ?MARKING @Rated voltage symbol EX) 16V47MF Rated voltage (Vdc) Symbol 4h 47 C ZD 6.3 j 10 A 16 C 25 E 35 V 50 H ?STANDARD RATINGS WV (Vdc) 6.3 10 16 25 Rated ripple Impedance Cap current Size code (omax/20c, (mF) (mArms/105c, 100kHz) 100kHz) 47 100 220 330 470 33 150 22 47 100 150 220 330 470 22 33 E73 F73 F90 F90 HA0 E73 F73 E73 F73 F73 F90 F90 HA0 HA0 E73 F73 2.2 1.1 1.0 1.0 0.22 2.2 1.1 2.2 1.1 1.1 1.0 1.0 0.22 0.22 2.2 1.1 95 140 230 230 600 95 140 95 140 140 230 230 600 600 95 140 Part No. EMZD6R3ADA470ME73G EMZD6R3ADA101MF73G EMZD6R3ADA221MF90G EMZD6R3ADA331MF90G EMZD6R3ADA471MHA0G EMZD100ADA330ME73G EMZD100ADA151MF73G EMZD160ADA220ME73G EMZD160ADA470MF73G EMZD160ADA101MF73G EMZD160ADA151MF90G EMZD160ADA221MF90G EMZD160ADA331MHA0G EMZD160ADA471MHA0G EMZD250ADA220ME73G EMZD250ADA330MF73G WV (Vdc) 25 35 50 Rated ripple Impedance Cap current Size code (omax/20c, (mF) (mArms/105c, 100kHz) 100kHz) 47 100 220 330 470 10 10 22 22 33 47 220 330 47 100 220 F73 F90 HA0 HA0 JA0 E73 F73 E73 F73 F90 F90 HA0 JA0 HA0 HA0 JA0 1.1 1.0 0.22 0.22 0.16 2.2 1.1 2.2 1.1 1.0 1.0 0.22 0.16 0.53 0.53 0.35 140 230 600 600 850 95 140 95 140 230 230 600 850 350 350 670 Part No. EMZD250ADA470MF73G EMZD250ADA101MF90G EMZD250ADA221MHA0G EMZD250ADA331MHA0G EMZD250ADA471MJA0G EMZD350ADA100ME73G EMZD350ADA100MF73G EMZD350ADA220ME73G EMZD350ADA220MF73G EMZD350ADA330MF90G EMZD350ADA470MF90G EMZD350ADA221MHA0G EMZD350ADA331MJA0G EMZD500ADA470MHA0G EMZD500ADA101MHA0G EMZD500ADA221MJA0G Specifications in this bulletin are subject to change without notice. NIPPON CHEMI-CON CORPORATION 1450 1
EMZD250ADA101MF90G 价格&库存
很抱歉,暂时无法提供与“EMZD250ADA101MF90G”相匹配的价格&库存,您可以联系我们找货
