SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS
@Endurance : 7,000 to 8,000 hours at 105C
@Rated voltage range : 6.3 to 50V
@Nominal capacitance range : 0.1 to 1,000MF
@Suitable for high reliability products
@RoHS Compliant
MVL
Longer life
MLD
7000 to 8000-hours-life, 105C
Longer life
MLE
?SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
Dissipation Factor
(tane)
Low Temperature
Characteristics
(Max. Impedance Ratio)
Endurance
Shelf Life
-25 to +105C
6.3 to 50Vdc
P20%(M)
I=0.03CV or 4MA, whichever is greater
Where, I : Max. leakage current (MA), C : Nominal capacitance (MF), V : Rated voltage (V)
6.3V 10V 16V 25V 35V 50V
Rated voltage (Vdc)
0.32 0.28 0.26 0.16 0.14 0.14
tanE (Max.)
Rated voltage(Vdc)
2
2
4
3
2
2
Z(-10C)/Z(+20C)
(at 20C,120Hz)
?PART NUMBERING SYSTEM
1
@Terminal Code : A
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
E ML E AAA A DA AAA M AAA G
W
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 47MF:470,100MF:101)
Taping code
Terminal code
Voltage code (ex. 6.3V:6R3,10V:100,25V:250)
Series code
Category
P
CP0.2
BP0.2
FDP0.5
(at 20C, after 2 minutes)
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20C after the rated voltage is applied for specified time
at 105C.
D73 to F73 : 7,000 hours
Time
F90 to JA0 : 8,000 hours
Capacitance change
[P30% of the initial value
D.F. (tanE)
[300% of the initial specified value
Leakage current
[The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20C after exposing them for 1,000 hours at 105C without
voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4.
Capacitance change
D.F. (tanE)
Leakage current
?DIMENSIONS [mm]
0.3max.
LP0.3 (Note)
AP0.2
Note : LP0.5 for HA0 and JA0
Size code
D73
E73
F73
F90
HA0
JA0
(at 20C,120Hz)
C
B
A
L
D
7.0 4.3 4.3 5.1
4
7.0 5.3 5.3 5.9
5
6.3 7.0 6.6 6.6 7.2
6.3 8.7 6.6 6.6 7.2
8 10.0 8.3 8.3 9.0
10 10.0 10.3 10.3 11.0
W
0.5 to 0.8
0.5 to 0.8
0.5 to 0.8
0.5 to 0.8
0.7 to 1.1
0.7 to 1.1
P
1.0
1.4
1.9
1.9
3.1
4.5
?MARKING
@Rated voltage symbol
EX) 16V47MF
Rated voltage (Vdc) 6.3
Symbol
j
4h
47
C LE
10
A
16
C
25
E
35
V
50
H
?STANDARD RATINGS
WV
(Vdc)
6.3
10
16
25
35
Cap
(mF)
Size code
Rated ripple current
(mArms/105c, 120Hz)
Part No.
22
47
100
220
330
1,000
33
220
10
22
47
100
470
33
47
100
0.10
D73
E73
F73
F90
HA0
JA0
E73
HA0
D73
E73
F73
F90
JA0
F73
F90
HA0
D73
22
36
60
101
160
313
35
141
18
30
50
81
254
48
63
116
1.0
EMLE6R3ADA220MD73G
EMLE6R3ADA470ME73G
EMLE6R3ADA101MF73G
EMLE6R3ADA221MF90G
EMLE6R3ADA331MHA0G
EMLE6R3ADA102MJA0G
EMLE100ADA330ME73G
EMLE100ADA221MHA0G
EMLE160ADA100MD73G
EMLE160ADA220ME73G
EMLE160ADA470MF73G
EMLE160ADA101MF90G
EMLE160ADA471MJA0G
EMLE250ADA330MF73G
EMLE250ADA470MF90G
EMLE250ADA101MHA0G
EMLE350ADAR10MD73G
WV
(Vdc)
(1/1)
35
50
Cap
(mF)
Size code
(mArms/105c, 120Hz)
Part No.
0.22
0.33
0.47
1.0
2.2
3.3
4.7
4.7
10
10
22
22
33
220
33
47
100
D73
D73
D73
D73
D73
D73
D73
E73
E73
F73
F73
F90
F90
JA0
HA0
HA0
JA0
2.6
3.2
3.8
6.2
11
14
15
19
25
30
42
49
57
216
77
92
151
EMLE350ADAR22MD73G
EMLE350ADAR33MD73G
EMLE350ADAR47MD73G
EMLE350ADA1R0MD73G
EMLE350ADA2R2MD73G
EMLE350ADA3R3MD73G
EMLE350ADA4R7MD73G
EMLE350ADA4R7ME73G
EMLE350ADA100ME73G
EMLE350ADA100MF73G
EMLE350ADA220MF73G
EMLE350ADA220MF90G
EMLE350ADA330MF90G
EMLE350ADA221MJA0G
EMLE500ADA330MHA0G
EMLE500ADA470MHA0G
EMLE500ADA101MJA0G
CAT. No. E1001I
很抱歉,暂时无法提供与“EMLE350ADA100ME73G”相匹配的价格&库存,您可以联系我们找货
