EMLE6R3ADA220MD73G
EMLE6R3ADA220MD73G
    NCC(贵弥功)
    插件
    22 µF 6.3 V 铝电解电容器 径向,Can - SMD 105°C 时为 7000 小时
EMLE6R3ADA220MD73G 数据手册
SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS @Endurance : 7,000 to 8,000 hours at 105C @Rated voltage range : 6.3 to 50V @Nominal capacitance range : 0.1 to 1,000MF @Suitable for high reliability products @RoHS Compliant MVL Longer life MLD 7000 to 8000-hours-life, 105C Longer life MLE ?SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current Dissipation Factor (tane) Low Temperature Characteristics (Max. Impedance Ratio) Endurance Shelf Life -25 to +105C 6.3 to 50Vdc P20%(M) I=0.03CV or 4MA, whichever is greater Where, I : Max. leakage current (MA), C : Nominal capacitance (MF), V : Rated voltage (V) 6.3V 10V 16V 25V 35V 50V Rated voltage (Vdc) 0.32 0.28 0.26 0.16 0.14 0.14 tanE (Max.) 6.3V 10V 16V 25V 35V 50V Rated voltage(Vdc) 2 2 4 3 2 2 Z(-10C)/Z(+20C) (at 20C,120Hz) ?PART NUMBERING SYSTEM 1 @Terminal Code : A 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E ML E AAA A DA AAA M AAA G W Supplement code Size code Capacitance tolerance code Capacitance code (ex. 47MF:470,100MF:101) Taping code Terminal code Voltage code (ex. 6.3V:6R3,10V:100,25V:250) Series code Category P CP0.2 BP0.2 FDP0.5 (at 20C, after 2 minutes) (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20C after the rated voltage is applied for specified time at 105C. D73 to F73 : 7,000 hours Time F90 to JA0 : 8,000 hours Capacitance change [P30% of the initial value D.F. (tanE) [300% of the initial specified value Leakage current [The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20C after exposing them for 1,000 hours at 105C without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change [P30% of the initial value D.F. (tanE) [300% of the initial specified value Leakage current [The initial specified value ?DIMENSIONS [mm] 0.3max. LP0.3 (Note) AP0.2 Note : LP0.5 for HA0 and JA0 Size code D73 E73 F73 F90 HA0 JA0 (at 20C,120Hz) C B A L D 7.0 4.3 4.3 5.1 4 7.0 5.3 5.3 5.9 5 6.3 7.0 6.6 6.6 7.2 6.3 8.7 6.6 6.6 7.2 8 10.0 8.3 8.3 9.0 10 10.0 10.3 10.3 11.0 W 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 0.7 to 1.1 0.7 to 1.1 P 1.0 1.4 1.9 1.9 3.1 4.5 ?MARKING @Rated voltage symbol EX) 16V47MF Rated voltage (Vdc) 6.3 Symbol j 4h 47 C LE 10 A 16 C 25 E 35 V 50 H ?STANDARD RATINGS WV (Vdc) 6.3 10 16 25 35 Cap (mF) Size code Rated ripple current (mArms/105c, 120Hz) Part No. 22 47 100 220 330 1,000 33 220 10 22 47 100 470 33 47 100 0.10 D73 E73 F73 F90 HA0 JA0 E73 HA0 D73 E73 F73 F90 JA0 F73 F90 HA0 D73 22 36 60 101 160 313 35 141 18 30 50 81 254 48 63 116 1.0 EMLE6R3ADA220MD73G EMLE6R3ADA470ME73G EMLE6R3ADA101MF73G EMLE6R3ADA221MF90G EMLE6R3ADA331MHA0G EMLE6R3ADA102MJA0G EMLE100ADA330ME73G EMLE100ADA221MHA0G EMLE160ADA100MD73G EMLE160ADA220ME73G EMLE160ADA470MF73G EMLE160ADA101MF90G EMLE160ADA471MJA0G EMLE250ADA330MF73G EMLE250ADA470MF90G EMLE250ADA101MHA0G EMLE350ADAR10MD73G WV (Vdc) (1/1) 35 50 Cap (mF) Size code Rated ripple current (mArms/105c, 120Hz) Part No. 0.22 0.33 0.47 1.0 2.2 3.3 4.7 4.7 10 10 22 22 33 220 33 47 100 D73 D73 D73 D73 D73 D73 D73 E73 E73 F73 F73 F90 F90 JA0 HA0 HA0 JA0 2.6 3.2 3.8 6.2 11 14 15 19 25 30 42 49 57 216 77 92 151 EMLE350ADAR22MD73G EMLE350ADAR33MD73G EMLE350ADAR47MD73G EMLE350ADA1R0MD73G EMLE350ADA2R2MD73G EMLE350ADA3R3MD73G EMLE350ADA4R7MD73G EMLE350ADA4R7ME73G EMLE350ADA100ME73G EMLE350ADA100MF73G EMLE350ADA220MF73G EMLE350ADA220MF90G EMLE350ADA330MF90G EMLE350ADA221MJA0G EMLE500ADA330MHA0G EMLE500ADA470MHA0G EMLE500ADA101MJA0G CAT. No. E1001I
EMLE6R3ADA220MD73G 价格&库存
很抱歉,暂时无法提供与“EMLE6R3ADA220MD73G”相匹配的价格&库存,您可以联系我们找货
