EMVA630ADAR22MD55G
EMVA630ADAR22MD55G
    NCC(贵弥功)
    插件
    0.22 µF 63 V 铝电解电容器 径向,Can - SMD 85°C 时为 2000 小时
EMVA630ADAR22MD55G 数据手册
SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS Downsized, 85C MVA @F4 through F18 case sizes are fully lined up @Endurance : 2,000 hours at 85C @Suitable to fit for downsized equipment @Solvent resistant type except 100 to 450Vdc (see PRECAUTIONS AND GUIDELINES) @RoHS Compliant Downsized Expanded case sizes MV ?SPECIFICATIONS Items Characteristics Category Temperature Range -40 to +85C Rated Voltage Range Capacitance Tolerance Leakage Current 4 to 450Vdc P20% (M) (at 20C, 120Hz) Rated voltage (Vdc) 4 to 100V 160 to 450V D55 to JA0 I=0.01CV or 3MA, whichever is greater.(after 2 minutes) KE0 to MN0 I=0.03CV or 4MA, whichever is greater.(after 1 minute) I=0.04CV+100MA max.(after 1 minute) Where, I : Max. leakage current (MA), C : Nominal capacitance (MF), V : Rated voltage (V) (at 20C) Rated voltage (Vdc) 4V 6.3V 10V 16V 25V 35V 50V 63V 100V 160 to 250V 400 & 450V D55 to JA0 0.42 0.35 0.30 0.26 0.16 0.14 0.12 0.12 0.12 tanE (Max.) KE0 to MN0 0.38 0.34 0.30 0.26 0.22 0.18 0.14 0.10 0.20 0.25 When nominal capacitance exceeds 1,000MF, add 0.02 to the value above for each 1,000MF increase. (at 20C, 120Hz) Rated voltage (Vdc) 4V 6.3V 10V 16V 25V 35V 50V 63V 100V 160 to 250V 400 & 450V Z(-25C)/Z(+20C) 3 2 2 2 2 2 3 4 7 D55 to JA0 Z(-40C)/Z(+20C) 4 3 3 3 4 6 8 10 17 Z(-25C)/Z(+20C) 2 2 2 2 2 3 4 5 3 6 KE0 to MN0 Z(-40C)/Z(+20C) (at 120Hz) 3 3 3 4 5 8 10 12 6 10 The following specifications shall be satisfied when the capacitors are restored to 20C after the rated voltage is applied for 2,000 hours at 85C. Size code D55 to JA0 D55 to JA0 KE0 to MN0 Rated voltage (Vdc) 4V & 6.3V 10 to 100V 6.3 to 450V Capacitance change [P30% of the initial value [P20% of the initial value DF (tanE) [200% of the initial specified value [200% of the initial specified value Leakage current [The initial specified value [The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20C after exposing them for 1,000 hours at 85C without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Size code D55 to JA0 D55 to JA0 KE0 to MN0 Rated voltage 4V & 6.3V 10 to 100V 6.3 to 450V Capacitance change [P30% of the initial value [P20% of the initial value DF (tanE) [200% of the initial specified value [200% of the initial specified value Leakage current [The initial specified value [The initial specified value Dissipation Factor (tane) Low Temperature Characteristics (Max. Impedance Ratio) Endurance Shelf Life ?DIMENSIONS [mm] @Terminal Code : G @Size code : LH0 to MN0 @Terminal Code : A @Size code : D55 to MN0 W 0.3max. 0.3max. LP0.3(Note) P CP0.2 BP0.2 FDP0.5 P CP0.2 BP0.2 FDP0.5 W AP0.2 LP0.5 AP0.2 Note : LP0.5 for HA0 to MN0 : Dummy terminals ?PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 C B A L Size code D 5.2 4.3 4.3 5.1 4 D55 5.2 5.3 5.3 5.9 5 E55 6.3 5.2 6.6 6.6 7.2 F55 6.3 5.7 6.6 6.6 7.2 F60 6.3 7.7 6.6 6.6 7.2 F80 8 10.0 8.3 8.3 9.0 HA0 10 10.0 10.3 10.3 11.0 JA0 12.5 13.5 13.0 13.0 13.7 KE0 12.5 16.0 13.0 13.0 13.7 KG5 16 16.5 17.0 17.0 18.0 LH0 16 21.5 17.0 17.0 18.0 LN0 18 16.5 19.0 19.0 20.0 MH0 18 21.5 19.0 19.0 20.0 MN0 W 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 0.7 to 1.1 0.7 to 1.1 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 P 1.0 1.4 1.9 1.9 1.9 3.1 4.5 4.2 4.2 6.5 6.5 6.5 6.5 ?MARKING 17 18 D55 to JA0 EX) 16V47MF E MV A AAA A AA AAA M AAA N Supplement code Size code Capacitance tolerance code Capacitance code (ex. 0.1MF:R10,100MF:101) Taping·Tray code Terminal code (A, G) Voltage code (ex. 6.3V:6R3,100V:101,450V:451) Series code Category 7hA 47 16V KE0 to HN0 EX) 25V1,000MF 0V MVA 1000 25V Please refer to "Product code guide (surface mount type)" (1/2) CAT. No. E1001J SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS Downsized, 85C ?STANDARD RATINGS WV (Vdc) 4 6.3 10 16 25 35 Cap (mF) 33 47 100 220 330 470 1,000 33 47 100 220 330 470 680 820 1,000 1,500 2,200 3,300 3,300 4,700 6,800 6,800 10,000 22 33 47 100 150 220 330 470 1,000 2,200 3,300 4,700 4,700 6,800 22 33 47 100 150 220 330 470 680 1,000 2,200 3,300 3,300 4,700 10 22 33 47 56 100 150 220 330 470 1,000 2,200 2,200 3,300 4.7 10 22 33 (47) 100 Size code tane D55 D55 E55 F55 F80 F80 HA0 D55 D55 E55 F55 F80 HA0 HA0 HA0 JA0 JA0 KE0 KG5 LH0 LH0 LN0 MH0 MN0 D55 D55 E55 F55 F55 F80 HA0 HA0 JA0 KE0 LH0 LN0 MH0 MN0 D55 E55 E55 F55 F80 F80 HA0 HA0 JA0 KE0 LH0 LN0 MH0 MN0 D55 E55 E55 F55 F55 F80 HA0 HA0 HA0 JA0 KE0 LN0 MH0 MN0 D55 D55 E55 F55 (F60) F80 0.42 0.42 0.42 0.42 0.42 0.42 0.42 0.35 0.35 0.35 0.35 0.35 0.35 0.35 0.35 0.35 0.35 0.40 0.42 0.42 0.44 0.48 0.48 0.56 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.36 0.38 0.40 0.40 0.44 0.26 0.26 0.26 0.26 0.26 0.26 0.26 0.26 0.26 0.30 0.32 0.34 0.34 0.36 0.16 0.16 0.16 0.16 0.16 0.16 0.16 0.16 0.16 0.16 0.26 0.28 0.28 0.30 0.14 0.14 0.14 0.14 (0.14) 0.14 is not solvent resistant. Rated ripple current (mArms/ 85c,120Hz) 25 30 50 80 135 150 320 30 33 55 88 135 280 290 320 430 480 890 1,000 1,200 1,400 1,750 1,700 2,000 26 30 44 70 79 130 270 280 430 960 1,300 1,550 1,600 1,850 26 37 44 70 110 130 270 280 380 710 1,150 1,450 1,450 1,750 24 41 47 60 66 120 210 260 300 400 820 1,450 1,400 1,800 18 24 41 54 (64) 120 WV (Vdc) Part No. EMVA4R0ADA330MD55G EMVA4R0ADA470MD55G EMVA4R0ADA101ME55G EMVA4R0ADA221MF55G EMVA4R0ADA331MF80G EMVA4R0ADA471MF80G EMVA4R0ADA102MHA0G EMVA6R3ADA330MD55G EMVA6R3ADA470MD55G EMVA6R3ADA101ME55G EMVA6R3ADA221MF55G EMVA6R3ADA331MF80G EMVA6R3ADA471MHA0G EMVA6R3ADA681MHA0G EMVA6R3ADA821MHA0G EMVA6R3ADA102MJA0G EMVA6R3ADA152MJA0G EMVA6R3ARA222MKE0S EMVA6R3ARA332MKG5S EMVA6R3SDA332MLH0S EMVA6R3SDA472MLH0S EMVA6R3SDA682MLN0S EMVA6R3SDA682MMH0S EMVA6R3SDA103MMN0S EMVA100ADA220MD55G EMVA100ADA330MD55G EMVA100ADA470ME55G EMVA100ADA101MF55G EMVA100ADA151MF55G EMVA100ADA221MF80G EMVA100ADA331MHA0G EMVA100ADA471MHA0G EMVA100ADA102MJA0G EMVA100ARA222MKE0S EMVA100SDA332MLH0S EMVA100SDA472MLN0S EMVA100SDA472MMH0S EMVA100SDA682MMN0S EMVA160ADA220MD55G EMVA160ADA330ME55G EMVA160ADA470ME55G EMVA160ADA101MF55G EMVA160ADA151MF80G EMVA160ADA221MF80G EMVA160ADA331MHA0G EMVA160ADA471MHA0G EMVA160ADA681MJA0G EMVA160ARA102MKE0S EMVA160SDA222MLH0S EMVA160SDA332MLN0S EMVA160SDA332MMH0S EMVA160SDA472MMN0S EMVA250ADA100MD55G EMVA250ADA220ME55G EMVA250ADA330ME55G EMVA250ADA470MF55G EMVA250ADA560MF55G EMVA250ADA101MF80G EMVA250ADA151MHA0G EMVA250ADA221MHA0G EMVA250ADA331MHA0G EMVA250ADA471MJA0G EMVA250ARA102MKE0S EMVA250SDA222MLN0S EMVA250SDA222MMH0S EMVA250SDA332MMN0S EMVA350ADA4R7MD55G EMVA350ADA100MD55G EMVA350ADA220ME55G EMVA350ADA330MF55G EMVA350ADA470MF60G EMVA350ADA101MF80G 35 50 63 100 160 200 250 400 450 Cap (mF) 150 220 330 470 1,000 2,200 3.3 4.7 10 22 33 47 100 220 330 470 470 1,000 1,000 0.10 0.22 0.33 0.47 1.0 2.2 3.3 4.7 10 22 33 47 56 68 100 220 330 330 470 470 22 33 68 100 220 220 330 47 68 100 100 22 33 47 68 68 100 10 22 33 47 47 68 4.7 10 22 22 33 4.7 10 22 33 Size code tane HA0 HA0 JA0 KE0 LH0 MN0 D55 D55 E55 F55 F80 F80 HA0 JA0 KE0 KG5 LH0 LN0 MN0 D55 D55 D55 D55 D55 D55 E55 E55 F55 F80 HA0 HA0 JA0 JA0 KE0 KE0 KG5 LH0 LH0 MH0 HA0 JA0 KE0 KE0 LN0 MH0 MN0 KG5 LH0 LN0 MH0 KE0 KG5 LH0 LN0 MH0 MN0 KE0 KG5 LH0 LN0 MH0 MN0 KE0 LH0 LN0 MH0 MN0 KE0 LH0 LN0 MN0 0.14 0.14 0.14 0.22 0.22 0.24 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.18 0.18 0.18 0.18 0.18 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.14 0.14 0.14 0.14 0.14 0.14 0.12 0.12 0.10 0.10 0.10 0.10 0.10 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 Rated ripple current (mArms/ 85c,120Hz) 210 260 360 600 1,100 1,700 15 18 30 47 70 85 190 320 600 740 850 1,300 1,400 1.3 3.0 4.0 5.0 8.0 12 17 20 32 60 110 130 160 170 380 580 720 820 950 1,000 90 120 380 440 850 800 1,000 370 500 590 590 240 310 420 510 510 590 150 240 340 420 420 490 120 140 280 280 350 120 140 280 350 Part No. EMVA350ADA151MHA0G EMVA350ADA221MHA0G EMVA350ADA331MJA0G EMVA350ARA471MKE0S EMVA350SDA102MLH0S EMVA350SDA222MMN0S EMVA500ADA3R3MD55G EMVA500ADA4R7MD55G EMVA500ADA100ME55G EMVA500ADA220MF55G EMVA500ADA330MF80G EMVA500ADA470MF80G EMVA500ADA101MHA0G EMVA500ADA221MJA0G EMVA500ARA331MKE0S EMVA500ARA471MKG5S EMVA500SDA471MLH0S EMVA500SDA102MLN0S EMVA500SDA102MMN0S EMVA630ADAR10MD55G EMVA630ADAR22MD55G EMVA630ADAR33MD55G EMVA630ADAR47MD55G EMVA630ADA1R0MD55G EMVA630ADA2R2MD55G EMVA630ADA3R3ME55G EMVA630ADA4R7ME55G EMVA630ADA100MF55G EMVA630ADA220MF80G EMVA630ADA330MHA0G EMVA630ADA470MHA0G EMVA630ADA560MJA0G EMVA630ADA680MJA0G EMVA630ARA101MKE0S EMVA630ARA221MKE0S EMVA630ARA331MKG5S EMVA630SDA331MLH0S EMVA630SDA471MLH0S EMVA630SDA471MMH0S EMVA101ADA220MHA0G EMVA101ADA330MJA0G EMVA101ARA680MKE0S EMVA101ARA101MKE0S EMVA101SDA221MLN0S EMVA101SDA221MMH0S EMVA101SDA331MMN0S EMVA161ARA470MKG5S EMVA161SDA680MLH0S EMVA161SDA101MLN0S EMVA161SDA101MMH0S EMVA201ARA220MKE0S EMVA201ARA330MKG5S EMVA201SDA470MLH0S EMVA201SDA680MLN0S EMVA201SDA680MMH0S EMVA201SDA101MMN0S EMVA251ARA100MKE0S EMVA251ARA220MKG5S EMVA251SDA330MLH0S EMVA251SDA470MLN0S EMVA251SDA470MMH0S EMVA251SDA680MMN0S EMVA401ARA4R7MKE0S EMVA401SDA100MLH0S EMVA401SDA220MLN0S EMVA401SDA220MMH0S EMVA401SDA330MMN0S EMVA451ARA4R7MKE0S EMVA451SDA100MLH0S EMVA451SDA220MLN0S EMVA451SDA330MMN0S S : Enter the appropriate terminal code. ( ) : Second standard (2/2) CAT. No. E1001J
EMVA630ADAR22MD55G 价格&库存
很抱歉,暂时无法提供与“EMVA630ADAR22MD55G”相匹配的价格&库存,您可以联系我们找货
