CP41B-ADS-CM0P0454
CP41B-ADS-CM0P0454
    CREELED
    DIP-4
    琥珀色 591nm LED 指示 - 分立 2.5V 4-DIP(0.200",5.08mm)
CP41B-ADS-CM0P0454 数据手册
PRODUCT FAMILY DATA SHEET CP41B-RxS, CP41B-AxS: P4 Red & Amber LEDs PRODUCT DESCRIPTION FEATURES APPLICATIONS P4 LEDs offer superior light output for • Size (mm): 7.6 x 7.6 • Channel Letter excellent readability in sunlight and • Amusement dependable performance. They provide • Color and Typical Dominant extremely stable light output over long Wavelength: periods of time. Red (628nm) Amber (591nm) These lamps are made with an advanced optical-grade epoxy offering superior hightemperature and high-moisture-resistance performance in vehicle signal lamps and • Viewing angles: 40°: CP41B-xDS 70°: CP41B-xFS 100°: CP41B-xHS amusement lighting. • Lead - Free • RoHS Compliant Cree LED / 4400 Silicon Drive / Durham, NC 27703 USA / +1.919.313.5330 / www.cree-led.com © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1143 REV 4 1 CP41B-RxS, CP41B-AxS: P4 RED & AMBER LEDs ABSOLUTE MAXIMUM RATINGS (TA = 25°C) Items Symbol Absolute Maximum Rating Unit Red/Amber Forward Current IF 70 Note1 mA IFP 200 mA Reverse Voltage VR 5 V Power Dissipation PD 210 mW Operation Temperature Topr -40 ~ +100 °C Storage Temperature Tstg -40 ~ +100 °C Peak Forward Current Note2 Lead Soldering Temperature Tsol Max. 260°C for 5 sec. max. (3 mm from the base of the epoxy bulb) Electrostatic Discharge Classification (MIL-STD-883E) ESD Class 2 Note: 1. A heat sink is recommended if the device is operated at ambient temperatures higher than 25°C. 2. Pulse width ≤0.1 msec, duty ≤1/10. TYPICAL ELECTRICAL & OPTICAL CHARACTERISTICS (TA = 25°C) Characteristics Color Symbol Condition Unit Minimum Typical Maximum 2.5 3.0 Forward Voltage Red/Amber VF IF = 70 mA V Reverse Current Red/Amber IR VR = 5 V μA Red λD IF = 70 mA nm 620 628 637 Amber λD IF = 70 mA nm 584 591 599 CP41B-RDS (40 degree) Φv IF = 70 mA mlm 4400 7000 Dominant Wavelength Red Luminous Flux Amber CP41B-RFS (70 degree) Φv IF = 70 mA mlm 4400 7500 CP41B-RHS (100 degree) Φv IF = 70 mA mlm 4400 8000 CP41B-ADS (40 degree) Φv IF = 70 mA mlm 4400 6500 CP41B-AFS (70 degree) Φv IF = 70 mA mlm 5500 7500 5500 8000 CP41B-AHS (100 degree) 50% Power Angle * 100 Φv IF = 70 mA mlm CP41B-RDS/ADS 2θ½ IF = 70 mA deg CP41B-RFS/AFS 2θ½ IF = 70 mA deg 70 CP41B-RHS/AHS 2θ½ IF = 70 mA deg 100 40 Continuous reverse voltage can cause LED damage. © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1143 REV 4 2 CP41B-RxS, CP41B-AxS: P4 RED & AMBER LEDs FLUX BIN LIMIT Red (70 mA) - CP41B-RDS/RFS Bin Code Amber (70 mA) - CP41B-ADS Min.(mlm) Max.(mlm) Bin Code L0 4400 5500 L0 4400 5500 M0 5500 6600 M0 5500 6600 Max.(mlm) N0 6600 8730 N0 6600 8730 P0 8730 11000 P0 8730 11000 Red (70 mA) - CP41B-RHS * Min.(mlm) Amber (70 mA) - CP41B-AFS/AHS Bin Code Min.(mlm) Max.(mlm) Bin Code Min.(mlm) Max.(mlm) L0 4400 5500 M0 5500 6600 M0 5500 6600 N0 6600 8730 N0 6600 8730 P0 8730 11000 P0 8730 11000 Q0 11000 13200 Q0 11000 13200 Tolerance of measurement of luminous flux is ±15% COLOR BIN LIMIT Red (70 mA) - CP41B-RDS/RFS/RHS * Amber (70 mA) - CP41B-ADS/AFS/AHS Bin Code Min.(nm) Max.(nm) Bin Code Min.(nm) Max.(nm) RE 620 637 A2 584 587 A3 587 590 A4 590 593 A5 593 596 A6 596 599 Tolerance of measurement of dominant wavelength is ±1 nm. VOLTAGE BIN LIMIT Red & Amber * Bin Code Min. (V) Max. (V) 23 2.0 2.2 24 2.2 2.4 25 2.4 2.6 26 2.6 2.8 27 2.8 3.0 Tolerance of measurement of voltage is ±0.05V © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1143 REV 4 3 CP41B-RxS, CP41B-AxS: P4 RED & AMBER LEDs ORDER CODE TABLE Color Viewing Angle 40° Red 70° 100° 40° Amber 70° 100° Luminous Flux (mlm) Kit Number Dominant Wavelength Min. Max. Color Bin Min.(nm) Color Bin Max.(nm) CP41B-RDS-CL0P0EE4 4400 11000 RE 620 RE 637 CP41B-RDS-CM0P0EE4 5500 11000 RE 620 RE 637 CP41B-RFS-CL0P0EE4 4400 11000 RE 620 RE 637 CP41B-RFS-CM0P0EE4 5500 11000 RE 620 RE 637 CP41B-RFS-CN0P0EE4 6600 11000 RE 620 RE 637 CP41B-RHS-CL0Q0EE4 4400 13200 RE 620 RE 637 CP41B-RHS-CM0Q0EE4 5500 13200 RE 620 RE 637 CP41B-RHS-CN0Q0EE4 6600 13200 RE 620 RE 637 CP41B-ADS-CL0P0264 4400 11000 A2 584 A6 599 CP41B-ADS-CM0P0354 5500 11000 A3 587 A5 596 CP41B-ADS-CM0P0454 5500 11000 A4 590 A5 596 CP41B-AFS-CM0Q0264 5500 13200 A2 584 A6 599 CP41B-AFS-CN0Q0354 6600 13200 A3 587 A5 596 CP41B-AFS-CN0Q0454 6600 13200 A4 590 A5 596 CP41B-AHS-CM0Q0264 5500 13200 A2 584 A6 599 CP41B-AHS-CN0Q0354 6600 13200 A3 587 A5 596 CP41B-AHS-CN0Q0454 6600 13200 A4 590 A5 596 Notes: • The above kit numbers represent order codes which include multiple flux-bin and color-bin codes. Only one flux-bin code and one color-bin code will be shipped on each reel. And single flux-bin code,single color bin-codes will not be orderable. • Please refer to the HB LED Lamp Reliability Test Standards document for reliability test conditions. • Please refer to the HB LED Lamp Soldering & Handling document for information about how to use this LED product safely. © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1143 REV 4 4 CP41B-RxS, CP41B-AxS: P4 RED & AMBER LEDs GRAPHS The data below are collected from statistical figures that do not necessarily correspond to the actual parameters of each single LED. Hence, these data will be changed without further notice.                                                                                                         © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1143 REV 4 5 CP41B-RxS, CP41B-AxS: P4 RED & AMBER LEDs GRAPHS The data below are collected from statistical figures that do not necessarily correspond to the actual parameters of each single LED. Hence, these data will be changed without further notice.                                                  © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1143 REV 4 6 CP41B-RxS, CP41B-AxS: P4 RED & AMBER LEDs MECHANICAL DIMENSIONS All dimensions are in mm. Tolerance is ±0.25 mm unless otherwise noted. An epoxy meniscus extend about 1.5 mm down the leads. All metal burr dimension is 0.2 mm max. CP41B-RDS/ADS: CP41B-RFS/AFS: NOTES RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1143 REV 4 7 CP41B-RxS, CP41B-AxS: P4 RED & AMBER LEDs MECHANICAL DIMENSIONS All dimensions are in mm. Tolerance is ±0.25 mm unless otherwise noted. An epoxy meniscus extend about 1.5 mm down the leads. All metal burr dimension is 0.2 mm max. CP41B-RHS/AHS: NOTES RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1143 REV 4 8 CP41B-RxS, CP41B-AxS: P4 RED & AMBER LEDs KIT NUMBER SYSTEM Cree LED lamps are tested and sorted into performance bins. A bin is specified by ranges of color, forward voltage, and brightness. Sorted LEDs are packaged for shipping in various convenient options. Cree LEDs are sold by order codes in combinations of bins called kits. Order codes are configured in the following manner: © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1143 REV 4 9 CP41B-RxS, CP41B-AxS: P4 RED & AMBER LEDs SOLDERING GUIDELINES The LED soldering specification is shown below(suitable for both leaded solder & lead-free solder): Manual Soldering Soldering iron 35 W max Temperature 300 ºC max Soldering time Position Solder Dipping Preheat 110 ºC max Preheat time 60 seconds max Solder-bath temperature 260 ºC Max 3 seconds max Dipping time 5 seconds max Not less than 3 mm from the base of the package. Position Not less than 3 mm from the base of the package. • Manual soldering onto the PCB is not recommended because soldering time is uncontrollable. • The recommended wave soldering is as below: 300 laminar wave Temperature ºC 250 200 150 100 50 30 0 Fluxing Preheat 10 20 30 40 50 60 70 Times (sec) 80 90 100 110 120 • Do not apply any stress to the LED package, particularly when heated. • Only bottom preheat is suggested & should not preheat on top in order to reduce thermal stress experienced by the LEDs. • The LEDs must not be re used once they have been extracted from PCB. • After soldering the LEDs, the package should be protected from mechanical shock or vibration until the LEDs have reached 40 ºC or below. • Precautions must be taken as mechanical stress on the LEDs may be caused by PCB warpage or from the clinching and cutting of the LED leads. • When it is necessary to clam the LEDs during soldering, it is important to ensure no mechanical stress is exerted on the LEDs. • Cut the LED lead at normal room temperature. Lead cutting at high temperature may cause failure of the LEDs. • Please refer to the HB LED Lamp Soldering & Handling document for information about how to use this LED product safely. © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1143 REV 4 10 CP41B-RxS, CP41B-AxS: P4 RED & AMBER LEDs PACKAGING • The LEDs are packed in cardboard boxes after packaging in normal or anti-electrostatic bags. • Cardboard boxes will be used to protect the LEDs from mechanical shock during transportation. • The boxes are not water resistant, and they must be kept away from water and moisture. • The Tube Pack type of packaging. Max 60 pcs per tube. R xxx xxx R C OL OR LED LAMP T YPE LXXXXXXXX-XXX LOT J OWAXXXXX -XX-XXX QT Y RANK P CS Iv Vf Hu e X XX XX AX XXX XXX XXX X © 2021 Cree LED. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks, and the Cree LED logo is a trademark, of Cree, Inc. CLD-CT1143 REV 4 11
CP41B-ADS-CM0P0454
物料型号:CP41B-RxS(红色)和CP41B-AxS(琥珀色)
器件简介: CREE的P4 LED提供优越的光输出,适用于在日光下具有极佳的可读性和可靠的性能。
它们在长时间内提供极其稳定的光输出。
这些灯具采用先进的光学级环氧树脂制造,具有出色的耐高温和耐潮湿性能,适用于车辆信号灯和娱乐照明。
引脚分配: - 2.3: ANODE(阳极) - 1.4: CATHODE(阴极)
参数特性: - 尺寸(mm):7.6 x 7.6 - 典型主导波长:红色(628nm),琥珀色(591nm) - 视场角度:40°(CP41B-xDS),70°(CP41B-xFS),100°(CP41B-xHS) - 无铅,符合RoHS标准 - 操作温度范围:-40~+100°C - 存储温度范围:-40~+100°C - 引线焊接温度:最大260°C,最多5秒(距离环氧泡壳底部3毫米内)
功能详解: - 正向电压:在70mA下,红色/琥珀色LED的正向电压范围为2.5V至3.0V。
- 反向电流:在5V下,红色/琥珀色LED的反向电流不超过100μA。
- 发光亮度:不同视场角度的LED具有不同的发光亮度范围,例如,CP41B-RDS(40度)在70mA下的发光亮度范围为4400至7000mlm。
应用信息: - 适用于通道字母、娱乐、信号灯等应用。
封装信息: - Cree为这些LED提供了多种封装选项,包括Ammo Pack、Tube Pack和Bulk Pack等。
- 封装尺寸公差为±0.25mm,除非另有说明。
- 环氧树脂凸出部分沿引线延伸约1.5mm。
所有金属毛刺尺寸最大为0.2mm。
焊接指南: - 焊接温度和时间:对于手动焊接,推荐使用最大35W的烙铁,最高温度300°C,焊接时间最长3秒。
- 焊接位置:距离环氧泡壳底部不少于3mm。
包装信息: - LEDs被包装在纸板箱中,以防止在运输过程中受到机械冲击。
- 纸板箱不防水,必须远离水分。
- 管装类型包装,每管最多60个。
请注意,以上信息摘自CREE的官方数据手册,具体参数可能会有变动,建议参考最新的产品数据手册或联系CREE的官方代表获取详细信息。
CP41B-ADS-CM0P0454 价格&库存
很抱歉,暂时无法提供与“CP41B-ADS-CM0P0454”相匹配的价格&库存,您可以联系我们找货
