CH601ASR
CH601ASR
    COSEMITECH(意瑞)
    SOT23-3
    霍尔线性传感器 3V~15V 1.5mV/Gs SOT23-3L
CH601ASR 数据手册
Cosemitech CH601 Automotive Product Group This is advanced information on a new product now in development or undergoing evaluation. Details are subject to change without notice and Cosemitech assumes no obligation for future manufacture of this product. Contact Cosemitech for the latest status. Draft Datasheet REV 0.4 FEATURES and FUNCTIONAL DIAGRAM • • • • • • • • • • • • • PACKAGE ⚫ Power consumption of 4 mA at 5 VDC for energy efficiency Single Current Sinking or Current Sourcing Output Linear output for circuit design flexibility Ratiometric Rail to Rail Linear Output Precise Sensitivity and Temperature Compensation Wide Operating Voltage Range: Supply Voltage 3.0~15V Sensitivity at 5V: TO-92S 1.5mV/Gauss (CH601) Specified Operating Temperature Range: From -40℃~150℃ Responds to either positive or negative gauss Quad Hall sensing element for stable output Lead Free Package: Flat TO-92, SOT-89-3L,SOT-23-3L SOT-23-3L SOT-89-3L High ESD Protection RoHS Compliant 2011/65/EU APPLICATIONS Automotive, Industrial, Home, appliances, Current sensing Speed Detection Position Detection Magnetic Encoder Solid-State Switch Ferrous metal sensing Liquid level sensing Vibration sensing Weight sensing DESCRIPTION The CH601 is high performance ratiometric linear hall effect sensor, produced with Bipolar technology; it is high performance small versatile linear Hall-effect devices which are operated by the magnetic field from a permanent magnet or an electromagnet. The ratiometric output voltage is set by the supply voltage and varies in proportion to the strength of the magnetic field. The CH601 family has a quiescent output voltage that is 50% of the supply voltage. The integrated circuitry provides increased temperature stability and sensitivity. The CH601 provide high accuracy and temperature compensation. The linear hall sensors have an operating temperature range from -40 to +150℃, appropriate for home appliances, industrial and automotive environments. They respond to either South or North pole. Page 1/9 Cosemitech CH601 Automotive Product Group . This is advanced information on a new product now in development or undergoing evaluation. Details are subject to change without notice and Cosemitech assumes no obligation for future manufacture of this product. Contact Cosemitech for the latest status. Draft Datasheet REV 0.4 Table of Contents 1. Product Family Members .............................................................................................................. 3 2. Pin Definitions and Descriptions .................................................................................................. 3 3. Absolute Maximum Ratings .......................................................................................................... 3 4. ESD Protections ............................................................................................................................ 4 5. Function Description .................................................................................................................... 4 6. Magnetic Activation ..................................................................................................................... 4 7. Transfer Characteristics ................................................................................................................ 4 8. Parameters Specification .............................................................................................................. 5 9. Typical Application Circuit ............................................................................................................ 5 10. Package Information ................................................................................................................... 6 Page 2/9 Cosemitech CH601 Automotive Product Group This is advanced information on a new product now in development or undergoing evaluation. Details are subject to change without notice and Cosemitech assumes no obligation for future manufacture of this product. Contact Cosemitech for the latest status. Draft Datasheet REV 0.4 1. Product Family Members Part Number Marking ID CH601ATB C601 CH601AER C601 CH601ASR C601 Description Linear Hall sensor IC, flat, TO-92S package, bulk packing (1000 units per bag) Linear Hall sensor IC, SOT-89-3L package, tape and reel packing (1000 units per reel) Linear Hall sensor IC, SOT-23-3L package, tape and reel packing (3000 units per reel) 2. Pin Definitions and Descriptions TO-92S (T) 1 SOT-89-3L (E) 1 SOT-23-3L (E) 1 2 2 3 3 Name Type VDD Supply Supply Voltage pin 3 GND Ground Ground pin 2 OUT Output Output pin TO-92S Function SOT-89-3L SOT-23-3L 3. Absolute Maximum Ratings Parameter Supply Voltage VDD Reverse Voltage VDD Output Voltage Symbol VDD VRDD VOUT Min -0.3 Max 15 -0.3 15 Units V V V IOUT - 5 mA Operating Ambient Temperature TA -40 150 °C Storage Temperature TS -50 150 °C Junction temperature TJ -50 165 °C Magnetic Flux B Output Current No Limit Gauss Note: Exceeding the absolute maximum ratings may cause permanent damage. Exposure to absolutemaximum- rated conditions for extended periods may affect device reliability. 4. ESD Protections Parameter Value Unit All pins 1) +/-6000 V All pins 2) +/-400 V +/-1000 V All pins 3) 1) HBM (human body mode, 100pF, 1.5 kohm ) according to MIL-STD-883H Method 3015.8 2) MM (Machine Mode C=200pF, R=0Ω) according to JEDEC EIA/JESD22-A115 3) CDM (charged device mode) according to JEDEC EIA/JESD22-C101F Page 3/9 Cosemitech CH601 Automotive Product Group . This is advanced information on a new product now in development or undergoing evaluation. Details are subject to change without notice and Cosemitech assumes no obligation for future manufacture of this product. Contact Cosemitech for the latest status. Draft Datasheet REV 0.4 5. Function Description The CH601 family MRL (Miniature Ratiometric Linear) sensors are small,versatile linear Hall effect devices which are operated by the magnetic field from a permanent magnet or an electromagnet. The ratiometric output voltage is set by the supply voltage and varies in proportion to the strength of the magnetic field. The integrated circuitry provides increased temperature stability, sensitivity and temperature compensation. These linear position sensors have an operating temperature range of -40oC to +150°C, appropriate for industrial and automotive environments. They respond to either positive or negative gauss, monitoring either or both magnetic poles. The quad Hall sensing element minimizes the effects of mechanical or thermal stress on the output. The product providing a robust design over a wide temperature range. Rail-to-rail operation (over full voltage range) provides a more usable signal for higher accuracy. The CH601 family has a typical sinking or sourcing output of 1.5 mA continuous, uses 4 mA of supply current at 5.0 volts and 25oC, and provides predictable performance over the full temperature range. The CH601 family Series sensors have wider null and sensitivity tolerances. 6. Magnetic Activation 7. Transfer Characteristics Page 4/9 Cosemitech CH601 Automotive Product Group This is advanced information on a new product now in development or undergoing evaluation. Details are subject to change without notice and Cosemitech assumes no obligation for future manufacture of this product. Contact Cosemitech for the latest status. Draft Datasheet REV 0.4 8. Parameters Specification (At VDD=5V, TA= -40 ºC to 150 ºC except where otherwise specified.) Symbo l Parameter Test Condition VDD Supply voltage -40 °C to 150 °C IDD Supply Current B=0 VH VL VNULL ISINK ISINK ISOURCE ISOURCE Output voltage Quiescent Voltage Sink Current Typ Max Units 3.0 5.0 15 V 3 6.5 mA 0.4 V B>=+1100 Gs B
CH601ASR 价格&库存
很抱歉,暂时无法提供与“CH601ASR”相匹配的价格&库存,您可以联系我们找货
