A16-700
A16-700
    JDTFUSE(集电通)
    插件,P=5.1mm
    PTC自恢复保险丝 7A 16V
A16-700 数据手册
PRODUCT DATASHEET A16 Series PTC Devices A16 Series PTC Devices Description JDTFUSE A16 Series Radial Leaded PTCs are designed to provide resettable overcurrent protection serving a wide range of electronics applications. With maximum 16 voltage and maximum 40-ampere short circuit rating,they offer an ideal solution for USB protection. Features ● 100A short circuit rating ● 16V Operating voltages ● Fast time-to-trip ● Meets all USB protection requirements ● RoHS compliant, Lead-Free and Halogen-Free* Agency Approvals Agency Applications File Number E472196 Regulation ● Computers & peripherals ● Any USB applications ● Motor protection ● General Electronics Standard 2002/95/EC EN14582 JDT FUSE Industrial Co., Ltd www.jdtfuse.com Page 1/6 Revised 06/11/19 A16 Series PTC Devices Performance Specification Model V max (V dc) I max (A) I hold I trip Pd @25°C (A) @25°C (A) Typ. (W) Maximum Time To Trip Current (A) Time (Sec) Resistance R i min R i max R1max (Ω) (Ω) (Ω) A16-030 16 40 0.30 0.60 0.30 1.50 1.00 0.300 0.900 1.30 A16-050 16 40 0.50 1.00 0.40 2.50 1.10 0.200 0.500 0.76 A16-065 16 40 0.65 1.30 0.60 3.25 5.00 0.120 0.480 0.65 A16-075 16 40 0.75 1.50 0.30 3.75 4.80 0.100 0.320 0.40 A16-090 16 40 0.90 1.80 0.60 4.50 1.20 0.090 0.180 0.25 A16-110 16 40 1.10 2.20 0.70 5.50 2.30 0.060 0.150 0.24 A16-120 16 40 1.20 2.40 0.60 6.00 5.50 0.050 0.180 0.24 A16-135 16 40 1.35 2.70 0.80 6.75 4.50 0.040 0.130 0.19 A16-160 16 40 1.60 3.20 0.90 8.00 9.00 0.030 0.110 0.20 A16-185 16 40 1.85 3.70 1.00 9.25 10.0 0.030 0.100 0.16 A16-200 16 40 2.00 4.00 2.40 10.0 15.0 0.018 0.075 0.14 A16-250 16 40 2.50 5.00 1.30 7.50 15.0 0.020 0.070 0.12 A16-300 16 40 3.00 5.10 2.30 15.0 2.00 0.020 0.070 0.11 A16-400 16 40 4.00 6.80 2.40 20.0 3.50 0.020 0.040 0.08 A16-500 16 40 5.00 8.50 2.60 25.0 3.60 0.014 0.025 0.033 A16-600 16 40 6.00 10.20 2.80 30.0 5.80 0.001 0.021 0.031 A16-700 16 40 7.00 11.90 3.00 35.0 8.00 0.008 0.015 0.022 A16-800 16 40 8.00 13.60 3.00 40.0 9.00 0.006 0.013 0.021 A16-900 16 40 9.00 15.30 3.30 40.0 12.0 0.004 0.012 0.018 A16-1000 16 40 10.00 17.00 3.60 40.0 12.5 0.004 0.011 0.015 A16-1100 16 40 11.00 18.70 3.70 40.0 13.5 0.003 0.009 0.013 A16-1200 16 40 12.00 20.40 4.20 40.0 16.0 0.003 0.008 0.012 A16-1400 16 40 14.00 23.80 4.60 40.0 20.0 0.003 0.007 0.011 I hold = Hold Current. Maximum current device will not trip in 25°C still air. I trip = Trip Current. Minimum current at which the device will always trip in 25°C still air. V max = Maximum operating voltage device can withstand without damage at rated current (Imax). I max = Maximum fault current device can withstand without damage at rated voltage (V max). Pd = Power dissipation when device is in the tripped state in 25°C still air environment at rated voltage. Ri min/max = Minimum/Maximum device resistance prior to tripping at 25°C. R1max = Maximum device resistance is measured one hour post reflow. CAUTION : Operation beyond the specified ratings may result in damage and possible arcing and flame. JDT FUSE Industrial Co., Ltd www.jdtfuse.com Page 2/6 Revised 06/11/19 A16 Series PTC Devices Environmental Specifications Conditions Test Resistance change Passive aging     +85°C, 1000 hrs. ±5% typical Humidity aging     +85°C, 85% R.H. , 168 hours ±5% typical Thermal shock     +85°C to -40°C, 20 times ±33% typical Resistance to solvent     MIL-STD-202,Method 215 No change MIL-STD-202,Method 201 No change Vibration     Ambient operating conditions : - 40 °C to +85 °C Maximum surface temperature of the device in the tripped state is 125 °C Thermal Derating Curve Derating Curves for A16 Series 1.8 Percentage of Rated Current 1.6 1.4 1.2 1.0 0.8 0.6 0.4 0.2 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 Temperature (°C ) JDT FUSE Industrial Co., Ltd www.jdtfuse.com Page 3/6 Revised 06/11/19 A16 Series PTC Devices Average Time-Current Curve A=A16-030 B=A16-050 C=A16-065 D=A16-075 E=A16-090 F=A16-110 G=A16-120 H=A16-135 I=A16-160 J=A16-185 K=A16-250 L=A16-300 M=A16-400 N=A16-500 O=A16-600 P=A16-700 Q=A16-800 R=A16-900 S=A16-1000 T=A16-1100 U=A16-1200 V=A16-1400 A TP 20~40 S Ramp-up Critical Zone TL to TP TL 217 tL Tsmax 60~150 s Temperature (°C ) Profile Feature Pb-Free Assembly Average Ramp-Up Rate 3°C/second mac. (Ts max to T p) 200 Preheat Tsmin Ramp-down ts Preheat 60~180 s 25 K L MNO PQR STUV Soldering Parameters TP 260 150 B C D E FGH I J t 25°C to peak Time Recommended reflow methods: IR, vapor phase oven, hot air oven, N2 environment for lead-free Recommended maximum paste thickness is 0.25mm Devices can be cleaned using standard industry methods and solvents. Note 1:All temperature refer to topside of the package, measured on the package body surface. Note 2: If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements. JDT FUSE Industrial Co., Ltd www.jdtfuse.com -Temperature Min(Ts min) 150°C -Temperature Max(Ts max) 200°C -Time(Ts min to Ts max) 60~180 seconds Time maintained above: -Temperature(TL) 217°C -Time(tL) 60~150 seconds Peak Temperature(Tp) 260°C Ramp-Down Rate 6°C/second max. Time 25°C to Peak Temperature 8 minutes max Storage Condition 0°C~35°C,≤70%RH Page 4/6 Revised 06/11/19 A16 Series PTC Devices Physical Dimensions(mm.) FIG A B C D E Max. Max. Typ. Min. Max. A16-030 5.50 13.0 5.10±0.5 7.6 3.1 1 A16-050 5.50 12.0 5.10±0.5 7.6 3.0 1 A16-065 6.90 12.0 5.10±0.5 7.6 3.0 1 A16-075 7.40 13.0 5.10±0.5 7.6 3.0 1 A16-090 7.40 13.0 5.10±0.5 7.6 3.0 1 A16-110 7.40 14.4 5.10±0.5 7.6 3.0 1 A16-120 7.40 14.4 5.10±0.5 7.6 3.0 2 A16-135 8.90 15.9 5.10±0.5 7.6 3.0 2 A16-160 8.90 16.7 5.10±0.5 7.6 3.0 2 A16-185 10.7 17.7 5.10±0.5 7.6 3.0 2 A16-200 8.9 14.8 5.10±0.5 7.6 3.0 2 A16-250 9.00 14.0 5.10±0.5 7.6 3.0 2 A16-300 9.00 12.0 5.10±0.5 7.6 3.0 3 A16-400 10.0 13.0 5.10±0.5 7.6 3.0 3 A16-500 10.7 17.5 5.10±0.5 7.6 3.0 3 A16-600 13.5 17.5 5.10±0.5 7.6 3.0 3 A16-700 13.5 23.0 5.10±0.5 7.6 3.0 3 A16-800 13.5 23.0 5.10±0.5 7.6 3.0 3 A16-900 15.0 24.0 5.10±0.5 7.6 3.0 3 A16-1000 18.0 26.0 5.10±0.5 7.6 3.0 3 A16-1100 18.0 26.0 5.10±0.5 7.6 3.0 3 A16-1200 22.5 28.0 5.10±0.5 7.6 3.5 3 A16-1400 24.5 30.0 10.2±0.5 7.6 3.5 3 Model PHYSICAL SPECIFICATIONS : Materials : Leads A16-030 ~ 250: Tin plated copper-clad steel,24AWG(0.51mm/0.020“ Dia.) A16-300 ~ 1100: Tin plated copper, 20AWG(0.81mm/0.032”Dia) A16-1200 ~ 1400: Tin plated copper, 18 AWG(1.0mm/0.04” Dia.) Lead Solderability : MIL-STD-202, Method 208E Device Labeling : Device is marked wiht Logo,amperage rating,voltage rating & date code. JDT FUSE Industrial Co., Ltd www.jdtfuse.com Page 5/6 Revised 06/11/19 A16 Series PTC Devices Packaging Quantity Model Reel QTY A16-030 ~ A16-600 3000 500 A16-700 ~ A16-900 1500 500 A16-1000 ~ A16-1400 - 500 Bag QTY Tape & Reel packaging per EIA468-B standard. Cross Reference Cross Reference Model Tyco / PolySwitch® Bourns / POLY-FUSE® Polytronics / EVERFUSE® A16-030 - - - A16-050 - - - A16-065 - - - A16-075 - MF-RHT070 - A16-090 RUEF090 MF-RHT090 RLD16P090BF A16-110 RUEF110 - RLD16P110BF A16-120 RUEF120 - A16-135 RUEF135 - RLD16P135BF A16-160 RUEF160 - RLD16P160BF A16-185 RUEF185 - RLD16P185BF A16-250 RUSBF250/RUEF250 - RLD16P250BF A16-300 RUEF300 MF-RG300 RLD16P300BF A16-400 RUEF400 MF-RHT450 RLD16P400BF A16-500 RUEF500 MF-RG500 RLD16P500BF A16-600 RUEF600 MF-RHT650 RLD16P600BF A16-700 RUEF700 MF-RHT750 RLD16P700BF A16-800 RUEF800 - RLD16P800BF A16-900 RUEF900 - RLD16P900BF A16-1000 RUEF1000 - RLD16P1000BF A16-1100 RUEF1100 MF-R1100 RLD16P1100BF A16-1200 RUEF1200 - RLD16P1200BF A16-1400 RUEF1400 MF-RHT1300 RLD16P1400BF “PolySwitch” is a registered trademark of Tyco Electronics. “POLY-FUSE” is a registered trademark of Littelfuse,Inc. “EVERFUSE” is a registered trademark of Polytronics Technology Corp. JDT FUSE Industrial Co., Ltd www.jdtfuse.com Page 6/6 Revised 06/11/19
A16-700 价格&库存
很抱歉,暂时无法提供与“A16-700”相匹配的价格&库存,您可以联系我们找货
A16-700
  • 10+0.91570
  • 100+0.54620
  • 500+0.38240
  • 1000+0.27310
  • 2000+0.25940
  • 10000+0.24030
库存:10032
A16-700
  • 5+0.51617
  • 50+0.41580
  • 150+0.36563
  • 500+0.29092
  • 2500+0.26079
  • 5000+0.24568
库存:10
A16-700
  • 5+0.46837
库存:47
