CKST353220-1.5UH/M
CKST353220-1.5UH/M
    CENKER(岑科)
    SMD,3.5x3.2mm
    功率电感 1.5μH ±20% 5.2A 33mΩ IND_3.5X3.2MM_SM 2.00mm 3.50 x 3.20mm
CKST353220-1.5UH/M 数据手册
● FEATURES 特性 1.磁屏蔽结构,闭合磁路,抗电磁干扰强,超低蜂鸣声,可高密度安装. 2.小体积,大电流,范围可到60A,在高频和高温环境下保持优良 的温升电流及饱和电流特性. 3.低损耗合金粉末压铸,低电阻.结构牢固,产品精准度高. 4.工作频率范围广,可达5MHz以上. 无卤环保产品. ● APPLICATIONS 用途 PAD,笔记本电脑,台式机,服务器,音箱,网通,安防,手机,智能家居等 ● PART NUMBERING SYSTEM 品名系统 ● SHAPES AND DIMENSIONS 外形尺寸 (Unit:mm) D A D B Fig 1 C Marking E C B A D Fig 2 TYPE(型号) A B C D E Fig CKST201210 2.0±0.2 1.2±0.2 1.0 Max 0.6±0.3 / 1 CKST201610 2.0±0.2 1.6±0.2 1.0 Max 0.6±0.3 / 1 CKST252010 2.5±0.2 2.0±0.2 1.0 Max 0.8±0.3 / 1 CKST252012 2.5±0.2 2.0±0.2 1.2 Max 0.8±0.3 / 1 CKST322512 3.2±0.2 2.5±0.2 1.2 Max 0.8±0.3 / 1 CKST353220 3.5±0.2 3.2±0.2 2.0 Max 0.7±0.2 / 1 CKSTT0410 4.0±0.3 4.0±0.3 1.0 Max 1.1±0.3 / 1 CKST04012P 4.4±0.35 4.2±0.25 1.2 Max 0.8±0.3 2.0±0.3 2 CKST0402 4.6±0.25 4.1±0.35 2.0 Max 0.76±0.3 1.5±0.3 2 CKST0502 5.7±0.25 5.1±0.35 2.0 Max 1.3±0.3 2.3±0.3 2 CKST0503 5.7±0.25 5.1±0.35 3.0 Max 1.3±0.3 2.3±0.3 2 CKST0603 7.4 Max 6.6±0.2 3.0 Max 1.6±0.3 3.0±0.2 2 CKST0605 7.5 Max 6.6±0.2 5.0 Max 1.6±0.3 3.0±0.2 2 CKST1003 11.6 Max. 10.1±0.3 3.0 Max 2.5±0.5 3.0±0.5 2 CKST1004 11.6 Max. 10.1±0.3 4.0 Max 2.5±0.5 3.0±0.5 2 CKST1005 11.6 Max. 10.1±0.3 5.0 Max 2.5±0.5 3.0±0.5 2 CKST1205 13.8 Max. 12.6±0.3 5.0 Max 2.7±0.7 3.0±0.5/3.5±0.5 2 CKST1206 13.8 Max. 12.6±0.3 6.0 Max 2.7±0.7 3.0±0.5/3.5±0.5 2 CKST1707 17.5±1.0 17.5 Max. 7.0 Max 2.5±0.5 11.94±0.3 2 Version B3 / Issue date:2022-4-9 ● Recommended patterns J I H H I J CKST201210 1.5 1 1.5 CKST201610 1.5 1 1.8 CKST252010 2 1.2 2.2 CKST252012 2 1.2 2.2 CKST322512 2.5 1.2 2.9 CKST353220 3 1 3.5 CKSTT0410 3.5 1.5 4.5 CKST04012P 3.7 1.26 2.5 CKST0402 3.7 1.26 2.5 CKST0502 4.1 1.9 2.8 CKST0503 4.1 1.9 2.8 CKST0603 6.05 2.35 3.5 CKST0605 6.05 2.35 3.5 CKST1003 9.5 3.5 4.0 CKST1004 9.5 3.5 4.0 CKST1005 9.5 3.5 4.0 CKST1205 10.5 4 5.5 CKST1206 10.5 4 5.5 CKST1707 13.8 3.4 12.6 TYPE(型号) ● SPECIFICATION TABLE: PART NUMBER CKST201210-0.47uH/M CKST201210-1uH/M CKST201210-2.2uH/M INDUCTANCE (μH) DCR (mΩ) @25℃ Saturation Current DC Amps. Isat(A) Heat Rating Current DC Amps. Irms (A) Typical Maximum Typical Maximum Typical Maximum 0.47±20% 26.0 31.0 6.1 5.4 4.3 4.0 1±20% 60.0 70.0 4.2 3.5 3.6 3.0 2.2±20% 125.0 145.0 2.7 2.4 2.2 2.0 ● SPECIFICATION TABLE: PART NUMBER INDUCTANCE (μH) DCR (mΩ) @25℃ Saturation Current DC Amps. Isat(A) Heat Rating Current DC Amps. Irms (A) Typical Maximum Typical Maximum Typical Maximum CKST201610-0.24uH/M 0.24±20% 18.0 21.0 6.7 6.1 5.5 5.0 CKST201610-0.33uH/M 0.33±20% 20.0 23.0 6.5 6.0 5.3 4.7 CKST201610-0.47uH/M 0.47±20% 23.0 28.0 5.6 5.0 5.0 4.5 CKST201610-0.68uH/M 0.68±20% 30.0 35.0 5.1 4.8 4.3 3.8 1±20% 43.0 49.0 4.2 4.0 4.0 3.4 CKST201610-1.5uH/M 1.5±20% 66.0 74.0 3.5 3.2 3.2 2.8 CKST201610-2.2uH/M 2.2±20% 94.0 110.0 3.0 2.7 2.7 2.5 CKST201610-3.3uH/M 3.3±20% 188.0 216.0 2.2 2.0 1.8 1.5 CKST201610-4.7uH/M 4.7±20% 250.0 280.0 2.0 1.7 1.4 1.2 CKST201610-1uH/M Remark: ● All test data is reference to 25℃ ambient. ● Test Condition:1MHz,1Vrms ● Isat: Max.Value, DC current at which the inductance drops less than 30% from its value without current; Typ. Value, DC current at which the inductance drops 30% from its value without current. ● Irms: For Max. Value, ∆T<40℃;for Typ. Value, ∆T is approximate 40℃. ● Operat between temperature range -40℃ to +125℃(Including self - temperature rise) ● Absolute maximum voltage: DC 25V ● SPECIFICATION TABLE: PART NUMBER INDUCTANCE (μH) DCR (mΩ) @25℃ Saturation Current DC Amps. Isat(A) Heat Rating Current DC Amps. Irms (A) Typical Maximum Typical Maximum Typical Maximum CKST252010-0.22uH/M 0.22±20% 15.0 19.0 8.3 8.0 5.7 5.1 CKST252010-0.33uH/M 0.33±20% 21.0 24.0 7.3 6.5 5.0 4.5 CKST252010-0.47uH/M 0.47±20% 23.0 27.0 6.1 5.6 4.8 4.3 CKST252010-0.68uH/M 0.68±20% 25.0 30.0 5.7 5.0 4.5 4.0 1±20% 40.0 46.0 4.5 4.0 3.7 3.4 CKST252010-1.5uH/M 1.5±20% 60.0 69.0 4.1 3.2 3.3 3.0 CKST252010-2.2uH/M 2.2±20% 82.0 94.0 3.5 3.0 2.5 2.2 CKST252010-4.7uH/M 4.7±20% 223.0 256.0 2.3 2.0 1.36 1.22 CKST252010L-4.7uH/M 4.7±20% 209.0 230.0 2.1 1.8 1.6 1.4 CKST252010-6.8uH/M 6.8±20% 251.0 290.0 2.1 1.8 1.3 1.1 CKST252010-10uH/M 10±20% 388.0 450.0 1.5 1.3 1.2 1.0 CKST252010-1uH/M ● SPECIFICATION TABLE: PART NUMBER INDUCTANCE (μH) DCR (mΩ) @25℃ Saturation Current DC Amps. Isat(A) Heat Rating Current DC Amps. Irms (A) Typical Maximum Typical Maximum Typical Maximum CKST252012-0.24uH/M 0.24±20% 16.0 19.0 9.0 8.5 6.4 5.6 CKST252012-0.33uH/M 0.33±20% 16.0 19.0 7.5 6.6 6.4 5.6 CKST252012-0.47uH/M 0.47±20% 21.0 24.0 6.5 5.7 4.7 4.2 CKST252012-0.68uH/M 0.68±20% 23.0 30.0 5.3 4.6 4.5 4.0 1±20% 32.0 36.0 4.8 4.3 4.1 3.6 CKST252012-1.5uH/M 1.5±20% 46.0 53.0 4.2 3.6 3.7 3.4 CKST252012-2.2uH/M 2.2±20% 70.0 84.0 3.5 3.0 2.7 2.4 CKST252012-3.3uH/M 3.3±20% 100.0 120.0 2.5 2.2 2.0 1.7 CKST252012-4.7uH/M 4.7±20% 144.0 167.0 2.4 2.0 1.8 1.6 CKST252012-6.8uH/M 6.8±20% 234.0 269.0 1.9 1.5 1.6 1.4 CKST252012-10uH/M 10±20% 310.0 360.0 1.7 1.5 1.4 1.2 CKST252012-1uH/M Remark: ● All test data is reference to 25℃ ambient. ● Test Condition:1MHz,1Vrms ● Isat: Max.Value, DC current at which the inductance drops less than 30% from its value without current; Typ. Value, DC current at which the inductance drops 30% from its value without current. ● Irms: For Max. Value, ∆T<40℃;for Typ. Value, ∆T is approximate 40℃. ● Operat between temperature range -40℃ to +125℃(Including self - temperature rise) ● Absolute maximum voltage: DC 25V ● SPECIFICATION TABLE: PART NUMBER INDUCTANCE (μH) DCR (mΩ) @25℃ Saturation Current DC Amps. Isat(A) Heat Rating Current DC Amps. Irms (A) Typical Maximum Typical Maximum Typical Maximum 0.47±20% 16.0 19.0 8.2 7.5 7.0 6.5 1±20% 26.0 30.0 6.5 5.7 5.5 5.0 CKST322512-1.5uH/M 1.5±20% 38.0 44.0 5.0 4.5 4.5 4.0 CKST322512-2.2uH/M 2.2±20% 58.0 67.0 4.5 4.0 4.1 3.7 CKST322512-3.3uH/M 3.3±20% 77.0 88.0 3.6 3.3 3.3 3.0 CKST322512-4.7uH/M 4.7±20% 102.0 115.0 3.0 2.7 3.0 2.6 CKST322512-6.8uH/M 6.8±20% 180.0 207.0 2.8 2.4 1.6 1.3 CKST322512-10uH/M 10±20% 250.0 288.0 1.9 1.5 1.0 0.9 CKST322512-0.47uH/M CKST322512-1uH/M ● SPECIFICATION TABLE: PART NUMBER INDUCTANCE (μH) DCR (mΩ) @25℃ Saturation Current DC Amps. Isat(A) Heat Rating Current DC Amps. Irms (A) Typical Maximum Typical Maximum Typical Maximum 0.47±20% 13.0 15.0 11.0 9.0 8.5 8.0 1±20% 20.0 24.0 7.5 7.0 7.0 6.6 CKST353220-1.5uH/M 1.5±20% 28.0 33.0 7.1 6.6 5.5 5.2 CKST353220-2.2uH/M 2.2±20% 33.0 40.0 6.0 5.5 5.0 4.5 CKST353220-3.3uH/M 3.3±20% 58.0 64.0 5.5 5.0 4.0 3.5 CKST353220-4.7uH/M 4.7±20% 70.0 80.0 4.2 3.7 3.5 3.2 CKST353220-6.8uH/M 6.8±20% 151.0 174.0 3.3 2.8 2.9 2.6 CKST353220-10uH/M 10±20% 175.0 200.0 3.0 2.5 2.6 2.3 CKST353220-0.47uH/M CKST353220-1uH/M Remark: ● All test data is reference to 25℃ ambient. ● Test Condition:1MHz,1Vrms ● Isat: Max.Value, DC current at which the inductance drops less than 30% from its value without current; Typ. Value, DC current at which the inductance drops 30% from its value without current. ● Irms: For Max. Value, ∆T<40℃;for Typ. Value, ∆T is approximate 40℃. ● Operat between temperature range -40℃ to +125℃(Including self - temperature rise) ● Absolute maximum voltage: DC 25V ● SPECIFICATION TABLE: PART NUMBER INDUCTANCE (μH) DCR (mΩ) @25℃ Saturation Current DC Amps. Isat(A) Heat Rating Current DC Amps. Irms (A) Typical Maximum Typical Maximum Typical Maximum 0.47±20% 17.0 20.0 8.5 7.5 7.5 6.5 1±20% 33.0 38.0 6.5 5.5 3.7 3.4 CKSTT0410-2.2uH/M 2.2±20% 58.0 67.0 5.3 4.7 3.6 3.2 CKSTT0410-4.7uH/M 4.7±20% 124.0 143.0 3.5 3.0 2.8 2.5 CKSTT0410-6.8uH/M 6.8±20% 155.0 180.0 3.0 2.5 2.3 2.1 CKSTT0410-10uH/M 10±20% 210.0 245.0 2.4 2.0 2.1 1.9 CKSTT0410-0.47uH/M CKSTT0410-1uH/M ● SPECIFICATION TABLE: PART NUMBER INDUCTANCE (μH) DCR (mΩ) @25℃ Saturation Current DC Amps. Isat(A) Heat Rating Current DC Amps. Irms (A) Typical Maximum Typical Typical CKST04012P-0.15uH/M 0.15±20% 8.0 9.0 12.0 6.8 CKST04012P-0.22uH/M 0.22±20% 8.3 11.0 8.8 6.5 CKST04012P-0.33uH/M 0.33±20% 13.5 19.0 6.7 5.7 CKST04012P-0.47uH/M 0.47±20% 16.0 21.0 5.4 5.2 CKST04012P-0.68uH/M 0.68±20% 21.0 36.0 4.8 4.2 1±20% 40.0 47.0 4.4 3.8 CKST04012P-1.5uH/M 1.5±20% 50.0 75.0 3.2 2.7 CKST04012P-2.2uH/M 2.2±20% 73.0 83.0 2.4 2.2 CKST04012P-1uH/M Remark: ● All test data is reference to 25℃ ambient. ● Test Condition:1MHz,1Vrms ● Isat: Max.Value, DC current at which the inductance drops less than 30% from its value without current; Typ. Value, DC current at which the inductance drops 30% from its value without current. ● Irms: For Max. Value, ∆T<40℃;for Typ. Value, ∆T is approximate 40℃. ● Operat between temperature range -40℃ to +125℃(Including self - temperature rise) ● Absolute maximum voltage: DC 25V ● SPECIFICATION TABLE: PART NUMBER DCR (mΩ) @25℃ INDUCTANCE (μH) Saturation Current DC Amps. Isat(A) Heat Rating Current DC Amps. Irms (A) Typical Maximum Typical Typical CKST0402-0.1uH/N 0.1±30% 3.5 4.0 25.0 12.0 CKST0402-0.22uH/M 0.22±20% 6.0 6.6 12.5 9.0 CKST0402-0.33uH/M 0.33±20% 8.7 12.5 11.0 8.0 CKST0402-0.47uH/M 0.47±20% 12.5 14.0 10.0 7.0 CKST0402-0.56uH/M 0.56±20% 14.0 16.0 8.0 6.5 CKST0402-0.68uH/M 0.68±20% 16.0 18.0 8.0 5.2 1±20% 24.0 27.0 7.0 4.5 CKST0402-1.5uH/M 1.5±20% 38.0 46.0 6.0 4.0 CKST0402-2.2uH/M 2.2±20% 52.0 58.0 5.0 3.0 CKST0402-3.3uH/M 3.3±20% 74.0 87.0 4.0 2.5 CKST0402-4.7uH/M 4.7±20% 100.0 126.0 3.0 2.2 CKST0402-6.8uH/M 6.8±20% 162.0 178.0 2.5 2.0 CKST0402-8.2uH/M 8.2±20% 188.0 216.0 2.2 1.8 CKST0402-10uH/M 10±20% 256.0 294.0 2.0 1.2 Saturation Current DC Amps. Isat(A) Heat Rating Current DC Amps. Irms (A) CKST0402-1uH/M ● SPECIFICATION TABLE: PART NUMBER DCR (mΩ) @25℃ INDUCTANCE (μH) Typical Maximum Typical Typical CKST0502-0.47uH/M 0.47±20% 7.2 10.0 12.0 7.5 CKST0502-0.68uH/M 0.68±20% 10.0 18.0 10.0 6.5 1±20% 14.0 20.0 9.0 6.0 CKST0502-1.5uH/M 1.5±20% 26.0 35.0 6.5 5.5 CKST0502-2.2uH/M 2.2±20% 32.0 45.0 6.0 4.0 CKST0502-3.3uH/M 3.3±20% 68.0 80.0 5.0 3.5 CKST0502-4.7uH/M 4.7±20% 82.0 95.0 4.0 3.0 CKST0502-5.6uH/M 5.6±20% 90.0 108.0 3.8 2.9 CKST0502-6.8uH/M 6.8±20% 108.0 130.0 3.5 2.8 CKST0502-10uH/M 10±20% 152.0 180.0 2.8 2.3 CKST0502-1uH/M Remark: ● All test data is reference to 25℃ ambient. ● Test Condition:100kHz,1Vrms ● Isat :DC current (A) that will cause L0 to drop approximately 30% Typ. ● Irms: DC current (A) that will cause an approximate △T of 40℃ ● Operat between temperature range -40℃ to +125℃(Including self - temperature rise) ● Absolute maximum voltage: DC 75V ● SPECIFICATION TABLE: PART NUMBER DCR (mΩ) @25℃ INDUCTANCE (μH) Saturation Current DC Amps. Isat(A) Heat Rating Current DC Amps. Irms (A) Typical Maximum Typical Typical CKST0503-0.22uH/M 0.22±20% 3.6 4.5 28.0 16.0 CKST0503-0.33uH/M 0.33±20% 5.0 7.0 18.0 14.0 CKST0503-0.47uH/M 0.47±20% 6.5 7.5 12.0 10.0 CKST0503-0.68uH/M 0.68±20% 11.0 12.0 12.0 8.0 1±20% 13.0 15.0 9.0 7.0 CKST0503-1.2uH/M 1.2±20% 14.0 15.0 8.8 6.5 CKST0503-1.5uH/M 1.5±20% 17.0 25.0 8.5 6.0 CKST0503-2.2uH/M 2.2±20% 27.0 35.0 8.0 5.5 CKST0503-3.3uH/M 3.3±20% 35.0 46.0 6.0 4.5 CKST0503-4.7uH/M 4.7±20% 50.0 60.0 5.0 4.0 CKST0503-6.8uH/M 6.8±20% 69.0 86.0 4.5 3.5 CKST0503-8.2uH/M 8.2±20% 80.0 105.0 4.0 3.3 CKST0503-10uH/M 10±20% 115.0 126.0 3.5 2.5 CKST0503-15uH/M 15±20% 174.0 190.0 2.2 1.8 CKST0503-22uH/M 22±20% 230.0 260.0 1.9 1.3 CKST0503-1uH/M Remark: ● All test data is reference to 25℃ ambient. ● Test Condition:100kHz,1Vrms ● Isat :DC current (A) that will cause L0 to drop approximately 30% Typ. ● Irms: DC current (A) that will cause an approximate △T of 40℃ ● Operat between temperature range -40℃ to +125℃(Including self - temperature rise) ● Absolute maximum voltage: DC 75V ● SPECIFICATION TABLE: PART NUMBER DCR (mΩ) @25℃ INDUCTANCE (μH) Saturation Current DC Amps. Isat(A) Heat Rating Current DC Amps. Irms (A) Typical Maximum Typical Typical CKST0603-0.1uH/N 0.1±30% 1.5 1.7 60.0 32.5 CKST0603-0.15uH/M 0.15±20% 1.9 2.5 50.0 30.0 CKST0603-0.22uH/M 0.22±20% 2.5 3.0 34.0 23.0 CKST0603-0.33uH/M 0.33±20% 3.0 3.5 25.0 21.0 CKST0603-0.47uH/M 0.47±20% 3.5 4.1 20.0 18.0 CKST0603-0.68uH/M 0.68±20% 5.3 5.9 17.0 16.0 CKST0603-0.82uH/M 0.82±20% 6.0 7.0 16.0 14.0 1±20% 7.0 7.5 15.0 12.0 CKST0603-1.5uH/M 1.5±20% 10.6 12.1 12.5 11.0 CKST0603-2.2uH/M 2.2±20% 15.5 17.5 10.0 8.0 CKST0603-3.3uH/M 3.3±20% 23.0 26.0 9.5 6.0 CKST0603-4.7uH/M 4.7±20% 34.5 38.0 6.5 5.0 CKST0603-6.8uH/M 6.8±20% 47.0 50.0 6.0 4.5 CKST0603-8.2uH/M 8.2±20% 58.5 65.0 6.0 4.0 CKST0603-10uH/M 10±20% 64.0 68.0 5.0 4.0 CKST0603-15uH/M 15±20% 106.0 115.0 3.8 2.6 CKST0603-22uH/M 22±20% 165.0 189.0 3.1 2.3 CKST0603-33uH/M 33±20% 250.0 270.0 2.5 2.0 CKST0603-47uH/M 47±20% 300.0 350.0 2.0 1.7 CKST0603-1uH/M Remark: ● All test data is reference to 25℃ ambient. ● Test Condition:100kHz,1Vrms ● Isat :DC current (A) that will cause L0 to drop approximately 30% Typ. ● Irms: DC current (A) that will cause an approximate △T of 40℃ ● Operat between temperature range -40℃ to +125℃(Including self - temperature rise) ● Absolute maximum voltage: DC 75V ● SPECIFICATION TABLE: PART NUMBER DCR (mΩ) @25℃ INDUCTANCE (μH) Saturation Current DC Amps. Isat(A) Heat Rating Current DC Amps. Irms (A) Typical Maximum Typical Typical 1±20% 5.6 6.5 13.0 12.0 CKST0605-1.5uH/M 1.5±20% 7.1 8.5 12.0 10.0 CKST0605-2.2uH/M 2.2±20% 11.6 13.5 10.0 7.0 CKST0605-3.3uH/M 3.3±20% 19.6 22.0 9.0 6.5 CKST0605-4.7uH/M 4.7±20% 27.0 30.0 8.0 5.7 CKST0605-6.8uH/M 6.8±20% 38.0 44.0 7.0 5.0 CKST0605-10uH/M 10±20% 46.0 55.0 6.0 4.5 CKST0605-15uH/M 15±20% 72.0 85.0 4.0 3.5 CKST0605-22uH/M 22±20% 115.0 130.0 3.2 2.8 CKST0605-33uH/M 33±20% 158.0 180.0 3.0 2.4 CKST0605-47uH/M 47±20% 260.0 290.0 2.5 2.0 CKST0605-68uH/M 68±20% 425.0 468.0 2.0 1.2 CKST0605-1uH/M Remark: ● All test data is reference to 25℃ ambient. ● Test Condition:100kHz,1Vrms ● Isat :DC current (A) that will cause L0 to drop approximately 30% Typ. ● Irms: DC current (A) that will cause an approximate △T of 40℃ ● Operat between temperature range -40℃ to +125℃(Including self - temperature rise) ● Absolute maximum voltage: DC 75V ● SPECIFICATION TABLE: PART NUMBER DCR (mΩ) @25℃ INDUCTANCE (μH) Saturation Current DC Amps. Isat(A) Heat Rating Current DC Amps. Irms (A) Typical Maximum Typical Typical CKST1003-0.22uH/M-B 0.22±20% 1.07 1.2 50.0 30.0 CKST1003-0.33uH/M-B 0.33±20% 1.3 1.6 32.0 23.0 CKST1003-0.47uH/M-B 0.47±20% 2.1 2.5 26.0 23.0 CKST1003-0.56uH/M-B 0.56±20% 2.4 3.0 24.0 22.0 CKST1003-0.68uH/M-B 0.68±20% 2.9 3.4 23.0 21.0 1±20% 5.5 6.0 21.0 15.0 CKST1003-1.5uH/M 1.5±20% 6.5 7.5 18.0 12.0 CKST1003-2.2uH/M 2.2±20% 8.0 9.0 12.0 11.0 CKST1003-3.3uH/M 3.3±20% 14.5 16.0 12.0 9.0 CKST1003-4.7uH/M 4.7±20% 20.5 25.0 10.0 7.0 CKST1003-5.6uH/M 5.6±20% 27.0 30.0 10.0 6.0 CKST1003-6.8uH/M 6.8±20% 30.0 35.0 7.5 5.5 CKST1003-8.2uH/M 8.2±20% 35.0 45.0 7.0 5.0 CKST1003-10uH/M 10±20% 50.0 55.0 6.5 4.5 CKST1003-15uH/M 15±20% 59.0 65.0 5.0 4.0 CKST1003-22uH/M 22±20% 90.0 99.0 4.0 3.0 CKST1003-1uH/M Remark: ● All test data is reference to 25℃ ambient. ● Test Condition:100kHz,1Vrms ● Isat :DC current (A) that will cause L0 to drop approximately 30% Typ. ● Irms: DC current (A) that will cause an approximate △T of 40℃ ● Operat between temperature range -40℃ to +125℃(Including self - temperature rise) ● Absolute maximum voltage: DC 75V ● SPECIFICATION TABLE: PART NUMBER DCR (mΩ) @25℃ INDUCTANCE (μH) Saturation Current DC Amps. Isat(A) Heat Rating Current DC Amps. Irms (A) Typical Maximum Typical Typical CKST1004-0.15uH/N-B 0.15±30% 0.53 0.65 45.0 75.0 CKST1004-0.22uH/M-B 0.22±20% 0.9 1.1 55.0 35.0 CKST1004-0.36uH/M-B 0.36±20% 1.05 1.2 42.0 34.0 CKST1004-0.47uH/M-B 0.47±20% 1.53 1.68 38.0 28.0 CKST1004-0.56uH/M-B 0.56±20% 1.6 1.8 32.0 27.0 CKST1004-0.68uH/M-B 0.68±20% 2.1 2.4 30.0 23.0 CKST1004-0.82uH/M-B 0.82±20% 2.7 3.9 26.0 20.0 1±20% 3.0 3.3 26.0 20.0 CKST1004-1.5uH/M-B 1.5±20% 3.8 4.2 22.0 16.0 CKST1004-2.2uH/M 2.2±20% 6.0 7.0 16.0 14.0 CKST1004-3.3uH/M 3.3±20% 10.8 11.8 13.0 11.0 CKST1004-4.7uH/M 4.7±20% 14.0 16.5 12.0 8.5 CKST1004-6.8uH/M 6.8±20% 22.5 25.0 10.0 8.0 CKST1004-8.2uH/M 8.2±20% 25.0 27.0 9.0 7.5 CKST1004-10uH/M 10±20% 27.0 30.0 7.0 6.5 CKST1004-15uH/M 15±20% 40.0 45.0 6.0 6.3 CKST1004-22uH/M 22±20% 60.0 66.0 5.5 5.0 CKST1004-33uH/M 33±20% 85.0 92.0 4.5 4.0 CKST10045-47uH/M 47±20% 130.0 150.0 4.0 3.0 CKST10045-68uH/M 68±20% 192.0 205.0 3.0 2.3 CKST1004-1uH/M-B Remark: ● All test data is reference to 25℃ ambient. ● Test Condition:100kHz,1Vrms ● Isat :DC current (A) that will cause L0 to drop approximately 30% Typ. ● Irms: DC current (A) that will cause an approximate △T of 40℃ ● Operat between temperature range -40℃ to +125℃(Including self - temperature rise) ● Absolute maximum voltage: DC 75V ● SPECIFICATION TABLE: PART NUMBER DCR (mΩ) @25℃ INDUCTANCE (μH) Saturation Current DC Amps. Isat(A) Heat Rating Current DC Amps. Irms (A) Typical Maximum Typical Typical 0.22±20% 0.6 0.8 65.0 37.0 1±20% 2.3 3.0 28.0 19.0 CKST1005-1.5uH/M-B 1.5±20% 3.2 4.0 21.0 16.0 CKST1005-1.8uH/M-B 1.8±20% 3.5 5.0 20.0 15.0 CKST1005-2.2uH/M 2.2±20% 5.5 6.6 19.0 13.0 CKST1005-3.3uH/M 3.3±20% 9.2 11.0 18.0 11.0 CKST1005-4.7uH/M 4.7±20% 12.0 15.0 15.0 10.0 CKST1005-5.6uH/M 5.6±20% 14.0 18.0 14.0 8.5 CKST1005-6.8uH/M 6.8±20% 16.0 19.2 13.0 8.0 CKST1005-10uH/M 10±20% 23.0 28.0 10.0 7.0 CKST1005-15uH/M 15±20% 35.0 42.0 7.0 6.5 CKST1005-22uH/M 22±20% 58.0 70.0 6.0 5.5 CKST1005-33uH/M 33±20% 70.0 84.0 5.0 4.5 CKST1005-47uH/M 47±20% 130.0 150.0 4.5 3.0 CKST1005-68uH/M 68±20% 185.0 205.0 3.5 2.5 CKST1005-0.22uH/M-B CKST1005-1uH/M-B Remark: ● All test data is reference to 25℃ ambient. ● Test Condition:100kHz,1Vrms ● Isat :DC current (A) that will cause L0 to drop approximately 30% Typ. ● Irms: DC current (A) that will cause an approximate △T of 40℃ ● Operat between temperature range -40℃ to +125℃(Including self - temperature rise) ● Absolute maximum voltage: DC 75V ● SPECIFICATION TABLE: PART NUMBER DCR (mΩ) @25℃ INDUCTANCE (μH) Saturation Current DC Amps. Isat(A) Heat Rating Current DC Amps. Irms (A) Typical Maximum Typical Typical CKST1205-0.33uH/M-B 0.33±20% 0.75 0.9 62.0 46.0 CKST1205-0.36uH/M-B 0.36±20% 0.77 1.1 60.0 41.0 CKST1205-0.47uH/M-B 0.47±20% 1.0 1.3 46.0 37.0 1±20% 1.9 2.5 37.0 29.0 CKST1205-1.5uH/M-B 1.5±20% 3.4 4.1 30.0 23.0 CKST1205-1.8uH/M-B 1.8±20% 3.5 4.5 26.0 18.0 CKST1205-2.2uH/M-B 2.2±20% 4.0 5.0 25.0 15.0 CKST1205-3.3uH/M 3.3±20% 7.5 9.0 20.0 12.0 CKST1205-4.7uH/M 4.7±20% 9.0 11.5 16.0 11.0 CKST1205-5.6uH/M 5.6±20% 13.0 15.0 15.0 10.5 CKST1205-6.8uH/M 6.8±20% 18.0 22.0 14.0 9.0 CKST1205-8.2uH/M 8.2±20% 19.0 24.0 13.0 8.5 CKST1205-10uH/M 10±20% 24.0 29.0 11.0 7.5 CKST1205-15uH/M 15±20% 27.0 32.0 9.0 6.0 CKST1205-22uH/M 22±20% 42.0 50.0 7.0 5.0 CKST1205-33uH/M 33±20% 60.0 84.0 6.0 3.5 CKST1205-47uH/M 47±20% 100.0 130.0 5.0 3.0 CKST1205-1uH/M-B Remark: ● All test data is reference to 25℃ ambient. ● Test Condition:100kHz,1Vrms ● Isat :DC current (A) that will cause L0 to drop approximately 30% Typ. ● Irms: DC current (A) that will cause an approximate △T of 40℃ ● Operat between temperature range -40℃ to +125℃(Including self - temperature rise) ● Absolute maximum voltage: DC 75V ● SPECIFICATION TABLE: PART NUMBER INDUCTANCE (μH) DCR (mΩ) @25℃ Saturation Current DC Amps. Isat(A) Heat Rating Current DC Amps. Irms (A) Typical Maximum Typical Typical 0.33±20% 0.58 0.8 65.0 43.0 1±20% 1.4 1.7 35.0 24.0 CKST1206-1.5uH/M-B 1.5±20% 2.5 4.0 31.0 22.0 CKST1206-2.2uH/M-B 2.2±20% 4.2 6.0 26.0 18.0 CKST1206-3.3uH/M-B 3.3±20% 5.6 9.0 23.0 12.0 CKST1206-4.7uH/M-B 4.7±20% 7.2 10.5 18.0 11.5 CKST1206-6.8uH/M 6.8±20% 10.0 13.8 15.0 11.5 CKST1206-8.2uH/M 8.2±20% 13.6 16.0 13.5 11.0 CKST1206-10uH/M 10±20% 18.0 20.7 12.5 10.0 CKST1206-15uH/M 15±20% 25.0 29.0 9.0 6.0 CKST1206-18uH/M 18±20% 30.0 35.0 8.0 5.0 CKST1206-22uH/M 22±20% 34.0 39.5 7.5 5.0 CKST1206-27uH/M 27±20% 54.0 60.0 6.5 4.0 CKST1206-33uH/M 33±20% 65.0 75.0 6.0 4.0 CKST1206-47uH/M 47±20% 80.0 90.0 5.5 3.5 CKST1206-68uH/M 68±20% 115.0 130.0 4.5 3.3 CKST1206-82uH/M 82±20% 120.0 140.0 4.0 3.0 CKST1206-100uH/M 100±20% 180.0 200.0 3.5 2.5 CKST1206-120uH/M 120±20% 210.0 235.0 3.2 2.3 CKST1206-150uH/M 150±20% 300.0 350.0 2.7 2.0 CKST1206-0.33uH/M-B CKST1206-1uH/M-B Remark: ● All test data is reference to 25℃ ambient. ● Test Condition:100kHz,1Vrms ● Isat :DC current (A) that will cause L0 to drop approximately 30% Typ. ● Irms: DC current (A) that will cause an approximate △T of 40℃ ● Operat between temperature range -40℃ to +125℃(Including self - temperature rise) ● Absolute maximum voltage: DC 75V ● SPECIFICATION TABLE: PART NUMBER DCR (mΩ) @25℃ INDUCTANCE (μH) Saturation Current DC Amps. Isat(A) Heat Rating Current DC Amps. Irms (A) Typical Maximum Typical Typical 1±20% 1.5 1.9 55.5 32.0 CKST1707-1.5uH/M 1.5±20% 2.1 2.8 40.0 23.0 CKST1707-2.2uH/M 2.2±20% 2.3 3.0 40.0 18.0 CKST1707-3.3uH/M 3.3±20% 2.9 3.2 35.0 15.0 CKST1707-4.7uH/M 4.7±20% 4.4 5.8 30.0 13.0 CKST1707-6.8uH/M 6.8±20% 6.2 8.0 22.5 10.5 CKST1707-8.2uH/M 8.2±20% 10.0 13.0 20.0 9.5 CKST1707-10uH/M 10±20% 10.0 13.0 19.0 9.5 CKST1707-15uH/M 15±20% 16.5 22.0 14.0 9.0 CKST1707-22uH/M 22±20% 20.0 26.0 12.0 8.5 CKST1707-33uH/M 33±20% 30.0 38.5 10.7 8.0 CKST1707-47uH/M 47±20% 43.0 53.0 8.7 6.0 CKST1707-56uH/M 56±20% 55.0 60.5 7.2 5.2 CKST1707-68uH/M 68±20% 58.0 79.0 6.1 4.5 CKST1707-100uH/M 100±20% 103.0 123.0 5.0 4.0 CKST1707-1uH/M Remark: ● All test data is reference to 25℃ ambient. ● Test Condition:100kHz,1Vrms ● Isat :DC current (A) that will cause L0 to drop approximately 30% Typ. ● Irms: DC current (A) that will cause an approximate △T of 40℃ ● Operat between temperature range -40℃ to +125℃(Including self - temperature rise) ● Absolute maximum voltage: DC 75V ● PACKAGING SPECIFICATION : PO P P2 D BO Maker Maker Maker ko W F BO E T AO Tape Dimension (mm) Reel Dimension (mm) Type Quantity (Pcs/Reel) Quantity (Pcs/ Carton) W A0 B0 K0 DO P A B C CKST201210 8.0 1.5 2.35 1.2 1.5 4.0 178 58 13 3000 75K CKST201610 8.0 1.95 2.35 1.2 1.5 4.0 178 58 13 3000 75K CKST252010 8.0 2.3 2.8 1.2 1.5 4.0 178 58 13 3000 75K CKST252012 8.0 2.3 2.8 1.5 1.5 4.0 178 58 13 3000 75K CKST322512 8.0 2.8 3.5 1.5 1.5 4.0 178 58 13 2000 50K CKST353220 12.0 3.7 3.9 2.2 1.5 8.0 330 100 13 3000 18K CKSTT0410 12.0 4.5 4.5 1.3 1.5 8.0 330 100 13 3000 18K CKST04012P 12.0 4.4 4.9 1.5 1.5 8.0 330 100 13 3000 18K CKST0402 12.0 4.4 5.2 2.2 1.5 8.0 330 100 13 3000 18K CKST0502 16.0 5.6 6.0 2.2 1.5 12.0 330 100 13 2000 12K CKST0503 16.0 5.6 6.0 3.3 1.5 12.0 330 100 13 1500 9K CKST0603 16.0 7.2 8.0 3.3 1.5 12.0 330 100 13 1500 9K CKST0605 16.0 7.2 8.0 5.5 1.5 12.0 330 100 13 1000 6K CKST1003 24.0 10.7 11.4 3.3 1.5 16.0 330 100 13 1000 4K CKST1004 24.0 10.7 11.4 4.3 1.5 16.0 330 100 13 1000 4K CKST1005 24.0 10.7 11.4 5.5 1.5 16.0 330 100 13 800 3.2K CKST1205 24.0 13.2 13.4 5.5 1.5 20.0 330 100 13 400 1.6K CKST1206 24.0 13.2 13.4 6.8 1.5 20.0 330 100 13 400 1.6K CKST1707 32.0 18.0 18.8 7.5 1.5 24.0 330 100 13 300 1.2K MODIFY RECORD Version Date A0 2017/9/1 A1 Content Prepared Approved 新版发行 贺军 肖中华 2017/12/1 新增1003系列 贺军 肖中华 A2 2018/6/15 新增1707系列 贺军 肖中华 A3 2018/9/20 新增0502系列 贺军 肖中华 A4 2021/4/21 变更CKST05系列载带宽度为16mm 万芳中 王其艮 A5 2021/5/26 增加CKST04012P,06012P,自制201610目录 万芳中 王其艮 B0 2021/8/5 增加CKST0401P,05012,06015,自制252010,252012目录 万芳中 王其艮 B1 2021/12/10 修改CKST20,25特性 (上1版本为仿真,此版本为实测值) , 新增 CKST322512 ,删除CKST0410,0612,0615(不具备量产) 万芳中 王其艮 B2 2022/2/9 修改CKST201610-1uH/M电阻,从45mΩ Max变更为49mΩ Max 万芳中 王其艮 B3 2022/4/9 增加CKST353220,CKSTT0410系列 万芳中 王其艮
