CKRF2179MM26-C4
CKRF2179MM26-C4
    CDK
    SOT363-6
    模拟开关芯片 1通道 单刀双掷 SOT363-6
CKRF2179MM26-C4 数据手册
DATA SHEET:CKRF2179MM26 L, S-band Middle Power SPDT Switch Applications Features   Wireless LAN (IEEE 802.11 b/g) Control voltage : VC(H) = 1.8 to 5.3 V (3.0V TYP.) VC(L) = -0.2 to 0.2 V (0V TYP.)  Low Insertion Loss : Package Lins1 = 0.30 dB TYP. @ f = 0.05 to 0.5 GHz  6-pin mini mold package Lins2 = 0.30 dB TYP. @ f = 0.5 to 1.0 GHz (2.0mm x 1.25mm x 0.9mm) Lins3 = 0.40 dB TYP. @ f = 1.0 to 2.0 GHz Lins4 = 0.45 dB TYP. @ f = 2.0 to 2.5 GHz Lins5 = 0.45 dB TYP. @ f = 2.5 to 3.0 GHz  High Isolation : Description ● The CKRF2179MM26 is a pHEMT GaAs SPDT ISL1= 39 dB TYP. @ f = 0.05 to 0.5 GHz ISL2= 33 dB TYP. @ f = 0.5 to 1.0 GHz (Single Pole Double Throw) switch. This device can operate from 0.05 to 3.0GHz, having low insertion loss and high isolation. ISL3= 27 dB TYP. @ f = 1.0 to 2.0 GHz ISL4= 26 dB TYP. @ f = 2.0 to 2.5 GHz ISL5= 23 dB TYP. @ f = 2.5 to 3.0 GHz  Handling power : Pin(0.5dB) = +32 dBm TYP. @ f = 3.0 GHz, VC(H) = 3.0 V, VC(L) = 0 V Pin Configuration And Internal Block Diagram Ordering Information Part Number CKRF2179MM26-C4 Order Number Package Marking CKRF2179MM26-C4 -pin mini mold 100 package (Pb-Free) Supplying Form ・Embossed tape 8 mm wide ・Pin 4, 5, 6 face the perforation side of the tape ・Qty 10 Kpcs/reel CDS-0008-07 Date Published Oct. 2017 Page 1 of 8 DATA SHEET:CKRF2179MM26 L, S-band Middle Power SPDT Switch Absolute Maximum Ratings (TA=+25℃, unless otherwise specified) Parameter Symbol Control Voltage Rating VC 6.0 Unit Note 1 V Pin1 +33 Note 2 dBm Pin2 +29 Note 3 dBm Operating Ambient Temperature TA -45~+85 ℃ Storage Temperature Tstg -55~+150 ℃ Input Power Note 1. |VC1 - VC2|≦6.0V 2. 3.0V≦|VC1 – VC2|≦5.0V, 0.4GHz≦f 3. 3.0V≦|VC1 – VC2|≦5.0V, 0.05GHz≦f≦0.4GHz Recommended Operating Range (TA=+25℃, unless otherwise specified) Parameter Symbol MIN. TYP. MAX. Unit f 0.05 - 3.0 GHz Switch Control Voltage (H) VC(H) +1.8 +3.0 +5.3 V Switch Control Voltage (L) VC(L) -0.2 0 +0.2 V Operating Frequency Truth Table VC1 VC2 RFC-RF1 RFC-RF2 Low High ON OFF High Low OFF ON CDS-0008-07 Page 2 of 8 DATA SHEET:CKRF2179MM26 L, S-band Middle Power SPDT Switch Electrical Characteristics 1 (TA=+25℃, VC(H)=3.0V, VC(L)=0V, Zo=50Ω, DC Block Capacitance=56pF, unless otherwise specified) Parameter Symbol Condition MIN. TYP. MAX. Unit LINS1 f=0.05 to 0.5GHz Note 1 --- 0.30 0.50 dB LINS2 f=0.5 to 1.0GHz --- 0.30 0.50 dB LINS3 f=1.0 to 2.0GHz --- 0.40 0.60 dB LINS4 f=2.0 to 2.5GHz --- 0.45 0.65 dB LINS5 f=2.5 to 3.0GHz --- 0.45 0.65 dB ISL1 f=0.05 to 0.5GHz Note 1 36 39 --- dB ISL2 f=0.5 to 1.0GHz 30 33 --- dB ISL3 f=1.0 to 2.0GHz 23 27 --- dB ISL4 f=2.0 to 2.5GHz 22 26 --- dB ISL5 f=2.5 to 3.0GHz 21 24 --- dB Input Return Loss RLin f=0.05 to 3.0GHz Note 1 15 20 --- dB Output Return Loss RLout f=0.05 to 3.0GHz Note 1 15 20 --- dB f=0.05~0.5GHz Note 1 --- +26 --- dBm f=0.5~3.0GHz --- +30 --- dBm f=0.05~0.5GHz Note 1 --- +28.5 --- dBm f=0.5~3.0GHz --- +32 --- dBm Insertion Loss Isolation 0.1dB Loss Compression Pin(0.1dB) Input Power Note 2 0.5dB Loss Compression Input Power Pin(0.5dB) Note 3 2nd Harmonics 2f0 f=3.0GHz, Pin=+20dBm --- -85 --- dBc 3rd Harmonics 3f0 f=3.0GHz, Pin=+20dBm --- -85 --- dBc 3rd Order Input Intercept IIP3 f=2.5GHz, 2-tone --- +58 --- dBm --- 2.5 --- % Point 1MHz Spacing Error Vector Magnitude EVM 802.11g, 64QAM, 54Mbps Pin≦+25dBm Switch Control Current ICONT RF none --- 1 10 uA Switching Speed TSW 50% CTL to 90/10% RF --- 50 --- ns Note 1. DC block capacitance = 1000pF at f=0.05 to 0.5GHz Note 2. Pin(0.1dB) is the measured input power level when the insertion loss increases 0.1dB more than that of the linear range. Note 3. Pin(0.5dB) is the measured input power level when the insertion loss increases 0.5dB more than that of the linear range. CDS-0008-07 Page 3 of 8 DATA SHEET:CKRF2179MM26 L, S-band Middle Power SPDT Switch Electrical Characteristics 2 (TA=+25℃, VC(H)=1.8V, VC(L)=0V, Zo=50Ω, DC Block Capacitance=56pF, unless otherwise specified) Parameter Symbol Condition MIN. TYP. MAX. Unit LINS1 f=0.05 to 0.5GHz Note 1 --- 0.30 0.50 dB LINS2 f=0.5 to 1.0GHz --- 0.30 0.50 dB LINS3 f=1.0 to 2.0GHz --- 0.40 0.60 dB LINS4 f=2.0 to 2.5GHz --- 0.45 0.65 dB LINS5 f=2.5 to 3.0GHz --- 0.45 0.65 dB ISL1 f=0.05 to 0.5GHz Note 1 36 39 --- dB ISL2 f=0.5 to 1.0GHz 30 33 --- dB ISL3 f=1.0 to 2.0GHz 23 27 --- dB ISL4 f=2.0 to 2.5GHz 22 26 --- dB ISL5 f=2.5 to 3.0GHz 21 24 --- dB Input Return Loss RLin f=0.05 to 3.0GHz Note 1 15 20 --- dB Output Return Loss RLout f=0.05 to 3.0GHz Note 1 15 20 --- dB f=0.05~0.5GHz Note 1 --- +19 --- dBm f=0.5~3.0GHz --- +23 --- dBm f=0.05~0.5GHz Note 1 --- +22 --- dBm f=0.5~3.0GHz --- +26 --- dBm Insertion Loss Isolation 0.1dB Loss Compression Input Power Note 2 0.5dB Loss Compression Input Power Pin(0.1dB) Pin(0.5dB) Note 3 Switch Control Current ICONT RF none --- 1 10 uA Switching Speed TSW 50% CTL to 90/10% RF --- 50 --- ns Note 1. DC block capacitance = 1000pF at f=0.05 to 0.5GHz Note 2. Pin(0.1dB) is the measured input power level when the insertion loss increases 0.1dB more than that of the linear range. Note 3. Pin(0.5dB) is the measured input power level when the insertion loss increases 0.5dB more than that of the linear range. CDS-0008-07 Page 4 of 8 DATA SHEET:CKRF2179MM26 L, S-band Middle Power SPDT Switch Evaluation Circuit Note C0: 0.05 to 0.5 GHz 1000pF :0.4 to 3.0 GHz 56pF The application circuits and their parameters are for reference only and are not intended for use in actual design-ins. This device is used it is necessary to use DC Block Capacitance. Package Dimensions 6-pin mini mold (Unit : mm) CDS-0008-07 Page 5 of 8 DATA SHEET:CKRF2179MM26 L, S-band Middle Power SPDT Switch PCB Layout Footprint 6-pin mini mold (Unit : mm) The PCB Layout Footprint in this document is for reference only. CDS-0008-07 Page 6 of 8 DATA SHEET:CKRF2179MM26 L, S-band Middle Power SPDT Switch [CAUTION] ・ All information included in this document is current as of the date this document is issued. Such information, however, is subject to change without any prior notice. ・ You should not alter, modify, copy, or otherwise misappropriate any CDK product, whether in whole or in part. ・ CDK does not assume any liability for infringement of patents, copyrights, or other intellectual property rights of third parties by or arising from the use of CDK products or technical information described in this document. No license, express, implied or otherwise, is granted hereby under any patents, copyrights or other intellectual property rights of CDK or others. ・ Descriptions of circuits, software and other related information in this document are provided only to illustrate the operation of semiconductor products and application examples. You are fully responsible for the incorporation of these circuits, software, and information in the design of your equipment. CDK assumes no responsibility for any losses incurred by you or third parties arising from the use of these circuits, software, or information. ・ CDK has used reasonable care in preparing the information included in this document, but CDK does not warrant that such information is error free. CDK assumes no liability whatsoever for any damages incurred by you resulting from errors in or omissions from the information included herein. ・ Although CDK endeavors to improve the quality and reliability of its products, semiconductor products have specific characteristics such as the occurrence of failure at a certain rate and malfunctions under certain use conditions. Please be sure to implement safety measures to guard them against the possibility of physical injury, and injury or damage caused by fire in the event of the failure of a CDK product, such as safety design for hardware and software including but not limited to redundancy, fire control and malfunction prevention, appropriate treatment for aging degradation or any other appropriate measures Because the evaluation of microcomputer software alone is very difficult, please evaluate the safety of the final products or system manufactured by you. ・ Please use CDK products in compliance with all applicable laws and regulations that regulate the inclusion or use of controlled substances, including without limitation, the EU RoHS Directive. CDK assumes no liability for damages or losses occurring as a result of your noncompliance with applicable laws and regulations. ・ This document may not be reproduced or duplicated, in any form, in whole or in part, without prior written consent of CDK. ・ Please contact a CDK if you have any questions regarding the information contained in this document or CDK products, or if you have any other inquiries. CDS-0008-07 Page 7 of 8 DATA SHEET : CKRF2179MM26 L, S-band Middle Power SPDT Switch [Caution in the gallium arsenide (GaAs) product handling] This product uses gallium arsenide (GaAs) of the toxic substance appointed in laws and ordinances. GaAs vapor and powder are hazardous to human health if inhaled or ingested. ・ Do not dispose in fire or break up this product. ・ Do not chemically make gas or powder with this product. ・ When discard this product, please obey the law of your country. ・ Do not lick the product or in any way allow it to enter the mouth. [CAUTION] Although this device is designed to be as robust as possible, ESD (Electrostatic Discharge) can damage this device. This device must be protected at all times from ESD. Static charges may easily produce potentials of several kilovolts on the human body or equipment, which can discharge without detection. Industry-standard ESD precautions should be used at all times. CHUO DENSHI KOGYO CO., LTD 3400, Matsubase-machi Koyama, Uki-shi, Kumamoto, 869-0512, JAPAN Tel : +81-964-32-2730 Fax : +81-964-32-3549 URL : http://www.en.cdk.co.jp/ Contact info for inquiries Electronic Devices Division Sales and Planning Depertment TEL : +81-964-32-2750 E-mail : info@cdk.co.jp FAX : +81-964-32-3549 CDS-0008-07 Page 8 of 8 © 2017 CHUO DENSHI KOGYO CO., LTD. All rights reserved.
CKRF2179MM26-C4 价格&库存
很抱歉,暂时无法提供与“CKRF2179MM26-C4”相匹配的价格&库存,您可以联系我们找货
CKRF2179MM26-C4
    • 5+1.05268
    • 50+0.83495
    • 150+0.74164
    • 500+0.62522
    • 2500+0.50544
    • 5000+0.47434
    库存:7286
