TS03-66-95-BK-260-LCR-D-67 数据手册
Additional Resources:
Product Page
3D Model
PCB Footprint
date
08/05/2022
page 1 of 4
SERIES: TS03 | DESCRIPTION: TACTILE SWITCH
FEATURES
• IP67
• long crimped pins
• through hole
SPECIFICATIONS
parameter
conditions/description
min
rated voltage
typ
1
rated current
0.01
withstanding voltage
for 1 minute
contact resistance
applying load of 2 times operating force at 5 Vdc, 10 mA
insulation resistance
at 100 Vdc for 1 minute
operating force
see force table
max
units
12
Vdc
50
250
mA
Vac
100
100
mΩ
MΩ
actuator travel
0.15
0.35
mm
operating temperature
-30
80
°C
-40
90
°C
storage temperature
life
rated load, 2 cycles/second, 1.5 times operating force
160 gf models
260 gf models
vibration
10~55~10 Hz, 1.5 mm amplitude, 2 hours on each XYZ
flammability rating
see material table
RoHS
yes
IP level
IP67
0.25
80,000
60,000
cycles
cycles
SOLDERABILITY
parameter
max
units
hand soldering
for maximum 3 seconds
min
typ
350
°C
wave soldering
for maximum 5 seconds
260
°C
PART NUMBER KEY
TS03 - 66 - XX - BK - XXX - LCR - D - 67
Base Number
Actuator Height:
50 = 5.0 mm
70 = 7.0 mm
80 = 8.0 mm
95 = 9.5 mm
cuidevices.com
Push Force:
160 = 160 gf
260 = 260 gf
Product Page
3D Model
PCB Footprint
CUI DEVICES | SERIES: TS03 | DESCRIPTION: TACTILE SWITCH
date 08/05/2022 | page 2 of 4
MECHANICAL DRAWING
units: mm
tolerance: ±0.2 mm
unless otherwise noted
ITEM
DESCRIPTION
MATERIAL
PLATING/COLOR
1
terminals
brass
silver
2
case
PA66 (UL94HB)
black
3
contacts
stainless steel
silver
4
waterproof silicone
silica gel
black
5
cover
PA66 (UL94V-0)
black
6
stem
PA66 (UL94HB)
yellow
+s
ACTUATOR POSITION
( ): MOMENTARY
s
s
s
Recommended PCB Layout
Top View
Operting Force Table
Model
Press Force (N)
Return Force (N)
160
1.6±0.5
>0.2
260
2.6±0.5
>0.2
cuidevices.com
DOWN
OFF
(ON)
SCHEMATIC
s
s
NORMAL
Product Page
3D Model
PCB Footprint
date 08/05/2022 | page 3 of 4
PACKAGING
units: mm
Bag Size: 190 x 160 mm
Carton Box Size: 445 x 350 x 280 mm
Bag QTY: 1,000 pcs per bag
Carton Box QTY: 60,000 pcs per carton
A=160mmǃB=190mm
C=160mmǃD=216mmǃE=48mm
X=350mmǃY=455ǃZ=280mm
cuidevices.com
Product Page
3D Model
PCB Footprint
date 08/05/2022 | page 4 of 4
REVISION HISTORY
rev.
description
date
1.0
initial release
09/20/2021
1.01
logo, datasheet style update
08/05/2022
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
TS03-66-95-BK-260-LCR-D-67 价格&库存
很抱歉,暂时无法提供与“TS03-66-95-BK-260-LCR-D-67”相匹配的价格&库存,您可以联系我们找货
