Additional Resources:
Product Page
date
08/05/2022
page 1 of 4
MODEL: HD04-19-TH-TR | DESCRIPTION: HDMI RECEPTACLE
• HDMI receptacle connector
• 19 position
• HDMI 2.1
• through hole
• reflow solder compatible
• tape & reel packaging
SPECIFICATIONS
parameter
conditions/description
rated voltage
min
typ
TI
rated current
N
UE
D
FEATURES
max
units
40
Vac
0.5
A
30
50
mΩ
mΩ
insulation resistance
unmated: at 500 Vdc between adjacent terminals
mated: at 150 Vdc between adjacent terminals
100
10
MΩ
MΩ
voltage withstand
unmated: for 1 minute between adjacent terminals
500
300
Vac
Vac
insertion force
ON
contact resistance
contact: dry circuit at 20 mV / 10 mA max
shell: open circuit at 5 V / 100 mA max
at 25±3 mm per minute
withdrawal force
life
9.8
at a rate of 100±50 cycles/hour
operating temperature
operating humidity
N
N
10,000
-20
non-condensing
flammability rating
44.1
39.2
cycles
85
°C
95
UL94V-0
RoHS
yes
SC
SOLDERABILITY
min
typ
max
units
wave soldering
see reflow profile
260
265
270
°C
DI
Temperature (°C)
parameter
Time (sec)
cuidevices.com
Product Page
CUI DEVICES | MODEL: HD04-19-TH-TR | DESCRIPTION: HDMI RECEPTACLE
date 08/05/2022 | page 2 of 4
MECHANICAL DRAWING
MATERIAL
PLATING
1
insulator
LCP (UL94V-0)
black
2
shell
brass
nickel
contact area: 0.025 µm gold;
solder area: tin
N
UE
D
units: mm
tolerance:
X.X ±0.30 mm
X.XX ±0.20 mm
X.XXX ±0.10 mm
PCB: ±0.05 mm
PCB thickness: 1.0~1.80 mm
unless otherwise noted
contacts
phosphor bronze
DI
SC
ON
TI
3
PIN CONNECTIONS
PIN
Recommended PCB Layout
Top View
cuidevices.com
SIGNAL
NAME
PIN
SIGNAL
NAME
1
TMDS data 2+
11
TMDS clock shield
2
TMDS data 2 shield
12
TMDS clock-
3
TMDS data 2-
13
CEC
4
TMDS data 1+
14
Not Connected
5
TMDS data 1 shield
15
DDC clock
6
TMDS data 1-
16
DDC data
7
TMDS data 0+
17
GND
8
TMDS data 0 shield
18
+5V power
9
TMDS data 0-
19
Hot plug detect
10
TMDS clock+
Product Page
date 08/05/2022 | page 3 of 4
PACKAGING
DI
SC
ON
TI
Reel Size: Ø330 mm
Reel QTY: 500 pcs per reel
Carton Size: 430 x 340 x 340 mm
Carton QTY: 5,000 pcs per carton
N
UE
D
units: mm
cuidevices.com
Product Page
date 08/05/2022 | page 4 of 4
REVISION HISTORY
rev.
description
date
initial release
09/29/2021
logo, datasheet style update
08/05/2022
N
UE
D
1.0
1.01
DI
SC
ON
TI
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“HD04-19-TH-TR”相匹配的价格&库存,您可以联系我们找货
