CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: PIFE20161B-000
REVISION
: A3
PAGE
: 1 OF 3
Power Choke Coil PIFE20161B type
Features
High performance (Isat) realized by metal dust core.
Low profile 2.0 mm x 1.6 mm x 1.2 mm
Low loss realized with low DCR
100% lead (Pb) free meet RoHS standard
Application
DC/DC converter for CPU in Notebook PC
Cellular phones, LCD displays, HDDs, DVCs, DSCs, PDAs etc..
Thin type on-board power supply module for exchanger
VRM for server
Outline Dimensions
L
W
P
Code
Dimensions
L
2.0 ± 0.2
W
1.6 ± 0.2
T
1.2 Max.
P
0.5 ± 0.2
Unit : mm
T
Recommend Land Pattern Dimensions
The customer shall determine the land dimensions shown below after confirming and safety.
B
A
C
A
1.6
B
0.9
C
2.3
Unit : mm
Nov., 2014
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: PIFE20161B-000
REVISION
: A3
PAGE
: 2 OF 3
Specifications
Part Number
PIFE20161B-R22MS
PIFE20161B-R24MS
PIFE20161B-R33MS
PIFE20161B-R47MS
PIFE20161B-R50MS
PIFE20161B-1R0MS
PIFE20161B-1R5MS
PIFE20161B-2R2MS
L0
Inductance
( µH )
@ (0A)
0.22
0.24
0.33
0.47
0.5
1.0
1.5
2.2
Heat Rating Current
DC Amps. Idc ( A )
Saturation Current
DC Amps. Isat ( A )
Maximum
Typical
Maximum
Typical
Maximum
16
21
33
36
39
72
112
186
5.2
4.5
3.9
3.5
3.3
2.4
1.9
1.5
4.68
4.0
3.5
3.1
3.0
2.2
1.7
1.35
5.7
5.3
4.6
3.9
3.7
2.9
2.4
2.1
5.1
4.77
4.0
3.5
3.4
2.61
2.16
1.70
Rdc ( mΩ)
Typical
13
17
27
30
32
60
93
155
:If you require another part number please contact with us.
**:Inductance Tolerance ± 20%
Note 1.: All test data is referenced to 25℃ ambient.
Note 2.: Test Condition:1MHz, 1.0Vrms
Note 3.: Idc : DC current (A) that will cause an approximate △T of 40℃
Note 4.: Isat : DC current (A) that will cause L0 to drop approximately 30%
Note 5.: Operating Temperature Range -55℃ to + 125℃
Note 6.: The part temperature (ambient + temp rise ) should not exceed 125℃ under the worst case operating
conditions. Circuit design, component placement, PWB trace size and thickness, airflow and other
cooling provision all affect the part temperature. Part temperature should be verified in the end
Note 7.
application.
The rated current as listed is either the saturation current or the heating current depending on which value
is lower.
Nov., 2014
CYNTEC CO., LTD.
乾坤科技股份有限公司
: 3 OF 3
0.10
TEMP RISE (
40
0.05
INDUCTANCE(µH)
0.15
TEMP RISE (
0.10
40
7.0
0.00
8.0
PIFE20161B-R33MS
0.35
100
0.60
80
0.50
0.28
60
INDUCTANCE(µH)
0.21
TEMP RISE (
40
0.14
0.07
0.7
1.4
2.1
0.60
2.8
3.5 4.2
DC BIAS(Amps)
4.9
5.6
6.3
0.30
TEMP RISE (
0.20
40
0.00
0.6
1.2
1.8
2.4 3.0 3.6 4.2
DC BIAS(Amps)
4.8
5.4
6.0
80
1.2
60
INDUCTANCE(µH)
0.8
TEMP RISE (
40
0.4
0.3
0.6
0.9
1.2 1.5 1.8 2.1
DC BIAS(Amps)
2.4
2.7
3.0
100
60
0.30
INDUCTANCE(µH)
0.20
TEMP RISE (
40
1.0
1.5
2.0 2.5 3.0 3.5
DC BIAS(Amps)
4.0
4.5
5.0
5.5
100
PIFE20161B-1R0MS
80
0.8
60
0.6
INDUCTANCE(µH)
TEMP RISE (
0.4
40
0.4
0.8
1.2
1.6
2.0
2.4
DC BIAS(Amps)
2.8
3.2
3.6
4.0
PIFE20161B-2R2MS
2.4
100
1.6
8.0
0.10
6.6
PIFE20161B-1R5MS
2.0
7.0
0.2
6.0
80
1.2
TEMP RISE( )
60
INDUCTANCE(µH)
3.0
4.0
5.0
DC BIAS(Amps)
PIFE20161B-R47MS
0.0
80
0.40
2.0
0.00
100
0.50
1.0
0.40
7.0
PIFE20161B-R50MS
INDUCTANCE(µH)
0.42
6.0
INDUCTANCE(µH)
3.0
4.0
5.0
DC BIAS(Amps)
INDUCTANCE(µH)
2.0
TEMP RISE( )
1.0
TEMP RISE( )
INDUCTANCE(µH)
80
0.20
TEMP RISE( )
60
0.15
100
TEMP RISE( )
TEMP RISE( )
0.20
TEMP RISE( )
INDUCTANCE(µH)
PAGE
0.25
80
0.0
INDUCTANCE(µH)
: A3
PIFE20161B-R24MS
0.30
100
0.25
INDUCTANCE(µH)
REVISION
100
2.0
80
1.6
60
1.2
INDUCTANCE(µH)
0.8
TEMP RISE (
40
0.0
0.5
1.0
1.5
DC BIAS(Amps)
2.0
TEMP RISE( )
PIFE20161B-R22MS
0.30
INDUCTANCE(µH)
: PIFE20161B-000
Current Characteristic
INDUCTANCE(µH)
DOCUMENT
2.5
Nov., 2014
很抱歉,暂时无法提供与“PIFE20161B-R47MS”相匹配的价格&库存,您可以联系我们找货
