13.10 [0.516]
5.10 [0.201]
1.90 [0.075]
12.80 [0.504]
6.20 [0.244]
12.35 [0.486]
Flat(F)
14.50 [0.571]
12.50 [0.492]
5.10 [0.201]
7.10 [0.280]
6.95 [0.273]
8.65 [0.341]
14.20 [0.559]
1.23 [0.048]
1.94 [0.076]
1.90 [0.075]
12.80 [0.504]
6.20 [0.244]
12.35 [0.486]
12.80 [0.504]
8.00 [0.315]
1.00 [0.039]
0.70 [0.028]
1
1.60 [0.063]
1.95 [0.077]
9-0.40 [0.016]
Pin #
SIGNAL NAME
MATING
SEQUENCE
DESCRIPTION
1
VBUS
POWER
SECOND
2
D-
THIRD
3
D+
USB 2.0
DIFFERENTIAL PAIR
4
GND
GROUND FOR POWER RETURN
SECOND
5
StdA_SSRX-
SUPERSPEED RECEIVER
DIFFERENTIAL PAIR
LAST
6
StdA_SSRX+
7
GND_DRAIN
GROUND FOR SIGNAL RETURN
8
StdA_SSTX-
9
SUPERSPEED TRANSMITTER
DIFFERENTIAL PAIR
StdA_SSTX+
Shell
Shield
CONNECTOR METAL SHELL
7
2
6
3
5
4
0.60 [0.024]
2.50 [0.099]
PCB
Scrolls(S)
Material
Housing Material: LCP, UL94V-0, blue
Contact Terminal: Copper Alloy
U231-09XN-4BLRA00-X
Metallic Shell:SPCC
Plating
1:Au 1U"
Underplating: Nickel
5:Au 15U"
S:Scrolls F:Flat
6:Au 30U"
Contact Plating: 1µ" Gold
Solder Tail: 100µ" Min. Tin
Metallic Shell: Nickel
Electrical
Voltage Rating: 100 V AC
Current Rating: 0.25A (Signal pins 2,3,5,6,7,8,9) 1.8A (Power Pins 1,4)
Contact Resistance: 30mΩ Max.
Insulation resistance: 1000MΩ Min.
Dielectric withstanding voltage: 100V AC/Minute
Mechanical
Durability: 1500 cycles
Mating Force: 35N (3.57Kgf) Max
Unmating Force: 10N (1.02Kgf) Min. initial, 8N min after test
Environmental and Processing
Operating Temperature: -40°C to +85°C
FRIST
X
X
X
MARK
8
9
8-1.00 [0.039]
12.50 [0.492]
6.95 [0.273]
8.65 [0.341]
14.20 [0.559]
DATE
DESCRIPTION
REVISIONS
www.xk-dg.cn
www.helloxkb.com
REVISED
APPROVED
ANGLAR
L≤4
4
U231-091N-4BLRA00-F 价格&库存
很抱歉,暂时无法提供与“U231-091N-4BLRA00-F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.00848
- 50+1.59560
- 150+1.36944
- 450+1.03382
- 2700+0.94537
- 4950+0.89220
