PSPMAF0515-1R0M-CGF-AP
    PROD(谱罗德)
    SMD,5.7x5.2mm
    功率电感 1μH ±20% 7A 24mΩ IND_5.7X5.2MM_SM 1.30mm 5.70 x 5.20mm
PSPMAF0515-1R0M-CGF-AP 数据手册
Version: 1.0 SPECIFICATION FOR APPROVAL ITEM P/N PSPMAF0515-1R0M-CGF-AP TEST INSTRUMENT Zentech-3305 / Zentech502BC PRODUCT SMD Inductor TEST FREQUENCY 100 kHz / 1.0V CUSTOMER : CUSTOMER P/N : DESCRIPTION : P/N SMD INDUCTOR : PSPMAF0515-1R0M-CGF-AP REVISION NO. : Version: 1.0 DATE : 2016-1-13 NOTES : STANDARD DOCUMENTED APPROVED Kevin CHECKED Peter PREPARED Ben CUSTOMER APPROVAL company seals PROD TECHNOLOGY CO., LTD. E-LIVEN TECHNOLOGY CO., LTD. NO.28 HO-CHENG RD, BADE CITY, TAOYUAN, TAIWAN Version: 1.0 SPECIFICATION FOR APPROVAL ITEM P/N PSPMAF0515-1R0M-CGF-AP TEST INSTRUMENT Zentech-3305 / Zentech502BC PRODUCT SMD Inductor TEST FREQUENCY 100 kHz / 1.0V Version REVISON ITEM 1.0 First Version BEFORE REVISON PROD TECHNOLOGY CO., LTD. AFTER REVISON DATE 2016-1-13 E-LIVEN TECHNOLOGY CO., LTD. NO.28 HO-CHENG RD, BADE CITY, TAOYUAN, TAIWAN Version: 1.0 COIL SPECIFICATION ITEM P/N PSPMAF0515-1R0M-CGF-AP TEST INSTRUMENT Zentech-3305 / Zentech502BC PRODUCT SMD Inductor TEST FREQUENCY 100 kHz / 1.0V PACKING DIMENSIONS (mm) 0515 Dimensions A B C D E 5.7±0.5 5.2±0.3 1.3±0.2 2.5±0.3 1.0±0.5 C G F - A Description EXPLANATION OF PART NUMBERS P S P M A Serial Codes F 0 5 1 5 Size - 1 R 0 M Inductance - P ELECTRICAL CHARACTERISTICS @ 26 ℃ Ambient Temperture Lo (μH) TOLERANCE Typical Heat Rating DC Current (A) (Idc) 1.00 ±20% 7 INDUCTANCE ITEM P/N PSPMAF051 5-1R0MCGF-AP Typical Saturation DC Current (A) (Isat) DCR mΩ @ 25℃ MAX 8.5 24.0 ¥           All test Data is referenced to 25℃ ambient ¥           Typical Heat Rating DC Current would cause an approximately △T of 40℃ ¥           Typical Saturation DC Current would cause Lo to drop approximately 20% ¥           Operation Temperature Range :  -40℃ ~ 125℃ ¥           The Part temperature (ambient + △T) should not exceed 125℃ under worst case operating conditions. ¥           Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions all effect the part temperature. Part temperature should be verified in the end application. Page: PROD TECHNOLOGY CO., LTD. 1 E-LIVEN TECHNOLOGY CO., LTD. NO.28 HO-CHENG RD, BADE CITY, TAOYUAN, TAIWAN Version: 1.0 CHARACTERISTICS ITEM P/N PSPMAF0515-1R0M-CGF-AP TEST INSTRUMENT Zentech-3305 / Zentech502BC PRODUCT SMD Inductor TEST FREQUENCY 100 kHz / 1.0V CONNECTIONS ◎ Inductor Contents ONE (1) Set(s) of Coil ◎ DC/AC Currnet Shall Be Introduced By Any One of Two Pads PERFORMANCE CURVES RECOMMENDED SOLDERING TEMP. GRAPH ℃        A B C D E 260℃ 230℃ 10 Sec 150℃ 60~240 Sec  Page: PROD TECHNOLOGY CO., LTD. 2 E-LIVEN TECHNOLOGY CO., LTD. NO.28 HO-CHENG RD, BADE CITY, TAOYUAN, TAIWAN CHARACTERISTICS Version: 1.0 ITEM P/N PSPMAF0515-1R0M-CGF-AP TEST INSTRUMENT Zentech-3305 / Zentech502BC PRODUCT SMD Inductor TEST FREQUENCY 100 kHz / 1.0V MECHANICAL RELIABILITY TEST Specification & Requirement Solderability Method Used The surface of terminal/pin tested shall Solder heat proof: be covered with new solder by 95% Preheating: 180 ±10℃ 90 seconds Soldering: 255 ±5℃ for 3 ±1 sec Shock Inductance change within ± 5% Without Drop down with 981m/s2 (100G) shock mechanical damage Attitude upon a rubber block method shock  testing machinem, 3 tests. Vibration Inductance change within ± 5% Without Vibration frequency: mechanical damage 10Hz to 55Hz to 10Hz 60 seconds cycle Vibration time: 2 hours ENDURANCE RELIABILITY TEST Specification & Requirement Thermal Shock Method Used Inductance change within ± 5% Without -25℃, (30 mins) -> room temp. (5 mins) -> mechanical damage 125℃, (30 mins) -> room temp. (5 mins) 100 cycles Heat Resistance Humidity Resistance Low Temp. Storing High Temp. Storing Inductance change within ± 5% Without Apply IDC current @ 85℃ ambient mechanical damage Duration: 1000 hrs Inductance change within ± 5% Without Apply IDC current @ 60℃ ambient mechanical damage Humidity: 90~95% Duration: 1000 hrs Inductance change within ± 5% Without Storing Temp. mechanical damage -25 ±2 ℃ for total 1,000 +4/-0 hours Inductance change within ± 5% Without Storing Temp. mechanical damage 125 ±2 ℃ for total 1,000 +4/-0 hours Page: PROD TECHNOLOGY CO., LTD. 3 E-LIVEN TECHNOLOGY CO., LTD. NO.28 HO-CHENG RD, BADE CITY, TAOYUAN, TAIWAN Version: 1.0 PACKING FOR SMD ITEM P/N PSPMAF0515-1R0M-CGF-AP TEST INSTRUMENT Zentech-3305 / Zentech502BC PRODUCT SMD Inductor TEST FREQUENCY 100 kHz / 1.0V CARRIERTAPEING REEL & CARRIER MATERIALS (PAPER PLASTICS) UNIT : (mm) Standard Quantity for Packaging: 3,500 pcs/Reel Page: PROD TECHNOLOGY CO., LTD. 4 E-LIVEN TECHNOLOGY CO., LTD. NO.28 HO-CHENG RD, BADE CITY, TAOYUAN, TAIWAN TESTING REPORT Version: 1.0 ITEM P/N PSPMAF0515-1R0M-CGF-AP TEST INSTRUMENT Zentech-3305 / Zentech502BC PRODUCT SMD Inductor TEST FREQUENCY 100 kHz / 1.0V TEST DATA SPEC A B C D E (mm) (mm) (mm) (mm) (mm) 1.3±0.2 2.5±0.3 1.0±0.5 24 1.00 ≈70% L(0) 5.7±0.5 5.2±0.3 No. DCR INDUCTANCE Max( mΩ )L(0) ± 20% 8.5 A 1 5.71 5.23 1.46 2.53 1.12 20.4 1.02 PASS 2 5.73 5.26 1.42 2.51 1.13 21.5 1.03 PASS 3 5.72 5.24 1.43 2.56 1.12 21.6 1.06 PASS 4 5.71 5.28 1.42 2.51 1.14 20.3 1.02 PASS 5 5.73 5.31 1.43 2.55 1.15 20.5 1.05 PASS 6 5.74 5.36 1.44 2.53 1.16 21.6 0.99 PASS 7 5.76 5.26 1.42 2.56 1.12 21.2 0.95 PASS 8 5.78 5.24 1.43 2.58 1.12 20.6 0.94 PASS 9 5.77 5.29 1.42 2.54 1.15 21.5 0.95 PASS 10 5.72 5.23 1.44 2.53 1.13 20.6 1.02 PASS X 5.74 5.27 1.43 2.54 1.13 20.98 1.00 R 0.07 0.13 0.04 0.07 0.04 1.30 0.12 ¥           All test Data is referenced to 25℃ ambient Page: PROD TECHNOLOGY CO., LTD. 5 E-LIVEN TECHNOLOGY CO., LTD. NO.28 HO-CHENG RD, BADE CITY, TAOYUAN, TAIWAN ANNOUNCEMENTS 产品注意事项 使用本产品时,请注意以下事项 © 产品保存期限为12个月,保存条件:温度5~40℃,湿度10~80%RH以内,超过保存期限可能会使 产品端子电极发生氧化。 © 请勿在极端环境下使用和保存(高盐,强酸,强碱,强辐射等)。 © 产品焊接前,请进行预热;预热温度与焊接温度之间温差建议控制在150℃以内。 © 产品焊接后需重新拆卸焊接修正时,请遵循规格书规定的条件范围;过高的加热温度以及反复的拆 卸可能会导致产品失效。 © 产品焊接到线路板后,请注意不可因线路板整体变形或局部变形而施加给电感剩余应力,这可能 会导致电感发生破裂,脱落,以致失效。 © 产品请勿接触清洗剂,酒精等液体,这会侵蚀产品本体,从而导致产品失效。 © 产品通电后温度会随电流的增大而上升,设计时请务必考虑留有余量。 © 过高的静电会对产品产生永久性损害,请注意静电防护。 © 产品通电过程请勿触摸产品任何部位,防止触电。 © 本产品作为磁性产品,设计时请务必考虑周边元器件与本产品可能产生的相互影响。 © 本产品适用于一般电子设备,如:AV设备,通信设备,家电产品,娱乐设备,计算机设备,个人设备,办 公设备,计测设备,工业机器人等。且该一般电子设备需在常规的操作和使用方法环境下使用。 对于需要高度安全性和可靠性的,或者因本产品失效造成设备故障,误操作,运转不良等危及到人的生命 身体及财产安全,以及对社会产生较大不良影响的特殊用途,设计使用前务必同本公司沟通,设计使用者 如在未取得我司书面同意状况下使用造成任何后果,我司不予承担。特殊用途包含但不限定如下清单: 1 军用设备 8 关系到国防安全的设备 2 运输设备(汽车,轨道交通产品,船舶等) 9 防灾赈灾设备 3 航空,航天设备 10 各种安规设备 4 发电控制设备 11 紧急救护设备 5 核动力相关设备 12 其他被认定为特殊用途的设备 6 爆炸引燃控制设备 7 交通控制设备 Page: 6 PROD TECHNOLOGY CO., LTD. E-LIVEN TECHNOLOGY CO., LTD. NO.28 HO-CHENG RD, BADE CITY, TAOYUAN, TAIWAN
PSPMAF0515-1R0M-CGF-AP 价格&库存
很抱歉,暂时无法提供与“PSPMAF0515-1R0M-CGF-AP”相匹配的价格&库存,您可以联系我们找货
    • 5+1.83152
    • 50+1.44379
    • 150+1.27758
    • 500+1.07022
    • 3500+0.87098
    • 7000+0.81558
    库存:3354
