CO75H4-50.000-33GDTST
    HCI(杭晶)
    SMD7050_4P
    有源晶振 50MHz ±20ppm 3.3V SMD7050_4P SMT 15pF
CO75H4-50.000-33GDTST 数据手册
SUZHOU HANGJING ELEC&TECH CO.,LTD 苏州杭晶电子科技有限公司 产 品 规 格 书 Product Specification 客户: CUSTOMER CUSTOMER PN HANG CRYSTAL P/N 客户 PN: 杭晶物料编码: 产品型号: MODEL CO75H4-50.000-33GDTST Oscillator SMD 7x5, HCMOS, 3.3V NOMINAL FREQUENCY 频率: 50.000MHz ISSUE DATE 日期: 2021 / 11 / 18 CUSTOMER’S APPROVAL APPROVED QA Peter Y. James J 客户确认 SUZHOU HANGJING ELEC&TECH CO.,LTD 苏州杭晶电子科技有限公司 (PLEASE RETURN A COPY WITH APPOVAL) (请将确认的复印件返回我司) Revision 1 2 3 4 HCI-FRM-Spec-2 Description / ECN Initial release Not issued Not issued Not issued No. 207, Blk. B, Chenlei Science & Technology Park, No. 1, First Qunxing Road, Suzhou Industrial Park, Jiangsu, China TEL.86 (0)512 65916689 FAX 86 (0)512 65918005 Prepared MB CO75H4-50.000-33GDTST_RevA.doc Approved James Jiang Date 2021-11-18 Page 1 of 5 SUZHOU HANGJING ELEC&TECH CO.,LTD 苏州杭晶电子科技有限公司 1. MAXIMUM RATINGS, OPERATING AND STORAGE CONDITIONS PARAMETER SYMB. MIN 1 Maximum voltage range VMAX –0.5 2 Nominal supply voltage VCC 2.97 3 Output load capacitance CL 4 Operating temperature range TOP –40 5 Storage temperature range TST –55 6 Enable / Disable function E/D (→ Output TRISTATE) TYP MAX 3.3 Unit Conditions / Remarks +5 VDC Between VCC and GND 3.63 VDC -- pF HCMOS 15PF +85 °C -- 125 °C -- 15 +25 Pin 1 = HIGH → Output pin 3 is enabled Note 1 Pin 1 = LOW → Output pin 3 is disabled (high impedance) Note 1: Output pin 3 is enabled when E/D input pin 1 is left open (floating). 2. ELECTRICAL PARAMETER LIMITS PARAMETER SYMB. 1 Nominal frequency MIN TYP MAX 50.000 FN Unit Conditions / Remarks MHz -- 2 Frequency tolerance ∆f/FN –20 +20 ppm Offset from FN at +25°C 3 Frequency stability (overall) ∆f/FN –50 +50 ppm Note 1 4 Aging first year ∆f/FA1 –3.0 +3.0 ppm at +25°C 5 Output voltage level HIGH VOH 2.97 VDC HCMOS level 90%VCC MIN 6 Output voltage level LOW VOL 0.33 VDC HCMOS level 10%VCC MAX 7 Output amplitude rise time tR 6.0 ns At 20~80%VCC /+25°C 8 Output amplitude fall time tF 6.0 ns At 80~20%VCC / +25°C 55 % At 50%VCC / 15pF / +25°C 9 Output amplitude symmetry DC 45 10 Phase Jitter RMS jRMS 0.5 ps At 20kHz~20MHz / +25°C 11 Current consumption ICC 10 mA With output load CL ±10% 12 Standby current ISTB 10 µA Output disabled (pin 1 = LOW) 13 Startup time tSTRT 5 ms VP-P reach >90% of amplitude Note 1: Including tolerance at +25°C, deviations over operating temperature range, input voltage changes, output load changes, shock and vibration. 3. PRODUCT MARKING 1 FF.fff Nominal frequency in MHz (three digits after decimal point) 2 HCI 3 Y 4 HCI YM .FF.fff Company logo Year code of manufacturing (see table below) Year 2021 2022 2023 2024 2025 2026 2027 2028 2029 2030 2031 2032 Code V W X Y Z A B C D E F G Jun Jul Aug Sep Oct Nov Dec M Month HCI-FRM-Spec-2 Month code of manufacturing (see table below) Jan Feb Mar Apr May CO75H4-50.000-33GDTST_RevA.doc Page 2 of 5 SUZHOU HANGJING ELEC&TECH CO.,LTD 苏州杭晶电子科技有限公司 Code A B C D E F G H J K L M 4. OUTLINE DRAWING Package descriptions Package model Remarks 1 Ceramic seam seal SMD package 7x5mm with 4 pads for CSO7050p4 h14 With E/D function on pin 1 Oscillator 5. RELIABILITY TEST INFORMATION Test item Test method Criteria 1 Temperature Cycle (GB/T2423.22-2002, Method Nb) 10 cycles from -55°C to +125°C. Tested after 24±2h at room temperature. ±5.0ppm 2 Low Temperature Storage (GB/T 2423.12001, Method Aa) 72h at -55°C±3°C constant temperature. Tested after 24±2h at room temperature. ±5.0ppm 3 High Temperature Storage(GB/T 2423.22001, Method Ba) 72h at +125°C±3°C constant temperature. Tested after 24±2h at room temperature. ±5.0ppm 4 Humidity (GB/T 2423.3-2006, Method Cab) 96h at +40 °C ± 3 °C, with 90± 3% RH. Tested after 24±2h at room temperature. ±5.0ppm 5 Vibration (GB/T 2423.10-1995, Method Fc) Apply 0.75mm vibration at frequency 10~500 Hz, for 2h. 10 cycles in each direction of 3 axis, test after 1h. ±5.0ppm 6 Shock (GB/T 2423.5-1995,Method Ea) Peak 1000m/s2, with 6ms half sine wave, 3.7m/s, in 3 perpendicular axis, 3 cycles /direction, test after 1h. ±5.0ppm 7 Drop (GB/T 2423.8-1995, M. Ed) Free drop onto wooden plate from 1.0 m height for 3times. ±5.0ppm 8 Solderability (GB/T2423.28-2005, Method Tc) Dip into 245 ± 5℃ solder bath for 2 ± 0.5 seconds. Inspection under 8-12X magnifier. 9 Terminal Strength (JIS-C-6429 Method 1 & Mount on a glass-epoxy board (100x50x1.6mm), then bend to 2mm 2) displacement (velocity 1mm/sec) and keep for 5 seconds. or pulling force 0.5 kg for at least 60seconds HCI-FRM-Spec-2 CO75H4-50.000-33GDTST_RevA.doc >95% cover. No damage Page 3 of 5 SUZHOU HANGJING ELEC&TECH CO.,LTD 苏州杭晶电子科技有限公司 10 Resistance to Solder Heat (GB/T 2423.28-2005,Test Tb Meth. 1B) Reflow at Preheat to 150°C±5°C for 60 to 120sec,and peak 265°C±5°C for 10s±3sec, Tested after 24±2h at room temp. ±5.0ppm 6. ENVIRONMENTAL COMPLIANCE INFORMATION Compliance information 1 RoHS This product is fully RoHS compliant, 6/6 compliant per EU legislation. 2 RoHS 2 This product is RoHS compliant per DIRECTIVE 2015/863 (also called RoHS10). In regards of CE marking directive for finished products, we can provide RoHS test reports and MDS to show compliance, but since our product is not a final application we have no CE mark. 3 Lead-Free This product is considered Lead-Free, Lead (Pb) contamination is controlled to be below 200ppm. 4 Halogen-Free This product is compliant to IEC 61249-2-21:2003 (Br
CO75H4-50.000-33GDTST 价格&库存
很抱歉,暂时无法提供与“CO75H4-50.000-33GDTST”相匹配的价格&库存,您可以联系我们找货
