SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS
TM
Alchip
MVE
Series
・Endurance : 1,000 to 2,000 hours at 105℃
・Case size range :φ4×5.2L to φ18×21.5L
・Solvent resistant type except 100 to 450Vdc (see PRECAUTIONS AND GUIDELINES)
・RoHS Compliant
・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information.
MVE
Standard, 105℃
Longer life
MVL P117
MVJ P119
◆SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
-40 to +105℃
6.3 to 450Vdc
(at 20℃, 120Hz)
±20%(M)
Rated voltage (Vdc)
6.3 to 100V
160 to 450V
D55 to JA0
I=0.01CV or 3μA, whichever is greater (2 minutes)
KE0 to MN0
I=0.03CV or 4μA, whichever is greater (1 minute)
I=0.04CV+100μA (1minute)
Where, I : Max. leakage current (μA), C : Nominal capacitance (μF), V : Rated voltage (V)
(at 20℃)
See STANDARD RATINGS
(at 20℃, 120Hz)
Rated voltage (Vdc)
6.3V 10V 16V 25V 35V 50V 63V 100V 160 to 250V 400 to 450V
Z(-25℃)/Z(+20℃)
4
3
2
2
2
2
2
3
D55 to JA0
Z(-40℃)/Z(+20℃) 12
8
6
4
3
3
3
4
Z(-25℃)/Z(+20℃)
5
4
3
2
2
2
2
2
3
6
KE0 to MN0
(at 120Hz)
Z(-40℃)/Z(+20℃) 10
8
6
4
3
3
3
3
6
10
The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for the specified
period of time at 105℃.
Size code
D55 to F80
HA0 to MN0
Time
1,000 hours
2,000 hours
Capacitance change
≦±30% of the initial value
≦±20% of the initial value
D.F. (tanδ)
≦300% of the initial specified value
≦200% of the initial specified value
Leakage current
≦The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours (500 hours
for B55 to F80 size) at 105℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage
according to Item 4.1 of JIS C 5101-4.
Size code
D55 to F80
HA0 to MN0
Capacitance change
≦±25% of the initial value
D.F. (tanδ)
Leakage current
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
Endurance
Shelf Life
◆DIMENSIONS [mm]
Code : A
to MN0
●Size code : D55
Vent
(Except D55 to HA0)
●Terminal
●Size
Code : G (Vibration resistant structure)
Size code
code : LH0 to MN0
W
0.3max.
Vent
0.3max.
L±0.3 (Note)
A±0.2
L±0.5
A±0.2
P
C±0.2
B±0.2
P
C±0.2
B±0.2
φD±0.5
W
φD±0.5
●Terminal
Note : L±0.5 for HA0 to MN0
: Dummy terminals
◆MARKING
D55 to JA0
Ex)16V22µF
Size code
1000
25V
D55 to JA0
◆PART NUMBERING SYSTEM
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
A
4.3
5.3
6.6
6.6
8.3
10.3
13.0
13.0
17.0
17.0
19.0
19.0
B
4.3
5.3
6.6
6.6
8.3
10.3
13.0
13.0
17.0
17.0
19.0
19.0
C
5.1
5.9
7.2
7.2
9.0
11.0
13.7
13.7
18.0
18.0
20.0
20.0
P
1.0
1.4
1.9
1.9
3.1
4.5
4.2
4.2
6.5
6.5
6.5
6.5
W
0.5 to 0.8
0.5 to 0.8
0.5 to 0.8
0.5 to 0.8
0.7 to 1.1
0.7 to 1.1
1.0 to 1.3
1.0 to 1.3
1.0 to 1.3
1.0 to 1.3
1.0 to 1.3
1.0 to 1.3
・Frequency Multipliers
0V
MVE
22
16V
L
5.2
5.2
5.2
7.7
10.0
10.0
13.5
16.0
16.5
21.5
16.5
21.5
D
4
5
6.3
6.3
8
10
12.5
12.5
16
16
18
18
◆RATED RIPPLE CURRENT MULTIPLIERS
KE0 to MN0
Ex)25V1,000µF
7hE
D55
E55
F55
F80
HA0
JA0
KE0
KG5
LH0
LN0
MH0
MN0
16
17
18
E MV E AAA A AA AAA M AAA N
KE0 to MN0
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 4.7µF:4R7,100µF:101)
Taping·Tray code
Terminal code (A, G)
Voltage code (ex. 6.3V:6R3,100V:101,450V:451)
Series code
Category
Capacitance(µF)
Frequency(Hz)
1.0
2.2 to 10
22 to 1,500
3.3 to 4.7
10 to 68
100 to 1,000
2,200 to 6,800
120
1.00
1.00
1.00
1.00
1.00
1.00
1.00
1k
1.50
1.30
1.05
1.75
1.50
1.30
1.05
10k
1.75
1.40
1.08
2.30
1.75
1.40
1.08
100k
1.80
1.50
1.08
2.50
1.80
1.50
1.08
The endurance of capacitors is reduced with internal
heating produced by ripple current at the rate of halving
the lifetime with every 5℃ rise.
When long life performance is required in actual use, the
rms ripple current has to be reduced.
Please refer to "Product code guide (surface mount type)"
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
94
Downloaded from Arrow.com.
CAT. No. E1001Q
TM
AIchip
Standard, 105℃
MVESeries
◆STANDARD RATINGS
WV
(Vdc)
6.3
10
16
25
35
Cap
(µF)
22
33
47
100
220
330
470
680
1,000
1,500
2,200
2,200
3,300
3,300
4,700
4,700
6,800
6,800
22
33
47
100
150
220
330
470
1,000
2,200
2,200
3,300
3,300
4,700
4,700
10
22
33
47
100
150
220
330
470
680
1,000
1,000
2,200
2,200
3,300
3,300
10
22
33
47
100
150
220
330
470
1,000
1,000
2,200
2,200
4.7
10
22
47
100
150
220
Size code tanδ
D55
E55
E55
F55
F80
HA0
HA0
HA0
JA0
JA0
KE0
LH0
KG5
MH0
LN0
MH0
LN0
MN0
E55
E55
F55
F55
F80
F80
HA0
HA0
JA0
KG5
LH0
LH0
MH0
LN0
MN0
D55
E55
F55
F55
F55
F80
F80
HA0
HA0
JA0
KE0
LH0
LH0
MH0
LN0
MH0
E55
F55
F55
F55
F80
HA0
HA0
JA0
JA0
LH0
MH0
LN0
MN0
D55
E55
F55
F80
F80
HA0
JA0
0.30
0.30
0.30
0.30
0.45
0.40
0.45
0.45
0.40
0.45
0.40
0.40
0.42
0.42
0.44
0.44
0.48
0.48
0.24
0.24
0.24
0.30
0.35
0.35
0.35
0.35
0.35
0.36
0.36
0.38
0.38
0.40
0.40
0.20
0.20
0.20
0.20
0.26
0.28
0.28
0.28
0.28
0.28
0.30
0.30
0.32
0.32
0.34
0.34
0.16
0.16
0.16
0.16
0.18
0.18
0.18
0.16
0.18
0.26
0.26
0.28
0.28
0.14
0.14
0.14
0.16
0.16
0.16
0.16
is not solvent resistant.
Rated ripple
current
(mArms/
105℃, 120Hz)
Part No.
22
34
38
69
120
290
320
340
410
550
680
840
850
1,000
1,200
1,200
1,200
1,350
30
34
48
69
100
120
290
320
410
750
850
1,000
1,100
1,300
1,350
17
30
45
48
69
100
120
290
320
470
550
650
950
1,000
1,200
1,200
27
44
50
60
100
240
320
450
490
820
880
1,250
1,300
16
27
44
80
100
260
375
EMVE6R3ADA220MD55G
EMVE6R3ADA330ME55G
EMVE6R3ADA470ME55G
EMVE6R3ADA101MF55G
EMVE6R3ADA221MF80G
EMVE6R3ADA331MHA0G
EMVE6R3ADA471MHA0G
EMVE6R3ADA681MHA0G
EMVE6R3ADA102MJA0G
EMVE6R3ADA152MJA0G
EMVE6R3ARA222MKE0S
EMVE6R3□DA222MLH0S
EMVE6R3ARA332MKG5S
EMVE6R3□DA332MMH0S
EMVE6R3□DA472MLN0S
EMVE6R3□DA472MMH0S
EMVE6R3□DA682MLN0S
EMVE6R3□DA682MMN0S
EMVE100ADA220ME55G
EMVE100ADA330ME55G
EMVE100ADA470MF55G
EMVE100ADA101MF55G
EMVE100ADA151MF80G
EMVE100ADA221MF80G
EMVE100ADA331MHA0G
EMVE100ADA471MHA0G
EMVE100ADA102MJA0G
EMVE100ARA222MKG5S
EMVE100□DA222MLH0S
EMVE100□DA332MLH0S
EMVE100□DA332MMH0S
EMVE100□DA472MLN0S
EMVE100□DA472MMN0S
EMVE160ADA100MD55G
EMVE160ADA220ME55G
EMVE160ADA330MF55G
EMVE160ADA470MF55G
EMVE160ADA101MF55G
EMVE160ADA151MF80G
EMVE160ADA221MF80G
EMVE160ADA331MHA0G
EMVE160ADA471MHA0G
EMVE160ADA681MJA0G
EMVE160ARA102MKE0S
EMVE160□DA102MLH0S
EMVE160□DA222MLH0S
EMVE160□DA222MMH0S
EMVE160□DA332MLN0S
EMVE160□DA332MMH0S
EMVE250ADA100ME55G
EMVE250ADA220MF55G
EMVE250ADA330MF55G
EMVE250ADA470MF55G
EMVE250ADA101MF80G
EMVE250ADA151MHA0G
EMVE250ADA221MHA0G
EMVE250ADA331MJA0G
EMVE250ADA471MJA0G
EMVE250□DA102MLH0S
EMVE250□DA102MMH0S
EMVE250□DA222MLN0S
EMVE250□DA222MMN0S
EMVE350ADA4R7MD55G
EMVE350ADA100ME55G
EMVE350ADA220MF55G
EMVE350ADA470MF80G
EMVE350ADA101MF80G
EMVE350ADA151MHA0G
EMVE350ADA221MJA0G
WV
(Vdc)
35
50
63
100
160
200
250
400
450
Cap
(µF)
330
470
470
1,000
1,000
2,200
1.0
2.2
3.3
4.7
10
33
47
100
220
330
330
470
470
1,000
1.0
2.2
3.3
4.7
10
22
33
47
100
220
220
330
330
470
470
22
33
47
68
100
100
220
220
330
33
47
68
68
100
10
22
33
47
47
68
4.7
10
22
33
33
47
4.7
10
22
3.3
4.7
10
22
Size code tanδ
JA0
KE0
LH0
LH0
MH0
MN0
D55
D55
D55
E55
F55
F80
F80
HA0
JA0
KE0
LH0
LH0
MH0
MN0
D55
D55
E55
F55
F55
F80
HA0
HA0
JA0
KE0
LH0
LH0
MH0
LN0
MH0
HA0
JA0
KE0
KE0
KE0
LH0
LN0
MH0
MN0
KE0
LH0
LN0
MH0
LN0
KE0
KG5
LH0
LN0
MH0
MN0
KE0
KG5
LH0
LN0
MH0
MN0
KG5
LH0
MN0
KE0
KG5
LH0
MN0
0.16
0.22
0.22
0.22
0.22
0.24
0.12
0.12
0.12
0.12
0.12
0.14
0.14
0.14
0.14
0.18
0.18
0.18
0.18
0.18
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.14
0.14
0.14
0.14
0.14
0.14
0.12
0.12
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.20
0.20
0.20
0.20
0.20
0.20
0.20
Rated ripple
current
(mArms/
105℃, 120Hz)
450
520
650
750
1,000
1,450
8.0
12
15
65
80
230
375
500
600
700
750
1,200
8.0
12
17
22
32
58
140
170
310
470
560
700
750
900
900
100
150
250
300
380
450
750
750
980
95
260
320
320
380
80
110
220
270
270
330
65
105
180
230
230
280
50
85
130
40
50
85
130
Part No.
EMVE350ADA331MJA0G
EMVE350ARA471MKE0S
EMVE350□DA471MLH0S
EMVE350□DA102MLH0S
EMVE350□DA102MMH0S
EMVE350□DA222MMN0S
EMVE500ADA1R0MD55G
EMVE500ADA2R2MD55G
EMVE500ADA3R3MD55G
EMVE500ADA4R7ME55G
EMVE500ADA100MF55G
EMVE500ADA330MF80G
EMVE500ADA470MF80G
EMVE500ADA101MHA0G
EMVE500ADA221MJA0G
EMVE500ARA331MKE0S
EMVE500□DA331MLH0S
EMVE500□DA471MLH0S
EMVE500□DA471MMH0S
EMVE500□DA102MMN0S
EMVE630ADA1R0MD55G
EMVE630ADA2R2MD55G
EMVE630ADA3R3ME55G
EMVE630ADA4R7MF55G
EMVE630ADA100MF55G
EMVE630ADA220MF80G
EMVE630ADA330MHA0G
EMVE630ADA470MHA0G
EMVE630ADA101MJA0G
EMVE630ARA221MKE0S
EMVE630□DA221MLH0S
EMVE630□DA331MLH0S
EMVE630□DA331MMH0S
EMVE630□DA471MLN0S
EMVE630□DA471MMH0S
EMVE101ADA220MHA0G
EMVE101ADA330MJA0G
EMVE101ARA470MKE0S
EMVE101ARA680MKE0S
EMVE101ARA101MKE0S
EMVE101□DA101MLH0S
EMVE101□DA221MLN0S
EMVE101□DA221MMH0S
EMVE101□DA331MMN0S
EMVE161ARA330MKE0S
EMVE161□DA470MLH0S
EMVE161□DA680MLN0S
EMVE161□DA680MMH0S
EMVE161□DA101MLN0S
EMVE201ARA100MKE0S
EMVE201ARA220MKG5S
EMVE201□DA330MLH0S
EMVE201□DA470MLN0S
EMVE201□DA470MMH0S
EMVE201□DA680MMN0S
EMVE251ARA4R7MKE0S
EMVE251ARA100MKG5S
EMVE251□DA220MLH0S
EMVE251□DA330MLN0S
EMVE251□DA330MMH0S
EMVE251□DA470MMN0S
EMVE401ARA4R7MKG5S
EMVE401□DA100MLH0S
EMVE401□DA220MMN0S
EMVE451ARA3R3MKE0S
EMVE451ARA4R7MKG5S
EMVE451□DA100MLH0S
EMVE451□DA220MMN0S
□ : Enter the appropriate terminal code.
95
CAT. No. E1001Q
