NRF52805-CAAA-R
NRF52805-CAAA-R
    NORDIC(北欧)
    WLCSP28_2.48X2.46MM
    2.4G无线芯片 1.7V~3.6V 2.4GHz 2Mbps 4dBm -97dBm
NRF52805-CAAA-R 数据手册
nRF52805 Product Specification v1.2 4454_187 v1.2 / 2020-07-02 Feature list Features: • ® Bluetooth 5.0, 2.4 GHz transceiver • • 192 kB flash and 24 kB RAM • Advanced on-chip interfaces • -97 dBm sensitivity in 1 Mbps Bluetooth Low Energy mode • -20 to +4 dBm TX power, configurable in 4 dB steps • Programmable peripheral interconnect (PPI) • On-air compatible with nRF52, nRF51, nRF24L, and nRF24AP Series • 10 general purpose I/O pins • Supported data rates: • EasyDMA automated data transfer between memory and • • ® peripherals ® • Bluetooth 5.0 - 2 Mbps, 1 Mbps • Proprietary 2.4 GHz – 2 Mbps, 1 Mbps Single-ended antenna output (on-chip balun) • 4.6 mA peak current in TX (0 dBm) • 4.6 mA peak current in RX • RSSI (1 dB resolution) ® ® ® 144 EEMBC CoreMark score running from flash memory • 34.4 µA/MHz running CoreMark from flash memory • 32.8 µA/MHz running CoreMark from RAM • Serial wire debug (SWD) Nordic SoftDevice ready with support for concurrent multiprotocol • Temperature sensor • 12-bit, 200 ksps ADC – 2 configurable channels with programmable gain Arm Cortex -M4 32-bit processor, 64 MHz • • Flexible power management • 1.7 V to 3.6 V supply voltage range • On-chip DC/DC and LDO regulators with automated low current modes • Fast wake-up using 64 MHz internal oscillator • 0.3 µA at 3 V in System OFF mode, no RAM retention • 0.5 µA at 3 V in System OFF mode with full 24 kB RAM retention • 1.1 µA at 3 V in System ON mode, with full 24 kB RAM retention, wake on • 3x 32-bit timer with Counter mode • SPI master/slave with EasyDMA • I2C compatible two-wire master/slave • UART (CTS/RTS) with EasyDMA • Quadrature decoder (QDEC) • AES HW encryption with EasyDMA • 2x real-time counter (RTC) • Single crystal operation • Package variants • WLCSP package, 2.482 x 2.464 mm RTC (running from LFXO clock) • 1.0 µA at 3 V in System ON mode, no RAM retention, wake on RTC (running from LFXO clock) Applications: • Proprietary protocol devices • Health monitoring • Network processor • Drug delivery • Beacons • Asset tags • Smart Home sensors • Toys • Presenters/Stylus • Retail tags and labels 4454_187 v1.2 ii Contents Feature list. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ii 1 Revision history. 2 About this document. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 10 2.1 Document status . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.2 Peripheral chapters . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.3 Register tables . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.3.1 Fields and values . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.3.2 Permissions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.4 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.4.1 DUMMY . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 10 10 11 11 11 11 3 Block diagram. 13 4 Core components. 5 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 4.1 CPU . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.1.1 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.1.2 CPU and support module configuration . . . . . . . . . . . . . . . . . . . . . 4.2 Memory . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.2.1 RAM - Random access memory . . . . . . . . . . . . . . . . . . . . . . . . 4.2.2 Flash - Non-volatile memory . . . . . . . . . . . . . . . . . . . . . . . . . 4.2.3 Memory map . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.2.4 Instantiation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.3 NVMC — Non-volatile memory controller . . . . . . . . . . . . . . . . . . . . . . 4.3.1 Writing to flash . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.3.2 Erasing a page in flash . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.3.3 Writing to user information configuration registers (UICR) . . . . . . . . . . . . . 4.3.4 Erasing user information configuration registers (UICR) . . . . . . . . . . . . . . . 4.3.5 Erase all . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.3.6 Partial erase of a page in flash . . . . . . . . . . . . . . . . . . . . . . . . . 4.3.7 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.3.8 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.4 FICR — Factory information configuration registers . . . . . . . . . . . . . . . . . . 4.4.1 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.5 UICR — User information configuration registers . . . . . . . . . . . . . . . . . . . 4.5.1 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.6 EasyDMA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.6.1 EasyDMA error handling . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.6.2 EasyDMA array list . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.7 AHB multilayer . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.8 Debug . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.8.1 DAP - Debug access port . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.8.2 CTRL-AP - Control access port . . . . . . . . . . . . . . . . . . . . . . . . . 4.8.3 Debug interface mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.8.4 Real-time debug . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 14 14 15 16 16 16 17 18 18 18 19 19 19 19 19 23 23 23 31 31 34 35 36 36 37 38 38 40 40 Power and clock management. 41 . . . . . . . . . . . . . . . . . . . . . . . 5.1 Power management unit (PMU) . . . . . . . . . . . . . . . . . . . . . . . . . . 41 4454_187 v1.2 iii 6 5.2 Current consumption . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.2.1 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.3 POWER — Power supply . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.3.1 Regulators . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.3.2 System OFF mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.3.3 System ON mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.3.4 Power supply supervisor . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.3.5 RAM power control . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.3.6 Reset . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.3.7 Retained registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.3.8 Reset behavior . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.3.9 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.3.10 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.4 CLOCK — Clock control . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.4.1 HFCLK clock controller . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.4.2 LFCLK clock controller . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.4.3 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.4.4 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . . 41 42 46 47 48 49 49 51 51 52 52 53 59 60 61 62 65 71 Peripherals. 73 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.1 Peripheral interface . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.1.1 Peripheral ID . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.1.2 Peripherals with shared ID . . . . . . . . . . . . . . . . . . . . . . . . . . 6.1.3 Peripheral registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.1.4 Bit set and clear . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.1.5 Tasks . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.1.6 Events . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.1.7 Shortcuts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.1.8 Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.2 AAR — Accelerated address resolver . . . . . . . . . . . . . . . . . . . . . . . . 6.2.1 EasyDMA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.2.2 Resolving a resolvable address . . . . . . . . . . . . . . . . . . . . . . . . . 6.2.3 Use case example for chaining RADIO packet reception with address resolution using AAR . 6.2.4 IRK data structure . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.2.5 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.2.6 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.3 BPROT — Block protection . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.3.1 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.4 CCM — AES CCM mode encryption . . . . . . . . . . . . . . . . . . . . . . . . 6.4.1 Keystream generation . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.4.2 Encryption . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.4.3 Decryption . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.4.4 AES CCM and RADIO concurrent operation . . . . . . . . . . . . . . . . . . . . 6.4.5 Encrypting packets on-the-fly in radio transmit mode . . . . . . . . . . . . . . . 6.4.6 Decrypting packets on-the-fly in RADIO receive mode . . . . . . . . . . . . . . . 6.4.7 CCM data structure . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.4.8 EasyDMA and ERROR event . . . . . . . . . . . . . . . . . . . . . . . . . . 6.4.9 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.4.10 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.5 ECB — AES electronic codebook mode encryption . . . . . . . . . . . . . . . . . . 6.5.1 Shared resources . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.5.2 EasyDMA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.5.3 ECB data structure . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.5.4 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4454_187 v1.2 iv 73 73 74 74 74 74 74 75 75 76 76 76 77 77 77 81 81 83 84 84 85 85 86 86 87 88 89 90 96 96 96 97 97 97 6.5.5 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.6 EGU — Event generator unit . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.6.1 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.6.2 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.7 GPIO — General purpose input/output . . . . . . . . . . . . . . . . . . . . . . 6.7.1 Pin configuration . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.7.2 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.7.3 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.8 GPIOTE — GPIO tasks and events . . . . . . . . . . . . . . . . . . . . . . . . . 6.8.1 Pin events and tasks . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.8.2 Port event . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.8.3 Tasks and events pin configuration . . . . . . . . . . . . . . . . . . . . . . 6.8.4 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.8.5 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.9 PPI — Programmable peripheral interconnect . . . . . . . . . . . . . . . . . . . . 6.9.1 Pre-programmed channels . . . . . . . . . . . . . . . . . . . . . . . . . . 6.9.2 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.10 QDEC — Quadrature decoder . . . . . . . . . . . . . . . . . . . . . . . . . . 6.10.1 Sampling and decoding . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.10.2 LED output . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.10.3 Debounce filters . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.10.4 Accumulators . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.10.5 Output/input pins . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.10.6 Pin configuration . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.10.7 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.10.8 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.11 RADIO — 2.4 GHz radio . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.11.1 Packet configuration . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.11.2 Address configuration . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.11.3 Data whitening . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.11.4 CRC . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.11.5 Radio states . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.11.6 Transmit sequence . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.11.7 Receive sequence . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.11.8 Received signal strength indicator (RSSI) . . . . . . . . . . . . . . . . . . . . 6.11.9 Interframe spacing (IFS) . . . . . . . . . . . . . . . . . . . . . . . . . . 6.11.10 Device address match . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.11.11 Bit counter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.11.12 EasyDMA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.11.13 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.11.14 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.12 RNG — Random number generator . . . . . . . . . . . . . . . . . . . . . . . 6.12.1 Bias correction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.12.2 Speed . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.12.3 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.12.4 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.13 RTC — Real-time counter . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.13.1 Clock source . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.13.2 Resolution versus overflow and the PRESCALER . . . . . . . . . . . . . . . . . 6.13.3 COUNTER register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.13.4 Overflow features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.13.5 TICK event . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.13.6 Event control feature . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.13.7 Compare feature . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4454_187 v1.2 v 100 100 100 102 102 103 105 110 110 111 111 112 112 116 116 118 118 122 123 124 124 124 125 125 126 137 137 137 138 139 139 140 141 142 144 144 145 145 146 147 168 173 173 173 174 176 176 177 177 178 178 178 179 179 6.13.8 TASK and EVENT jitter/delay . . . . . . . . . . . . . . . . . . . . . . . . . 6.13.9 Reading the COUNTER register . . . . . . . . . . . . . . . . . . . . . . . 6.13.10 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.13.11 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.14 SAADC — Successive approximation analog-to-digital converter . . . . . . . . . . . . 6.14.1 Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.14.2 Digital output . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.14.3 Analog inputs and channels . . . . . . . . . . . . . . . . . . . . . . . . . 6.14.4 Operation modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.14.5 EasyDMA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.14.6 Resistor ladder . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.14.7 Reference . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.14.8 Acquisition time . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.14.9 Limits event monitoring . . . . . . . . . . . . . . . . . . . . . . . . . . 6.14.10 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.14.11 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.14.12 Performance factors . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.15 SPI — Serial peripheral interface master . . . . . . . . . . . . . . . . . . . . . 6.15.1 Functional description . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.15.2 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.15.3 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.16 SPIM — Serial peripheral interface master with EasyDMA . . . . . . . . . . . . . . 6.16.1 SPI master transaction sequence . . . . . . . . . . . . . . . . . . . . . . . 6.16.2 Master mode pin configuration . . . . . . . . . . . . . . . . . . . . . . . 6.16.3 EasyDMA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.16.4 Low power . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.16.5 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.16.6 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.17 SPIS — Serial peripheral interface slave with EasyDMA . . . . . . . . . . . . . . . . 6.17.1 Shared resources . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.17.2 EasyDMA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.17.3 SPI slave operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.17.4 Pin configuration . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.17.5 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.17.6 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.18 SWI — Software interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.18.1 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.19 TEMP — Temperature sensor . . . . . . . . . . . . . . . . . . . . . . . . . . 6.19.1 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.19.2 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.20 TWI — I2C compatible two-wire interface . . . . . . . . . . . . . . . . . . . . . 6.20.1 Functional description . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.20.2 Master mode pin configuration . . . . . . . . . . . . . . . . . . . . . . . 6.20.3 Shared resources . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.20.4 Master write sequence . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.20.5 Master read sequence . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.20.6 Master repeated start sequence . . . . . . . . . . . . . . . . . . . . . . . 6.20.7 Low power . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.20.8 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.20.9 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.21 TIMER — Timer/counter . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.21.1 Capture . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.21.2 Compare . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.21.3 Task delays . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4454_187 v1.2 vi 181 183 184 189 189 189 190 191 191 193 194 195 195 196 197 211 212 212 213 216 219 220 221 222 223 223 223 232 233 234 234 234 236 237 247 249 249 249 250 256 256 256 257 257 258 258 259 260 260 268 269 270 270 270 6.21.4 Task priority . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.21.5 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.21.6 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.22 TWIM — I2C compatible two-wire interface master with EasyDMA . . . . . . . . . . . 6.22.1 EasyDMA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.22.2 Master write sequence . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.22.3 Master read sequence . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.22.4 Master repeated start sequence . . . . . . . . . . . . . . . . . . . . . . . 6.22.5 Low power . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.22.6 Master mode pin configuration . . . . . . . . . . . . . . . . . . . . . . . 6.22.7 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.22.8 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.22.9 Pullup resistor . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.23 TWIS — I2C compatible two-wire interface slave with EasyDMA . . . . . . . . . . . . 6.23.1 EasyDMA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.23.2 TWI slave responding to a read command . . . . . . . . . . . . . . . . . . . 6.23.3 TWI slave responding to a write command . . . . . . . . . . . . . . . . . . . 6.23.4 Master repeated start sequence . . . . . . . . . . . . . . . . . . . . . . . 6.23.5 Terminating an ongoing TWI transaction . . . . . . . . . . . . . . . . . . . . 6.23.6 Low power . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.23.7 Slave mode pin configuration . . . . . . . . . . . . . . . . . . . . . . . . 6.23.8 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.23.9 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.24 UART — Universal asynchronous receiver/transmitter . . . . . . . . . . . . . . . . 6.24.1 Functional description . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.24.2 Pin configuration . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.24.3 Shared resources . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.24.4 Transmission . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.24.5 Reception . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.24.6 Suspending the UART . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.24.7 Error conditions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.24.8 Using the UART without flow control . . . . . . . . . . . . . . . . . . . . . 6.24.9 Parity and stop bit configuration . . . . . . . . . . . . . . . . . . . . . . . 6.24.10 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.24.11 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.25 UARTE — Universal asynchronous receiver/transmitter with EasyDMA . . . . . . . . . 6.25.1 EasyDMA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.25.2 Transmission . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.25.3 Reception . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.25.4 Error conditions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.25.5 Using the UARTE without flow control . . . . . . . . . . . . . . . . . . . . 6.25.6 Parity and stop bit configuration . . . . . . . . . . . . . . . . . . . . . . . 6.25.7 Low power . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.25.8 Pin configuration . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.25.9 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.25.10 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.26 WDT — Watchdog timer . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.26.1 Reload criteria . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.26.2 Temporarily pausing the watchdog . . . . . . . . . . . . . . . . . . . . . . 6.26.3 Watchdog reset . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.26.4 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.26.5 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 Hardware and layout. 4454_187 v1.2 . . . . . . . . . . . . . . . . . . . . . . . . . . . . vii 270 270 275 275 277 277 278 279 280 280 280 291 292 292 294 294 296 297 297 298 298 298 308 309 309 309 310 310 311 311 312 312 312 312 321 321 322 322 323 324 324 325 325 325 325 338 338 339 339 339 339 342 343 7.1 Pin assignments . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.1.1 WLCSP ball assignments . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.2 Mechanical specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.2.1 WLCSP 2.482 x 2.464 mm package . . . . . . . . . . . . . . . . . . . . . . 7.3 Reference circuitry . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.3.1 Schematic CAAA WLCSP with internal LDO regulator setup . . . . . . . . . . . . . 7.3.2 Schematic CAAA WLCSP with DC/DC regulator setup . . . . . . . . . . . . . . . 7.3.3 PCB guidelines . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.3.4 PCB layout example . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 9 Recommended operating conditions. 343 343 344 345 345 345 346 348 348 . . . . . . . . . . . . . . . . . . . 351 8.1 WLCSP light sensitivity . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 351 Absolute maximum ratings. 10 Ordering information. 10.1 10.2 10.3 10.4 10.5 . . . . . . . . . . . . . . . . . . . . . . . . 352 . . . . . . . . . . . . . . . . . . . . . . . . . . . 353 IC marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Box labels . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Order code . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Code ranges and values . . . . . . . . . . . . . . . . . . . . . . . . . . . . Product options . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Legal notices. 4454_187 v1.2 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . viii 353 353 354 355 356 358 1 Revision history Date Version Description July 2020 1.2 The following content has been added or updated: • Added QDEC — Quadrature decoder on page 122 peripheral information. June 2020 1.1 The following content has been added or updated: • About this document on page 10 - Added field permission descriptions section. • Current consumption on page 41 - Parameter update, modified graphs. • Corrected minimum valid value for EasyDMA MAXCNT and AMOUNT registers in SPIM — Serial peripheral interface master with EasyDMA on page 220, SPIS — Serial peripheral interface slave with EasyDMA on page 233, TWIM — I2C compatible two-wire interface master with EasyDMA on page 275, TWIS — I2C compatible twowire interface slave with EasyDMA on page 292 and UARTE — Universal asynchronous receiver/transmitter with EasyDMA on page 321. • RADIO — 2.4 GHz radio on page 137 - EDSAMPLE register corrected to read-only. Output power and sensitivity figures changed. Parameters C/I2MBLE, +2MHz,-2MHz,+4MHz,-4MHz updated. All Radio Timing parameters set as Typical. • SPIS — Serial peripheral interface slave with EasyDMA on page 233 - Relaxed parameter tSPIS,HCSN. • TWIM — I2C compatible two-wire interface master with EasyDMA on page 275 - Parameter tTWIM,HD_STA value updated. • Editorial changes August 2019 4454_187 v1.2 1.0 First release 9 2 About this document This document is organized into chapters that are based on the modules and peripherals available in the IC. 2.1 Document status The document status reflects the level of maturity of the document. Document name Description Objective Product Specification (OPS) Applies to document versions up to 1.0. This document contains target specifications for product development. Product Specification (PS) Applies to document versions 1.0 and higher. This document contains final product specifications. Nordic Semiconductor ASA reserves the right to make changes at any time without notice in order to improve design and supply the best possible product. Table 1: Defined document names 2.2 Peripheral chapters Every peripheral has a unique capitalized name or an abbreviation of its name, e.g. TIMER, used for identification and reference. This name is used in chapter headings and references, and it will appear in the ARM® Cortex® Microcontroller Software Interface Standard (CMSIS) hardware abstraction layer to identify the peripheral. The peripheral instance name, which is different from the peripheral name, is constructed using the peripheral name followed by a numbered postfix, starting with 0, for example, TIMER0. A postfix is normally only used if a peripheral can be instantiated more than once. The peripheral instance name is also used in the CMSIS to identify the peripheral instance. The chapters describing peripherals may include the following information: • A detailed functional description of the peripheral • Register configuration for the peripheral • Electrical specification tables, containing performance data which apply for the operating conditions described in Recommended operating conditions on page 351. 2.3 Register tables Individual registers are described using register tables. These tables are built up of two sections. The first three colored rows describe the position and size of the different fields in the register. The following rows describe the fields in more detail. 4454_187 v1.2 10 About this document 2.3.1 Fields and values The Id (Field Id) row specifies the bits that belong to the different fields in the register. If a field has enumerated values, then every value will be identified with a unique value id in the Value Id column. A blank space means that the field is reserved and read as undefined, and it also must be written as 0 to secure forward compatibility. If a register is divided into more than one field, a unique field name is specified for each field in the Field column. The Value Id may be omitted in the single-bit bit fields when values can be substituted with a Boolean type enumerator range, e.g. true/false, disable(d)/enable(d), on/ off, and so on. Values are usually provided as decimal or hexadecimal. Hexadecimal values have a 0x prefix, decimal values have no prefix. The Value column can be populated in the following ways: • Individual enumerated values, for example 1, 3, 9. • Range of values, e.g. [0..4], indicating all values from and including 0 and 4. • Implicit values. If no values are indicated in the Value column, all bit combinations are supported, or alternatively the field's translation and limitations are described in the text instead. If two or more fields are closely related, the Value Id, Value, and Description may be omitted for all but the first field. Subsequent fields will indicate inheritance with '..'. A feature marked Deprecated should not be used for new designs. 2.3.2 Permissions Different fields in a register might have different access permissions enforced by hardware. The access permission for each register field is documented in the Access column in the following ways: Access Description Hardware behavior RO Read-only Field can only be read. A write will be ignored. WO Write-only Field can only be written. A read will return an undefined value. RW Read-write Field can be read and written multiple times. W1 Write-once Field can only be written once per reset. Any subsequent write will be ignored. A read will return an undefined value. RW1 Read-write-once Field can be read multiple times, but only written once per reset. Any subsequent write will be ignored. Table 2: Register field permission schemes 2.4 Registers Register Offset Description DUMMY 0x514 Example of a register controlling a dummy feature Table 3: Register overview 2.4.1 DUMMY Address offset: 0x514 Example of a register controlling a dummy feature 4454_187 v1.2 11 About this document Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID D D D D Reset 0x00050002 ID Access Field A RW FIELD_A C C C B A A 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 Value ID Value Description Example of a read-write field with several enumerated values Disabled 0 The example feature is disabled NormalMode 1 The example feature is enabled in normal mode ExtendedMode 2 The example feature is enabled along with extra functionality B RW FIELD_B C RW FIELD_C D RW FIELD_D Example of a deprecated read-write field Disabled 0 The override feature is disabled Enabled 1 The override feature is enabled Example of a read-write field with a valid range of values ValidRange [2..7] Example of allowed values for this field Example of a read-write field with no restriction on the values 4454_187 v1.2 12 Deprecated Block diagram This block diagram illustrates the overall system. Arrows with white heads indicate signals that share physical pins with other signals. CTRL-AP NVIC slave slave slave CPU ARM CORTEX-M4 slave AHB multilayer AHB-AP nRESET P0 (10 GPIOs) GPIO slave RAM2 slave SW-DP RAM1 slave SWCLK SWDIO RAM0 slave nRF52805 master AHB TO APB BRIDGE FICR UICR Flash SysTick NVMC RNG POWER RTC [0..1] TIMER [0..2] WDT TEMP PPI XC1 XC2 XL1 XL2 CLOCK ANT RADIO ECB master EasyDMA master EasyDMA master mast AAR er EasyDMA CCM EasyDMA master APB0 3 P0 (10 GPIOs) SPIM master GPIOTE EasyDMA TWIS AIN2, AIN3 EasyDMA LED A B master EasyDMA master EasyDMA SAADC TWIM master QDEC UARTE master Figure 1: Block diagram 4454_187 v1.2 13 SCL SDA SCL SDA RTS CTS TXD RXD EasyDMA SPIS master SCK MOSI MISO EasyDMA CSN MISO MOSI SCK 4 Core components 4.1 CPU The ARM® Cortex®-M4 processor has a 32-bit instruction set (Thumb®-2 technology) that implements a superset of 16- and 32-bit instructions to maximize code density and performance. This processor implements several features that enable energy-efficient arithmetic and high-performance signal processing including: • • • • Digital signal processing (DSP) instructions Single-cycle multiply and accumulate (MAC) instructions Hardware divide 8- and 16-bit single instruction multiple data (SIMD) instructions The ARM Cortex Microcontroller Software Interface Standard (CMSIS) hardware abstraction layer for the ARM Cortex processor series is implemented and available for the M4 CPU. Real-time execution is highly deterministic in thread mode, to and from sleep modes, and when handling events at configurable priority levels via the nested vectored interrupt controller (NVIC). Executing code from flash will have a wait state penalty on the nRF52 Series. The section Electrical specification on page 14 shows CPU performance parameters including wait states in different modes, CPU current and efficiency, and processing power and efficiency based on the CoreMark® benchmark. The ARM System Timer (SysTick) is present on the device. The SysTick's clock will only tick when the CPU is running or when the system is in debug interface mode. 4.1.1 Electrical specification 4.1.1.1 CPU performance The CPU clock speed is 64 MHz. Current and efficiency data is taken when in System ON and the CPU is executing the CoreMark® benchmark. It includes power regulator and clock base currents. All other blocks are IDLE. Symbol Description Min. WFLASH CPU wait states, running from flash 0 Typ. Max. Units WRAM CPU wait states, running from RAM CMFLASH CoreMark1, running from flash 144 CoreMark CMFLASH/MHz CoreMark per MHz, running from flash 2.25 CoreMark/ CMFLASH/mA CoreMark per mA, running from flash, DCDC 3V 65 2 0 MHz CoreMark/ mA 4.1.2 CPU and support module configuration The ARM® Cortex®-M4 processor has a number of CPU options and support modules implemented on the device. 1 Using IAR v6.50.1.4452 with flags --endian=little --cpu=Cortex-M4 -e --fpu=VFPv4_sp –Ohs -no_size_constraints 4454_187 v1.2 14 Core components Option / Module Description Implemented NVIC Nested vector interrupt controller 30 vectors PRIORITIES Priority bits 3 WIC Wakeup interrupt controller NO Endianness Memory system endianness Little endian Bit-banding Bit banded memory NO DWT Data watchpoint and trace NO SysTick System tick timer YES MPU Memory protection unit YES FPU Floating-point unit NO DAP Debug access port YES ETM Embedded trace macrocell NO ITM Instrumentation trace macrocell NO TPIU Trace port interface unit NO ETB Embedded trace buffer NO FPB Flash patch and breakpoint unit YES HTM AMBA AHB trace macrocell Core options Modules ® NO 4.2 Memory The nRF52805 contains flash and RAM that can be used for code and data storage. The amount of RAM and flash differs depending on variant, see Memory variants on page 15. Device name RAM Flash nRF52805-CAAA 24 kB 192 kB Table 4: Memory variants The CPU and peripherals with EasyDMA can access memory via the AHB multilayer interconnect. The CPU is also able to access peripherals via the AHB multilayer interconnect, as illustrated in Memory layout on page 16. 4454_187 v1.2 15 Core components AHB2APB APB CPU System bus EasyDMA ICODE EasyDMA DMA bus Peripheral DMA bus Peripheral DCODE ARM Cortex-M4 Data RAM System Code RAM ICODE/DCODE RAM2 AHB slave Section 1 0x20005000 0x00805000 Section 0 0x20004000 0x00804000 RAM1 AHB slave Section 1 0x20003000 0x00803000 Section 0 0x20002000 0x00802000 RAM0 AHB slave Section 1 0x20001000 0x00801000 Section 0 0x20000000 0x00800000 AHB multilayer interconnect NVMC DCODE AHB slave ICODE AHB AHB slave Page 47 Flash ICODE/DCODE 0x0002F000 Page 3..46 0x00003000 Page 2 Page 1 Page 0 0x00002000 0x00001000 Block 7 0x00000E00 Block 2..6 0x00000400 Block 1 0x00000200 Block 0 0x00000000 Figure 2: Memory layout See AHB multilayer on page 36 and EasyDMA on page 34 for more information about the AHB multilayer interconnect and the EasyDMA. The same physical RAM is mapped to both the Data RAM region and the Code RAM region. It is up to the application to partition the RAM within these regions so that one does not corrupt the other. 4.2.1 RAM - Random access memory The RAM interface is divided into three RAM AHB slaves. RAM AHB slaves 0 to 2 are connected to two 4 kB RAM sections each, as shown in Memory layout on page 16. Each RAM section has separate power control for System ON and System OFF mode operation, which is configured via RAM register (see the POWER — Power supply on page 46). 4.2.2 Flash - Non-volatile memory The flash can be read an unlimited number of times by the CPU, but it has restrictions on the number of times it can be written and erased, and also on how it can be written. Writing to flash is managed by the non-volatile memory controller (NVMC), see NVMC — Non-volatile memory controller on page 18. The flash is divided into multiple 4 kB pages that can be accessed by the CPU via both the ICODE and DCODE buses as shown in, Memory layout on page 16. Each page is divided into 8 blocks. 4.2.3 Memory map The complete memory map is shown in Memory map on page 17. As described in Memory on page 15, Code RAM and Data RAM are the same physical RAM. 4454_187 v1.2 16 Core components Cortex M4 system address map 0xFFFFFFFF 0xE0100000 0xE0000000 Private peripheral bus 0x5FFFFFFF AHB peripherals 0x50000000 APB peripherals 0x1FFFFFFF 0x10002000 0x40000000 UICR 0x10001000 FICR 0x10000000 0x00806000 Code RAM 0x00800000 0x00030000 Peripheral 0.5GB SRAM 0.5GB Code 0.5GB 0x3FFFFFFF 0x20006000 Data RAM Flash 0x20000000 0x00000000 Figure 3: Memory map 4.2.4 Instantiation ID Base address Peripheral Instance Description 0 0x40000000 BPROT BPROT Block protect 0 0x40000000 CLOCK CLOCK Clock control 0 0x40000000 POWER POWER Power control 0 0x50000000 GPIO P0 General purpose input and output 1 0x40001000 RADIO RADIO 2.4 GHz radio 2 0x40002000 UART UART0 Universal asynchronous receiver/transmitter 2 0x40002000 UARTE UARTE0 Universal asynchronous receiver/transmitter with EasyDMA 3 0x40003000 TWI TWI0 Two-wire interface master 3 0x40003000 TWIM TWIM0 Two-wire interface master 3 0x40003000 TWIS TWIS0 Two-wire interface slave 4 0x40004000 SPI SPI0 SPI master 4 0x40004000 SPIM SPIM0 SPI master 4 0x40004000 SPIS SPIS0 SPI slave 6 0x40006000 GPIOTE GPIOTE GPIO tasks and events 7 0x40007000 SAADC SAADC Analog-to-digital converter 8 0x40008000 TIMER TIMER0 Timer 0 9 0x40009000 TIMER TIMER1 Timer 1 10 0x4000A000 TIMER TIMER2 Timer 2 11 0x4000B000 RTC RTC0 Real-time counter 0 12 0x4000C000 TEMP TEMP Temperature sensor 13 0x4000D000 RNG RNG Random number generator 14 0x4000E000 ECB ECB AES Electronic Codebook (ECB) mode block encryption 15 0x4000F000 AAR AAR Accelerated address resolver 15 0x4000F000 CCM CCM AES CCM mode encryption 16 0x40010000 WDT WDT Watchdog timer 17 0x40011000 RTC RTC1 Real-time counter 1 4454_187 v1.2 17 Deprecated Deprecated Deprecated Core components ID Base address Peripheral Instance Description 18 0x40012000 QDEC QDEC Quadrature decoder 20 0x40014000 EGU EGU0 Event generator unit 0 20 0x40014000 SWI SWI0 Software interrupt 0 21 0x40015000 EGU EGU1 Event generator unit 1 21 0x40015000 SWI SWI1 Software interrupt 1 22 0x40016000 SWI SWI2 Software interrupt 2 23 0x40017000 SWI SWI3 Software interrupt 3 24 0x40018000 SWI SWI4 Software interrupt 4 25 0x40019000 SWI SWI5 Software interrupt 5 30 0x4001E000 NVMC NVMC Non-volatile memory controller 31 0x4001F000 PPI PPI Programmable peripheral interconnect N/A 0x10000000 FICR FICR Factory information configuration N/A 0x10001000 UICR UICR User information configuration Table 5: Instantiation table 4.3 NVMC — Non-volatile memory controller The non-volatile memory controller (NVMC) is used for writing and erasing of the internal flash memory and the UICR (user information configuration registers). The CONFIG on page 20 is used to enable the NVMC for writing (CONFIG.WEN = Wen) and erasing (CONFIG.WEN = Een). The CPU must be halted before initiating a NVMC operation from the debug system. 4.3.1 Writing to flash When write is enabled, full 32-bit words can be written to word-aligned addresses in flash memory. As illustrated in Memory on page 15, the flash is divided into multiple pages. The same 32-bit word in flash memory can only be written n WRITE number of times before a page erase must be performed. The NVMC is only able to write 0 to bits in flash memory that are erased (set to 1). It cannot rewrite a bit back to 1. Only full 32-bit words can be written to flash memory using the NVMC interface. To write less than 32 bits, write the data as a full 32-bit word and set all the bits that should remain unchanged in the word to 1. The restriction on the number of writes (nWRITE) still applies in this case. Only word-aligned writes are allowed. Byte or half-word-aligned writes will result in a hard fault. The time it takes to write a word to flash is specified by tWRITE. The CPU is halted while the NVMC is writing to the flash. 4.3.2 Erasing a page in flash When erase is enabled, the flash memory can be erased page by page using the ERASEPAGE on page 20. After erasing a flash page, all bits in the page are set to 1. The time it takes to erase a page is specified by tERASEPAGE. The CPU is halted if the CPU executes code from the flash while the NVMC is writing to the flash. See Partial erase of a page in flash on page 19 for information on dividing the page erase time into shorter chunks. 4454_187 v1.2 18 Core components 4.3.3 Writing to user information configuration registers (UICR) User information configuration registers (UICR) are written in the same way as flash. After UICR has been written, the new UICR configuration will only take effect after a reset. UICR can only be written nWRITE number of times before an erase must be performed using ERASEUICR on page 21 or ERASEALL on page 21. The time it takes to write a word to UICR is specified by tWRITE. The CPU is halted while the NVMC is writing to the UICR. 4.3.4 Erasing user information configuration registers (UICR) When erase is enabled, UICR can be erased using the ERASEUICR on page 21. After erasing UICR, all bits in UICR are set to 1. The time it takes to erase UICR is specified by tERASEPAGE. The CPU is halted if the CPU executes code from the flash while the NVMC performs the erase operation. 4.3.5 Erase all When erase is enabled, flash and UICR can be erased completely in one operation by using the ERASEALL on page 21. This operation will not erase the factory information configuration registers (FICR). The time it takes to perform an ERASEALL command is specified by tERASEALL. The CPU is halted if the CPU executes code from the flash while the NVMC performs the erase operation. 4.3.6 Partial erase of a page in flash Partial erase is a feature in the NVMC to split a page erase time into shorter chunks to prevent longer CPU stalls in time-critical applications. Partial erase is only applicable to the code area in flash memory and does not work with UICR. When erase is enabled, the partial erase of a flash page can be started by writing to ERASEPAGEPARTIAL on page 22. The duration of a partial erase can be configured in ERASEPAGEPARTIALCFG on page 22. A flash page is erased when its erase time reaches tERASEPAGE. Use ERASEPAGEPARTIAL N number of times so that N * ERASEPAGEPARTIALCFG ≥ tERASEPAGE, where N * ERASEPAGEPARTIALCFG gives the cumulative (total) erase time. Every time the cumulative erase time reaches tERASEPAGE, it counts as one erase cycle. After the erase is complete, all bits in the page are set to 1. The CPU is halted if the CPU executes code from the flash while the NVMC performs the partial erase operation. The bits in the page are undefined if the flash page erase is incomplete, i.e. if a partial erase has started but the total erase time is less than tERASEPAGE. 4.3.7 Registers Base address Peripheral Instance Description 0x4001E000 NVMC NVMC Non-volatile memory controller Configuration Table 6: Instances Register Offset Description READY 0x400 Ready flag CONFIG 0x504 Configuration register ERASEPAGE 0x508 Register for erasing a page in code area ERASEPCR1 0x508 Register for erasing a page in code area, equivalent to ERASEPAGE ERASEALL 0x50C Register for erasing all non-volatile user memory ERASEPCR0 0x510 Register for erasing a page in code area, equivalent to ERASEPAGE ERASEUICR 0x514 Register for erasing user information configuration registers 4454_187 v1.2 19 Deprecated Deprecated Core components Register Offset Description ERASEPAGEPARTIAL 0x518 Register for partial erase of a page in code area ERASEPAGEPARTIALCFG 0x51C Register for partial erase configuration Table 7: Register overview 4.3.7.1 READY Address offset: 0x400 Ready flag Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000001 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 Value ID Value Description Busy 0 NVMC is busy (on-going write or erase operation) Ready 1 NVMC is ready READY NVMC is ready or busy 4.3.7.2 CONFIG Address offset: 0x504 Configuration register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A Reset 0x00000000 ID Access Field A RW WEN 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Program memory access mode. It is strongly recommended to only activate erase and write modes when they are actively used. Ren 0 Read only access Wen 1 Write enabled Een 2 Erase enabled 4.3.7.3 ERASEPAGE Address offset: 0x508 Register for erasing a page in code area Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description ERASEPAGE Register for starting erase of a page in code area The value is the address to the page to be erased. (Addresses of first word in page). The erase must be enabled using CONFIG.WEN before the page can be erased. Attempts to erase pages that are outside the code area may result in undesirable behavior, e.g. the wrong page may be erased. 4454_187 v1.2 20 Core components 4.3.7.4 ERASEPCR1 ( Deprecated ) Address offset: 0x508 Register for erasing a page in code area, equivalent to ERASEPAGE Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field A W Value ID Value Description ERASEPCR1 Register for erasing a page in code area, equivalent to ERASEPAGE 4.3.7.5 ERASEALL Address offset: 0x50C Register for erasing all non-volatile user memory Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description ERASEALL Erase all non-volatile memory including UICR registers. The erase must be enabled using CONFIG.WEN before the nonvolatile memory can be erased. NoOperation 0 No operation Erase 1 Start chip erase 4.3.7.6 ERASEPCR0 ( Deprecated ) Address offset: 0x510 Register for erasing a page in code area, equivalent to ERASEPAGE Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field A W Value ID Value Description ERASEPCR0 Register for starting erase of a page in code area, equivalent to ERASEPAGE 4.3.7.7 ERASEUICR Address offset: 0x514 Register for erasing user information configuration registers 4454_187 v1.2 21 Core components Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description ERASEUICR Register starting erase of all user information configuration registers. The erase must be enabled using CONFIG.WEN before the UICR can be erased. NoOperation 0 No operation Erase 1 Start erase of UICR 4.3.7.8 ERASEPAGEPARTIAL Address offset: 0x518 Register for partial erase of a page in code area Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description ERASEPAGEPARTIAL Register for starting partial erase of a page in code area The value is the address to the page to be partially erased (address of the first word in page). The erase must be enabled using CONFIG.WEN before every erase page partial and disabled using CONFIG.WEN after every erase page partial. Attempts to erase pages that are outside the code area may result in undesirable behavior, e.g. the wrong page may be erased. 4.3.7.9 ERASEPAGEPARTIALCFG Address offset: 0x51C Register for partial erase configuration Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A Reset 0x0000000A ID Access Field A RW DURATION 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 1 0 Value ID Value Description Duration of the partial erase in milliseconds The user must ensure that the total erase time is long enough for a complete erase of the flash page. 4454_187 v1.2 22 Core components 4.3.8 Electrical specification 4.3.8.1 Flash programming Symbol Description nWRITE Number of times a 32-bit word can be written before erase Min. nENDURANCE Erase cycles per page tWRITE Time to write one 32-bit word tERASEPAGE Time to erase one page tERASEALL Time to erase all flash Typ. Max. Units 2 10000 µs 412 ms 2 85 169 tERASEPAGEPARTIAL,acc Accuracy of the partial page erase duration. Total 2 ms 1.052 execution time for one partial page erase is defined as ERASEPAGEPARTIALCFG * tERASEPAGEPARTIAL,acc. 4.4 FICR — Factory information configuration registers Factory information configuration registers (FICR) are pre-programmed in factory and cannot be erased by the user. These registers contain chip-specific information and configuration. 4.4.1 Registers Base address Peripheral Instance Description Configuration 0x10000000 FICR FICR Factory information configuration Table 8: Instances Register Offset Description CODEPAGESIZE 0x010 Code memory page size CODESIZE 0x014 Code memory size DEVICEID[0] 0x060 Device identifier DEVICEID[1] 0x064 Device identifier ER[0] 0x080 Encryption root, word 0 ER[1] 0x084 Encryption root, word 1 ER[2] 0x088 Encryption root, word 2 ER[3] 0x08C Encryption root, word 3 IR[0] 0x090 Identity root, word 0 IR[1] 0x094 Identity root, word 1 IR[2] 0x098 Identity root, word 2 IR[3] 0x09C Identity root, word 3 DEVICEADDRTYPE 0x0A0 Device address type DEVICEADDR[0] 0x0A4 Device address 0 DEVICEADDR[1] 0x0A8 Device address 1 INFO.PART 0x100 Part code INFO.VARIANT 0x104 Part variant, hardware version and production configuration INFO.PACKAGE 0x108 Package option INFO.RAM 0x10C RAM variant INFO.FLASH 0x110 Flash variant INFO.UNUSED8[0] 0x114 2 Reserved HFXO is used here 4454_187 v1.2 23 Core components Register Offset Description INFO.UNUSED8[1] 0x118 INFO.UNUSED8[2] 0x11C TEMP.A0 0x404 Slope definition A0 TEMP.A1 0x408 Slope definition A1 TEMP.A2 0x40C Slope definition A2 TEMP.A3 0x410 Slope definition A3 TEMP.A4 0x414 Slope definition A4 TEMP.A5 0x418 Slope definition A5 TEMP.B0 0x41C Y-intercept B0 TEMP.B1 0x420 Y-intercept B1 TEMP.B2 0x424 Y-intercept B2 TEMP.B3 0x428 Y-intercept B3 TEMP.B4 0x42C Y-intercept B4 TEMP.B5 0x430 Y-intercept B5 TEMP.T0 0x434 Segment end T0 TEMP.T1 0x438 Segment end T1 TEMP.T2 0x43C Segment end T2 TEMP.T3 0x440 Segment end T3 TEMP.T4 0x444 Segment end T4 Reserved Reserved Table 9: Register overview 4.4.1.1 CODEPAGESIZE Address offset: 0x010 Code memory page size Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00001000 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description CODEPAGESIZE Code memory page size 4.4.1.2 CODESIZE Address offset: 0x014 Code memory size Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000030 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 0 0 0 Value ID Value Description CODESIZE Code memory size in number of pages Total code space is: CODEPAGESIZE * CODESIZE 4.4.1.3 DEVICEID[n] (n=0..1) Address offset: 0x060 + (n × 0x4) Device identifier 4454_187 v1.2 24 Core components Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 ID Access Field A R Value ID Value Description DEVICEID 64 bit unique device identifier DEVICEID[0] contains the least significant bits of the device identifier. DEVICEID[1] contains the most significant bits of the device identifier. 4.4.1.4 ER[n] (n=0..3) Address offset: 0x080 + (n × 0x4) Encryption root, word n Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF ID Access Field A R 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description ER Encryption root, word n 4.4.1.5 IR[n] (n=0..3) Address offset: 0x090 + (n × 0x4) Identity root, word n Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 ID Access Field A R Value ID Value Description IR Identity root, word n 4.4.1.6 DEVICEADDRTYPE Address offset: 0x0A0 Device address type Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0xFFFFFFFF ID Access Field A R 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description DEVICEADDRTYPE Device address type Public 0 Public address Random 1 Random address 4.4.1.7 DEVICEADDR[n] (n=0..1) Address offset: 0x0A4 + (n × 0x4) Device address n 4454_187 v1.2 25 Core components Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 ID Access Field A R Value ID Value Description DEVICEADDR 48 bit device address DEVICEADDR[0] contains the least significant bits of the device address. DEVICEADDR[1] contains the most significant bits of the device address. Only bits [15:0] of DEVICEADDR[1] are used. 4.4.1.8 INFO.PART Address offset: 0x100 Part code Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00052805 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 1 0 0 1 0 1 0 0 0 0 0 0 0 0 1 0 1 Value ID Value Description N52805 0x52805 nRF52805 N52810 0x52810 nRF52810 N52811 0x52811 nRF52811 N52832 0x52832 nRF52832 Unspecified 0xFFFFFFFF Unspecified PART Part code 4.4.1.9 INFO.VARIANT Address offset: 0x104 Part variant, hardware version and production configuration Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF ID Access Field A R 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description VARIANT Part variant, hardware version and production configuration, encoded as ASCII AAAA 0x41414141 AAAA AAA0 0x41414130 AAA0 AABA 0x41414241 AABA AABB 0x41414242 AABB AAB0 0x41414230 AAB0 AACA 0x41414341 AACA AACB 0x41414342 AACB AAC0 0x41414330 AAC0 Unspecified 0xFFFFFFFF Unspecified 4.4.1.10 INFO.PACKAGE Address offset: 0x108 Package option 4454_187 v1.2 26 Core components Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 ID Access Field A R Value ID Value Description CA 0x2004 CAxx - WLCSP Unspecified 0xFFFFFFFF Unspecified PACKAGE Package option 4.4.1.11 INFO.RAM Address offset: 0x10C RAM variant Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000018 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 0 0 ID Access Field A R Value ID Value Description K24 0x18 24 kByte RAM Unspecified 0xFFFFFFFF Unspecified RAM RAM variant 4.4.1.12 INFO.FLASH Address offset: 0x110 Flash variant Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x000000C0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 ID Access Field A R Value ID Value Description K192 0xC0 192 kByte flash Unspecified 0xFFFFFFFF Unspecified FLASH Flash variant 4.4.1.13 TEMP.A0 Address offset: 0x404 Slope definition A0 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A Reset 0xFFFFFFFF ID Access Field A R 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description A A (slope definition) register 4.4.1.14 TEMP.A1 Address offset: 0x408 Slope definition A1 4454_187 v1.2 27 Core components Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A Reset 0xFFFFFFFF ID Access Field A R 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description A A (slope definition) register 4.4.1.15 TEMP.A2 Address offset: 0x40C Slope definition A2 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A Reset 0xFFFFFFFF ID Access Field A R 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description A A (slope definition) register 4.4.1.16 TEMP.A3 Address offset: 0x410 Slope definition A3 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A Reset 0xFFFFFFFF ID Access Field A R 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description A A (slope definition) register 4.4.1.17 TEMP.A4 Address offset: 0x414 Slope definition A4 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A Reset 0xFFFFFFFF ID Access Field A R 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description A A (slope definition) register 4.4.1.18 TEMP.A5 Address offset: 0x418 Slope definition A5 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A Reset 0xFFFFFFFF ID Access Field A R 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description A 4454_187 v1.2 A (slope definition) register 28 Core components 4.4.1.19 TEMP.B0 Address offset: 0x41C Y-intercept B0 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A Reset 0xFFFFFFFF ID Access Field A R 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description B B (y-intercept) 4.4.1.20 TEMP.B1 Address offset: 0x420 Y-intercept B1 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A Reset 0xFFFFFFFF ID Access Field A R 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description B B (y-intercept) 4.4.1.21 TEMP.B2 Address offset: 0x424 Y-intercept B2 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A Reset 0xFFFFFFFF ID Access Field A R 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description B B (y-intercept) 4.4.1.22 TEMP.B3 Address offset: 0x428 Y-intercept B3 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A Reset 0xFFFFFFFF ID Access Field A R 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description B B (y-intercept) 4.4.1.23 TEMP.B4 Address offset: 0x42C Y-intercept B4 4454_187 v1.2 29 Core components Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A Reset 0xFFFFFFFF ID Access Field A R 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description B B (y-intercept) 4.4.1.24 TEMP.B5 Address offset: 0x430 Y-intercept B5 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A Reset 0xFFFFFFFF ID Access Field A R 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description B B (y-intercept) 4.4.1.25 TEMP.T0 Address offset: 0x434 Segment end T0 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A Reset 0xFFFFFFFF ID Access Field A R 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description T T (segment end) register 4.4.1.26 TEMP.T1 Address offset: 0x438 Segment end T1 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A Reset 0xFFFFFFFF ID Access Field A R 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description T T (segment end) register 4.4.1.27 TEMP.T2 Address offset: 0x43C Segment end T2 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A Reset 0xFFFFFFFF ID Access Field A R 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description T 4454_187 v1.2 T (segment end) register 30 Core components 4.4.1.28 TEMP.T3 Address offset: 0x440 Segment end T3 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A Reset 0xFFFFFFFF ID Access Field A R 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description T T (segment end) register 4.4.1.29 TEMP.T4 Address offset: 0x444 Segment end T4 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A Reset 0xFFFFFFFF ID Access Field A R 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description T T (segment end) register 4.5 UICR — User information configuration registers The user information configuration registers (UICRs) are non-volatile memory (NVM) registers for configuring user-specific settings. For information on writing UICR registers, see the NVMC — Non-volatile memory controller on page 18 and Memory on page 15 chapters. 4.5.1 Registers Base address Peripheral Instance Description 0x10001000 UICR UICR User information configuration Configuration Table 10: Instances Register Offset UNUSED0 0x000 Reserved UNUSED1 0x004 Reserved UNUSED2 0x008 Reserved UNUSED3 0x010 NRFFW[0] 0x014 Reserved for Nordic firmware design NRFFW[1] 0x018 Reserved for Nordic firmware design NRFFW[2] 0x01C Reserved for Nordic firmware design NRFFW[3] 0x020 Reserved for Nordic firmware design NRFFW[4] 0x024 Reserved for Nordic firmware design NRFFW[5] 0x028 Reserved for Nordic firmware design NRFFW[6] 0x02C Reserved for Nordic firmware design NRFFW[7] 0x030 Reserved for Nordic firmware design 4454_187 v1.2 Description Reserved 31 Core components Register Offset Description NRFFW[8] 0x034 Reserved for Nordic firmware design NRFFW[9] 0x038 Reserved for Nordic firmware design NRFFW[10] 0x03C Reserved for Nordic firmware design NRFFW[11] 0x040 Reserved for Nordic firmware design NRFFW[12] 0x044 Reserved for Nordic firmware design NRFHW[0] 0x050 Reserved for Nordic hardware design NRFHW[1] 0x054 Reserved for Nordic hardware design NRFHW[2] 0x058 Reserved for Nordic hardware design NRFHW[3] 0x05C Reserved for Nordic hardware design NRFHW[4] 0x060 Reserved for Nordic hardware design NRFHW[5] 0x064 Reserved for Nordic hardware design NRFHW[6] 0x068 Reserved for Nordic hardware design NRFHW[7] 0x06C Reserved for Nordic hardware design NRFHW[8] 0x070 Reserved for Nordic hardware design NRFHW[9] 0x074 Reserved for Nordic hardware design NRFHW[10] 0x078 Reserved for Nordic hardware design NRFHW[11] 0x07C Reserved for Nordic hardware design CUSTOMER[0] 0x080 Reserved for customer CUSTOMER[1] 0x084 Reserved for customer CUSTOMER[2] 0x088 Reserved for customer CUSTOMER[3] 0x08C Reserved for customer CUSTOMER[4] 0x090 Reserved for customer CUSTOMER[5] 0x094 Reserved for customer CUSTOMER[6] 0x098 Reserved for customer CUSTOMER[7] 0x09C Reserved for customer CUSTOMER[8] 0x0A0 Reserved for customer CUSTOMER[9] 0x0A4 Reserved for customer CUSTOMER[10] 0x0A8 Reserved for customer CUSTOMER[11] 0x0AC Reserved for customer CUSTOMER[12] 0x0B0 Reserved for customer CUSTOMER[13] 0x0B4 Reserved for customer CUSTOMER[14] 0x0B8 Reserved for customer CUSTOMER[15] 0x0BC Reserved for customer CUSTOMER[16] 0x0C0 Reserved for customer CUSTOMER[17] 0x0C4 Reserved for customer CUSTOMER[18] 0x0C8 Reserved for customer CUSTOMER[19] 0x0CC Reserved for customer CUSTOMER[20] 0x0D0 Reserved for customer CUSTOMER[21] 0x0D4 Reserved for customer CUSTOMER[22] 0x0D8 Reserved for customer CUSTOMER[23] 0x0DC Reserved for customer CUSTOMER[24] 0x0E0 Reserved for customer CUSTOMER[25] 0x0E4 Reserved for customer CUSTOMER[26] 0x0E8 Reserved for customer CUSTOMER[27] 0x0EC Reserved for customer CUSTOMER[28] 0x0F0 Reserved for customer CUSTOMER[29] 0x0F4 Reserved for customer CUSTOMER[30] 0x0F8 Reserved for customer CUSTOMER[31] 0x0FC Reserved for customer PSELRESET[0] 0x200 Mapping of the nRESET function (see POWER chapter for details) PSELRESET[1] 0x204 Mapping of the nRESET function (see POWER chapter for details) APPROTECT 0x208 Access port protection Table 11: Register overview 4454_187 v1.2 32 Core components 4.5.1.1 NRFFW[n] (n=0..12) Address offset: 0x014 + (n × 0x4) Reserved for Nordic firmware design Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF ID Access Field A RW NRFFW 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description Reserved for Nordic firmware design 4.5.1.2 NRFHW[n] (n=0..11) Address offset: 0x050 + (n × 0x4) Reserved for Nordic hardware design Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 ID Access Field A RW NRFHW Value ID Value Description Reserved for Nordic hardware design 4.5.1.3 CUSTOMER[n] (n=0..31) Address offset: 0x080 + (n × 0x4) Reserved for customer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF ID Access Field A RW CUSTOMER 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description Reserved for customer 4.5.1.4 PSELRESET[n] (n=0..1) Address offset: 0x200 + (n × 0x4) Mapping of the nRESET function (see POWER chapter for details) All PSELRESET registers have to contain the same value for a pin mapping to be valid. If values are not the same, there will be no nRESET function exposed on a GPIO. As a result, the device will always start independently of the levels present on any of the GPIOs. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID C Reset 0xFFFFFFFF ID Access Field A RW PIN C RW CONNECT 4454_187 v1.2 A A A A A 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description 21 GPIO pin number onto which nRESET is exposed Connection Disconnected 1 Disconnect Connected 0 Connect 33 Core components 4.5.1.5 APPROTECT Address offset: 0x208 Access port protection Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A Reset 0xFFFFFFFF ID Access Field A RW PALL 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description Enable or disable access port protection. See Debug on page 37 for more information. Disabled 0xFF Disable Enabled 0x00 Enable 4.6 EasyDMA EasyDMA is a module implemented by some peripherals to gain direct access to Data RAM. EasyDMA is an AHB bus master similar to CPU and is connected to the AHB multilayer interconnect for direct access to Data RAM. EasyDMA is not able to access flash. A peripheral can implement multiple EasyDMA instances to provide dedicated channels. For example, for reading and writing of data between the peripheral and RAM. This concept is illustrated in EasyDMA example on page 34. RAM AHB multilayer Peripheral READER RAM RAM AHB EasyDMA WRITER AHB EasyDMA Figure 4: EasyDMA example 4454_187 v1.2 34 Peripheral core Core components An EasyDMA channel is implemented in the following way, but some variations may occur: READERBUFFER_SIZE 5 WRITERBUFFER_SIZE 6 uint8_t readerBuffer[READERBUFFER_SIZE] __at__ 0x20000000; uint8_t writerBuffer[WRITERBUFFER_SIZE] __at__ 0x20000005; // Configuring the READER channel MYPERIPHERAL->READER.MAXCNT = READERBUFFER_SIZE; MYPERIPHERAL->READER.PTR = &readerBuffer; // Configure the WRITER channel MYPERIPHERAL->WRITER.MAXCNT = WRITEERBUFFER_SIZE; MYPERIPHERAL->WRITER.PTR = &writerBuffer; This example shows a peripheral called MYPERIPHERAL that implements two EasyDMA channels - one for reading called READER, and one for writing called WRITER. When the peripheral is started, it is assumed that the peripheral will perform the following tasks: • Read 5 bytes from the readerBuffer located in RAM at address 0x20000000 • Process the data • Write no more than 6 bytes back to the writerBuffer located in RAM at address 0x20000005 The memory layout of these buffers is illustrated in EasyDMA memory layout on page 35. 0x20000000 readerBuffer[0] readerBuffer[1] readerBuffer[2] readerBuffer[3] 0x20000004 readerBuffer[4] writerBuffer[0] writerBuffer[1] writerBuffer[2] 0x20000008 writerBuffer[3] writerBuffer[4] writerBuffer[5] Figure 5: EasyDMA memory layout The WRITER.MAXCNT register should not be specified larger than the actual size of the buffer (writerBuffer). Otherwise, the channel would overflow the writerBuffer. Once an EasyDMA transfer is completed, the AMOUNT register can be read by the CPU to see how many bytes were transferred. For example, CPU can read MYPERIPHERAL->WRITER.AMOUNT register to see how many bytes WRITER wrote to RAM. Note: The PTR register of a READER or WRITER must point to a valid memory region before use. The reset value of a PTR register is not guaranteed to point to valid memory. See Memory on page 15 for more information about the different memory regions and EasyDMA connectivity. 4.6.1 EasyDMA error handling Some errors may occur during DMA handling. If READER.PTR or WRITER.PTR is not pointing to a valid memory region, an EasyDMA transfer may result in a HardFault or RAM corruption. See Memory on page 15 for more information about the different memory regions. 4454_187 v1.2 35 Core components If several AHB bus masters try to access the same AHB slave at the same time, AHB bus congestion might occur. An EasyDMA channel is an AHB master. Depending on the peripheral, the peripheral may either stall and wait for access to be granted, or lose data. 4.6.2 EasyDMA array list EasyDMA is able to operate in Array List mode. The Array List mode is implemented in channels where the LIST register is available. The array list does not provide a mechanism to explicitly specify where the next item in the list is located. Instead, it assumes that the list is organized as a linear array where items are located one after the other in RAM. The EasyDMA Array List can be implemented by using the data structure ArrayList_type as illustrated in the code example below using a READER EasyDMA channel as an example: #define BUFFER_SIZE 4 typedef struct ArrayList { uint8_t buffer[BUFFER_SIZE]; } ArrayList_type; ArrayList_type ReaderList[3] __at__ 0x20000000; MYPERIPHERAL->READER.MAXCNT = BUFFER_SIZE; MYPERIPHERAL->READER.PTR = &ReaderList; MYPERIPHERAL->READER.LIST = MYPERIPHERAL_READER_LIST_ArrayList; The data structure only includes a buffer with size equal to the size of READER.MAXCNT register. EasyDMA uses the READER.MAXCNT register to determine when the buffer is full. READER.PTR = &ReaderList 0x20000000 : ReaderList[0] buffer[0] buffer[1] buffer[2] buffer[3] 0x20000004 : ReaderList[1] buffer[0] buffer[1] buffer[2] buffer[3] 0x20000008 : ReaderList[2] buffer[0] buffer[1] buffer[2] buffer[3] Figure 6: EasyDMA array list 4.7 AHB multilayer AHB multilayer enables parallel access paths between multiple masters and slaves in a system. Access is resolved using priorities. Each bus master is connected to the slave devices using an interconnection matrix. The bus masters are assigned priorities. Priorities are used to resolve access when two (or more) bus masters request access to the same slave device. The following applies: 4454_187 v1.2 36 Core components • If two (or more) bus masters request access to the same slave device, the master with the highest priority is granted the access first. • Bus masters with lower priority are stalled until the higher priority master has completed its transaction. • If the higher priority master pauses at any point during its transaction, the lower priority master in queue is temporarily granted access to the slave device until the higher priority master resumes its activity. • Bus masters that have the same priority are mutually exclusive, thus cannot be used concurrently. Below is a list of bus masters in the system and their priorities. Bus master name Description CPU SPIM0/SPIS0 Same priority and mutually exclusive RADIO CCM/ECB/AAR Same priority and mutually exclusive SAADC UARTE0 TWIM0/TWIS0 Same priority and mutually exclusive Table 12: AHB bus masters (listed in priority order, highest to lowest) Defined bus masters are the CPU and the peripherals with implemented EasyDMA, and the available slaves are RAM AHB slaves. How the bus masters and slaves are connected using the interconnection matrix is illustrated in Memory on page 15. 4.8 Debug Debug system offers a flexible and powerful mechanism for non-intrusive debugging. DAP SWDCLK External debugger CTRL-AP NVMC SW-DP APPROTECT.PALL SWDIO UICR DAP bus interconnect AHB AHB-AP CxxxPWRUPREQ CxxxPWRUPRACK POWER Power CPU ARM Cortex-M4 APB/AHB Figure 7: Debug overview The main features of the debug system are the following: • Two-pin serial wire debug (SWD) interface • Flash patch and breakpoint (FPB) unit that supports: • Two literal comparators 4454_187 v1.2 RAM & flash 37 Peripherals Core components • Six instruction comparators 4.8.1 DAP - Debug access port An external debugger can access the device via the DAP. The debug access port (DAP) implements a standard ARM® CoreSight™ serial wire debug port (SW-DP), which implements the serial wire debug protocol (SWD). SWD is a two-pin serial interface, see SWDCLK and SWDIO in Debug overview on page 37. In addition to the default access port in CPU (AHB-AP), the DAP includes a custom control access port (CTRL-AP). The CTRL-AP is described in more detail in CTRL-AP - Control access port on page 38. Note: • The SWDIO line has an internal pull-up resistor. • The SWDCLK line has an internal pull-down resistor. 4.8.2 CTRL-AP - Control access port The control access port (CTRL-AP) is a custom access port that enables control of the device when other access ports in the DAP are disabled by the access port protection. Access port protection blocks the debugger from read and write access to all CPU registers and memorymapped addresses. See the UICR register APPROTECT on page 34 for more information on enabling access port protection. Control access port has the following features: • Soft reset, see Reset on page 51 for more information • Disabling of access port protection, which is the reason why CTRL-AP allows control of the device even when all other access ports in the DAP are disabled by the access port protection Access port protection is disabled by issuing an ERASEALL command via CTRL-AP. This command will erase the flash, UICR, and RAM. 4.8.2.1 Registers Register Offset Description RESET 0x000 Soft reset triggered through CTRL-AP ERASEALL 0x004 Erase all ERASEALLSTATUS 0x008 Status register for the ERASEALL operation APPROTECTSTATUS 0x00C Status register for access port protection IDR 0x0FC CTRL-AP identification register, IDR Table 13: Register overview 4.8.2.1.1 RESET Address offset: 0x000 Soft reset triggered through CTRL-AP 4454_187 v1.2 38 Core components Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW RESET 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Soft reset triggered through CTRL-AP. See Reset behavior in POWER chapter for more details. NoReset 0 Reset is not active Reset 1 Reset is active. Device is held in reset. 4.8.2.1.2 ERASEALL Address offset: 0x004 Erase all Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description NoOperation 0 No operation Erase 1 Erase all flash and RAM ERASEALL Erase all flash and RAM 4.8.2.1.3 ERASEALLSTATUS Address offset: 0x008 Status register for the ERASEALL operation Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Ready 0 ERASEALL is ready Busy 1 ERASEALL is busy (on-going) ERASEALLSTATUS Status register for the ERASEALL operation 4.8.2.1.4 APPROTECTSTATUS Address offset: 0x00C Status register for access port protection Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description APPROTECTSTATUS Status register for access port protection Enabled 0 Access port protection enabled Disabled 1 Access port protection not enabled 4.8.2.1.5 IDR Address offset: 0x0FC CTRL-AP identification register, IDR 4454_187 v1.2 39 Core components Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID E E E E D D D D C C C C C C C B B B B Reset 0x02880000 0 0 0 0 0 0 1 0 1 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field A R APID Value ID Value AP identification B R CLASS Access port (AP) class A A A A A A A A Description NotDefined 0x0 No defined class MEMAP 0x8 Memory access port C R JEP106ID JEDEC JEP106 identity code D R JEP106CONT JEDEC JEP106 continuation code E R REVISION Revision 4.8.2.2 Electrical specification 4.8.2.2.1 Control access port Symbol Description Rpull Internal SWDIO and SWDCLK pull up/down resistance fSWDCLK SWDCLK frequency Min. Typ. Max. 13 0.125 Units kΩ 8 MHz 4.8.3 Debug interface mode Before an external debugger can access either CPU's access port (AHB-AP) or the control access port (CTRL-AP), the debugger must first request the device to power up via CxxxPWRUPREQ in the SWJ-DP. If the device is in System OFF when power is requested via CxxxPWRUPREQ, the system will wake up and the DIF flag in RESETREAS on page 56 will be set. The device is in the debug interface mode as long as the debugger is requesting power via CxxxPWRUPREQ. Once the debugger stops requesting power via CxxxPWRUPREQ, the device is back in normal mode. Some peripherals behave differently in Debug Interface mode compared to normal mode. These differences are described in more detail in the chapters of the peripherals that are affected. When a debug session is over, the external debugger must make sure to put the device back into normal mode since the overall power consumption is higher in debug interface mode than in normal mode. For details on how to use the debug capabilities, read the debug documentation of your IDE. 4.8.4 Real-time debug The nRF52805 supports real-time debugging. Real-time debugging allows interrupts to execute to completion in real time when breakpoints are set in thread mode or lower priority interrupts. This enables developers to set breakpoints and single-step through the code without the risk of real-time event-driven threads running at higher priority failing. For example, this enables the device to continue to service the high-priority interrupts of an external controller or sensor without failure or loss of state synchronization while the developer steps through code in a low-priority thread. 4454_187 v1.2 40 5 Power and clock management 5.1 Power management unit (PMU) Power and clock management in nRF52805 is designed to automatically ensure maximum power efficiency. The core of the power and clock management system is the power management unit (PMU) illustrated in Power management unit on page 41. MCU CPU External power sources Internal voltage regulators PMU Memory External crystals Internal oscillators Peripheral Figure 8: Power management unit The PMU automatically detects which power and clock resources are required by the different components in the system at any given time. It will then start/stop and choose operation modes in supply regulators and clock sources, without user interaction, to achieve the lowest power consumption possible. 5.2 Current consumption Because the system is continually being tuned by the Power management unit (PMU) on page 41, estimating an application's current consumption can be challenging when measurements cannot be directly performed on the hardware. To facilitate the estimation process, a set of current consumption scenarios are provided to show the typical current drawn from the VDD supply. Each scenario specifies a set of operations and conditions applying to the given scenario. The following table shows a set of common conditions used in all scenarios, unless otherwise stated in the description of a given scenario. All scenarios are listed in Electrical specification on page 42. 4454_187 v1.2 41 Power and clock management Condition Value VDD 3V Temperature 25°C CPU WFI (wait for interrupt)/WFE (wait for event) sleep Peripherals All idle Clock Not running Regulator LDO RAM In System ON, full 24 kB powered. In System OFF or System ON Idle, full 24 kB retention. Compiler3 GCC v4.9.3 20150529 (arm-none-eabi-gcc). Compiler flags: -O0 -falignfunctions=16 -fno-strict-aliasing -mcpu=cortex-m4 -mfloat-abi=soft -msoftfloat -mthumb. 32 MHz crystal4 SMD 2520, 32 MHz, 10 pF +/- 10 ppm Table 14: Current consumption scenarios, common conditions 5.2.1 Electrical specification 5.2.1.1 Sleep Symbol Description ION_RAMOFF_EVENT System ON, no RAM retention, wake on any event Min. Typ. 0.6 Max. Units µA ION_RAMON_EVENT System ON, full 24 kB RAM retention, wake on any event 0.8 µA ION_RAMON_POF System ON, full 24 kB RAM retention, wake on any event, 0.8 µA 3.3 µA 0.8 µA 1.4 µA 1.5 µA power-fail comparator enabled ION_RAMON_GPIOTE System ON, full 24 kB RAM retention, wake on GPIOTE input (event mode) ION_RAMON_GPIOTEPORTSystem ON, full 24 kB RAM retention, wake on GPIOTE PORT event ION_RAMOFF_RTC System ON, no RAM retention, wake on RTC (running from LFRC clock) ION_RAMON_RTC System ON, full 24 kB RAM retention, wake on RTC (running from LFRC clock) IOFF_RAMOFF_RESET System OFF, no RAM retention, wake on reset 0.3 µA IOFF_RAMON_RESET System OFF, full 24 kB RAM retention, wake on reset 0.5 µA 1.1 µA 1.0 µA ION_RAMON_RTC_LFXO System ON, full 24 kB RAM retention, wake on RTC (running from LFXO clock) ION_RAMOFF_RTC_LFXO System ON, no RAM retention, wake on RTC (running from LFXO clock) 3 4 Applying only when CPU is running Applying only when HFXO is running 4454_187 v1.2 42 Power and clock management 2.5 Current consumption [µA] 2 1.5 1 0.5 0 -40 -20 0 20 40 60 80 100 Temperature Range [ºC] 1.7 V 3V 3.6 V Figure 9: System OFF, no RAM retention, wake on reset (typical values) 16 14 Current consumption [µA] 12 10 8 6 4 2 0 -40 -20 0 20 40 60 80 100 Temperature Range [ºC] 1.7 V 3V 3.6 V Figure 10: System ON, full 24 kB RAM retention, wake on any event (typical values) 4454_187 v1.2 43 Power and clock management 5.2.1.2 CPU running Symbol Description ICPU0 CPU running CoreMark @64 MHz from flash, Clock = HFXO, Min. Typ. Max. Units 2.2 mA Regulator = DC/DC ICPU1 CPU running CoreMark @64 MHz from flash, Clock = HFXO 4.2 mA ICPU2 CPU running CoreMark @64 MHz from RAM, Clock = HFXO, 2.1 mA Regulator = DC/DC ICPU3 CPU running CoreMark @64 MHz from RAM, Clock = HFXO 4 mA ICPU4 CPU running CoreMark @64 MHz from flash, Clock = HFINT, 2 mA Regulator = DC/DC 5.2.1.3 Radio transmitting/receiving Symbol Description IRADIO_TX0 Radio transmitting @ 4 dBm output power, 1 Mbps Min. Typ. Max. Units 8 mA 5.8 mA 3.4 mA 10.5 mA 5.1 mA 6.1 mA 10.8 mA ® Bluetooth Low Energy (BLE) mode, Clock = HFXO, Regulator = DC/DC IRADIO_TX1 Radio transmitting @ 0 dBm output power, 1 Mbps BLE mode, Clock = HFXO, Regulator = DC/DC IRADIO_TX2 Radio transmitting @ -40 dBm output power, 1 Mbps BLE mode, Clock = HFXO, Regulator = DC/DC IRADIO_TX3 Radio transmitting @ 0 dBm output power, 1 Mbps BLE mode, Clock = HFXO IRADIO_TX4 Radio transmitting @ -40 dBm output power, 1 Mbps BLE mode, Clock = HFXO IRADIO_RX0 Radio receiving @ 1 Mbps BLE mode, Clock = HFXO, Regulator = DC/DC IRADIO_RX1 4454_187 v1.2 Radio receiving @ 1 Mbps BLE mode, Clock = HFXO 44 Power and clock management 15 14 Current consumption [mA] 13 12 11 10 9 8 7 1.6 1.8 2 2.2 2.4 2.6 2.8 3 3.2 3.4 3.6 Supply voltage [V] -40 ºC 25 ºC 85 ºC Figure 11: Radio transmitting @ 4 dBm output power, 1 Mbps BLE mode, Clock = HFXO, Regulator = DC/DC (typical values) 10 9.5 Current consumption [mA] 9 8.5 8 7.5 7 6.5 6 5.5 5 1.6 1.8 2 2.2 2.4 2.6 2.8 3 3.2 3.4 Supply voltage [V] -40 ºC 25 ºC 85 ºC Figure 12: Radio transmitting @ 0 dBm output power, 1 Mbps BLE mode, Clock = HFXO, Regulator = DC/DC (typical values) 4454_187 v1.2 45 3.6 Power and clock management 5.2.1.4 RNG active Symbol Description IRNG0 RNG running Min. Typ. Max. 539 Units µA 5.2.1.5 TEMP active Symbol Description ITEMP0 TEMP started Min. Typ. Max. 1.0 Units mA 5.2.1.6 TIMER running Symbol Description ITIMER0 One TIMER instance running @ 1 MHz, Clock = HFINT Min. Typ. 432 Max. Units µA ITIMER1 Two TIMER instances running @ 1 MHz, Clock = HFINT 432 µA ITIMER2 One TIMER instance running @ 1 MHz, Clock = HFXO 730 µA ITIMER3 One TIMER instance running @ 16 MHz, Clock = HFINT 495 µA ITIMER4 One TIMER instance running @ 16 MHz, Clock = HFXO 792 µA 5.2.1.7 SAADC active Symbol Description ISAADC,RUN SAADC sampling @ 16 ksps, Acquisition time = 20 µs, Clock = Min. Typ. Max. 1.1 Units mA HFXO, Regulator = DCDC 5.2.1.8 WDT active Symbol Description IWDT,STARTED WDT started Min. Typ. Max. 1.3 Units µA 5.2.1.9 Compounded Symbol Description IS0 CPU running CoreMark from flash, Radio transmitting @ 0 Min. Typ. Max. Units 7.4 mA 7.6 mA 13.8 mA 14.2 mA ® dBm output power, 1 Mbps Bluetooth Low Energy (BLE) mode, Clock = HFXO, Regulator = DC/DC IS1 CPU running CoreMark from flash, Radio receiving @ 1 Mbps BLE mode, Clock = HFXO, Regulator = DC/DC IS2 CPU running CoreMark from flash, Radio transmitting @ 0 dBm output power, 1 Mbps BLE mode, Clock = HFXO IS3 CPU running CoreMark from flash, Radio receiving @ 1 Mbps BLE mode, Clock = HFXO 5.3 POWER — Power supply This device has the following power supply features: • On-chip LDO and DC/DC regulators • Global System ON/OFF modes with individual RAM section power control 4454_187 v1.2 46 Power and clock management • • • • Analog or digital pin wakeup from System OFF Supervisor HW to manage power on reset, brownout, and power fail Auto-controlled refresh modes for LDO and DC/DC regulators to maximize efficiency Automatic switching between LDO and DC/DC regulator based on load to maximize efficiency Note: Two additional external passive components are required to use the DC/DC regulator. 5.3.1 Regulators The following internal power regulator alternatives are supported: • Internal LDO regulator • Internal DC/DC regulator The LDO is the default regulator. The DC/DC regulator can be used as an alternative to the LDO regulator and is enabled through the DCDCEN on page 58 register. Using the DC/DC regulator will reduce current consumption compared to when using the LDO regulator, but the DC/DC regulator requires an external LC filter to be connected, as shown in DC/DC regulator setup on page 48. POWER DCDCEN REG Supply LDO 1.3V System power VDD DC/DC DCC DEC4 Figure 13: LDO regulator setup 4454_187 v1.2 47 GND Power and clock management POWER DCDCEN REG Supply LDO 1.3V System power VDD DC/DC DCC DEC4 GND Figure 14: DC/DC regulator setup 5.3.2 System OFF mode System OFF is the deepest power saving mode the system can enter. In this mode, the system’s core functionality is powered down and all ongoing tasks are terminated. The device can be put into System OFF mode using the register SYSTEMOFF on page 56. When in System OFF mode, the device can be woken up through one of the following signals: • The DETECT signal, optionally generated by the GPIO peripheral • A reset When the system wakes up from System OFF mode, it gets reset. For more details, see Reset behavior on page 52. One or more RAM sections can be retained in System OFF mode, depending on the settings in the RAM[n].POWER registers. RAM[n].POWER are retained registers, see Reset behavior. These registers are usually overwritten by the startup code provided with the nRF application examples. Before entering System OFF mode, the user must make sure that all on-going EasyDMA transactions have been completed. This is usually accomplished by making sure that the EasyDMA enabled peripheral is not active when entering System OFF. 5.3.2.1 Emulated System OFF mode If the device is in debug interface mode, System OFF will be emulated to secure that all required resources needed for debugging are available during System OFF. See Debug on page 37 for more information. Required resources needed for debugging include the following key components: • • • • • • Debug on page 37 CLOCK — Clock control on page 60 POWER — Power supply on page 46 NVMC — Non-volatile memory controller on page 18 CPU Flash 4454_187 v1.2 48 Power and clock management • RAM Since the CPU is kept on in an emulated System OFF mode, it is recommended to add an infinite loop directly after entering System OFF, to prevent the CPU from executing code that normally should not be executed. 5.3.3 System ON mode System ON is the default state after power-on reset. In System ON, all functional blocks such as the CPU or peripherals can be in IDLE or RUN mode, depending on the configuration set by the software and the state of the application executing. Register RESETREAS on page 56 provides information about the source causing the wakeup or reset. The system can switch the appropriate internal power sources on and off, depending on how much power is needed at any given time. The power requirement of a peripheral is directly related to its activity level, and the activity level of a peripheral is usually raised and lowered when specific tasks are triggered or events are generated. 5.3.3.1 Sub power modes In System ON mode, when both the CPU and all the peripherals are in IDLE mode, the system can reside in one of the two sub power modes. The sub power modes are: • Constant Latency • Low-power In Constant Latency mode, the CPU wakeup latency and the PPI task response are constant and kept at a minimum. This is secured by forcing a set of basic resources to be turned on while in sleep. Having a constant and predictable latency is at the cost of having increased power consumption. The Constant Latency mode is selected by triggering the CONSTLAT task. In Low-power mode, the automatic power management system described in System ON mode on page 49 ensures that the most efficient supply option is chosen to save most power. Having the lowest power possible is at the cost of having a varying CPU wakeup latency and PPI task response. The Lowpower mode is selected by triggering the LOWPWR task. When the system enters System ON mode, it is by default in Low-power sub power mode. 5.3.4 Power supply supervisor The power supply supervisor initializes the system at power-on and provides an early warning of impending power failure. In addition, the power supply supervisor puts the system in a reset state if the supply voltage is too low for safe operation (brownout). The power supply supervisor is illustrated in Power supply supervisor on page 50. 4454_187 v1.2 49 Power and clock management VDD C Power on reset R VBOR POFCON Brownout reset 1.7V ........... MUX POFWARN Vpof 2.8V Figure 15: Power supply supervisor 5.3.4.1 Power-fail comparator The power-fail comparator (POF) can provide the CPU with an early warning of impending power failure. It will not reset the system, but give the CPU time to prepare for an orderly power-down. The comparator features a hysteresis of VHYST, as illustrated in Power-fail comparator (BOR = Brownout reset) on page 50. The threshold VPOF is set in register POFCON on page 57. If the POF is enabled and the supply voltage falls below VPOF, the POFWARN event will be generated. This event will also be generated if the supply voltage is already below VPOF at the time the POF is enabled, or if VPOF is reconfigured to a level above the supply voltage. If power-fail warning is enabled and the supply voltage is below VPOF the power-fail comparator will prevent the NVMC from performing write operations to the NVM. See NVMC — Non-volatile memory controller on page 18 for more information about the NVMC. VDD VPOF+VHYST VPOF 1.7V POFWARN POFWARN MCU t BOR Figure 16: Power-fail comparator (BOR = Brownout reset) To save power, the power-fail comparator is not active in System OFF or in System ON when HFCLK is not running. 4454_187 v1.2 50 Power and clock management 5.3.5 RAM power control The RAM power control registers are used for configuring the following: • The RAM sections to be retained during System OFF • The RAM sections to be retained and accessible during System ON In System OFF, retention of a RAM section is configured in the RETENTION field of the corresponding RAM[n] register. In System ON, retention and accessibility for a RAM section is configured in the RETENTION and POWER fields of the corresponding RAM[n] register. The following table summarizes the behavior of these registers. Configuration RAM section status System on/off RAM[n].POWER.POWER RAM[n].POWER.RETENTION Accessible Retained Off x Off No No Off x On No Yes On Off Off No No On Off1 On No Yes On On x Yes Yes Table 15: RAM section configuration The advantage of not retaining RAM contents is that the overall current consumption is reduced. See chapter Memory on page 15 for more information on RAM sections. 5.3.6 Reset There are multiple sources that may trigger a reset. After a reset has occurred, register RESETREAS can be read to determine which source generated the reset. 5.3.6.1 Power-on reset The power-on reset generator initializes the system at power-on. The system is held in reset state until the supply has reached the minimum operating voltage and the internal voltage regulators have started. A step increase in supply voltage of 300 mV or more, with rise time of 300 ms or less, within the valid supply range, may result in a system reset. 5.3.6.2 Pin reset A pin reset is generated when the physical reset pin on the device is asserted. Pin reset is configured via the PSELRESET[n] registers. Note: Pin reset is not available on all pins. 5.3.6.3 Wakeup from System OFF mode reset The device is reset when it wakes up from System OFF mode. 1 Not useful setting. RAM section power off gives negligible reduction in current consumption when retention is on. 4454_187 v1.2 51 Power and clock management The debug access port (DAP) is not reset following a wake up from System OFF mode if the device is in Debug Interface mode. See chapter Debug on page 37 for more information. 5.3.6.4 Soft reset A soft reset is generated when the SYSRESETREQ bit of the Application Interrupt and Reset Control Register (AIRCR register) in the ARM® core is set. Refer to ARM documentation for more details. A soft reset can also be generated via the RESET on page 38 register in the CTRL-AP. 5.3.6.5 Watchdog reset A Watchdog reset is generated when the watchdog times out. See chapter WDT — Watchdog timer on page 338 for more information. 5.3.6.6 Brown-out reset The brown-out reset generator puts the system in reset state if the supply voltage drops below the brownout reset (BOR) threshold. Refer to section Power fail comparator on page 60 for more information. 5.3.7 Retained registers A retained register is a register that will retain its value in System OFF mode and through a reset, depending on reset source. See individual peripheral chapters for information of which registers are retained for the various peripherals. 5.3.8 Reset behavior Reset source Reset target CPU Peripherals GPIO Debuga SWJ-DP RAM WDT Retained RESETREAS registers CPU lockup 5 x x x Soft reset x x x Wakeup from System OFF x x Watchdog reset 8 x x Pin reset x Brownout reset x Power on reset x x6 x7 x x x x x x x x x x x x x x x x x x x x x x x x x x x x mode reset Note: The RAM is never reset, but depending on reset source, RAM content may be corrupted. a 5 6 7 8 All debug components excluding SWJ-DP. See Debug on page 37 for more information about the different debug components in the system. Reset from CPU lockup is disabled if the device is in debug interface mode. CPU lockup is not possible in System OFF. The Debug components will not be reset if the device is in debug interface mode. RAM is not reset on wakeup from System OFF mode, but depending on settings in the RAM registers, parts, or the whole RAM may not be retained after the device has entered System OFF mode. Watchdog reset is not available in System OFF. 4454_187 v1.2 52 Power and clock management 5.3.9 Registers Base address Peripheral Instance Description Configuration 0x40000000 POWER POWER Power control For 24 kB RAM variant, only RAM[0].x to RAM[2].x registers are in use. Table 16: Instances Register Offset Description TASKS_CONSTLAT 0x078 Enable Constant Latency mode TASKS_LOWPWR 0x07C Enable Low-power mode (variable latency) EVENTS_POFWARN 0x108 Power failure warning EVENTS_SLEEPENTER 0x114 CPU entered WFI/WFE sleep EVENTS_SLEEPEXIT 0x118 CPU exited WFI/WFE sleep INTENSET 0x304 Enable interrupt INTENCLR 0x308 Disable interrupt RESETREAS 0x400 Reset reason SYSTEMOFF 0x500 System OFF register POFCON 0x510 Power failure comparator configuration GPREGRET 0x51C General purpose retention register GPREGRET2 0x520 General purpose retention register DCDCEN 0x578 DC/DC enable register RAM[0].POWER 0x900 RAM0 power control register. The RAM size will vary depending on product variant, and the RAM0 register will only be present if the corresponding RAM AHB slave is present on the device. RAM[0].POWERSET 0x904 RAM0 power control set register RAM[0].POWERCLR 0x908 RAM0 power control clear register RAM[1].POWER 0x910 RAM1 power control register. The RAM size will vary depending on product variant, and the RAM1 register will only be present if the corresponding RAM AHB slave is present on the device. RAM[1].POWERSET 0x914 RAM1 power control set register RAM[1].POWERCLR 0x918 RAM1 power control clear register RAM[2].POWER 0x920 RAM2 power control register. The RAM size will vary depending on product variant, and the RAM2 register will only be present if the corresponding RAM AHB slave is present on the device. RAM[2].POWERSET 0x924 RAM2 power control set register RAM[2].POWERCLR 0x928 RAM2 power control clear register RAM[3].POWER 0x930 RAM3 power control register. The RAM size will vary depending on product variant, and the RAM3 register will only be present if the corresponding RAM AHB slave is present on the device. RAM[3].POWERSET 0x934 RAM3 power control set register RAM[3].POWERCLR 0x938 RAM3 power control clear register RAM[4].POWER 0x940 RAM4 power control register. The RAM size will vary depending on product variant, and the RAM4 register will only be present if the corresponding RAM AHB slave is present on the device. RAM[4].POWERSET 0x944 RAM4 power control set register RAM[4].POWERCLR 0x948 RAM4 power control clear register RAM[5].POWER 0x950 RAM5 power control register. The RAM size will vary depending on product variant, and the RAM5 register will only be present if the corresponding RAM AHB slave is present on the device. RAM[5].POWERSET 0x954 RAM5 power control set register RAM[5].POWERCLR 0x958 RAM5 power control clear register 4454_187 v1.2 53 Power and clock management Register Offset Description RAM[6].POWER 0x960 RAM6 power control register. The RAM size will vary depending on product variant, and the RAM6 register will only be present if the corresponding RAM AHB slave is present on the device. RAM[6].POWERSET 0x964 RAM6 power control set register RAM[6].POWERCLR 0x968 RAM6 power control clear register RAM[7].POWER 0x970 RAM7 power control register. The RAM size will vary depending on product variant, and the RAM7 register will only be present if the corresponding RAM AHB slave is present on the device. RAM[7].POWERSET 0x974 RAM7 power control set register RAM[7].POWERCLR 0x978 RAM7 power control clear register Table 17: Register overview 5.3.9.1 TASKS_CONSTLAT Address offset: 0x078 Enable Constant Latency mode Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_CONSTLAT Enable Constant Latency mode Trigger task 5.3.9.2 TASKS_LOWPWR Address offset: 0x07C Enable Low-power mode (variable latency) Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_LOWPWR Enable Low-power mode (variable latency) Trigger task 5.3.9.3 EVENTS_POFWARN Address offset: 0x108 Power failure warning Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_POFWARN 4454_187 v1.2 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Power failure warning NotGenerated 0 Event not generated Generated 1 Event generated 54 Power and clock management 5.3.9.4 EVENTS_SLEEPENTER Address offset: 0x114 CPU entered WFI/WFE sleep Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_SLEEPENTER 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description NotGenerated 0 Event not generated Generated 1 Event generated CPU entered WFI/WFE sleep 5.3.9.5 EVENTS_SLEEPEXIT Address offset: 0x118 CPU exited WFI/WFE sleep Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_SLEEPEXIT 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description NotGenerated 0 Event not generated Generated 1 Event generated CPU exited WFI/WFE sleep 5.3.9.6 INTENSET Address offset: 0x304 Enable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID C B Reset 0x00000000 ID Access Field A RW POFWARN B C Value ID Value Description Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Write '1' to enable interrupt for event POFWARN RW SLEEPENTER Write '1' to enable interrupt for event SLEEPENTER RW SLEEPEXIT Write '1' to enable interrupt for event SLEEPEXIT 5.3.9.7 INTENCLR Address offset: 0x308 Disable interrupt 4454_187 v1.2 A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 55 Power and clock management Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID C B Reset 0x00000000 ID Access Field A RW POFWARN B C A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Write '1' to disable interrupt for event POFWARN RW SLEEPENTER Write '1' to disable interrupt for event SLEEPENTER RW SLEEPEXIT Write '1' to disable interrupt for event SLEEPEXIT 5.3.9.8 RESETREAS Address offset: 0x400 Reset reason Unless cleared, the RESETREAS register will be cumulative. A field is cleared by writing '1' to it. If none of the reset sources are flagged, this indicates that the chip was reset from the on-chip reset generator, which will indicate a power-on-reset or a brownout reset. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID F Reset 0x00000000 ID Access Field A RW RESETPIN B C D E E 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description NotDetected 0 Not detected Detected 1 Detected Reset from pin-reset detected RW DOG Reset from watchdog detected NotDetected 0 Not detected Detected 1 Detected NotDetected 0 Not detected Detected 1 Detected NotDetected 0 Not detected Detected 1 Detected RW SREQ Reset from soft reset detected RW LOCKUP Reset from CPU lock-up detected RW OFF Reset due to wake up from System OFF mode when wakeup is triggered from DETECT signal from GPIO F NotDetected 0 Not detected Detected 1 Detected RW DIF Reset due to wake up from System OFF mode when wakeup is triggered from entering into debug interface mode NotDetected 0 Not detected Detected 1 Detected 5.3.9.9 SYSTEMOFF Address offset: 0x500 4454_187 v1.2 D C B A 56 Power and clock management System OFF register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description SYSTEMOFF Enable System OFF mode Enter 1 Enable System OFF mode 5.3.9.10 POFCON Address offset: 0x510 Power failure comparator configuration Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID B B B B A Reset 0x00000000 ID Access Field A RW POF B 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Disabled 0 Disable Enabled 1 Enable V17 4 Set threshold to 1.7 V V18 5 Set threshold to 1.8 V V19 6 Set threshold to 1.9 V V20 7 Set threshold to 2.0 V V21 8 Set threshold to 2.1 V V22 9 Set threshold to 2.2 V V23 10 Set threshold to 2.3 V V24 11 Set threshold to 2.4 V V25 12 Set threshold to 2.5 V V26 13 Set threshold to 2.6 V V27 14 Set threshold to 2.7 V V28 15 Set threshold to 2.8 V Enable or disable power failure comparator RW THRESHOLD Power failure comparator threshold setting 5.3.9.11 GPREGRET Address offset: 0x51C General purpose retention register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A Reset 0x00000000 ID Access Field A RW GPREGRET 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description General purpose retention register This register is a retained register 5.3.9.12 GPREGRET2 Address offset: 0x520 General purpose retention register 4454_187 v1.2 57 Power and clock management Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A Reset 0x00000000 ID Access Field A RW GPREGRET 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description General purpose retention register This register is a retained register 5.3.9.13 DCDCEN Address offset: 0x578 DC/DC enable register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW DCDCEN 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Disabled 0 Disable Enabled 1 Enable Enable or disable DC/DC converter 5.3.9.14 RAM[n].POWER (n=0..7) Address offset: 0x900 + (n × 0x10) RAMn power control register. The RAM size will vary depending on product variant, and the RAMn register will only be present if the corresponding RAM AHB slave is present on the device. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID D C Reset 0x0000FFFF ID Access Field A-B RW S[i]POWER (i=0..1) Value ID Value Description Keep RAM section Si ON or OFF in System ON mode. RAM sections are always retained when ON, but can also be retained when OFF dependent on the settings in SiRETENTION. All RAM sections will be OFF in System OFF mode. C-D Off 0 Off On 1 On RW S[i]RETENTION (i=0..1) Keep retention on RAM section Si when RAM section is in OFF Off 0 Off On 1 On 5.3.9.15 RAM[n].POWERSET (n=0..7) Address offset: 0x904 + (n × 0x10) RAMn power control set register When read, this register will return the value of the POWER register. 4454_187 v1.2 B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 58 Power and clock management Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID D C Reset 0x0000FFFF ID Access Field A-B W C-D W B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value On 1 Description S[i]POWER (i=0..1) Keep RAM section Si of RAMn on or off in System ON mode On S[i]RETENTION (i=0..1) Keep retention on RAM section Si when RAM section is switched off On 1 On 5.3.9.16 RAM[n].POWERCLR (n=0..7) Address offset: 0x908 + (n × 0x10) RAMn power control clear register When read, this register will return the value of the POWER register. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID D C Reset 0x0000FFFF B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 ID Access Field Value ID A-B W S[i]POWER (i=0..1) C-D W S[i]RETENTION (i=0..1) Value Description Keep RAM section Si of RAMn on or off in System ON mode Off 1 Off Keep retention on RAM section Si when RAM section is switched off Off 1 Off 5.3.10 Electrical specification 5.3.10.1 Device startup times Symbol Description tPOR Time in Power on Reset after VDD reaches 1.7 V for all Min. Typ. Max. Units supply voltages and temperatures. Dependent on supply rise time. 9 tPOR,10us VDD rise time 10 µs 1 ms tPOR,10ms VDD rise time 10 ms 9 ms tPOR,60ms VDD rise time 60 ms 23 ms tPINR If a GPIO pin is configured as reset, the maximum time taken to pull up the pin and release reset after power on reset. Dependent on the pin capacitive load (C)10: t=5RC, R = 13 kΩ tPINR,500nF C = 500 nF 32.5 ms tPINR,10uF C = 10 µF 650 ms tR2ON Time from reset to ON (CPU execute) tR2ON,NOTCONF If reset pin not configured tPOR ms tR2ON,CONF If reset pin configured tPOR + ms tPINR tOFF2ON 9 10 Time from OFF to CPU execute 16.5 µs A step increase in supply voltage of 300 mV or more, with rise time of 300 ms or less, within the valid supply range, may result in a system reset. To decrease maximum time a device could hold in reset, a strong external pullup resistor can be used. 4454_187 v1.2 59 Power and clock management Symbol Description Min. Typ. Max. Units tIDLE2CPU Time from IDLE to CPU execute 3.0 µs tEVTSET,CL1 Time from HW event to PPI event in Constant Latency 0.0625 µs 0.0625 µs System ON mode tEVTSET,CL0 Time from HW event to PPI event in Low Power System ON mode 5.3.10.2 Power fail comparator Symbol Description Min. VPOF Nominal power level warning thresholds (falling supply 1.7 Typ. Max. Units 2.8 V ±5 % voltage). Levels are configurable between Min. and Max. in 100 mV increments. VPOFTOL Threshold voltage tolerance ±1 VPOFHYST Threshold voltage hysteresis 50 VBOR,OFF Brown out reset voltage range SYSTEM OFF mode 1.2 1.7 V VBOR,ON Brown out reset voltage range SYSTEM ON mode 1.48 1.7 V mV 5.4 CLOCK — Clock control The clock control system can source the system clocks from a range of internal or external high and low frequency oscillators and distribute them to modules based upon a module’s individual requirements. Clock distribution is automated and grouped independently by module to limit current consumption in unused branches of the clock tree. Listed here are the main features for CLOCK: • • • • • • • 64 MHz on-chip oscillator 64 MHz crystal oscillator, using external 32 MHz crystal 32.768 kHz +/-500 ppm RC oscillator 32.768 kHz crystal oscillator, using external 32.768 kHz crystal 32.768 kHz oscillator synthesized from 64 MHz oscillator Firmware (FW) override control of oscillator activity for low latency start up Automatic oscillator and clock control, and distribution for ultra-low power 4454_187 v1.2 60 Power and clock management HFCLKSTART HFCLKSTOP LFCLKSTART LFCLKSTOP CLOCK HFINT Internal oscillator PCLK1M PCLK16M XC1 PCLK32M HFCLK Clock control HFXO Crystal oscillator 32 MHz HCLK64M XC2 LFRC RC oscillator CAL SYNT XL1 LFXO Crystal oscillator 32.768 kHz LFCLK Clock control PCLK32KI XL2 HFCLKSTARTED LFCLKSTARTED Figure 17: Clock control 5.4.1 HFCLK clock controller The HFCLK clock controller provides the following clocks to the system. • • • • HCLK64M: 64 MHz CPU clock PCLK1M: 1 MHz peripheral clock PCLK16M: 16 MHz peripheral clock PCLK32M: 32 MHz peripheral clock The HFCLK controller supports the following high frequency clock (HFCLK) sources: • 64 MHz internal oscillator (HFINT) • 64 MHz crystal oscillator (HFXO) For illustration, see Clock control on page 61. When the system requests one or more clocks from the HFCLK controller, the HFCLK controller will automatically provide them. If the system does not request any clocks provided by the HFCLK controller, the controller will enter a power saving mode. These clocks are only available when the system is in ON mode. When the system enters ON mode, the internal oscillator (HFINT) clock source will automatically start to be able to provide the required HFCLK clock(s) for the system. The HFINT will be used when HFCLK is requested and HFXO has not been started. The HFXO is started by triggering the HFCLKSTART task and stopped using the HFCLKSTOP task. A HFCLKSTARTED event will be generated when the HFXO has started and its frequency is stable. The HFXO must be running to use the RADIO or the calibration mechanism associated with the 32.768 kHz RC oscillator. 5.4.1.1 64 MHz crystal oscillator (HFXO) The 64 MHz crystal oscillator (HFXO) is controlled by a 32 MHz external crystal 4454_187 v1.2 61 Power and clock management The crystal oscillator is designed for use with an AT-cut quartz crystal in parallel resonant mode. To achieve correct oscillation frequency, the load capacitance must match the specification in the crystal data sheet. Circuit diagram of the 64 MHz crystal oscillator on page 62 shows how the 32 MHz crystal is connected to the 64 MHz crystal oscillator. XC1 XC2 C1 C2 32 MHz crystal Figure 18: Circuit diagram of the 64 MHz crystal oscillator The load capacitance (CL) is the total capacitance seen by the crystal across its terminals and is given by: C1 and C2 are ceramic SMD capacitors connected between each crystal terminal and ground. For more information, see Reference circuitry on page 345. Cpcb1 and Cpcb2 are stray capacitances on the PCB. Cpin is the pin input capacitance on the XC1 and XC2 pins. See table 64 MHz crystal oscillator (HFXO) on page 71. The load capacitors C1 and C2 should have the same value. For reliable operation, the crystal load capacitance, shunt capacitance, equivalent series resistance, and drive level must comply with the specifications in table 64 MHz crystal oscillator (HFXO) on page 71. It is recommended to use a crystal with lower than maximum load capacitance and/or shunt capacitance. A low load capacitance will reduce both start up time and current consumption. 5.4.2 LFCLK clock controller The system supports several low frequency clock sources. As illustrated in Clock control on page 61, the system supports the following low frequency clock sources: • 32.768 kHz RC oscillator (LFRC) • 32.768 kHz crystal oscillator (LFXO) • 32.768 kHz synthesized from HFCLK (LFSYNT) The LFCLK clock is started by first selecting the preferred clock source in register LFCLKSRC on page 70 and then triggering the LFCLKSTART task. If the LFXO is selected as the clock source, the LFCLK will initially start running from the 32.768 kHz LFRC while the LFXO is starting up and automatically switch to using the LFXO once this oscillator is running. The LFCLKSTARTED event will be generated when the LFXO has been started. 4454_187 v1.2 62 Power and clock management The LFCLK clock is stopped by triggering the LFCLKSTOP task. It is not allowed to write to register LFCLKSRC on page 70 when the LFCLK is running. A LFCLKSTOP task will stop the LFCLK oscillator. However, the LFCLKSTOP task can only be triggered after the STATE field in register LFCLKSTAT on page 70 indicates a 'LFCLK running' state. The LFCLK clock controller and all of the LFCLK clock sources are always switched off when in OFF mode. 5.4.2.1 32.768 kHz RC oscillator (LFRC) The default source of the low frequency clock (LFCLK) is the 32.768 kHz RC oscillator (LFRC). The LFRC frequency will be affected by variation in temperature. The LFRC oscillator can be calibrated to improve accuracy by using the HFXO as a reference oscillator during calibration. See Table 32.768 kHz RC oscillator (LFRC) on page 72 for details on the default and calibrated accuracy of the LFRC oscillator. The LFRC oscillator does not require additional external components. 5.4.2.2 Calibrating the 32.768 kHz RC oscillator After the 32.768 kHz RC oscillator is started and running, it can be calibrated by triggering the CAL task. In this case, the HFCLK will be temporarily switched on and used as a reference. A DONE event will be generated when calibration has finished. The calibration mechanism will only work as long as HFCLK is generated from the HFCLK crystal oscillator, it is therefore necessary to explicitly start this crystal oscillator before calibration can be started, see HFCLKSTART task. It is not allowed to stop the LFRC during an ongoing calibration. 5.4.2.3 Calibration timer The calibration timer can be used to time the calibration interval of the 32.768 kHz RC oscillator. The calibration timer is started by triggering the CTSTART task and stopped by triggering the CTSTOP task. The calibration timer will always start counting down from the value specified in CTIV and generate a CTTO timeout event when it reaches 0. The Calibration timer will stop by itself when it reaches 0. CTSTART CTSTOP Calibration timer CTIV CTTO Figure 19: Calibration timer Due to limitations in the calibration timer, only one task related to calibration, that is, CAL, CTSTART and CTSTOP, can be triggered for every period of LFCLK. 5.4.2.4 32.768 kHz crystal oscillator (LFXO) For higher LFCLK accuracy the low frequency crystal oscillator (LFXO) must be used. The following external clock sources are supported: • Low swing clock signal applied to the XL1 pin. The XL2 pin shall then be grounded. • Rail-to-rail clock signal applied to the XL1 pin. The XL2 pin shall then be grounded or left unconnected. The LFCLKSRC on page 70 register controls the clock source, and its allowed swing. The truth table for various situations is as follows: 4454_187 v1.2 63 Power and clock management SRC EXTERNAL BYPASS Comment 0 0 0 Normal operation, RC is source 0 0 1 DO NOT USE 0 1 X DO NOT USE 1 0 0 Normal XTAL operation 1 1 0 Apply external low swing signal to XL1, ground XL2 1 1 1 Apply external full swing signal to XL1, leave XL2 grounded or unconnected 1 0 1 DO NOT USE 2 0 0 Normal operation, synth is source 2 0 1 DO NOT USE 2 1 X DO NOT USE Table 18: LFCLKSRC configuration depending on clock source To achieve correct oscillation frequency, the load capacitance must match the specification in the crystal data sheet. Circuit diagram of the 32.768 kHz crystal oscillator on page 64 shows the LFXO circuitry. XL1 XL2 C1 C2 32.768 kHz crystal Figure 20: Circuit diagram of the 32.768 kHz crystal oscillator The load capacitance (CL) is the total capacitance seen by the crystal across its terminals and is given by: C1 and C2 are ceramic SMD capacitors connected between each crystal terminal and ground. Cpcb1 and Cpcb2 are stray capacitances on the PCB. Cpin is the pin input capacitance on the XC1 and XC2 pins (see 32.768 kHz crystal oscillator (LFXO) on page 72). The load capacitors C1 and C2 should have the same value. For more information, see Reference circuitry on page 345. 5.4.2.5 32.768 kHz synthesized from HFCLK (LFSYNT) LFCLK can also be synthesized from the HFCLK clock source. The accuracy of LFCLK will then be the accuracy of the HFCLK. Using the LFSYNT clock avoids the requirement for a 32.768 kHz crystal, but increases average power consumption as the HFCLK will need to be requested in the system. 4454_187 v1.2 64 Power and clock management 5.4.3 Registers Base address Peripheral Instance Description 0x40000000 CLOCK CLOCK Clock control Configuration Table 19: Instances Register Offset Description TASKS_HFCLKSTART 0x000 Start HFCLK crystal oscillator TASKS_HFCLKSTOP 0x004 Stop HFCLK crystal oscillator TASKS_LFCLKSTART 0x008 Start LFCLK source TASKS_LFCLKSTOP 0x00C Stop LFCLK source TASKS_CAL 0x010 Start calibration of LFRC oscillator TASKS_CTSTART 0x014 Start calibration timer TASKS_CTSTOP 0x018 Stop calibration timer EVENTS_HFCLKSTARTED 0x100 HFCLK oscillator started EVENTS_LFCLKSTARTED 0x104 LFCLK started EVENTS_DONE 0x10C Calibration of LFCLK RC oscillator complete event EVENTS_CTTO 0x110 Calibration timer timeout INTENSET 0x304 Enable interrupt INTENCLR 0x308 Disable interrupt HFCLKRUN 0x408 Status indicating that HFCLKSTART task has been triggered HFCLKSTAT 0x40C HFCLK status LFCLKRUN 0x414 Status indicating that LFCLKSTART task has been triggered LFCLKSTAT 0x418 LFCLK status LFCLKSRCCOPY 0x41C Copy of LFCLKSRC register, set when LFCLKSTART task was triggered LFCLKSRC 0x518 Clock source for the LFCLK CTIV 0x538 Calibration timer interval Retained Table 20: Register overview 5.4.3.1 TASKS_HFCLKSTART Address offset: 0x000 Start HFCLK crystal oscillator Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_HFCLKSTART Start HFCLK crystal oscillator Trigger task 5.4.3.2 TASKS_HFCLKSTOP Address offset: 0x004 Stop HFCLK crystal oscillator 4454_187 v1.2 65 Power and clock management Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_HFCLKSTOP Stop HFCLK crystal oscillator Trigger task 5.4.3.3 TASKS_LFCLKSTART Address offset: 0x008 Start LFCLK source Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_LFCLKSTART Start LFCLK source Trigger task 5.4.3.4 TASKS_LFCLKSTOP Address offset: 0x00C Stop LFCLK source Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_LFCLKSTOP Stop LFCLK source Trigger task 5.4.3.5 TASKS_CAL Address offset: 0x010 Start calibration of LFRC oscillator Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description TASKS_CAL Start calibration of LFRC oscillator Trigger 1 Trigger task 5.4.3.6 TASKS_CTSTART Address offset: 0x014 Start calibration timer 4454_187 v1.2 66 Power and clock management Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_CTSTART Start calibration timer Trigger task 5.4.3.7 TASKS_CTSTOP Address offset: 0x018 Stop calibration timer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_CTSTOP Stop calibration timer Trigger task 5.4.3.8 EVENTS_HFCLKSTARTED Address offset: 0x100 HFCLK oscillator started Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_HFCLKSTARTED 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description NotGenerated 0 Event not generated Generated 1 Event generated HFCLK oscillator started 5.4.3.9 EVENTS_LFCLKSTARTED Address offset: 0x104 LFCLK started Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_LFCLKSTARTED 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description NotGenerated 0 Event not generated Generated 1 Event generated LFCLK started 5.4.3.10 EVENTS_DONE Address offset: 0x10C Calibration of LFCLK RC oscillator complete event 4454_187 v1.2 67 Power and clock management Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_DONE 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description NotGenerated 0 Event not generated Generated 1 Event generated Calibration of LFCLK RC oscillator complete event 5.4.3.11 EVENTS_CTTO Address offset: 0x110 Calibration timer timeout Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_CTTO 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description NotGenerated 0 Event not generated Generated 1 Event generated Calibration timer timeout 5.4.3.12 INTENSET Address offset: 0x304 Enable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID D C Reset 0x00000000 ID Access Field A RW HFCLKSTARTED B C D Value ID Value Description Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Write '1' to enable interrupt for event HFCLKSTARTED RW LFCLKSTARTED Write '1' to enable interrupt for event LFCLKSTARTED RW DONE Write '1' to enable interrupt for event DONE RW CTTO Write '1' to enable interrupt for event CTTO 5.4.3.13 INTENCLR Address offset: 0x308 Disable interrupt 4454_187 v1.2 B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 68 Power and clock management Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID D C Reset 0x00000000 ID Access Field A RW HFCLKSTARTED B C D B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Write '1' to disable interrupt for event HFCLKSTARTED RW LFCLKSTARTED Write '1' to disable interrupt for event LFCLKSTARTED RW DONE Write '1' to disable interrupt for event DONE RW CTTO Write '1' to disable interrupt for event CTTO 5.4.3.14 HFCLKRUN Address offset: 0x408 Status indicating that HFCLKSTART task has been triggered Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description STATUS HFCLKSTART task triggered or not NotTriggered 0 Task not triggered Triggered 1 Task triggered 5.4.3.15 HFCLKSTAT Address offset: 0x40C HFCLK status Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID B Reset 0x00000000 ID Access Field A R B R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description SRC Source of HFCLK RC 0 64 MHz internal oscillator (HFINT) Xtal 1 64 MHz crystal oscillator (HFXO) NotRunning 0 HFCLK not running Running 1 HFCLK running STATE HFCLK state 5.4.3.16 LFCLKRUN Address offset: 0x414 4454_187 v1.2 A 69 Power and clock management Status indicating that LFCLKSTART task has been triggered Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description STATUS LFCLKSTART task triggered or not NotTriggered 0 Task not triggered Triggered 1 Task triggered 5.4.3.17 LFCLKSTAT Address offset: 0x418 LFCLK status Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID B Reset 0x00000000 ID Access Field A R B R A A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description SRC Source of LFCLK RC 0 32.768 kHz RC oscillator Xtal 1 32.768 kHz crystal oscillator Synth 2 32.768 kHz synthesized from HFCLK STATE LFCLK state NotRunning 0 LFCLK not running Running 1 LFCLK running 5.4.3.18 LFCLKSRCCOPY Address offset: 0x41C Copy of LFCLKSRC register, set when LFCLKSTART task was triggered Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A Reset 0x00000000 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description SRC Clock source RC 0 32.768 kHz RC oscillator Xtal 1 32.768 kHz crystal oscillator Synth 2 32.768 kHz synthesized from HFCLK 5.4.3.19 LFCLKSRC Address offset: 0x518 Clock source for the LFCLK 4454_187 v1.2 70 Power and clock management Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID C B Reset 0x00000000 ID Access Field A RW SRC B A A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description RC 0 32.768 kHz RC oscillator Xtal 1 32.768 kHz crystal oscillator Synth 2 32.768 kHz synthesized from HFCLK Clock source RW BYPASS Enable or disable bypass of LFCLK crystal oscillator with external clock source C Disabled 0 Disable (use with Xtal or low-swing external source) Enabled 1 Enable (use with rail-to-rail external source) Disabled 0 Disable external source (use with Xtal) Enabled 1 Enable use of external source instead of Xtal (SRC needs to RW EXTERNAL Enable or disable external source for LFCLK be set to Xtal) 5.4.3.20 CTIV ( Retained ) Address offset: 0x538 This register is a retained register Calibration timer interval Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A Reset 0x00000000 ID Access Field A RW CTIV 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Calibration timer interval in multiple of 0.25 seconds. Range: 0.25 seconds to 31.75 seconds. 5.4.4 Electrical specification 5.4.4.1 64 MHz internal oscillator (HFINT) Symbol Description fNOM_HFINT Nominal output frequency Min. Typ. 64 fTOL_HFINT Frequency tolerance EVENTS_READY CCM->TASKS_KSGEN 25 RADIO->EVENTS_ADDRESS CCM->TASKS_CRYPT 26 RADIO->EVENTS_ADDRESS TIMER0->TASKS_CAPTURE[1] 27 RADIO->EVENTS_END TIMER0->TASKS_CAPTURE[2] 28 RTC0->EVENTS_COMPARE[0] RADIO->TASKS_TXEN 29 RTC0->EVENTS_COMPARE[0] RADIO->TASKS_RXEN 30 RTC0->EVENTS_COMPARE[0] TIMER0->TASKS_CLEAR 31 RTC0->EVENTS_COMPARE[0] TIMER0->TASKS_START Table 43: Pre-programmed channels 6.9.2 Registers Base address Peripheral Instance Description 0x4001F000 PPI PPI Programmable peripheral interconnect Configuration Table 44: Instances Register Offset Description TASKS_CHG[0].EN 0x000 Enable channel group 0 TASKS_CHG[0].DIS 0x004 Disable channel group 0 TASKS_CHG[1].EN 0x008 Enable channel group 1 TASKS_CHG[1].DIS 0x00C Disable channel group 1 4454_187 v1.2 118 Peripherals Register Offset Description TASKS_CHG[2].EN 0x010 Enable channel group 2 TASKS_CHG[2].DIS 0x014 Disable channel group 2 TASKS_CHG[3].EN 0x018 Enable channel group 3 TASKS_CHG[3].DIS 0x01C Disable channel group 3 TASKS_CHG[4].EN 0x020 Enable channel group 4 TASKS_CHG[4].DIS 0x024 Disable channel group 4 TASKS_CHG[5].EN 0x028 Enable channel group 5 TASKS_CHG[5].DIS 0x02C Disable channel group 5 CHEN 0x500 Channel enable register CHENSET 0x504 Channel enable set register CHENCLR 0x508 Channel enable clear register CH[0].EEP 0x510 Channel 0 event endpoint CH[0].TEP 0x514 Channel 0 task endpoint CH[1].EEP 0x518 Channel 1 event endpoint CH[1].TEP 0x51C Channel 1 task endpoint CH[2].EEP 0x520 Channel 2 event endpoint CH[2].TEP 0x524 Channel 2 task endpoint CH[3].EEP 0x528 Channel 3 event endpoint CH[3].TEP 0x52C Channel 3 task endpoint CH[4].EEP 0x530 Channel 4 event endpoint CH[4].TEP 0x534 Channel 4 task endpoint CH[5].EEP 0x538 Channel 5 event endpoint CH[5].TEP 0x53C Channel 5 task endpoint CH[6].EEP 0x540 Channel 6 event endpoint CH[6].TEP 0x544 Channel 6 task endpoint CH[7].EEP 0x548 Channel 7 event endpoint CH[7].TEP 0x54C Channel 7 task endpoint CH[8].EEP 0x550 Channel 8 event endpoint CH[8].TEP 0x554 Channel 8 task endpoint CH[9].EEP 0x558 Channel 9 event endpoint CH[9].TEP 0x55C Channel 9 task endpoint CHG[0] 0x800 Channel group 0 CHG[1] 0x804 Channel group 1 CHG[2] 0x808 Channel group 2 CHG[3] 0x80C Channel group 3 CHG[4] 0x810 Channel group 4 CHG[5] 0x814 Channel group 5 FORK[0].TEP 0x910 Channel 0 task endpoint FORK[1].TEP 0x914 Channel 1 task endpoint FORK[2].TEP 0x918 Channel 2 task endpoint FORK[3].TEP 0x91C Channel 3 task endpoint FORK[4].TEP 0x920 Channel 4 task endpoint FORK[5].TEP 0x924 Channel 5 task endpoint FORK[6].TEP 0x928 Channel 6 task endpoint FORK[7].TEP 0x92C Channel 7 task endpoint FORK[8].TEP 0x930 Channel 8 task endpoint FORK[9].TEP 0x934 Channel 9 task endpoint FORK[20].TEP 0x960 Channel 20 task endpoint FORK[21].TEP 0x964 Channel 21 task endpoint FORK[22].TEP 0x968 Channel 22 task endpoint FORK[23].TEP 0x96C Channel 23 task endpoint FORK[24].TEP 0x970 Channel 24 task endpoint FORK[25].TEP 0x974 Channel 25 task endpoint 4454_187 v1.2 119 Peripherals Register Offset Description FORK[26].TEP 0x978 Channel 26 task endpoint FORK[27].TEP 0x97C Channel 27 task endpoint FORK[28].TEP 0x980 Channel 28 task endpoint FORK[29].TEP 0x984 Channel 29 task endpoint FORK[30].TEP 0x988 Channel 30 task endpoint FORK[31].TEP 0x98C Channel 31 task endpoint Table 45: Register overview 6.9.2.1 TASKS_CHG[n].EN (n=0..5) Address offset: 0x000 + (n × 0x8) Enable channel group n Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description EN Enable channel group n Trigger task 6.9.2.2 TASKS_CHG[n].DIS (n=0..5) Address offset: 0x004 + (n × 0x8) Disable channel group n Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description DIS Disable channel group n Trigger task 6.9.2.3 CHEN Address offset: 0x500 Channel enable register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID V U T S R Q P O N M L K Reset 0x00000000 ID Access Field A-J RW CH[i] (i=0..9) K-V 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Enable or disable channel i Disabled 0 Disable channel Enabled 1 Enable channel Disabled 0 Disable channel Enabled 1 Enable channel RW CH[i] (i=20..31) Enable or disable channel i 6.9.2.4 CHENSET Address offset: 0x504 4454_187 v1.2 J I H G F E D C B A 120 Peripherals Channel enable set register Read: reads value of CH{i} field in CHEN register. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID V U T S R Q P O N M L K Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field A-J RW CH[i] (i=0..9) K-V Value ID Value Disabled 0 Read: channel disabled Enabled 1 Read: channel enabled Set 1 Write: Enable channel Disabled 0 Read: channel disabled Enabled 1 Read: channel enabled Set 1 Write: Enable channel J I H G F E D C B A Description Channel i enable set register. Writing '0' has no effect. RW CH[i] (i=20..31) Channel i enable set register. Writing '0' has no effect. 6.9.2.5 CHENCLR Address offset: 0x508 Channel enable clear register Read: reads value of CH{i} field in CHEN register. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID V U T S R Q P O N M L K Reset 0x00000000 ID Access Field A-J RW CH[i] (i=0..9) K-V J I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Channel i enable clear register. Writing '0' has no effect. Disabled 0 Read: channel disabled Enabled 1 Read: channel enabled Clear 1 Write: disable channel RW CH[i] (i=20..31) Channel i enable clear register. Writing '0' has no effect. Disabled 0 Read: channel disabled Enabled 1 Read: channel enabled Clear 1 Write: disable channel 6.9.2.6 CH[n].EEP (n=0..9) Address offset: 0x510 + (n × 0x8) Channel n event endpoint Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 ID Access Field A RW EEP 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Pointer to event register. Accepts only addresses to registers from the Event group. 6.9.2.7 CH[n].TEP (n=0..9) Address offset: 0x514 + (n × 0x8) Channel n task endpoint 4454_187 v1.2 121 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field A RW TEP Value ID Value Description Pointer to task register. Accepts only addresses to registers from the Task group. 6.9.2.8 CHG[n] (n=0..5) Address offset: 0x800 + (n × 0x4) Channel group n Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID V U T S R Q P O N M L K Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field A-J RW CH[i] (i=0..9) K-V Value ID Value Excluded 0 Exclude Included 1 Include Excluded 0 Exclude Included 1 Include J I H G F E D C B A Description Include or exclude channel i RW CH[i] (i=20..31) Include or exclude channel i 6.9.2.9 FORK[n].TEP (n=0..9, 20..31) Address offset: 0x910 + (n × 0x4) Channel n task endpoint Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 ID Access Field A RW TEP 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Pointer to task register 6.10 QDEC — Quadrature decoder The Quadrature decoder (QDEC) provides buffered decoding of quadrature-encoded sensor signals. It is suitable for mechanical and optical sensors. The sample period and accumulation are configurable to match application requirements. The QDEC provides the following: • • • • Digital waveform decoding from off-chip quadrature encoder Sample accumulation eliminating hard real-time requirements to be enforced on application Optional input de-bounce filters. Optional LED output signal for optical encoders 4454_187 v1.2 122 Peripherals ACCREAD ACCDBLREAD ACC ACCDBL + + SAMPLE Quadrature decoder IO router On-chip Off-chip Phase A Phase B LED Mechanical to electrical Mechanical device Quadrature Encoder Figure 36: Quadrature decoder configuration 6.10.1 Sampling and decoding The QDEC decodes the output from an incremental motion encoder by sampling the QDEC phase input pins (A and B). The off-chip quadrature encoder is an incremental motion encoder outputting two waveforms, phase A and phase B. The two output waveforms are always 90 degrees out of phase, meaning that one always changes level before the other. The direction of movement is indicated by the waveform that changes level first. Invalid transitions may occur, meaning the two waveforms simultaneously switch. This may occur if the wheel rotates too fast relative to the sample rate set for the decoder. The QDEC decodes the output from the off-chip encoder by sampling the QDEC phase input pins (A and B) at a fixed rate as specified in the SAMPLEPER register. If the SAMPLEPER value needs to be changed, the QDEC shall be stopped using the STOP task. SAMPLEPER can be then changed upon receiving the STOPPED event, and QDEC can be restarted using the START task. Failing to do so may result in unpredictable behavior. It is good practice to only change registers LEDPOL, REPORTPER, DBFEN, and LEDPRE when the QDEC is stopped. When started, the decoder continuously samples the two input waveforms and decodes these by comparing the current sample pair (n) with the previous sample pair (n-1). The decoding of the sample pairs is described in the table below. 4454_187 v1.2 123 Peripherals Previous Current SAMPLE sample pair(n samples register - 1) ACC operation ACCDBL Description operation pair(n) A B A B 0 0 0 0 0 No change No change No movement 0 0 0 1 1 Increment No change Movement in positive direction 0 0 1 0 -1 Decrement No change Movement in negative direction 0 0 1 1 2 No change Increment Error: Double transition 0 1 0 0 -1 Decrement No change Movement in negative direction 0 1 0 1 0 No change No change No movement 0 1 1 0 2 No change Increment Error: Double transition 0 1 1 1 1 Increment No change Movement in positive direction 1 0 0 0 1 Increment No change Movement in positive direction 1 0 0 1 2 No change Increment Error: Double transition 1 0 1 0 0 No change No change No movement 1 0 1 1 -1 Decrement No change Movement in negative direction 1 1 0 0 2 No change Increment Error: Double transition 1 1 0 1 -1 Decrement No change Movement in negative direction 1 1 1 0 1 Increment No change Movement in positive direction 1 1 1 1 0 No change No change No movement Table 46: Sampled value encoding 6.10.2 LED output The LED output follows the sample period. The LED is switched on for a set period before sampling and then switched off immediately after. The period the LED is switched on before sampling is given in the LEDPRE register. The LED output pin polarity is specified in the LEDPOL register. When using off-chip mechanical encoders not requiring an LED, the LED output can be disabled by writing value 'Disconnected' to the CONNECT field of the PSEL.LED register. In this case, the QDEC will not acquire access to a pin for the LED output. 6.10.3 Debounce filters Each of the two-phase inputs have digital debounce filters. When enabled through the DBFEN register, the filter inputs are sampled at a fixed 1 MHz frequency during the entire sample period (which is specified in the SAMPLEPER register). The filters require all of the samples within this sample period to equal before the input signal is accepted and transferred to the output of the filter. As a result, only input signal with a steady state longer than twice the period specified in SAMPLEPER are guaranteed to pass through the filter. Any signal with a steady state shorter than SAMPLEPER will always be suppressed by the filter. It is assumed that the frequency during the debounce period never exceeds 500 kHz (as required by the Nyquist theorem when using a 1 MHz sample frequency). The LED will always be ON when the debounce filters are enabled, as the inputs in this case will be sampled continuously. When the debounce filters are enabled, displacements reported by the QDEC peripheral are delayed by one SAMPLEPER period. 6.10.4 Accumulators The quadrature decoder contains two accumulator registers, ACC and ACCDBL. These registers accumulate valid motion sample values and the number of detected invalid samples (double transitions), respectively. 4454_187 v1.2 124 Peripherals The ACC register accumulates all valid values (1/-1) written to the SAMPLE register. This can be useful for preventing hard real-time requirements from being enforced on the application. When using the ACC register, the application can fetch data when necessary instead of reading all SAMPLE register output. The ACC register holds the relative movement of the external mechanical device from the previous clearing of the ACC register. Sample values indicating a double transition (2) will not be accumulated in the ACC register. An ACCOF event is generated if the ACC receives a SAMPLE value that would cause the register to overflow or underflow. Any SAMPLE value that would cause an ACC overflow or underflow will be discarded, but any samples that do not cause the ACC to overflow or underflow will still be accepted. The accumulator ACCDBL accumulates the number of detected double transitions since the previous clearing of the ACCDBL register. The ACC and ACCDBL registers can be cleared by the READCLRACC and subsequently read using the ACCREAD and ACCDBLREAD registers. The ACC register can be separately cleared by the RDCLRACC and subsequently read using the ACCREAD registers. The ACCDBL register can be separately cleared by the RDCLRDBL and subsequently read using the ACCDBLREAD registers. The REPORTPER register allows automated capture of multiple samples before sending an event. When a non-null displacement is captured and accumulated, a REPORTRDY event is sent. When one or more double-displacements are captured and accumulated, a DBLRDY event is sent. The REPORTPER field in this register determines how many samples must be accumulated before the contents are evaluated and a REPORTRDY or DBLRDY event is sent. Using the RDCLRACC task (manually sent upon receiving the event, or using the DBLRDY_RDCLRACC shortcut), ACCREAD can then be read. When a double transition has been captured and accumulated, a DBLRDY event is sent. Using the RDCLRDBL task (manually sent upon receiving the event, or using the DBLRDY_RDCLRDBL shortcut), ACCDBLREAD can then be read. 6.10.5 Output/input pins The QDEC uses a three-pin interface to the off-chip quadrature encoder. These pins are acquired when the QDEC is enabled in the ENABLE register. The pins acquired by the QDEC cannot be written by the CPU, but they can still be read by the CPU. The pin numbers used for the QDEC are selected using the PSEL.n registers. 6.10.6 Pin configuration The Phase A, Phase B, and LED signals are mapped to physical pins according to the configuration specified in the PSEL.A, PSEL.B, and PSEL.LED registers respectively. If the CONNECT field value 'Disconnected' is specified in any of these registers, the associated signal will not be connected to any physical pin. The PSEL.A, PSEL.B, and PSEL.LED registers and their configurations are only used as long as the QDEC is enabled, and retained only as long as the device is in ON mode. When the peripheral is disabled, the pins will behave as regular GPIOs, and use the configuration in their respective OUT bit field and PIN_CNF[n] register. To secure correct behavior in the QDEC, the pins used by the QDEC must be configured in the GPIO peripheral as described in GPIO configuration before enabling peripheral on page 126 before enabling the QDEC. This configuration must be retained in the GPIO for the selected I/Os as long as the QDEC is enabled. 4454_187 v1.2 125 Peripherals Only one peripheral can be assigned to drive a particular GPIO pin at a time. Failing to do so may result in unpredictable behavior. QDEC signal QDEC pin Direction Output value Phase A As specified in PSEL.A Input Not applicable Phase B As specified in PSEL.B Input Not applicable LED As specified in PSEL.LED Input Not applicable Comment Table 47: GPIO configuration before enabling peripheral 6.10.7 Registers Base address Peripheral Instance Description 0x40012000 QDEC QDEC Quadrature decoder Configuration Table 48: Instances Register Offset Description TASKS_START 0x000 Task starting the quadrature decoder TASKS_STOP 0x004 Task stopping the quadrature decoder TASKS_READCLRACC 0x008 Read and clear ACC and ACCDBL TASKS_RDCLRACC 0x00C Read and clear ACC TASKS_RDCLRDBL 0x010 Read and clear ACCDBL EVENTS_SAMPLERDY 0x100 Event being generated for every new sample value written to the SAMPLE register EVENTS_REPORTRDY 0x104 Non-null report ready EVENTS_ACCOF 0x108 ACC or ACCDBL register overflow EVENTS_DBLRDY 0x10C Double displacement(s) detected EVENTS_STOPPED 0x110 QDEC has been stopped SHORTS 0x200 Shortcuts between local events and tasks INTENSET 0x304 Enable interrupt INTENCLR 0x308 Disable interrupt ENABLE 0x500 Enable the quadrature decoder LEDPOL 0x504 LED output pin polarity SAMPLEPER 0x508 Sample period SAMPLE 0x50C Motion sample value REPORTPER 0x510 Number of samples to be taken before REPORTRDY and DBLRDY events can be generated ACC 0x514 Register accumulating the valid transitions ACCREAD 0x518 Snapshot of the ACC register, updated by the READCLRACC or RDCLRACC task PSEL.LED 0x51C Pin select for LED signal PSEL.A 0x520 Pin select for A signal PSEL.B 0x524 Pin select for B signal DBFEN 0x528 Enable input debounce filters LEDPRE 0x540 Time period the LED is switched ON prior to sampling ACCDBL 0x544 Register accumulating the number of detected double transitions ACCDBLREAD 0x548 Snapshot of the ACCDBL, updated by the READCLRACC or RDCLRDBL task Table 49: Register overview 6.10.7.1 TASKS_START Address offset: 0x000 Task starting the quadrature decoder 4454_187 v1.2 126 Peripherals When started, the SAMPLE register will be continuously updated at the rate given in the SAMPLEPER register. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description TASKS_START Task starting the quadrature decoder When started, the SAMPLE register will be continuously updated at the rate given in the SAMPLEPER register. Trigger 1 Trigger task 6.10.7.2 TASKS_STOP Address offset: 0x004 Task stopping the quadrature decoder Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_STOP Task stopping the quadrature decoder Trigger task 6.10.7.3 TASKS_READCLRACC Address offset: 0x008 Read and clear ACC and ACCDBL Task transferring the content of ACC to ACCREAD and the content of ACCDBL to ACCDBLREAD, and then clearing the ACC and ACCDBL registers. These read-and-clear operations will be done atomically. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description TASKS_READCLRACC Read and clear ACC and ACCDBL Task transferring the content of ACC to ACCREAD and the content of ACCDBL to ACCDBLREAD, and then clearing the ACC and ACCDBL registers. These read-and-clear operations will be done atomically. Trigger 1 Trigger task 6.10.7.4 TASKS_RDCLRACC Address offset: 0x00C Read and clear ACC Task transferring the content of ACC to ACCREAD, and then clearing the ACC register. This read-and-clear operation will be done atomically. 4454_187 v1.2 127 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description TASKS_RDCLRACC Read and clear ACC Task transferring the content of ACC to ACCREAD, and then clearing the ACC register. This read-and-clear operation will be done atomically. Trigger 1 Trigger task 6.10.7.5 TASKS_RDCLRDBL Address offset: 0x010 Read and clear ACCDBL Task transferring the content of ACCDBL to ACCDBLREAD, and then clearing the ACCDBL register. This readand-clear operation will be done atomically. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description TASKS_RDCLRDBL Read and clear ACCDBL Task transferring the content of ACCDBL to ACCDBLREAD, and then clearing the ACCDBL register. This read-and-clear operation will be done atomically. Trigger 1 Trigger task 6.10.7.6 EVENTS_SAMPLERDY Address offset: 0x100 Event being generated for every new sample value written to the SAMPLE register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_SAMPLERDY 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Event being generated for every new sample value written to the SAMPLE register NotGenerated 0 Event not generated Generated 1 Event generated 6.10.7.7 EVENTS_REPORTRDY Address offset: 0x104 Non-null report ready Event generated when REPORTPER number of samples has been accumulated in the ACC register and the content of the ACC register is not equal to 0. (Thus, this event is only generated if a motion is detected since the previous clearing of the ACC register). 4454_187 v1.2 128 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_REPORTRDY 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Non-null report ready Event generated when REPORTPER number of samples has been accumulated in the ACC register and the content of the ACC register is not equal to 0. (Thus, this event is only generated if a motion is detected since the previous clearing of the ACC register). NotGenerated 0 Event not generated Generated 1 Event generated 6.10.7.8 EVENTS_ACCOF Address offset: 0x108 ACC or ACCDBL register overflow Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_ACCOF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description ACC or ACCDBL register overflow NotGenerated 0 Event not generated Generated 1 Event generated 6.10.7.9 EVENTS_DBLRDY Address offset: 0x10C Double displacement(s) detected Event generated when REPORTPER number of samples has been accumulated and the content of the ACCDBL register is not equal to 0. (Thus, this event is only generated if a double transition is detected since the previous clearing of the ACCDBL register). Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_DBLRDY 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Double displacement(s) detected Event generated when REPORTPER number of samples has been accumulated and the content of the ACCDBL register is not equal to 0. (Thus, this event is only generated if a double transition is detected since the previous clearing of the ACCDBL register). NotGenerated 0 Event not generated Generated 1 Event generated 6.10.7.10 EVENTS_STOPPED Address offset: 0x110 QDEC has been stopped 4454_187 v1.2 129 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_STOPPED 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description NotGenerated 0 Event not generated Generated 1 Event generated QDEC has been stopped 6.10.7.11 SHORTS Address offset: 0x200 Shortcuts between local events and tasks Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID G F E D C B A Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field A RW REPORTRDY_READCLRACC B C D E F G Value ID Value Description Shortcut between event REPORTRDY and task READCLRACC Disabled 0 Disable shortcut Enabled 1 Enable shortcut Disabled 0 Disable shortcut Enabled 1 Enable shortcut Disabled 0 Disable shortcut Enabled 1 Enable shortcut RW SAMPLERDY_STOP Shortcut between event SAMPLERDY and task STOP RW REPORTRDY_RDCLRACC Shortcut between event REPORTRDY and task RDCLRACC RW REPORTRDY_STOP Shortcut between event REPORTRDY and task STOP Disabled 0 Disable shortcut Enabled 1 Enable shortcut Disabled 0 Disable shortcut Enabled 1 Enable shortcut Disabled 0 Disable shortcut Enabled 1 Enable shortcut RW DBLRDY_RDCLRDBL Shortcut between event DBLRDY and task RDCLRDBL RW DBLRDY_STOP Shortcut between event DBLRDY and task STOP RW SAMPLERDY_READCLRACC Shortcut between event SAMPLERDY and task READCLRACC Disabled 0 Disable shortcut Enabled 1 Enable shortcut 6.10.7.12 INTENSET Address offset: 0x304 Enable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID E D C B A Reset 0x00000000 ID Access Field A RW SAMPLERDY 4454_187 v1.2 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Write '1' to enable interrupt for event SAMPLERDY 130 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID E D C B A Reset 0x00000000 ID Access Field B RW REPORTRDY 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Write '1' to enable interrupt for event REPORTRDY Event generated when REPORTPER number of samples has been accumulated in the ACC register and the content of the ACC register is not equal to 0. (Thus, this event is only generated if a motion is detected since the previous clearing of the ACC register). C D Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ACCOF Write '1' to enable interrupt for event ACCOF Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW DBLRDY Write '1' to enable interrupt for event DBLRDY Event generated when REPORTPER number of samples has been accumulated and the content of the ACCDBL register is not equal to 0. (Thus, this event is only generated if a double transition is detected since the previous clearing of the ACCDBL register). E Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW STOPPED Write '1' to enable interrupt for event STOPPED 6.10.7.13 INTENCLR Address offset: 0x308 Disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID E D C B A Reset 0x00000000 ID Access Field A RW SAMPLERDY B 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Write '1' to disable interrupt for event SAMPLERDY RW REPORTRDY Write '1' to disable interrupt for event REPORTRDY Event generated when REPORTPER number of samples has been accumulated in the ACC register and the content of the ACC register is not equal to 0. (Thus, this event is only generated if a motion is detected since the previous clearing of the ACC register). 4454_187 v1.2 Clear 1 Disable Disabled 0 Read: Disabled 131 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID E D C B A Reset 0x00000000 ID C D Access Field 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Enabled 1 Read: Enabled RW ACCOF Write '1' to disable interrupt for event ACCOF Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW DBLRDY Write '1' to disable interrupt for event DBLRDY Event generated when REPORTPER number of samples has been accumulated and the content of the ACCDBL register is not equal to 0. (Thus, this event is only generated if a double transition is detected since the previous clearing of the ACCDBL register). E Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW STOPPED Write '1' to disable interrupt for event STOPPED 6.10.7.14 ENABLE Address offset: 0x500 Enable the quadrature decoder Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW ENABLE 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Enable or disable the quadrature decoder When enabled the decoder pins will be active. When disabled the quadrature decoder pins are not active and can be used as GPIO . Disabled 0 Disable Enabled 1 Enable 6.10.7.15 LEDPOL Address offset: 0x504 LED output pin polarity Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW LEDPOL 4454_187 v1.2 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description ActiveLow 0 Led active on output pin low ActiveHigh 1 Led active on output pin high LED output pin polarity 132 Peripherals 6.10.7.16 SAMPLEPER Address offset: 0x508 Sample period Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A Reset 0x00000000 ID Access Field A RW SAMPLEPER 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Sample period. The SAMPLE register will be updated for every new sample 128us 0 128 µs 256us 1 256 µs 512us 2 512 µs 1024us 3 1024 µs 2048us 4 2048 µs 4096us 5 4096 µs 8192us 6 8192 µs 16384us 7 16384 µs 32ms 8 32768 µs 65ms 9 65536 µs 131ms 10 131072 µs 6.10.7.17 SAMPLE Address offset: 0x50C Motion sample value Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID SAMPLE Value Description [-1..2] Last motion sample The value is a 2's complement value, and the sign gives the direction of the motion. The value '2' indicates a double transition. 6.10.7.18 REPORTPER Address offset: 0x510 Number of samples to be taken before REPORTRDY and DBLRDY events can be generated 4454_187 v1.2 133 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A Reset 0x00000000 ID Access Field A RW REPORTPER 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Specifies the number of samples to be accumulated in the ACC register before the REPORTRDY and DBLRDY events can be generated. The report period in [µs] is given as: RPUS = SP * RP Where RPUS is the report period in [µs/report], SP is the sample period in [µs/sample] specified in SAMPLEPER, and RP is the report period in [samples/report] specified in REPORTPER . 10Smpl 0 10 samples/report 40Smpl 1 40 samples/report 80Smpl 2 80 samples/report 120Smpl 3 120 samples/report 160Smpl 4 160 samples/report 200Smpl 5 200 samples/report 240Smpl 6 240 samples/report 280Smpl 7 280 samples/report 1Smpl 8 1 sample/report 6.10.7.19 ACC Address offset: 0x514 Register accumulating the valid transitions Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID ACC Value Description [-1024..1023] Register accumulating all valid samples (not double transition) read from the SAMPLE register. Double transitions ( SAMPLE = 2 ) will not be accumulated in this register. The value is a 32 bit 2's complement value. If a sample that would cause this register to overflow or underflow is received, the sample will be ignored and an overflow event ( ACCOF ) will be generated. The ACC register is cleared by triggering the READCLRACC or the RDCLRACC task. 6.10.7.20 ACCREAD Address offset: 0x518 Snapshot of the ACC register, updated by the READCLRACC or RDCLRACC task Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field A R ACCREAD Value ID Value Description [-1024..1023] Snapshot of the ACC register. The ACCREAD register is updated when the READCLRACC or RDCLRACC task is triggered. 4454_187 v1.2 134 Peripherals 6.10.7.21 PSEL.LED Address offset: 0x51C Pin select for LED signal Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID C Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 ID Access Field A RW PIN C RW CONNECT Value ID A A A A A Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 6.10.7.22 PSEL.A Address offset: 0x520 Pin select for A signal Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID C Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 ID Access Field A RW PIN C RW CONNECT Value ID A A A A A Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 6.10.7.23 PSEL.B Address offset: 0x524 Pin select for B signal Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID C Reset 0xFFFFFFFF ID Access Field A RW PIN C RW CONNECT A A A A A 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 6.10.7.24 DBFEN Address offset: 0x528 Enable input debounce filters 4454_187 v1.2 135 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW DBFEN 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Disabled 0 Debounce input filters disabled Enabled 1 Debounce input filters enabled Enable input debounce filters 6.10.7.25 LEDPRE Address offset: 0x540 Time period the LED is switched ON prior to sampling Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A Reset 0x00000010 ID Access Field A RW LEDPRE 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 Value ID Value Description [1..511] Period in µs the LED is switched on prior to sampling 6.10.7.26 ACCDBL Address offset: 0x544 Register accumulating the number of detected double transitions Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A Reset 0x00000000 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID ACCDBL Value Description [0..15] Register accumulating the number of detected double or illegal transitions. ( SAMPLE = 2 ). When this register has reached its maximum value, the accumulation of double/illegal transitions will stop. An overflow event (ACCOF) will be generated if any double or illegal transitions are detected after the maximum value was reached. This field is cleared by triggering the READCLRACC or RDCLRDBL task. 6.10.7.27 ACCDBLREAD Address offset: 0x548 Snapshot of the ACCDBL, updated by the READCLRACC or RDCLRDBL task Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A Reset 0x00000000 ID Access Field A R ACCDBLREAD 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description [0..15] Snapshot of the ACCDBL register. This field is updated when the READCLRACC or RDCLRDBL task is triggered. 4454_187 v1.2 136 Peripherals 6.10.8 Electrical specification 6.10.8.1 QDEC Electrical Specification Symbol Description Min. Max. Units tSAMPLE Time between sampling signals from quadrature decoder 128 Typ. 131072 µs tLED Time from LED is turned on to signals are sampled 0 511 µs 6.11 RADIO — 2.4 GHz radio The 2.4 GHz radio transceiver is compatible with multiple radio standards such as 1 Mbps and 2 Mbps Bluetooth® Low Energy modes, as well as Nordic's proprietary 1 Mbps and 2 Mbps modes. Listed here are main features for the RADIO: • Multidomain 2.4 GHz radio transceiver • 1 Mbps and 2 Mbps Bluetooth® Low Energy modes • 1 Mbps and 2 Mbps Nordic proprietary modes • Best in class link budget and low power operation • Efficient data interface with EasyDMA support • Automatic address filtering and pattern matching EasyDMA, in combination with an automated packet assembler, packet disassembler, automated CRC generator and CRC checker, makes it easy to configure and use the RADIO. See the following figure for details. RAM RADIO PACKETPTR Device address match Packet synch S0 CRC Packet disassembler L RSSI Address match Dewhitening 2.4 GHz receiver S1 Payload EasyDMA IFS control unit Bit counter S0 ANT1 L Packet assembler S1 Payload CRC Whitening 2.4 GHz transmitter MAXLEN Figure 37: RADIO block diagram The RADIO includes a device address match unit and an interframe spacing control unit that can be utilized to simplify address whitelisting and interframe spacing respectively in Bluetooth® low energy and similar applications. The RADIO also includes a received signal strength indicator (RSSI) and a bit counter. The bit counter generates events when a preconfigured number of bits are sent or received by the RADIO. 6.11.1 Packet configuration A RADIO packet contains the fields PREAMBLE, ADDRESS, S0, LENGTH, S1, PAYLOAD, and CRC. 4454_187 v1.2 137 Peripherals The content of a RADIO packet is illustrated in the figure below. The RADIO sends the fields in the packet according to the order illustrated in the figure, starting on the left. BASE PREFIX S0 LENGTH S1 LSByte PAYLOAD LSByte MSBit PREAMBLE LSBit LSBit LSBit 0x55 1 0 1 0 1 0 1 0 1 0xAA 0 1 0 1 0 1 0 1 0 CRC MSByte ADDRESS Figure 38: On-air packet layout Not shown in the figure is the static payload add-on (the length of which is defined in PCNF1.STATLEN, and which is 0 bytes in a standard BLE packet). The static payload add-on is sent between PAYLOAD and CRC fields. The RADIO sends the different fields in the packet in the order they are illustrated above, from left to right. PREAMBLE is sent with least significant bit first on air. The size of the PREAMBLE depends on the mode selected in the MODE register: • The PREAMBLE is one byte for MODE = Ble_1Mbit as well as all Nordic proprietary operating modes (MODE = Nrf_1Mbit and MODE = Nrf_2Mbit), and PCNF0.PLEN has to be set accordingly. If the first bit of the ADDRESS is 0, the preamble will be set to 0xAA. Otherwise the PREAMBLE will be set to 0x55. • For MODE = Ble_2Mbit, the PREAMBLE must be set to 2 bytes through PCNF0.PLEN. If the first bit of the ADDRESS is 0, the preamble will be set to 0xAAAA. Otherwise the PREAMBLE will be set to 0x5555. Radio packets are stored in memory inside instances of a RADIO packet data structure as illustrated below. The PREAMBLE, ADDRESS and CRC fields are omitted in this data structure. Fields S0, LENGTH, and S1 are optional. S0 LENGTH 0 S1 PAYLOAD LSByte n Figure 39: Representation of a RADIO packet in RAM The byte ordering on air is always least significant byte first for the ADDRESS and PAYLOAD fields, and most significant byte first for the CRC field. The ADDRESS fields are always transmitted and received least significant bit first. The CRC field is always transmitted and received most significant bit first. The endianness, i.e. the order in which the bits are sent and received, of the S0, LENGTH, S1, and PAYLOAD fields can be configured via PCNF1.ENDIAN. The sizes of the S0, LENGTH, and S1 fields can be individually configured via S0LEN, LFLEN, and S1LEN in PCNF0 respectively. If any of these fields are configured to be less than 8 bits, the least significant bits of the fields are used. If S0, LENGTH, or S1 are specified with zero length, their fields will be omitted in memory. Otherwise each field will be represented as a separate byte, regardless of the number of bits in their on-air counterpart. Independent of the configuration of PCNF1.MAXLEN, the combined length of S0, LENGTH, S1, and PAYLOAD cannot exceed 258 bytes. 6.11.2 Address configuration The on-air radio ADDRESS field is composed of two parts, the base address field and the address prefix field. The size of the base address field is configurable via PCNF1.BALEN. The base address is truncated from the least significant byte if the PCNF1.BALEN is less than 4. See Definition of logical addresses on page 139. 4454_187 v1.2 138 Peripherals The on-air addresses are defined in the BASE0/BASE1 and PREFIX0/PREFIX1 registers. It is only when writing these registers that the user must relate to the actual on-air addresses. For other radio address registers, such as the TXADDRESS, RXADDRESSES, and RXMATCH registers, logical radio addresses ranging from 0 to 7 are being used. The relationship between the on-air radio addresses and the logical addresses is described in the following table. Logical address Base address Prefix byte 0 BASE0 PREFIX0.AP0 1 BASE1 PREFIX0.AP1 2 BASE1 PREFIX0.AP2 3 BASE1 PREFIX0.AP3 4 BASE1 PREFIX1.AP4 5 BASE1 PREFIX1.AP5 6 BASE1 PREFIX1.AP6 7 BASE1 PREFIX1.AP7 Table 50: Definition of logical addresses 6.11.3 Data whitening The RADIO is able to do packet whitening and de-whitening, enabled in PCNF1.WHITEEN. When enabled, whitening and de-whitening will be handled by the RADIO automatically as packets are sent and received. The whitening word is generated using polynomial g(D) = D7+ D4 + 1, which then is XORed with the data packet that is to be whitened, or de-whitened. The linear feedback shift register is initialized via DATAWHITEIV. See the following figure. D0 D4 D7 + Position 0 1 2 3 Data out + 4 5 6 Data in Figure 40: Data whitening and de-whitening Whitening and de-whitening will be performed over the whole packet except for the preamble and the address fields. 6.11.4 CRC The CRC generator in RADIO calculates the CRC over the whole packet excluding the preamble. If desirable, the address field can be excluded from the CRC calculation as well. See CRCCNF register for more information. The CRC polynomial is configurable as illustrated in the following figure, where bit 0 in the CRCPOLY register corresponds to X0 and bit 1 corresponds to X1 etc. See CRCPOLY on page 164 for more information. 4454_187 v1.2 139 Peripherals Xn-1 Xn X2 X1 X0 Packet (Clocked in serially) + + + bn + + b0 Figure 41: CRC generation of an n bit CRC The figure shows that the CRC is calculated by feeding the packet serially through the CRC generator. Before the packet is clocked through the CRC generator, the CRC generator's latches b0 through bn will be initialized with a predefined value specified in the CRCINIT register. After the whole packet has been clocked through the CRC generator, b0 through bn will hold the resulting CRC. This value will be used by the RADIO during both transmission and reception. Latches b0 through bn are not available to be read by the CPU at any time. However, a received CRC can be read by the CPU via the RXCRC register. The length (n) of the CRC is configurable, see CRCCNF for more information. Once the entire packet, including the CRC, has been received and no errors were detected, RADIO generates a CRCOK event. If CRC errors were detected, a CRCERROR event is generated. The status of the CRC check can be read from the CRCSTATUS register after a packet has been received. 6.11.5 Radio states Tasks and events are used to control the operating state of RADIO. RADIO can enter the states described in the following table. State Description DISABLED No operations are going on inside the RADIO and the power consumption is at a minimum RXRU RADIO is ramping up and preparing for reception RXIDLE RADIO is ready for reception to start RX Reception has been started and the addresses enabled in the RXADDRESSES register are being monitored TXRU RADIO is ramping up and preparing for transmission TXIDLE RADIO is ready for transmission to start TX RADIO is transmitting a packet RXDISABLE RADIO is disabling the receiver TXDISABLE RADIO is disabling the transmitter Table 51: RADIO state diagram A state diagram showing an overview of RADIO is shown in the following figure. 4454_187 v1.2 140 Peripherals DISABLE Address sent / ADDRESS START TXDISABLE TXRU Ramp-up complete / READY / DISABLED TXEN TXEN TXIDLE TX Payload sent [payload length >=0] / PAYLOAD STOP Packet sent / END Last bit sent / PHYEND DISABLED Last bit received / PHYEND RXEN / DISABLED Ramp-up complete / READY RXRU RXDISABLE Packet received / END Address received [Address match] / ADDRESS START RXIDLE RX Payload received [payload length >=0] / PAYLOAD STOP DISABLE Figure 42: Radio states This figure shows how the tasks and events relate to the RADIO's operation. The RADIO does not prevent a task from being triggered from the wrong state. If a task is triggered from the wrong state, for example if the RXEN task is triggered from the RXDISABLE state, this may lead to incorrect behavior. The PAYLOAD event is always generated even if the payload is zero. 6.11.6 Transmit sequence Before the RADIO is able to transmit a packet, it must first ramp-up in TX mode. See TXRU in Radio states on page 141 and Transmit sequence on page 141. A TXRU ramp-up sequence is initiated when the TXEN task is triggered. After the RADIO has successfully ramped up it will generate the READY event indicating that a packet transmission can be initiated. A packet transmission is initiated by triggering the START task. The START task can first be triggered after the RADIO has entered into the TXIDLE state. PAYLOAD ADDRESS S0 L S1 2 (carrier) DISABLE Figure 43: Transmit sequence 4454_187 v1.2 CRC TXDISABLE 3 START TXEN Lifeline 1 A TXIDLE DISABLED P READY (carrier) TX PHYEND TXIDLE END Transmitter TXRU PAYLOAD State The following figure illustrates a single packet transmission where the CPU manually triggers the different tasks needed to control the flow of the RADIO, i.e. no shortcuts are used. If shortcuts are not used, a certain amount of delay caused by CPU execution is expected between READY and START, and between END and DISABLE. As illustrated in Transmit sequence on page 141 the RADIO will by default transmit 1s between READY and START, and between END and DISABLED. What is transmitted can be programmed through the DTX field in the MODECNF0 register. 141 Peripherals TX CRC (carrier) DISABLED PAYLOAD PAYLOAD Lifeline S0 L S1 PHYEND A READY P TXDISABLE ADDRESS Transmitter TXRU END State The following figure shows a slightly modified version of the transmit sequence where RADIO is configured to use shortcuts between READY and START, and between END and DISABLE, which means that no delay is introduced. 1 TXEN START DISABLE 2 Figure 44: Transmit sequence using shortcuts to avoid delays A S0 L S1 PAYLOAD CRC (carrier) DISABLE 3 START START 2 DISABLED P END (carrier) PHYEND CRC ADDRESS PAYLOAD END S0 L S1 TXDISABLE TX PHYEND A 1 TXEN Lifeline READY P TXIDLE PAYLOAD TX ADDRESS Transmitter TXRU PAYLOAD State RADIO is able to send multiple packets one after the other without having to disable and re-enable the RADIO between packets, as illustrated in the following figure. Figure 45: Transmission of multiple packets 6.11.7 Receive sequence Before RADIO is able to receive a packet, it must first ramp up in RX mode. See RXRU in Radio states on page 141 and Receive sequence on page 143 for more information. An RXRU ramp up sequence is initiated when the RXEN task is triggered. After RADIO has successfully ramped up it will generate the READY event indicating that a packet reception can be initiated. A packet reception is initiated by triggering the START task. As illustrated in Radio states on page 141, the START task can first be triggered after RADIO has entered into the RXIDLE state. The following figure shows a single packet reception where the CPU manually triggers the different tasks needed to control the flow of RADIO, i.e. no shortcuts are used. If shortcuts are not used, a certain amount of delay caused by CPU execution is expected between READY and START, and between END and DISABLE. RADIO will be listening and possibly receiving undefined data, represented with an 'X', from START and until a packet with valid preamble (P) is received. 4454_187 v1.2 142 RX S0 L S1 ADDRESS CRC 2 3 RXEN START 1 DISABLE Lifeline PAYLOAD RXDISABLE DISABLED A PHYEND P READY ’X’ RXIDLE END RXIDLE Reception RXRU PAYLOAD State Peripherals Figure 46: Receive sequence RX Lifeline PAYLOAD CRC ADDRESS S0 L S1 DISABLED A END P READY ’X’ RXDISABLE PAYLOAD Reception RXRU PHYEND State The following figure shows a modified version of the receive sequence, where RADIO is configured to use shortcuts between READY and START, and between END and DISABLE, which means that no delay is introduced. 1 DISABLE RXEN START 2 Figure 47: Receive sequence using shortcuts to avoid delays S0 L S1 CRC 143 3 DISABLE START START 2 Figure 48: Reception of multiple packets 4454_187 v1.2 PAYLOAD DISABLED A END ’X’ P PHYEND CRC ADDRESS PAYLOAD RXDISABLE RX END S0 L S1 PHYEND A 1 RXEN Lifeline READY ’X’ P RXIDLE PAYLOAD RX ADDRESS Receiver RXRU PAYLOAD State RADIO is able to receive consecutive packets without having to disable and re-enable RADIO between packets, as illustrated in the following figure. Peripherals 6.11.8 Received signal strength indicator (RSSI) RADIO implements a mechanism for measuring the power in the received signal. This feature is called received signal strength indicator (RSSI). The RSSI is measured continuously and the value filtered using a single-pole IIR filter. After a signal level change, the RSSI will settle after approximately RSSISETTLE. Sampling of the received signal strength is started by using the RSSISTART task. The sample can be read from the RSSISAMPLE register. The sample period of the RSSI is defined by RSSIPERIOD. The RSSISAMPLE will hold the filtered received signal strength after this sample period. For the RSSI sample to be valid, the RADIO has to be enabled in receive mode (RXEN task) and the reception has to be started (READY event followed by START task). 6.11.9 Interframe spacing (IFS) Interframe spacing (IFS) is defined as the time, in microseconds, between two consecutive packets, starting from when the end of the last bit of the previous packet is received, to the beginning of the first bit of the subsequent packet that is transmitted. The RADIO is able to enforce this interval, as specified in the TIFS register, as long as the TIFS is not specified to be shorter than the RADIO's turnaround time, i.e. the time needed to switch off the receiver, and then switch the transmitter back on. The TIFS register can be written any time before the last bit on air is received. This timing is illustrated in the figure below. Change to MODE OK TXRU TX P READY DISABLED CRC END A S0 L S1 PAYLOAD START DISABLE TIFS TXEN PAYLOAD RXDISABLE ADDRESS RX PAYLOAD Lifeline On air State Change to SHORTS and TIFS OK Figure 49: IFS timing detail The TIFS duration starts after the last bit on air (just before the END event), and elapses with first bit being transmitted on air (just after READY event). TIFS is only enforced if the shortcuts END to DISABLE and DISABLED to TXEN or END to DISABLE and DISABLED to RXEN are enabled. TIFS is qualified for use in 1 Mbps and 2 Mbps Bluetooth® Low Energy modes, using the default ramp-up mode. SHORTS and TIFS registers are not double-buffered, and can be updated at any point before the last bit on air is received. The MODE register is double-buffered and sampled at the TXEN or RXEN task. 4454_187 v1.2 144 Peripherals 6.11.10 Device address match The device address match feature is tailored for address whitelisting in Bluetooth® low energy and similar implementations. This feature enables on-the-fly device address matching while receiving a packet on air. This feature only works in receive mode and when the RADIO is configured for little endian, see PCNF1.ENDIAN. The device address match unit assumes that the first 48 bits of the payload are the device address and that bit number 6 in S0 is the TxAdd bit. See the Bluetooth® Core Specification for more information about device addresses, TxAdd, and whitelisting. The RADIO is able to listen for eight different device addresses at the same time. These addresses are specified in a DAB/DAP register pair, one pair per address, in addition to a TxAdd bit configured in the DACNF register. The DAB register specifies the 32 least significant bits of the device address, while the DAP register specifies the 16 most significant bits of the device address. Each of the device addresses can be individually included or excluded from the matching mechanism. This is configured in the DACNF register. 6.11.11 Bit counter The RADIO implements a simple counter that can be configured to generate an event after a specific number of bits have been transmitted or received. By using shortcuts, this counter can be started from different events generated by the RADIO and count relative to these. The bit counter is started by triggering the BCSTART task, and stopped by triggering the BCSTOP task. A BCMATCH event will be generated when the bit counter has counted the number of bits specified in the BCC register. The bit counter will continue to count bits until the DISABLED event is generated or until the BCSTOP task is triggered. After a BCMATCH event, the CPU can reconfigure the BCC value for new BCMATCH events within the same packet. The bit counter can only be started after the RADIO has received the ADDRESS event. The bit counter will stop and reset on either the BCSTOP, STOP, or DISABLE task, or the END event. RX BCSTART START 145 DISABLED END 3 Figure 50: Bit counter example 4454_187 v1.2 CRC PAYLOAD PAYLOAD 2 BCC = 12 RXEN 1 2 BCMATCH READY S0 L S1 BCC = 12 + 16 Lifeline Assuming that the combined length of S0, length (L) and S1 is 12 bits. A 1 BCMATCH ’X’ P ADDRESS Reception 0 RXDISABLE DISABLE RXRU BCSTOP State The following figure shows how the bit counter can be used to generate a BCMATCH event in the beginning of the packet payload, and again generate a second BCMATCH event after sending 2 bytes (16 bits) of the payload. Peripherals 6.11.12 EasyDMA The RADIO uses EasyDMA to read and write packets to RAM without CPU involvement. As illustrated in RADIO block diagram on page 137, the RADIO's EasyDMA utilizes the same PACKETPTR for receiving and transmitting packets. This pointer should be reconfigured by the CPU each time before RADIO is started by the START task. The PACKETPTR register is double-buffered, meaning that it can be updated and prepared for the next transmission. The END event indicates that the last bit has been processed by the RADIO. The DISABLED event is issued to acknowledge that a DISABLE task is done. The structure of a packet is described in detail in Packet configuration on page 137. The data that is stored in Data RAM and transported by EasyDMA consists of the following fields: • • • • S0 LENGTH S1 PAYLOAD In addition, a static add-on is sent immediately after the payload. The size of each of the above fields in the frame is configurable (see Packet configuration on page 137), and the space occupied in RAM depends on these settings. The size of the field can be zero, as long as the resulting frame complies with the chosen RF protocol. All fields are extended in size to align with a byte boundary in RAM. For instance, a 3-bit long field on air will occupy 1 byte in RAM while a 9-bit long field will be extended to 2 bytes. The packet's elements can be configured as follows: • • • • • S0 is configured through the PCNF0.S0LEN field LENGTH is configured through the PCNF0.LFLEN field S1 is configured through the PCNF0.S1LEN field Payload size is configured through the value in RAM corresponding to the LENGTH field Static add-on size is configured through the PCNF1.STATLEN field The PCNF1.MAXLEN field configures the maximum packet payload plus add-on size in number of bytes that can be transmitted or received by the RADIO. This feature can be used to ensure that the RADIO does not overwrite, or read beyond, the RAM assigned to the packet payload. This means that if the LENGTH field of the packet payload exceedes PCNF1.STATLEN, and the LENGTH field in the packet specifies a packet larger than configured in PCNF1.MAXLEN, the payload will be truncated to the length specified in PCNF1.MAXLEN. Note: The PCNF1.MAXLEN field includes the payload and the add-on, but excludes the size occupied by the S0, LENGTH, and S1 fields. This has to be taken into account when allocating RAM. If the payload and add-on length is specified larger than PCNF1.MAXLEN, the RADIO will still transmit or receive in the same way as before, except the payload is now truncated to PCNF1.MAXLEN. The packet's LENGTH field will not be altered when the payload is truncated. The RADIO will calculate CRC as if the packet length is equal to PCNF1.MAXLEN. Note: If PACKETPTR is not pointing to the Data RAM region, an EasyDMA transfer may result in a HardFault or RAM corruption. See Memory on page 15 for more information about the different memory regions. The END event indicates that the last bit has been processed by the RADIO. The DISABLED event is issued to acknowledge that an DISABLE task is done. 4454_187 v1.2 146 Peripherals 6.11.13 Registers Base address Peripheral Instance Description 0x40001000 RADIO RADIO 2.4 GHz radio Configuration Table 52: Instances Register Offset Description TASKS_TXEN 0x000 Enable RADIO in TX mode TASKS_RXEN 0x004 Enable RADIO in RX mode TASKS_START 0x008 Start RADIO TASKS_STOP 0x00C Stop RADIO TASKS_DISABLE 0x010 Disable RADIO TASKS_RSSISTART 0x014 Start the RSSI and take one single sample of the receive signal strength TASKS_RSSISTOP 0x018 Stop the RSSI measurement TASKS_BCSTART 0x01C Start the bit counter TASKS_BCSTOP 0x020 Stop the bit counter EVENTS_READY 0x100 RADIO has ramped up and is ready to be started EVENTS_ADDRESS 0x104 Address sent or received EVENTS_PAYLOAD 0x108 Packet payload sent or received EVENTS_END 0x10C Packet sent or received EVENTS_DISABLED 0x110 RADIO has been disabled EVENTS_DEVMATCH 0x114 A device address match occurred on the last received packet EVENTS_DEVMISS 0x118 No device address match occurred on the last received packet EVENTS_RSSIEND 0x11C Sampling of receive signal strength complete EVENTS_BCMATCH 0x128 Bit counter reached bit count value EVENTS_CRCOK 0x130 Packet received with CRC ok EVENTS_CRCERROR 0x134 Packet received with CRC error EVENTS_TXREADY 0x154 RADIO has ramped up and is ready to be started TX path EVENTS_RXREADY 0x158 RADIO has ramped up and is ready to be started RX path EVENTS_MHRMATCH 0x15C MAC header match found EVENTS_PHYEND 0x16C Generated when last bit is sent on air, or received from air SHORTS 0x200 Shortcuts between local events and tasks INTENSET 0x304 Enable interrupt INTENCLR 0x308 Disable interrupt CRCSTATUS 0x400 CRC status RXMATCH 0x408 Received address RXCRC 0x40C CRC field of previously received packet DAI 0x410 Device address match index PDUSTAT 0x414 Payload status PACKETPTR 0x504 Packet pointer FREQUENCY 0x508 Frequency TXPOWER 0x50C Output power MODE 0x510 Data rate and modulation PCNF0 0x514 Packet configuration register 0 PCNF1 0x518 Packet configuration register 1 BASE0 0x51C Base address 0 BASE1 0x520 Base address 1 PREFIX0 0x524 Prefixes bytes for logical addresses 0-3 PREFIX1 0x528 Prefixes bytes for logical addresses 4-7 TXADDRESS 0x52C Transmit address select RXADDRESSES 0x530 Receive address select CRCCNF 0x534 CRC configuration 4454_187 v1.2 147 Peripherals Register Offset Description CRCPOLY 0x538 CRC polynomial CRCINIT 0x53C CRC initial value TIFS 0x544 Interframe spacing in µs RSSISAMPLE 0x548 RSSI sample STATE 0x550 Current radio state DATAWHITEIV 0x554 Data whitening initial value BCC 0x560 Bit counter compare DAB[n] 0x600 Device address base segment n DAP[n] 0x620 Device address prefix n DACNF 0x640 Device address match configuration MODECNF0 0x650 Radio mode configuration register 0 POWER 0xFFC Peripheral power control Table 53: Register overview 6.11.13.1 TASKS_TXEN Address offset: 0x000 Enable RADIO in TX mode Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_TXEN Enable RADIO in TX mode Trigger task 6.11.13.2 TASKS_RXEN Address offset: 0x004 Enable RADIO in RX mode Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description TASKS_RXEN Enable RADIO in RX mode Trigger 1 Trigger task 6.11.13.3 TASKS_START Address offset: 0x008 Start RADIO Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_START 4454_187 v1.2 Start RADIO Trigger task 148 Peripherals 6.11.13.4 TASKS_STOP Address offset: 0x00C Stop RADIO Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_STOP Stop RADIO Trigger task 6.11.13.5 TASKS_DISABLE Address offset: 0x010 Disable RADIO Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_DISABLE Disable RADIO Trigger task 6.11.13.6 TASKS_RSSISTART Address offset: 0x014 Start the RSSI and take one single sample of the receive signal strength Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description TASKS_RSSISTART Start the RSSI and take one single sample of the receive signal strength Trigger 1 Trigger task 6.11.13.7 TASKS_RSSISTOP Address offset: 0x018 Stop the RSSI measurement Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description TASKS_RSSISTOP Stop the RSSI measurement Trigger 4454_187 v1.2 1 Trigger task 149 Peripherals 6.11.13.8 TASKS_BCSTART Address offset: 0x01C Start the bit counter Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_BCSTART Start the bit counter Trigger task 6.11.13.9 TASKS_BCSTOP Address offset: 0x020 Stop the bit counter Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_BCSTOP Stop the bit counter Trigger task 6.11.13.10 EVENTS_READY Address offset: 0x100 RADIO has ramped up and is ready to be started Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_READY 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description RADIO has ramped up and is ready to be started NotGenerated 0 Event not generated Generated 1 Event generated 6.11.13.11 EVENTS_ADDRESS Address offset: 0x104 Address sent or received Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_ADDRESS 4454_187 v1.2 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Address sent or received NotGenerated 0 Event not generated Generated 1 Event generated 150 Peripherals 6.11.13.12 EVENTS_PAYLOAD Address offset: 0x108 Packet payload sent or received Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_PAYLOAD 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description NotGenerated 0 Event not generated Generated 1 Event generated Packet payload sent or received 6.11.13.13 EVENTS_END Address offset: 0x10C Packet sent or received Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_END 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description NotGenerated 0 Event not generated Generated 1 Event generated Packet sent or received 6.11.13.14 EVENTS_DISABLED Address offset: 0x110 RADIO has been disabled Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_DISABLED 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description NotGenerated 0 Event not generated Generated 1 Event generated RADIO has been disabled 6.11.13.15 EVENTS_DEVMATCH Address offset: 0x114 A device address match occurred on the last received packet 4454_187 v1.2 151 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_DEVMATCH 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description A device address match occurred on the last received packet NotGenerated 0 Event not generated Generated 1 Event generated 6.11.13.16 EVENTS_DEVMISS Address offset: 0x118 No device address match occurred on the last received packet Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_DEVMISS 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description No device address match occurred on the last received packet NotGenerated 0 Event not generated Generated 1 Event generated 6.11.13.17 EVENTS_RSSIEND Address offset: 0x11C Sampling of receive signal strength complete A new RSSI sample is ready for readout from the RADIO.RSSISAMPLE register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_RSSIEND 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Sampling of receive signal strength complete A new RSSI sample is ready for readout from the RADIO.RSSISAMPLE register NotGenerated 0 Event not generated Generated 1 Event generated 6.11.13.18 EVENTS_BCMATCH Address offset: 0x128 Bit counter reached bit count value Bit counter value is specified in the RADIO.BCC register 4454_187 v1.2 152 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_BCMATCH 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Bit counter reached bit count value Bit counter value is specified in the RADIO.BCC register NotGenerated 0 Event not generated Generated 1 Event generated 6.11.13.19 EVENTS_CRCOK Address offset: 0x130 Packet received with CRC ok Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_CRCOK 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Packet received with CRC ok NotGenerated 0 Event not generated Generated 1 Event generated 6.11.13.20 EVENTS_CRCERROR Address offset: 0x134 Packet received with CRC error Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_CRCERROR 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Packet received with CRC error NotGenerated 0 Event not generated Generated 1 Event generated 6.11.13.21 EVENTS_TXREADY Address offset: 0x154 RADIO has ramped up and is ready to be started TX path Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_TXREADY 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description RADIO has ramped up and is ready to be started TX path NotGenerated 0 Event not generated Generated 1 Event generated 6.11.13.22 EVENTS_RXREADY Address offset: 0x158 4454_187 v1.2 153 Peripherals RADIO has ramped up and is ready to be started RX path Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_RXREADY 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description RADIO has ramped up and is ready to be started RX path NotGenerated 0 Event not generated Generated 1 Event generated 6.11.13.23 EVENTS_MHRMATCH Address offset: 0x15C MAC header match found Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_MHRMATCH 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description MAC header match found NotGenerated 0 Event not generated Generated 1 Event generated 6.11.13.24 EVENTS_PHYEND Address offset: 0x16C Generated when last bit is sent on air, or received from air Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_PHYEND 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Generated when last bit is sent on air, or received from air NotGenerated 0 Event not generated Generated 1 Event generated 6.11.13.25 SHORTS Address offset: 0x200 Shortcuts between local events and tasks Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID U T S R Reset 0x00000000 ID Access Field A RW READY_START B G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Shortcut between event READY and task START Disabled 0 Disable shortcut Enabled 1 Enable shortcut Disabled 0 Disable shortcut Enabled 1 Enable shortcut RW END_DISABLE 4454_187 v1.2 H Shortcut between event END and task DISABLE 154 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID U T S R Reset 0x00000000 ID Access Field C RW DISABLED_TXEN D E F G H R S T U H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Disabled 0 Disable shortcut Enabled 1 Enable shortcut Disabled 0 Disable shortcut Enabled 1 Enable shortcut Disabled 0 Disable shortcut Enabled 1 Enable shortcut Shortcut between event DISABLED and task TXEN RW DISABLED_RXEN Shortcut between event DISABLED and task RXEN RW ADDRESS_RSSISTART Shortcut between event ADDRESS and task RSSISTART RW END_START Shortcut between event END and task START Disabled 0 Disable shortcut Enabled 1 Enable shortcut Disabled 0 Disable shortcut Enabled 1 Enable shortcut Disabled 0 Disable shortcut Enabled 1 Enable shortcut Disabled 0 Disable shortcut Enabled 1 Enable shortcut RW ADDRESS_BCSTART Shortcut between event ADDRESS and task BCSTART RW DISABLED_RSSISTOP Shortcut between event DISABLED and task RSSISTOP RW TXREADY_START Shortcut between event TXREADY and task START RW RXREADY_START Shortcut between event RXREADY and task START Disabled 0 Disable shortcut Enabled 1 Enable shortcut Disabled 0 Disable shortcut Enabled 1 Enable shortcut Disabled 0 Disable shortcut Enabled 1 Enable shortcut RW PHYEND_DISABLE Shortcut between event PHYEND and task DISABLE RW PHYEND_START Shortcut between event PHYEND and task START 6.11.13.26 INTENSET Address offset: 0x304 Enable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID Z Reset 0x00000000 ID Access Field A RW READY B C V U T Value ID Value I Description Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Write '1' to enable interrupt for event READY RW ADDRESS Write '1' to enable interrupt for event ADDRESS RW PAYLOAD 4454_187 v1.2 L K H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Write '1' to enable interrupt for event PAYLOAD 155 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID Z Reset 0x00000000 ID D E F G H Access Field V U T L K I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW END Write '1' to enable interrupt for event END RW DISABLED Write '1' to enable interrupt for event DISABLED RW DEVMATCH Write '1' to enable interrupt for event DEVMATCH RW DEVMISS Write '1' to enable interrupt for event DEVMISS RW RSSIEND Write '1' to enable interrupt for event RSSIEND A new RSSI sample is ready for readout from the RADIO.RSSISAMPLE register I Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW BCMATCH Write '1' to enable interrupt for event BCMATCH Bit counter value is specified in the RADIO.BCC register K L T U V Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CRCOK Write '1' to enable interrupt for event CRCOK RW CRCERROR Write '1' to enable interrupt for event CRCERROR RW TXREADY Write '1' to enable interrupt for event TXREADY RW RXREADY Write '1' to enable interrupt for event RXREADY RW MHRMATCH 4454_187 v1.2 Write '1' to enable interrupt for event MHRMATCH 156 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID Z Reset 0x00000000 ID Access Field Z RW PHYEND V U T L K I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Write '1' to enable interrupt for event PHYEND 6.11.13.27 INTENCLR Address offset: 0x308 Disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID Z Reset 0x00000000 ID Access Field A RW READY B C D E F G H V U T L K I 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Write '1' to disable interrupt for event READY Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ADDRESS Write '1' to disable interrupt for event ADDRESS Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW PAYLOAD Write '1' to disable interrupt for event PAYLOAD Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW END Write '1' to disable interrupt for event END Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW DISABLED Write '1' to disable interrupt for event DISABLED Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW DEVMATCH Write '1' to disable interrupt for event DEVMATCH Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW DEVMISS Write '1' to disable interrupt for event DEVMISS Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW RSSIEND Write '1' to disable interrupt for event RSSIEND A new RSSI sample is ready for readout from the RADIO.RSSISAMPLE register 4454_187 v1.2 H G F E D C B A Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 157 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID Z Reset 0x00000000 ID Access Field I RW BCMATCH V U T L K I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Write '1' to disable interrupt for event BCMATCH Bit counter value is specified in the RADIO.BCC register K L T U V Z Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CRCOK Write '1' to disable interrupt for event CRCOK Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CRCERROR Write '1' to disable interrupt for event CRCERROR Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TXREADY Write '1' to disable interrupt for event TXREADY Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW RXREADY Write '1' to disable interrupt for event RXREADY Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW MHRMATCH Write '1' to disable interrupt for event MHRMATCH Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW PHYEND Write '1' to disable interrupt for event PHYEND Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 6.11.13.28 CRCSTATUS Address offset: 0x400 CRC status Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description CRCError 0 Packet received with CRC error CRCOk 1 Packet received with CRC ok CRCSTATUS CRC status of packet received 6.11.13.29 RXMATCH Address offset: 0x408 Received address 4454_187 v1.2 158 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A Reset 0x00000000 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description RXMATCH Received address Logical address of which previous packet was received 6.11.13.30 RXCRC Address offset: 0x40C CRC field of previously received packet Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description RXCRC CRC field of previously received packet CRC field of previously received packet 6.11.13.31 DAI Address offset: 0x410 Device address match index Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A Reset 0x00000000 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description DAI Device address match index Index (n) of device address, see DAB[n] and DAP[n], that got an address match 6.11.13.32 PDUSTAT Address offset: 0x414 Payload status Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description LessThan 0 Payload less than PCNF1.MAXLEN GreaterThan 1 Payload greater than PCNF1.MAXLEN PDUSTAT Status on payload length vs. PCNF1.MAXLEN 6.11.13.33 PACKETPTR Address offset: 0x504 Packet pointer 4454_187 v1.2 159 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field A RW PACKETPTR Value ID Value Description Packet pointer Packet address to be used for the next transmission or reception. When transmitting, the packet pointed to by this address will be transmitted and when receiving, the received packet will be written to this address. This address is a byte aligned RAM address. See the memory chapter for details about which memories are avilable for EasyDMA. 6.11.13.34 FREQUENCY Address offset: 0x508 Frequency Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID B Reset 0x00000002 ID Access Field A RW FREQUENCY A A A A A A A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 Value ID Value Description [0..100] Radio channel frequency Frequency = 2400 + FREQUENCY (MHz) B RW MAP Channel map selection Default 0 Channel map between 2400 MHZ .. 2500 MHz Frequency = 2400 + FREQUENCY (MHz) Low 1 Channel map between 2360 MHZ .. 2460 MHz Frequency = 2360 + FREQUENCY (MHz) 6.11.13.35 TXPOWER Address offset: 0x50C Output power Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A Reset 0x00000000 ID Access Field A RW TXPOWER 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description RADIO output power Output power in number of dBm, i.e. if the value -20 is specified the output power will be set to -20 dBm. 4454_187 v1.2 Pos4dBm 0x4 +4 dBm Pos3dBm 0x3 +3 dBm 0dBm 0x0 0 dBm Neg4dBm 0xFC -4 dBm Neg8dBm 0xF8 -8 dBm Neg12dBm 0xF4 -12 dBm Neg16dBm 0xF0 -16 dBm Neg20dBm 0xEC -20 dBm Neg30dBm 0xE2 -40 dBm Neg40dBm 0xD8 -40 dBm 160 Deprecated Peripherals 6.11.13.36 MODE Address offset: 0x510 Data rate and modulation Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A Reset 0x00000000 ID Access Field A RW MODE 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Radio data rate and modulation setting. The radio supports frequency-shift keying (FSK) modulation. Nrf_1Mbit 0 1 Mbps Nordic proprietary radio mode Nrf_2Mbit 1 2 Mbps Nordic proprietary radio mode Ble_1Mbit 3 1 Mbps BLE Ble_2Mbit 4 2 Mbps BLE 6.11.13.37 PCNF0 Address offset: 0x514 Packet configuration register 0 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID I H H Reset 0x00000000 F E E E E C 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field A RW LFLEN Length on air of LENGTH field in number of bits C RW S0LEN Length on air of S0 field in number of bytes E RW S1LEN Length on air of S1 field in number of bits F RW S1INCL Include or exclude S1 field in RAM H I Value ID Value Description Automatic 0 Include S1 field in RAM only if S1LEN > 0 Include 1 Always include S1 field in RAM independent of S1LEN 8bit 0 8-bit preamble 16bit 1 16-bit preamble Exclude 0 LENGTH does not contain CRC Include 1 LENGTH includes CRC RW PLEN Length of preamble on air. Decision point: TASKS_START task RW CRCINC Indicates if LENGTH field contains CRC or not 6.11.13.38 PCNF1 Address offset: 0x518 Packet configuration register 1 4454_187 v1.2 A A A A 161 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID E D Reset 0x00000000 ID Access Field A RW MAXLEN C C C B B B B B B B B A A A A A A A A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description [0..255] Maximum length of packet payload. If the packet payload is larger than MAXLEN, the radio will truncate the payload to MAXLEN. B RW STATLEN [0..255] Static length in number of bytes The static length parameter is added to the total length of the payload when sending and receiving packets, e.g. if the static length is set to N the radio will receive or send N bytes more than what is defined in the LENGTH field of the packet. C RW BALEN [2..4] Base address length in number of bytes The address field is composed of the base address and the one byte long address prefix, e.g. set BALEN=2 to get a total address of 3 bytes. D RW ENDIAN On-air endianness of packet, this applies to the S0, LENGTH, S1, and the PAYLOAD fields. E Little 0 Least significant bit on air first Big 1 Most significant bit on air first Disabled 0 Disable Enabled 1 Enable RW WHITEEN Enable or disable packet whitening 6.11.13.39 BASE0 Address offset: 0x51C Base address 0 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 ID Access Field A RW BASE0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Base address 0 6.11.13.40 BASE1 Address offset: 0x520 Base address 1 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field A RW BASE1 Value ID Value Description Base address 1 6.11.13.41 PREFIX0 Address offset: 0x524 Prefixes bytes for logical addresses 0-3 4454_187 v1.2 162 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID D D D D D D D D C C C C C C C C B B B B B B B B A A A A A A A A Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field A-D RW AP[i] (i=0..3) Value ID Value Description Address prefix i. 6.11.13.42 PREFIX1 Address offset: 0x528 Prefixes bytes for logical addresses 4-7 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID D D D D D D D D C C C C C C C C B B B B B B B B A A A A A A A A Reset 0x00000000 ID Access Field A-D RW AP[i] (i=4..7) 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Address prefix i. 6.11.13.43 TXADDRESS Address offset: 0x52C Transmit address select Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A Reset 0x00000000 ID Access Field A RW TXADDRESS 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Transmit address select Logical address to be used when transmitting a packet 6.11.13.44 RXADDRESSES Address offset: 0x530 Receive address select Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID H G F E D C B A Reset 0x00000000 ID Access Field A-H RW ADDR[i] (i=0..7) 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Disabled 0 Disable Enabled 1 Enable Enable or disable reception on logical address i. 6.11.13.45 CRCCNF Address offset: 0x534 CRC configuration 4454_187 v1.2 163 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID B B Reset 0x00000000 ID Access Field A RW LEN B A A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description [1..3] CRC length in number of bytes Disabled 0 CRC length is zero and CRC calculation is disabled One 1 CRC length is one byte and CRC calculation is enabled Two 2 CRC length is two bytes and CRC calculation is enabled Three 3 CRC length is three bytes and CRC calculation is enabled RW SKIPADDR Include or exclude packet address field out of CRC calculation. Include 0 CRC calculation includes address field Skip 1 CRC calculation does not include address field. The CRC calculation will start at the first byte after the address. 6.11.13.46 CRCPOLY Address offset: 0x538 CRC polynomial Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 ID Access Field A RW CRCPOLY 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description CRC polynomial Each term in the CRC polynomial is mapped to a bit in this register which index corresponds to the term's exponent. The least significant term/bit is hardwired internally to 1, and bit number 0 of the register content is ignored by the hardware. The following example is for an 8 bit CRC polynomial: x8 + x7 + x3 + x2 + 1 = 1 1000 1101 . 6.11.13.47 CRCINIT Address offset: 0x53C CRC initial value Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 ID Access Field A RW CRCINIT 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description CRC initial value Initial value for CRC calculation 6.11.13.48 TIFS Address offset: 0x544 Interframe spacing in µs 4454_187 v1.2 164 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A Reset 0x00000000 ID Access Field A RW TIFS 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Interframe spacing in µs. Interframe space is the time interval between two consecutive packets. It is defined as the time, in microseconds, from the end of the last bit of the previous packet to the start of the first bit of the subsequent packet. 6.11.13.49 RSSISAMPLE Address offset: 0x548 RSSI sample Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A Reset 0x00000000 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID RSSISAMPLE Value Description [0..127] RSSI sample. RSSI sample result. The value of this register is read as a positive value while the actual received signal strength is a negative value. Actual received signal strength is therefore as follows: received signal strength = -A dBm. 6.11.13.50 STATE Address offset: 0x550 Current radio state Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A Reset 0x00000000 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Disabled 0 RADIO is in the Disabled state RxRu 1 RADIO is in the RXRU state RxIdle 2 RADIO is in the RXIDLE state Rx 3 RADIO is in the RX state RxDisable 4 RADIO is in the RXDISABLED state TxRu 9 RADIO is in the TXRU state TxIdle 10 RADIO is in the TXIDLE state Tx 11 RADIO is in the TX state TxDisable 12 RADIO is in the TXDISABLED state STATE Current radio state 6.11.13.51 DATAWHITEIV Address offset: 0x554 Data whitening initial value 4454_187 v1.2 165 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A Reset 0x00000040 ID Access Field A RW DATAWHITEIV 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 Value ID Value Description Data whitening initial value. Bit 6 is hardwired to '1', writing '0' to it has no effect, and it will always be read back and used by the device as '1'. Bit 0 corresponds to Position 6 of the LSFR, Bit 1 to Position 5, etc. 6.11.13.52 BCC Address offset: 0x560 Bit counter compare Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 ID Access Field A RW BCC 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Bit counter compare Bit counter compare register 6.11.13.53 DAB[n] (n=0..7) Address offset: 0x600 + (n × 0x4) Device address base segment n Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 ID Access Field A RW DAB 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Device address base segment n 6.11.13.54 DAP[n] (n=0..7) Address offset: 0x620 + (n × 0x4) Device address prefix n Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A Reset 0x00000000 ID Access Field A RW DAP 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Device address prefix n 6.11.13.55 DACNF Address offset: 0x640 Device address match configuration 4454_187 v1.2 166 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID P O N M L K J I H G F E D C B A Reset 0x00000000 ID Access Field A-H RW ENA[i] (i=0..7) 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Enable or disable device address matching using device address i I-P Disabled 0 Disabled Enabled 1 Enabled RW TXADD[i] (i=0..7) TxAdd for device address i 6.11.13.56 MODECNF0 Address offset: 0x650 Radio mode configuration register 0 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID C C Reset 0x00000200 ID Access Field A RW RU 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 Value ID Value Default 0 Fast 1 Description Radio ramp-up time Default ramp-up time (tRXEN and tTXEN), compatible with firmware written for nRF51 Fast ramp-up (tRXEN,FAST and tTXEN,FAST), see electrical specifications for more information When enabled, TIFS is not enforced by hardware and software needs to control when to turn on the Radio C RW DTX Default TX value Specifies what the RADIO will transmit when it is not started, i.e. between: RADIO.EVENTS_READY and RADIO.TASKS_START RADIO.EVENTS_END and RADIO.TASKS_START RADIO.EVENTS_END and RADIO.EVENTS_DISABLED B1 0 Transmit '1' B0 1 Transmit '0' Center 2 Transmit center frequency When tuning the crystal for center frequency, the RADIO must be set in DTX = Center mode to be able to achieve the expected accuracy 6.11.13.57 POWER Address offset: 0xFFC Peripheral power control 4454_187 v1.2 A 167 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000001 ID Access Field A RW POWER 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 Value ID Value Description Peripheral power control. The peripheral and its registers will be reset to its initial state by switching the peripheral off and then back on again. Disabled 0 Peripheral is powered off Enabled 1 Peripheral is powered on 6.11.14 Electrical specification 6.11.14.1 General radio characteristics Symbol Description Min. fOP Operating frequencies 2360 Typ. Max. Units 2500 MHz fPLL,CH,SP PLL channel spacing 1 MHz fDELTA,1M Frequency deviation @ 1 Mbps ±170 kHz fDELTA,BLE,1M Frequency deviation @ BLE 1 Mbps ±250 kHz fDELTA,2M Frequency deviation @ 2 Mbps ±320 kHz fDELTA,BLE,2M Frequency deviation @ BLE 2 Mbps fskBPS On-the-air data rate ±500 1000 kHz 2000 kbps Max. Units 6.11.14.2 Radio current consumption (transmitter) Symbol Description ITX,PLUS4dBM,DCDC TX only run current (DC/DC, 3 V) PRF = +4 dBm Min. 7.0 mA ITX,PLUS4dBM TX only run current PRF = +4 dBm 15.4 mA ITX,0dBM,DCDC TX only run current (DC/DC, 3 V)PRF = 0 dBm 4.6 mA ITX,0dBM TX only run current PRF = 0 dBm 10.1 mA ITX,MINUS4dBM,DCDC TX only run current DC/DC, 3 V PRF = -4 dBm 3.6 mA ITX,MINUS4dBM TX only run current PRF = -4 dBm 7.8 mA ITX,MINUS8dBM,DCDC TX only run current DC/DC, 3 V PRF = -8 dBm 3.2 mA ITX,MINUS8dBM TX only run current PRF = -8 dBm 6.8 mA ITX,MINUS12dBM,DCDC TX only run current DC/DC, 3 V PRF = -12 dBm 2.9 mA ITX,MINUS12dBM TX only run current PRF = -12 dBm Typ. 6.2 mA ITX,MINUS16dBM,DCDC TX only run current DC/DC, 3 V PRF = -16 dBm 2.7 mA ITX,MINUS16dBM 5.7 mA ITX,MINUS20dBM,DCDC TX only run current DC/DC, 3 V PRF = -20 dBm 2.5 mA ITX,MINUS20dBM TX only run current PRF = -16 dBm 5.4 mA ITX,MINUS40dBM,DCDC TX only run current DC/DC, 3 V PRF = -40 dBm 2.1 mA ITX,MINUS40dBM TX only run current PRF = -40 dBm 4.3 ISTART,TX,DCDC TX start-up current DC/DC, 3 V, PRF = 4 dBm .. .. .. mA ISTART,TX TX start-up current, PRF = 4 dBm .. .. .. mA 4454_187 v1.2 TX only run current PRF = -20 dBm 168 mA Peripherals 6.11.14.3 Radio current consumption (Receiver) Symbol Description IRX,1M,DCDC RX only run current (DC/DC, 3 V) 1 Mbps/1 Mbps BLE Min. Typ. 4.6 Max. Units mA IRX,1M RX only run current (LDO, 3 V) 1 Mbps/1 Mbps BLE 10.0 mA IRX,2M,DCDC RX only run current (DC/DC, 3 V) 2 Mbps/2 Mbps BLE 5.2 mA IRX,2M RX only run current (LDO, 3 V) 2 Mbps/2 Mbps BLE 11.2 mA ISTART,RX,1M,DCDC RX start-up current (DC/DC, 3 V) 1 Mbps/1 Mbps BLE 3.5 mA ISTART,RX,1M RX start-up current 1 Mbps/1 Mbps BLE 6.7 mA 6.11.14.4 Transmitter specification Symbol Description Min. Typ. Max. PRF Maximum output power 4.0 PRFC RF power control range 24 PRFCR RF power accuracy PRF1,1 1st Adjacent Channel Transmit Power 1 MHz (1 Mbps) -25 dBc PRF2,1 2nd Adjacent Channel Transmit Power 2 MHz (1 Mbps) -50 dBc PRF1,2 1st Adjacent Channel Transmit Power 2 MHz (2 Mbps) -25 dBc PRF2,2 2nd Adjacent Channel Transmit Power 4 MHz (2 Mbps) -50 dBc dBm dB ±4 6 5.5 Output power [dBm] 5 4.5 4 3.5 3 -40 -20 0 20 40 60 Temperature Range [°C] 1.7 V 3V 3.6 V Figure 51: Output power, 1 Mbps Bluetooth low energy mode, at maximum TXPOWER setting (typical values) 4454_187 v1.2 169 80 Units 100 dB Peripherals 2.5 2 Output power [dBm] 1.5 1 0.5 0 -0.5 -1 -40 -20 0 20 40 60 80 100 Temperature Range [°C] 1.7 V 3V 3.6 V Figure 52: Output power, 1 Mbps Bluetooth low energy mode, at 0 dBm TXPOWER setting (typical values) 6.11.14.5 Receiver operation Symbol Description PRX,MAX Maximum received signal strength at < 0.1% PER Min. Typ. Max. Units 0 dBm PSENS,IT,1M Sensitivity, 1 Mbps nRF mode ideal transmitter 14 -94 dBm PSENS,IT,2M Sensitivity, 2 Mbps nRF mode ideal transmitter 14 -91 dBm PSENS,IT,SP,1M,BLE Sensitivity, 1 Mbps BLE ideal transmitter, packet length ≤ 37 -97 dBm -96 dBm -94 dBm 15 bytes BER=1E-3 PSENS,IT,LP,1M,BLE Sensitivity, 1 Mbps BLE ideal transmitter, packet length ≥ 128 bytes BER=1E-4 PSENS,IT,SP,2M,BLE 16 Sensitivity, 2 Mbps BLE ideal transmitter, packet length ≤ 37 bytes 14 15 16 Typical sensitivity applies when ADDR0 is used for receiver address correlation. When ADDR[1...7] are used for receiver address correlation, the typical sensitivity for this mode is degraded by 3 dB. As defined in the Bluetooth Core Specification v4.0 Volume 6: Core System Package (Low Energy Controller Volume). Equivalent BER limit < 10E-04. 4454_187 v1.2 170 Peripherals -95.5 -96 Sensitivity [dBm] -96.5 -97 -97.5 -98 -98.5 -40 -20 0 20 40 60 80 100 Temperature Range [°C] 1.7 V 3V 3.6 V Figure 53: Sensitivity, 1 Mbps Bluetooth low energy mode, Regulator = LDO (typical values) 6.11.14.6 RX selectivity RX selectivity with equal modulation on interfering signal17 Symbol Description C/I1M,co-channel 1Mbps mode, co-channel interference 9 dB C/I1M,-1MHz 1 Mbps mode, Adjacent (-1 MHz) interference -2 dB C/I1M,+1MHz 1 Mbps mode, Adjacent (+1 MHz) interference -10 dB C/I1M,-2MHz 1 Mbps mode, Adjacent (-2 MHz) interference -19 dB C/I1M,+2MHz 1 Mbps mode, Adjacent (+2 MHz) interference -42 dB C/I1M,-3MHz 1 Mbps mode, Adjacent (-3 MHz) interference -38 dB C/I1M,+3MHz 1 Mbps mode, Adjacent (+3 MHz) interference -48 dB C/I1M,±6MHz 1 Mbps mode, Adjacent (≥6 MHz) interference -50 dB C/I1MBLE,co-channel 1 Mbps BLE mode, co-channel interference 6 dB C/I1MBLE,-1MHz 1 Mbps BLE mode, Adjacent (-1 MHz) interference -2 dB C/I1MBLE,+1MHz 1 Mbps BLE mode, Adjacent (+1 MHz) interference -9 dB C/I1MBLE,-2MHz 1 Mbps BLE mode, Adjacent (-2 MHz) interference -22 dB C/I1MBLE,+2MHz 1 Mbps BLE mode, Adjacent (+2 MHz) interference -46 dB C/I1MBLE,>3MHz 1 Mbps BLE mode, Adjacent (≥3 MHz) interference -50 dB C/I1MBLE,image Image frequency interference -22 dB C/I1MBLE,image,1MHz Adjacent (1 MHz) interference to in-band image frequency -35 dB C/I2M,co-channel 2 Mbps mode, co-channel interference 10 dB C/I2M,-2MHz 2 Mbps mode, Adjacent (-2 MHz) interference 6 dB C/I2M,+2MHz 2 Mbps mode, Adjacent (+2 MHz) interference -14 dB C/I2M,-4MHz 2 Mbps mode, Adjacent (-4 MHz) interference -20 dB C/I2M,+4MHz 2 Mbps mode, Adjacent (+4 MHz) interference -44 dB 17 Min. Typ. Max. Units Desired signal level at PIN = -67 dBm. One interferer is used, having equal modulation as the desired signal. The input power of the interferer where the sensitivity equals BER = 0.1% is presented. 4454_187 v1.2 171 Peripherals Symbol Description Min. C/I2M,-6MHz 2 Mbps mode, Adjacent (-6 MHz) interference -42 dB C/I2M,+6MHz 2 Mbps mode, Adjacent (+6 MHz) interference -47 dB C/I2M,≥12MHz 2 Mbps mode, Adjacent (≥12 MHz) interference -52 dB C/I2MBLE,co-channel 2 Mbps BLE mode, co-channel interference 6 dB C/I2MBLE,-2MHz 2 Mbps BLE mode, Adjacent (-2 MHz) interference -2 dB C/I2MBLE,+2MHz 2 Mbps BLE mode, Adjacent (+2 MHz) interference -12 dB C/I2MBLE,-4MHz 2 Mbps BLE mode, Adjacent (-4 MHz) interference -22 dB C/I2MBLE,+4MHz 2 Mbps BLE mode, Adjacent (+4 MHz) interference -46 dB C/I2MBLE,≥6MHz 2 Mbps BLE mode, Adjacent (≥6 MHz) interference -50 dB C/I2MBLE,image Image frequency interference -29 dB -44 dB C/I2MBLE,image, 2MHz Adjacent (2 MHz) interference to in-band image frequency Typ. Max. Units 6.11.14.7 RX intermodulation RX intermodulation. Desired signal level at PIN = -64 dBm. Two interferers with equal input power are used. The interferer closest in frequency is not modulated, the other interferer is modulated equal with the desired signal. The input power of the interferers where the sensitivity equals BER = 0.1% is presented. Symbol Description PIMD,5TH,1M IMD performance, 1 Mbps, 5th offset channel, packet length Min. Typ. Max. Units -33 dBm -30 dBm -33 dBm -31 dBm ≤ 37 bytes PIMD,5TH,1M,BLE IMD performance, BLE 1 Mbps, 5th offset channel, packet length ≤ 37 bytes PIMD,5TH,2M IMD performance, 2 Mbps, 5th offset channel, packet length ≤ 37 bytes PIMD,5TH,2M,BLE IMD performance, BLE 2 Mbps, 5th offset channel, packet length ≤ 37 bytes 6.11.14.8 Radio timing Symbol Description tTXEN,BLE,1M Time between TXEN task and READY event after channel Min. Typ. Max. Units 140 µs 40 µs 6 µs 140 µs 40 µs 0 µs 4 µs 0 µs FREQUENCY configured (1 Mbps BLE and 150 µs TIFS) tTXEN,FAST,BLE,1M Time between TXEN task and READY event after channel FREQUENCY configured (1 Mbps BLE with fast ramp-up and 150 µs TIFS) tTXDIS,BLE,1M When in TX, delay between DISABLE task and DISABLED event for MODE = Nrf_1Mbit and MODE = Ble_1Mbit tRXEN,BLE,1M Time between the RXEN task and READY event after channel FREQUENCY configured (1 Mbps BLE) tRXEN,FAST,BLE,1M Time between the RXEN task and READY event after channel FREQUENCY configured (1 Mbps BLE with fast ramp-up) tRXDIS,BLE,1M When in RX, delay between DISABLE task and DISABLED event for MODE = Nrf_1Mbit and MODE = Ble_1Mbit tTXDIS,BLE,2M When in TX, delay between DISABLE task and DISABLED event for MODE = Nrf_2Mbit and MODE = Ble_2Mbit tRXDIS,BLE,2M When in RX, delay between DISABLE task and DISABLED event for MODE = Nrf_2Mbit and MODE = Ble_2Mbit 4454_187 v1.2 172 Peripherals 6.11.14.9 Received signal strength indicator (RSSI) specifications Symbol Description RSSIACC RSSI accuracy 18 Min. Typ. ±2 Max. Units dB RSSIRESOLUTION RSSI resolution 1 dB RSSIPERIOD RSSI sampling time from RSSI_START task 0.25 µs RSSISETTLE RSSI settling time after signal level change 15 µs 6.11.14.10 Jitter Symbol Description Min. tDISABLEDJITTER Jitter on DISABLED event relative to END event when Typ. Max. Units 0.25 µs 0.25 µs shortcut between END and DISABLE is enabled tREADYJITTER Jitter on READY event relative to TXEN and RXEN task 6.12 RNG — Random number generator The Random number generator (RNG) generates true non-deterministic random numbers based on internal thermal noise that are suitable for cryptographic purposes. The RNG does not require a seed value. START STOP Random number generator VALRDY VALUE Figure 54: Random number generator The RNG is started by triggering the START task and stopped by triggering the STOP task. When started, new random numbers are generated continuously and written to the VALUE register when ready. A VALRDY event is generated for every new random number that is written to the VALUE register. This means that after a VALRDY event is generated the CPU has the time until the next VALRDY event to read out the random number from the VALUE register before it is overwritten by a new random number. 6.12.1 Bias correction A bias correction algorithm is employed on the internal bit stream to remove any bias toward '1' or '0'. The bits are then queued into an eight-bit register for parallel readout from the VALUE register. It is possible to enable bias correction in the CONFIG register. This will result in slower value generation, but will ensure a statistically uniform distribution of the random values. 6.12.2 Speed The time needed to generate one random byte of data is unpredictable, and may vary from one byte to the next. This is especially true when bias correction is enabled. 18 Valid range -90 to -20 dBm 4454_187 v1.2 173 Peripherals 6.12.3 Registers Base address Peripheral Instance Description Configuration 0x4000D000 RNG RNG Random number generator Table 54: Instances Register Offset Description TASKS_START 0x000 Task starting the random number generator TASKS_STOP 0x004 Task stopping the random number generator EVENTS_VALRDY 0x100 Event being generated for every new random number written to the VALUE register SHORTS 0x200 Shortcuts between local events and tasks INTENSET 0x304 Enable interrupt INTENCLR 0x308 Disable interrupt CONFIG 0x504 Configuration register VALUE 0x508 Output random number Table 55: Register overview 6.12.3.1 TASKS_START Address offset: 0x000 Task starting the random number generator Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_START Task starting the random number generator Trigger task 6.12.3.2 TASKS_STOP Address offset: 0x004 Task stopping the random number generator Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_STOP Task stopping the random number generator Trigger task 6.12.3.3 EVENTS_VALRDY Address offset: 0x100 Event being generated for every new random number written to the VALUE register 4454_187 v1.2 174 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_VALRDY 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Event being generated for every new random number written to the VALUE register NotGenerated 0 Event not generated Generated 1 Event generated 6.12.3.4 SHORTS Address offset: 0x200 Shortcuts between local events and tasks Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW VALRDY_STOP 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Shortcut between event VALRDY and task STOP Disabled 0 Disable shortcut Enabled 1 Enable shortcut 6.12.3.5 INTENSET Address offset: 0x304 Enable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW VALRDY 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Write '1' to enable interrupt for event VALRDY Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 6.12.3.6 INTENCLR Address offset: 0x308 Disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW VALRDY 4454_187 v1.2 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Write '1' to disable interrupt for event VALRDY 175 Peripherals 6.12.3.7 CONFIG Address offset: 0x504 Configuration register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW DERCEN 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Disabled 0 Disabled Enabled 1 Enabled Bias correction 6.12.3.8 VALUE Address offset: 0x508 Output random number Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A Reset 0x00000000 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID VALUE Value Description [0..255] Generated random number 6.12.4 Electrical specification 6.12.4.1 RNG Electrical Specification Symbol Description tRNG,START Time from setting the START task to generation begins. Min. Typ. Max. Units 128 µs 30 µs 120 µs This is a one-time delay on START signal and does not apply between samples. tRNG,RAW Run time per byte without bias correction. Uniform distribution of 0 and 1 is not guaranteed. tRNG,BC Run time per byte with bias correction. Uniform distribution of 0 and 1 is guaranteed. Time to generate a byte cannot be guaranteed. 6.13 RTC — Real-time counter The Real-time counter (RTC) module provides a generic, low power timer on the low-frequency clock source (LFCLK). 4454_187 v1.2 176 Peripherals 32.768 kHz START STOP CLEAR TRIGOVRFLW task PRESCALER event TICK event OVRFLW event COMPARE[0..N] COUNTER task RTC task task CC[0:3] Figure 55: RTC block schematic The RTC module features a 24-bit COUNTER, a 12-bit (1/X) prescaler, capture/compare registers, and a tick event generator for low power, tickless RTOS implementation. 6.13.1 Clock source The RTC will run off the LFCLK. The COUNTER resolution will therefore be 30.517 μs. Depending on the source, the RTC is able to run while the HFCLK is OFF and PCLK16M is not available. The software has to explicitely start LFCLK before using the RTC. See CLOCK — Clock control on page 60 for more information about clock sources. 6.13.2 Resolution versus overflow and the PRESCALER Counter increment frequency: fRTC [kHz] = 32.768 / (PRESCALER + 1 ) The PRESCALER register is read/write when the RTC is stopped. The PRESCALER register is read-only once the RTC is STARTed. Writing to the PRESCALER register when the RTC is started has no effect. The PRESCALER is restarted on START, CLEAR and TRIGOVRFLW, that is, the prescaler value is latched to an internal register () on these tasks. Examples: 1. Desired COUNTER frequency 100 Hz (10 ms counter period) PRESCALER = round(32.768 kHz / 100 Hz) - 1 = 327 fRTC = 99.9 Hz 10009.576 μs counter period 2. Desired COUNTER frequency 8 Hz (125 ms counter period) PRESCALER = round(32.768 kHz / 8 Hz) – 1 = 4095 fRTC = 8 Hz 4454_187 v1.2 177 Peripherals 125 ms counter period Prescaler Counter resolution Overflow 0 30.517 μs 512 seconds 28-1 7812.5 μs 131072 seconds 125 ms 582.542 hours 12 2 -1 Table 56: RTC resolution versus overflow 6.13.3 COUNTER register The COUNTER increments on LFCLK when the internal PRESCALER register () is 0x00. is reloaded from the PRESCALER register. If enabled, the TICK event occurs on each increment of the COUNTER. The TICK event is disabled by default. SysClk LFClk TICK PRESC COUNTER 0x000 0x000 0x000 0x000 0x000 0x000000 0x000001 0x000002 0x000003 Figure 56: Timing diagram - COUNTER_PRESCALER_0 SysClk LFClk TICK PRESC 0x001 0x000 COUNTER 0x001 0x000000 0x000 0x001 0x000001 Figure 57: Timing diagram - COUNTER_PRESCALER_1 6.13.4 Overflow features The TRIGOVRFLW task sets the COUNTER value to 0xFFFFF0 to allow SW test of the overflow condition. OVRFLW occurs when COUNTER overflows from 0xFFFFFF to 0. Important: The OVRFLW event is disabled by default. 6.13.5 TICK event The TICK event enables low power "tick-less" RTOS implementation as it optionally provides a regular interrupt source for a RTOS without the need to use the ARM® SysTick feature. Using the RTC TICK event rather than the SysTick allows the CPU to be powered down while still keeping RTOS scheduling active. 4454_187 v1.2 178 Peripherals Important: The TICK event is disabled by default. 6.13.6 Event control feature To optimize RTC power consumption, events in the RTC can be individually disabled to prevent PCLK16M and HFCLK being requested when those events are triggered. This is managed using the EVTEN register. For example, if the TICK event is not required for an application, this event should be disabled as it is frequently occurring and may increase power consumption if HFCLK otherwise could be powered down for long durations. This means that the RTC implements a slightly different task and event system compared to the standard system described in Peripheral interface on page 73. The RTC task and event system is illustrated in Tasks, events and interrupts in the RTC on page 179. Task signal from PPI RTC write TASK OR task RTC core event EVTEN m INTEN m EVENT m IRQ signal to NVIC Event signal to PPI Figure 58: Tasks, events and interrupts in the RTC 6.13.7 Compare feature There are a number of Compare registers. For more information, see Registers on page 184. When setting a compare register, the following behavior of the RTC compare event should be noted: • If a CC register value is 0 when a CLEAR task is set, this will not trigger a COMPARE event. 4454_187 v1.2 179 Peripherals SysClk LFClk PRESC 0x000 COUNTER X 0x000000 CLEAR CC[0] 0x000000 COMPARE[0] 0 Figure 59: Timing diagram - COMPARE_CLEAR • If a CC register is N and the COUNTER value is N when the START task is set, this will not trigger a COMPARE event. SysClk LFClk PRESC 0x000 COUNTER N-1 N N+1 START CC[0] N COMPARE[0] 0 Figure 60: Timing diagram - COMPARE_START • COMPARE occurs when a CC register is N and the COUNTER value transitions from N-1 to N. SysClk LFClk PRESC COUNTER 0x000 N-2 N-1 CC[0] COMPARE[0] N N+1 N 0 1 Figure 61: Timing diagram - COMPARE • If the COUNTER is N, writing N+2 to a CC register is guaranteed to trigger a COMPARE event at N+2. 4454_187 v1.2 180 Peripherals SysClk LFClk PRESC COUNTER 0x000 N-1 N N+1 N+2 > 62.5 ns CC[0] X N+2 COMPARE[0] 0 1 Figure 62: Timing diagram - COMPARE_N+2 • If the COUNTER is N, writing N or N+1 to a CC register may not trigger a COMPARE event. SysClk LFClk PRESC COUNTER 0x000 N-2 N-1 N N+1 >= 0 CC[0] X N+1 COMPARE[0] 0 Figure 63: Timing diagram - COMPARE_N+1 • If the COUNTER is N and the current CC register value is N+1 or N+2 when a new CC value is written, a match may trigger on the previous CC value before the new value takes effect. If the current CC value greater than N+2 when the new value is written, there will be no event due to the old value. SysClk LFClk PRESC COUNTER CC[0] 0x000 N-2 N-1 N N+1 >= 0 N X COMPARE[0] 0 1 Figure 64: Timing diagram - COMPARE_N-1 6.13.8 TASK and EVENT jitter/delay Jitter or delay in the RTC is due to the peripheral clock being a low frequency clock (LFCLK) which is not synchronous to the faster PCLK16M. Registers in the peripheral interface, part of the PCLK16M domain, have a set of mirrored registers in the LFCLK domain. For example, the COUNTER value accessible from the CPU is in the PCLK16M domain and is latched on read from an internal register called COUNTER in the LFCLK domain. COUNTER is the register which is actually modified each time the RTC ticks. These registers must be synchronised between clock domains (PCLK16M and LFCLK). 4454_187 v1.2 181 Peripherals The following is a summary of the jitter introduced on tasks and events. Figures illustrating jitter follow. Task Delay CLEAR, STOP, START, TRIGOVRFLOW +15 to 46 μs Table 57: RTC jitter magnitudes on tasks Operation/Function Jitter START to COUNTER increment COMPARE to COMPARE +/- 15 μs +/- 62.5 ns 19 Table 58: RTC jitter magnitudes on events 1. CLEAR and STOP (and TRIGOVRFLW; not shown) will be delayed as long as it takes for the peripheral to clock a falling edge and rising of the LFCLK. This is between 15.2585 μs and 45.7755 μs – rounded to 15 μs and 46 μs for the remainder of the section. SysClk CLEAR LFClk PRESC COUNTER CLEARa 0x000 X X+1 0x000000 0x000001 0 or more SysClk after = ~15 us 1 or more SysClk before CLEARb Figure 65: Timing diagram - DELAY_CLEAR SysClk STOP LFClk PRESC COUNTER STOPa STOPb 0x000 X X+1 0 or more SysClk after = ~15 us 1 or more SysClk before Figure 66: Timing diagram - DELAY_STOP 2. The START task will start the RTC. Assuming that the LFCLK was previously running and stable, the first increment of COUNTER (and instance of TICK event) will be typically after 30.5 μs +/-15 μs. In some cases, in particular if the RTC is STARTed before the LFCLK is running, that timing can be up to ~250 μs. The software should therefore wait for the first TICK if it has to make sure the RTC is running. 19 Assumes RTC runs continuously between these events. Note: 32.768 kHz clock jitter is additional to the numbers provided above. 4454_187 v1.2 182 Peripherals Sending a TRIGOVRFLW task sets the COUNTER to a value close to overflow. However, since the update of COUNTER relies on a stable LFCLK, sending this task while LFCLK is not running will start LFCLK, but the update will then be delayed by the same amount of time of up to ~250 us. The figures show the smallest and largest delays to on the START task which appears as a +/-15 μs jitter on the first COUNTER increment. SysClk First tick LFClk PRESC 0x000 COUNTER X X+1 X+2 X+3 >= ~15 us 0 or more SysClk before START Figure 67: Timing diagram - JITTER_STARTSysClk First tick LFClk PRESC 0x000 COUNTER X X+1 X+2
NRF52805-CAAA-R 价格&库存
很抱歉,暂时无法提供与“NRF52805-CAAA-R”相匹配的价格&库存,您可以联系我们找货
NRF52805-CAAA-R
    • 1+9.39400
    • 100+8.23900
    • 500+7.63400
    • 1750+7.27100
    • 3500+7.06200
    • 7000+6.85300
    库存:7000
    NRF52805-CAAA-R
    • 1+30.37440
    • 10+20.43153
    • 50+19.35182
    • 100+18.27210
    • 250+17.26358
    • 500+16.63473
    • 1000+16.00589
    • 2500+15.69740
    库存:6980
    NRF52805-CAAA-R
