OG8EI-112-15.36M
OG8EI-112-15.36M
    YXC(扬兴科技)
    SMD7050_4P
    有源晶振 YSO691ER 15.36MHz ±50ppm 3.3V SMD7050_4P 表面贴装 15pF -40~85℃ CMOS
OG8EI-112-15.36M 数据手册
Programmable Crystal Oscillator YSO691ER Applications Low Jitter Features ‧Any frequency ‧One time programmable ‧ PLL circuit provides wide frequency range application (1-200MHz) ‧Low jitter design with new developed IC ‧Package Size: 5.0*3.2, 7.0*5.0mm Specifications(规格参数) Item / Type CMOS Parameter Frequency Range Supply Voltage Variation (Vdd)10% 1.8 V 2.5 V 3.3 V 1MHz to 125MHz 1MHz to 200MHz 1MHz to 200MHz 1.62V~1.98V 2.25V~2.75V 2.97V~3.63V Standby Current 400uA Frequency Tolerance ±30ppm, ±50ppm or specify Output Load 15pF Operating Temperature Range -40~+85℃, -40~+125℃, or specify Storage Temperature Range -55~+150℃ Voltage Vol ( Max. ) / Vol ( Min. ) VOH = 90%Vdd/VOL = 10%Vdd Duty Cycle 45~55% Start-up Time 7ms Max Period Jitter (@12K-20Mhz) 1.8V<1.5ps 2.5V<1.1ps 3.3V<1ps Supply Current See Below Frequency Aging (at 25℃) ±3 ppm / year Max Pin Dimension(脚位尺寸) Pin Functionality Symbol Output Enable 1 OE/ST/NC H:specified frequency output L:output is low. Specified frequency output stop. Standby H:specified frequency output L:output is low. Device goes to sleep mode. Supply current reduces to 400uA(Standby Current). No Connect Pin 1 = VDD or Pin 1 is Open : Specified frequency output.Pin 1 has no function 2 GNG Power Electrical ground 3 OUT Output Oscillator output 4 VDD Power Power supply voltage www.yxc.hk 1 Programmable Crystal Oscillator YSO691ER Low Jitter Dimensions and Recommended land pattern(外观尺寸及推荐焊盘) Package Size – Dimensions (Unit: mm) Recommended Land Pattern (Unit: mm) 5.0*3.2mm 7.0*5.0mm Test Circuit(测试电路) CMOS www.yxc.hk 2
OG8EI-112-15.36M 价格&库存
很抱歉,暂时无法提供与“OG8EI-112-15.36M”相匹配的价格&库存,您可以联系我们找货
