“MINI” AUTOMOTIVE FUSE CLIPS & HOLDERS
For .110 (2.8) × .032 (.80) MINI BLADE FUSES
For Littelfuse Mini 297 or 997 series/Bussmann ATM series or equivalent
VERTICAL FUSE ENTRY
Thru Hole Mount
Surface Mount
AVAILABLE ON TAPE AND REEL
MATERIAL:
.016 (.41) Brass, Matte Tin Plate
UL Current Rating: 15 Amps @ 500V AC
.236 [6.0]
.079 [2.00]
• Low Profile
.250 [6.4]
• Low Profile
.079 [2.00]
.125 [3.2]
.197 [5.0]
.125 [3.2]
Mounting Detail
For Two Clips
.091 [2.30]
Pad Layout
For Two Clips
.244 [6.2]
.236 [6.0]
.091 [2.30]
(2) PLS
.400 [10.2]
CAT. NO. 3563 (Bulk)
.320 [8.2]
“AUTO” FUSE CLIPS & HOLDERS
.320 [8.2]
.094 [2.4] DIA.
(4) PLS
.270
[6.9]
.120 [3.1] DIA.
(2) PLS
CAT. NO. 3564
.091 [2.30]
MIN. TYP.
CAT. NO. 3563TR (Tape & Reel)
.400 [10.2]
MIN.
Tape & Reel Spec’s: 24mm wide; 12mm pitch;
13 inch reel (1500 pieces per reel)
.125 [3.2]
.120 [3.1] DIA.
SPECIFICATIONS
Material: .012 (.30) Brass
Insulator: Nylon, UL Rated 94V-0
UL Temperature Rating: -58°F to+292°F (-50°C to+145°C)
.156 [4.0]
.578 [14.7]
.196
[5.0]
.138
[3.5]
.187 [4.8]
.440 [11.2]
.340 [8.7]
.062 [1.55]
.125 [3.2]
.125 [3.2]
Mounting Detail For Two Clips
.086 [2.20]
.144 [3.7]
.100 [2.6]
.176 [4.5]
.144
[3.7]
.075 [1.90]
.144
[3.7]
.065 [1.65] DIA. (4) PLS
CAT. NO. 3544 Tin-Nickel Plate UL Current Rating: 30 Amps @ 500V AC
LOW PROFILE MINI FUSE HOLDER
UL Current Rating: 20 Amps @ 500V AC CAT. NO. 3544-2 Tin Plate
MINI FUSE HOLDER
• Low insertion force
• Thru hole PC mountable, maintains position during wave soldering
• Fuse holder fully insulates clips to protect fuse from shorting
• Holder assures proper spacing and reduces assembly time
For Littelfuse Low Profile
Mini 897 series or equivalent
or equivalents
SPECIFICATIONS
Contacts: .016 (.41) Brass,
Tin-Nickel Plate
Insulator: Nylon 4/6, UL Rated 94V-0
(-50°C to+145°C)
.265 [6.8]
.780 [19.8]
.290 [7.4]
.265 [6.73]
.630 [16.00]
.290 [7.37]
.110 [2.8]
.530 [13.5]
.062 [1.57] (2) PLS
.134
[3.4]
.110 [2.79]
.390 [9.9]
.062 [1.57] TYP
Mounting Detail
Mounting Detail
.390
[9.9]
.530 [13.5]
Refer to page 41
for Cat. No. 3557
Clip details
.134 [3.4]
CAT. NO. 3557-2
.134
[3.41]
.063 [1.60] DIA. (4) PLS
.134
[3.40]
.063 [1.60]
DIA. (4) PLS
CAT. NO. 3568
HORIZONTAL FUSE ENTRY
SPECIFICATIONS
Contacts: .012 (.30) Brass
Insulator: Nylon 6/6, UL Rated 94V-0
.062
[1.55]
.280 [7.1]
.156 [4.0]
.075 [1.90]
.212
[5.4]
.295 [7.5]
.040
[1.00]
.100 [2.6]
.400 [10.2]
.070 [1.80]
.145 [3.7]
.400
[10.2]
.070 [1.8]
(2) PLS
CAT. NO. 3549 Nickel Plate UL Current Rating: 30 Amps @ 500V AC
Tel (718) 956-8900 • Fax (718) 956-9040
(800) 221-5510 • kec@keyelco.com
.700 [17.8]
.228 [5.8]
.046 [1.17]
DIA. (2) PLS
.076 [1.93]
DIA. (2) PLS
42
.394
[10.0]
.295 [7.5]
.406 [10.3]
.040 [1.0]
(2) PLS
UL Current Rating: 20 Amps @ 500V AC CAT. NO. 3549-2 Tin Plate
RoHS COMPLIANT ~ ISO 9001 CERTIFIED
www.keyelco.com
31-07 20th Road – Astoria, NY 11105-2017
