DATA SHEET
Very High Performance Single-Phase
Filters FN2090
Multi-stage AC/DC EMI Filter with Excellent Attenuation
Performance
Rated currents from 1 to 30 A
Approvals & Compliances
Two-stage filter
Very high differential and common-mode
attenuation
Optional medical versions (B type)
Optional safety versions (A type)
Optional enhanced performance versions
Optional overvoltage protection (Z type)
Features and Benefits
FN 2090 two-stage filters are designed for easy
and fast chassis mounting.
FN 2090 B versions without capacitors to earth
comply to 1MOP for ME (medical equipment) acc.
IEC 60601-1
Performance indicators
FN 2090 A versions with low capacitance to earth
for safety critical applications with a requirement
for low leakage currents.
FN 2090 filters offers an optimized filter range for
enhanced performance AC and DC applications ,
in same compact size (KK, LL, NN types)
All filters provide an exceptional conducted
attenuation performance, based on chokes with
high permeable core material.
FN 2090 two-stage filters are designed for noisy
applications requiring excellent filter
performance.
The higher inductivity offers increased
attenuation performance with the same form
factor as FN 2060 and FN 2080 series.
Technical Specifications
All FN 2090 filters can be delivered with optional
surge pulse protection (Z type).
Rated voltage*
250 VAC, 50/60 Hz
250 VDC
FN 2090 filters are also available as singlestage
filters (FN 2030 series).
Operating frequency
DC to 400 Hz
Rated currents
1 to 30 A @ 40°C max.
Various terminal options allow you to select the
desired connection style.
High potential test voltage
P –> N 1100 VDC for 2 sec
P –> PE 2000 VAC for 2 sec (equiv. cap PE 2550 VDC for 2 sec (equiv. cap >88 nF)
P –> PE 2500 VAC for 2 sec (B types)
Typical Applications
Electrical and electronic equipment
Temperature range (operation and storage)
-25°C to +100°C (25/100/21)**
Consumer goods
Certified to
UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 (applies to
AC and DC applications)
Household equipment
Flammability corresponding to
Laces for -07 version: UL 94 VW-1
Terminal plastic for -06/-08 version: UL 94 V-0
Grommet for -07 version: UL 94 V-0
Industrial applications
Surge pulse protection (Z type)
Helps compliance to IEC61000-4-5 (Differential Mode
only)
Electronic data processing equipment
Overvoltage category
II acc. IEC 60664-1
Pollution degree
2 acc. IEC 60664-1
Altitude
2000m (above derating applies)**
maximum RMS operating voltage at rated frequency or the maximum DC operating voltage
for dedicated requests exceeding this specification (e.g. -40 °C or higher altitude) please contact
your local
Schaffner Sales office
Building automation
Machinery
Medical equipment
Office automation and datacom equipment
Various noisy applications requiring high filter
performance
Typical electrical schematic
2
Very High Performance Single-Phase Filters
Schaffner Group
DATA SHEET
11. Jul 2023
Filter Selection Table
Filter*
Buy
Rated current
@ 40°C (25°C)
Leakage current**
Power Loss
Inductance***
Capacitance***
@ 250V AC/50 Hz
@ 25°C/DC
L
Cx
Cy1
Resistance***
Input/Output
Cy2
R
connections
Weight
(@ 120V AC/60 Hz)
[A]
[mA]
[W]
[mH]
[μF]
[nF]
[nF]
[kΩ]
FN2090-1-..
1 (1.1)
0.45 (0.26)
1.8
2.2
1.0
680
-06
-07
73
FN2090-3-..
3 (3.4)
0.45 (0.26)
3.7
14
0.33
2.2
1.0
470
-06
-07
158
FN2090-4-..
4 (4.5)
0.45 (0.26)
6.4
14
0.33
2.2
1.0
470
-06
-07
176
FN2090-6-..
6 (6.7)
0.61 (0.35)
7.1
8
0.47
3.3
1.0
330
-06
-07
FN2090-8-..
8 (8.9)
0.61 (0.35)
7.7
8
0.47
3.3
1.0
330
-06
-07
FN2090-10-..
10 (11.2)
0.61 (0.35)
8.4
8
0.47
3.3
1.0
330
-06
-07
-08
369
FN2090-12-..
12 (13.4)
0.93 (0.54)
12.1
4
1
10
1.0
220
-06
-07
-08
391
FN2090-16-..
16 (17.9)
0.93 (0.54)
10.7
4
1
10
1.0
220
-06
-07
FN2090-20-..
20 (22.4)
0.93 (0.54)
8.2
2.7
1
10
1.0
220
-06
FN2090-30-08
30 (33.5)
0.93 (0.54)
10.1
1.5
1
10
1.0
220
FN2090A-1-..
1 (1.1)
0.13 (0.07)
1.8
0.47
0.47
680
-06
-07
73
FN2090A-3-..
3 (3.4)
0.13 (0.07)
3.7
14
0.33
0.47
0.47
470
-06
-07
158
FN2090A-4-..
4 (4.5)
0.13 (0.07)
6.4
14
0.33
0.47
0.47
470
-06
-07
176
FN2090A-6-..
6 (6.7)
0.13 (0.07)
7.1
8
0.47
0.47
0.47
330
-06
-07
FN2090A-8-..
[g]
-08
191
330
425
-08
530
-08
548
-08
191
8 (8.9)
0.13 (0.07)
7.7
8
0.47
0.47
0.47
330
-06
-07
FN2090A-10-..
10 (11.2)
0.13 (0.07)
8.4
8
0.47
0.47
0.47
330
-06
-07
-08
330
369
FN2090A-12-..
12 (13.4)
0.13 (0.07)
12.1
4
1
0.47
0.47
220
-06
-07
-08
391
FN2090A-16-..
16 (17.9)
0.13 (0.07)
10.7
4
1
0.47
0.47
220
-06
-07
FN2090A-20-..
20 (22.4)
0.13 (0.07)
8.2
2.7
1
0.47
0.47
220
-06
FN2090A-30-08
30 (33.5)
0.13 (0.07)
10.1
1.5
1
10
10
220
FN2090B-1-..
1 (1.1)
0.00
1.8
680
-06
-07
73
FN2090B-3-..
3 (3.4)
0.00
3.7
14
0.33
470
-06
-07
158
FN2090B-4-..
4 (4.5)
0.00
6.4
14
0.33
470
-06
-07
FN2090B-6-..
6 (6.7)
0.00
7.1
8
0.47
330
-06
-07
FN2090B-8-..
8 (8.9)
0.00
7.7
8
0.47
330
-06
-07
FN2090B-10-..
10 (11.2)
0.00
8.4
8
0.47
330
-06
-07
-08
369
FN2090B-12-..
12 (13.4)
0.00
12.1
4
1
220
-06
-07
-08
391
FN2090B-16-..
16 (17.9)
0.00
10.7
4
1
220
-06
-07
FN2090B-20-..
20 (22.4)
0.00
8.2
2.7
1
220
-06
FN2090B-30-08
30 (33.5)
0.00
10.1
1.5
1
220
FN2090KK-1-06
1 (1.15)
3.46 (1.99)
1.8
22
22
680
-06
FN2090NN-3-06
3 (3.4)
15.71 (9.05)
3.7
14
0.33
100
100
470
-06
200
FN2090NN-4-06
4 (4.5)
15.71 (9.05)
6.4
14
0.33
100
100
470
-06
210
FN2090NN-6-06
6 (6.7)
15.71 (9.05)
7.1
8
0.47
100
100
330
-06
220
425
-08
530
-08
548
176
-08
191
330
425
-08
530
-08
548
Enhanced performance
FN2090NN-8-06
-07
95
8 (8.9)
15.71 (9.05)
7.7
8
0.47
100
100
330
-06
FN2090LL-10-..
10 (11.2)
5.18 (2.98)
8.4
8
0.47
33
33
330
-06
-08
470
FN2090LL-12-..
12 (13.4)
5.18 (2.98)
12.1
4
1
33
33
220
-06
-08
500
FN2090LL-16-06
16 (17.9)
5.18 (2.98)
10.7
4
1
33
33
220
-06
20 (23)
5.18 (2.98)
8.2
2.7
1
33
33
220
-06
30 (33.5)
5.18 (2.98)
10.1
1.5
1
33
33
220
FN2090LL-20-..
FN2090LL-30-08
340
530
-08
580
-08
600
** To compile a complete part number, please replace the -.. with the required I/O connection style.
** For surge pulse protection, please add Z (e.g. FN2090Z-10-06, FN2090BZ-20-08). The different letters code the used Cy values in the filter type (A = 0.47nF; K
= 22nF; L = 33nF; N = 100nF; as the FN2090 is a dual stage filter each letter stands for one stage of Cy)
** Maximum leakage under usual AC operating conditions (acc. IEC 60939-3). Note: if the neutral line is interrupted, worst case leakage could reach twice this
level. Leakage current for DC application is 0mA
*** Tolerances apply: Inductance: -30/+50%, Capacitance: ±20%, Resistance: ±10%
3
Schaffner Group
DATA SHEET
11. Jul 2023
Typical Filter Attenuation
Per CISPR 17: symmetrical 50 Ω/50 Ω -> Differential Mode (DM); asymmetrical 50 Ω/50 Ω -> Common Mode (CM)
1 A: Standard type
A type
B type
3 A: Standard type
A type
B type
4 A: Standard type
A type
B type
6 A: Standard type
A type
B type
8 A: Standard type
A type
B type
4
Schaffner Group
DATA SHEET
11. Jul 2023
10 A: Standard type
A type
B type
12 A: Standard type
A type
B type
16 A: Standard type
A type
B type
20 A: Standard type
A type
B type
30 A: Standard type
A type
B type
5
Schaffner Group
DATA SHEET
Product Selector
Mechanical Data
Connection style -06, 1 A types
Connection style -06, 3 to 20 A types
Connection style -07, 1 A types (same dimensions as style -06)
Connection style -07, 3 to 16 A types (same dimensions as style -06)
Connection style -08, 10 to 30 A types
11. Jul 2023
6
Schaffner Group
DATA SHEET
11. Jul 2023
Dimensions
1A
3A
4A
6A
8A
10 A
12 A
16 A
20 A
30 A
Tolerances
A
71
85
85
85
113.5 ±1
113.5 ±1
113.5 ±1
113.5 ±1
113.5 ±1
113.5 ±1
±0.5
B
46.6
54
54
54
57.5 ±1
57.5 ±1
57.5 ±1
57.5 ±1
57.5 ±1
57.5 ±1
±0.5
C
22.3
30.3
30.3
30.3
45.4 ±1
45.4 ±1
45.4 ±1
45.4 ±1
45.4 ±1
45.4 ±1
±0.5
D
50.5
64.8
64.8
64.8
94 ±1
94 ±1
94 ±1
94 ±1
94 ±1
94 ±1
±0.5
E
44.5
49.8
49.8
49.8
56
56
56
56
56
56
±0.5
F
61
75
75
75
103
103
103
103
103
103
±0.3
G
21
27
27
27
25
25
25
25
25
25
±0.2
H
10.8
12.3
12.3
12.3
12.4
12.4
12.4
12.4
12.4
12.4
±0.5
I
16.8
20.8
20.8
20.8
32.4
32.4
32.4
32.4
32.4
32.4
±0.5
J
25.25
19.9
19.9
19.9
15.5
15.5
15.5
15.5
15.5
15.5
±0.5
K
5.3
5.3
5.3
5.3
4.4
4.4
4.4
4.4
4.4
4.4
L
6.3
6.3
6.3
6.3
6
6
6
6
6
6
M
0.7
0.7
0.7
0.7
1
1
1
1
1
1
6.3 x 0.8
6.3 x 0.8
6.3 x 0.8
6.3 x 0.8
6.3 x 0.8
6.3 x 0.8
6.3 x 0.8
6.3 x 0.8
6.3 x 0.8
6.3 x 0.8
O
8.3
8.3
8.3
8.3
8.4
8.4
8.4
8.4
±0.5
P
14
14.9
14.9
14.9
18
18
18
18
±0.5
AWG type wire
AWG 20
AWG 20
AWG 20
AWG 18
AWG 18
AWG 18
AWG 16
AWG 16
Wire length
140
140
140
140
140
140
140
140
N
M4
M4
M4
M4
M4
Recommended torque (Nm)
1.2 - 1.3
1.2 - 1.3
1.2 - 1.3
1.2 - 1.3
1.2 - 1.3
Earth terminal
1.5 - 1.7
1.5 - 1.7
1.5 - 1.7
1.5 - 1.7
1.5 - 1.7
±0.3
N
+5
All dimensions in mm; 1 inch = 25.4 mm
Tolerances according: ISO 2768-m/EN 22768-m
Please visit www.schaffner.com to find more details on filter connectors.
7
Headquarters, Global
Innovation and
Development
Switzerland
Schaffner Group
Industrie Nord
Nordstrasse 11e
4542
Luterbach
+41 32 681 66 26
info@schaffner.com
Schaffner Group
Finland
Schaffner Oy
Sauvonrinne 19 H
8500
Lohja
+358 50 468 7284
finlandsales@schaffner.com
Sweden
Schaffner EMC AB
Östermalmstrorg 1
114 42
Stockholm
+46 8 5050 2425
swedensales@schaffner.com
France
Schaffner EMC S.A.S.
16-20 Rue Louis Rameau
95875
Bezons
+33 1 34 34 30 60
francesales@schaffner.com
Switzerland
Schaffner EMV AG
Industrie Nord
Nordstrasse 11e
4542
Luterbach
+41 32 681 66 26
switzerlandsales@schaffner.com
India
Schaffner India Pvt. Ltd
Regus World Trade Centre
WTC 22nd Floor Unit No 2238 Brigade
Gateway Campus 26/1 Dr. Rajkumar Road
Malleshwaram (W)
560055
Bangalore
+91 8067935355
indiasales@schaffner.com
© 2023 Schaffner Group
The content of this document has been
carefully
checked
and
understood.
However, neither Schaffner nor its
subsidiaries
assume
any
liability
whatsoever for any errors or inaccuracies
of this document and the consequences
thereof. Published specifica-tionsw are
subject to change without notice. Product
suitability for any area of application must
ultimately
be
determined
by
the
customer. In all cases, products must
never be operated outside their published
specifications.
Schaffner
does
not
guarantee the availability of all published
products. This disclaimer shall be
governed by substantive Swiss law and
resulting disputes shall be settled by the
courts at the place of business of Schaffner
Holding AG. Latest publications and a
complete disclaimer can be downloa-ded
from the Schaffner website. All trademarks
recognized.
11. Jul 2023
Sales and Application
Centers
Germany
Schaffner Deutschland GmbH
Schoemperlenstrasse 12B
76185
Karlsruhe
+49 721 56910
germanysales@schaffner.com
To find your local partner within
Schaffner‘s global network schaffner.com
DATA SHEET
Taiwan
Schaffner EMV Ltd.
U-Town
20 Floor-2 No 97 Section 1 XinTai 5th Road
XiZhi District
22175
New Taipei City
+886 226975500
taiwansales@schaffner.com
Italy
Schaffner EMC S.r.l.
Via Ticino, 30
20900
Monza (MB)
+39 039 21 41 070
italysales@schaffner.com
United Kingdom
Schaffner Ltd.
Suite 1 Oakmede Place
Terrace Road
RG42 4JF
Binfield
+44 118 9770070
uksales@schaffner.com
Japan
Schaffner EMC K.K.
ISM Sangenjaya
7F 1-32-12 Kamiuma Setagaya-ku
154-0011
Tokyo
+81 3 5712 3650
japansales@schaffner.com
United States
Schaffner EMC Inc.
52 Mayfield Avenue
Edison, New Jersey
+1 732 225 9533
usasales@schaffner.com
Singapore
Schaffner EMC Pte Ltd.
Blk 3015A Ubi Road 1 #05-09 Kampong Ubi
Industrial Estate
408705
Singapore
+65 63773283
singaporesales@schaffner.com
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Schaffner:
FN2090-1-06 FN2090-1-07 FN2090-3-06 FN2090-3-07 FN2090-4-06 FN2090-4-07 FN2090-6-06 FN2090-6-07
FN2090-8-06 FN2090-8-07 FN2090-10-06 FN2090-10-07 FN2090-12-06 FN2090-12-07 FN2090-16-06 FN209016-07 FN2090-20-06 FN2090-20-07 FN2090A-1-06 FN2090A-3-06 FN2090A-4-06 FN2090A-6-06 FN2090A-8-06
FN2090A-10-06 FN2090A-12-06 FN2090A-16-06 FN2090B-1-06 FN2090B-3-06 FN2090B-4-06 FN2090B-6-06
FN2090B-8-06 FN2090B-10-06 FN2090B-12-06 FN2090B-16-06 FN2090A-20-06 FN2090B-20-06 FN2090-8-06-1
FN2090-20-08 FN2090Z-16-06 FN2090-30-08 FN2090B-20-08 FN2090B-30-08 FN2090Z-1-06 FN2090Z-3-06
FN2090Z-4-06 FN2090Z-6-06 FN2090Z-8-06 FN2090Z-10-06 FN2090Z-12-06 FN2090Z-20-06 FN2090Z-20-08
FN2090BZ-1-06 FN2090BZ-3-06 FN2090BZ-4-06 FN2090BZ-6-06 FN2090BZ-8-06 FN2090BZ-10-06 FN2090BZ12-06 FN2090BZ-16-06 FN2090BZ-20-06 FN2090NN-8-06 FN2090NN-3-06 FN2090NN-4-06 FN2090LL-30-08
FN2090LL-10-06 FN2090LL-20-06 FN2090NN-6-06 FN2090LL-16-06 FN2090LL-20-08 FN2090LL-12-06
FN2090KK-1-06 FN2090Z-30-08 FN2090BZ-30-08 FN2090B-10-07 FN2090A-20-08 FN2090B-16-07 FN2090Z-6-07
FN2090Z-10-08 FN2090Z-12-08 FN2090-12-08 FN2090B-4-07 FN2090LL-10-08 FN2090LL-12-08 FN2090-6-08
FN2090-10-08 FN2090KK-1-07
很抱歉,暂时无法提供与“FN2090A-20-06”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+737.59680
- 200+294.31080
- 500+284.47200
