ZC78K-2B-12VMWFTY
ZC78K-2B-12VMWFTY
    GOLDEN(高登)
    磁保持继电器 12VDC 90A 250VAC,双线圈,铜柱连接,防磁
ZC78K-2B-12VMWFTY 数据手册
Shunt resistance Relay specification 150±5% μΩ 90A 250V AC DC 12V Marking(Up cover) GOLDEN 90A 250VAC COIL: 12VDC ZC78K-2B-12VMWFTZ QR code info : 1.Brand:GOLDEN 2.Part number :ZC78K-90A-12V dual 3.Production date :20230727 Yellow 黄 24AWG UL1569 Red Black 红 24AWG UL1569 黑 24AWG UL1569 85 100+5 -0 80+5 -0 Green 21 绿 24AWG UL3266 Black Pin3 黑 64 Yellow Pin2 黄 Red 36.5 Pin1 红 5 Blue 1 2 蓝 24AWG UL3266 4 3 Red 50.5 42.5 红 24AWG UL3266 10平方电刷线 套硅胶管 .5 Ø4 10mm flexible braided coppe with covered with silicon rubber case 镀锡 3.75 19.5 40 67 Tin plated 10平方电刷线 套硅胶管 焊接处套黑色热缩管 2 10mm flexible braided coppe with covered with silicon rubber case Black heatshrink tube cover welding area Technical requirement : 1.Product specification :ZC78K-90A 12V dual coils ; 2.Contact loading :2×90A 250VAC ; Contacts 3.Coil resistance :24Ω +/-10%/24 Ω +/-10% wiring 4.Contact resistance :≤ 0.8 Ω diagram 5.Operating time (At rated voltage ):≤ 30ms,Releasing time ≤30ms; 6.Dieletric withstand voltage :Between coil and contact≥4000VAC/1min ;Between open contacts ≥1800VAC/1min1 ; 2 7.Shunt resistace value:150+/-5%u ? ; 8.Product contact keep close when shipping. Relay coil operating diagram 3 4 Pin1 Red -VC E nterprise secrets copying prohibited Designer Date ±0.2 Angel tolarance 陈禄生 Checker 2023.10.12 Date ±1° ZC78K-2B-12VMWFTZ-001 Pin3 Black Yellow 断开 闭合 OFF +VC ON -VC Golden relay ZC78K-90A-12Vdual coils-6W Name Size tolarance Pin2 Magnetic latching relay File No. Unit:MM 1:1 Ratio Version V1.0 1 QTY Page 1/1
ZC78K-2B-12VMWFTY 价格&库存
很抱歉,暂时无法提供与“ZC78K-2B-12VMWFTY”相匹配的价格&库存,您可以联系我们找货
