TM
DUO mXTEND
(NN03-320)
DATASHEET
DATASHEET
DUO mXTENDTM (NN03-320)
DUO mXTEND™ (NN03-320)
The DUO mXTEND™ antenna booster can provide optimal performance, even under the
restriction of having no ground clearance beyond the antenna footprint. This miniature and
multipurpose component is designed to provide GNSS and Bluetooth connectivity worldwide,
simultaneously, as well as other regions of the spectrum, such as 5G and UWB,
simultaneously, thanks to its multiport nature.
Product Benefits
Multipurpose: Multiband and multi-RAT IoT chip antenna component with 2
independents ports.
Smallest clearance: No clearance beyond the antenna footprint.
Miniature: Small form factor of 7.0 mm x 3.0 mm x 2.0 mm.
Best for combining: One or more of GNSS, Bluetooth, UWB and 5G applications.
Versatile: Dual mounting on device corner or center edge.
Reliability: Off-the-Shelf standard product, no antenna part customization (electronic
optimization).
Use cases: tracking devices, wearables, gaming devices, IoT-5G modules.
Operation Bands Summary
GNSS, Bluetooth, 5G and UWB (1561 – 1606MHz, 2400 – 2500MHz, 3400 – 3800MHz,
3100 – 4800MHz and 6000 – 10600 MHz).
Last Update: January 2021
2
DATASHEET
1. AVAILABLE SOLUTIONS SUMMARY
Class
Frequency
Regions
2 Ports
4
1 Port
3
1 Port
1
2400 MHz to 2500 MHz
BLUETOOTH
1 Port
1
3400 MHz to 3800 MHz
5G
1 Port
1
3100 MHz to 4800 MHz and
6000 MHz to 10600 MHz
UWB
Frequency range
More detailed info
1561MHz, 1575MHz,
1598MHz to 1606MHz, and
2400MHz to 2500MHz.
1561 MHz, 1575 MHz,
1598MHz to 1606MHz
GNSS + BLUETOOTH
GNSS
2. DETAILED AVAILABLE SOLUTIONS
2.1. GNSS AND BLUETOOTH SOLUTION
Technical
features
Average
Efficiency
Peak Gain
VSWR
Radiation Pattern
Polarization
Weight (approx.)
Temperature
Impedance
Dimensions
(L x W x H)
BeiDou
GPS & GALILEO
GLONASS
Bluetooth
1561MHz
1575MHz
1598 – 1606MHz
2400 – 2500MHz
> 40%
> 45%
> 50%
> 50%
-1.1 dBi
-1.0 dBi
-1.0 dBi
< 3:1
Omnidirectional
Linear
0.11 g.
-40 to +125 ºC
50
-0.9 dBi
Technical features. Measures from the evaluation board (80 mm x 40 mm x 1 mm).
3
DATASHEET
2.2 GNSS SOLUTION
Technical
features
Average
Efficiency
Peak Gain
1561 MHz
1575 MHz
1598 – 1606 MHz
> 60 %
> 70 %
> 60 %
1.6 dBi
1.8 dBi
< 2.5:1
Omnidirectional
Linear
0.11 g.
-40 to +125 ºC
50
VSWR
Radiation Pattern
Polarization
Weight (approx.)
Temperature
Impedance
Dimensions
(L x W x H)
1.1 dBi
2.3 BLUETOOTH SOLUTION
Technical features
2400 MHz – 2500 MHz
Average Efficiency
> 70 %
1.8 dBi
< 2.5:1
Omnidirectional
Linear
0.11 g.
-40 to +125 ºC
50
Peak Gain
VSWR
Radiation Pattern
Polarization
Weight (approx.)
Temperature
Impedance
Dimensions
(L x W x H)
4
DATASHEET
2.4 5G SOLUTION
Technical features
3.4 – 3.8 GHz
Average Efficiency
Peak Gain
VSWR
Radiation Pattern
Polarization
Weight (approx.)
Temperature
Impedance
Dimensions
(L x W x H)
> 60%
2.6 dBi
< 3.0:1
Omnidirectional
Linear
0.11 g.
-40 to + 125 ºC
50
2.5 UWB SOLUTION
Technical features
Average Efficiency
Peak Gain
VSWR
Radiation Pattern
Polarization
Weight (approx.)
Temperature
Impedance
Dimensions
(L x W x H)
Option 1 UWB (LFR)
Option 2 UWB (HFR)
3.1 – 4.8 GHz
6.0 – 10.6 GHz
> 80%
> 80%
2.3 dBi
3.6 dBi
< 2.6:1
< 4.0:1
Omnidirectional
Linear
0.11 g.
-40 to + 125 ºC
50
Technical features. Measures from the evaluation board (25 mm x 20 mm x 1 mm).
If you need assistance to design your matching network, please contact support@ignion.io
You can also try our free of charge1 NN Wireless Fast Track service you will receive a tailored
antenna design approach for free in 24h1. discover the feasibility of your next wireless project
including the antenna!
1
See terms and conditions for a free NN Wireless Fast-Track service in 24h at: https://www.ignion.io/fast-track-project/
5
DATASHEET
Contact:
support@ignion.io
+34 935 660 710
Barcelona
Av. Alcalde Barnils, 64-68 Modul C, 3a pl.
Sant Cugat del Vallés
08174 Barcelona
Spain
Shanghai
Shanghai Bund Centre
18/F Bund Centre, 222 Yan’an Road East,
Huangpu District
Shanghai, 200002
China
New Dehli
New Delhi, Red Fort Capital Parsvnath Towers
Bhai Veer Singh Marg, Gole Market,
New Delhi, 110001
India
Tampa
8875 Hidden River Parkway
Suite 300
Tampa, FL 33637
USA
6
很抱歉,暂时无法提供与“NN03-320”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2500+7.567752500+0.98379
- 5000+7.279885000+0.94636
- 7500+7.119217500+0.92548
- 12500+6.9246712500+0.90019
- 国内价格 香港价格
- 1+12.255051+1.59312
- 10+10.5751810+1.37474
- 25+9.9738425+1.29657
- 100+9.15087100+1.18959
- 250+8.65572250+1.12522
- 500+8.30575500+1.07972
- 1000+7.975521000+1.03680
