75102 HD
75102 HD
    GEEHY(极海半导体)
    #10 密封 垫圈 厚 不锈钢
75102 HD 数据手册
Seeloc Washers   APM Hexseal’s Seeloc® Washers consist of molded silicone rubber bonded to specially formed stainless steel washers. Designed to be used in conjunction with conventional screws, bolts or studs, Seeloc Washers are a simple solution for all sorts of sealing needs. The silicone contact surface features a continuous ridge which, upon compression, creates a 360° sealing barrier around the periphery of the washer face. The silicone rubber also forms a seal under the head of the associated fastener and makes full vertical contact with the threads/shank, making for a complete, highpressure seal unlike any other. In addition to conventional mounting holes, Seeloc Washers can be used over extra‐large holes, or even oddly shaped adjustment slots. They also make an excellent “plug” for sealing optional knockout holes in control boxes or electrical cabinets. Their reusability make them perfect for applications that might require periodic maintenance or adjustments. UL Recognized (UL Type 4X/6 enclosures) and IP66/68 rated, Seeloc Washers provide a high‐performance, air‐ and liquid‐tight seal that is ideal for applications where spray, vapors or wash‐downs are present, or where there is a concern of damage from a wide range of contaminants, such as dust, oils and salt build‐up. APM Hexseal is now introducing our newly developed Heavy Duty Seeloc® Washers, capable of handling torque values AT LEAST 50% higher than our original Seeloc Washers. Currently available in both 1/2” (14mm) and 1” (25.4mm) O.D. sizes, these new sealing washers are perfect for a myriad of sealing requirements, from medical equipment and chemical handling, to construction equipment and food processing. Seeloc® Washers are a proven solution just waiting for a problem! For information on maximum torque values for our Original and Heavy Duty Seeloc Washers please see our table of Torque Values for Seeloc® Washers.         MATERIAL SPECIFICATIONS For APM Hexseal® Standard Seeloc® Washers Washer Material: 18/8 Stainless Steel Elastomer: Silicone† conforms to A-A-59588, Class 3A, GR50, Green ‡ Temperature Range: -103° F to +400° F ( -75° C to +204° C) Pressure Range: Up to 100 psig internal and external. Resistant to: Splash, salt spray, sunlight, ozone, weather, fungus, dust, and most acids and lubricating oils. Shelf Life: Excess of 25 years Alternative elastomers are available. Please consult our Molded Elastomer Options for details. ‡ Standard color for Metric Seeloc Washers is red. Alternative elastomer colors are available by special order.    STANDARD AND HEAVY DUTY SEELOC® WASHERSFig.1 APM Hexseal  Part #  Compatible  Thread Size  Outer  Diameter (C)  Max. Mounting  Hole Diameter  75601 #6 1/2" (0.550") 1/4" (6.35mm) 75801 #8 1/2" (0.550") 1/4" (6.35mm) 75101 #10 1/2" (0.550") 1/4" (6.35mm) 75101HD #10 1/2" (0.550") 1/4" (6.35mm) 75602 #6 1" 3/8" (9.53mm) 75602HD #6 1" 3/8" (9.53mm) 75802 #8 1" 3/8" (9.53mm) 75102 #10 1" 3/8" (9.53mm) 75102HD #10 1" 3/8" (9.53mm) 75082 1/4" 1" 3/8" (9.53mm) 75082HD 1/4" 1" 3/8" (9.53mm) 75107 5/16" 1" 1/2" (12.70mm) 75122 3/8" 1" 5/8" (15.87mm) 75122HD 3/8" 1" 5/8" (15.87mm) 75142 7/16" 1" 5/8" (15.87mm) 75162 1/2" 1" 5/8" (15.87mm) 75603 #6 1‐1/2" 5/8" (15.87mm) 75803 #8 1‐1/2" 5/8" (15.87mm) 75103 #10 1‐1/2" 5/8" (15.87mm) 75083 1/4" 1‐1/2" 5/8" (15.87mm) 75108 5/16" 1‐1/2" 5/8" (15.87mm) 75123 3/8" 1‐1/2" 3/4" (19.05mm) 75143 7/16" 1‐1/2" 3/4" (19.05mm) 75163 1/2" 1‐1/2" 3/4" (19.05mm) METRIC SEELOC® WASHERSFig.1 APM Hexseal  Part #  Compatible  Thread Size  Outer  Diameter (C)  Max. Mounting  Hole Diameter      75031 M3 14.0mm 6.35mm 75041 M4 14.0mm 6.35mm 75051 M5 14.0mm 6.35mm 75032 M3 25.4mm 9.53mm 75042 M4 25.4mm 9.53mm 75052 M5 25.4mm 9.53mm 75062 M6 25.4mm 12.70mm 75312 M8 25.4mm 12.70mm 75392 M10 25.4mm 15.87mm 75472 M12 25.4mm 15.87mm
75102 HD 价格&库存
很抱歉,暂时无法提供与“75102 HD”相匹配的价格&库存,您可以联系我们找货
