N5040 2
N5040 2
    GEEHY(极海半导体)
    PUSHBUTTON FULL BOOT GRAY
N5040 2 数据手册
Sealing Boots for Pushbutton-Actuated Switches HEXSEAL® and E-SEEL® pushbutton boots are molded from a high tear-strength silicone rubber bonded to a built-in mounting nut (other materials available for specific environments). Each encloses the base of the protruding switch bushing and forms a watertight and dust-tight seal against the front panel surface. SPECIFICATIONS Material ........................HEXSEALS: Silicone rubber conforms to A-A-59588, Class 3B, Grade 50 unless otherwise specified. E-SEELS: Silicone rubber polymer type ASTM D1418 Mounting Nut ..............HEXSEALS: Brass, nickel-plated E-SEELS: Brass, black-oxide Temperature Range....HEXSEALS: -94°F to +400°F (-70°C to +204°C) E-SEELS: -80°F to +400°F (-62°C to +204°C) Enclosure Protection..NEMA/UL/ULC Types 1, 2, 3, 3S, 3R, 4, 4X, 6P, 12, 13; IEC IP66/IP68 Pressure Range ..........Exceeds 15 psi internal and 1500 psi external Operational Life ..........100,000 actuations (minimum) Shelf Life .....................Excess of 25 years Resistant to.................Salt spray, sunlight, ozone, weather, fungus, and most acids and lubricating oils Military Specs*............Most HEXSEALS meet MIL-DTL-5423. (See listing on page 6) Agency Recognition...UL & ULC Recognized Component to UL Std. 50 Installation...................Please see installation instructions on page 19 HEXSEAL® & E-SEEL® Silicone Rubber Boot Single Piece Design Molded-in Mounting Nut Panel Sealing Rib (eliminates need for O-ring) Panel *APM’s policy is to manufacture our HEXSEAL® sealing boots as defined by the requirements of MIL-Spec MILDTL-5423 which we regard as the standard for the switch, circuit breaker and potentiometer industry. These requirements were formulated based on our original patent. Switch Housing HOW TO ORDER For metric sizes, see page 20. Full Pushbutton Boots – IP66/68 Rated FIGURE 9 C A B Flat inch mm .250 6.35 .250 6.35 .375 9.53 .375 9.53 .375 9.53 .375 9.53 .375 9.53 .437 11.11 .500 12.70 .500 12.70 .625 15.88 .625 15.88 .625 15.88 .625 15.88 .625 15.88 .625 15.88 .625 15.88 .625 15.88 .625 15.88 .750 19.05 .625 15.88 .625 15.88 C I.D. inch mm .125 3.18 .120 3.18 .188 4.76 .125 3.18 .188 4.76 .188 4.76 .125 3.18 .156 3.97 .300 7.60 .300 7.60 .422 10.72 .422 10.72 .422 10.72 .422 10.72 .422 10.72 .422 10.72 .422 10.72 .422 10.72 .422 10.72 .515 13.10 .422 10.72 .422 10.72 Military Part Number — SCL6303A-03 M5423/10-01 — M5423/10-03 M5423/10-02 — — — — — — M5423/07-01 M5423/07-11 M5423/07-02 M5423/07-12 M5423/07-03 M5423/07-05 — M5423/07-04 — — B O.D. inch mm .641 16.27 .766 19.45 .641 16.27 .641 16.27 .641 16.27 .641 16.27 C I.D. inch mm .320 8.11 .375 9.53 .320 8.11 .320 8.11 .320 8.11 .320 8.11 Military Part Number — — — — — — B Flat inch mm .625 15.88 .625 15.88 .625 15.88 C I.D. inch mm .344 8.73 .344 8.73 .344 8.73 Military Part Number — — — APM Boot Part Number Color* 1231/17 N5045 N5040G 1231/32 N5040 N5040R 1231/31 1231/27 1231/8 1231/35 NC3030 7⁄ 16-28 NC3030 7⁄ 16-32 N3030 N3030-2513 NC3030 NC3030-2513 NH3030 NH3030S NC3030H N3040 C1231/41 C1231/42 Gray Gray Gray Gray Gray Gray Gray Gray Gray Clear Clear Gray Gray Clear Gray Clear Gray Gray Gray Gray Black Black IP66/68 Rated B Thread Size FIGURE 10 3⁄ 8-27NS-2B 15⁄ 32-32NS-2B 3⁄ 8-24NF-2B 3⁄ 8-27NS-2B 3⁄ 8-27NS-2B 3⁄ 8-32NEF-2B Max. Plunger Height inch mm .330 8.38 .400 10.14 .330 8.38 .330 8.38 .330 8.38 .330 8.38 A inch .609 .719 .609 .609 .609 .609 mm 15.48 18.26 15.48 15.48 15.48 15.48 Mounting nut material: Aluminum Thread Size 7⁄ 16-28UNEF-2B 7⁄ 16-32UN-2B 15⁄ 32-32NS-2B A inch .797 .797 .797 mm 20.24 20.24 20.24 Color* 1221/12 1221/15 C1221/22 C1221/21 C1221/21 4 C1221/23 Gray Gray Clear Black Clear Clear APM Boot Part Number 7⁄ 16-28 NC3030FL NC3030FL 7⁄ 16-32 NC3030FL • • • • • • • • • • • • • • • • • • • • • • Figure 9 APM Boot Part Number IP66/68 Rated Max. Plunger Height inch mm .313 7.94 .313 7.94 .313 7.94 • • • • • • Figure 10 Color* Gray Gray Gray • • • *Other colors available. Please consult factory. DIMENSIONS FOR REFERENCE ONLY. Current dimensional drawings can be viewed on our website and CAD drawings can also be downloaded. RoHS Compliant www.apmhexseal.com 12 800.498.9034 E-SEEL mm 5.70 7.54 7.94 13.49 7.94 7.94 13.49 9.13 16.60 16.60 18.26 18.26 13.89 13.89 18.26 18.26 13.89 13.89 18.65 15.48 13.89 18.26 HEXSEAL A inch .226 .297 .313 .531 .313 .313 .531 .359 .653 .653 .719 .719 .547 .547 .719 .719 .547 .547 .734 .609 .547 .719 HEXSEAL Aluminum insert 8-40 NS-2B 8-40 NS-2B 1⁄ 4-32NS-2B 1⁄ 4-32NS-2B 1⁄ 4-40NS-2B 1⁄ 4-40NS-2B 1⁄ 4-40NS-2B 5⁄ 16-32UNEF-2B 3⁄ 8-27NS-2B 3⁄ 8-32NEF-2B 7⁄ 16-28UNEF-2B 7⁄ 16-32UN-2B 15⁄ 32-32NS-2B 15⁄ 32-32NS-2B 15⁄ 32-32NS-2B 15⁄ 32-32NS-2B 1⁄ 2-32NS-2B 1⁄ 2-32NS-2B 1⁄ 2-32NS-2B 5⁄ 8-24NEF-2B 15⁄ 32-32NS-2B 15⁄ 32-32NS-2B Max. Plunger Height inch mm .118 3.00 .188 4.76 .203 5.16 .453 11.51 .141 3.57 .203 5.16 .344 11.51 .212 5.41 .545 13.80 .545 13.80 .438 11.11 .438 11.11 .281 7.14 .281 7.14 .438 11.11 .438 11.11 .281 7.14 .188 4.76 .469 11.91 .281 7.14 .281 7.14 .438 11.11 E-SEEL Thread Size Figure 8 HEXSEAL FIGURE 8 E-SEEL Specify APM boot part number and, if necessary, the appropriate bushing adaptor part number (please see page 19). Panel-Mounted Full Pushbutton Boots – IP66/68 Rated 5⁄ 8-27NS-2A 5⁄ 8-24NEF-2A 5⁄ 8-27NS-2A 5⁄ 8-24NEF-2A A inch .844 .844 .844 .844 B O.D. inch mm .875 22.23 .875 22.23 .875 22.23 .875 22.23 mm 21.44 21.44 21.44 21.44 C Inside Thread 1⁄ 2-32NS-2B 1⁄ 2-32NS-2B 1⁄ 2-32NS-2B 1⁄ 2-32NS-2B Military Part Number M5423/06-01† M5423/06-03 M5423/06-02† M5423/06-04 Figure 11 APM Boot Part Number 3070 3073 3075 3077 Color* Gray Gray Gray Gray • • • • E-SEEL Outside Thread PlungerBushing Height mm inch .438 11.12 .438 11.12 .688 17.47 .688 17.47 HEXSEAL FIGURE 11 *Other colors available. Please consult factory. †Inactive for new designs. Thread Size 7⁄ 16-28NS-2B 7⁄ 16-32UN-2B 15⁄ 32-32NS-2B 1⁄ 2-32NS-2B B Flat A Height inch mm .547 13.89 .547 13.89 .547 13.89 .547 13.89 inch .625 .625 .625 .625 mm 15.88 15.88 15.88 15.88 C Throat inch mm .250 6.35 .250 6.35 .250 6.35 .250 6.35 Military Part Number — — — — APM Boot Part Number 7⁄ 16-28 N3030B N3030B 7⁄ 16-32 N3030B NH3030B Figure 12 HEXSEAL Half-Pushbutton Boots (Pushbutton Actuator Protrudes) – IP66/68 Rated Color* Clear Clear Clear Clear E-SEEL FIGURE 12 • • • • *Other colors available. Please consult factory Armored Pushbutton Boots – IP66/68 Rated 15⁄ 32-32NS-2B 15⁄ 32-32NS-2B A inch .984 .984 mm 25.00 25.00 B Flat inch mm .750 19.05 .750 19.05 Figure 13 C I.D. inch mm .422 10.72 .422 10.72 Military Part Number — — APM Boot Part Number Color HEXSEAL Thread Size Plunger Height mm inch .438 11.11 .438 11.11 1238/1 SS 1238/5* SS †† †† • • E-SEEL FIGURE 13 *P/N 1238/5 features a 11/4" diameter actuator button. ††Stainless steel housing with silicone boot. EMI/RFI Shielded Full Pushbutton Boots – IP66/68 Rated 15⁄ 32-32NS-2B 15⁄ 32-32NS-2B 1⁄ 2-32NS-2B 1⁄ 2-32NS-2B 5⁄ 8-24NEF-2B 1⁄ 2-32NS-2B A inch .547 .719 .547 .547 .609 .734 mm 13.89 18.26 13.89 13.89 15.48 18.65 B Flat inch mm .625 15.88 .625 15.88 .625 15.88 .625 15.88 .750 19.05 .625 15.88 C I.D. inch mm .422 10.72 .422 10.72 .422 10.72 .422 10.72 .516 13.10 .422 10.72 Military Part Number M5423/07-06 M5423/07-07 M5423/07-08 M5423/07-10 M5423/07-09 — Figure 14 APM Boot Part Number Color* N3030RFI NC3030RFI NH3030RFI NH3030SRFI N3040RFI NC3030HRFI Gray Gray Gray Gray Gray Gray HEXSEAL Thread Size Plunger Height inch mm .281 7.14 .438 11.11 .281 7.14 .188 4.76 .281 7.14 .469 11.91 E-SEEL FIGURE 14 • • • • • • *Other colors available. Please consult factory. All standard EMI/RFI boots feature a molded knitted Monel shield. EMI/RFI shielded pushbutton boots have an operational life of 15,000 actuations (minimum) Back-of-Panel Mounted Pushbutton Boots Full Pushbutton Boots FIGURE 16 C Width inch .750 .750 mm 19.05 19.05 Military Part Number APM Boot Part Number Color — — 3050 3051 Clear Clear • • Half Pushbutton Boots (Pushbutton Actuator Protrudes) D A B C Hole Height O.D. Throat Locations inch mm inch mm inch mm inch mm .578 14.68 .531 13.49 .156 3.97 1.813 46.04 Part numbers in this group conform to A-A-59588 Gr. 50. Width inch .750 mm 19.05 Figure 16 Military Part Number APM Boot Part Number Color — 3050B Clear DIMENSIONS FOR REFERENCE ONLY. Current dimensional drawings can be viewed on our website and CAD drawings can also be downloaded. 13 www.apmhexseal.com E-SEEL B O.D. E-SEEL D Hole Locations inch mm inch mm inch mm inch mm .906 23.02 .531 13.49 .453 11.51 1.813 46.04 .399 10.13 .438 11.11 .359 9.13 1.813 46.04 Part numbers in this group conform to A-A-59588 Gr. 50. A Height HEXSEAL Figure 15 HEXSEAL FIGURE 15 • RoHS Compliant 800.498.9034 METRIC Sizes for Toggle, Pushbutton and Rotary Switches and Circuit Breakers Operator Chamber E-SEEL® Silicone Rubber Boot SPECIFICATIONS Material ........................Silicone rubber polymer type ASTM D 1418 Mounting Nut ..............Brass, black-oxide. *Brass, nickel-plated. Temperature Range....-80°F to +400°F (-62°C to +204°C) Enclosure Protection..NEMA/UL/ULC Types 1, 2, 3, 3S, 3R, 4, 4X, 6P, 12, 13; IEC IP66/IP68 Pressure Range ..........Exceeds 15 psi internal and 1500 psi external Operational Life ..........100,000 actuations (minimum) RoHS Shelf Life .....................Excess of 25 years Compliant Resistant to.................Salt spray, sunlight, ozone, weather, fungus, ® and most acids and lubricating oils C US Agency Recognition...UL & ULC Recognized Component to UL Std. 50 UL Recognized Component Installation...................Please see installation instructions on page 19 Single Piece Design Molded-in Mounting Nut Panel Sealing Rib (eliminates need for O-ring) Panel  Switch Housing Additional metric sizes available (consult factory) Full Toggle (with Constant I.D.) Switch Boots (covers all external portions of switch & seals switch mounting hole) TOGGLE SWITCH BOOTS Fig. A Thread Size Throat Size1 (“A”) Max Toggle Height2 Max Boot Height (“B”) mm in. mm in. mm in. Figure A Flat (“C”) mm in. Color APM Cat. No. M6 X 0.75 2.9 0.116 10.8 0.43 14.3 0.562 9.0 0.352 Black 1131/25* M12 X 0.75 5.3 0.21 16.2 0.64 21.6 0.85 15.8 0.625 Black C1131/41 M12 X 0.75 5.5 0.219 22.8 0.90 27.7 1.1 15.8 0.625 Black 1131/26-M12-.75 M12 X 1 6.5 0.256 16.7 0.66 21.4 0.844 15.8 0.625 Black 1131/31-M12 M12 X 1 5.9 0.234 16.9 0.66 21.8 0.859 15.8 0.625 Black 1131/40 M12 X 1 5.5 0.219 22.8 0.90 27.7 1.1 15.8 0.625 Black 1131/26-M12-.10 1 2 IP66/IP68/NEMA 6P Enclosure Protection Throat size is the maximum diameter of the switch toggle/handle (Dimension “A”). Max toggle height is the maximum distance from the end of the switch mounting stem to the end of the switch toggle. Half Toggle Switch Boots (Seals switch mounting stem & hole; toggle actuator protrudes) Fig. B Thread Size Throat Size (“A”) mm Toggle Diameter Accomodated Max Boot Height (“B”) in. mm in. mm in. Figure B Flat (“C”) Color mm in. APM Cat. No. M5 X 0.5 1.1 0.42 1.57-4.57 0.062-0.18 5.7 0.225/0.25 7.9 0.313 Black 1132/17-M5-5 M12 X 1 2.36 0.093 2.92-6.09 0.115-0.24 11.1 0.437 15.9 0.625 Black 1132/33-M12-1 IP66/IP68/NEMA 6P Enclosure Protection PUSHBUTTON SWITCHES & CIRCUIT BREAKERS/PROTECTORS Fig. C Half Toggle Switch Boots (Seals switch mounting stem & hole; toggle actuator protrudes) Fig. D Thread Size1 A 1 Max Plunger Height Dimension “B” Max Plunger Diameter (“C”) in. mm in. mm 8.4 0.33 16.3 0.64 8.1 11.9 0.469 18.3 0.72 10.72 0.469 15.9 0.625 10.72 0.422 mm in. M10 X 1 15.47 0.62 M11 X 1 15.47 0.62 M12 X 1 18.64 0.47 11.9 C Aluminum insert Max Boot Height (“A”) mm Figures C & D Color1 APM Cat. No. Fig. 0.32 Black C1221/21 D 0.422 Clear C1221/27 D Black NC3030H-M12-1 C in. “Clear” allows viewing of breaker amp rating and trip state; please enquire for other available colors. B IP66/IP68/NEMA 6P Enclosure Protection ROTARY SHAFT SEALS Seal the shaft and mounting hole of standard rotary switches/potentiometers that use a threaded stem and nut mounting. Fig. E Thread Size Shaft Size1 (“A”) mm in. Height (“B”) mm Flat (“C”) in. mm in. Figure E Color2 APM Cat. No. M7 X 0.75 5.0 0.2 5.5 0.2 12.7 0.500 Gray 1332/39-2* M9 X 0.75 6.35 0.250 5.56 0.219 12.7 0.500 Gray C1332/41* M10 X 1 6.0 0.236 5.9 0.236 12.7 0.500 Gray 1332/45* Switch/potentiometer shaft must have a smooth, round cross-section where it meets the sealing edge of the shaft seal device. 2 Please enquire for other available colors. 1 IP66/IP68/NEMA 6P Enclosure Protection www.apmhexseal.com 20 800.498.9034
N5040 2
1. 物料型号:文档中列出了多种型号的密封靴(Sealing Boots),包括HEXSEAL®和E-SEEL®,它们是用于按钮式开关的保护装置。
2. 器件简介:这些密封靴由高撕裂强度的硅橡胶制成,并与内置的安装螺母(或其他特定环境下的材料)结合。它们封闭了突出的开关布什的底座,并在前面板表面上形成了防水和防尘的密封。
3. 引脚分配:文档中没有明确提到引脚分配,但提供了安装螺母的尺寸和规格。
4. 参数特性: - 材料:硅橡胶符合A-A-59588标准,Class 3B, Grade 50,除非另有规定。 - 安装螺母:HEXSEALS为镀镍黄铜,E-SEELS为黑色氧化黄铜。 - 温度范围:HEXSEALS为-94°F至+400°F(-70°C至+204°C),E-SEELS为-80°F至+400°F(-62°C至+204°C)。 - 外壳保护:符合NEMA、UL、ULC的多种类型,以及IEC的IP66/IP68标准。 - 压力范围:超过15 psi内部和1500 psi外部。 - 操作寿命:至少100,000次动作。 - 保质期:超过25年。 - 耐性:耐盐雾、阳光、臭氧、天气、真菌以及大多数酸和润滑油。
5. 功能详解:密封靴设计为单件式,带有模制的安装螺母和面板密封肋,可以消除对O型圈的需求。
6. 应用信息:这些密封靴适用于多种环境,包括军事规格MIL-DTL-5423,并且被UL和ULC认可为UL Std. 50的组件。
7. 封装信息:文档提供了详细的安装说明和不同尺寸的密封靴的型号、颜色和军事部件编号。
N5040 2 价格&库存
很抱歉,暂时无法提供与“N5040 2”相匹配的价格&库存,您可以联系我们找货
