1SMB5913B THRU 1SMB5957B
1.5 AMP SURFACE MOUNT SILICON RECTIFIERS
Silicon Planar Zener Diodes
PINNING
PIN
FEATURES
• Total power dissipation: Max. 1.5 W.
• Wide zener reverse voltage range 3.3V to 240V.
• Small plastic package suitable for surface mounted design.
MECHANICAL DATA
• Case: SMB
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 0.055g / 0.002oz
DESCRIPTION
1
Cathode
2
Anode
1
2
Top View
Simplified outline SMB and symbol
Absolute Maximum Ratings And Characteristics (Ta = 25 °C)
Symbol
Value
Unit
Power Dissipation at T L =75°C
PD
1.5
W
Forward Voltage at I F = 200 mA
VF
1.5
V
Junction Temperature Range
TJ
- 55 to + 150
°C
Storage Temperature Range
TS
- 55 to + 150
°C
Parameter
Fig.1 Maximum Continuous Power Derating
1.8
Power Dissipation ( W )
1.5
1.2
0.9
0.6
0.3
P.C.B. mounted with 1.0 X 1.0"
(2.54 X 2.54 cm) copper pad areas.
0.0
25
50
75
100
125
150
175
T C ,C ase Temperature (°C)
REV 1.0 2017 JAN
PAGE:1/3
Characteristics at T a = 25°C
Dynamic
Impedance
Zener Voltage Range(note2)
Type
Marking
(note1)
(note1)
1SMB5913B
V ZT(at I ZT)
Reverse Current
at I ZT
Z ZT(at I ZT)
IR
at V R
Admissible
Zener Current
Min(V)
Nom(V)
Max(V)
(mA)
Max (Ω)
Max(μA)
(V)
I ZM (mA)
913B
3.13
3.3
3.47
113.6
10
100
1
454
3.78
104.2
9.0
75
1
416
1SMB5914B
914B
3.42
3.6
1SMB5915B
915B
3.70
3.9
4.10
96.1
7.5
25
1
384
1SMB5916B
916B
4.08
4.3
4.52
87.2
6.0
5
1
348
1SMB5917B
917B
4.46
4.7
4.94
79.8
5.0
5
1.5
319
1SMB5918B
918B
4.84
5.1
5.36
73.5
4.0
5
2
294
1SMB5919B
919B
5.32
5.6
5.88
66.9
2.0
5
3
267
1SMB5920B
920B
5.89
6.2
6.51
60.5
2.0
5
4
241
1SMB5921B
921B
6.46
6.8
7.14
55
2.5
5
5.2
220
1SMB5922B
922B
7.12
7.5
7.88
50
3.0
5
6
200
1SMB5923B
923B
7.79
8.2
8.61
45.7
3.5
5
6.5
182
1SMB5924B
924B
8.60
9.1
9.56
41.2
4.0
5
7
164
10
10.5
37.5
4.5
5
8
150
1SMB5925B
925B
9.50
1SMB5926B
926B
10.4
11
11.6
34
5.5
1
8.4
136
1SMB5927B
927B
11.4
12
12.6
31.2
6.5
1
9
125
1SMB5928B
928B
12.35
13
14.1
28.8
7.0
1
9.9
115
1SMB5929B
929B
13.8
15
15.8
25
9.0
1
11.4
100
1SMB5930B
930B
15.2
16
16.8
23.4
10
1
12.2
93
1SMB5931B
931B
16.8
18
19.2
21
12
1
13.7
83
1SMB5932B
932B
19.0
19
14
1
15.2
75
1SMB5933B
933B
20.8
22
23.3
17
18
1
16.7
68
1SMB5934B
934B
22.8
24
25.2
16
19
1
18.2
62
1SMB5935B
935B
25.3
27
28.9
14
23
1
20.6
55
1SMB5936B
936B
28.2
30
32.0
12.5
26
1
23
50
1SMB5937B
937B
31.3
33
34.9
11.4
33
1
25
45
1SMB5938B
938B
34.2
36
37.9
10.4
38
1
27
41
1SMB5939B
939B
37.2
39
41.5
9.6
45
1
30
38
1SMB5940B
940B
40.9
43
45.6
8.7
53
1
33
34
1SMB5941B
941B
44.9
47
49.8
8.0
67
1
36
31
1SMB5942B
942B
48.6
51
54.0
7.3
70
1
39
29
1SMB5943B
943B
53.6
56
58.8
6.7
86
1
42
26
1SMB5944B
944B
58.9
62
65.6
6.0
100
1
47
24
1SMB5945B
945B
64.6
68
71.7
5.5
120
1
52
22
1SMB5946B
946B
71.2
75
78.8
5.0
140
1
57
1SMB5947B
947B
77.9
82
87.0
4.6
160
1
62
18
1SMB5948B
948B
86.0
91
96.0
4.1
200
1
69
16
1SMB5949B
949B
95.0
100
105
3.7
250
1
76
15
1SMB5950B
950B
104
110
116
3.4
300
1
84
13
1SMB5951B
951B
114
120
127
3.1
380
1
91
12
1SMB5952B
952B
125
130
142
2.9
450
1
100
11
1SMB5953B
953B
140
150
157
2.5
600
1
114
10
1SMB5954B
954B
152
160
168
2.3
700
1
121.6
9.0
1SMB5955B
955B
168
180
189
2.1
900
1
136.8
8.0
1SMB5956B
956B
189
200
211
1.9
1200
1
152
7.0
1SMB5957B
957B
228
240
252
1.5
1600
1
182.4
6.0
(1)Suffix “A” indicates ±10% tolerance, Suffix “B” indicates ±5% tolerance
(2)V ZT is tested with pulses (20 ms)
REV 1.0 2017 JAN
PAGE:2/3
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
A
A
SMB
c
a
VM
e
A
HE
g
e
E
A
D
E
HE
c
e
g
max
2.2
4.5
2.7
5.2
0.31
1.6
1.5
min
1.9
4.0
2.3
4.7
0.15
1.3
0.9
max
87
181
106
205
12
63
59
min
75
157
91
185
6
51
35
UNIT
mm
mil
g
e
A
D
a
0.3
12
The recommended mounting pad size
2.2
(86)
2.4
(94)
2.8
(110)
2.4
(94)
mm
Unit :
(mil)
REV 1.0 2017 JAN
PAGE:3/3
很抱歉,暂时无法提供与“1SMB5914B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.45706
- 100+0.37736
- 300+0.33750
- 3000+0.28556
- 6000+0.26169
- 12000+0.24970
