SK54U
SK54U
    DY(迪一电子)
    SMB(DO-214AA)
    肖特基二极管 SMB Vrrm=40V If=5A Ifsm=110A Vfm=500mV Cj=12pF
SK54U 数据手册
SK52U THRU SK525U 5.0 AMP SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS Features SMB/DO-214AA ·Low Power Loss,High Efficiency · Ideally Suited for Automatic Assembly 0.154(3.90) 0.130(3.30) 0.083(2.11) 0.075(1.91) · For Use in Low Voltage Application · Plastic Case Material has UL Flammability Classification Rating 94V-0 Mechanical Data 0.187(4.75) 0.163(4.15) · Case: Molded plastic SMB 0.012(0.300) 0.004(0.100) · Terminals: Plated leads solderable per MIL-STD-750,Method 2026 guaranteed 0.096(2.44) 0.084(2.13) · Polarity: Color band dentes cathode end · Mounting Position: Any 0.057(1.45) 0.033(0.85) · Making: Type Number 0.008(0.20) 0.004(0.10) 0.010(0.25) 0.004(0.1) 0.217(5.50) 0.197(5.00) Dimensions in inches and (millimeters) Maximum Ratings and Electrical Characteristics Rating at 25℃ ambient temperature unless otherwise specified Single phase,half wave,60Hz,resistive or inductive load For capacitive load derate current by 20% Type Number Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage SK SK SK SK SK SK SK SK SK SK SK SYMBOL 52U 53U 54U 545U 55U 56U 58UI510U 515U 520U 525U Unit 20 30 40 45 50 60 80 100 150 200 250 V VRRM 14 21 28 31 35 42 56 70 105 140 175 V VRMS 20 30 40 45 50 60 80 100 150 200 250 Maximum DC Blocking Voltage VDC Average Rectified Output Current @TL =100℃ IF(AV) 5.0 A Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 110 A Forward Voltage VFM @IF=5.0A (Note 1) Peak Reverse Current @TA =25 ℃ At Rated DC Blocking Voltage @TA =100 ℃ 2 0.5 IR 2 0.67 0.8 0.9 0.1 0.05 10 5 0.92 V V mA A2s I t Rating for fusing (t
SK54U 价格&库存
很抱歉,暂时无法提供与“SK54U”相匹配的价格&库存,您可以联系我们找货
