Technical Data ELX1045
Effective June 2021
PTSAHT1206
Automotive high temperature SMD PTC fuses
Applications
• Infotainment
• In-vehicle navigation
• Telematics
• Car lighting
• Power window and seat control
• Instrument clusters
• PCB trace protection
Environmental compliance
Product features
• AEC-Q200 qualified
HALOGEN
Pb HF
FREE
• Positive temperature coefficient (PTC)
• Surface mount resettable fuse
• Compact 1206 (3216 metric) footprint
• High temperature
• Voltage rating 16 V to 30 V
• Current rating from 0.16 A to 0.50 A
• Fast time-to-trip
Part number system/ordering:
PTSAHT120630V016
• PT= PTC resettable fuse
• S= Surface mount
• AHT= Automotive with high operating temperature
• 1206= Dimension code
• 30V= Maximum voltage
• 016= Ihold current rating (016= 0.16 A)
PTSAHT1206
Effective June 2021
Product specifications
Vmax1
lmax2
lhold3
ltrip4
Pd5
Time-to-trip
(maximum)
Resistance6
Part number
(Vdc)
(A)
(A)
(A)
typical
(W)
(A)
(seconds)
Initial (Ri)
minimum (Ω)
Post trip (R1)
maximum
(Ω)
Part
marking
PTSAHT120630V016
30
0.80
0.90
8.00
0.10
0.70
6.00
01H
PTSAHT120616V035
16
50
0.35
0.95
1.00
3.50
0.20
0.20
1.60
03H
PTSAHT120630V035
30
1.75
1.20
8.00
0.10
0.20
2.20
03H
PTSAHT120624V050
24
2.50
1.70
8.00
0.10
0.20
1.60
05H
1.
2.
3.
4.
Vmax: Maximum continuous voltage the device can withstand without damage at rated current
Imax: Maximum fault current the device can withstand without damage at rated voltage
Ihold: Maximum current the device will pass without interruption at +23 °C still air
Itrip: Minimum current that will transition the device from low resistance to high resistance at
+23 °C still air
5. Pd: Power dissipated from the device when in tripped state at +23 °C still air
6. Ri: Minimum resistance of the device at +23 °C
R1: Maximum resistance of the device one hour after tripping at +23 °C
Dimensions–mm
Recommended pad layout
Part number
A typ
A max
B typ
B max
C typ
C max
D min
E min
F
G
H
PTSAHT120630V016
PTSAHT120616V035
PTSAHT120630V035
PTSAHT120624V050
3.35
3.35
3.35
3.35
3.50
3.50
3.50
3.50
1.70
1.70
1.70
1.70
1.80
1.80
1.80
1.80
0.60
0.65
1.05
1.05
0.89
1.14
1.46
1.46
0.25
0.25
0.25
0.25
0.076
0.076
0.076
0.076
1.8
1.8
1.8
1.8
1.0
1.0
1.0
1.0
1.8
1.8
1.8
1.8
Thermal derating chart - Ihold (A)
Part number
PTSAHT120630V016
PTSAHT120616V035
PTSAHT120630V035
PTSAHT120624V050
2
Maximum ambient temperature (°C)
-40
-20
40
50
60
70
85
125
0.25
0.54
0.51
0.73
0.21
0.48
0.46
0.66
0.19
0.43
0.41
0.58
0.16
0.35
0.35
0.50
0.14
0.32
0.31
0.45
0.13
0.29
0.29
0.42
0.12
0.26
0.26
0.39
0.11
0.24
0.24
0.35
0.09
0.20
0.20
0.31
0.05
0.10
0.10
0.17
www.eaton.com/electronics
PTSAHT1206
Effective June 2021
General specifications
Operating temperature: -40 °C to + 125 °C (with derating)
Storage temperature: -10 °C to + 40 °C
Storage relative humidity: ≤70%
Storage conditon: Keep away form corrosive atmosphere and sunlight
Passive aging: IEC60738-1 , +60 °C, 1000 hours, ± ≤ 20%
IEC60738-1 , +85 °C, 1000 hours, ± ≤ 20%
Humidity aging: +85 °C, 85% RH, 100 hours, ± ≤ 20%
Thermal shock: IEC60738-1, +125 °C/ -40 °C, 20 cycles, ≤ 50%
Trip cycle life: UL1434, Vmax, Imax, 100 cycles, no arcing or burning
Trip endurance: UL1434, Vmax, Itrip ≤ I ≤ Imax, 2 hours, no arcing or burning
MSL test: J-STD-020, MSL=1, pass and no visible damage
Packaging information
PTSAHT120616V035, PTSAHT120630V016
Supplied in tape and reel packaging, 4000 parts per 7.0” (178 mm) diameter reel (EIA-481 compliant)
PTSAHT120624V050, PTSAHT120630V035
Supplied in tape and reel packaging, 3000 parts per 7.0” (178 mm) diameter reel (EIA-481 compliant)
A
E1
P2
P0
D0
T
B
B
F
E2
D1
W
B0
A
P1
K0
SECTION A-A
A0
SECTION B-B
W
F
E1
E2
8.00 ± 0.30
3.50 ± 0.10
1.75 ± 0.10
P0
P1
P2
D0
4.00 ± 0.10 4.00 ± 0.10 2.00 ± 0.05 1.55 + 0.10/-0
D1
A0
B0
K0
1.77 ± 0.10 3.40 ± 0.10 1.04 ± 0.10
T
0.22 ± 0.05
3
PTSAHT1206
Effective June 2021
Solder reflow profile
Table 1 - Standard SnPb solder (Tc)
Package
thickness
Volume
mm3
很抱歉,暂时无法提供与“PTSAHT120616V035”相匹配的价格&库存,您可以联系我们找货
