PTSAHT120630V035
PTSAHT120630V035
    EATON(伊顿)
    PTC 自恢复保险丝 30V 350 mA Ih 表面贴装型 1206(3216 公制),凹陷
PTSAHT120630V035 数据手册
Technical Data ELX1045 Effective June 2021 PTSAHT1206 Automotive high temperature SMD PTC fuses Applications • Infotainment • In-vehicle navigation • Telematics • Car lighting • Power window and seat control • Instrument clusters • PCB trace protection Environmental compliance Product features • AEC-Q200 qualified HALOGEN Pb HF FREE • Positive temperature coefficient (PTC) • Surface mount resettable fuse • Compact 1206 (3216 metric) footprint • High temperature • Voltage rating 16 V to 30 V • Current rating from 0.16 A to 0.50 A • Fast time-to-trip Part number system/ordering: PTSAHT120630V016 • PT= PTC resettable fuse • S= Surface mount • AHT= Automotive with high operating temperature • 1206= Dimension code • 30V= Maximum voltage • 016= Ihold current rating (016= 0.16 A) PTSAHT1206 Automotive high temperature SMD PTC fuses  Technical Data ELX1045 Effective June 2021 Product specifications Vmax1 lmax2 lhold3 ltrip4 Pd5 Time-to-trip (maximum) Resistance6 Part number (Vdc) (A) (A) (A) typical (W) (A) (seconds) Initial (Ri) minimum (Ω) Post trip (R1) maximum (Ω) Part marking PTSAHT120630V016 30 20 0.16 0.80 0.90 8.00 0.10 0.70 6.00 01H PTSAHT120616V035 16 50 0.35 0.95 1.00 3.50 0.20 0.20 1.60 03H PTSAHT120630V035 30 20 0.35 1.75 1.20 8.00 0.10 0.20 2.20 03H PTSAHT120624V050 24 20 0.50 2.50 1.70 8.00 0.10 0.20 1.60 05H 1. 2. 3. 4. Vmax: Maximum continuous voltage the device can withstand without damage at rated current Imax: Maximum fault current the device can withstand without damage at rated voltage Ihold: Maximum current the device will pass without interruption at +23 °C still air Itrip: Minimum current that will transition the device from low resistance to high resistance at +23 °C still air 5. Pd: Power dissipated from the device when in tripped state at +23 °C still air 6. Ri: Minimum resistance of the device at +23 °C R1: Maximum resistance of the device one hour after tripping at +23 °C Dimensions–mm Recommended pad layout Part number A typ A max B typ B max C typ C max D min E min F G H PTSAHT120630V016 PTSAHT120616V035 PTSAHT120630V035 PTSAHT120624V050 3.35 3.35 3.35 3.35 3.50 3.50 3.50 3.50 1.70 1.70 1.70 1.70 1.80 1.80 1.80 1.80 0.60 0.65 1.05 1.05 0.89 1.14 1.46 1.46 0.25 0.25 0.25 0.25 0.076 0.076 0.076 0.076 1.8 1.8 1.8 1.8 1.0 1.0 1.0 1.0 1.8 1.8 1.8 1.8 Thermal derating chart - Ihold (A) Part number PTSAHT120630V016 PTSAHT120616V035 PTSAHT120630V035 PTSAHT120624V050 2 Maximum ambient temperature (°C) -40 -20 0 25 40 50 60 70 85 125 0.25 0.54 0.51 0.73 0.21 0.48 0.46 0.66 0.19 0.43 0.41 0.58 0.16 0.35 0.35 0.50 0.14 0.32 0.31 0.45 0.13 0.29 0.29 0.42 0.12 0.26 0.26 0.39 0.11 0.24 0.24 0.35 0.09 0.20 0.20 0.31 0.05 0.10 0.10 0.17 www.eaton.com/electronics Technical Data ELX1045 PTSAHT1206 Automotive high temperature SMD PTC fuses Effective June 2021  General specifications Operating temperature: -40 °C to + 125 °C (with derating) Storage temperature: -10 °C to + 40 °C Storage relative humidity: ≤70% Storage conditon: Keep away form corrosive atmosphere and sunlight Passive aging: IEC60738-1 , +60 °C, 1000 hours, ± ≤ 20% IEC60738-1 , +85 °C, 1000 hours, ± ≤ 20% Humidity aging: +85 °C, 85% RH, 100 hours, ± ≤ 20% Thermal shock: IEC60738-1, +125 °C/ -40 °C, 20 cycles, ≤ 50% Trip cycle life: UL1434, Vmax, Imax, 100 cycles, no arcing or burning Trip endurance: UL1434, Vmax, Itrip ≤ I ≤ Imax, 2 hours, no arcing or burning MSL test: J-STD-020, MSL=1, pass and no visible damage Packaging information PTSAHT120616V035, PTSAHT120630V016 Supplied in tape and reel packaging, 4000 parts per 7.0” (178 mm) diameter reel (EIA-481 compliant) PTSAHT120624V050, PTSAHT120630V035 Supplied in tape and reel packaging, 3000 parts per 7.0” (178 mm) diameter reel (EIA-481 compliant) A E1 P2 P0 D0 T B B F E2 D1 W B0 A P1 K0 SECTION A-A A0 SECTION B-B W F E1 E2 8.00 ± 0.30 3.50 ± 0.10 1.75 ± 0.10 - P0 P1 P2 D0 4.00 ± 0.10 4.00 ± 0.10 2.00 ± 0.05 1.55 + 0.10/-0 D1 - A0 B0 K0 1.77 ± 0.10 3.40 ± 0.10 1.04 ± 0.10 T 0.22 ± 0.05 www.eaton.com/electronics 3 PTSAHT1206 Automotive high temperature SMD PTC fuses  Technical Data ELX1045 Effective June 2021 Solder reflow profile Table 1 - Standard SnPb solder (Tc) Package thickness Volume mm3
PTSAHT120630V035 价格&库存
很抱歉,暂时无法提供与“PTSAHT120630V035”相匹配的价格&库存,您可以联系我们找货
PTSAHT120630V035
    • 1+5.11920
    • 10+4.14720
    • 30+3.66120
    库存:3
    PTSAHT120630V035
    • 1+5.195581+0.67462
    • 5+4.297005+0.55795
    • 10+3.9616310+0.51440
    • 50+3.2840850+0.42642
    • 100+3.03047100+0.39350
    • 250+2.72406250+0.35371
    • 500+2.51275500+0.32627
    • 1000+2.317111000+0.30087
    库存:1303
