SOT-23 Plastic-Encapsulate MOSFETs
2N7002K
MOSFET(N-Channel)
V(BR)DSS
SOT-23
ID
RDS(on)MAX
3
2Ω@10V
60 V
300mA
2.8 Ω@4.5V
1. GATE
2. SOURCE 3
1
2
. DRAIN
FEATURE
z
High density cell design for Low RDS(on)
z
Voltage controlled small signal switch
z
Rugged and reliable
z
High saturation current capability
z
ESD protected
APPLICATION
z Load Switch for Portable Devices
z DC/DC Converter
M$5.,1*
Equivalent circuit
7002/702*
MOSFET MAXIMUM RATINGS (Ta = 25°C unless otherwise noted)
Parameter
Symbol
VDS
VGS
Value
Drain-Source voltage
Gate-Source voltage
Unit
60
V
±20
V
ID
Drain Current
300
mA
PD
Power Dissipation
0.35
W
TJ
Junction Temperature
150
Tstg
Storage Temperature
-55~+150
RθJA
Thermal Resistance fromJunction to Ambient
1/4
357
℃ /W
www.realchip.net
2N7002K
MOSFET ELECTRICAL CHARACTERISTICS
Ta =25 ℃ unless otherwise specified
Parameter
Symbol
Test Condition
Min
Typ
Max
Units
Static Characteristics
Drain-Source Breakdown Voltage
Gate Threshold Voltage*
Zero Gate Voltage Drain Current
Gate –Source leakage current
Drain-Source On-Resistance*
VDS
VGS = 0V, ID =250µA
60
VGS(th)
VDS =VGS, ID =1mA
1.1
IDSS
VDS =48V,VGS = 0V
IGSS1
V
2.1
V
1
µA
VGS =±20V, VDS = 0V
±10
µA
IGSS2
VGS =±10V, VDS = 0V
±200
nA
IGSS3
VGS =±5V, VDS = 0V
±100
nA
RDS(on)
1.6
VGS = 4.5V, ID =250mA
2
2.8
Ω
VGS =10V,ID =250mA
1.6
2
Ω
1.2
V
Diode Forward Voltage
VSD
VGS=0V, IS=100mA
Recovered charge
Qr
VGS=0V,IS=300mA,VR=25V,
dls/dt=-100A/µS
30
nC
Dynamic Characteristics**
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
VDS =10V,VGS =0V,f =1MHz
40
pF
30
pF
10
pF
10
ns
15
ns
Switching Characteristics**
Turn-On Delay Time
td(on)
Turn-Off Delay Time
td(off)
Reverse recovery Time
trr
VGS=10V,VDD=50V,RG=50Ω,
RGS=50Ω, RL=250Ω
dls/dt=-100A/µS
30
ns
GATE-SOURCE ZENER DIODE
Gate-Source Breakdown Voltage
BVGSO
Igs=±1mA (Open Drain)
±21.5
±30
V
Notes :
*Pulse Test : Pulse Width ≤300µs, Duty Cycle ≤2%.
**These parameters have no way to verify.
2/4
www.realchip.net
2N7002K
Typical Characteristics
Output Characteristics
Transfer Characteristics
1.2
1.2
Ta=25℃
VDS=3V
VGS=5V,6V,7V,10V
Pulsed
Pulsed
(A)
(A)
VGS=4V
DRAIN CURRENT
DRAIN CURRENT
ID
ID
0.8
VGS=3V
0.4
0.0
0.8
Ta=100℃
Ta=25℃
0.4
0.0
2
3
4
DRAIN TO SOURCE VOLTAGE
VDS
5
4
8
6
GATE TO SOURCE VOLTAGE
(V)
VGS
(V)
RDS(ON) —— VGS
RDS(ON) —— ID
10
5
Ta=25℃
Ta=25℃
Pulsed
Pulsed
8
RDS(ON)
3
ON-RESISTANCE
ON-RESISTANCE
RDS(ON)
4
2
VGS=4.5V
ID=500mA
6
4
2
1
VGS=10V
900
DRAIN CURRENT
ID
1200
1500
(mA)
2
4
8
VGS
10
(V)
Threshold Voltage
IS —— VSD
2
1
6
1.8
Pulsed
VTH
0.1
Ta=100℃
THRESHOLD VOLTAGE
SOURCE CURRENT
IS (A)
(V)
1.6
Ta=25℃
0.01
1.4
ID=250uA
1.2
1.0
0.8
0.6
1E-3
0.0
0.2
0.4
0.6
0.8
1.0
SOURCE TO DRAIN VOLTAGE
1.2
1.4
0.4
25
1.6
VSD (V)
50
75
JUNCTION TEMPERATURE
3/4
100
Tj
125
www.realchip.net
2N7002K
SOT-23 Package Outline Dimensions
Symbol
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
θ
Dimensions In Millimeters
Min
Max
0.900
1.150
0.000
0.100
0.900
1.050
0.300
0.500
0.080
0.150
2.800
3.000
1.200
1.400
2.250
2.550
0.950 TYP
1.800
2.000
0.550 REF
0.300
0.500
0°
8°
Dimensions In Inches
Min
Max
0.035
0.045
0.000
0.004
0.035
0.041
0.012
0.020
0.003
0.006
0.110
0.118
0.047
0.055
0.089
0.100
0.037 TYP
0.071
0.079
0.022 REF
0.012
0.020
0°
8°
SOT-23 Suggested Pad Layout
4/4
www.realchip.net
很抱歉,暂时无法提供与“2N7002K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.07614
- 500+0.05940
- 3000+0.05001
- 6000+0.04439
