932157100
    BELDEN
    圆形电缆组件 16.00 x 23.00mm 50V 6A 黑色
932157100 数据手册
Product: G 4 W 1 F black G-Series Power Field Attachable Connector: Female, angled, 4-pin, black body, solder type; 50V AC/DC, 6 A Product Description G-Series Power Field Attachable Connector: Female, angled, 4-pin, black body, solder type; 50V AC/DC, 6 A Technical Drawing Technical Specifications Technical Data Product Family: Power Connector Product Sub Family: G Series Brand: Hirschmann Connector Type: Field Attachable Type of Contact / Gender: female Connector Design: angled Number of Pins: 4 Shielding: Unshielded Attachment Type: Central Screw Rated Voltage: 50V AC/DC Rated Impulse Voltage: 1.5 kV Operating Voltage: 50 V AC/DC Rated Current*: 6A Contact Resistance: ≤ 10 mOhm Mating Cycles: ≤ 50 Type of Connection: solder Cable Gland: PG 7 Conductor Cross Section: max. 0.50 mm² Suitable Cables: Ø3.5 mm - Ø6 mm Ambient Temperature (Operation)*: -40°C to +90°C Protection Degree / IP Rating**: IP65 Design Standard: DIN EN 61984 (VDE 0627) Pollution Degree: 3 acc. to DIN EN 60664-1 (VDE 0110-1) Clearance / Creepage Distance: DIN EN 60664-1 (2008/01); VDE 0110-1 Materials Contact Base Material: CuZn Contact Plating: Cu/Sn Contact Bearer Material: PA GF Contact Bearer Color: black Flammability Class (Contact Bearer): UL 94 HB Housing Material: PA GF Housing Color: black Flammability Class (Housing): UL 94 HB Cable Gland Material: PA GF Cable Gland Color: black Flammability Class (Cable Gland): UL 94 HB Attachment Material: 4.8 , Fe/Zn B Gasket Material: NBR Additional Technical Data Fastening Torque (Cable Gland): PG 7:(150-250) Ncm Fastening Torque (Attachment): M 3: (50-60) Ncm Mating Connectors / Fitting to: G 4 E 1 M…, G 4 A 1 M…., G 4 A 5 M… Accessories to Order Separately: Central Screw Stainless Steel: 732750003 Approvals VDE: VDE-Reg.-Nr.: 3113 Safety & Environmental Compliance RoHS Compliant: yes Notes Note Derating: Notice derating Protection Degree / IP Rating Note: ** only if mounted and locked in combination with Hirschmann / Lumberg Automation connector. Note: Do not connect or disconnect under load. Variants Item # Item Description 932157100 G 4 W 1 F black © 2023 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
932157100 价格&库存
很抱歉,暂时无法提供与“932157100”相匹配的价格&库存,您可以联系我们找货
