Approval sheet
RFLPF Series – 1005(0402)- RoHS Compliance
MULTILAYER CERAMIC LOW PASS FILTER
Halogens Free Product
1695 ~ 2180 MHz Working Frequency
P/N: RFLPF1005040F0T
*Contents in this sheet are subject to change without prior notice.
Page 1 of 7
ASC_ RFLPF1005040F0T_V04
Feb. 2019
Approval sheet
FEATURES
3
1.
Miniature footprint: 1.0 X 0.5 X 0.4 mm .
2.
Low Profile Thickness
3.
Low Insertion loss
4.
LTCC process
APPLICATIONS
1.
1695~2180 MHz Working Frequency.
CONSTRUCTION
Top view
P6
P1
P5
P2
P4
P3
PIN
Connection
1
*NC
2
GND
3
*NC
4
I/O port
5
GND
6
I/O port
*NC:No connect.
DIMENSIONS
Figure
Symbol
Dimension (mm)
L
1.00 ± 0.10
W
0.50 ± 0.10
T
0.50 max.
A
0.18 ± 0.05
B
0.18 ± 0.05
C
0.05 ± 0.05
D
0.125 ± 0.05
E
0.15 ± 0.05
F
0.05 ± 0.05
Top view
Side view
Side view
Bottom view
Page 2 of 7
Feb. 2019
Approval sheet
ELECTRICAL CHARACTERISTICS
RFLPF1005040F0T
Specification
Frequency Range
1695 ~ 2180 MHz
0.6 dB max. at 25 °C
Insertion Loss
0.8 dB max. at – 40 ~ + 85 °C
20 dB min. @ 3350 ~ 4360 MHz
Attenuation
45 dB min. @ 5085 ~ 6540 MHz
Return Loss
10 dB min.
Characteristics Impedance
50 Ω
Moisture sensitivity levels
LEVEL 1 (Refer to : IPC/JEDEC J-STD-020)
Operating & Storage Condition (Component)
Operation Temperature Range: -40 ~ +85 ℃
Storage Temperature Range: -40 ~ +85 ℃
Storage Condition before Soldering (Included packaging material)
Storage Temperature Range: +5 ~ +40 ℃
Humidity: 30 to 70% relative humidity
Typical Electrical Chart
LAND PATTERN
Figure
*Don’t connect NC pin (pin1 and pin3) to I/O or GND.
Unit : mm
Line width to be designed to match 50 Ω characteristic impedance, depending on PCB material and thickness.
Page 3 of 7
Feb. 2019
Approval sheet
RELIABILITY TEST
Test condition / Test method
Test item
Specification
Solderability
*Solder bath temperature:235 5C
At least 95% of a surface of each terminal
JIS C 0050-4.6
*Immersion time:2 0.5 sec
electrode must be covered by fresh solder.
JESD22-B102D
Resistance to soldering
Solder:Sn3Ag0.5Cu for lead-free
*Preheating temperature:120~150C,
No mechanical damage.
heat
JIS C 0050-5.4
1 minute.
Electrical specification shall satisfy the
*Solder temperature:2705C
descriptions in electrical characteristics under
the operational temperature range within -40
*Immersion time:101 sec
~ 85°C.
Measurement to be made after keeping at
Loss of metallization on the edges of each
electrode shall not exceed 25%.
room temperature for 242 hrs
Drop Test
*Height:75 cm
*Test Surface:Rigid surface of concrete or
JIS C 0044
Customer’s specification.
steel.
*Times:6 surfaces for each units;2 times
for each side.
Vibration
JIS C 0040
~ 85°C.
*Frequency:10Hz~55Hz~10Hz(1min)
*Total amplitude:1.5mm
*Test times:6hrs.(Two hrs each in three
mutually perpendicular directions)
~ 85°C.
Adhesive Strength
of Termination
JIS C 0051- 7.4.3
*Pressurizing force:
5N (LGA terminal series);5N(≦0603);
No remarkable damage or removal of the
termination.
10N(>0603)
*Test time:10±1 sec
Bending test
JIS C 0051- 7.4.1
The middle part of substrate shall be
pressurized by means of the pressurizing rod Electrical specification shall satisfy the
at a rate of about 1 mm/s per second until the descriptions in electrical characteristics under
deflection becomes 1mm/s and then pressure the operational temperature range within -40
shall be maintained for 51 sec.
~ 85°C.
room temperature for 242 hours
Page 4 of 7
Feb. 2019
Approval sheet
Temperature cycle
JIS C 0025
1.
303 minutes at -40C3C,
2.
10~15 minutes at room temperature,
3.
303 minutes at +85C3C,
4.
under the operational temperature range
within -40 ~ 85°C.
Total 100 continuous cycles
High temperature
JIS C 0021
*Temperature:85C2C
*Test duration:1000+24/-0 hours
~ 85°C.
Humidity
(steady conditions)
*Humidity:90% to 95% R.H.
*Temperature:402C
JIS C 0022
*Time:1000+24/-0 hrs.
~ 85°C.
※ 500hrs measuring the first data then
1000hrs data
Low temperature
JIS C 0020
*Temperature:-40C2C
~ 85°C.
Page 5 of 7
Feb. 2019
Approval sheet
SOLDERING CONDITION
Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 2,
Fig 2. Infrared soldering profile
ORDERING CODE
RF
LPF
100504
Walsin
Product Code
Dimension code
RF device
LPF :
Per 2 digits of
Length, Width
Low Pass Filter
F
Unit of
dimension
T
Application
Specification
Packing
F: 1695~2180 MHz
Design Code
T : Reeled
0 : 0.1 mm
e.g:100504:
1 : 1.0 mm
L=1.0mm,
W= 0.5mm,
T= 0.4mm.
Minimum Ordering Quantity: 4000 pcs per reel.
PACKAGING
Paper Tape specifications (unit :mm)
Index
Ao
Bo
D
T
W
Dimension (mm)
0.67 0.10
1.14 0.10
1.55 + 0.05
0.42 ± 0.10
8.0 0.10
Index
E
F
Po
P1
P2
Dimension (mm)
1.75 0.10
3.50 0.05
4.00 0.10
4.00 0.10
2.00 0.05
Page 6 of 7
Feb. 2019
Approval sheet
Reel dimensions
C
Index
Dimension (mm)
A
Φ178.0
B
Φ60.0
A
B
C
Φ13.0
Taping Quantity:4000 pieces per 7” reel
CAUTION OF HANDLING
Limitation of Applications
Please contact us before using our products for the applications listed below which require especially high reliability for the
prevention of defects, which might directly cause damage to the third party’s life, body or property.
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(8)
Aircraft equipment
Aerospace equipment
Undersea equipment
Medical equipment
Disaster prevention / crime prevention equipment
Traffic signal equipment
Transportation equipment (vehicles, trains, ships, etc.)
Applications of similar complexity and /or reliability requirements to the applications listed in the above.
Storage condition
(1)
Products should be used in 6 months from the day of WALSIN outgoing inspection.
(2)
Storage environment condition.
Page 7 of 7
Products should be storage in the warehouse on the following conditions.
Temperature
: +5 to +40℃
Humidity
Don’t keep products in corrosive gases such as sulfur. Chlorine gas or acid or it may cause oxidization of
electrode, resulting in poor solderability.
Products should be storage on the palette for the prevention of the influence from humidity, dust and son on.
Products should be storage in the warehouse without heat shock, vibration, direct sunlight and so on.
Products should be storage under the airtight packaged condition.
Feb. 2019
很抱歉,暂时无法提供与“RFLPF1005040F0T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2.113311+0.27342
- 10+1.7034610+0.22039
- 25+1.5711125+0.20327
- 50+1.4776150+0.19117
- 100+1.38934100+0.17975
- 250+1.28092250+0.16573
- 500+1.20465500+0.15586
- 1000+1.133071000+0.14660
- 国内价格 香港价格
- 4000+1.003254000+0.12980
- 8000+0.943738000+0.12210
- 12000+0.9105712000+0.11781
- 20000+0.8704320000+0.11262
- 28000+0.8449528000+0.10932
- 40000+0.8187540000+0.10593
