A1101R08C00GM
A1101R08C00GM
    TTM(迅达)
    BLGA24
    通用 ISM < 1GHz RF 收发器模块 868MHz 不含天线,U.FL 表面贴装型
A1101R08C00GM 数据手册
AP2 RF Transceiver Module FEATURES  2.4GHz worldwide ISM band  78 selectable RF channels (2403 to 2480MHz)  20mm x 20mm drop-in module  Ultra low power operation  Simple sync/async serial interface  Integrated F antenna  On board 32.768 kHz crystal oscillator  Broadcast, acknowledged, or burst data transmissions  ANT channel combined message rate up to 190Hz (8byte data payload)  Minimum message rate per ANT channel 0.5Hz  Burst transfer rate up to 20Kbps (true data throughput)  Up to 8 ANT channels  Up to 3 public, managed and/or private network keys  1 Mbps RF data rate, GFSK modulation  1.9V to 3.6V supply voltage range  -40°C to +85°C operating temperature  Pin compatible with ANT AP1 and AT3 modules  Radio regulatory approval for major markets  RoHS compliant FAMILY MEMBERS ANTAP281M4IB – 8 ANT channels; surface mount ANTAP281M5IB – 8 ANT channels; Molex connector ANT NETWORK CONFIGURATIONS PEER TO PEER BROADCAST ANT-FS (Secure Authenticated) SCANNING MODE STAR 14 15 n 16 13 1 12 2 11 3 10 4 Acknowledged Bidirectional 5 9 8 M 6 7 M M 1 12 1 12 1 12 2 11 2 11 2 11 3 10 3 10 3 10 4 9 4 9 4 9 5 8 5 8 6 7 6 7 8 ? PRACTICAL MESH Relay Sensor Hub D00001266 Rev1.8 SHARED CLUSTER SHARED UNI-DIRECTIONAL SHARED BI-DIRECTIONAL 6 7 AD-HOC AUTO SHARED 2 of 23 AP2 RF Transceiver Module, Rev 1.8 TABLE OF CONTENTS NOTICES AND RESTRICTED USE INFORMATION ············································································· 3 ANT™ OVERVIEW······················································································································· 4 1 ANT AP2 MODULE ·············································································································· 6 1.1 MODULE VERSION ····················································································································· 6 1.2 INTERFACE ····························································································································· 6 1.3 APPLICATION MCU CONNECTION ····································································································· 8 1.3.1 Async Mode·················································································································· 8 1.3.2 Byte Sync Mode············································································································· 9 1.3.3 Bit Sync Mode ·············································································································· 10 1.4 MOUNTING GUIDELINE ··············································································································· 10 1.5 REFLOW GUIDELINE ·················································································································· 10 1.6 PICK-N-PLACE ························································································································ 11 2 REGULATORY APPROVAL ·································································································· 12 2.1 UNITED STATES ······················································································································ 12 2.2 INDUSTRY CANADA COMPLIANCE ···································································································· 12 2.3 CE DECLARATION OF CONFORMITY·································································································· 13 2.4 JAPAN ································································································································· 13 2.5 AUSTRALIA & NEW ZEALAND ········································································································ 13 3 ELECTRICAL SPECIFICATIONS ··························································································· 14 4 MECHANICAL DRAWINGS ································································································· 19 5 TECHNICAL SUPPORT ······································································································· 23 5.1 ANT FORUM ·························································································································· 23 5.2 PUBLIC TECHNICAL REFERENCES ···································································································· 23 5.3 ANT DEVELOPER’S ZONE AND ANT+ ADOPTER ZONE ············································································· 23 5.4 ANT SOCIAL NETWORKS ············································································································· 23 dynastream.com thisisant.com AP2 RF Transceiver Module, Rev 1.8 3 of 23 Notices and Restricted Use Information Information contained in this document is provided only for your ("Customer" or “you”) convenience and may be superseded by updates. It is your responsibility to ensure that your application meets with your specifications. Dynastream Innovations Inc. ("DYNASTREAM" ) makes no representations or warranties of any kind whether express or implied, written or oral, statutory or otherwise, related to the information, including but not limited to its condition, quality, performance, merchantability or fitness for purpose. DYNASTREAM disclaims all liability arising from this information and its use. DYNASTREAM does not assume any responsibility for the use of the described ANT RF module (“the Module(s)”). Dynastream makes no representation with respect to the adequacy of the module in low-power wireless data communications applications or systems. Any Products using the Module must be designed so that a loss of communications due to radio interference or otherwise will not endanger either people or property, and will not cause the loss of valuable data. DYNASTREAM assumes no liability for the performance of products which are designed or created using the Modules. The Modules are not designed, intended, or authorized for use as components in systems intended for surgical implant into the body, or other applications intended to support or sustain life, or for any other application in which the failure of the Module could create a situation where personal injury or death may occur. If you use the Modules for such unintended and unauthorized applications, you do so at your own risk and you shall indemnify and hold DYNASTREAM and its officers, employees, subsidiaries, affiliates, and distributors harmless against all claims, costs, damages, and expenses, and reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized use, even if such claim alleges that DYNASTREAM was negligent regarding the design or manufacture of the Product. The information disclosed herein is the exclusive property of D YNASTREAM, and is not to be reproduced and/or distributed without the written consent of DYNASTREAM. No part of this publication may be reproduced or transmitted in any form or by any means including electronic storage, reproduction, execution or transmission without the prior written consent of DYNASTREAM. The recipient of this document by i ts retention and use agrees to respect the security status of the information contained herein. DYNASTREAM believes the information contained herein is correct and accurate at the time of its release. However, the information contained in this document is subject to change without notice and should not be construed as a commitment by DYNASTREAM unless such commitment is expressly given in a covering document. ©2012 Dynastream Innovations Inc. All Rights Reserved. ANT is a registered trade mark of Dynastream Innovations Inc. dynastream.com thisisant.com 4 of 23 AP2 RF Transceiver Module, Rev 1.8 ANT™ Overview ANT™ is a practical wireless sensor network protocol running on 2.4 GHz ISM band. Designed for ultra low power, ease of use, efficiency and scalability, ANT easily handles peer-to-peer, star, tree and practical mesh topologies. ANT provides reliable data communications, flexible and adaptive network operation and cross-talk immunity. The protocol stack of ANT is extremely compact, requiring minimal microcontroller resources and considerably reducing system costs. ANT provides carefree handling of the Physical, Network, and Transport OSI layers. In addition, it incorporates key low-level security features that form the foundation for user -defined, sophisticated, network-security implementations. ANT ensures adequate user control while considerably lightening computational burden in providing a simple yet effective wireless networking solution. Application / Presentation Layers Higher Level Security Network / Transport & Low Level Security Data Link Layer Physical Layer } } User Defined Implemented by ANT ANT supports public, managed and private network architectures with 2 32 uniquely addressable devices possible, ensuring that each device can be uniquely identified from each other in the same network. ANT is proven with an installed base of multimillion nodes in ultra low power sensor network applications in sport, fitness, home and industrial automation. The ANT solutions are available in chips, chipsets and modules to suit a wide variety of application needs. Incorporated in AP2 product family are several ANT core stack enhancements :  Background scanning  Continuous scanning mode  High density node support  Improved channel search  Channel ID management  Improved transmission power control  Frequency agility  Proximity acquisition The complete description of ANT message protocol is found in the document “ANT Message Proto col and Usage”. The serial interface details are provided in the document “Interfacing with ANT General Purpose Chipsets and Modules”. Both documents are available on www.thisisant.com. ANT+ and ANT+ Alliance ANT+ is the open application layer on the top of the ANT stack. It standardizes communications and facilitates interoperability between a wide array of personal sports, wellness and lifestyle monitoring devices. ANT+ defines device profiles that specify access, data formats, and channel parameters. dynastream.com thisisant.com AP2 RF Transceiver Module, Rev 1.8 5 of 23 The ANT+ Alliance is comprised of companies who have adopted the ANT+ promise of interoperability. The Alliance ensures standardized communication through optimized brand value and partnerships with other top tier companies and products. dynastream.com thisisant.com 6 of 23 1 AP2 RF Transceiver Module, Rev 1.8 ANT AP2 Module The ANT AP2 module is a drop-in module based on the reference design of nRF24AP2, a new generation of ANT system on chip family from Nordic Semiconductor. An F antenna is integrated on the small-sized 20mm by 20mm board. The module has been certified to comply with radio regulation or standards covering global markets include North America, Europe, Japan and Australia. The integrated module ease s the burden for application and system developers from extensive RF and antenna design, and regulatory compliance testing, allowing quicker time to market. Able to support 8 ANT channels, the module is ideal to build control or hub nodes of a wireless sensor network. AP2 modules are currently available in the following varieties. Module ANT chip Used Description ANTAP281M4IB nRF24AP28CHQ32 Surface mountable, 8 ANT channels, 20x20mm, industrial temperature range ANTAP281M5IB nRF24AP28CHQ32 With Molex connector, 8 ANT channels, 20x20mm, industrial temperature range Packaging Option - Tray: 20 modules on a tray 1.1 - Reel: 500 modules taped on a 13” reel Module version AP2 modules have gone through many versions to incorporate new features and correct known issues. Data consumption specification in this datasheet only applies to module version F and above. Please check the “AP2 module Revision History” for the feature upgrades, known issues with fixes or workarounds, as well as the current consumption data. AP281MxIB module revision is identified by the last character of a 6 character tracking code as indicated on the pictures below: 1.2 Interface The module may be connected to the user’s host controller using the 17 pin -out assignment (surface mount) style or the 20-pin Molex header connection style provided below : Surface Mount Pin Molex Header Pin Pin Name Async Mode Sync Mode Description 1 6 TEST TEST (Tie to GND) TEST (Tie to GND) Tie to Ground 2 10 RST RST RST Reset the device 3 1 V CC V CC V CC Power supply source 4 19 GND GND GND Power supply ground dynastream.com thisisant.com AP2 RF Transceiver Module, Rev 1.8 5 8 6 17 7 of 23 NC NC NC No connection Async -> Suspend control SUSPEND SUSPEND / SRDY SRDY Sync -> Serial port ready Async -> Sleep mode enable 7 15 SLEEP/ MRDY SLEEP MRDY Sync -> Message ready indication 8 13 NC 9 11 PORTSEL NC NC PORTSEL PORTSEL (Tie to GND) (Tie to V CC ) BR2 SCLK BR2/SCLK 10 No connection Asynchronous or synchronous port select Async -> Baud rate selection 7 Sync -> Clock output signal Async -> transmit data signal 11 4 TXD0/SOUT TXD0 SOUT Sync -> Data output 12 3 Async -> Receive data signal RXD0/SIN RXD0 SIN Sync -> Data input Async -> Baud rate selection 13 5 BR1/SFLOW BR1 SFLOW 14 9 BR3 BR3 Tie to GND Sync -> Bit or byte flow control select Async -> Baud rate selection Sync - > Not used, tie to ground 15 14 RESERVERD2 Tie to GND Tie to GND Reserved Pin, Tie to ground 16 12 RESERVERD1 Tie to GND Tie to GND Reserved Pin, Tie to ground 17 2 RTS/SEN RTS SEN Async -> Request to send Sync -> Serial enable signal 16,18,20 NC NC NC No connection The baud rate of the asynchronous communication is controlled by the speed select signals BR1, BR2 and BR3. The table below shows the relationship between the states of the speed select signals and the corresponding baud rates. BR3 BR2 BR1 Baud Rate 0 0 0 4800 0 1 0 19200 0 0 1 38400 0 1 1 50000 1 0 0 1200 dynastream.com thisisant.com 8 of 23 1.3 AP2 RF Transceiver Module, Rev 1.8 1 1 0 2400 1 0 1 9600 1 1 1 57600 Application MCU connection Please refer to “Interfacing with ANT General Purpose Chipsets and Modules ” and “nRF24AP2 Product Specification” section 5 “Host Interface”. The following sample designs show the proper electrical connectivity of an ANT AP2 module to an application microcontroller, using TI MSP430F1232 as example. 1.3.1 Async Mode Notes:  Module RXD and TXD connected directly to hardware USART of microcontroller.  Switches on baud rate selection pins (BR1, BR2 and BR3) are for ease of use only. They can be connected directly to the logic level of interest.  RTS can be connected to an interrupt pin for conve nience in some applications. (Interrupt pins located on Port 1&2 on the MSP430F1232) dynastream.com thisisant.com AP2 RF Transceiver Module, Rev 1.8 9 of 23 1.3.2 Byte Sync Mode Notes:  Module SOUT, SIN, and SCLK connected directly to hardware USART of microcontroller. S E N needs to be on an interrupt capable I/O pin on the microcontroller. (Interrupt pins located on  Port 1&2 on the MSP430F1232) dynastream.com thisisant.com 10 of 23 AP2 RF Transceiver Module, Rev 1.8 1.3.3 Bit Sync Mode Notes:  All interface signals are connected directly to I/O pins on the microcontroller.  SCLK and S E N need to be on an interrupt capable I/O pin on the microcontroller. (Interrupt pins located on Port 1&2 on the MSP430F1232) 1.4 Mounting Guideline Refer to the recommended footprint drawing in section 4. It is best to position the AP2 module so that the copper keepout area is on the edge or over hanging the edge of the mating PCB. If the copper keepout layer is completely within the boundaries of the PCB, the ground plane should not fully surround the copper keepout. If this is not possible, the copper keepout should be made much larger to prevent RF degradation. The ground plane is recommended to extend to the full size of the mating PCB, with the exception of the copper keepout. To connect to M5IB type of AP2 module, the mating socket is Molex 52991-0208. 1.5 Reflow Guideline AP281M4IB module is rated at moisture sensitive level 2 (MSL=2). To handle and Use these modules, please follow the standard IPC/JEDEC J-STD-033B.1, “Handling, Packing, Shipping and Use of Moisture/Reflow Sensitive Surface Mount Devices” . dynastream.com thisisant.com AP2 RF Transceiver Module, Rev 1.8 11 of 23 To reflow, it is recommended that the peak solder joint/pad temperatures NOT exceeding 240 ºC. If possible, pre-heat the assembly within the oven profile for ~30 seconds at ~150 ºC . Follow the solder paste manufacturer’s recommendations, especially regarding temperature ramp rate and the time above liquidus. 1.6 Pick-n-Place AP281M4IB module has the package option of 500 modules on a JEDEC standard 13” reel to facilitate machine pick and place. Please refer to section 4 for tape and reel dimensions. dynastream.com thisisant.com 12 of 23 2 AP2 RF Transceiver Module, Rev 1.8 Regulatory Approval The ANT AP2 module has received regulatory approvals in the United States (FCC), Canada (IC), Europe (ETSI), Japan (ARIB), Australia and New Zealand. Such approvals allow the user to place the module inside a finished product and, in usual case, not require regulatory testing for an intentional radiator, provided no changes or modifications are made to the module circuitry. This does not preclude the possibility that some other form of authorization or testing may be required for the finished product. Changes or modifications could void the user’s authority to operate the equipment. The end user must comply with all of the instructions provided by the Grantee, which indicate installation and/or operating conditions necessary for compliance. 2.1 United States The AP2 module has been tested and found to comply with Part 15 of the FCC interference limits for Class B devices. Operation is subject to the following two (2) conditions: 1) This device may not cause harmful interference and 2) This device must accept any interference received i ncluding interference that may cause undesired operation. This equipment generates, uses and can radiate radio frequency energy and may cause harmful interference to radio communications if not installed and used in accordance with the instructions. However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one of the following measures:  Reorient or relocate the receiving antenna.  Increase the separation between the equipment and the receiver.  Connect the equipment into an outlet that is on a different circuit from the re ceiver.  Consult the dealer or an experienced radio/TV technician for help. This product does not contain any user -serviceable parts. Unauthorized repairs or modifications could result in permanent damage to the equipment, and void your warranty and your a uthority to operate this device under Part 15 regulations. The AP2 module is labeled with its own FCC ID, O6R1695 (note: First Character is the letter O, not the # 0.) If the FCC ID is not visible when the module is installed inside another device, then the outside of the device into which the module is installed must also display a label referring to the enclosed module. This exterior label can use wording such as the following: “Contains Transmitter Module FCC ID: O6 R1695” or “Contains FCC ID: O6R1695”. Any similar wording that expresses the same meaning may be used. 2.2 Industry Canada Compliance This device complies with Industry Canada licence -exempt RSS standard(s). Operation is subject to the following two conditions: (1) this device may not cau se interference, and (2) this device must accept any interference, including interference that may cause undesired operation of the device. (Le présent appareil est conforme aux CNR d'Industrie Canada applicables aux appareils radio exempts de licence. L'exploitation est autorisée aux deux conditions suivantes : (1) l'appareil ne doit pas produire de brouillage, et (2) l'utilisateur de l'appareil doit accepter tout brouillage radioélectrique subi, même si le brouillage est susceptible d'en compromettre le fonctionnement.) To comply with Industry Canada regulations, it is required that product containing the AP2 module display a label referring to the enclosed module. This exterior label can use wording similar to the following: “Contains IC: 3797A-1695” This information shall be affixed in such a manner as not to be removable except by destruction or defacement. The size of the lettering shall be legible without the aid of magnification but is not required to be larger than 8-point font size. If the device is too small to meet this condition, the information can be included in the user manual upon agreement with Industry Canada. dynastream.com thisisant.com AP2 RF Transceiver Module, Rev 1.8 2.3 13 of 23 CE Declaration of Conformity The AP2 module is declared to be in conformance with the essential requirements and other relevant provisions of Directive 73/23/EEC and 1999/5/EC, as a low-powered unlicensed transmitter:  EN 60950-1:2006 Safety of Information Technology Equipment  EN 300 440-2 v1.1.1 Electromagnetic compatibility and Radio spectrum Matters (ERM); Short range devices 2.4 Japan The AP281M5IB module has been granted type certificate (certified number 003WWA090685) in accordance with the provisions of Article 38 -24, Paragraph 1 of the Radio Law, in the classification of Article 2-1-19. In a finished product, the RF module has to remain user-installable at any time; otherwise, such that the module is soldered on another board, the finished product will have to be re-certified. 2.5 Australia & New Zealand The AP2 module has been tested and found to comply with AS/NZS 4268:2003 , Radio equipment and systems – Short range devices. The ACMA/MED supplier code number is N 20233. dynastream.com thisisant.com 14 of 23 3 AP2 RF Transceiver Module, Rev 1.8 Electrical Specifications Absolute Maximum Ratings Voltage applied at V CC to V SS -0.3V to +3.6V Input voltage at any pin -0.3V to V CC + 0.3V; max +3.6V Operating temperature -40ºC to +85ºC Storage temperature -40ºC to +85ºC Note: Stress exceeding one or more of the above maximum ratings may cause permanent damage . Conditions: VCC = +3.0V, VSS = 0V, TA = - 40ºC to +85ºC Symbol Parameter (condition) Notes Min Typ. Max Units 3.0 3.6 V Operating conditions V CC Supply voltage 1.9 TA Operating temperature -40 +85 ºC Digital input pin VIH HIGH level input voltage 0.7V CC V CC V VIL LOW level input voltage V SS 0.3V CC V Digital output pin VOH HIGH level output voltage (I O H =-0.5mA) V CC 0.3 V CC V VOL LOW level output voltage (I O L =0.5mA) V SS 0.3 V 2403 2480 MHz General RF conditions fOP Operating frequency 1) PLL res PLL Programming resolution 1 MHz f XT AL Crystal frequency 16 MHz f Frequency deviation ±160 kHz R GFSK Air data rate in each burst on-air 1 Mbps F CHANNE L Non-overlapping channel spacing 1 MHz Transmitter operation P RF Maximum output power P RFC RF power control range P RFCR RF power accuracy PBW 20dB bandwidth for modulated carrier 2) 16 0 +4 dBm 18 20 dB ±4 dB 1100 kHz 950 dynastream.com thisisant.com AP2 RF Transceiver Module, Rev 1.8 15 of 23 Symbol Parameter (condition) P RF1. 1 P RF2. 1 Notes Min Typ. Max Units 1st adjacent channel transmit power 1MHz -20 dBc 2nd adjacent channel transmit power 2MHz -40 dBc Receiver operation RX MAX Maximum received signal at
A1101R08C00GM 价格&库存
很抱歉,暂时无法提供与“A1101R08C00GM”相匹配的价格&库存,您可以联系我们找货
A1101R08C00GM
  • 1+252.419911+32.78807
